OffsetHexCenterNodes Class Reference
+ Inheritance diagram for OffsetHexCenterNodes:
+ Collaboration diagram for OffsetHexCenterNodes:
Public Member Functions
 OffsetHexCenterNodes (Interface *mb, double x, double y, double z)
 ~OffsetHexCenterNodes ()
void node_added (EntityHandle node, EntityHandle)
void node_removed (EntityHandle)
Private Attributes
InterfacegMB
double mCoords [3]
double mOffset [3]
Detailed Description
Definition at line 3114 of file MBTest.cpp.
OffsetHexCenterNodes::OffsetHexCenterNodes ( Interface mb,
double  x,
double  y,
double  z
) [inline]
Definition at line 3117 of file MBTest.cpp.
References z.
        : gMB( mb )
        mCoords[0] = 0.0;
        mCoords[1] = 0.0;
        mCoords[2] = 0.0;
        mOffset[0] = x;
        mOffset[1] = y;
        mOffset[2] = z;
Definition at line 3127 of file MBTest.cpp.
Member Function Documentation
void OffsetHexCenterNodes::node_added ( EntityHandle  node,
EntityHandle  element
) [inline, virtual]
node_added called when a node was added to an element's connectivity array note: connectivity array of element may be incomplete (corner nodes will exist always)
Parameters:
nodeNode being added
elementElement node is being added to
Implements moab::Interface::HONodeAddedRemoved.
Definition at line 3129 of file MBTest.cpp.
References moab::Interface::get_coords(), and moab::Interface::set_coords().
        gMB->get_coords( &node, 1, mCoords );
        mCoords[0] += mOffset[0];
        mCoords[1] += mOffset[1];
        mCoords[2] += mOffset[2];
        gMB->set_coords( &node, 1, mCoords );
void OffsetHexCenterNodes::node_removed ( EntityHandle  node) [inline, virtual]
Parameters:
nodeNode being removed.
Definition at line 3139 of file MBTest.cpp.
Member Data Documentation
Definition at line 3142 of file MBTest.cpp.
double OffsetHexCenterNodes::mCoords[3] [private]
Definition at line 3143 of file MBTest.cpp.
double OffsetHexCenterNodes::mOffset[3] [private]
Definition at line 3144 of file MBTest.cpp.
List of all members.
