Mesh Oriented datABase
(version 5.4.1)
Bounding Volume Hierarchy (sorta like a tree), for sorting and searching entities spatially. More...
#include <BVHTree.hpp>
Inheritance diagram for moab::BVHTree:
Collaboration diagram for moab::BVHTree:Classes | |
| class | Bucket |
| class | HandleData |
| class | HandleData_comparator |
| class | Node |
| class | Split_comparator |
| class | SplitData |
| class | TreeNode |
Public Member Functions | |
| BVHTree (Interface *impl) | |
| ~BVHTree () | |
| virtual ErrorCode | reset_tree () |
| Destroy the tree maintained by this object, optionally checking we have the right root. | |
| virtual ErrorCode | parse_options (FileOptions &opts) |
| Parse options for this tree, including common options for all trees. | |
| virtual ErrorCode | get_bounding_box (BoundBox &box, EntityHandle *tree_node=NULL) const |
| Get bounding box for tree below tree_node, or entire tree If no tree has been built yet, returns +/- DBL_MAX for all dimensions. Note for some tree types, boxes are not available for non-root nodes, and this function will return failure if non-root is passed in. | |
| virtual ErrorCode | build_tree (const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *options=NULL) |
| virtual ErrorCode | point_search (const double *point, EntityHandle &leaf_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL, CartVect *params=NULL) |
| Get leaf containing input position. | |
| virtual ErrorCode | distance_search (const double from_point[3], const double distance, std::vector< EntityHandle > &result_list, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, std::vector< double > *result_dists=NULL, std::vector< CartVect > *result_params=NULL, EntityHandle *tree_root=NULL) |
| Find all leaves within a given distance from point If dists_out input non-NULL, also returns distances from each leaf; if point i is inside leaf, 0 is given as dists_out[i]. If params_out is non-NULL and myEval is non-NULL, will evaluate individual entities in tree nodes and return containing entities in leaves_out. In those cases, if params_out is also non-NULL, will return parameters in those elements in that vector. | |
| virtual ErrorCode | print () |
| print various things about this tree | |
Private Types | |
| typedef std::vector< HandleData > | HandleDataVec |
Private Member Functions | |
| BVHTree (const BVHTree &s) | |
| void | establish_buckets (HandleDataVec::const_iterator begin, HandleDataVec::const_iterator end, const BoundBox &interval, std::vector< std::vector< Bucket > > &buckets) const |
| unsigned int | set_interval (BoundBox &interval, std::vector< Bucket >::const_iterator begin, std::vector< Bucket >::const_iterator end) const |
| void | initialize_splits (std::vector< std::vector< SplitData > > &splits, const std::vector< std::vector< Bucket > > &buckets, const SplitData &data) const |
| void | order_elements (HandleDataVec::iterator &begin, HandleDataVec::iterator &end, SplitData &data) const |
| void | median_order (HandleDataVec::iterator &begin, HandleDataVec::iterator &end, SplitData &data) const |
| void | choose_best_split (const std::vector< std::vector< SplitData > > &splits, SplitData &data) const |
| void | find_split (HandleDataVec::iterator &begin, HandleDataVec::iterator &end, SplitData &data) const |
| ErrorCode | find_point (const std::vector< double > &point, const unsigned int &index, const double iter_tol, const double inside_tol, std::pair< EntityHandle, CartVect > &result) |
| EntityHandle | bruteforce_find (const double *point, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6) |
| int | local_build_tree (std::vector< Node > &tree_nodes, HandleDataVec::iterator begin, HandleDataVec::iterator end, const int index, const BoundBox &box, const int depth=0) |
| ErrorCode | construct_element_vec (std::vector< HandleData > &handle_data_vec, const Range &elements, BoundBox &bounding_box) |
| ErrorCode | convert_tree (std::vector< Node > &tree_nodes) |
| ErrorCode | print_nodes (std::vector< Node > &nodes) |
Private Attributes | |
| Range | entityHandles |
| std::vector< TreeNode > | myTree |
| int | splitsPerDir |
| EntityHandle | startSetHandle |
Static Private Attributes | |
| static MOAB_EXPORT const char * | treeName = "BVHTree" |
Definition at line 31 of file BVHTree.hpp.
typedef std::vector< HandleData > moab::BVHTree::HandleDataVec [private] |
Definition at line 139 of file BVHTree.hpp.
| moab::BVHTree::BVHTree | ( | Interface * | impl | ) | [inline] |
Definition at line 357 of file BVHTree.hpp.
References moab::Tree::boxTagName, and treeName.
: Tree( impl ), splitsPerDir( 3 ), startSetHandle( 0 ) { boxTagName = treeName; }
| moab::BVHTree::~BVHTree | ( | ) | [inline] |
| moab::BVHTree::BVHTree | ( | const BVHTree & | s | ) | [private] |
| EntityHandle moab::BVHTree::bruteforce_find | ( | const double * | point, |
| const double | iter_tol = 1.0e-10, |
| const double | inside_tol = 1.0e-6 |
| ) | [private] |
Definition at line 547 of file BVHTree.cpp.
References moab::CartVect::array(), dim, ErrorCode, moab::ElemEvaluator::find_containing_entity(), moab::TreeStats::leavesVisited, MB_SUCCESS, moab::Tree::myEval, myTree, moab::TreeStats::numTraversals, startSetHandle, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
treeStats.numTraversals++;
CartVect params;
for( unsigned int i = 0; i < myTree.size(); i++ )
if( myTree[i].dim != 3 || !myTree[i].box.contains_point( point, iter_tol ) ) continue;
if( myEval )
EntityHandle entity = 0;
treeStats.leavesVisited++;
ErrorCode rval = myEval->find_containing_entity( startSetHandle + i, point, iter_tol, inside_tol, entity,
params.array(), &treeStats.traversalLeafObjectTests );
if( entity )
return entity;
else if( MB_SUCCESS != rval )
return 0;
else
return startSetHandle + i;
return 0;
| ErrorCode moab::BVHTree::build_tree | ( | const Range & | entities, |
| EntityHandle * | tree_root_set = NULL, |
| FileOptions * | options = NULL |
| ) | [virtual] |
Build the tree Build a tree with the entities input. If a non-NULL tree_root_set pointer is input, use the pointed-to set as the root of this tree (*tree_root_set!=0) otherwise construct a new root set and pass its handle back in *tree_root_set. Options vary by tree type; see Tree.hpp for common options; options specific to AdaptiveKDTree: SPLITS_PER_DIR: number of candidate splits considered per direction; default = 3 CANDIDATE_PLANE_SET: method used to decide split planes; see CandidatePlaneSet enum (below) for possible values; default = 1 (SUBDIVISION_SNAP)
| entities | Entities with which to build the tree |
| tree_root | Root set for tree (see function description) |
| opts | Options for tree (see function description) |
Implements moab::Tree.
Definition at line 11 of file BVHTree.cpp.
References moab::Interface::add_entities(), moab::FileOptions::all_seen(), moab::CartVect::array(), moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, moab::Tree::boundBox, moab::TreeStats::compute_stats(), construct_element_vec(), convert_tree(), moab::Tree::create_root(), moab::Range::end(), ErrorCode, moab::TreeStats::initTime, moab::BoundBox::intersects_box(), local_build_tree(), moab::Tree::maxPerLeaf, MB_SUCCESS, moab::Tree::mbImpl, moab::Tree::moab(), parse_options(), moab::TreeStats::reset(), moab::Range::size(), startSetHandle, moab::CpuTimer::time_elapsed(), moab::Tree::treeDepth, moab::Tree::treeStats, and moab::BoundBox::update().
ErrorCode rval;
CpuTimer cp;
if( options )
rval = parse_options( *options );
if( MB_SUCCESS != rval ) return rval;
if( !options->all_seen() ) return MB_FAILURE;
// calculate bounding box of elements
BoundBox box;
rval = box.update( *moab(), entities );
// create tree root
EntityHandle tmp_root;
if( !tree_root_set ) tree_root_set = &tmp_root;
rval = create_root( box.bMin.array(), box.bMax.array(), *tree_root_set );
rval = mbImpl->add_entities( *tree_root_set, entities );
// a fully balanced tree will have 2*_entities.size()
// which is one doubling away..
std::vector< Node > tree_nodes;
tree_nodes.reserve( entities.size() / maxPerLeaf );
std::vector< HandleData > handle_data_vec;
rval = construct_element_vec( handle_data_vec, entities, boundBox );
#ifndef NDEBUG
for( std::vector< HandleData >::const_iterator i = handle_data_vec.begin(); i != handle_data_vec.end(); ++i )
if( !boundBox.intersects_box( i->myBox, 0 ) )
std::cerr << "BB:" << boundBox << "EB:" << i->myBox << std::endl;
return MB_FAILURE;
#endif
// We only build nonempty trees
if( !handle_data_vec.empty() )
// initially all bits are set
tree_nodes.push_back( Node() );
const int depth = local_build_tree( tree_nodes, handle_data_vec.begin(), handle_data_vec.end(), 0, boundBox );
#ifndef NDEBUG
std::set< EntityHandle > entity_handles;
for( std::vector< Node >::iterator n = tree_nodes.begin(); n != tree_nodes.end(); ++n )
for( HandleDataVec::const_iterator j = n->entities.begin(); j != n->entities.end(); ++j )
entity_handles.insert( j->myHandle );
if( entity_handles.size() != entities.size() )
std::cout << "Entity Handle Size Mismatch!" << std::endl;
for( Range::iterator i = entities.begin(); i != entities.end(); ++i )
if( entity_handles.find( *i ) == entity_handles.end() )
std::cout << "Tree is missing an entity! " << std::endl;
#endif
treeDepth = std::max( depth, treeDepth );
// convert vector of Node's to entity sets and vector of TreeNode's
rval = convert_tree( tree_nodes );
treeStats.reset();
rval = treeStats.compute_stats( mbImpl, startSetHandle );
treeStats.initTime = cp.time_elapsed();
return rval;
| void moab::BVHTree::choose_best_split | ( | const std::vector< std::vector< SplitData > > & | splits, |
| SplitData & | data | ||
| ) | const [inline, private] |
Definition at line 398 of file BVHTree.hpp.
Referenced by find_split().
std::vector< SplitData > best_splits;
for( std::vector< std::vector< SplitData > >::const_iterator i = splits.begin(); i != splits.end(); ++i )
std::vector< SplitData >::const_iterator j =
std::min_element( ( *i ).begin(), ( *i ).end(), Split_comparator() );
best_splits.push_back( *j );
data = *std::min_element( best_splits.begin(), best_splits.end(), Split_comparator() );
| ErrorCode moab::BVHTree::construct_element_vec | ( | std::vector< HandleData > & | handle_data_vec, |
| const Range & | elements, | ||
| BoundBox & | bounding_box | ||
| ) | [inline, private] |
Definition at line 410 of file BVHTree.hpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, moab::Tree::mbImpl, and moab::BoundBox::update().
Referenced by build_tree().
std::vector< double > coordinate( 3 * CN::MAX_NODES_PER_ELEMENT );
int num_conn;
ErrorCode rval = MB_SUCCESS;
std::vector< EntityHandle > storage;
for( Range::iterator i = elements.begin(); i != elements.end(); ++i )
// TODO: not generic enough. Why dim != 3
// Commence un-necessary deep copying.
const EntityHandle* connect;
rval = mbImpl->get_connectivity( *i, connect, num_conn, false, &storage );
rval = mbImpl->get_coords( connect, num_conn, &coordinate[0] );
BoundBox box;
for( int j = 0; j < num_conn; j++ )
box.update( &coordinate[3 * j] );
if( i == elements.begin() )
bounding_box = box;
else
bounding_box.update( box );
handle_data_vec.push_back( HandleData( *i, box, 0.0 ) );
return rval;
| ErrorCode moab::BVHTree::convert_tree | ( | std::vector< Node > & | tree_nodes | ) | [private] |
Definition at line 94 of file BVHTree.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), moab::ReadUtilIface::create_entity_sets(), ErrorCode, moab::Range::insert(), MB_SUCCESS, moab::Tree::mbImpl, moab::Tree::meshsetFlags, myTree, moab::Interface::query_interface(), moab::Interface::release_interface(), and startSetHandle.
// first construct the proper number of entity sets
ReadUtilIface* read_util;
ErrorCode rval = mbImpl->query_interface( read_util );
{ // isolate potentially-large std::vector so it gets deleted earlier
std::vector< unsigned int > tmp_flags( tree_nodes.size(), meshsetFlags );
rval = read_util->create_entity_sets( tree_nodes.size(), &tmp_flags[0], 0, startSetHandle );
rval = mbImpl->release_interface( read_util );
// populate the sets and the TreeNode vector
EntityHandle set_handle = startSetHandle;
std::vector< Node >::iterator it;
myTree.reserve( tree_nodes.size() );
for( it = tree_nodes.begin(); it != tree_nodes.end(); ++it, set_handle++ )
if( it != tree_nodes.begin() && !it->entities.empty() )
Range range;
for( HandleDataVec::iterator hit = it->entities.begin(); hit != it->entities.end(); ++hit )
range.insert( hit->myHandle );
rval = mbImpl->add_entities( set_handle, range );
myTree.push_back( TreeNode( it->dim, it->child, it->Lmax, it->Rmin, it->box ) );
if( it->dim != 3 )
rval = mbImpl->add_child_meshset( set_handle, startSetHandle + it->child );
rval = mbImpl->add_child_meshset( set_handle, startSetHandle + it->child + 1 );
return MB_SUCCESS;
| ErrorCode moab::BVHTree::distance_search | ( | const double | from_point[3], |
| const double | distance, | ||
| std::vector< EntityHandle > & | result_list, | ||
| const double | inside_tol = 1.0e-6, |
| std::vector< double > * | result_dists = NULL, |
| std::vector< CartVect > * | result_params = NULL, |
| EntityHandle * | tree_root = NULL |
| ) | [virtual] |
| from_point | Point to be located in tree |
| distance | Distance within which to query |
| result_list | Leaves within distance or containing point |
| iter_tol | Tolerance for convergence of point search |
| inside_tol | Tolerance for inside element calculation |
| result_dists | If non-NULL, will contain distsances to leaves |
| result_params | If non-NULL, will contain parameters of the point in the ents in leaves_out |
| tree_root | Start from this tree node (non-NULL) instead of tree root (NULL) |
Definition at line 646 of file BVHTree.cpp.
References moab::CartVect::array(), child, dim, moab::BoundBox::distance_squared(), ErrorCode, moab::ElemEvaluator::find_containing_entity(), get_bounding_box(), moab::TreeStats::leavesVisited, moab::Tree::maxDepth, MB_SUCCESS, moab::Tree::myEval, moab::Tree::myRoot, myTree, moab::TreeStats::nodesVisited, moab::TreeStats::numTraversals, startSetHandle, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
// non-NULL root should be in tree
// convoluted check because the root is different from startSetHandle
EntityHandle this_set = ( tree_root ? *tree_root : startSetHandle );
if( this_set != myRoot && ( this_set < startSetHandle || this_set >= startSetHandle + myTree.size() ) )
return MB_FAILURE;
else if( this_set == myRoot )
this_set = startSetHandle;
const double dist_sqr = distance * distance;
const CartVect from( from_point );
std::vector< EntityHandle > candidates; // list of subtrees to traverse
// pre-allocate space for default max tree depth
candidates.reserve( maxDepth );
// misc temporary values
ErrorCode rval;
BoundBox box;
candidates.push_back( this_set - startSetHandle );
while( !candidates.empty() )
EntityHandle ind = candidates.back();
this_set = startSetHandle + ind;
candidates.pop_back();
treeStats.nodesVisited++;
if( myTree[ind].dim == 3 ) treeStats.leavesVisited++;
// test box of this node
rval = get_bounding_box( box, &this_set );
double d_sqr = box.distance_squared( from_point );
// if greater than cutoff, continue
if( d_sqr > dist_sqr ) continue;
// else if not a leaf, test children & put on list
else if( myTree[ind].dim != 3 )
candidates.push_back( myTree[ind].child );
candidates.push_back( myTree[ind].child + 1 );
continue;
if( myEval && result_params )
EntityHandle ent;
CartVect params;
rval = myEval->find_containing_entity( startSetHandle + ind, from_point, iter_tol, inside_tol, ent,
return rval;
else if( ent )
result_list.push_back( ent );
result_params->push_back( params );
if( result_dists ) result_dists->push_back( 0.0 );
else
// leaf node within distance; return in list
result_list.push_back( this_set );
if( result_dists ) result_dists->push_back( sqrt( d_sqr ) );
return MB_SUCCESS;
| void moab::BVHTree::establish_buckets | ( | HandleDataVec::const_iterator | begin, |
| HandleDataVec::const_iterator | end, | ||
| const BoundBox & | interval, | ||
| std::vector< std::vector< Bucket > > & | buckets | ||
| ) | const [private] |
Definition at line 150 of file BVHTree.cpp.
References moab::BVHTree::Bucket::boundingBox, moab::BVHTree::Bucket::bucket_index(), dim, moab::BoundBox::intersects_box(), moab::BVHTree::Bucket::mySize, size, splitsPerDir, and moab::BoundBox::update().
// put each element into its bucket
for( HandleDataVec::const_iterator i = begin; i != end; ++i )
const BoundBox& box = i->myBox;
for( unsigned int dim = 0; dim < 3; ++dim )
const unsigned int index = Bucket::bucket_index( splitsPerDir, box, interval, dim );
assert( index < buckets[dim].size() );
Bucket& bucket = buckets[dim][index];
if( bucket.mySize > 0 )
bucket.boundingBox.update( box );
else
bucket.boundingBox = box;
bucket.mySize++;
#ifndef NDEBUG
BoundBox elt_union = begin->myBox;
elt_union.update( box );
if( !bucket.boundingBox.intersects_box( box ) ) std::cerr << "Buckets not covering elements!" << std::endl;
if( !elt_union.intersects_box( interval ) )
std::cout << "element union: " << std::endl << elt_union;
std::cout << "intervals: " << std::endl << interval;
std::cout << "union of elts does not contain original box!" << std::endl;
if( !interval.intersects_box( elt_union ) )
std::cout << "original box does not contain union of elts" << std::endl;
std::cout << interval << std::endl << elt_union << std::endl;
for( unsigned int d = 0; d < 3; ++d )
std::vector< unsigned int > nonempty;
const std::vector< Bucket >& buckets_ = buckets[d];
unsigned int j = 0;
for( std::vector< Bucket >::const_iterator i = buckets_.begin(); i != buckets_.end(); ++i, ++j )
if( i->mySize > 0 )
nonempty.push_back( j );
BoundBox test_box = buckets_[nonempty.front()].boundingBox;
for( unsigned int i = 0; i < nonempty.size(); ++i )
test_box.update( buckets_[nonempty[i]].boundingBox );
if( !test_box.intersects_box( interval ) )
std::cout << "union of buckets in dimension: " << d << "does not contain original box!" << std::endl;
if( !interval.intersects_box( test_box ) )
std::cout << "original box does "
<< "not contain union of buckets"
<< "in dimension: " << d << std::endl;
std::cout << interval << std::endl << test_box << std::endl;
#endif
| ErrorCode moab::BVHTree::find_point | ( | const std::vector< double > & | point, |
| const unsigned int & | index, | ||
| const double | iter_tol, | ||
| const double | inside_tol, | ||
| std::pair< EntityHandle, CartVect > & | result | ||
| ) | [private] |
Definition at line 466 of file BVHTree.cpp.
References moab::CartVect::array(), moab::Range::begin(), children, moab::BVHTree::TreeNode::dim, moab::Range::end(), entities, ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::TreeStats::leavesVisited, moab::BVHTree::TreeNode::Lmax, MB_SUCCESS, moab::Tree::mbImpl, moab::Tree::myEval, myTree, moab::TreeStats::nodesVisited, moab::TreeStats::numTraversals, moab::ElemEvaluator::reverse_eval(), moab::BVHTree::TreeNode::Rmin, moab::ElemEvaluator::set_ent_handle(), startSetHandle, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
if( index == 0 ) treeStats.numTraversals++;
const TreeNode& node = myTree[index];
CartVect params;
int is_inside;
if( node.dim == 3 )
Range entities;
rval = mbImpl->get_entities_by_handle( startSetHandle + index, entities );
treeStats.traversalLeafObjectTests++;
myEval->set_ent_handle( *i );
myEval->reverse_eval( &point[0], iter_tol, inside_tol, params.array(), &is_inside );
if( is_inside )
result.first = *i;
result.second = params;
return MB_SUCCESS;
result.first = 0;
return MB_SUCCESS;
// the extra tol here considers the case where
// 0 < Rmin - Lmax < 2tol
std::vector< EntityHandle > children;
rval = mbImpl->get_child_meshsets( startSetHandle + index, children );
if( MB_SUCCESS != rval || children.size() != 2 ) return rval;
if( ( node.Lmax + iter_tol ) < ( node.Rmin - iter_tol ) )
if( point[node.dim] <= ( node.Lmax + iter_tol ) )
return find_point( point, children[0] - startSetHandle, iter_tol, inside_tol, result );
else if( point[node.dim] >= ( node.Rmin - iter_tol ) )
return find_point( point, children[1] - startSetHandle, iter_tol, inside_tol, result );
result = std::make_pair( 0, CartVect( &point[0] ) ); // point lies in empty space.
return MB_SUCCESS;
// Boxes overlap
// left of Rmin, you must be on the left
// we can't be sure about the boundaries since the boxes overlap
// this was a typo in the paper which caused pain.
if( point[node.dim] < ( node.Rmin - iter_tol ) )
// if you are on the right Lmax, you must be on the right
else if( point[node.dim] > ( node.Lmax + iter_tol ) )
/* pg5 of paper
* However, instead of always traversing either subtree
* first (e.g. left always before right), we first traverse
* the subtree whose bounding plane has the larger distance to the
* sought point. This results in less overall traversal, and the correct
* cell is identified more quickly.
// So far all testing confirms that this 'heuristic' is
// significantly slower.
// I conjecture this is because it gets improperly
// branch predicted..
// bool dir = (point[ node.dim] - node.Rmin) <=
// (node.Lmax - point[ node.dim]);
if( result.first == 0 )
return MB_SUCCESS;
| void moab::BVHTree::find_split | ( | HandleDataVec::iterator & | begin, |
| HandleDataVec::iterator & | end, | ||
Definition at line 320 of file BVHTree.cpp.
References moab::BVHTree::SplitData::boundingBox, choose_best_split(), moab::BVHTree::SplitData::dim, establish_buckets(), initialize_splits(), moab::BoundBox::intersects_box(), left_box, moab::BVHTree::SplitData::leftBox, moab::BVHTree::SplitData::Lmax, median_order(), moab::BVHTree::SplitData::nl, moab::BVHTree::SplitData::nr, order_elements(), right_box, moab::BVHTree::SplitData::rightBox, moab::BVHTree::SplitData::Rmin, splitsPerDir, and moab::BoundBox::update().
Referenced by local_build_tree().
std::vector< std::vector< Bucket > > buckets( 3, std::vector< Bucket >( splitsPerDir + 1 ) );
std::vector< std::vector< SplitData > > splits( 3, std::vector< SplitData >( splitsPerDir, data ) );
const BoundBox interval = data.boundingBox;
establish_buckets( begin, end, interval, buckets );
initialize_splits( splits, buckets, data );
choose_best_split( splits, data );
const bool use_median = ( 0 == data.nl ) || ( data.nr == 0 );
if( !use_median )
order_elements( begin, end, data );
else
median_order( begin, end, data );
#ifndef NDEBUG
bool seen_one = false, issue = false;
bool first_left = true, first_right = true;
unsigned int count_left = 0, count_right = 0;
BoundBox left_box, right_box;
for( HandleDataVec::iterator i = begin; i != end; ++i )
int order = i->myDim;
if( order != 0 && order != 1 )
std::cerr << "Invalid order element !";
std::cerr << order << std::endl;
std::exit( -1 );
if( order == 1 )
seen_one = 1;
count_right++;
if( first_right )
right_box = i->myBox;
first_right = false;
else
right_box.update( i->myBox );
if( !right_box.intersects_box( i->myBox ) )
if( !issue )
std::cerr << "Bounding right box issue!" << std::endl;
issue = true;
if( order == 0 )
count_left++;
if( first_left )
left_box = i->myBox;
first_left = false;
else
left_box.update( i->myBox );
if( !data.leftBox.intersects_box( i->myBox ) )
if( !issue )
std::cerr << "Bounding left box issue!" << std::endl;
issue = true;
if( seen_one )
std::cerr << "Invalid ordering!" << std::endl;
std::cout << ( i - 1 )->myDim << order << std::endl;
exit( -1 );
if( !left_box.intersects_box( data.leftBox ) ) std::cout << "left elts do not contain left box" << std::endl;
if( !data.leftBox.intersects_box( left_box ) ) std::cout << "left box does not contain left elts" << std::endl;
if( !right_box.intersects_box( data.rightBox ) ) std::cout << "right elts do not contain right box" << std::endl;
if( !data.rightBox.intersects_box( right_box ) ) std::cout << "right box do not contain right elts" << std::endl;
if( count_left != data.nl || count_right != data.nr )
std::cerr << "counts are off!" << std::endl;
std::cerr << "total: " << std::distance( begin, end ) << std::endl;
std::cerr << "Dim: " << data.dim << std::endl;
std::cerr << data.Lmax << " , " << data.Rmin << std::endl;
std::cerr << "Right box: " << std::endl << data.rightBox << "Left box: " << std::endl << data.leftBox;
std::cerr << "supposed to be: " << data.nl << " " << data.nr << std::endl;
std::cerr << "accountant says: " << count_left << " " << count_right << std::endl;
std::exit( -1 );
#endif
| ErrorCode moab::BVHTree::get_bounding_box | ( | BoundBox & | box, |
| EntityHandle * | tree_node = NULL |
| ) | const [virtual] |
| box | The box for this tree |
| tree_node | If non-NULL, node for which box is requested, tree root if NULL |
Reimplemented from moab::Tree.
Definition at line 571 of file BVHTree.cpp.
References moab::Tree::boundBox, MB_SUCCESS, myTree, and startSetHandle.
Referenced by distance_search(), and point_search().
if( !tree_node || *tree_node == startSetHandle )
box = boundBox;
return MB_SUCCESS;
else if( ( tree_node && !startSetHandle ) || *tree_node < startSetHandle ||
*tree_node - startSetHandle > myTree.size() )
return MB_FAILURE;
box = myTree[*tree_node - startSetHandle].box;
return MB_SUCCESS;
| void moab::BVHTree::initialize_splits | ( | std::vector< std::vector< SplitData > > & | splits, |
| const std::vector< std::vector< Bucket > > & | buckets, | ||
| const SplitData & | data | ||
Definition at line 225 of file BVHTree.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, moab::BVHTree::SplitData::boundingBox, moab::BoundBox::intersects_box(), set_interval(), and moab::BoundBox::update().
std::vector< SplitData >::iterator splits_begin = splits[d].begin();
std::vector< SplitData >::iterator splits_end = splits[d].end();
std::vector< Bucket >::const_iterator left_begin = buckets[d].begin();
std::vector< Bucket >::const_iterator _end = buckets[d].end();
std::vector< Bucket >::const_iterator left_end = buckets[d].begin() + 1;
for( std::vector< SplitData >::iterator s = splits_begin; s != splits_end; ++s, ++left_end )
s->nl = set_interval( s->leftBox, left_begin, left_end );
if( s->nl == 0 )
s->leftBox = data.boundingBox;
s->leftBox.bMax[d] = s->leftBox.bMin[d];
s->nr = set_interval( s->rightBox, left_end, _end );
if( s->nr == 0 )
s->rightBox = data.boundingBox;
s->rightBox.bMin[d] = s->rightBox.bMax[d];
s->Lmax = s->leftBox.bMax[d];
s->Rmin = s->rightBox.bMin[d];
s->split = std::distance( splits_begin, s );
s->dim = d;
#ifndef NDEBUG
for( std::vector< SplitData >::iterator s = splits_begin; s != splits_end; ++s )
BoundBox test_box = s->leftBox;
test_box.update( s->rightBox );
if( !data.boundingBox.intersects_box( test_box ) )
std::cout << "nr: " << s->nr << std::endl;
std::cout << "Test box: " << std::endl << test_box;
std::cout << "Left box: " << std::endl << s->leftBox;
std::cout << "Right box: " << std::endl << s->rightBox;
std::cout << "Interval: " << std::endl << data.boundingBox;
std::cout << "Split boxes larger than bb" << std::endl;
if( !test_box.intersects_box( data.boundingBox ) )
std::cout << "bb larger than union of split boxes" << std::endl;
#endif
| int moab::BVHTree::local_build_tree | ( | std::vector< Node > & | tree_nodes, |
| HandleDataVec::iterator | begin, | ||
| HandleDataVec::iterator | end, | ||
| const int | index, | ||
| const BoundBox & | box, | ||
| const int | depth = 0 |
| ) | [private] |
Definition at line 418 of file BVHTree.cpp.
References moab::BVHTree::SplitData::boundingBox, moab::BVHTree::SplitData::dim, entities, find_split(), moab::BoundBox::intersects_box(), moab::BVHTree::SplitData::leftBox, moab::BVHTree::SplitData::Lmax, moab::Tree::maxDepth, moab::Tree::maxPerLeaf, moab::BVHTree::SplitData::nl, moab::BVHTree::SplitData::rightBox, and moab::BVHTree::SplitData::Rmin.
#ifndef NDEBUG
if( !box.intersects_box( i->myBox, 0 ) )
std::cerr << "depth: " << depth << std::endl;
std::cerr << "BB:" << box << "EB:" << i->myBox << std::endl;
std::exit( -1 );
#endif
const unsigned int total_num_elements = std::distance( begin, end );
tree_nodes[index].box = box;
// logic for splitting conditions
if( (int)total_num_elements > maxPerLeaf && depth < maxDepth )
SplitData data;
data.boundingBox = box;
find_split( begin, end, data );
// assign data to node
tree_nodes[index].Lmax = data.Lmax;
tree_nodes[index].Rmin = data.Rmin;
tree_nodes[index].dim = data.dim;
tree_nodes[index].child = tree_nodes.size();
// insert left, right children;
const int left_depth =
local_build_tree( tree_nodes, begin, begin + data.nl, tree_nodes[index].child, data.leftBox, depth + 1 );
const int right_depth =
local_build_tree( tree_nodes, begin + data.nl, end, tree_nodes[index].child + 1, data.rightBox, depth + 1 );
return std::max( left_depth, right_depth );
tree_nodes[index].dim = 3;
std::copy( begin, end, std::back_inserter( tree_nodes[index].entities ) );
return depth;
| void moab::BVHTree::median_order | ( | HandleDataVec::iterator & | begin, |
Definition at line 278 of file BVHTree.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, moab::BVHTree::SplitData::boundingBox, dim, moab::BVHTree::SplitData::dim, moab::BoundBox::intersects_box(), moab::BVHTree::SplitData::leftBox, moab::BVHTree::SplitData::Lmax, moab::BVHTree::SplitData::nl, moab::BVHTree::SplitData::nr, moab::BVHTree::SplitData::rightBox, moab::BVHTree::SplitData::Rmin, moab::BVHTree::SplitData::split, and moab::BoundBox::update().
int dim = data.dim;
i->myDim = 0.5 * ( i->myBox.bMin[dim], i->myBox.bMax[dim] );
std::sort( begin, end, BVHTree::HandleData_comparator() );
const unsigned int total = std::distance( begin, end );
HandleDataVec::iterator middle = begin + ( total / 2 );
double middle_center = middle->myDim;
middle_center += ( ++middle )->myDim;
middle_center *= 0.5;
data.split = middle_center;
data.nl = std::distance( begin, middle ) + 1;
data.nr = total - data.nl;
++middle;
data.leftBox = begin->myBox;
data.rightBox = middle->myBox;
for( HandleDataVec::iterator i = begin; i != middle; ++i )
i->myDim = 0;
data.leftBox.update( i->myBox );
for( HandleDataVec::iterator i = middle; i != end; ++i )
i->myDim = 1;
data.rightBox.update( i->myBox );
data.Rmin = data.rightBox.bMin[data.dim];
data.Lmax = data.leftBox.bMax[data.dim];
#ifndef NDEBUG
BoundBox test_box( data.rightBox );
std::cerr << "MEDIAN: BB Does not contain splits" << std::endl;
std::cerr << "test_box: " << test_box << std::endl;
std::cerr << "data.boundingBox: " << data.boundingBox << std::endl;
#endif
| void moab::BVHTree::order_elements | ( | HandleDataVec::iterator & | begin, |
Definition at line 386 of file BVHTree.hpp.
References moab::BVHTree::SplitData::boundingBox, moab::BVHTree::Bucket::bucket_index(), moab::BVHTree::SplitData::dim, moab::BVHTree::SplitData::split, and splitsPerDir.
const int index = Bucket::bucket_index( splitsPerDir, i->myBox, data.boundingBox, data.dim );
i->myDim = ( index <= data.split ) ? 0 : 1;
std::sort( begin, end, HandleData_comparator() );
| ErrorCode moab::BVHTree::parse_options | ( | FileOptions & | opts | ) | [virtual] |
| opts | Options |
Definition at line 137 of file BVHTree.cpp.
References ErrorCode, moab::FileOptions::get_int_option(), MB_SUCCESS, moab::Tree::parse_common_options(), and splitsPerDir.
ErrorCode rval = parse_common_options( opts );
// SPLITS_PER_DIR: number of candidate splits considered per direction; default = 3
int tmp_int;
rval = opts.get_int_option( "SPLITS_PER_DIR", tmp_int );
if( MB_SUCCESS == rval ) splitsPerDir = tmp_int;
return MB_SUCCESS;
| ErrorCode moab::BVHTree::point_search | ( | const double * | point, |
| EntityHandle & | leaf_out, | ||
| bool * | multiple_leaves = NULL, |
| EntityHandle * | start_node = NULL, |
| CartVect * | params = NULL |
| ) | [virtual] |
Does not take into account global bounding box of tree.
| leaf_out | Leaf containing point |
| multiple_leaves | Some tree types can have multiple leaves containing a point; if non-NULL, this parameter is returned true if multiple leaves contain the input point |
| start_node | Start from this tree node (non-NULL) instead of tree root (NULL) |
Definition at line 586 of file BVHTree.cpp.
References moab::CartVect::array(), child, moab::BoundBox::contains_point(), dim, ErrorCode, moab::ElemEvaluator::find_containing_entity(), get_bounding_box(), moab::TreeStats::leavesVisited, MB_SUCCESS, moab::Tree::myEval, moab::Tree::myRoot, myTree, moab::TreeStats::nodesVisited, moab::TreeStats::numTraversals, startSetHandle, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
EntityHandle this_set = ( start_node ? *start_node : startSetHandle );
return MB_FAILURE;
std::vector< EntityHandle > candidates,
result_list; // list of subtrees to traverse, and results
BoundBox box;
ErrorCode rval = get_bounding_box( box, &this_set );
if( !box.contains_point( point, iter_tol ) ) continue;
continue;
else if( myTree[ind].dim == 3 && myEval && params )
rval = myEval->find_containing_entity( startSetHandle + ind, point, iter_tol, inside_tol, leaf_out,
params->array(), &treeStats.traversalLeafObjectTests );
if( leaf_out || MB_SUCCESS != rval ) return rval;
else
if( !result_list.empty() ) leaf_out = result_list[0];
if( multiple_leaves && result_list.size() > 1 ) *multiple_leaves = true;
return MB_SUCCESS;
| ErrorCode moab::BVHTree::print | ( | ) | [virtual] |
Definition at line 740 of file BVHTree.cpp.
References MB_SUCCESS, and myTree.
int i;
std::vector< TreeNode >::iterator it;
for( it = myTree.begin(), i = 0; it != myTree.end(); ++it, i++ )
std::cout << "Node " << i << ": dim = " << it->dim << ", child = " << it->child << ", Lmax/Rmin = " << it->Lmax
<< "/" << it->Rmin << ", box = " << it->box << std::endl;
return MB_SUCCESS;
| ErrorCode moab::BVHTree::print_nodes | ( | std::vector< Node > & | nodes | ) | [private] |
Definition at line 728 of file BVHTree.cpp.
References MB_SUCCESS.
int i;
for( it = nodes.begin(), i = 0; it != nodes.end(); ++it, i++ )
return MB_SUCCESS;
| ErrorCode moab::BVHTree::reset_tree | ( | ) | [inline, virtual] |
| root | If non-NULL, check that this is the root, return failure if not |
Definition at line 440 of file BVHTree.hpp.
References moab::Tree::delete_tree_sets().
Referenced by ~BVHTree().
return delete_tree_sets();
| unsigned int moab::BVHTree::set_interval | ( | BoundBox & | interval, |
| std::vector< Bucket >::const_iterator | begin, | ||
| std::vector< Bucket >::const_iterator | end | ||
Definition at line 362 of file BVHTree.hpp.
References moab::GeomUtil::first(), and moab::BoundBox::update().
Referenced by initialize_splits().
bool first = true;
unsigned int count = 0;
for( std::vector< Bucket >::const_iterator b = begin; b != end; ++b )
const BoundBox& box = b->boundingBox;
count += b->mySize;
if( b->mySize != 0 )
if( first )
interval = box;
first = false;
else
interval.update( box );
return count;
Range moab::BVHTree::entityHandles [private] |
Definition at line 323 of file BVHTree.hpp.
std::vector< TreeNode > moab::BVHTree::myTree [private] |
Definition at line 324 of file BVHTree.hpp.
Referenced by bruteforce_find(), convert_tree(), distance_search(), find_point(), get_bounding_box(), point_search(), and print().
int moab::BVHTree::splitsPerDir [private] |
Definition at line 325 of file BVHTree.hpp.
Referenced by establish_buckets(), find_split(), order_elements(), and parse_options().
EntityHandle moab::BVHTree::startSetHandle [private] |
Definition at line 326 of file BVHTree.hpp.
Referenced by bruteforce_find(), build_tree(), convert_tree(), distance_search(), find_point(), get_bounding_box(), and point_search().
const char * moab::BVHTree::treeName = "BVHTree" [static, private] |
Definition at line 327 of file BVHTree.hpp.
Referenced by BVHTree().
