FindVolume_IntRegCtxt Class Reference
An intersection context used for finding a volume. More...
Detailed Description
This context is used to find the nearest intersection location and is intended for use with a global surface tree from the GeomTopoTool.
The behavior of this context is relatively simple in that it returns only one intersection distance, surface, and facet. Intersections of any orientation are accepted. The positive value of the search window is limited to the current nearest intersection distance.
