Mesh Oriented datABase
(version 5.4.1)
#include <EntityRefiner.hpp>
Inheritance diagram for moab::EntityRefinerOutputFunctor:Public Member Functions | |
| virtual | ~EntityRefinerOutputFunctor () |
| virtual EntityHandle | map_vertex (EntityHandle vhash, const double *vcoords, const void *vtags)=0 |
| Map an input vertex to the output mesh. This should return the same value when given the same input across multiple calls. | |
| EntityHandle | operator() (EntityHandle h0, EntityHandle h1, const double *vcoords, const void *vtags) |
| Create a new vertex along an edge. | |
| virtual EntityHandle | operator() (EntityHandle h0, EntityHandle h1, EntityHandle h2, const double *vcoords, const void *vtags) |
| Create a new vertex on a triangular face. | |
| virtual EntityHandle | operator() (int nhash, EntityHandle *hash, const double *vcoords, const void *vtags)=0 |
| Create a new vertex along a \(k\)-facet. | |
| virtual void | operator() (EntityHandle vhash)=0 |
| Append an output vertex to the list of vertices defining a new entity. | |
| virtual void | operator() (EntityType etyp)=0 |
| Create a new entity from all previously appended output vertices. | |
Definition at line 79 of file EntityRefiner.hpp.
| virtual moab::EntityRefinerOutputFunctor::~EntityRefinerOutputFunctor | ( | ) | [inline, virtual] |
Definition at line 82 of file EntityRefiner.hpp.
| virtual EntityHandle moab::EntityRefinerOutputFunctor::map_vertex | ( | EntityHandle | vhash, |
| const double * | vcoords, | ||
| const void * | vtags | ||
| ) | [pure virtual] |
Implemented in moab::MeshOutputFunctor.
Referenced by moab::SimplexTemplateRefiner::refine_entity().
| EntityHandle moab::EntityRefinerOutputFunctor::operator() | ( | EntityHandle | h0, |
| EntityHandle | h1, | ||
| ) | [inline] |
| [in] | h0 | An edge endpoint handle on the output mesh. |
| [in] | h1 | An edge endpoint handle on the output mesh. |
| [in] | vcoords | The location of the midpoint in world coordinates. |
| [in] | vtags | Field values at the midpoint. |
| A | handle for the midpoint on the output mesh. |
Definition at line 94 of file EntityRefiner.hpp.
EntityHandle harr[2];
// Cppcheck warning (false positive): variable harr is assigned a value that is never used
harr[0] = h0;
harr[1] = h1;
return ( *this )( 2, harr, vcoords, vtags );
| virtual EntityHandle moab::EntityRefinerOutputFunctor::operator() | ( | EntityHandle | h0, |
| EntityHandle | h2, | ||
| [in] | h0 | A triangle corner handle on the output mesh. |
| [in] | h1 | A triangle corner handle on the output mesh. |
| [in] | h2 | A triangle corner handle on the output mesh. |
| [in] | vcoords | The location of the mid-face point in world coordinates. |
| [in] | vtags | Field values at the mid-face point. |
| A | handle for the mid-face point on the output mesh. |
Definition at line 111 of file EntityRefiner.hpp.
EntityHandle harr[3];
harr[0] = h0;
harr[1] = h1;
harr[2] = h2;
return ( *this )( 3, harr, vcoords, vtags );
| virtual EntityHandle moab::EntityRefinerOutputFunctor::operator() | ( | int | nhash, |
| EntityHandle * | hash, | ||
| [in] | nhash | The number of corner vertices (i.e, \(k\) ). |
| [in] | hash | An array of corner handles on the output mesh. |
| [in] | vcoords | The location of the new point in world coordinates. |
| [in] | vtags | Field values at the new point. |
| A | handle for the new point on the output mesh. |
| virtual void moab::EntityRefinerOutputFunctor::operator() | ( | EntityHandle | vhash | ) | [pure virtual] |
| [in] | vhash | A vertex of the output mesh. |
| virtual void moab::EntityRefinerOutputFunctor::operator() | ( | EntityType | etyp | ) | [pure virtual] |
This resets the list of appended vertices.
| [in] | etyp | The type of entity to create. |
