Mesh Oriented datABase
(version 5.4.1)
| create_sets(int num_sets, EntityHandle start_vertex, int num_verts, EntityHandle start_elem, int num_elems, Range &read_ents) | moab::ReadTemplate | [private] |
| factory(Interface *) | moab::ReadTemplate | [static] |
| fileName | moab::ReadTemplate | [private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadTemplate | [virtual] |
| mbImpl | moab::ReadTemplate | [private] |
| process_options(const FileOptions &opts) | moab::ReadTemplate | [private] |
| read_elements(int num_elems, EntityHandle start_vertex, EntityHandle &start_elem, Range &read_ents) | moab::ReadTemplate | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadTemplate | [virtual] |
| read_vertices(int num_verts, EntityHandle &start_vertex, Range &read_ents) | moab::ReadTemplate | [private] |
| readMeshIface | moab::ReadTemplate | [private] |
| ReadTemplate(Interface *impl=NULL) | moab::ReadTemplate | |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~ReadTemplate() | moab::ReadTemplate | [virtual] |
