Mesh Oriented datABase
(version 5.4.1)
#include <SweptVertexData.hpp>
Inheritance diagram for moab::SweptVertexData:
Collaboration diagram for moab::SweptVertexData:Public Member Functions | |
| SweptVertexData (const EntityHandle start_vertex, const int imin, const int jmin, const int kmin, const int imax, const int jmax, const int kmax) | |
| constructor | |
| virtual | ~SweptVertexData () |
| EntityHandle | get_vertex (const int i, const int j, const int k) const |
| get handle of vertex at i, j, k | |
| EntityHandle | get_vertex (const HomCoord &coords) const |
| get handle of vertex at homogeneous coordinates | |
| ErrorCode | get_params (const EntityHandle vhandle, int &i, int &j, int &k) const |
| get the parameters of a given handle; return MB_FAILURE if vhandle not in this sequence | |
| void | min_params (int &i, int &j, int &k) const |
| get min params for this vertex | |
| void | max_params (int &i, int &j, int &k) const |
| get max params for this vertex | |
| const HomCoord & | min_params () const |
| get the min params | |
| const HomCoord & | max_params () const |
| get the max params | |
| void | param_extents (int &di, int &dj, int &dk) const |
| get the number of vertices in each direction, inclusive | |
| int | i_min () const |
| convenience functions for parameter extents | |
| int | j_min () const |
| int | k_min () const |
| int | i_max () const |
| int | j_max () const |
| int | k_max () const |
| bool | contains (const HomCoord &coords) const |
| return whether this vseq's parameter space contains these parameters | |
| bool | contains (const int i, const int j, const int k) const |
| SequenceData * | subset (EntityHandle start, EntityHandle end, const int *sequence_data_sizes, const int *tag_data_sizes) const |
Private Attributes | |
| HomCoord | vertexParams [3] |
| parameter min/max, in homogeneous coords ijkh (extra row for stride eventually) | |
| int | dIJK [3] |
| difference between max and min params plus one (i.e. # VERTICES in each parametric direction) | |
| int | dIJKm1 [3] |
| difference between max and min params (i.e. # VERTEXS in each parametric direction) | |
Definition at line 33 of file SweptVertexData.hpp.
| moab::SweptVertexData::SweptVertexData | ( | const EntityHandle | start_vertex, |
| const int | imin, | ||
| const int | jmin, | ||
| const int | kmin, | ||
| const int | imax, | ||
| const int | jmax, | ||
| const int | kmax | ||
constructor
Definition at line 23 of file SweptVertexData.cpp.
References moab::SequenceData::create_sequence_data(), dIJK, dIJKm1, and vertexParams.
: SequenceData( 3, start_vertex, start_vertex + ( imax - imin + 1 ) * ( jmax - jmin + 1 ) * ( kmax - kmin + 1 ) - 1 ) { // need to have meaningful parameters assert( imax >= imin && jmax >= jmin && kmax >= kmin ); vertexParams[0] = HomCoord( imin, jmin, kmin ); vertexParams[1] = HomCoord( imax, jmax, kmax ); vertexParams[2] = HomCoord( 1, 1, 1 ); dIJK[0] = imax - imin + 1; dIJK[1] = jmax - jmin + 1; dIJK[2] = kmax - kmin + 1; dIJKm1[0] = dIJK[0] - 1; dIJKm1[1] = dIJK[1] - 1; dIJKm1[2] = dIJK[2] - 1; create_sequence_data( 0, sizeof( double ) ); create_sequence_data( 1, sizeof( double ) ); create_sequence_data( 2, sizeof( double ) ); }
| virtual moab::SweptVertexData::~SweptVertexData | ( | ) | [inline, virtual] |
Definition at line 58 of file SweptVertexData.hpp.
| bool moab::SweptVertexData::contains | ( | const HomCoord & | coords | ) | const [inline] |
Definition at line 185 of file SweptVertexData.hpp.
References vertexParams.
Referenced by contains().
return ( coords >= vertexParams[0] && coords <= vertexParams[1] ) ? true : false;
| bool moab::SweptVertexData::contains | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 190 of file SweptVertexData.hpp.
References contains().
return contains( HomCoord( i, j, k ) );
| ErrorCode moab::SweptVertexData::get_params | ( | const EntityHandle | vhandle, |
| int & | i, | ||
| int & | j, | ||
| int & | k | ||
Definition at line 131 of file SweptVertexData.hpp.
References dIJK, moab::HomCoord::i(), i_max(), i_min(), moab::HomCoord::j(), j_max(), j_min(), moab::HomCoord::k(), k_max(), k_min(), MB_SUCCESS, MBVERTEX, moab::SequenceData::start_handle(), moab::TYPE_FROM_HANDLE(), and vertexParams.
if( TYPE_FROM_HANDLE( vhandle ) != MBVERTEX ) return MB_FAILURE;
int hdiff = vhandle - start_handle();
k = hdiff / ( dIJK[0] * dIJK[1] );
j = ( hdiff - ( k * dIJK[0] * dIJK[1] ) ) / dIJK[0];
i = hdiff % dIJK[0];
k += vertexParams[0].k();
j += vertexParams[0].j();
i += vertexParams[0].i();
return ( vhandle >= start_handle() && i >= i_min() && i <= i_max() && j >= j_min() && j <= j_max() &&
k >= k_min() && k <= k_max() )
? MB_SUCCESS
: MB_FAILURE;
| EntityHandle moab::SweptVertexData::get_vertex | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 121 of file SweptVertexData.hpp.
References dIJK, i_min(), j_min(), k_min(), and moab::SequenceData::start_handle().
Referenced by get_vertex().
| EntityHandle moab::SweptVertexData::get_vertex | ( | const HomCoord & | coords | ) | const [inline] |
Definition at line 126 of file SweptVertexData.hpp.
References get_vertex(), and moab::HomCoord::hom_coord().
return get_vertex( coords.hom_coord()[0], coords.hom_coord()[1], coords.hom_coord()[2] );
| int moab::SweptVertexData::i_max | ( | ) | const [inline] |
Definition at line 98 of file SweptVertexData.hpp.
References moab::HomCoord::hom_coord(), and vertexParams.
Referenced by get_params(), and max_params().
return vertexParams[1].hom_coord()[0];
| int moab::SweptVertexData::i_min | ( | ) | const [inline] |
Definition at line 86 of file SweptVertexData.hpp.
Referenced by get_params(), get_vertex(), and min_params().
return vertexParams[0].hom_coord()[0];
| int moab::SweptVertexData::j_max | ( | ) | const [inline] |
Definition at line 102 of file SweptVertexData.hpp.
return vertexParams[1].hom_coord()[1];
| int moab::SweptVertexData::j_min | ( | ) | const [inline] |
Definition at line 90 of file SweptVertexData.hpp.
return vertexParams[0].hom_coord()[1];
| int moab::SweptVertexData::k_max | ( | ) | const [inline] |
Definition at line 106 of file SweptVertexData.hpp.
return vertexParams[1].hom_coord()[2];
| int moab::SweptVertexData::k_min | ( | ) | const [inline] |
Definition at line 94 of file SweptVertexData.hpp.
return vertexParams[0].hom_coord()[2];
| void moab::SweptVertexData::max_params | ( | int & | i, |
| int & | j, | ||
| int & | k | ||
Definition at line 160 of file SweptVertexData.hpp.
References i_max(), j_max(), and k_max().
Referenced by moab::SweptElementData::add_vsequence().
| const HomCoord & moab::SweptVertexData::max_params | ( | ) | const [inline] |
get the max params
Definition at line 172 of file SweptVertexData.hpp.
return vertexParams[1];
| void moab::SweptVertexData::min_params | ( | int & | i, |
| int & | j, | ||
| int & | k | ||
Definition at line 152 of file SweptVertexData.hpp.
References i_min(), j_min(), and k_min().
| const HomCoord & moab::SweptVertexData::min_params | ( | ) | const [inline] |
get the min params
Definition at line 167 of file SweptVertexData.hpp.
return vertexParams[0];
| void moab::SweptVertexData::param_extents | ( | int & | di, |
| int & | dj, | ||
| int & | dk | ||
| SequenceData * moab::SweptVertexData::subset | ( | EntityHandle | start, |
| EntityHandle | end, | ||
| const int * | sequence_data_sizes, | ||
| const int * | tag_data_sizes | ||
| ) | const |
Definition at line 53 of file SweptVertexData.cpp.
return 0;
int moab::SweptVertexData::dIJK[3] [private] |
Definition at line 42 of file SweptVertexData.hpp.
Referenced by get_params(), get_vertex(), param_extents(), and SweptVertexData().
int moab::SweptVertexData::dIJKm1[3] [private] |
Definition at line 46 of file SweptVertexData.hpp.
Referenced by SweptVertexData().
HomCoord moab::SweptVertexData::vertexParams[3] [private] |
Definition at line 38 of file SweptVertexData.hpp.
Referenced by contains(), get_params(), i_max(), i_min(), j_max(), j_min(), k_max(), k_min(), max_params(), min_params(), and SweptVertexData().
