Mesh Oriented datABase
(version 5.4.1)
beginner tutorial, example 1: Demonstrates constructing/saving a simple 2x2x2 hex mesh More...
Include dependency graph for mbex1.cpp:Go to the source code of this file.
Functions | |
| int | main () |
This example creates a 2x2x2 mesh (uniform grid) and writes it out to a VTK file and an H5M file. Each cell is of size 1x1x1 and is axis aligned. This example demonstrates how to manually create a mesh using the unstructured mesh interface. The mesh is then written out to file.
Definition in file mbex1.cpp.
| int main | ( | ) |
Definition at line 25 of file mbex1.cpp.
References moab::Core::create_element(), moab::Core::create_vertices(), ErrorCode, moab::Range::insert(), MB_CHK_SET_ERR, MBHEX, and moab::Core::write_file().
moab::ErrorCode rval;
// MOAB functionality is accessed through an instance of the
// moab::Interface class:
moab::Core mbcore;
// * Create the vertexes *
// We are going to create 27 vertexes which will be used to define 8
// hexahedron cells. First, we have to create an array to store the
// coordinates of each vertex.
const unsigned NUMVTX = 27; // The number of vertexes
const unsigned NUMHEX = 8; // The number of hexahedrons
// This double array stores the x, y, z coordinate of each vertex.
const double vertex_coords[3 * NUMVTX] = {
0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0,
0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1,
0, 0, 2, 1, 0, 2, 2, 0, 2, 0, 1, 2, 1, 1, 2, 2, 1, 2, 0, 2, 2, 1, 2, 2, 2, 2, 2 };
// Create the vertexes and store their entity handles in the
// vertex_handles range. In MOAB, entities are defined using Entity
// Handles (type moab::EntityHandle). An entity handle is a unique
// integer that is used to identify/refer to specific entities (such
// as vertexes, edges, hexahedrons, etc...) on the mesh. MOAB
// guarantees that when multiple entities are created at the same
// time, as in the create_vertices call below, that those entities
// get adjacent handles. Thus, the second of the 27 vertexes we are
// creating will have an entity handle that is 1 greater than the
// handle of the first vertex. A range (type moab::Range) is a
// container which stores entity handles. Of course, sets of handles
// can also be stored in vectors or arrays, but ranges are much more
// memory efficient, so use them when possible!
moab::Range vertex_handles;
rval = mbcore.create_vertices( vertex_coords, NUMVTX, vertex_handles );MB_CHK_SET_ERR( rval, "create_vertices failed" );
// You can print out a range to see what elements it contains:
std::cout << "Created 27 vertex entities:" << vertex_handles;
// * Create the Hexahedrons *
// The conn array stores the connectivity for each hex. It defines
// which 8 vertexes connect to define a single hexahedron. The loop
// below adds the handle of the first vertex (stored in
// first_vertex_handle) to conn thereby ensuring that the entries of
// conn are actual entity handles. This only works because MOAB
// guarantees that entities (such as our vertexes) created at once
// have adjacent entity handles.
moab::EntityHandle conn[NUMHEX][8] = { { 0, 1, 4, 3, 9, 10, 13, 12 }, { 1, 2, 5, 4, 10, 11, 14, 13 },
{ 3, 4, 7, 6, 12, 13, 16, 15 }, { 4, 5, 8, 7, 13, 14, 17, 16 },
{ 9, 10, 13, 12, 18, 19, 22, 21 }, { 10, 11, 14, 13, 19, 20, 23, 22 },
{ 12, 13, 16, 15, 21, 22, 25, 24 }, { 13, 14, 17, 16, 22, 23, 26, 25 } };
// Lets get the handle for the first vertex. Note that we can use
// the square brackets operator on ranges just like vectors or
// arrays:
moab::EntityHandle first_vertex_handle = vertex_handles[0];
for( unsigned i = 0; i < NUMHEX; ++i )
for( unsigned j = 0; j < 8; ++j )
// Add first_vertex_handle to each element of conn. This ensures
// that the handles are specified properly (i.e. when
// first_vertex_handle > 0)
conn[i][j] = conn[i][j] + first_vertex_handle;
// Now that the connectivity of each hex has been defined, we can
// create each hex using a call to the create_element method which
// gives back an entity handle for the hex that was created. We'll
// then insert that entity into a range:
moab::Range hexahedron_handles;
moab::EntityHandle element;
rval = mbcore.create_element( moab::MBHEX, conn[i], 8, element );MB_CHK_SET_ERR( rval, "create_element failed" );
hexahedron_handles.insert( element );
// Let's see what entities we just created:
std::cout << "Created HEX8 entities: " << hexahedron_handles;
// * Write Mesh to Files *
// Now that we've created this amazing mesh, we can write it out to
// a file. Since MOAB can write out to a variety of standard file
// formats, you can quickly visualize and manipulate your mesh using
// standard tools, such as VisIt.
// In these examples, we will stick to using the VTK file format
// because it is text based and will work whether or not you've got
// HDF5, NETCDF, etc... installed and is a fairly standard file
// format so a lot of tools work with it out of the box.
rval = mbcore.write_file( "mbex1.vtk" );MB_CHK_SET_ERR( rval, "write_file(mbex1.vtk) failed" );
return 0;
