Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
| integer(c_int) function | iMOAB_ReadHeaderInfo (filename, num_global_vertices, num_global_elements, num_dimension, num_parts) |
Definition at line 62 of file iMOABF.F90.
| integer(c_int) function iMOAB::iMOAB_ReadHeaderInfo::iMOAB_ReadHeaderInfo | ( | character(kind=c_char), dimension(*), intent(in) | filename, |
| integer(c_int), intent(out) | num_global_vertices, | ||
| integer(c_int), intent(out) | num_global_elements, | ||
| integer(c_int), intent(out) | num_dimension, | ||
| integer(c_int), intent(out) | num_parts | ||
