Mesh Oriented datABase
(version 5.4.1)
Collaboration diagram for moab::AdjSides< CORNERS >:Classes | |
| struct | Side |
Public Types | |
| typedef std::vector< Side > ::iterator | iterator |
| typedef std::vector< Side > ::const_iterator | const_iterator |
Public Member Functions | |
| const_iterator | begin () const |
| const_iterator | end () const |
| void | clear () |
| bool | empty () const |
| AdjSides () | |
| size_t | num_skin () const |
| void | insert (const EntityHandle *handles, int skip_idx, EntityHandle adj_elem, unsigned short elem_side) |
| insert side, specifying side connectivity | |
| void | insert (const EntityHandle *handles, int skip_idx, EntityHandle adj_elem, unsigned short elem_side, const short *indices) |
| insert side, specifying list of indices into parent element connectivity. | |
| bool | find_and_unmark (const EntityHandle *other, int skip_index, EntityHandle &elem_out) |
| Search list for a given side, and if found, mark as not skin. | |
Private Attributes | |
| std::vector< Side > | data |
| List of sides. | |
| size_t | skin_count |
| Cached count of sides that are skin. | |
Definition at line 1144 of file Skinner.cpp.
| typedef std::vector< Side >::const_iterator moab::AdjSides< CORNERS >::const_iterator |
Definition at line 1252 of file Skinner.cpp.
| typedef std::vector< Side >::iterator moab::AdjSides< CORNERS >::iterator |
Definition at line 1251 of file Skinner.cpp.
| moab::AdjSides< CORNERS >::AdjSides | ( | ) | [inline] |
Definition at line 1272 of file Skinner.cpp.
: skin_count( 0 ) {}
| const_iterator moab::AdjSides< CORNERS >::begin | ( | ) | const [inline] |
Definition at line 1253 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::data.
Referenced by moab::Skinner::find_skin_vertices_2D(), and moab::Skinner::find_skin_vertices_3D().
return data.begin();
| void moab::AdjSides< CORNERS >::clear | ( | ) | [inline] |
Definition at line 1262 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::data, and moab::AdjSides< CORNERS >::skin_count.
data.clear();
skin_count = 0;
| bool moab::AdjSides< CORNERS >::empty | ( | ) | const [inline] |
Definition at line 1267 of file Skinner.cpp.
return data.empty();
| const_iterator moab::AdjSides< CORNERS >::end | ( | ) | const [inline] |
Definition at line 1257 of file Skinner.cpp.
return data.end();
| bool moab::AdjSides< CORNERS >::find_and_unmark | ( | const EntityHandle * | other, |
| int | skip_index, | ||
| EntityHandle & | elem_out | ||
| ) | [inline] |
| other | Connectivity of side |
| skip_index | Index in 'other' at which implicit vertex occurs. |
| elem_out | If return value is true, the element that the side is a side of. If return value is false, not set. |
Given the connectivity of some existing element, check if it occurs in the list. If it does, clear the "is skin" state of the side so that we know that we don't need to later create the side element.
Definition at line 1355 of file Skinner.cpp.
Side s( other, skip_index, 0, 0 );
iterator p = std::find( data.begin(), data.end(), s );
if( p == data.end() || !p->adj_elem )
return false;
else
elem_out = p->adj_elem;
p->adj_elem = 0; // clear "is skin" state for side
--skin_count; // decrement cached count of skin sides
return true;
| void moab::AdjSides< CORNERS >::insert | ( | const EntityHandle * | handles, |
| int | skip_idx, | ||
| EntityHandle | adj_elem, | ||
| unsigned short | elem_side | ||
| ) | [inline] |
Either insert a new side, or if the side is already in the list, mark it as not on the skin.
| handles | The connectivity of the element side. |
| skip_idx | The index of the implicit vertex (contained in all sides in the list.) |
| adj_elem | The element that this is a side of. |
| elem_side | Which side of adj_elem are we storing (CN side number.) |
Definition at line 1291 of file Skinner.cpp.
Side side( handles, skip_idx, adj_elem, elem_side );
iterator p = std::find( data.begin(), data.end(), side );
if( p == data.end() )
data.push_back( side );
++skin_count; // not in list yet, so skin side (so far)
else if( p->adj_elem )
p->adj_elem = 0; // mark as not on skin
--skin_count; // decrement cached count of skin elements
| unsigned short | elem_side, | ||
| const short * | indices | ||
| ) | [inline] |
| handles | The connectivity of the parent element |
| skip_idx | The index of the implicit vertex (contained in all sides in the list.) This is an index into 'indices', not 'handles'. |
| adj_elem | The element that this is a side of (parent handle). |
| indices | The indices into 'handles' at which the vertices representing the side occur. |
Definition at line 1323 of file Skinner.cpp.
Side side( handles, skip_idx, adj_elem, elem_side, indices );
| size_t moab::AdjSides< CORNERS >::num_skin | ( | ) | const [inline] |
Definition at line 1274 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::skin_count.
return skin_count;
std::vector< Side > moab::AdjSides< CORNERS >::data [private] |
List of sides.
Definition at line 1247 of file Skinner.cpp.
Referenced by moab::AdjSides< CORNERS >::begin(), moab::AdjSides< CORNERS >::clear(), moab::AdjSides< CORNERS >::empty(), moab::AdjSides< CORNERS >::end(), moab::AdjSides< CORNERS >::find_and_unmark(), and moab::AdjSides< CORNERS >::insert().
size_t moab::AdjSides< CORNERS >::skin_count [private] |
Definition at line 1248 of file Skinner.cpp.
Referenced by moab::AdjSides< CORNERS >::clear(), moab::AdjSides< CORNERS >::find_and_unmark(), moab::AdjSides< CORNERS >::insert(), and moab::AdjSides< CORNERS >::num_skin().
