Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef TAG_INFO_HPP 00002 #define TAG_INFO_HPP 00003 00004 #include "moab/Range.hpp" 00005 #include <string> 00006 00007 namespace moab 00008 { 00009 00010 class SequenceManager; 00011 class Range; 00012 class Error; 00013 00014 // ! stores information about a tag 00015 class TagInfo 00016 { 00017 public: 00018 //! constructor 00019 TagInfo() 00020 : mDefaultValue( NULL ), mMeshValue( NULL ), mDefaultValueSize( 0 ), mMeshValueSize( 0 ), mDataSize( 0 ), 00021 dataType( MB_TYPE_OPAQUE ) 00022 { 00023 } 00024 00025 //! constructor that takes all parameters 00026 TagInfo( const char* name, int size, DataType type, const void* default_value, int default_value_size ); 00027 00028 virtual ~TagInfo(); 00029 00030 /**\brief Remove/clear tag data for all entities 00031 * 00032 * Remove tag values from entities. 00033 * 00034 *\param tag_delete_pending If true, then release any global 00035 * data associated with the tag in preparation for deleting 00036 * the tag itself. 00037 * 00038 *\Note Invalidates tag if \c tag_delete_pending is true. The only 00039 * valid method that can be invoked that is is the destructor. 00040 * 00041 *\param seqman Pointer to mesh entity database 00042 */ 00043 virtual ErrorCode release_all_data( SequenceManager* seqman, Error* error_handler, bool tag_delete_pending ) = 0; 00044 00045 //! set the name of the tag 00046 void set_name( const std::string& name ) 00047 { 00048 mTagName = name; 00049 } 00050 00051 //! get the name of the tag 00052 const std::string& get_name() const 00053 { 00054 return mTagName; 00055 } 00056 00057 //! get length of default value 00058 int get_default_value_size() const 00059 { 00060 return mDefaultValueSize; 00061 } 00062 00063 //! get the default data 00064 const void* get_default_value() const 00065 { 00066 return mDefaultValue; 00067 } 00068 00069 //! compare the passed value to the default value. 00070 //! returns false if no default value. 00071 bool equals_default_value( const void* data, int size = -1 ) const; 00072 00073 inline DataType get_data_type() const 00074 { 00075 return dataType; 00076 } 00077 00078 //! get the size of the data in bytes 00079 int get_size() const 00080 { 00081 return mDataSize; 00082 } 00083 00084 //! Check if variable-length tag 00085 bool variable_length() const 00086 { 00087 return get_size() == MB_VARIABLE_LENGTH; 00088 } 00089 00090 static int size_from_data_type( DataType t ); 00091 00092 // Check that all lengths are valid multiples of the type size. 00093 // Returns true if all lengths are valid, false otherwise. 00094 bool check_valid_sizes( const int* sizes, int num_sizes ) const; 00095 00096 /**\return MB_VARIABLE_LENGTH_DATA If variable_length() && lengths is NULL 00097 * MB_INVALID_SIZE If variable_length() && lengths is not 00098 * NULL && any size is not a multiple of 00099 * type size. 00100 * MB_INVALID_SIZE If !variable_length() && lengths is not 00101 * NULL && any size is not the tag size. 00102 * MB_SUCCESS Otherwise. 00103 */ 00104 ErrorCode validate_lengths( Error* error_handler, const int* lengths, size_t num_lengths ) const; 00105 00106 virtual TagType get_storage_type() const = 0; 00107 00108 /**\brief Get tag value for passed entities 00109 * 00110 * Get tag values for specified entities. 00111 * 00112 *\Note Will fail for variable-length data. 00113 *\param seqman Pointer to mesh entity database 00114 *\param entities Entity handles for which to retrieve tag data 00115 *\param num_entities Length of \c entities array 00116 *\param data Pointer to memory in which to store consecutive tag values, 00117 * one for each passed entity. 00118 */ 00119 virtual ErrorCode get_data( const SequenceManager* seqman, 00120 Error* error_handler, 00121 const EntityHandle* entities, 00122 size_t num_entities, 00123 void* data ) const = 0; 00124 00125 /**\brief Get tag value for passed entities 00126 * 00127 * Get tag values for specified entities. 00128 * 00129 *\Note Will fail for variable-length data. 00130 *\param seqman Pointer to mesh entity database 00131 *\param entities Entity handles for which to retrieve tag data 00132 *\param data Pointer to memory in which to store consecutive tag values, 00133 * one for each passed entity. 00134 */ 00135 virtual ErrorCode get_data( const SequenceManager* seqman, 00136 Error* error_handler, 00137 const Range& entities, 00138 void* data ) const = 0; 00139 00140 /**\brief Get tag value for passed entities 00141 * 00142 * Get tag values for specified entities. 00143 * 00144 *\param seqman Pointer to mesh entity database 00145 *\param entities Entity handles for which to retrieve tag data 00146 *\param num_entities Length of \c entities array 00147 *\param data_ptrs Array of pointers to tag values, one pointer 00148 * for each passed entity. 00149 *\param data_lengths One value for each entity specifying the 00150 * length of the tag value for the corresponding 00151 * entity. 00152 */ 00153 virtual ErrorCode get_data( const SequenceManager* seqman, 00154 Error* error_handler, 00155 const EntityHandle* entities, 00156 size_t num_entities, 00157 const void** data_ptrs, 00158 int* data_lengths ) const = 0; 00159 00160 /**\brief Get tag value for passed entities 00161 * 00162 * Get tag values for specified entities. 00163 * 00164 *\param seqman Pointer to mesh entity database 00165 *\param entities Entity handles for which to retrieve tag data 00166 *\param data_ptrs Array of pointers to tag values, one pointer 00167 * for each passed entity. 00168 *\param data_lengths One value for each entity specifying the 00169 * length of the tag value for the corresponding 00170 * entity. 00171 */ 00172 virtual ErrorCode get_data( const SequenceManager* seqman, 00173 Error* error_handler, 00174 const Range& entities, 00175 const void** data_ptrs, 00176 int* data_lengths ) const = 0; 00177 00178 /**\brief Set tag value for passed entities 00179 * 00180 * Store tag data or update stored tag values 00181 *\Note Will fail for variable-length data. 00182 *\param seqman Pointer to mesh entity database 00183 *\param entities Entity handles for which to store tag data 00184 *\param num_entities Length of \c entities array 00185 *\param data Pointer to memory holding consecutive tag values, 00186 * one for each passed entity. 00187 */ 00188 virtual ErrorCode set_data( SequenceManager* seqman, 00189 Error* error_handler, 00190 const EntityHandle* entities, 00191 size_t num_entities, 00192 const void* data ) = 0; 00193 00194 /**\brief Set tag value for passed entities 00195 * 00196 * Store tag data or update stored tag values 00197 *\Note Will fail for variable-length data. 00198 *\param seqman Pointer to mesh entity database 00199 *\param entities Entity handles for which to store tag data 00200 *\param data Pointer to memory holding consecutive tag values, 00201 * one for each passed entity. 00202 */ 00203 virtual ErrorCode set_data( SequenceManager* seqman, 00204 Error* error_handler, 00205 const Range& entities, 00206 const void* data ) = 0; 00207 00208 /**\brief Set tag value for passed entities 00209 * 00210 * Store tag data or update stored tag values 00211 * 00212 *\param seqman Pointer to mesh entity database 00213 *\param entities Entity handles for which to store tag data 00214 *\param num_entities Length of \c entities array 00215 *\param data_ptrs Array of pointers to tag values, one pointer 00216 * for each passed entity. 00217 *\param data_lengths One value for each entity specifying the 00218 * length of the tag value for the corresponding 00219 * entity. Array is required for variable-length 00220 * tags and is ignored for fixed-length tags. 00221 */ 00222 virtual ErrorCode set_data( SequenceManager* seqman, 00223 Error* error_handler, 00224 const EntityHandle* entities, 00225 size_t num_entities, 00226 void const* const* data_ptrs, 00227 const int* data_lengths ) = 0; 00228 00229 /**\brief Set tag value for passed entities 00230 * 00231 * Store tag data or update stored tag values 00232 * 00233 *\param seqman Pointer to mesh entity database 00234 *\param entities Entity handles for which to store tag data 00235 *\param data_ptrs Array of pointers to tag values, one pointer 00236 * for each passed entity. 00237 *\param data_lengths One value for each entity specifying the 00238 * length of the tag value for the corresponding 00239 * entity. Array is required for variable-length 00240 * tags and is ignored for fixed-length tags. 00241 */ 00242 virtual ErrorCode set_data( SequenceManager* seqman, 00243 Error* error_handler, 00244 const Range& entities, 00245 void const* const* data_ptrs, 00246 const int* data_lengths ) = 0; 00247 00248 /**\brief Set tag value for passed entities 00249 * 00250 * Store tag data or update stored tag values. 00251 * 00252 *\param seqman Pointer to mesh entity database 00253 *\param entities Entity handles for which to store tag data 00254 *\param num_entities Length of \c entities array 00255 *\param value_ptr Pointer to a single tag value which is to be 00256 * stored for each of the passed entities. 00257 *\param value_len Length of tag value in bytes. Ignored for 00258 * fixed-length tags. Required for variable- 00259 * length tags. 00260 */ 00261 virtual ErrorCode clear_data( SequenceManager* seqman, 00262 Error* error_handler, 00263 const EntityHandle* entities, 00264 size_t num_entities, 00265 const void* value_ptr, 00266 int value_len = 0 ) = 0; 00267 00268 /**\brief Set tag value for passed entities 00269 * 00270 * Store tag data or update stored tag values. 00271 * 00272 *\param seqman Pointer to mesh entity database 00273 *\param entities Entity handles for which to store tag data 00274 *\param value_ptr Pointer to a single tag value which is to be 00275 * stored for each of the passed entities. 00276 *\param value_len Length of tag value in bytes. Ignored for 00277 * fixed-length tags. Required for variable- 00278 * length tags. 00279 */ 00280 virtual ErrorCode clear_data( SequenceManager* seqman, 00281 Error* error_handler, 00282 const Range& entities, 00283 const void* value_ptr, 00284 int value_len = 0 ) = 0; 00285 00286 /**\brief Remove/clear tag data for entities 00287 * 00288 * Remove tag values from entities. 00289 * 00290 *\param seqman Pointer to mesh entity database 00291 *\param entities Entity handles for which to store tag data 00292 *\param num_entities Length of \c entities array 00293 */ 00294 virtual ErrorCode remove_data( SequenceManager* seqman, 00295 Error* error_handler, 00296 const EntityHandle* entities, 00297 size_t num_entities ) = 0; 00298 00299 /**\brief Remove/clear tag data for entities 00300 * 00301 * Remove tag values from entities. 00302 * 00303 *\param seqman Pointer to mesh entity database 00304 *\param entities Entity handles for which to store tag data 00305 */ 00306 virtual ErrorCode remove_data( SequenceManager* seqman, Error* error_handler, const Range& entities ) = 0; 00307 00308 /**\brief Access tag data via direct pointer into contiguous blocks 00309 * 00310 * Iteratively obtain direct access to contiguous blocks of tag 00311 * storage. This function cannot be used with bit tags because 00312 * of the compressed bit storage. This function cannot be used 00313 * with variable length tags because it does not provide a mechanism 00314 * to determine the length of the value for each entity. This 00315 * function may be used with sparse tags, but if it is used, it 00316 * will return data for a single entity at a time. 00317 * 00318 *\param iter As input, the first entity for which to return 00319 * data. As output, one past the last entity for 00320 * which data was returned. 00321 *\param end One past the last entity for which data is desired 00322 *\param data_ptr Output: pointer to tag storage. 00323 *\param allocate If true, space for this tag will be allocated, if not it wont 00324 * 00325 *\Note If this function is called for entities for which no tag value 00326 * has been set, but for which a default value exists, it will 00327 * force the allocation of explicit storage for each such entity 00328 * even though MOAB would normally not explicitly store tag values 00329 * for such entities. 00330 */ 00331 virtual ErrorCode tag_iterate( SequenceManager* seqman, 00332 Error* error_handler, 00333 Range::iterator& iter, 00334 const Range::iterator& end, 00335 void*& data_ptr, 00336 bool allocate = true ) = 0; 00337 00338 /**\brief Get all tagged entities 00339 * 00340 * Get the list of entities for which the a tag value has been set, 00341 * or a close approximation if the tag storage scheme cannot 00342 * accurately determine exactly which entities have explicit values. 00343 * 00344 *\param seqman Pointer to entity storage database 00345 *\param output_entities Results *appended* to this range 00346 *\param type Optional entity type. If specified, search is 00347 * limited to entities of specified type. 00348 *\param intersect Optional intersect list. If specified, 00349 * search is restricted to entities in this list. 00350 */ 00351 virtual ErrorCode get_tagged_entities( const SequenceManager* seqman, 00352 Range& output_entities, 00353 EntityType type = MBMAXTYPE, 00354 const Range* intersect = 0 ) const = 0; 00355 00356 /**\brief Count all tagged entities 00357 * 00358 * Count the entities for which the a tag value has been set, 00359 * or a close approximation if the tag storage scheme cannot 00360 * accurately determine exactly which entities have explicit values. 00361 * 00362 *\param seqman Pointer to entity storage database 00363 *\param output_count This is *incremented* for each detected entity. 00364 *\param type Optional entity type. If specified, search is 00365 * limited to entities of specified type. 00366 *\param intersect Optional intersect list. If specified, 00367 * search is restricted to entities in this list. 00368 */ 00369 virtual ErrorCode num_tagged_entities( const SequenceManager* seqman, 00370 size_t& output_count, 00371 EntityType type = MBMAXTYPE, 00372 const Range* intersect = 0 ) const = 0; 00373 00374 /**\brief Get all tagged entities with tag value 00375 * 00376 * Get the list of entities which have the specified tag value. 00377 * 00378 *\param seqman Pointer to entity storage database 00379 *\param output_entities Results *appended* to this range 00380 *\param value Pointer to tag value 00381 *\param value_bytes Size of tag value in bytes. 00382 *\param type Optional entity type. If specified, search is 00383 * limited to entities of specified type. 00384 *\param intersect_entities Optional intersect list. If specified, 00385 * search is restricted to entities in this list. 00386 */ 00387 virtual ErrorCode find_entities_with_value( const SequenceManager* seqman, 00388 Error* error_handler, 00389 Range& output_entities, 00390 const void* value, 00391 int value_bytes = 0, 00392 EntityType type = MBMAXTYPE, 00393 const Range* intersect_entities = 0 ) const = 0; 00394 00395 /**\brief Check if entity is tagged */ 00396 virtual bool is_tagged( const SequenceManager* seqman, EntityHandle entity ) const = 0; 00397 00398 /**\brief Get memory use for tag data. 00399 * 00400 */ 00401 virtual ErrorCode get_memory_use( const SequenceManager* seqman, 00402 unsigned long& total, 00403 unsigned long& per_entity ) const = 0; 00404 00405 protected: 00406 unsigned long get_memory_use() const 00407 { 00408 return get_default_value_size() + get_name().size(); 00409 } 00410 00411 private: 00412 TagInfo( const TagInfo& copy ); 00413 00414 TagInfo& operator=( const TagInfo& copy ); 00415 00416 //! stores the default data, if any 00417 void* mDefaultValue; 00418 00419 //! store the mesh value, if any 00420 void* mMeshValue; 00421 00422 //! Size of mDefaultValue and mMeshValue, in bytes 00423 //! NOTE: These sizes differ from mDataSize in two cases: 00424 //! a) Variable-length tags 00425 //! b) Bit tags (where mDataSize is bits, not bytes.) 00426 int mDefaultValueSize, mMeshValueSize; 00427 00428 //! stores the size of the data for this tag 00429 int mDataSize; 00430 00431 //! type of tag data 00432 DataType dataType; 00433 00434 //! stores the tag name 00435 std::string mTagName; 00436 }; 00437 00438 } // namespace moab 00439 00440 #endif // TAG_INFO_HPP
