Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "SweptVertexData.hpp" 00017 #include <cassert> 00018 00019 namespace moab 00020 { 00021 00022 //! constructor 00023 SweptVertexData::SweptVertexData( const EntityHandle start_vertex, 00024 const int imin, 00025 const int jmin, 00026 const int kmin, 00027 const int imax, 00028 const int jmax, 00029 const int kmax ) 00030 : SequenceData( 3, 00031 start_vertex, 00032 start_vertex + ( imax - imin + 1 ) * ( jmax - jmin + 1 ) * ( kmax - kmin + 1 ) - 1 ) 00033 { 00034 // need to have meaningful parameters 00035 assert( imax >= imin && jmax >= jmin && kmax >= kmin ); 00036 00037 vertexParams[0] = HomCoord( imin, jmin, kmin ); 00038 vertexParams[1] = HomCoord( imax, jmax, kmax ); 00039 vertexParams[2] = HomCoord( 1, 1, 1 ); 00040 00041 dIJK[0] = imax - imin + 1; 00042 dIJK[1] = jmax - jmin + 1; 00043 dIJK[2] = kmax - kmin + 1; 00044 dIJKm1[0] = dIJK[0] - 1; 00045 dIJKm1[1] = dIJK[1] - 1; 00046 dIJKm1[2] = dIJK[2] - 1; 00047 00048 create_sequence_data( 0, sizeof( double ) ); 00049 create_sequence_data( 1, sizeof( double ) ); 00050 create_sequence_data( 2, sizeof( double ) ); 00051 } 00052 00053 SequenceData* SweptVertexData::subset( EntityHandle /*start*/, 00054 EntityHandle /*end*/, 00055 const int* /*sequence_data_sizes*/, 00056 const int* /*tag_data_sizes*/ ) const 00057 { 00058 return 0; 00059 } 00060 00061 } // namespace moab
