Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
| size_t | len () const |
| void * | default_value () |
| const void * | default_value () const |
| void | set_default_value (const void *val) |
Static Public Member Functions | |
| static size_t | pad (size_t len) |
| static size_t | def_val_bytes (int def_val_len, DataType type) |
| static size_t | len (int name_len, int def_val_len, DataType type) |
Public Attributes | |
| TagType | storage |
| DataType | type |
| int | size |
| int | name_len |
| int | def_val_len |
| char | name [sizeof(unsigned long)] |
Definition at line 524 of file WriteHDF5Parallel.cpp.
| static size_t moab::serial_tag_data::def_val_bytes | ( | int | def_val_len, |
| DataType | type | ||
| ) | [inline, static] |
Definition at line 541 of file WriteHDF5Parallel.cpp.
References def_val_len, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, and MB_TYPE_OPAQUE.
Referenced by len(), and set_default_value().
switch( type )
case MB_TYPE_BIT:
return def_val_len ? 1 : 0;
case MB_TYPE_OPAQUE:
return def_val_len;
case MB_TYPE_INTEGER:
return def_val_len * sizeof( int );
case MB_TYPE_DOUBLE:
return def_val_len * sizeof( double );
case MB_TYPE_HANDLE:
return def_val_len * sizeof( EntityHandle );
return 0;
| void* moab::serial_tag_data::default_value | ( | ) | [inline] |
Definition at line 568 of file WriteHDF5Parallel.cpp.
References def_val_len, name, and name_len.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), default_value(), and set_default_value().
return def_val_len ? name + name_len : 0;
| const void* moab::serial_tag_data::default_value | ( | ) | const [inline] |
Definition at line 572 of file WriteHDF5Parallel.cpp.
References default_value().
return const_cast< serial_tag_data* >( this )->default_value();
| static size_t moab::serial_tag_data::len | ( | int | name_len, |
| int | def_val_len, | ||
Definition at line 559 of file WriteHDF5Parallel.cpp.
References def_val_bytes(), and pad().
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data().
return sizeof( serial_tag_data ) + pad( name_len + def_val_bytes( def_val_len, type ) ) -
sizeof( unsigned long );
| size_t moab::serial_tag_data::len | ( | ) | const [inline] |
Definition at line 564 of file WriteHDF5Parallel.cpp.
References def_val_len, name_len, and type.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), and pad().
return len( name_len, def_val_len, type );
| static size_t moab::serial_tag_data::pad | ( | size_t | len | ) | [inline, static] |
| void moab::serial_tag_data::set_default_value | ( | const void * | val | ) | [inline] |
Definition at line 576 of file WriteHDF5Parallel.cpp.
References def_val_bytes(), def_val_len, default_value(), and type.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data().
memcpy( default_value(), val, def_val_bytes( def_val_len, type ) );
Definition at line 530 of file WriteHDF5Parallel.cpp.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), moab::WriteHDF5Parallel::check_serial_tag_data(), def_val_bytes(), default_value(), len(), and set_default_value().
| char moab::serial_tag_data::name[sizeof(unsigned long)] |
Definition at line 531 of file WriteHDF5Parallel.cpp.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), moab::WriteHDF5Parallel::check_serial_tag_data(), and default_value().
Definition at line 529 of file WriteHDF5Parallel.cpp.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), default_value(), and len().
Definition at line 528 of file WriteHDF5Parallel.cpp.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), and moab::WriteHDF5Parallel::check_serial_tag_data().
Definition at line 526 of file WriteHDF5Parallel.cpp.
Definition at line 527 of file WriteHDF5Parallel.cpp.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), moab::WriteHDF5Parallel::check_serial_tag_data(), len(), and set_default_value().
