Mesh Oriented datABase
(version 5.4.1)
Template for implementing new file readers in MOAB This class is a template for writing new file readers in MOAB. This shows how to efficiently create vertices and elements using the ReadUtilIface class, and to translate indices in connectivity lists into vertex handles created during the read. More...
#include <ReadTemplate.hpp>
Inheritance diagram for moab::ReadTemplate:
Collaboration diagram for moab::ReadTemplate:Public Member Functions | |
| ErrorCode | load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) |
| Load mesh from a file. | |
| ErrorCode | read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) |
| Read tag values from a file. | |
| ReadTemplate (Interface *impl=NULL) | |
| Constructor. | |
| virtual | ~ReadTemplate () |
| Destructor. | |
Static Public Member Functions | |
| static ReaderIface * | factory (Interface *) |
| factory method | |
Private Member Functions | |
| ErrorCode | read_vertices (int num_verts, EntityHandle &start_vertex, Range &read_ents) |
| Read vertex data and create vertices in MOAB database. | |
| ErrorCode | read_elements (int num_elems, EntityHandle start_vertex, EntityHandle &start_elem, Range &read_ents) |
| Read element data and create elements in MOAB database. | |
| ErrorCode | create_sets (int num_sets, EntityHandle start_vertex, int num_verts, EntityHandle start_elem, int num_elems, Range &read_ents) |
| Read entity set data and create/populate sets in MOAB database. | |
| ErrorCode | process_options (const FileOptions &opts) |
| Process options passed into the reader. | |
Private Attributes | |
| ReadUtilIface * | readMeshIface |
| Interface * | mbImpl |
| interface instance | |
| const char * | fileName |
After writing the new reader class, you should also modify src/ReaderWriterSet.cpp, to register the new reader along with the file extensions that it reads. This will turn on automatic creating of this reader based on file extension, which is done in Core::serial_load_file.
Definition at line 23 of file ReadTemplate.hpp.
| ReadTemplate::ReadTemplate | ( | Interface * | impl = NULL | ) |
Constructor.
Definition at line 24 of file ReadTemplate.cpp.
References mbImpl, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
: mbImpl( impl ), fileName( NULL ) { mbImpl->query_interface( readMeshIface ); }
| ReadTemplate::~ReadTemplate | ( | ) | [virtual] |
Destructor.
Definition at line 29 of file ReadTemplate.cpp.
References mbImpl, readMeshIface, and moab::Interface::release_interface().
if( readMeshIface )
mbImpl->release_interface( readMeshIface );
readMeshIface = 0;
| ErrorCode ReadTemplate::create_sets | ( | int | num_sets, |
| EntityHandle | start_vertex, | ||
| int | num_verts, | ||
| EntityHandle | start_elem, | ||
| int | num_elems, | ||
| Range & | read_ents | ||
| ) | [private] |
Read/create sets.
| num_sets | Number of sets to be read |
| start_vertex | Starting vertex handle |
| num_verts | Total number of vertices read from file |
| start_elem | Starting element handle |
| num_elems | Total number of elements read from file |
| read_ents | Range storing all entities read from this file |
Definition at line 208 of file ReadTemplate.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), ErrorCode, fileName, moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MESHSET_SET.
Referenced by load_file().
ErrorCode result = MB_SUCCESS;
EntityHandle this_set;
for( int i = 0; i < num_sets; i++ )
// Create set
result = mbImpl->create_meshset( MESHSET_SET, this_set );MB_CHK_SET_ERR( result, fileName << ": Trouble creating set" );
Range set_ents;
// Read/compute what's in this set; REMEMBER TO CONVERT THESE TO MOAB HANDLES
// Add them to the set
result = mbImpl->add_entities( this_set, set_ents );MB_CHK_SET_ERR( result, fileName << ": Trouble putting entities in set" );
// Add the new set to read_ents
read_ents.insert( this_set );
return MB_SUCCESS;
| ReaderIface * ReadTemplate::factory | ( | Interface * | iface | ) | [static] |
factory method
Definition at line 19 of file ReadTemplate.cpp.
References ReadTemplate().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
return new ReadTemplate( iface );
| ErrorCode ReadTemplate::load_file | ( | const char * | file_name, |
| const EntityHandle * | file_set, | ||
| const FileOptions & | opts, | ||
| const SubsetList * | subset_list = 0, |
| const Tag * | file_id_tag = 0 |
| ) | [virtual] |
Method all readers must provide to import a mesh.
| file_name | The file to read. |
| file_set | Optional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data. |
| subset_list | An optional struct pointer specifying the tags identifying entity sets to be read. |
| file_id_tag | If specified, reader should store for each entity it reads, a unique integer ID for this tag. |
Implements moab::ReaderIface.
Definition at line 47 of file ReadTemplate.cpp.
References moab::Interface::add_entities(), create_sets(), ErrorCode, fileName, MB_CHK_SET_ERR, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, mbImpl, process_options(), read_elements(), and read_vertices().
if( subset_list )
// See src/moab/ReaderIface.hpp, definition of SubsetList struct; this basically specifies
// an integer tag and tag values for sets to read on this proc, or a part number and total #
// parts for reading a trivial partition of entities
// Save filename to member variable so we don't need to pass as an argument
// to called functions
fileName = filename;
// Process options; see src/FileOptions.hpp for API for FileOptions class, and
// doc/metadata_info.doc for a description of various options used by some of the readers in
// MOAB
ErrorCode result = process_options( opts );MB_CHK_SET_ERR( result, fileName << ": problem reading options" );
// Open file; filePtr is member of ReadTemplate, change to whatever mechanism is used to
// identify file
FILE* filePtr = fopen( fileName, "r" );
if( !filePtr )
MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, fileName << ": fopen returned error" );
// Read number of verts, elements, sets
long num_verts = 0, num_elems = 0, num_sets = 0;
// read_ents keeps a running set of entities read from this file, including vertices, elements,
// and sets; these will get added to file_set (if input) at the end of the read
Range read_ents;
// start_vertex is passed back so we know how to convert indices from the file into vertex
// handles; most of the time this is done by adding start_vertex to the (0-based) index; if the
// index is 1-based, you also need to subtract one; see read_elements for details
EntityHandle start_vertex;
result = read_vertices( num_verts, start_vertex, read_ents );
if( MB_SUCCESS != result )
fclose( filePtr );
return result;
// Create/read elements; this template assumes that all elements are the same type, so can be
// read in a single call to read_elements, and kept track of with a single start_elem handle. If
// there are more entity types, might have to keep these start handles in an array/vector.
// start_elem is only really needed if you're reading sets later, and need to convert some
// file-based index to an entity handle
EntityHandle start_elem;
result = read_elements( num_elems, start_vertex, start_elem, read_ents );
fclose( filePtr );
return result;
// Read/create entity sets; typically these sets have some tag identifying what they're for, see
// doc/metadata_info.doc for examples of different kinds of sets and how they're marked
result = create_sets( num_sets, start_vertex, num_verts, start_elem, num_elems, read_ents );
fclose( filePtr );
return result;
// Finally, add all read_ents into the file set, if one was input
if( file_set && *file_set )
result = mbImpl->add_entities( *file_set, read_ents );
fclose( filePtr );
return result;
fclose( filePtr );
return result;
| ErrorCode ReadTemplate::process_options | ( | const FileOptions & | opts | ) | [private] |
| opts | Options passed into this read |
Definition at line 236 of file ReadTemplate.cpp.
References moab::FileOptions::mark_all_seen(), and MB_SUCCESS.
// Mark all options seen, to avoid compile warning on unused variable
opts.mark_all_seen();
return MB_SUCCESS;
| ErrorCode ReadTemplate::read_elements | ( | int | num_elems, |
| EntityHandle & | start_elem, | ||
| ) | [private] |
Read/create elements.
| num_elems | Number of elements to be read |
| start_vertex | Starting vertex handle; used to offset connectivity indices |
| start_elem | Starting element handle; may be used later to offset set entities |
Definition at line 157 of file ReadTemplate.cpp.
References ErrorCode, fileName, moab::ReadUtilIface::get_element_connect(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MBHEX, moab::Range::rbegin(), readMeshIface, and moab::ReadUtilIface::update_adjacencies().
// Get the entity type being read
EntityType ent_type = MBHEX;
// Get the number of vertices per entity
int verts_per_elem = 8;
// Create the element sequence; passes back a pointer to the internal storage for connectivity
// and the starting entity handle
EntityHandle* conn_array;
ErrorCode result =
readMeshIface->get_element_connect( num_elems, verts_per_elem, ent_type, 1, start_elem, conn_array );MB_CHK_SET_ERR( result, fileName << ": Trouble reading elements" );
// Read connectivity into conn_array directly
for( long i = 0; i < num_elems; i++ )
// Convert file-based connectivity indices to vertex handles in-place; be careful, if indices
// are smaller than handles, need to do from the end of the list so we don't overwrite data
// Here, we assume indices are smaller than handles, just for demonstration; create an
// integer-type pointer to connectivity initialized to same start of connectivity array
int* ind_array = reinterpret_cast< int* >( conn_array );
// OFFSET is value of first vertex index in file; most files are 1-based, but some might be
// 0-based
int OFFSET = 1;
for( long i = num_elems * verts_per_elem - 1; i >= 0; i-- )
conn_array[i] = ind_array[i] + start_vertex + OFFSET;
// This assert assumes last handle in read_ents is highest vertex handle in this file
assert( conn_array[i] >= start_vertex && conn_array[i] <= *read_ents.rbegin() );
// Notify MOAB of the new elements
result = readMeshIface->update_adjacencies( start_elem, num_elems, verts_per_elem, conn_array );
if( MB_SUCCESS != result ) return result;
// Add elements to read_ents
if( num_elems ) read_ents.insert( start_elem, start_elem + num_elems - 1 );
return MB_SUCCESS;
| ErrorCode ReadTemplate::read_tag_values | ( | const char * | file_name, |
| const char * | tag_name, | ||
| std::vector< int > & | tag_values_out, | ||
| const SubsetList * | subset_list = 0 |
| ) | [virtual] |
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
| tag_name | The tag for which to read values |
| tag_values_out | Output: The list of tag values. |
| subset_list | An array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read. |
| subset_list_length | The length of the 'subset_list' array. |
Definition at line 38 of file ReadTemplate.cpp.
References MB_NOT_IMPLEMENTED.
return MB_NOT_IMPLEMENTED;
| ErrorCode ReadTemplate::read_vertices | ( | int | num_verts, |
| EntityHandle & | start_vertex, | ||
| ) | [private] |
| num_verts | Number of vertices to be read |
| start_vertex | Starting vertex handle; used later to offset connectivity indices |
Definition at line 133 of file ReadTemplate.cpp.
References ErrorCode, fileName, moab::ReadUtilIface::get_node_coords(), moab::Range::insert(), MB_CHK_SET_ERR, and readMeshIface.
// Allocate nodes; these are allocated in one shot, get contiguous handles starting with
// start_handle, and the reader is passed back double*'s pointing to MOAB's native storage for
// vertex coordinates for those verts
std::vector< double* > coord_arrays;
ErrorCode result = readMeshIface->get_node_coords( 3, num_verts, 1, start_vertex, coord_arrays );MB_CHK_SET_ERR( result, fileName << ": Trouble reading vertices" );
// Fill in vertex coordinate arrays
double *x = coord_arrays[0], *y = coord_arrays[1], *z = coord_arrays[2];
for( long i = 0; i < num_verts; ++i )
// Read x/y/z; do something with them for now to avoid warning
if( x || y || z )
if( num_verts ) read_ents.insert( start_vertex, start_vertex + num_verts - 1 );
return result;
const char* moab::ReadTemplate::fileName [private] |
Definition at line 89 of file ReadTemplate.hpp.
Referenced by create_sets(), load_file(), read_elements(), and read_vertices().
Interface* moab::ReadTemplate::mbImpl [private] |
interface instance
Definition at line 87 of file ReadTemplate.hpp.
Referenced by create_sets(), load_file(), ReadTemplate(), and ~ReadTemplate().
ReadUtilIface* moab::ReadTemplate::readMeshIface [private] |
Definition at line 84 of file ReadTemplate.hpp.
Referenced by read_elements(), read_vertices(), ReadTemplate(), and ~ReadTemplate().
