Mesh Oriented datABase
(version 5.4.1)
#include <spectral_hex_map.hpp>
Inheritance diagram for moab::element_utility::Spectral_hex_map< _Matrix >:
Collaboration diagram for moab::element_utility::Spectral_hex_map< _Matrix >:Public Member Functions | |
| Spectral_hex_map () | |
| Spectral_hex_map (int order) | |
| Spectral_hex_map (const Self &f) | |
| template<typename Moab , typename Entity_handle , typename Points , typename Point > | |
| std::pair< bool, Point > | operator() (const Moab &, const Entity_handle &, const Points &v, const Point &p, const double tol=1.e-6) |
Static Public Member Functions | |
| typedef _Matrix | Matrix |
Private Types | |
| typedef Spectral_hex_map< Matrix > | Self |
Private Member Functions | |
| void | initialize_spectral_hex (int order) |
| void | free_data () |
| void | set_gl_points (double *x, double *y, double *z) |
| template<typename Point > | |
| bool | is_contained (const Point &p, const double tol) const |
| template<typename Point , typename Points > | |
| bool | solve_inverse (const Point &x, Point &xi, const Points &points, const double tol=1.e-6) |
| Point & | evaluate (const Point &p, const Points &, Point &f) |
| template<typename Point , typename Field > | |
| double | evaluate_scalar_field (const Point &p, const Field &field) const |
| template<typename Points , typename Field > | |
| double | integrate_scalar_field (const Points &p, const Field &field) const |
| Matrix & | jacobian (const Point &, const Points &, Matrix &J) |
Private Attributes | |
| bool | _init |
| int | _n |
| real * | _z [3] |
| lagrange_data | _ld [3] |
| opt_data_3 | _data |
| real * | _odwork |
| real * | _xyz [3] |
Definition at line 22 of file spectral_hex_map.hpp.
typedef _Matrix moab::element_utility::Spectral_hex_map< _Matrix >::Matrix [static] |
Definition at line 25 of file spectral_hex_map.hpp.
typedef Spectral_hex_map< Matrix > moab::element_utility::Spectral_hex_map< _Matrix >::Self [private] |
Definition at line 28 of file spectral_hex_map.hpp.
| moab::element_utility::Spectral_hex_map< _Matrix >::Spectral_hex_map | ( | ) | [inline] |
Definition at line 32 of file spectral_hex_map.hpp.
| moab::element_utility::Spectral_hex_map< _Matrix >::Spectral_hex_map | ( | int | order | ) | [inline] |
Definition at line 33 of file spectral_hex_map.hpp.
initialize_spectral_hex( order );
| moab::element_utility::Spectral_hex_map< _Matrix >::Spectral_hex_map | ( | const Self & | f | ) | [inline] |
Definition at line 38 of file spectral_hex_map.hpp.
| Point& moab::element_utility::Spectral_hex_map< _Matrix >::evaluate | ( | const Point & | p, |
| const Points & | , | ||
| Point & | f | ||
| ) | [inline, private] |
Definition at line 160 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::solve_inverse().
| double moab::element_utility::Spectral_hex_map< _Matrix >::evaluate_scalar_field | ( | const Point & | p, |
| const Field & | field | ||
| ) | const [inline, private] |
| void moab::element_utility::Spectral_hex_map< _Matrix >::free_data | ( | ) | [inline, private] |
Definition at line 63 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex().
for( int d = 0; d < 3; d++ )
free( _z[d] );
lagrange_free( &_ld[d] );
opt_free_3( &_data );
free( _odwork );
| void moab::element_utility::Spectral_hex_map< _Matrix >::initialize_spectral_hex | ( | int | order | ) | [inline, private] |
Definition at line 41 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::Spectral_hex_map().
if( _init && _n == order )
return;
if( _init && _n != order )
free_data();
_init = true;
_n = order;
lobatto_nodes( _z[d], _n );
lagrange_setup( &_ld[d], _z[d], _n );
opt_alloc_3( &_data, _ld );
std::size_t nf = _n * _n, ne = _n, nw = 2 * _n * _n + 3 * _n;
_odwork = tmalloc( real, 6 * nf + 9 * ne + nw );
| double moab::element_utility::Spectral_hex_map< _Matrix >::integrate_scalar_field | ( | const Points & | p, |
Definition at line 184 of file spectral_hex_map.hpp.
// set the position of GL points
// set the positions of GL nodes, before evaluations
_data.elx[0] = _xyz[0];
_data.elx[1] = _xyz[1];
_data.elx[2] = _xyz[2];
double xi[3];
// triple loop; the most inner loop is in r direction, then s, then t
double integral = 0.;
// double volume = 0;
int index = 0; // used fr the inner loop
for( int k = 0; k < _n; k++ )
xi[2] = _ld[2].z[k];
// double wk= _ld[2].w[k];
for( int j = 0; j < _n; j++ )
xi[1] = _ld[1].z[j];
// double wj= _ld[1].w[j];
for( int i = 0; i < _n; i++ )
xi[0] = _ld[0].z[i];
// double wi= _ld[0].w[i];
opt_vol_set_intp_3( (opt_data_3*)&_data, xi ); // cast away const-ness
double wk = _ld[2].J[k];
double wj = _ld[1].J[j];
double wi = _ld[0].J[i];
Matrix3 J( 0. );
for( int n = 0; n < 8; n++ )
J( n / 3, n % 3 ) = _data.jac[n];
double bm = wk * wj * wi * J.determinant();
integral += bm * field[index++];
// volume +=bm;
// std::cout << "volume: " << volume << "\n";
return integral;
| bool moab::element_utility::Spectral_hex_map< _Matrix >::is_contained | ( | const Point & | p, |
| const double | tol | ||
Definition at line 101 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::operator()().
// just look at the box+tol here
return ( p[0] >= -1. - tol ) && ( p[0] <= 1. + tol ) && ( p[1] >= -1. - tol ) && ( p[1] <= 1. + tol ) &&
( p[2] >= -1. - tol ) && ( p[2] <= 1. + tol );
| Matrix& moab::element_utility::Spectral_hex_map< _Matrix >::jacobian | ( | const Point & | , |
| Matrix & | J | ||
Definition at line 226 of file spectral_hex_map.hpp.
| std::pair< bool, Point > moab::element_utility::Spectral_hex_map< _Matrix >::operator() | ( | const Moab & | , |
| const Entity_handle & | , | ||
| const Points & | v, | ||
| const Point & | p, | ||
| const double | tol = 1.e-6 |
| ) | [inline] |
Definition at line 77 of file spectral_hex_map.hpp.
Point result( 3, 0.0 );
moab.tag_get_by_ptr(_xm1Tag, &eh, 1,(const void **) &_xyz[ 0] );
moab.tag_get_by_ptr(_ym1Tag, &eh, 1,(const void **) &_xyz[ 1] );
moab.tag_get_by_ptr(_zm1Tag, &eh, 1,(const void **) &_xyz[ 2] );
bool point_found = solve_inverse( p, result, v, tol ) && is_contained( result, tol );
return std::make_pair( point_found, result );
| void moab::element_utility::Spectral_hex_map< _Matrix >::set_gl_points | ( | double * | x, |
| double * | y, | ||
| double * | z | ||
Definition at line 94 of file spectral_hex_map.hpp.
| bool moab::element_utility::Spectral_hex_map< _Matrix >::solve_inverse | ( | const Point & | x, |
| Point & | xi, | ||
| const Points & | points, | ||
Definition at line 109 of file spectral_hex_map.hpp.
const double error_tol_sqr = tol * tol;
Point delta( 3, 0.0 );
xi = delta;
evaluate( xi, points, delta );
vec_subtract( delta, x );
std::size_t num_iterations = 0;
#ifdef SPECTRAL_HEX_DEBUG
std::stringstream ss;
ss << "Point: ";
ss << x[0] << ", " << x[1] << ", " << x[2] << std::endl;
ss << "Hex: ";
for( int i = 0; i < 8; ++i )
ss << points[i][0] << ", " << points[i][1] << ", " << points[i][2] << std::endl;
ss << std::endl;
#endif
while( normsq( delta ) > error_tol_sqr )
ss << "Iter #: " << num_iterations << " Err: " << sqrt( normsq( delta ) ) << " Iterate: ";
ss << xi[0] << ", " << xi[1] << ", " << xi[2] << std::endl;
#endif
if( ++num_iterations >= 5 )
return false;
Matrix J;
jacobian( xi, points, J );
double det = moab::Matrix::determinant3( J );
if( fabs( det ) < 1.e-10 )
std::cerr << ss.str();
#endif
#ifndef SPECTRAL_HEX_DEBUG
std::cerr << x[0] << ", " << x[1] << ", " << x[2] << std::endl;
#endif
std::cerr << "inverse solve failure: det: " << det << std::endl;
exit( -1 );
vec_subtract( xi, moab::Matrix::inverse( J, 1.0 / det ) * delta );
return true;
opt_data_3 moab::element_utility::Spectral_hex_map< _Matrix >::_data [private] |
Definition at line 246 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::free_data(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::integrate_scalar_field(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::jacobian().
bool moab::element_utility::Spectral_hex_map< _Matrix >::_init [private] |
Definition at line 242 of file spectral_hex_map.hpp.
lagrange_data moab::element_utility::Spectral_hex_map< _Matrix >::_ld[3] [private] |
Definition at line 245 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate_scalar_field(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::free_data(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::integrate_scalar_field().
int moab::element_utility::Spectral_hex_map< _Matrix >::_n [private] |
Definition at line 243 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::integrate_scalar_field().
real* moab::element_utility::Spectral_hex_map< _Matrix >::_odwork [private] |
Definition at line 247 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate_scalar_field(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::free_data(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex().
real* moab::element_utility::Spectral_hex_map< _Matrix >::_xyz[3] [private] |
Definition at line 248 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::integrate_scalar_field(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::jacobian(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::set_gl_points().
real* moab::element_utility::Spectral_hex_map< _Matrix >::_z[3] [private] |
Definition at line 244 of file spectral_hex_map.hpp.
Referenced by moab::element_utility::Spectral_hex_map< moab::Matrix3 >::free_data(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex().
