Mesh Oriented datABase
(version 5.4.1)
| AdjacencyDataType typedef | moab::SequenceData | |
| allocate_adjacency_data() | moab::SequenceData | |
| allocate_tag_array(int index, int bytes_per_ent, const void *default_value=0) | moab::SequenceData | |
| contains(const HomCoord &coords) const | moab::SweptVertexData | [inline] |
| contains(const int i, const int j, const int k) const | moab::SweptVertexData | [inline] |
| create_custom_data(int array_num, size_t total_bytes) | moab::SequenceData | |
| create_sequence_data(int array_num, int bytes_per_ent, const void *initial_val=0) | moab::SequenceData | |
| dIJK | moab::SweptVertexData | [private] |
| dIJKm1 | moab::SweptVertexData | [private] |
| end_handle() const | moab::SequenceData | [inline] |
| get_adjacency_data() | moab::SequenceData | [inline] |
| get_adjacency_data() const | moab::SequenceData | [inline] |
| get_params(const EntityHandle vhandle, int &i, int &j, int &k) const | moab::SweptVertexData | [inline] |
| get_sequence_data(int array_num) | moab::SequenceData | [inline] |
| get_sequence_data(int array_num) const | moab::SequenceData | [inline] |
| get_tag_data(unsigned tag_num) | moab::SequenceData | [inline] |
| get_tag_data(unsigned tag_num) const | moab::SequenceData | [inline] |
| get_vertex(const int i, const int j, const int k) const | moab::SweptVertexData | [inline] |
| get_vertex(const HomCoord &coords) const | moab::SweptVertexData | [inline] |
| i_max() const | moab::SweptVertexData | [inline] |
| i_min() const | moab::SweptVertexData | [inline] |
| j_max() const | moab::SweptVertexData | [inline] |
| j_min() const | moab::SweptVertexData | [inline] |
| k_max() const | moab::SweptVertexData | [inline] |
| k_min() const | moab::SweptVertexData | [inline] |
| max_params(int &i, int &j, int &k) const | moab::SweptVertexData | [inline] |
| max_params() const | moab::SweptVertexData | [inline] |
| min_params(int &i, int &j, int &k) const | moab::SweptVertexData | [inline] |
| min_params() const | moab::SweptVertexData | [inline] |
| move_tag_data(SequenceData *destination, const int *tag_sizes, int num_tag_sizes) | moab::SequenceData | |
| param_extents(int &di, int &dj, int &dk) const | moab::SweptVertexData | [inline] |
| release_tag_data(const int *tag_sizes, int num_tag_sizes) | moab::SequenceData | |
| release_tag_data(int index, int tag_size) | moab::SequenceData | |
| seqManData | moab::SequenceData | |
| SequenceData(int num_sequence_arrays, EntityHandle start, EntityHandle end) | moab::SequenceData | [inline] |
| SequenceData(const SequenceData *subset_from, EntityHandle start, EntityHandle end, const int *sequence_data_sizes) | moab::SequenceData | [protected] |
| size() const | moab::SequenceData | [inline] |
| start_handle() const | moab::SequenceData | [inline] |
| subset(EntityHandle start, EntityHandle end, const int *sequence_data_sizes, const int *tag_data_sizes) const | moab::SweptVertexData | |
| moab::SequenceData::subset(EntityHandle start, EntityHandle end, const int *sequence_data_sizes) const | moab::SequenceData | |
| SweptVertexData(const EntityHandle start_vertex, const int imin, const int jmin, const int kmin, const int imax, const int jmax, const int kmax) | moab::SweptVertexData | |
| vertexParams | moab::SweptVertexData | [private] |
| ~SequenceData() | moab::SequenceData | [virtual] |
| ~SweptVertexData() | moab::SweptVertexData | [inline, virtual] |
