Mesh Oriented datABase
(version 5.4.1)
An offline map between two Meshes. More...
#include <TempestOnlineMap.hpp>
Collaboration diagram for moab::TempestOnlineMap:Public Types | |
| enum | DiscretizationType { DiscretizationType_FV, DiscretizationType_CGLL, DiscretizationType_DGLL, DiscretizationType_PCLOUD } |
| typedef double(* | sample_function )(double, double) |
Public Member Functions | |
| TempestOnlineMap (moab::TempestRemapper *remapper) | |
| Generate the metadata associated with the offline map. | |
| virtual | ~TempestOnlineMap () |
| Define a virtual destructor. | |
| moab::ErrorCode | GenerateRemappingWeights (std::string strInputType, std::string strOutputType, const GenerateOfflineMapAlgorithmOptions &mapOptions, const std::string &srcDofTagName="GLOBAL_ID", const std::string &tgtDofTagName="GLOBAL_ID") |
| Generate the offline map, given the source and target mesh and discretization details. This method generates the mapping between the two meshes based on the overlap and stores the result in the SparseMatrix. | |
| moab::ErrorCode | ReadParallelMap (const char *strSource, const std::vector< int > &owned_dof_ids, bool row_major_ownership=true) |
| moab::ErrorCode | WriteParallelMap (const std::string &strTarget) |
| Write the TempestOnlineMap to a parallel NetCDF file. | |
| virtual int | IsConsistent (double dTolerance) |
| Determine if the map is first-order accurate. | |
| virtual int | IsConservative (double dTolerance) |
| Determine if the map is conservative. | |
| virtual int | IsMonotone (double dTolerance) |
| Determine if the map is monotone. | |
| const DataArray1D< double > & | GetGlobalSourceAreas () const |
| If we computed the reduction, get the vector representing the source areas for all entities in the mesh. | |
| const DataArray1D< double > & | GetGlobalTargetAreas () const |
| If we computed the reduction, get the vector representing the target areas for all entities in the mesh. | |
| moab::ErrorCode | SetDOFmapTags (const std::string srcDofTagName, const std::string tgtDofTagName) |
| Store the tag names associated with global DoF ids for source and target meshes. | |
| moab::ErrorCode | SetDOFmapAssociation (DiscretizationType srcType, bool isSrcContinuous, DataArray3D< int > *srcdataGLLNodes, DataArray3D< int > *srcdataGLLNodesSrc, DiscretizationType destType, bool isDestContinuous, DataArray3D< int > *tgtdataGLLNodes) |
| Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently. | |
| int | GetSourceGlobalNDofs () |
| Get the number of total Degrees-Of-Freedom defined on the source mesh. | |
| int | GetDestinationGlobalNDofs () |
| Get the number of total Degrees-Of-Freedom defined on the destination mesh. | |
| int | GetSourceLocalNDofs () |
| Get the number of local Degrees-Of-Freedom defined on the source mesh. | |
| int | GetDestinationLocalNDofs () |
| Get the number of local Degrees-Of-Freedom defined on the destination mesh. | |
| int | GetSourceNDofsPerElement () |
| Get the number of Degrees-Of-Freedom per element on the source mesh. | |
| int | GetDestinationNDofsPerElement () |
| Get the number of Degrees-Of-Freedom per element on the destination mesh. | |
| void | SetSourceNDofsPerElement (int ns) |
| Set the number of Degrees-Of-Freedom per element on the source mesh. | |
| void | SetDestinationNDofsPerElement (int nt) |
| int | GetRowGlobalDoF (int localID) const |
| Get the global Degrees-Of-Freedom ID on the destination mesh. | |
| int | GetIndexOfRowGlobalDoF (int globalRowDoF) const |
| Get the index of globaRowDoF. | |
| int | GetColGlobalDoF (int localID) const |
| Get the global Degrees-Of-Freedom ID on the source mesh. | |
| int | GetIndexOfColGlobalDoF (int globalColDoF) const |
| Get the index of globaColDoF. | |
| moab::ErrorCode | ApplyWeights (std::vector< double > &srcVals, std::vector< double > &tgtVals, bool transpose=false) |
Apply the weight matrix onto the source vector provided as input, and return the column vector (solution projection) after the map application Compute: tgtVals = A(S->T) * , or if (transpose) tgtVals = [A(T->S)]^T * . | |
| moab::ErrorCode | ApplyWeights (moab::Tag srcSolutionTag, moab::Tag tgtSolutionTag, bool transpose=false) |
Apply the weight matrix onto the source vector (tag) provided as input, and return the column vector (solution projection) in a tag, after the map application Compute: tgtVals = A(S->T) * , or if (transpose) tgtVals = [A(T->S)]^T * . | |
| moab::ErrorCode | DefineAnalyticalSolution (moab::Tag &exactSolnTag, const std::string &solnName, Remapper::IntersectionContext ctx, sample_function testFunction, moab::Tag *clonedSolnTag=NULL, std::string cloneSolnName="") |
| Define an analytical solution over the given (source or target) mesh, as specificed in the context. This routine will define a tag that is compatible with the specified discretization method type and order and sample the solution exactly using the analytical function provided by the user. | |
| moab::ErrorCode | ComputeMetrics (Remapper::IntersectionContext ctx, moab::Tag &exactTag, moab::Tag &approxTag, std::map< std::string, double > &metrics, bool verbose=true) |
| Compute the error between a sampled (exact) solution and a projected solution in various error norms. | |
| moab::ErrorCode | fill_row_ids (std::vector< int > &ids_of_interest) |
| moab::ErrorCode | fill_col_ids (std::vector< int > &ids_of_interest) |
| moab::ErrorCode | set_col_dc_dofs (std::vector< int > &values_entities) |
| moab::ErrorCode | set_row_dc_dofs (std::vector< int > &values_entities) |
Private Member Functions | |
| moab::ErrorCode | LinearRemapNN_MOAB (bool use_GID_matching=false, bool strict_check=false) |
| Compute the remapping weights as a permutation matrix that relates DoFs on the source mesh to DoFs on the target mesh. | |
| void | LinearRemapFVtoFV_Tempest_MOAB (int nOrder) |
| Compute the remapping weights for a FV field defined on the source to a FV field defined on the target mesh. | |
| void | LinearRemapSE0_Tempest_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian) |
| Generate the OfflineMap for linear conserative element-average spectral element to element average remapping. | |
| void | LinearRemapSE4_Tempest_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian, int nMonotoneType, bool fContinuousIn, bool fNoConservation) |
| Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping. | |
| void | LinearRemapFVtoGLL_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian, const DataArray1D< double > &dataGLLNodalArea, int nOrder, int nMonotoneType, bool fContinuous, bool fNoConservation) |
| Generate the OfflineMap for remapping from finite volumes to finite elements. | |
| void | LinearRemapGLLtoGLL2_MOAB (const DataArray3D< int > &dataGLLNodesIn, const DataArray3D< double > &dataGLLJacobianIn, const DataArray3D< int > &dataGLLNodesOut, const DataArray3D< double > &dataGLLJacobianOut, const DataArray1D< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut, bool fNoConservation) |
| Generate the OfflineMap for remapping from finite elements to finite elements. | |
| void | LinearRemapGLLtoGLL2_Pointwise_MOAB (const DataArray3D< int > &dataGLLNodesIn, const DataArray3D< double > &dataGLLJacobianIn, const DataArray3D< int > &dataGLLNodesOut, const DataArray3D< double > &dataGLLJacobianOut, const DataArray1D< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut) |
| Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation). | |
| moab::ErrorCode | WriteSCRIPMapFile (const std::string &strOutputFile) |
| Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections. | |
| moab::ErrorCode | WriteHDF5MapFile (const std::string &filename) |
| Parallel I/O with NetCDF to write out the SCRIP file from multiple processors. | |
| void | setup_sizes_dimensions () |
Private Attributes | |
| moab::TempestRemapper * | m_remapper |
| The fundamental remapping operator object. | |
| moab::Interface * | m_interface |
| The reference to the moab::Core object that contains source/target and overlap sets. | |
| moab::Tag | m_dofTagSrc |
| The original tag data and local to global DoF mapping to associate matrix values to solution. | |
| moab::Tag | m_dofTagDest |
| std::vector< unsigned > | row_gdofmap |
| std::vector< unsigned > | col_gdofmap |
| std::vector< unsigned > | srccol_gdofmap |
| std::vector< int > | row_dtoc_dofmap |
| std::vector< int > | col_dtoc_dofmap |
| std::vector< int > | srccol_dtoc_dofmap |
| std::map< int, int > | rowMap |
| std::map< int, int > | colMap |
| DataArray3D< int > | dataGLLNodesSrc |
| DataArray3D< int > | dataGLLNodesSrcCov |
| DataArray3D< int > | dataGLLNodesDest |
| DiscretizationType | m_srcDiscType |
| DiscretizationType | m_destDiscType |
| int | m_nTotDofs_Src |
| int | m_nTotDofs_SrcCov |
| int | m_nTotDofs_Dest |
| int | m_nDofsPEl_Src |
| int | m_nDofsPEl_Dest |
| DiscretizationType | m_eInputType |
| DiscretizationType | m_eOutputType |
| bool | m_bConserved |
| int | m_iMonotonicity |
| Mesh * | m_meshInput |
| Mesh * | m_meshInputCov |
| Mesh * | m_meshOutput |
| Mesh * | m_meshOverlap |
| bool | is_parallel |
| bool | is_root |
| int | rank |
| int | size |
| int | root_proc |
Definition at line 48 of file TempestOnlineMap.hpp.
| typedef double( * moab::TempestOnlineMap::sample_function)(double, double) |
Definition at line 347 of file TempestOnlineMap.hpp.
| DiscretizationType_FV | |
| DiscretizationType_CGLL | |
| DiscretizationType_DGLL | |
| DiscretizationType_PCLOUD |
Definition at line 64 of file TempestOnlineMap.hpp.
Definition at line 55 of file TempestOnlineMap.cpp.
References moab::Remapper::get_interface(), moab::TempestRemapper::GetCoveringMesh(), moab::TempestRemapper::GetMesh(), is_parallel, is_root, m_interface, m_meshInput, m_meshInputCov, m_meshOutput, m_meshOverlap, m_remapper, moab::Remapper::OverlapMesh, rank, root_proc, setup_sizes_dimensions(), size, moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
: OfflineMap(), m_remapper( remapper ) { // Get the references for the MOAB core objects m_interface = m_remapper->get_interface(); #ifdef MOAB_HAVE_MPI m_pcomm = m_remapper->get_parallel_communicator(); #endif // Update the references to the meshes m_meshInput = remapper->GetMesh( moab::Remapper::SourceMesh ); m_meshInputCov = remapper->GetCoveringMesh(); m_meshOutput = remapper->GetMesh( moab::Remapper::TargetMesh ); m_meshOverlap = remapper->GetMesh( moab::Remapper::OverlapMesh ); is_parallel = false; is_root = true; rank = 0; root_proc = rank; size = 1; #ifdef MOAB_HAVE_MPI int flagInit; MPI_Initialized( &flagInit ); if( flagInit ) { is_parallel = true; assert( m_pcomm != NULL ); rank = m_pcomm->rank(); size = m_pcomm->size(); is_root = ( rank == 0 ); } #endif // Compute and store the total number of source and target DoFs corresponding // to number of rows and columns in the mapping. // Initialize dimension information from file this->setup_sizes_dimensions(); // Build a matrix of source and target discretization so that we know how to assign // the global DoFs in parallel for the mapping weights // For example, FV->FV: rows X cols = faces_source X faces_target }
| moab::TempestOnlineMap::~TempestOnlineMap | ( | ) | [virtual] |
Definition at line 145 of file TempestOnlineMap.cpp.
m_interface = NULL;
m_pcomm = NULL;
#endif
m_meshInput = NULL;
m_meshOutput = NULL;
m_meshOverlap = NULL;
| moab::ErrorCode moab::TempestOnlineMap::ApplyWeights | ( | std::vector< double > & | srcVals, |
| std::vector< double > & | tgtVals, | ||
| bool | transpose = false |
Referenced by main().
| moab::ErrorCode moab::TempestOnlineMap::ApplyWeights | ( | moab::Tag | srcSolutionTag, |
| moab::Tag | tgtSolutionTag, | ||
Definition at line 1658 of file TempestOnlineMap.cpp.
References moab::Remapper::CoveringMesh, ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::size(), and moab::Remapper::TargetMesh.
moab::ErrorCode rval;
std::vector< double > solSTagVals;
std::vector< double > solTTagVals;
moab::Range sents, tents;
if( m_remapper->point_cloud_source || m_remapper->point_cloud_target )
if( m_remapper->point_cloud_source )
moab::Range& covSrcEnts = m_remapper->GetMeshVertices( moab::Remapper::CoveringMesh );
solSTagVals.resize( covSrcEnts.size(), -1.0 );
sents = covSrcEnts;
else
moab::Range& covSrcEnts = m_remapper->GetMeshEntities( moab::Remapper::CoveringMesh );
solSTagVals.resize( covSrcEnts.size() * this->GetSourceNDofsPerElement() * this->GetSourceNDofsPerElement(),
-1.0 );
sents = covSrcEnts;
if( m_remapper->point_cloud_target )
moab::Range& tgtEnts = m_remapper->GetMeshVertices( moab::Remapper::TargetMesh );
solTTagVals.resize( tgtEnts.size(), -1.0 );
tents = tgtEnts;
else
moab::Range& tgtEnts = m_remapper->GetMeshEntities( moab::Remapper::TargetMesh );
solTTagVals.resize(
tgtEnts.size() * this->GetDestinationNDofsPerElement() * this->GetDestinationNDofsPerElement(), -1.0 );
tents = tgtEnts;
else
-1.0 );
solTTagVals.resize(
sents = covSrcEnts;
tents = tgtEnts;
// The tag data is np*np*n_el_src
rval = m_interface->tag_get_data( srcSolutionTag, sents, &solSTagVals[0] );MB_CHK_SET_ERR( rval, "Getting local tag data failed" );
// Compute the application of weights on the suorce solution data and store it in the
// destination solution vector data Optionally, can also perform the transpose application of
// the weight matrix. Set the 3rd argument to true if this is needed
rval = this->ApplyWeights( solSTagVals, solTTagVals, transpose );MB_CHK_SET_ERR( rval, "Applying remap operator onto source vector data failed" );
// The tag data is np*np*n_el_dest
rval = m_interface->tag_set_data( tgtSolutionTag, tents, &solTTagVals[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
return moab::MB_SUCCESS;
| moab::ErrorCode moab::TempestOnlineMap::ComputeMetrics | ( | Remapper::IntersectionContext | ctx, |
| moab::Tag & | exactTag, | ||
| moab::Tag & | approxTag, | ||
| std::map< std::string, double > & | metrics, | ||
| bool | verbose = true |
Definition at line 2086 of file TempestOnlineMap.cpp.
References entities, moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, moab::Range::size(), moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
const bool outputEnabled = ( is_root );
int discOrder;
DiscretizationType discMethod;
moab::EntityHandle meshset;
moab::Range entities;
Mesh* trmesh;
switch( ctx )
case Remapper::SourceMesh:
meshset = m_remapper->m_covering_source_set;
trmesh = m_remapper->m_covering_source;
entities = ( m_remapper->point_cloud_source ? m_remapper->m_covering_source_vertices
: m_remapper->m_covering_source_entities );
discOrder = m_nDofsPEl_Src;
discMethod = m_eInputType;
break;
case Remapper::TargetMesh:
meshset = m_remapper->m_target_set;
trmesh = m_remapper->m_target;
entities =
( m_remapper->point_cloud_target ? m_remapper->m_target_vertices : m_remapper->m_target_entities );
discOrder = m_nDofsPEl_Dest;
discMethod = m_eOutputType;
break;
default:
if( outputEnabled )
std::cout << "Invalid context specified for defining an analytical solution tag" << std::endl;
return moab::MB_FAILURE;
// Let us create teh solution tag with appropriate information for name, discretization order
// (DoF space)
std::string exactTagName, projTagName;
const int ntotsize = entities.size() * discOrder * discOrder;
int ntotsize_glob = 0;
std::vector< double > exactSolution( ntotsize, 0.0 ), projSolution( ntotsize, 0.0 );
rval = m_interface->tag_get_name( exactTag, exactTagName );MB_CHK_ERR( rval );
rval = m_interface->tag_get_data( exactTag, entities, &exactSolution[0] );MB_CHK_ERR( rval );
rval = m_interface->tag_get_name( approxTag, projTagName );MB_CHK_ERR( rval );
rval = m_interface->tag_get_data( approxTag, entities, &projSolution[0] );MB_CHK_ERR( rval );
std::vector< double > errnorms( 3, 0.0 ), globerrnorms( 3, 0.0 ); // L1Err, L2Err, LinfErr
for( int i = 0; i < ntotsize; ++i )
const double error = fabs( exactSolution[i] - projSolution[i] );
errnorms[0] += error;
errnorms[1] += error * error;
errnorms[2] = ( error > errnorms[2] ? error : errnorms[2] );
if( m_pcomm )
MPI_Reduce( &ntotsize, &ntotsize_glob, 1, MPI_INT, MPI_SUM, 0, m_pcomm->comm() );
MPI_Reduce( &errnorms[0], &globerrnorms[0], 2, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
MPI_Reduce( &errnorms[2], &globerrnorms[2], 1, MPI_DOUBLE, MPI_MAX, 0, m_pcomm->comm() );
#else
ntotsize_glob = ntotsize;
globerrnorms = errnorms;
#endif
globerrnorms[0] = ( globerrnorms[0] / ntotsize_glob );
globerrnorms[1] = std::sqrt( globerrnorms[1] / ntotsize_glob );
metrics.clear();
metrics["L1Error"] = globerrnorms[0];
metrics["L2Error"] = globerrnorms[1];
metrics["LinfError"] = globerrnorms[2];
if( verbose && is_root )
std::cout << "Error metrics when comparing " << projTagName << " against " << exactTagName << std::endl;
std::cout << "\t L_1 error = " << globerrnorms[0] << std::endl;
std::cout << "\t L_2 error = " << globerrnorms[1] << std::endl;
std::cout << "\t L_inf error = " << globerrnorms[2] << std::endl;
| moab::ErrorCode moab::TempestOnlineMap::DefineAnalyticalSolution | ( | moab::Tag & | exactSolnTag, |
| const std::string & | solnName, | ||
| Remapper::IntersectionContext | ctx, | ||
| sample_function | testFunction, | ||
| moab::Tag * | clonedSolnTag = NULL, |
| std::string | cloneSolnName = "" |
Definition at line 1724 of file TempestOnlineMap.cpp.
References entities, ErrorCode, MB_CHK_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::Range::size(), moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
int discOrder;
Mesh* trmesh;
switch( ctx )
break;
entities =
break;
default:
if( outputEnabled )
// (DoF space)
rval = m_interface->tag_get_handle( solnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE, solnTag,
MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
if( clonedSolnTag != NULL )
if( cloneSolnName.size() == 0 )
cloneSolnName = solnName + std::string( "Cloned" );
rval = m_interface->tag_get_handle( cloneSolnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE,
*clonedSolnTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
// Triangular quadrature rule
const int TriQuadratureOrder = 10;
if( outputEnabled ) std::cout << "Using triangular quadrature of order " << TriQuadratureOrder << std::endl;
TriangularQuadratureRule triquadrule( TriQuadratureOrder );
const int TriQuadraturePoints = triquadrule.GetPoints();
const DataArray2D< double >& TriQuadratureG = triquadrule.GetG();
const DataArray1D< double >& TriQuadratureW = triquadrule.GetW();
// Output data
DataArray1D< double > dVar;
DataArray1D< double > dVarMB; // re-arranged local MOAB vector
// Nodal geometric area
DataArray1D< double > dNodeArea;
// Calculate element areas
// trmesh->CalculateFaceAreas(fContainsConcaveFaces);
if( discMethod == DiscretizationType_CGLL || discMethod == DiscretizationType_DGLL )
/* Get the spectral points and sample the functionals accordingly */
const bool fGLL = true;
const bool fGLLIntegrate = false;
// Generate grid metadata
DataArray3D< int > dataGLLNodes;
DataArray3D< double > dataGLLJacobian;
GenerateMetaData( *trmesh, discOrder, false, dataGLLNodes, dataGLLJacobian );
// Number of elements
int nElements = trmesh->faces.size();
// Verify all elements are quadrilaterals
for( int k = 0; k < nElements; k++ )
const Face& face = trmesh->faces[k];
if( face.edges.size() != 4 )
_EXCEPTIONT( "Non-quadrilateral face detected; "
"incompatible with --gll" );
// Number of unique nodes
int iMaxNode = 0;
for( int i = 0; i < discOrder; i++ )
for( int j = 0; j < discOrder; j++ )
if( dataGLLNodes[i][j][k] > iMaxNode )
iMaxNode = dataGLLNodes[i][j][k];
// Get Gauss-Lobatto quadrature nodes
DataArray1D< double > dG;
DataArray1D< double > dW;
GaussLobattoQuadrature::GetPoints( discOrder, 0.0, 1.0, dG, dW );
// Get Gauss quadrature nodes
const int nGaussP = 10;
DataArray1D< double > dGaussG;
DataArray1D< double > dGaussW;
GaussQuadrature::GetPoints( nGaussP, 0.0, 1.0, dGaussG, dGaussW );
// Allocate data
dVar.Allocate( iMaxNode );
dVarMB.Allocate( discOrder * discOrder * nElements );
dNodeArea.Allocate( iMaxNode );
// Sample data
// Sample data at GLL nodes
if( fGLL )
// Apply local map
Node node;
Node dDx1G;
Node dDx2G;
ApplyLocalMap( face, trmesh->nodes, dG[i], dG[j], node, dDx1G, dDx2G );
// Sample data at this point
double dNodeLon = atan2( node.y, node.x );
if( dNodeLon < 0.0 )
dNodeLon += 2.0 * M_PI;
double dNodeLat = asin( node.z );
double dSample = ( *testFunction )( dNodeLon, dNodeLat );
dVar[dataGLLNodes[j][i][k] - 1] = dSample;
// High-order Gaussian integration over basis function
else
DataArray2D< double > dCoeff( discOrder, discOrder );
for( int p = 0; p < nGaussP; p++ )
for( int q = 0; q < nGaussP; q++ )
// Apply local map
Node node;
Node dDx1G;
Node dDx2G;
ApplyLocalMap( face, trmesh->nodes, dGaussG[p], dGaussG[q], node, dDx1G, dDx2G );
// Cross product gives local Jacobian
Node nodeCross = CrossProduct( dDx1G, dDx2G );
double dJacobian =
sqrt( nodeCross.x * nodeCross.x + nodeCross.y * nodeCross.y + nodeCross.z * nodeCross.z );
// Find components of quadrature point in basis
// of the first Face
SampleGLLFiniteElement( 0, discOrder, dGaussG[p], dGaussG[q], dCoeff );
// Integrate
double dNodalArea = dCoeff[i][j] * dGaussW[p] * dGaussW[q] * dJacobian;
dVar[dataGLLNodes[i][j][k] - 1] += dSample * dNodalArea;
dNodeArea[dataGLLNodes[i][j][k] - 1] += dNodalArea;
// Divide by area
if( fGLLIntegrate )
for( size_t i = 0; i < dVar.GetRows(); i++ )
dVar[i] /= dNodeArea[i];
// Let us rearrange the data based on DoF ID specification
if( ctx == Remapper::SourceMesh )
for( unsigned j = 0; j < entities.size(); j++ )
for( int p = 0; p < discOrder; p++ )
for( int q = 0; q < discOrder; q++ )
const int offsetDOF = j * discOrder * discOrder + p * discOrder + q;
dVarMB[offsetDOF] = dVar[col_dtoc_dofmap[offsetDOF]];
else
dVarMB[offsetDOF] = dVar[row_dtoc_dofmap[offsetDOF]];
// Set the tag data
rval = m_interface->tag_set_data( solnTag, entities, &dVarMB[0] );MB_CHK_ERR( rval );
else
// assert( discOrder == 1 );
if( discMethod == DiscretizationType_FV )
/* Compute an element-wise integral to store the sampled solution based on Quadrature
* rules */
// Resize the array
dVar.Allocate( trmesh->faces.size() );
std::vector< Node >& nodes = trmesh->nodes;
// Loop through all Faces
for( size_t i = 0; i < trmesh->faces.size(); i++ )
const Face& face = trmesh->faces[i];
// Loop through all sub-triangles
for( size_t j = 0; j < face.edges.size() - 2; j++ )
const Node& node0 = nodes[face[0]];
const Node& node1 = nodes[face[j + 1]];
const Node& node2 = nodes[face[j + 2]];
// Triangle area
Face faceTri( 3 );
faceTri.SetNode( 0, face[0] );
faceTri.SetNode( 1, face[j + 1] );
faceTri.SetNode( 2, face[j + 2] );
double dTriangleArea = CalculateFaceArea( faceTri, nodes );
// Calculate the element average
double dTotalSample = 0.0;
// Loop through all quadrature points
for( int k = 0; k < TriQuadraturePoints; k++ )
Node node( TriQuadratureG[k][0] * node0.x + TriQuadratureG[k][1] * node1.x +
TriQuadratureG[k][2] * node2.x,
TriQuadratureG[k][0] * node0.y + TriQuadratureG[k][1] * node1.y +
TriQuadratureG[k][2] * node2.y,
TriQuadratureG[k][0] * node0.z + TriQuadratureG[k][1] * node1.z +
TriQuadratureG[k][2] * node2.z );
double dMagnitude = node.Magnitude();
node.x /= dMagnitude;
node.y /= dMagnitude;
node.z /= dMagnitude;
double dLon = atan2( node.y, node.x );
if( dLon < 0.0 )
dLon += 2.0 * M_PI;
double dLat = asin( node.z );
double dSample = ( *testFunction )( dLon, dLat );
dTotalSample += dSample * TriQuadratureW[k] * dTriangleArea;
dVar[i] += dTotalSample / trmesh->vecFaceArea[i];
rval = m_interface->tag_set_data( solnTag, entities, &dVar[0] );MB_CHK_ERR( rval );
else /* discMethod == DiscretizationType_PCLOUD */
/* Get the coordinates of the vertices and sample the functionals accordingly */
// Resize the array
dVar.Allocate( nodes.size() );
for( size_t j = 0; j < nodes.size(); j++ )
Node& node = nodes[j];
if( dLon < 0.0 )
dLon += 2.0 * M_PI;
dVar[j] = dSample;
| moab::ErrorCode moab::TempestOnlineMap::fill_col_ids | ( | std::vector< int > & | ids_of_interest | ) | [inline] |
Definition at line 382 of file TempestOnlineMap.hpp.
References col_gdofmap, and MB_SUCCESS.
ids_of_interest.reserve( col_gdofmap.size() );
// need to add 1
for( auto it = col_gdofmap.begin(); it != col_gdofmap.end(); it++ )
ids_of_interest.push_back( *it + 1 );
| moab::ErrorCode moab::TempestOnlineMap::fill_row_ids | ( | std::vector< int > & | ids_of_interest | ) | [inline] |
Definition at line 372 of file TempestOnlineMap.hpp.
References MB_SUCCESS, and row_gdofmap.
ids_of_interest.reserve( row_gdofmap.size() );
// need to add 1
for( auto it = row_gdofmap.begin(); it != row_gdofmap.end(); it++ )
| moab::ErrorCode moab::TempestOnlineMap::GenerateRemappingWeights | ( | std::string | strInputType, |
| std::string | strOutputType, | ||
| const GenerateOfflineMapAlgorithmOptions & | mapOptions, | ||
| const std::string & | srcDofTagName = "GLOBAL_ID", |
| const std::string & | tgtDofTagName = "GLOBAL_ID" |
the tag should be created already in the e3sm workflow; if not, create it here
Definition at line 731 of file TempestOnlineMap.cpp.
References dbgprint, moab::error(), ErrorCode, MB_ALREADY_ALLOCATED, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_DOUBLE, moab::Remapper::OverlapMesh, moab::DebugOutput::printf(), and moab::DebugOutput::set_prefix().
NcError error( NcError::silent_nonfatal );
moab::DebugOutput dbgprint( std::cout, rank, 0 );
dbgprint.set_prefix( "[TempestOnlineMap]: " );
const bool m_bPointCloudSource = ( m_remapper->point_cloud_source );
const bool m_bPointCloudTarget = ( m_remapper->point_cloud_target );
const bool m_bPointCloud = m_bPointCloudSource || m_bPointCloudTarget;
try
// Check command line parameters (data type arguments)
STLStringHelper::ToLower( strInputType );
STLStringHelper::ToLower( strOutputType );
DiscretizationType eInputType;
DiscretizationType eOutputType;
if( strInputType == "fv" )
eInputType = DiscretizationType_FV;
else if( strInputType == "cgll" )
eInputType = DiscretizationType_CGLL;
else if( strInputType == "dgll" )
eInputType = DiscretizationType_DGLL;
else if( strInputType == "pcloud" )
eInputType = DiscretizationType_PCLOUD;
else
_EXCEPTION1( "Invalid \"in_type\" value (%s), expected [fv|cgll|dgll]", strInputType.c_str() );
if( strOutputType == "fv" )
eOutputType = DiscretizationType_FV;
else if( strOutputType == "cgll" )
eOutputType = DiscretizationType_CGLL;
else if( strOutputType == "dgll" )
eOutputType = DiscretizationType_DGLL;
else if( strOutputType == "pcloud" )
eOutputType = DiscretizationType_PCLOUD;
else
_EXCEPTION1( "Invalid \"out_type\" value (%s), expected [fv|cgll|dgll]", strOutputType.c_str() );
// set all required input params
m_bConserved = !mapOptions.fNoConservation;
m_eInputType = eInputType;
m_eOutputType = eOutputType;
// Method flags
std::string strMapAlgorithm( "" );
int nMonotoneType = ( mapOptions.fMonotone ) ? ( 1 ) : ( 0 );
// Make an index of method arguments
std::set< std::string > setMethodStrings;
int iLast = 0;
for( size_t i = 0; i <= mapOptions.strMethod.length(); i++ )
if( ( i == mapOptions.strMethod.length() ) || ( mapOptions.strMethod[i] == ';' ) )
std::string strMethodString = mapOptions.strMethod.substr( iLast, i - iLast );
STLStringHelper::RemoveWhitespaceInPlace( strMethodString );
if( strMethodString.length() > 0 )
setMethodStrings.insert( strMethodString );
iLast = i + 1;
for( auto it : setMethodStrings )
// Piecewise constant monotonicity
if( it == "mono2" )
if( nMonotoneType != 0 )
_EXCEPTIONT( "Multiple monotonicity specifications found (--mono) or (--method \"mono#\")" );
if( ( m_eInputType == DiscretizationType_FV ) && ( m_eOutputType == DiscretizationType_FV ) )
_EXCEPTIONT( "--method \"mono2\" is only used when remapping to/from CGLL or DGLL grids" );
nMonotoneType = 2;
// Piecewise linear monotonicity
else if( it == "mono3" )
_EXCEPTIONT( "--method \"mono3\" is only used when remapping to/from CGLL or DGLL grids" );
nMonotoneType = 3;
// Volumetric remapping from FV to GLL
else if( it == "volumetric" )
if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType == DiscretizationType_FV ) )
_EXCEPTIONT( "--method \"volumetric\" may only be used for FV->CGLL or FV->DGLL remapping" );
strMapAlgorithm = "volumetric";
// Inverse distance mapping
else if( it == "invdist" )
if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
_EXCEPTIONT( "--method \"invdist\" may only be used for FV->FV remapping" );
strMapAlgorithm = "invdist";
// Delaunay triangulation mapping
else if( it == "delaunay" )
_EXCEPTIONT( "--method \"delaunay\" may only be used for FV->FV remapping" );
strMapAlgorithm = "delaunay";
// Bilinear
else if( it == "bilin" )
_EXCEPTIONT( "--method \"bilin\" may only be used for FV->FV remapping" );
strMapAlgorithm = "fvbilin";
// Integrated bilinear (same as mono3 when source grid is CGLL/DGLL)
else if( it == "intbilin" )
if( m_eOutputType != DiscretizationType_FV )
_EXCEPTIONT( "--method \"intbilin\" may only be used when mapping to FV." );
if( m_eInputType == DiscretizationType_FV )
strMapAlgorithm = "fvintbilin";
else
strMapAlgorithm = "mono3";
// Integrated bilinear with generalized Barycentric coordinates
else if( it == "intbilingb" )
_EXCEPTIONT( "--method \"intbilingb\" may only be used for FV->FV remapping" );
strMapAlgorithm = "fvintbilingb";
else
_EXCEPTION1( "Invalid --method argument \"%s\"", it.c_str() );
m_nDofsPEl_Src =
( m_eInputType == DiscretizationType_FV || m_eInputType == DiscretizationType_PCLOUD ? 1
: mapOptions.nPin );
m_nDofsPEl_Dest =
( m_eOutputType == DiscretizationType_FV || m_eOutputType == DiscretizationType_PCLOUD ? 1
: mapOptions.nPout );
rval = SetDOFmapTags( srcDofTagName, tgtDofTagName );MB_CHK_ERR( rval );
/// the tag should be created already in the e3sm workflow; if not, create it here
Tag areaTag;
rval = m_interface->tag_get_handle( "aream", 1, MB_TYPE_DOUBLE, areaTag,
MB_TAG_DENSE | MB_TAG_EXCL | MB_TAG_CREAT );
if ( MB_ALREADY_ALLOCATED == rval )
if( is_root ) dbgprint.printf( 0, "aream tag already defined \n" );
double dTotalAreaInput = 0.0, dTotalAreaOutput = 0.0;
if( !m_bPointCloudSource )
// Calculate Input Mesh Face areas
if( is_root ) dbgprint.printf( 0, "Calculating input mesh Face areas\n" );
double dTotalAreaInput_loc = m_meshInput->CalculateFaceAreas( mapOptions.fSourceConcave );
rval = m_interface->tag_set_data( areaTag, m_remapper->m_source_entities, m_meshInput->vecFaceArea );MB_CHK_ERR( rval );
dTotalAreaInput = dTotalAreaInput_loc;
if( m_pcomm )
MPI_Reduce( &dTotalAreaInput_loc, &dTotalAreaInput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root ) dbgprint.printf( 0, "Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput );
// Input mesh areas
m_meshInputCov->CalculateFaceAreas( mapOptions.fSourceConcave );
// we do not need to set the area on coverage mesh, only on source and target meshes
// rval = m_interface->tag_set_data( areaTag, m_remapper->m_covering_source_entities, m_meshInputCov->vecFaceArea );MB_CHK_ERR( rval );
if( !m_bPointCloudTarget )
// Calculate Output Mesh Face areas
if( is_root ) dbgprint.printf( 0, "Calculating output mesh Face areas\n" );
double dTotalAreaOutput_loc = m_meshOutput->CalculateFaceAreas( mapOptions.fTargetConcave );
dTotalAreaOutput = dTotalAreaOutput_loc;
if( m_pcomm )
MPI_Reduce( &dTotalAreaOutput_loc, &dTotalAreaOutput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root ) dbgprint.printf( 0, "Output Mesh Geometric Area: %1.15e\n", dTotalAreaOutput );
rval = m_interface->tag_set_data( areaTag, m_remapper->m_target_entities, m_meshOutput->vecFaceArea );MB_CHK_ERR( rval );
if( !m_bPointCloud )
// Calculate Face areas
if( is_root ) dbgprint.printf( 0, "Calculating overlap mesh Face areas\n" );
double dTotalAreaOverlap_loc = m_meshOverlap->CalculateFaceAreas( false );
double dTotalAreaOverlap = dTotalAreaOverlap_loc;
if( m_pcomm )
MPI_Reduce( &dTotalAreaOverlap_loc, &dTotalAreaOverlap, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root ) dbgprint.printf( 0, "Overlap Mesh Area: %1.15e\n", dTotalAreaOverlap );
// Correct areas to match the areas calculated in the overlap mesh
// if (fCorrectAreas) // In MOAB-TempestRemap, we will always keep this to be true
if( is_root ) dbgprint.printf( 0, "Correcting source/target areas to overlap mesh areas\n" );
DataArray1D< double > dSourceArea( m_meshInputCov->faces.size() );
DataArray1D< double > dTargetArea( m_meshOutput->faces.size() );
assert( m_meshOverlap->vecSourceFaceIx.size() == m_meshOverlap->faces.size() );
assert( m_meshOverlap->vecTargetFaceIx.size() == m_meshOverlap->faces.size() );
assert( m_meshOverlap->vecFaceArea.GetRows() == m_meshOverlap->faces.size() );
assert( m_meshInputCov->vecFaceArea.GetRows() == m_meshInputCov->faces.size() );
assert( m_meshOutput->vecFaceArea.GetRows() == m_meshOutput->faces.size() );
for( size_t i = 0; i < m_meshOverlap->faces.size(); i++ )
if( m_meshOverlap->vecSourceFaceIx[i] < 0 || m_meshOverlap->vecTargetFaceIx[i] < 0 )
continue; // skip this cell since it is ghosted
// let us recompute the source/target areas based on overlap mesh areas
assert( static_cast< size_t >( m_meshOverlap->vecSourceFaceIx[i] ) < m_meshInputCov->faces.size() );
dSourceArea[m_meshOverlap->vecSourceFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
assert( static_cast< size_t >( m_meshOverlap->vecTargetFaceIx[i] ) < m_meshOutput->faces.size() );
dTargetArea[m_meshOverlap->vecTargetFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
for( size_t i = 0; i < m_meshInputCov->faces.size(); i++ )
if( fabs( dSourceArea[i] - m_meshInputCov->vecFaceArea[i] ) < 1.0e-10 )
m_meshInputCov->vecFaceArea[i] = dSourceArea[i];
for( size_t i = 0; i < m_meshOutput->faces.size(); i++ )
if( fabs( dTargetArea[i] - m_meshOutput->vecFaceArea[i] ) < 1.0e-10 )
m_meshOutput->vecFaceArea[i] = dTargetArea[i];
// Set source mesh areas in map
if( !m_bPointCloudSource && eInputType == DiscretizationType_FV )
this->SetSourceAreas( m_meshInputCov->vecFaceArea );
if( m_meshInputCov->vecMask.size() )
this->SetSourceMask( m_meshInputCov->vecMask );
// Set target mesh areas in map
if( !m_bPointCloudTarget && eOutputType == DiscretizationType_FV )
this->SetTargetAreas( m_meshOutput->vecFaceArea );
if( m_meshOutput->vecMask.size() )
this->SetTargetMask( m_meshOutput->vecMask );
// Recalculate input mesh area from overlap mesh
if (fabs(dTotalAreaOverlap - dTotalAreaInput) > 1.0e-10) {
dbgprint.printf(0, "Overlap mesh only covers a sub-area of the sphere\n");
dbgprint.printf(0, "Recalculating source mesh areas\n");
dTotalAreaInput = m_meshInput->CalculateFaceAreasFromOverlap(m_meshOverlap);
dbgprint.printf(0, "New Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput);
// Finite volume input / Finite volume output
if( ( eInputType == DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
// Generate reverse node array and edge map
if( m_meshInputCov->revnodearray.size() == 0 ) m_meshInputCov->ConstructReverseNodeArray();
if( m_meshInputCov->edgemap.size() == 0 ) m_meshInputCov->ConstructEdgeMap( false );
// Initialize coordinates for map
this->InitializeSourceCoordinatesFromMeshFV( *m_meshInputCov );
this->InitializeTargetCoordinatesFromMeshFV( *m_meshOutput );
// Finite volume input / Finite element output
rval = this->SetDOFmapAssociation( eInputType, false, NULL, NULL, eOutputType, false, NULL );MB_CHK_ERR( rval );
// Construct remap for FV-FV
if( is_root ) dbgprint.printf( 0, "Calculating remap weights\n" );
// Construct OfflineMap
if( strMapAlgorithm == "invdist" )
if( is_root ) AnnounceStartBlock( "Calculating map (invdist)" );
LinearRemapFVtoFVInvDist( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
else if( strMapAlgorithm == "delaunay" )
if( is_root ) AnnounceStartBlock( "Calculating map (delaunay)" );
LinearRemapTriangulation( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
else if( strMapAlgorithm == "fvintbilin" )
if( is_root ) AnnounceStartBlock( "Calculating map (intbilin)" );
LinearRemapIntegratedBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
else if( strMapAlgorithm == "fvintbilingb" )
if( is_root ) AnnounceStartBlock( "Calculating map (intbilingb)" );
LinearRemapIntegratedGeneralizedBarycentric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
else if( strMapAlgorithm == "fvbilin" )
if( is_root ) AnnounceStartBlock( "Calculating map (bilin)" );
LinearRemapBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
else
if( is_root ) AnnounceStartBlock( "Calculating map (default)" );
// LinearRemapFVtoFV( *m_meshInputCov, *m_meshOutput, *m_meshOverlap,
// ( mapOptions.fMonotone ) ? ( 1 ) : ( mapOptions.nPin ), *this );
LinearRemapFVtoFV_Tempest_MOAB( ( mapOptions.fMonotone ? 1 : mapOptions.nPin ) );
else if( eInputType == DiscretizationType_FV )
if( is_root ) dbgprint.printf( 0, "Generating output mesh meta data\n" );
double dNumericalArea_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
dataGLLNodesDest, dataGLLJacobian );
double dNumericalArea = dNumericalArea_loc;
if( m_pcomm )
MPI_Reduce( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root ) dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalArea );
this->InitializeTargetCoordinatesFromMeshFE( *m_meshOutput, mapOptions.nPout, dataGLLNodesDest );
// Generate the continuous Jacobian
bool fContinuous = ( eOutputType == DiscretizationType_CGLL );
if( eOutputType == DiscretizationType_CGLL )
GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas() );
else
GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetTargetAreas() );
( eOutputType == DiscretizationType_CGLL ), &dataGLLNodesDest );MB_CHK_ERR( rval );
// Generate remap weights
if( strMapAlgorithm == "volumetric" )
if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL (volumetric)\n" );
LinearRemapFVtoGLL_Volumetric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest,
dataGLLJacobian, this->GetTargetAreas(), mapOptions.nPin, *this,
nMonotoneType, fContinuous, mapOptions.fNoConservation );
else
if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL\n" );
LinearRemapFVtoGLL( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest, dataGLLJacobian,
this->GetTargetAreas(), mapOptions.nPin, *this, nMonotoneType, fContinuous,
else if( ( eInputType == DiscretizationType_PCLOUD ) || ( eOutputType == DiscretizationType_PCLOUD ) )
else
if( is_root ) dbgprint.printf( 0, "Generating input mesh meta data\n" );
DataArray3D< double > dataGLLJacobianSrc;
GenerateMetaData( *m_meshInputCov, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrcCov,
dataGLLJacobian );
GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrc,
dataGLLJacobianSrc );
// else { /* Source is a point cloud dataset */ }
if( m_meshOutput->revnodearray.size() == 0 ) m_meshOutput->ConstructReverseNodeArray();
if( m_meshOutput->edgemap.size() == 0 ) m_meshOutput->ConstructEdgeMap( false );
if( eOutputType == DiscretizationType_FV )
this->InitializeSourceCoordinatesFromMeshFV( *m_meshOutput );
else
GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble, dataGLLNodesDest,
dataGLLJacobian );
// else { /* Target is a point cloud dataset */ }
eInputType, ( eInputType == DiscretizationType_CGLL ),
( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrcCov ),
( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrc ), eOutputType,
( eOutputType == DiscretizationType_CGLL ), ( m_bPointCloudTarget ? NULL : &dataGLLNodesDest ) );MB_CHK_ERR( rval );
// Construct remap
if( is_root ) dbgprint.printf( 0, "Calculating remap weights with Nearest-Neighbor method\n" );
rval = LinearRemapNN_MOAB( true /*use_GID_matching*/, false /*strict_check*/ );MB_CHK_ERR( rval );
else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
DataArray3D< double > dataGLLJacobianSrc, dataGLLJacobian;
// double dNumericalAreaCov_loc =
dataGLLJacobian );
double dNumericalArea_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
dataGLLNodesSrc, dataGLLJacobianSrc );
// if ( is_root ) dbgprint.printf ( 0, "Input Mesh: Coverage Area: %1.15e, Output Area:
// %1.15e\n", dNumericalAreaCov_loc, dTotalAreaOutput_loc );
// assert(dNumericalAreaCov_loc >= dTotalAreaOutput_loc);
if( m_pcomm )
#endif
if( is_root )
dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalArea );
if( fabs( dNumericalArea - dTotalAreaInput ) > 1.0e-12 )
dbgprint.printf( 0, "WARNING: Significant mismatch between input mesh "
"numerical area and geometric area\n" );
if( dataGLLNodesSrcCov.GetSubColumns() != m_meshInputCov->faces.size() )
_EXCEPTIONT( "Number of element does not match between metadata and "
"input mesh" );
this->InitializeSourceCoordinatesFromMeshFE( *m_meshInputCov, mapOptions.nPin, dataGLLNodesSrcCov );
// Generate the continuous Jacobian for input mesh
bool fContinuousIn = ( eInputType == DiscretizationType_CGLL );
if( eInputType == DiscretizationType_CGLL )
GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobian, this->GetSourceAreas() );
else
GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetSourceAreas() );
// Finite element input / Finite volume output
rval = this->SetDOFmapAssociation( eInputType, ( eInputType == DiscretizationType_CGLL ),
&dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType, false, NULL );MB_CHK_ERR( rval );
// Generate remap
_EXCEPTIONT( "Unimplemented: Volumetric currently unavailable for"
"GLL input mesh" );
LinearRemapSE4_Tempest_MOAB( dataGLLNodesSrcCov, dataGLLJacobian, nMonotoneType, fContinuousIn,
else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType != DiscretizationType_FV ) )
DataArray3D< double > dataGLLJacobianIn, dataGLLJacobianSrc;
DataArray3D< double > dataGLLJacobianOut;
// Input metadata
dataGLLJacobianIn );
double dNumericalAreaSrc_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
double dNumericalAreaIn = dNumericalAreaSrc_loc;
if( m_pcomm )
MPI_Reduce( &dNumericalAreaSrc_loc, &dNumericalAreaIn, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root )
dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalAreaIn );
if( fabs( dNumericalAreaIn - dTotalAreaInput ) > 1.0e-12 )
// Output metadata
double dNumericalAreaOut_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
dataGLLNodesDest, dataGLLJacobianOut );
double dNumericalAreaOut = dNumericalAreaOut_loc;
if( m_pcomm )
MPI_Reduce( &dNumericalAreaOut_loc, &dNumericalAreaOut, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
if( is_root )
dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalAreaOut );
if( fabs( dNumericalAreaOut - dTotalAreaOutput ) > 1.0e-12 )
if( is_root )
dbgprint.printf( 0, "WARNING: Significant mismatch between output mesh "
GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobianIn, this->GetSourceAreas() );
else
GenerateDiscontinuousJacobian( dataGLLJacobianIn, this->GetSourceAreas() );
// Generate the continuous Jacobian for output mesh
bool fContinuousOut = ( eOutputType == DiscretizationType_CGLL );
GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianOut, this->GetTargetAreas() );
else
GenerateDiscontinuousJacobian( dataGLLJacobianOut, this->GetTargetAreas() );
// Input Finite Element to Output Finite Element
// Generate remap
LinearRemapGLLtoGLL2_MOAB( dataGLLNodesSrcCov, dataGLLJacobianIn, dataGLLNodesDest, dataGLLJacobianOut,
this->GetTargetAreas(), mapOptions.nPin, mapOptions.nPout, nMonotoneType,
fContinuousIn, fContinuousOut, mapOptions.fNoConservation );
else
_EXCEPTIONT( "Not implemented" );
#ifdef MOAB_HAVE_EIGEN3
copy_tempest_sparsemat_to_eigen3();
#endif
// Remove ghosted entities from overlap set
moab::Range ghostedEnts;
rval = m_remapper->GetOverlapAugmentedEntities( ghostedEnts );MB_CHK_ERR( rval );
moab::EntityHandle m_meshOverlapSet = m_remapper->GetMeshSet( moab::Remapper::OverlapMesh );
rval = m_interface->remove_entities( m_meshOverlapSet, ghostedEnts );MB_CHK_SET_ERR( rval, "Deleting ghosted entities failed" );
#endif
// Verify consistency, conservation and monotonicity, globally
if( !mapOptions.fNoCheck )
if( is_root ) dbgprint.printf( 0, "Verifying map" );
this->IsConsistent( 1.0e-8 );
if( !mapOptions.fNoConservation ) this->IsConservative( 1.0e-8 );
this->IsMonotone( 1.0e-12 );
catch( Exception& e )
dbgprint.printf( 0, "%s", e.ToString().c_str() );
return ( moab::MB_FAILURE );
catch( ... )
| int moab::TempestOnlineMap::GetColGlobalDoF | ( | int | localID | ) | const [inline] |
Definition at line 480 of file TempestOnlineMap.hpp.
return col_gdofmap[localColID];
| int moab::TempestOnlineMap::GetDestinationNDofsPerElement | ( | ) | [inline] |
Definition at line 498 of file TempestOnlineMap.hpp.
return m_nDofsPEl_Dest;
| const DataArray1D< double >& moab::TempestOnlineMap::GetGlobalSourceAreas | ( | ) | const |
| const DataArray1D< double >& moab::TempestOnlineMap::GetGlobalTargetAreas | ( | ) | const |
| int moab::TempestOnlineMap::GetIndexOfColGlobalDoF | ( | int | globalColDoF | ) | const [inline] |
Definition at line 485 of file TempestOnlineMap.hpp.
return globalColDoF + 1; // temporary
| int moab::TempestOnlineMap::GetIndexOfRowGlobalDoF | ( | int | globalRowDoF | ) | const [inline] |
Definition at line 474 of file TempestOnlineMap.hpp.
return globalRowDoF + 1;
| int moab::TempestOnlineMap::GetRowGlobalDoF | ( | int | localID | ) | const [inline] |
Definition at line 469 of file TempestOnlineMap.hpp.
return row_gdofmap[localRowID];
| int moab::TempestOnlineMap::GetSourceNDofsPerElement | ( | ) | [inline] |
Definition at line 491 of file TempestOnlineMap.hpp.
return m_nDofsPEl_Src;
| int moab::TempestOnlineMap::IsConservative | ( | double | dTolerance | ) | [virtual] |
Definition at line 1478 of file TempestOnlineMap.cpp.
References size.
#ifndef MOAB_HAVE_MPI
return OfflineMap::IsConservative( dTolerance );
#else
// return OfflineMap::IsConservative(dTolerance);
int ierr;
// Get map entries
DataArray1D< int > dataRows;
DataArray1D< int > dataCols;
DataArray1D< double > dataEntries;
const DataArray1D< double >& dTargetAreas = this->GetTargetAreas();
const DataArray1D< double >& dSourceAreas = this->GetSourceAreas();
// Calculate column sums
std::vector< int > dColumnsUnique;
std::vector< double > dColumnSums;
int nColumns = m_mapRemap.GetColumns();
m_mapRemap.GetEntries( dataRows, dataCols, dataEntries );
dColumnSums.resize( m_nTotDofs_SrcCov, 0.0 );
dColumnsUnique.resize( m_nTotDofs_SrcCov, -1 );
for( unsigned i = 0; i < dataEntries.GetRows(); i++ )
dColumnSums[dataCols[i]] += dataEntries[i] * dTargetAreas[dataRows[i]] / dSourceAreas[dataCols[i]];
assert( dataCols[i] < m_nTotDofs_SrcCov );
// GID for column DoFs: col_gdofmap[ col_ldofmap [ dataCols[i] ] ]
int colGID = this->GetColGlobalDoF( dataCols[i] ); // col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
// int colGID = col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
dColumnsUnique[dataCols[i]] = colGID;
// std::cout << "Column dataCols[i]=" << dataCols[i] << " with GID = " << colGID <<
// std::endl;
int rootProc = 0;
std::vector< int > nElementsInProc;
const int nDATA = 3;
if( !rank ) nElementsInProc.resize( size * nDATA );
int senddata[nDATA] = {nColumns, m_nTotDofs_SrcCov, m_nTotDofs_Src};
ierr = MPI_Gather( senddata, nDATA, MPI_INT, nElementsInProc.data(), nDATA, MPI_INT, rootProc, m_pcomm->comm() );
if( ierr != MPI_SUCCESS ) return -1;
int nTotVals = 0, nTotColumns = 0, nTotColumnsUnq = 0;
std::vector< int > dColumnIndices;
std::vector< double > dColumnSourceAreas;
std::vector< double > dColumnSumsTotal;
std::vector< int > displs, rcount;
if( rank == rootProc )
displs.resize( size + 1, 0 );
rcount.resize( size, 0 );
int gsum = 0;
for( int ir = 0; ir < size; ++ir )
nTotVals += nElementsInProc[ir * nDATA];
nTotColumns += nElementsInProc[ir * nDATA + 1];
nTotColumnsUnq += nElementsInProc[ir * nDATA + 2];
displs[ir] = gsum;
rcount[ir] = nElementsInProc[ir * nDATA + 1];
gsum += rcount[ir];
// printf("%d: nTotColumns: %d, Displs: %d, rcount: %d, gsum = %d\n", ir, nTotColumns,
// displs[ir], rcount[ir], gsum);
dColumnIndices.resize( nTotColumns, -1 );
dColumnSumsTotal.resize( nTotColumns, 0.0 );
// dColumnSourceAreas.resize ( nTotColumns, 0.0 );
// Gather all ColumnSums to root process and accumulate
// We expect that the sums of all columns equate to 1.0 within user specified tolerance
// Need to do a gatherv here since different processes have different number of elements
// MPI_Reduce(&dColumnSums[0], &dColumnSumsTotal[0], m_mapRemap.GetColumns(), MPI_DOUBLE,
// MPI_SUM, 0, m_pcomm->comm());
ierr = MPI_Gatherv( &dColumnsUnique[0], m_nTotDofs_SrcCov, MPI_INT, &dColumnIndices[0], rcount.data(),
displs.data(), MPI_INT, rootProc, m_pcomm->comm() );
ierr = MPI_Gatherv( &dColumnSums[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSumsTotal[0], rcount.data(),
displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() );
// ierr = MPI_Gatherv ( &dSourceAreas[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSourceAreas[0],
// rcount.data(), displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() ); if ( ierr !=
// MPI_SUCCESS ) return -1;
// Clean out unwanted arrays now
dColumnSums.clear();
dColumnsUnique.clear();
// Verify all column sums equal the input Jacobian
int fConservative = 0;
displs[size] = ( nTotColumns );
// std::vector<double> dColumnSumsOnRoot(nTotColumnsUnq, 0.0);
std::map< int, double > dColumnSumsOnRoot;
// std::map<int, double> dColumnSourceAreasOnRoot;
for( int ir = 0; ir < size; ir++ )
for( int ips = displs[ir]; ips < displs[ir + 1]; ips++ )
if( dColumnIndices[ips] < 0 ) continue;
// printf("%d, %d: dColumnIndices[ips]: %d\n", ir, ips, dColumnIndices[ips]);
assert( dColumnIndices[ips] < nTotColumnsUnq );
dColumnSumsOnRoot[dColumnIndices[ips]] += dColumnSumsTotal[ips]; // / dColumnSourceAreas[ips];
// dColumnSourceAreasOnRoot[ dColumnIndices[ips] ] = dColumnSourceAreas[ips];
// dColumnSourceAreas[ dColumnIndices[ips] ]
for( std::map< int, double >::iterator it = dColumnSumsOnRoot.begin(); it != dColumnSumsOnRoot.end(); ++it )
// if ( fabs ( it->second - dColumnSourceAreasOnRoot[it->first] ) > dTolerance )
if( fabs( it->second - 1.0 ) > dTolerance )
fConservative++;
Announce( "TempestOnlineMap is not conservative in column "
// "%i (%1.15e)", it->first, it->second );
"%i (%1.15e)",
it->first, it->second /* / dColumnSourceAreasOnRoot[it->first] */ );
// TODO: Just do a broadcast from root instead of a reduction
ierr = MPI_Bcast( &fConservative, 1, MPI_INT, rootProc, m_pcomm->comm() );
return fConservative;
#endif
| int moab::TempestOnlineMap::IsConsistent | ( | double | dTolerance | ) | [virtual] |
Definition at line 1432 of file TempestOnlineMap.cpp.
return OfflineMap::IsConsistent( dTolerance );
#else
// Get map entries
// Calculate row sums
DataArray1D< double > dRowSums;
dRowSums.Allocate( m_mapRemap.GetRows() );
for( unsigned i = 0; i < dataRows.GetRows(); i++ )
dRowSums[dataRows[i]] += dataEntries[i];
// Verify all row sums are equal to 1
int fConsistent = 0;
for( unsigned i = 0; i < dRowSums.GetRows(); i++ )
if( fabs( dRowSums[i] - 1.0 ) > dTolerance )
fConsistent++;
int rowGID = row_gdofmap[i];
Announce( "TempestOnlineMap is not consistent in row %i (%1.15e)", rowGID, dRowSums[i] );
int ierr;
int fConsistentGlobal = 0;
ierr = MPI_Allreduce( &fConsistent, &fConsistentGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
return fConsistentGlobal;
#endif
| int moab::TempestOnlineMap::IsMonotone | ( | double | dTolerance | ) | [virtual] |
Definition at line 1620 of file TempestOnlineMap.cpp.
return OfflineMap::IsMonotone( dTolerance );
#else
// Get map entries
// Verify all entries are in the range [0,1]
int fMonotone = 0;
if( ( dataEntries[i] < -dTolerance ) || ( dataEntries[i] > 1.0 + dTolerance ) )
fMonotone++;
Announce( "TempestOnlineMap is not monotone in entry (%i): %1.15e", i, dataEntries[i] );
int ierr;
int fMonotoneGlobal = 0;
ierr = MPI_Allreduce( &fMonotone, &fMonotoneGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
return fMonotoneGlobal;
#endif
| void moab::TempestOnlineMap::LinearRemapFVtoFV_Tempest_MOAB | ( | int | nOrder | ) | [private] |
Definition at line 115 of file TempestLinearRemap.cpp.
References moab::Remapper::CoveringMesh, dbgprint, moab::DebugOutput::printf(), and moab::DebugOutput::set_prefix().
// Order of triangular quadrature rule
const int TriQuadRuleOrder = 4;
// Verify ReverseNodeArray has been calculated
if( m_meshInputCov->faces.size() > 0 && m_meshInputCov->revnodearray.size() == 0 )
_EXCEPTIONT( "ReverseNodeArray has not been calculated for m_meshInput" );
TriangularQuadratureRule triquadrule( TriQuadRuleOrder );
// Number of coefficients needed at this order
#ifdef RECTANGULAR_TRUNCATION
int nCoefficients = nOrder * nOrder;
#endif
#ifdef TRIANGULAR_TRUNCATION
int nCoefficients = nOrder * ( nOrder + 1 ) / 2;
#endif
// Number of faces you need
const int nRequiredFaceSetSize = nCoefficients;
// Fit weight exponent
const int nFitWeightsExponent = nOrder + 2;
// Announcemnets
moab::DebugOutput dbgprint( std::cout, this->rank, 0 );
dbgprint.set_prefix( "[LinearRemapFVtoFV_Tempest_MOAB]: " );
if( is_root )
dbgprint.printf( 0, "Finite Volume to Finite Volume Projection\n" );
dbgprint.printf( 0, "Triangular quadrature rule order %i\n", TriQuadRuleOrder );
dbgprint.printf( 0, "Number of coefficients: %i\n", nCoefficients );
dbgprint.printf( 0, "Required adjacency set size: %i\n", nRequiredFaceSetSize );
dbgprint.printf( 0, "Fit weights exponent: %i\n", nFitWeightsExponent );
// Current overlap face
int ixOverlap = 0;
const unsigned outputFrequency = ( m_meshInputCov->faces.size() / 10 ) + 1;
DataArray2D< double > dIntArray;
DataArray1D< double > dConstraint( nCoefficients );
// Loop through all faces on m_meshInput
for( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ )
// Output every 1000 elements
#ifdef VERBOSE
if( ixFirst % outputFrequency == 0 && is_root )
dbgprint.printf( 0, "Element %zu/%lu\n", ixFirst, m_meshInputCov->faces.size() );
#endif
// Find the set of Faces that overlap faceFirst
int ixOverlapBegin = ixOverlap;
unsigned ixOverlapEnd = ixOverlapBegin;
for( ; ixOverlapEnd < m_meshOverlap->faces.size(); ixOverlapEnd++ )
if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapEnd] != 0 ) break;
unsigned nOverlapFaces = ixOverlapEnd - ixOverlapBegin;
if( nOverlapFaces == 0 )
std::cout << "rank:" << rank << " " << m_remapper->GetGlobalID( Remapper::CoveringMesh, ixFirst )
<< "\n";
continue;
// Build integration array
BuildIntegrationArray( *m_meshInputCov, *m_meshOverlap, triquadrule, ixFirst, ixOverlapBegin, ixOverlapEnd,
nOrder, dIntArray );
// Set of Faces to use in building the reconstruction and associated
// distance metric.
AdjacentFaceVector vecAdjFaces;
GetAdjacentFaceVectorByEdge( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces );
// Number of adjacent Faces
int nAdjFaces = vecAdjFaces.size();
// Determine the conservative constraint equation
double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst];
dConstraint.Zero();
for( int p = 0; p < nCoefficients; p++ )
for( unsigned j = 0; j < nOverlapFaces; j++ )
dConstraint[p] += dIntArray[p][j];
dConstraint[p] /= dFirstArea;
// Build the fit array from the integration operator
DataArray2D< double > dFitArray;
DataArray1D< double > dFitWeights;
DataArray2D< double > dFitArrayPlus;
BuildFitArray( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint,
dFitArray, dFitWeights );
// Compute the inverse fit array
bool fSuccess = InvertFitArray_Corrected( dConstraint, dFitArray, dFitWeights, dFitArrayPlus );
// Multiply integration array and fit array
DataArray2D< double > dComposedArray( nAdjFaces, nOverlapFaces );
if( fSuccess )
// Multiply integration array and inverse fit array
for( int i = 0; i < nAdjFaces; i++ )
for( size_t j = 0; j < nOverlapFaces; j++ )
for( int k = 0; k < nCoefficients; k++ )
dComposedArray( i, j ) += dIntArray( k, j ) * dFitArrayPlus( i, k );
// Unable to invert fit array, drop to 1st order. In this case
// dFitArrayPlus(0,0) = 1 and all other entries are zero.
else
dComposedArray.Zero();
dComposedArray( 0, j ) += dIntArray( 0, j );
// Put composed array into map
for( unsigned i = 0; i < vecAdjFaces.size(); i++ )
int& ixFirstFaceLoc = vecAdjFaces[i].first;
int& ixSecondFaceLoc = m_meshOverlap->vecTargetFaceIx[ixOverlap + j];
// int ixFirstFaceGlob = m_remapper->GetGlobalID(moab::Remapper::SourceMesh,
// ixFirstFaceLoc); int ixSecondFaceGlob =
// m_remapper->GetGlobalID(moab::Remapper::TargetMesh, ixSecondFaceLoc);
// signal to not participate, because it is a ghost target
if( ixSecondFaceLoc < 0 ) continue; // do not do anything
m_mapRemap( ixSecondFaceLoc, ixFirstFaceLoc ) +=
dComposedArray[i][j] / m_meshOutput->vecFaceArea[ixSecondFaceLoc];
// Increment the current overlap index
ixOverlap += nOverlapFaces;
return;
| void moab::TempestOnlineMap::LinearRemapFVtoGLL_MOAB | ( | const DataArray3D< int > & | dataGLLNodes, |
| const DataArray3D< double > & | dataGLLJacobian, | ||
| const DataArray1D< double > & | dataGLLNodalArea, | ||
| int | nOrder, | ||
| int | nMonotoneType, | ||
| bool | fContinuous, | ||
| bool | fNoConservation | ||
| ) | [private] |
| void moab::TempestOnlineMap::LinearRemapGLLtoGLL2_MOAB | ( | const DataArray3D< int > & | dataGLLNodesIn, |
| const DataArray3D< double > & | dataGLLJacobianIn, | ||
| const DataArray3D< int > & | dataGLLNodesOut, | ||
| const DataArray3D< double > & | dataGLLJacobianOut, | ||
| const DataArray1D< double > & | dataNodalAreaOut, | ||
| int | nPin, | ||
| int | nPout, | ||
| bool | fContinuousIn, | ||
| bool | fContinuousOut, | ||
| ) | [private] |
Definition at line 900 of file TempestLinearRemap.cpp.
References center(), dbgprint, ForceIntArrayConsistencyConservation(), moab::DebugOutput::printf(), moab::DebugOutput::set_prefix(), and t.
TriangularQuadratureRule triquadrule( 8 );
const DataArray2D< double >& dG = triquadrule.GetG();
const DataArray1D< double >& dW = triquadrule.GetW();
// Get SparseMatrix represntation of the OfflineMap
SparseMatrix< double >& smatMap = this->GetSparseMatrix();
// Sample coefficients
DataArray2D< double > dSampleCoeffIn( nPin, nPin );
DataArray2D< double > dSampleCoeffOut( nPout, nPout );
// Announcemnets
dbgprint.set_prefix( "[LinearRemapGLLtoGLL2_MOAB]: " );
if( is_root )
dbgprint.printf( 0, "Finite Element to Finite Element Projection\n" );
dbgprint.printf( 0, "Order of the input FE polynomial interpolant: %i\n", nPin );
dbgprint.printf( 0, "Order of the output FE polynomial interpolant: %i\n", nPout );
// Build the integration array for each element on m_meshOverlap
DataArray3D< double > dGlobalIntArray( nPin * nPin, m_meshOverlap->faces.size(), nPout * nPout );
// Number of overlap Faces per source Face
DataArray1D< int > nAllOverlapFaces( m_meshInputCov->faces.size() );
int ixOverlap = 0;
// Determine how many overlap Faces and triangles are present
int nOverlapFaces = 0;
size_t ixOverlapTemp = ixOverlap;
for( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ )
// const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp];
if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 )
break;
nOverlapFaces++;
nAllOverlapFaces[ixFirst] = nOverlapFaces;
ixOverlap += nAllOverlapFaces[ixFirst];
// Geometric area of each output node
DataArray2D< double > dGeometricOutputArea( m_meshOutput->faces.size(), nPout * nPout );
// Area of each overlap element in the output basis
DataArray2D< double > dOverlapOutputArea( m_meshOverlap->faces.size(), nPout * nPout );
ixOverlap = 0;
if( is_root ) dbgprint.printf( 0, "Building conservative distribution maps\n" );
// generic triangle used for area computation, for triangles around the center of overlap face;
// used for overlap faces with more than 4 edges;
// nodes array will be set for each triangle;
// these triangles are not part of the mesh structure, they are just temporary during
// aforementioned decomposition.
Face faceTri( 3 );
NodeVector nodes( 3 );
faceTri.SetNode( 0, 0 );
faceTri.SetNode( 1, 1 );
faceTri.SetNode( 2, 2 );
#ifdef VERBOSE
// Announce computation progress
#endif
// Quantities from the First Mesh
const Face& faceFirst = m_meshInputCov->faces[ixFirst];
const NodeVector& nodesFirst = m_meshInputCov->nodes;
// Number of overlapping Faces and triangles
int nOverlapFaces = nAllOverlapFaces[ixFirst];
if( !nOverlapFaces ) continue;
// // Calculate total element Jacobian
// double dTotalJacobian = 0.0;
// for (int s = 0; s < nPin; s++) {
// for (int t = 0; t < nPin; t++) {
// dTotalJacobian += dataGLLJacobianIn[s][t][ixFirst];
// Loop through all Overlap Faces
for( int i = 0; i < nOverlapFaces; i++ )
// Quantities from the overlap Mesh
const Face& faceOverlap = m_meshOverlap->faces[ixOverlap + i];
const NodeVector& nodesOverlap = m_meshOverlap->nodes;
// Quantities from the Second Mesh
int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
if( ixSecond < 0 ) continue; // do not do anything
const NodeVector& nodesSecond = m_meshOutput->nodes;
const Face& faceSecond = m_meshOutput->faces[ixSecond];
int nbEdges = faceOverlap.edges.size();
int nOverlapTriangles = 1;
Node center; // not used if nbEdges == 3
if( nbEdges > 3 )
{ // decompose from center in this case
nOverlapTriangles = nbEdges;
for( int k = 0; k < nbEdges; k++ )
const Node& node = nodesOverlap[faceOverlap[k]];
center = center + node;
center = center / nbEdges;
center = center.Normalized(); // project back on sphere of radius 1
Node node0, node1, node2;
double dTriArea;
// Loop over all sub-triangles of this Overlap Face
for( int j = 0; j < nOverlapTriangles; j++ )
if( nbEdges == 3 ) // will come here only once, nOverlapTriangles == 1 in this case
node0 = nodesOverlap[faceOverlap[0]];
node1 = nodesOverlap[faceOverlap[1]];
node2 = nodesOverlap[faceOverlap[2]];
dTriArea = CalculateFaceArea( faceOverlap, nodesOverlap );
else // decompose polygon in triangles around the center
node0 = center;
node1 = nodesOverlap[faceOverlap[j]];
int j1 = ( j + 1 ) % nbEdges;
node2 = nodesOverlap[faceOverlap[j1]];
nodes[0] = center;
nodes[1] = node1;
nodes[2] = node2;
dTriArea = CalculateFaceArea( faceTri, nodes );
for( int k = 0; k < triquadrule.GetPoints(); k++ )
// Get the nodal location of this point
double dX[3];
dX[0] = dG( k, 0 ) * node0.x + dG( k, 1 ) * node1.x + dG( k, 2 ) * node2.x;
dX[1] = dG( k, 0 ) * node0.y + dG( k, 1 ) * node1.y + dG( k, 2 ) * node2.y;
dX[2] = dG( k, 0 ) * node0.z + dG( k, 1 ) * node1.z + dG( k, 2 ) * node2.z;
double dMag = sqrt( dX[0] * dX[0] + dX[1] * dX[1] + dX[2] * dX[2] );
dX[0] /= dMag;
dX[1] /= dMag;
dX[2] /= dMag;
Node nodeQuadrature( dX[0], dX[1], dX[2] );
// Find the components of this quadrature point in the basis
// of the first Face.
double dAlphaIn;
double dBetaIn;
ApplyInverseMap( faceFirst, nodesFirst, nodeQuadrature, dAlphaIn, dBetaIn );
// of the second Face.
double dAlphaOut;
double dBetaOut;
ApplyInverseMap( faceSecond, nodesSecond, nodeQuadrature, dAlphaOut, dBetaOut );
// Check inverse map value
if ((dAlphaIn < 0.0) || (dAlphaIn > 1.0) ||
(dBetaIn < 0.0) || (dBetaIn > 1.0)
_EXCEPTION2("Inverse Map out of range (%1.5e %1.5e)",
dAlphaIn, dBetaIn);
if ((dAlphaOut < 0.0) || (dAlphaOut > 1.0) ||
(dBetaOut < 0.0) || (dBetaOut > 1.0)
dAlphaOut, dBetaOut);
// Sample the First finite element at this point
SampleGLLFiniteElement( nMonotoneType, nPin, dAlphaIn, dBetaIn, dSampleCoeffIn );
// Sample the Second finite element at this point
SampleGLLFiniteElement( nMonotoneType, nPout, dAlphaOut, dBetaOut, dSampleCoeffOut );
// Overlap output area
for( int s = 0; s < nPout; s++ )
for( int t = 0; t < nPout; t++ )
double dNodeArea = dSampleCoeffOut[s][t] * dW[k] * dTriArea;
dOverlapOutputArea[ixOverlap + i][s * nPout + t] += dNodeArea;
dGeometricOutputArea[ixSecond][s * nPout + t] += dNodeArea;
// Compute overlap integral
int ixp = 0;
for( int p = 0; p < nPin; p++ )
for( int q = 0; q < nPin; q++ )
int ixs = 0;
dGlobalIntArray[ixp][ixOverlap + i][ixs] +=
dSampleCoeffOut[s][t] * dSampleCoeffIn[p][q] * dW[k] * dTriArea;
ixs++;
ixp++;
// Coefficients
DataArray2D< double > dCoeff( nOverlapFaces * nPout * nPout, nPin * nPin );
// int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
int ixp = 0;
int ixs = 0;
dCoeff[i * nPout * nPout + ixs][ixp] = dGlobalIntArray[ixp][ixOverlap + i][ixs] /
dOverlapOutputArea[ixOverlap + i][s * nPout + t];
ixs++;
ixp++;
// Source areas
DataArray1D< double > vecSourceArea( nPin * nPin );
vecSourceArea[p * nPin + q] = dataGLLJacobianIn[p][q][ixFirst];
// Target areas
DataArray1D< double > vecTargetArea( nOverlapFaces * nPout * nPout );
// int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
int ixs = 0;
vecTargetArea[i * nPout * nPout + ixs] = dOverlapOutputArea[ixOverlap + i][nPout * s + t];
ixs++;
// Force consistency and conservation
if( !fNoConservation )
ForceIntArrayConsistencyConservation( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType != 0 ) );
// Update global coefficients
int ixp = 0;
int ixs = 0;
dGlobalIntArray[ixp][ixOverlap + i][ixs] =
dCoeff[i * nPout * nPout + ixs][ixp] * dOverlapOutputArea[ixOverlap + i][s * nPout + t];
ixs++;
ixp++;
#ifdef VVERBOSE
// Check column sums (conservation)
for( int i = 0; i < nPin * nPin; i++ )
double dColSum = 0.0;
for( int j = 0; j < nOverlapFaces * nPout * nPout; j++ )
dColSum += dCoeff[j][i] * vecTargetArea[j];
printf( "Col %i: %1.15e\n", i, dColSum / vecSourceArea[i] );
// Check row sums (consistency)
double dRowSum = 0.0;
dRowSum += dCoeff[j][i];
printf( "Row %i: %1.15e\n", j, dRowSum );
#endif
// Build redistribution map within target element
if( is_root ) dbgprint.printf( 0, "Building redistribution maps on target mesh\n" );
DataArray1D< double > dRedistSourceArea( nPout * nPout );
DataArray1D< double > dRedistTargetArea( nPout * nPout );
std::vector< DataArray2D< double > > dRedistributionMaps;
dRedistributionMaps.resize( m_meshOutput->faces.size() );
for( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ )
dRedistributionMaps[ixSecond].Allocate( nPout * nPout, nPout * nPout );
for( int i = 0; i < nPout * nPout; i++ )
dRedistributionMaps[ixSecond][i][i] = 1.0;
for( int s = 0; s < nPout * nPout; s++ )
dRedistSourceArea[s] = dGeometricOutputArea[ixSecond][s];
dRedistTargetArea[s] = dataGLLJacobianOut[s / nPout][s % nPout][ixSecond];
ForceIntArrayConsistencyConservation( dRedistSourceArea, dRedistTargetArea, dRedistributionMaps[ixSecond],
for( int t = 0; t < nPout * nPout; t++ )
dRedistributionMaps[ixSecond][s][t] *= dRedistTargetArea[s] / dRedistSourceArea[t];
// Construct the total geometric area
DataArray1D< double > dTotalGeometricArea( dataNodalAreaOut.GetRows() );
dTotalGeometricArea[dataGLLNodesOut[s][t][ixSecond] - 1] +=
dGeometricOutputArea[ixSecond][s * nPout + t];
// Compose the integration operator with the output map
ixOverlap = 0;
if( is_root ) dbgprint.printf( 0, "Assembling map\n" );
// Map from source DOFs to target DOFs with redistribution applied
DataArray2D< double > dRedistributedOp( nPin * nPin, nPout * nPout );
#ifdef VERBOSE
#endif
for( int j = 0; j < nOverlapFaces; j++ )
int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + j];
if( ixSecondFace < 0 ) continue; // do not do anything
dRedistributedOp.Zero();
for( int p = 0; p < nPin * nPin; p++ )
dRedistributedOp[p][s] +=
dRedistributionMaps[ixSecondFace][s][t] * dGlobalIntArray[p][ixOverlap + j][t];
int ixp = 0;
int ixFirstNode;
if( fContinuousIn )
ixFirstNode = dataGLLNodesIn[p][q][ixFirst] - 1;
else
ixFirstNode = ixFirst * nPin * nPin + p * nPin + q;
int ixs = 0;
int ixSecondNode;
if( fContinuousOut )
ixSecondNode = dataGLLNodesOut[s][t][ixSecondFace] - 1;
smatMap( ixSecondNode, ixFirstNode ) +=
dRedistributedOp[ixp][ixs] / dataNodalAreaOut[ixSecondNode];
else
dRedistributedOp[ixp][ixs] / dTotalGeometricArea[ixSecondNode];
else
ixSecondNode = ixSecondFace * nPout * nPout + s * nPout + t;
dRedistributedOp[ixp][ixs] / dataGLLJacobianOut[s][t][ixSecondFace];
else
dRedistributedOp[ixp][ixs] / dGeometricOutputArea[ixSecondFace][s * nPout + t];
ixs++;
ixp++;
return;
| void moab::TempestOnlineMap::LinearRemapGLLtoGLL2_Pointwise_MOAB | ( | const DataArray3D< int > & | dataGLLNodesIn, |
| int | nPin, | ||
| int | nPout, | ||
| bool | fContinuousOut | ||
| ) | [private] |
Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation).
Definition at line 1450 of file TempestLinearRemap.cpp.
References dbgprint, moab::DebugOutput::printf(), moab::DebugOutput::set_prefix(), and t.
// Gauss-Lobatto quadrature within Faces
DataArray1D< double > dGL;
DataArray1D< double > dWL;
GaussLobattoQuadrature::GetPoints( nPout, 0.0, 1.0, dGL, dWL );
// Announcemnets
dbgprint.set_prefix( "[LinearRemapGLLtoGLL2_Pointwise_MOAB]: " );
if( is_root )
dbgprint.printf( 0, "Finite Element to Finite Element (Pointwise) Projection\n" );
int ixOverlap = 0;
if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) break;
nAllOverlapFaces[ixFirst]++;
// Number of times this point was found
DataArray1D< bool > fSecondNodeFound( dataNodalAreaOut.GetRows() );
ixOverlap = 0;
// Loop through all faces on m_meshInputCov
#ifdef VERBOSE
#endif
// Loop through all nodes on the second face
size_t ixSecondNode;
ixSecondNode = dataGLLNodesOut[s][t][ixSecond] - 1;
else
ixSecondNode = ixSecond * nPout * nPout + s * nPout + t;
if( ixSecondNode >= fSecondNodeFound.GetRows() )
_EXCEPTIONT( "Logic error" );
// Check if this node has been found already
if( fSecondNodeFound[ixSecondNode] )
continue;
// Check this node
Node node;
Node dDx1G;
Node dDx2G;
ApplyLocalMap( faceSecond, nodesSecond, dGL[t], dGL[s], node, dDx1G, dDx2G );
double dAlphaIn;
double dBetaIn;
ApplyInverseMap( faceFirst, nodesFirst, node, dAlphaIn, dBetaIn );
// Check if this node is within the first Face
if( ( dAlphaIn < -1.0e-10 ) || ( dAlphaIn > 1.0 + 1.0e-10 ) || ( dBetaIn < -1.0e-10 ) ||
( dBetaIn > 1.0 + 1.0e-10 ) )
continue;
// Node is within the overlap region, mark as found
fSecondNodeFound[ixSecondNode] = true;
// Add to map
int ixFirstNode;
if( fContinuousIn )
else
smatMap( ixSecondNode, ixFirstNode ) += dSampleCoeffIn[p][q];
// Check for missing samples
for( size_t i = 0; i < fSecondNodeFound.GetRows(); i++ )
if( !fSecondNodeFound[i] )
_EXCEPTION1( "Can't sample point %i", i );
return;
| moab::ErrorCode moab::TempestOnlineMap::LinearRemapNN_MOAB | ( | bool | use_GID_matching = false, |
| bool | strict_check = false |
| ) | [private] |
Compute the remapping weights as a permutation matrix that relates DoFs on the source mesh to DoFs on the target mesh.
Definition at line 52 of file TempestLinearRemap.cpp.
References col_gdofmap, m_nTotDofs_Dest, m_nTotDofs_SrcCov, MB_SUCCESS, and row_gdofmap.
/* m_mapRemap size = (m_nTotDofs_Dest X m_nTotDofs_SrcCov) */
#ifdef VVERBOSE
std::ofstream output_file( "rowcolindices.txt", std::ios::out );
output_file << m_nTotDofs_Dest << " " << m_nTotDofs_SrcCov << " " << row_gdofmap.size() << " "
<< row_ldofmap.size() << " " << col_gdofmap.size() << " " << col_ldofmap.size() << "\n";
output_file << "Rows \n";
for( unsigned iv = 0; iv < row_gdofmap.size(); iv++ )
output_file << row_gdofmap[iv] << " " << row_dofmap[iv] << "\n";
output_file << "Cols \n";
for( unsigned iv = 0; iv < col_gdofmap.size(); iv++ )
output_file << col_gdofmap[iv] << " " << col_dofmap[iv] << "\n";
output_file.flush(); // required here
output_file.close();
#endif
if( use_GID_matching )
std::map< unsigned, unsigned > src_gl;
for( unsigned it = 0; it < col_gdofmap.size(); ++it )
src_gl[col_gdofmap[it]] = it;
std::map< unsigned, unsigned >::iterator iter;
for( unsigned it = 0; it < row_gdofmap.size(); ++it )
unsigned row = row_gdofmap[it];
iter = src_gl.find( row );
if( strict_check && iter == src_gl.end() )
std::cout << "Searching for global target DOF " << row
<< " but could not find correspondence in source mesh.\n";
assert( false );
else if( iter == src_gl.end() )
continue;
else
unsigned icol = src_gl[row];
unsigned irow = it;
// Set the permutation matrix in local space
m_mapRemap( irow, icol ) = 1.0;
else
/* Create a Kd-tree to perform local queries to find nearest neighbors */
| void moab::TempestOnlineMap::LinearRemapSE0_Tempest_MOAB | ( | const DataArray3D< int > & | dataGLLNodes, |
| const DataArray3D< double > & | dataGLLJacobian | ||
| ) | [private] |
Generate the OfflineMap for linear conserative element-average spectral element to element average remapping.
| void moab::TempestOnlineMap::LinearRemapSE4_Tempest_MOAB | ( | const DataArray3D< int > & | dataGLLNodes, |
| ) | [private] |
Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping.
Definition at line 475 of file TempestLinearRemap.cpp.
References center(), dbgprint, ForceConsistencyConservation3(), moab::DebugOutput::printf(), and moab::DebugOutput::set_prefix().
// Order of the polynomial interpolant
int nP = dataGLLNodes.GetRows();
DataArray2D< double > dSampleCoeff( nP, nP );
// GLL Quadrature nodes on quadrilateral elements
GaussLobattoQuadrature::GetPoints( nP, 0.0, 1.0, dG, dW );
// Announcements
dbgprint.set_prefix( "[LinearRemapSE4_Tempest_MOAB]: " );
if( is_root )
dbgprint.printf( 0, "Finite Element to Finite Volume Projection\n" );
dbgprint.printf( 0, "Order of the FE polynomial interpolant: %i\n", nP );
// NodeVector from m_meshOverlap
// Vector of source areas
DataArray1D< double > vecSourceArea( nP * nP );
DataArray1D< double > vecTargetArea;
DataArray2D< double > dCoeff;
#ifdef VERBOSE
std::stringstream sstr;
sstr << "remapdata_" << rank << ".txt";
std::ofstream output_file( sstr.str() );
#endif
// Current Overlap Face
int ixOverlap = 0;
Face faceTri( 3 );
// Loop over all input Faces
if( faceFirst.edges.size() != 4 )
_EXCEPTIONT( "Only quadrilateral elements allowed for SE remapping" );
#ifdef VERBOSE
#endif
// Need to re-number the overlap elements such that vecSourceFaceIx[a:b] = 0, then 1 and so
// on wrt the input mesh data Then the overlap_end and overlap_begin will be correct.
// However, the relation with MOAB and Tempest will go out of the roof
break;
nOverlapFaces++;
// No overlaps
continue;
// Allocate remap coefficients array for meshFirst Face
DataArray3D< double > dRemapCoeff( nP, nP, nOverlapFaces );
// Find the local remap coefficients
const Face& faceOverlap = m_meshOverlap->faces[ixOverlap + j];
if( m_meshOverlap->vecFaceArea[ixOverlap + j] < 1.e-16 ) // machine precision
Announce( "Very small overlap at index %i area polygon: (%1.10e )", ixOverlap + j,
m_meshOverlap->vecFaceArea[ixOverlap + j] );
int n = faceOverlap.edges.size();
Announce( "Number nodes: %d", n );
for( int k = 0; k < n; k++ )
Node nd = nodesOverlap[faceOverlap[k]];
Announce( "Node %d %d : %1.10e %1.10e %1.10e ", k, faceOverlap[k], nd.x, nd.y, nd.z );
continue;
// #ifdef VERBOSE
// if ( is_root )
// Announce ( "\tLocal ID: %i/%i = %i, areas = %2.8e", j + ixOverlap, nOverlapFaces,
// m_remapper->lid_to_gid_covsrc[m_meshOverlap->vecSourceFaceIx[ixOverlap + j]],
// m_meshOverlap->vecFaceArea[ixOverlap + j] );
// #endif
if( nbEdges > 3 )
double dTriangleArea;
for( int k = 0; k < nOverlapTriangles; k++ )
dTriangleArea = CalculateFaceArea( faceOverlap, nodesOverlap );
node0 = center;
node1 = nodesOverlap[faceOverlap[k]];
int k1 = ( k + 1 ) % nbEdges;
node2 = nodesOverlap[faceOverlap[k1]];
nodes[0] = center;
nodes[1] = node1;
nodes[2] = node2;
// Coordinates of quadrature Node
for( int l = 0; l < TriQuadraturePoints; l++ )
Node nodeQuadrature;
nodeQuadrature.x = TriQuadratureG[l][0] * node0.x + TriQuadratureG[l][1] * node1.x +
TriQuadratureG[l][2] * node2.x;
nodeQuadrature.y = TriQuadratureG[l][0] * node0.y + TriQuadratureG[l][1] * node1.y +
TriQuadratureG[l][2] * node2.y;
nodeQuadrature.z = TriQuadratureG[l][0] * node0.z + TriQuadratureG[l][1] * node1.z +
TriQuadratureG[l][2] * node2.z;
nodeQuadrature = nodeQuadrature.Normalized();
double dAlpha;
double dBeta;
ApplyInverseMap( faceFirst, nodesFirst, nodeQuadrature, dAlpha, dBeta );
if( ( dAlpha < -1.0e-13 ) || ( dAlpha > 1.0 + 1.0e-13 ) || ( dBeta < -1.0e-13 ) ||
( dBeta > 1.0 + 1.0e-13 ) )
_EXCEPTION4( "Inverse Map for element %d and subtriangle %d out of range "
"(%1.5e %1.5e)",
j, l, dAlpha, dBeta );
// Sample the finite element at this point
SampleGLLFiniteElement( nMonotoneType, nP, dAlpha, dBeta, dSampleCoeff );
// Add sample coefficients to the map if m_meshOverlap->vecFaceArea[ixOverlap + j] > 0
for( int p = 0; p < nP; p++ )
for( int q = 0; q < nP; q++ )
dRemapCoeff[p][q][j] += TriQuadratureW[l] * dTriangleArea * dSampleCoeff[p][q] /
m_meshOverlap->vecFaceArea[ixOverlap + j];
#ifdef VERBOSE
output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t";
output_file << dRemapCoeff[p][q][j] << " ";
output_file << std::endl;
#endif
double dTargetArea = 0.0;
dTargetArea += m_meshOverlap->vecFaceArea[ixOverlap + j];
vecSourceArea[p * nP + q] = dataGLLJacobian[p][q][ixFirst];
const double areaTolerance = 1e-10;
// Source elements are completely covered by target volumes
if( fabs( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea ) <= areaTolerance )
vecTargetArea.Allocate( nOverlapFaces );
vecTargetArea[j] = m_meshOverlap->vecFaceArea[ixOverlap + j];
dCoeff.Allocate( nOverlapFaces, nP * nP );
dCoeff[j][p * nP + q] = dRemapCoeff[p][q][j];
// Target volumes only partially cover source elements
else if( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea > areaTolerance )
double dExtraneousArea = m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea;
vecTargetArea.Allocate( nOverlapFaces + 1 );
vecTargetArea[nOverlapFaces] = dExtraneousArea;
#ifdef VERBOSE
Announce( "Partial volume: %i (%1.10e / %1.10e)", ixFirst, dTargetArea,
m_meshInputCov->vecFaceArea[ixFirst] );
#endif
if( dTargetArea > m_meshInputCov->vecFaceArea[ixFirst] )
_EXCEPTIONT( "Partial element area exceeds total element area" );
dCoeff.Allocate( nOverlapFaces + 1, nP * nP );
dCoeff[nOverlapFaces][p * nP + q] = dataGLLJacobian[p][q][ixFirst];
dCoeff[nOverlapFaces][p * nP + q] -=
dRemapCoeff[p][q][j] * m_meshOverlap->vecFaceArea[ixOverlap + j];
dCoeff[nOverlapFaces][p * nP + q] /= dExtraneousArea;
// Source elements only partially cover target volumes
else
Announce( "Coverage area: %1.10e, and target element area: %1.10e)", ixFirst,
m_meshInputCov->vecFaceArea[ixFirst], dTargetArea );
_EXCEPTIONT( "Target grid must be a subset of source grid" );
ForceConsistencyConservation3( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType > 0 )
/*, m_remapper->lid_to_gid_covsrc[ixFirst]*/ );
dRemapCoeff[p][q][j] = dCoeff[j][p * nP + q];
#ifdef VERBOSE
// output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t";
// for ( int j = 0; j < nOverlapFaces; j++ )
// for ( int p = 0; p < nP; p++ )
// for ( int q = 0; q < nP; q++ )
// output_file << dRemapCoeff[p][q][j] << " ";
// output_file << std::endl;
#endif
// Put these remap coefficients into the SparseMatrix map
if( fContinuousIn )
int ixFirstNode = dataGLLNodes[p][q][ixFirst] - 1;
smatMap( ixSecondFace, ixFirstNode ) += dRemapCoeff[p][q][j] *
m_meshOverlap->vecFaceArea[ixOverlap + j] /
m_meshOutput->vecFaceArea[ixSecondFace];
else
int ixFirstNode = ixFirst * nP * nP + p * nP + q;
#ifdef VERBOSE
#endif
return;
| moab::ErrorCode moab::TempestOnlineMap::ReadParallelMap | ( | const char * | strSource, |
| const std::vector< int > & | owned_dof_ids, | ||
| bool | row_major_ownership = true |
Generate the metadata associated with the offline map.
Read the OfflineMap from a NetCDF file.
Definition at line 1181 of file TempestOnlineMapIO.cpp.
References CHECK_EXCEPTION, moab::TupleList::enableWriteAccess(), moab::error(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_SUCCESS, moab::TupleList::reset(), size, moab::TupleList::sort(), moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vr_rd, and moab::TupleList::vr_wr.
NcVar *varRow = NULL, *varCol = NULL, *varS = NULL;
int nS = 0, nA = 0, nB = 0;
#ifdef MOAB_HAVE_PNETCDF
// some variables will be used just in the case netcdfpar reader fails
int ncfile = -1, ret = 0;
int ndims, nvars, ngatts, unlimited;
#endif
#ifdef MOAB_HAVE_NETCDFPAR
bool is_independent = true;
ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 );
// ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcmpiFile::replace, NcmpiFile::classic5 );
#else
NcFile ncMap( strSource, NcFile::ReadOnly );
#endif
#define CHECK_EXCEPTION( obj, type, varstr ) \
if( obj == NULL ) \
_EXCEPTION3( "Map file \"%s\" does not contain %s \"%s\"", strSource, type, varstr ); \
// Read SparseMatrix entries
if( ncMap.is_valid() )
NcDim* dimNS = ncMap.get_dim( "n_s" );
CHECK_EXCEPTION( dimNS, "dimension", "n_s" );
NcDim* dimNA = ncMap.get_dim( "n_a" );
CHECK_EXCEPTION( dimNA, "dimension", "n_a" );
NcDim* dimNB = ncMap.get_dim( "n_b" );
CHECK_EXCEPTION( dimNB, "dimension", "n_b" );
// store total number of nonzeros
nS = dimNS->size();
nA = dimNA->size();
nB = dimNB->size();
varRow = ncMap.get_var( "row" );
CHECK_EXCEPTION( varRow, "variable", "row" );
varCol = ncMap.get_var( "col" );
CHECK_EXCEPTION( varCol, "variable", "col" );
varS = ncMap.get_var( "S" );
CHECK_EXCEPTION( varS, "variable", "S" );
ncMap.enable_var_par_access( varRow, is_independent );
ncMap.enable_var_par_access( varCol, is_independent );
ncMap.enable_var_par_access( varS, is_independent );
#endif
else
// read the file using pnetcdf directly, in parallel; need to have MPI, we do not check that anymore
// why build wth pnetcdf without MPI ?
// ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 );
ret = ncmpi_open( m_pcomm->comm(), strSource, NC_NOWRITE, MPI_INFO_NULL, &ncfile );
ERR_PARNC( ret ); // bail out completely
ret = ncmpi_inq( ncfile, &ndims, &nvars, &ngatts, &unlimited );
ERR_PARNC( ret );
// find dimension ids for n_S
int ins;
ret = ncmpi_inq_dimid( ncfile, "n_s", &ins );
ERR_PARNC( ret );
MPI_Offset leng;
ret = ncmpi_inq_dimlen( ncfile, ins, &leng );
ERR_PARNC( ret );
nS = (int)leng;
ret = ncmpi_inq_dimid( ncfile, "n_b", &ins );
ERR_PARNC( ret );
ERR_PARNC( ret );
nB = (int)leng;
#else
_EXCEPTION1( "cannot read the file %s", strSource );
#endif
// Let us declare the map object for every process
SparseMatrix< double >& sparseMatrix = this->GetSparseMatrix();
int localSize = nS / size;
long offsetRead = rank * localSize;
// leftovers on last rank
if( rank == size - 1 )
localSize += nS % size;
std::vector< int > vecRow, vecCol;
std::vector< double > vecS;
vecRow.resize( localSize );
vecCol.resize( localSize );
vecS.resize( localSize );
varRow->set_cur( (long)( offsetRead ) );
varRow->get( &( vecRow[0] ), localSize );
varCol->set_cur( (long)( offsetRead ) );
varCol->get( &( vecCol[0] ), localSize );
varS->set_cur( (long)( offsetRead ) );
varS->get( &( vecS[0] ), localSize );
ncMap.close();
else
// fill the local vectors with the variables from pnetcdf file; first inquire, then fill
MPI_Offset start = (MPI_Offset)offsetRead;
MPI_Offset count = (MPI_Offset)localSize;
int varid;
ret = ncmpi_inq_varid( ncfile, "S", &varid );
ERR_PARNC( ret );
ret = ncmpi_get_vara_double_all( ncfile, varid, &start, &count, &vecS[0] );
ERR_PARNC( ret );
ret = ncmpi_inq_varid( ncfile, "row", &varid );
ERR_PARNC( ret );
ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecRow[0] );
ERR_PARNC( ret );
ret = ncmpi_inq_varid( ncfile, "col", &varid );
ERR_PARNC( ret );
ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecCol[0] );
ERR_PARNC( ret );
ret = ncmpi_close( ncfile );
ERR_PARNC( ret );
#endif
// Now let us set the necessary global-to-local ID maps so that A*x operations
// can be performed cleanly as if map was computed online
row_dtoc_dofmap.clear();
// row_dtoc_dofmap.reserve( nB / size );
col_dtoc_dofmap.clear();
rowMap.clear();
colMap.clear();
// col_dtoc_dofmap.reserve( 2 * nA / size );
// row_dtoc_dofmap.resize( m_nTotDofs_Dest, UINT_MAX );
// col_dtoc_dofmap.resize( m_nTotDofs_SrcCov, UINT_MAX );
#ifdef MOAB_HAVE_MPI
// bother with tuple list only if size > 1
// otherwise, just fill the sparse matrix
if( size > 1 )
std::vector< int > ownership;
// the default trivial partitioning scheme
int nDofs = nB; // this is for row partitioning
if( !row_partition ) nDofs = nA; // column partitioning
// assert(row_major_ownership == true); // this block is valid only for row-based partitioning
ownership.resize( size );
int nPerPart = nDofs / size;
int nRemainder = nDofs % size; // Keep the remainder in root
ownership[0] = nPerPart + nRemainder;
for( int ip = 1, roffset = ownership[0]; ip < size; ++ip )
roffset += nPerPart;
ownership[ip] = roffset;
moab::TupleList* tl = new moab::TupleList;
unsigned numr = 1; //
tl->initialize( 3, 0, 0, numr, localSize ); // to proc, row, col, value
tl->enableWriteAccess();
// populate
for( int i = 0; i < localSize; i++ )
int rowval = vecRow[i] - 1; // dofs are 1 based in the file
int colval = vecCol[i] - 1;
int to_proc = -1;
int dof_val = colval;
if( row_partition ) dof_val = rowval;
if( ownership[0] > dof_val )
to_proc = 0;
else
for( int ip = 1; ip < size; ++ip )
if( ownership[ip - 1] <= dof_val && ownership[ip] > dof_val )
to_proc = ip;
break;
int n = tl->get_n();
tl->vi_wr[3 * n] = to_proc;
tl->vi_wr[3 * n + 1] = rowval;
tl->vi_wr[3 * n + 2] = colval;
tl->vr_wr[n] = vecS[i];
tl->inc_n();
// heavy communication
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl, 0 );
if( owned_dof_ids.size() > 0 )
// we need to send desired dof to the rendez_vous point
moab::TupleList tl_re; //
tl_re.initialize( 2, 0, 0, 0, owned_dof_ids.size() ); // to proc, value
tl_re.enableWriteAccess();
// send first to rendez_vous point, decided by trivial partitioning
for( size_t i = 0; i < owned_dof_ids.size(); i++ )
int to_proc = -1;
int dof_val = owned_dof_ids[i] - 1; // dofs are 1 based in the file, partition from 0 ?
to_proc = 0;
else
to_proc = ip;
break;
int n = tl_re.get_n();
tl_re.vi_wr[2 * n] = to_proc;
tl_re.vi_wr[2 * n + 1] = dof_val;
tl_re.inc_n();
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tl_re, 0 );
// now we know in tl_re where do we need to send back dof_val
moab::TupleList::buffer sort_buffer;
sort_buffer.buffer_init( tl_re.get_n() );
tl_re.sort( 1, &sort_buffer ); // so now we order by value
sort_buffer.buffer_init( tl->get_n() );
int indexOrder = 2; // colVal
if( row_partition ) indexOrder = 1; // rowVal
//tl->sort( indexOrder, &sort_buffer );
std::map< int, int > startDofIndex, endDofIndex; // indices in tl_re for values we want
int dofVal = -1;
if( tl_re.get_n() > 0 ) dofVal = tl_re.vi_rd[1]; // first dof val on this rank
startDofIndex[dofVal] = 0;
endDofIndex[dofVal] = 0; // start and end
for( unsigned k = 1; k < tl_re.get_n(); k++ )
int newDof = tl_re.vi_rd[2 * k + 1];
if( dofVal == newDof )
endDofIndex[dofVal] = k; // increment by 1 actually
else
dofVal = newDof;
startDofIndex[dofVal] = k;
// basically, for each value we are interested in, index in tl_re with those values are
// tl_re.vi_rd[2*startDofIndex+1] == valDof == tl_re.vi_rd[2*endDofIndex+1]
// so now we have ordered
// tl_re shows to what proc do we need to send the tuple (row, col, val)
moab::TupleList* tl_back = new moab::TupleList;
// localSize is a good guess, but maybe it should be bigger ?
// this could be bigger for repeated dofs
tl_back->initialize( 3, 0, 0, numr, tl->get_n() ); // to proc, row, col, value
tl_back->enableWriteAccess();
// now loop over tl and tl_re to see where to send
// form the new tuple, which will contain the desired dofs per task, per row or column distribution
for( unsigned k = 0; k < tl->get_n(); k++ )
int valDof = tl->vi_rd[3 * k + indexOrder]; // 1 for row, 2 for column // first value, it should be
for( int ire = startDofIndex[valDof]; ire <= endDofIndex[valDof]; ire++ )
int to_proc = tl_re.vi_rd[2 * ire];
int n = tl_back->get_n();
tl_back->vi_wr[3 * n] = to_proc;
tl_back->vi_wr[3 * n + 1] = tl->vi_rd[3 * k + 1]; // row
tl_back->vi_wr[3 * n + 2] = tl->vi_rd[3 * k + 2]; // col
tl_back->vr_wr[n] = tl->vr_rd[k];
tl_back->inc_n();
// now communicate to the desired tasks:
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl_back, 0 );
tl_re.reset(); // clear memory, although this will go out of scope
tl->reset();
tl = tl_back;
int rindexMax = 0, cindexMax = 0;
// populate the sparsematrix, using rowMap and colMap
for( int i = 0; i < n; i++ )
int rindex, cindex;
const int& vecRowValue = tl->vi_wr[3 * i + 1];
const int& vecColValue = tl->vi_wr[3 * i + 2];
std::map< int, int >::iterator riter = rowMap.find( vecRowValue );
if( riter == rowMap.end() )
rowMap[vecRowValue] = rindexMax;
rindex = rindexMax;
row_gdofmap.push_back( vecRowValue );
// row_dtoc_dofmap.push_back( vecRowValue );
rindexMax++;
else
rindex = riter->second;
std::map< int, int >::iterator citer = colMap.find( vecColValue );
if( citer == colMap.end() )
colMap[vecColValue] = cindexMax;
cindex = cindexMax;
col_gdofmap.push_back( vecColValue );
// col_dtoc_dofmap.push_back( vecColValue );
cindexMax++;
else
cindex = citer->second;
sparseMatrix( rindex, cindex ) = tl->vr_wr[i];
tl->reset();
else
#endif
for( int i = 0; i < nS; i++ )
int rindex, cindex;
const int& vecRowValue = vecRow[i] - 1; // the rows, cols are 1 based in the file
const int& vecColValue = vecCol[i] - 1;
rindex = rindexMax;
rindexMax++;
else
cindex = cindexMax;
cindexMax++;
else
sparseMatrix( rindex, cindex ) = vecS[i];
m_nTotDofs_SrcCov = sparseMatrix.GetColumns();
m_nTotDofs_Dest = sparseMatrix.GetRows();
this->copy_tempest_sparsemat_to_eigen3();
#endif
// Reset the source and target data first
m_rowVector.setZero();
m_colVector.setZero();
return moab::MB_SUCCESS;
| moab::ErrorCode moab::TempestOnlineMap::set_col_dc_dofs | ( | std::vector< int > & | values_entities | ) |
Definition at line 687 of file TempestOnlineMap.cpp.
References MB_SUCCESS.
// col_gdofmap has global dofs , that should be in the list of values, such that
// row_dtoc_dofmap[offsetDOF] = localDOF;
// // we need to find col_dtoc_dofmap such that: col_gdofmap[ col_dtoc_dofmap[i] ] == values_entities [i];
// we know that col_gdofmap[0..(nbcols-1)] = global_col_dofs -> in values_entities
// form first inverse
col_dtoc_dofmap.resize( values_entities.size() );
for( int j = 0; j < (int)values_entities.size(); j++ )
if( colMap.find( values_entities[j] - 1 ) != colMap.end() )
col_dtoc_dofmap[j] = colMap[values_entities[j] - 1];
else
col_dtoc_dofmap[j] = -1; // signal that this value should not be used in
// std::cout <<"values_entities[j] - 1: " << values_entities[j] - 1 <<" at index j = " << j << " not
// found in colMap \n";
| moab::ErrorCode moab::TempestOnlineMap::set_row_dc_dofs | ( | std::vector< int > & | values_entities | ) |
Definition at line 710 of file TempestOnlineMap.cpp.
// row_dtoc_dofmap = values_entities; // needs to point to local
// we need to find row_dtoc_dofmap such that: row_gdofmap[ row_dtoc_dofmap[i] ] == values_entities [i];
row_dtoc_dofmap.resize( values_entities.size() );
if( rowMap.find( values_entities[j] - 1 ) != rowMap.end() )
row_dtoc_dofmap[j] = rowMap[values_entities[j] - 1]; // values are 1 based, but rowMap, colMap are not
else
row_dtoc_dofmap[j] = -1; // not all values are used
// found in rowMap \n";
| void moab::TempestOnlineMap::SetDestinationNDofsPerElement | ( | int | nt | ) | [inline] |
Get the number of Degrees-Of-Freedom per element on the destination mesh.
Definition at line 509 of file TempestOnlineMap.hpp.
m_nDofsPEl_Dest = nt;
| moab::ErrorCode moab::TempestOnlineMap::SetDOFmapAssociation | ( | DiscretizationType | srcType, |
| bool | isSrcContinuous, | ||
| DataArray3D< int > * | srcdataGLLNodes, | ||
| DataArray3D< int > * | srcdataGLLNodesSrc, | ||
| DiscretizationType | destType, | ||
| bool | isDestContinuous, | ||
| DataArray3D< int > * | tgtdataGLLNodes | ||
Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently.
Definition at line 214 of file TempestOnlineMap.cpp.
References ErrorCode, MB_CHK_ERR, and MB_SUCCESS.
moab::ErrorCode rval;
std::vector< bool > dgll_cgll_row_ldofmap, dgll_cgll_col_ldofmap, dgll_cgll_covcol_ldofmap;
std::vector< int > src_soln_gdofs, locsrc_soln_gdofs, tgt_soln_gdofs;
// We are assuming that these are element based tags that are sized: np * np
m_srcDiscType = srcType;
m_destDiscType = destType;
bool vprint = is_root && false;
#ifdef VVERBOSE
src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, -1 );
rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src );
rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest );
rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
if( is_root )
std::ofstream output_file( "sourcecov-gids-0.txt" );
output_file << "I, GDOF\n";
for( unsigned i = 0; i < src_soln_gdofs.size(); ++i )
output_file << i << ", " << src_soln_gdofs[i] << "\n";
output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
m_nTotDofs_SrcCov = 0;
if( isSrcContinuous )
dgll_cgll_covcol_ldofmap.resize(
m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
for( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ )
for( int p = 0; p < m_nDofsPEl_Src; p++ )
for( int q = 0; q < m_nDofsPEl_Src; q++ )
const int localDOF = ( *srcdataGLLNodes )[p][q][j] - 1;
const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
if( isSrcContinuous && !dgll_cgll_covcol_ldofmap[localDOF] )
m_nTotDofs_SrcCov++;
dgll_cgll_covcol_ldofmap[localDOF] = true;
output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", " << localDOF
<< ", " << src_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
dgll_cgll_covcol_ldofmap.clear();
std::ofstream output_file( "source-gids-0.txt" );
for( unsigned i = 0; i < locsrc_soln_gdofs.size(); ++i )
output_file << i << ", " << locsrc_soln_gdofs[i] << "\n";
m_nTotDofs_Src = 0;
dgll_cgll_col_ldofmap.resize(
m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
for( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ )
const int localDOF = ( *srcdataGLLNodesSrc )[p][q][j] - 1;
if( isSrcContinuous && !dgll_cgll_col_ldofmap[localDOF] )
m_nTotDofs_Src++;
dgll_cgll_col_ldofmap[localDOF] = true;
output_file << m_remapper->lid_to_gid_src[j] << ", " << offsetDOF << ", " << localDOF
<< ", " << locsrc_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_Src << "\n";
dgll_cgll_col_ldofmap.clear();
std::ofstream output_file( "target-gids-0.txt" );
for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
output_file << i << ", " << tgt_soln_gdofs[i] << "\n";
output_file << "ELEMID, IDOF, GDOF, NDOF\n";
m_nTotDofs_Dest = 0;
output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", "
<< m_nTotDofs_Dest << "\n";
m_nTotDofs_Dest++;
else
std::ofstream output_file( "sourcecov-gids-1.txt" );
std::ofstream output_file( "source-gids-1.txt" );
m_nTotDofs_Src = 0;
m_nTotDofs_Src++;
std::ofstream output_file( "target-gids-1.txt" );
m_nTotDofs_Dest++;
#endif
// Now compute the mapping and store it for the covering mesh
int srcTagSize = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
if( m_remapper->point_cloud_source )
assert( m_nDofsPEl_Src == 1 );
col_gdofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
col_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
src_soln_gdofs.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_vertices, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
srcTagSize = 1;
else
col_gdofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
col_dtoc_dofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
// std::cout << "TOnlineMap: Process: " << rank << " and covering entities = [" <<
// col_dofmap.size() << ", " << src_soln_gdofs.size() << "]\n"; MPI_Barrier(MPI_COMM_WORLD);
#ifdef ALTERNATE_NUMBERING_IMPLEMENTATION
unsigned maxSrcIndx = 0;
// for ( unsigned j = 0; j < m_covering_source_entities.size(); j++ )
std::vector< int > locdofs( srcTagSize );
std::map< Node, moab::EntityHandle > mapLocalMBNodes;
double elcoords[3];
for( unsigned iel = 0; iel < m_remapper->m_covering_source_entities.size(); ++iel )
EntityHandle eh = m_remapper->m_covering_source_entities[iel];
rval = m_interface->get_coords( &eh, 1, elcoords );MB_CHK_ERR( rval );
Node elCentroid( elcoords[0], elcoords[1], elcoords[2] );
mapLocalMBNodes.insert( std::pair< Node, moab::EntityHandle >( elCentroid, eh ) );
const NodeVector& nodes = m_remapper->m_covering_source->nodes;
for( unsigned j = 0; j < m_remapper->m_covering_source->faces.size(); j++ )
const Face& face = m_remapper->m_covering_source->faces[j];
Node centroid;
centroid.x = centroid.y = centroid.z = 0.0;
for( unsigned l = 0; l < face.edges.size(); ++l )
centroid.x += nodes[face[l]].x;
centroid.y += nodes[face[l]].y;
centroid.z += nodes[face[l]].z;
const double factor = 1.0 / face.edges.size();
centroid.x *= factor;
centroid.y *= factor;
centroid.z *= factor;
EntityHandle current_eh;
if( mapLocalMBNodes.find( centroid ) != mapLocalMBNodes.end() )
current_eh = mapLocalMBNodes[centroid];
rval = m_interface->tag_get_data( m_dofTagSrc, ¤t_eh, 1, &locdofs[0] );MB_CHK_ERR( rval );
const int offsetDOF = p * m_nDofsPEl_Src + q;
maxSrcIndx = ( localDOF > maxSrcIndx ? localDOF : maxSrcIndx );
std::cout << "Col: " << current_eh << ", " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF
<< ", " << localDOF << ", " << locdofs[offsetDOF] - 1 << ", " << maxSrcIndx << "\n";
#endif
if( srcdataGLLNodes == NULL )
{ /* we only have a mapping for elements as DoFs */
for( unsigned i = 0; i < col_gdofmap.size(); ++i )
assert( src_soln_gdofs[i] > 0 );
col_gdofmap[i] = src_soln_gdofs[i] - 1;
col_dtoc_dofmap[i] = i;
if( vprint ) std::cout << "Col: " << i << ", " << col_gdofmap[i] << "\n";
else
dgll_cgll_covcol_ldofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, false );
const int offsetDOF = j * srcTagSize + p * m_nDofsPEl_Src + q;
if( !isSrcContinuous ) m_nTotDofs_SrcCov++;
assert( src_soln_gdofs[offsetDOF] > 0 );
col_gdofmap[localDOF] = src_soln_gdofs[offsetDOF] - 1;
col_dtoc_dofmap[offsetDOF] = localDOF;
if( vprint )
std::cout << "Col: " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", "
<< localDOF << ", " << col_gdofmap[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
srccol_gdofmap.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
srccol_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
locsrc_soln_gdofs.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_vertices, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
else
srccol_gdofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
srccol_dtoc_dofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
// Now compute the mapping and store it for the original source mesh
m_nTotDofs_Src = 0;
if( srcdataGLLNodesSrc == NULL )
for( unsigned i = 0; i < srccol_gdofmap.size(); ++i )
assert( locsrc_soln_gdofs[i] > 0 );
srccol_gdofmap[i] = locsrc_soln_gdofs[i] - 1;
srccol_dtoc_dofmap[i] = i;
m_nTotDofs_Src++;
else
if( isSrcContinuous ) dgll_cgll_col_ldofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, false );
m_nTotDofs_Src++;
if( !isSrcContinuous ) m_nTotDofs_Src++;
assert( locsrc_soln_gdofs[offsetDOF] > 0 );
srccol_gdofmap[localDOF] = locsrc_soln_gdofs[offsetDOF] - 1;
srccol_dtoc_dofmap[offsetDOF] = localDOF;
int tgtTagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
if( m_remapper->point_cloud_target )
assert( m_nDofsPEl_Dest == 1 );
row_gdofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
row_dtoc_dofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
tgt_soln_gdofs.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_vertices, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
tgtTagSize = 1;
else
row_gdofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
row_dtoc_dofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
// Now compute the mapping and store it for the target mesh
// To access the GID for each row: row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF
if( tgtdataGLLNodes == NULL )
for( unsigned i = 0; i < row_gdofmap.size(); ++i )
assert( tgt_soln_gdofs[i] > 0 );
row_gdofmap[i] = tgt_soln_gdofs[i] - 1;
row_dtoc_dofmap[i] = i;
if( vprint ) std::cout << "Row: " << i << ", " << row_gdofmap[i] << "\n";
m_nTotDofs_Dest++;
else
if( isTgtContinuous ) dgll_cgll_row_ldofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, false );
for( unsigned j = 0; j < m_remapper->m_target_entities.size(); j++ )
for( int p = 0; p < m_nDofsPEl_Dest; p++ )
for( int q = 0; q < m_nDofsPEl_Dest; q++ )
const int localDOF = ( *tgtdataGLLNodes )[p][q][j] - 1;
const int offsetDOF = j * tgtTagSize + p * m_nDofsPEl_Dest + q;
if( isTgtContinuous && !dgll_cgll_row_ldofmap[localDOF] )
m_nTotDofs_Dest++;
dgll_cgll_row_ldofmap[localDOF] = true;
if( !isTgtContinuous ) m_nTotDofs_Dest++;
assert( tgt_soln_gdofs[offsetDOF] > 0 );
row_gdofmap[localDOF] = tgt_soln_gdofs[offsetDOF] - 1;
if( vprint )
std::cout << "Row: " << m_remapper->lid_to_gid_tgt[j] << ", " << offsetDOF << ", " << localDOF
<< ", " << row_gdofmap[offsetDOF] << ", " << m_nTotDofs_Dest << "\n";
// Let us also allocate the local representation of the sparse matrix
#if defined( MOAB_HAVE_EIGEN3 ) && defined( VERBOSE )
if( vprint )
std::cout << "[" << rank << "]"
<< "DoFs: row = " << m_nTotDofs_Dest << ", " << row_gdofmap.size() << ", col = " << m_nTotDofs_Src
<< ", " << m_nTotDofs_SrcCov << ", " << col_gdofmap.size() << "\n";
// std::cout << "Max col_dofmap: " << maxcol << ", Min col_dofmap" << mincol << "\n";
#endif
// check monotonicity of row_gdofmap and col_gdofmap
#ifdef CHECK_INCREASING_DOF
for( size_t i = 0; i < row_gdofmap.size() - 1; i++ )
if( row_gdofmap[i] > row_gdofmap[i + 1] )
std::cout << " on rank " << rank << " in row_gdofmap[" << i << "]=" << row_gdofmap[i] << " > row_gdofmap["
<< i + 1 << "]=" << row_gdofmap[i + 1] << " \n";
for( size_t i = 0; i < col_gdofmap.size() - 1; i++ )
if( col_gdofmap[i] > col_gdofmap[i + 1] )
std::cout << " on rank " << rank << " in col_gdofmap[" << i << "]=" << col_gdofmap[i] << " > col_gdofmap["
<< i + 1 << "]=" << col_gdofmap[i + 1] << " \n";
#endif
| moab::ErrorCode moab::TempestOnlineMap::SetDOFmapTags | ( | const std::string | srcDofTagName, |
| const std::string | tgtDofTagName | ||
Store the tag names associated with global DoF ids for source and target meshes.
Definition at line 158 of file TempestOnlineMap.cpp.
References ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, and MB_TYPE_INTEGER.
int tagSize = 0;
tagSize = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
rval =
m_interface->tag_get_handle( srcDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagSrc, MB_TAG_ANY );
if( rval == moab::MB_TAG_NOT_FOUND && m_eInputType != DiscretizationType_FV )
int ntot_elements = 0, nelements = m_remapper->m_source_entities.size();
int ierr = MPI_Allreduce( &nelements, &ntot_elements, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
if( ierr != 0 ) MB_CHK_SET_ERR( MB_FAILURE, "MPI_Allreduce failed to get total source elements" );
#else
ntot_elements = nelements;
#endif
rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_covering_source_entities,
&m_remapper->m_source_entities, srcDofTagName, m_nDofsPEl_Src );MB_CHK_ERR( rval );
rval = m_interface->tag_get_handle( srcDofTagName.c_str(), m_nDofsPEl_Src * m_nDofsPEl_Src, MB_TYPE_INTEGER,
this->m_dofTagSrc, MB_TAG_ANY );MB_CHK_ERR( rval );
else
MB_CHK_ERR( rval );
tagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
rval =
m_interface->tag_get_handle( tgtDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagDest, MB_TAG_ANY );
if( rval == moab::MB_TAG_NOT_FOUND && m_eOutputType != DiscretizationType_FV )
int ntot_elements = 0, nelements = m_remapper->m_target_entities.size();
#else
#endif
rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_target_entities, NULL, tgtDofTagName,
m_nDofsPEl_Dest );MB_CHK_ERR( rval );
rval = m_interface->tag_get_handle( tgtDofTagName.c_str(), m_nDofsPEl_Dest * m_nDofsPEl_Dest, MB_TYPE_INTEGER,
this->m_dofTagDest, MB_TAG_ANY );MB_CHK_ERR( rval );
else
MB_CHK_ERR( rval );
| void moab::TempestOnlineMap::SetSourceNDofsPerElement | ( | int | ns | ) | [inline] |
Set the number of Degrees-Of-Freedom per element on the source mesh.
Definition at line 504 of file TempestOnlineMap.hpp.
m_nDofsPEl_Src = ns;
| void moab::TempestOnlineMap::setup_sizes_dimensions | ( | ) | [private] |
Definition at line 98 of file TempestOnlineMap.cpp.
References moab::TempestRemapper::RLL.
Referenced by TempestOnlineMap().
if( m_meshInputCov )
std::vector< std::string > dimNames;
std::vector< int > dimSizes;
if( m_remapper->m_source_type == moab::TempestRemapper::RLL && m_remapper->m_source_metadata.size() )
dimNames.push_back( "lat" );
dimNames.push_back( "lon" );
dimSizes.resize( 2, 0 );
dimSizes[0] = m_remapper->m_source_metadata[1];
dimSizes[1] = m_remapper->m_source_metadata[2];
else
dimNames.push_back( "num_elem" );
dimSizes.push_back( m_meshInputCov->faces.size() );
this->InitializeSourceDimensions( dimNames, dimSizes );
if( m_meshOutput )
if( m_remapper->m_target_type == moab::TempestRemapper::RLL && m_remapper->m_target_metadata.size() )
dimSizes[0] = m_remapper->m_target_metadata[1];
dimSizes[1] = m_remapper->m_target_metadata[2];
else
dimSizes.push_back( m_meshOutput->faces.size() );
this->InitializeTargetDimensions( dimNames, dimSizes );
| moab::ErrorCode moab::TempestOnlineMap::WriteHDF5MapFile | ( | const std::string & | filename | ) | [private] |
Parallel I/O with NetCDF to write out the SCRIP file from multiple processors.
Need to get the global maximum of number of vertices per element Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However, when writing this out, other processes may have a different size for the same array. This is hence a mess to consolidate in h5mtoscrip eventually.
Definition at line 776 of file TempestOnlineMapIO.cpp.
References ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, moab::TempestRemapper::RLL, root_set, size, and t.
* Need to get the global maximum of number of vertices per element
* Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for
*dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However,
*when writing this out, other processes may have a different size for the same array. This is
*hence a mess to consolidate in h5mtoscrip eventually.
/* Let us compute all relevant data for the current original source mesh on the process */
DataArray1D< double > vecSourceFaceArea, vecTargetFaceArea;
DataArray1D< double > dSourceCenterLon, dSourceCenterLat, dTargetCenterLon, dTargetCenterLat;
DataArray2D< double > dSourceVertexLon, dSourceVertexLat, dTargetVertexLon, dTargetVertexLat;
if( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD )
this->InitializeCoordinatesFromMeshFV(
*m_meshInput, dSourceCenterLon, dSourceCenterLat, dSourceVertexLon, dSourceVertexLat,
( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ) /* fLatLon = false */,
m_remapper->max_source_edges );
vecSourceFaceArea.Allocate( m_meshInput->vecFaceArea.GetRows() );
for( unsigned i = 0; i < m_meshInput->vecFaceArea.GetRows(); ++i )
vecSourceFaceArea[i] = m_meshInput->vecFaceArea[i];
else
DataArray3D< double > dataGLLJacobianSrc;
this->InitializeCoordinatesFromMeshFE( *m_meshInput, m_nDofsPEl_Src, dataGLLNodesSrc, dSourceCenterLon,
dSourceCenterLat, dSourceVertexLon, dSourceVertexLat );
// Generate the continuous Jacobian for input mesh
GenerateMetaData( *m_meshInput, m_nDofsPEl_Src, false /* fBubble */, dataGLLNodesSrc, dataGLLJacobianSrc );
if( m_srcDiscType == DiscretizationType_CGLL )
GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, m_meshInput->vecFaceArea );
else
GenerateDiscontinuousJacobian( dataGLLJacobianSrc, m_meshInput->vecFaceArea );
vecSourceFaceArea.Allocate( m_meshInput->faces.size() * m_nDofsPEl_Src * m_nDofsPEl_Src );
int offset = 0;
for( size_t e = 0; e < m_meshInput->faces.size(); e++ )
for( int s = 0; s < m_nDofsPEl_Src; s++ )
for( int t = 0; t < m_nDofsPEl_Src; t++ )
vecSourceFaceArea[srccol_dtoc_dofmap[offset + s * m_nDofsPEl_Src + t]] =
dataGLLJacobianSrc[s][t][e];
offset += m_nDofsPEl_Src * m_nDofsPEl_Src;
if( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD )
*m_meshOutput, dTargetCenterLon, dTargetCenterLat, dTargetVertexLon, dTargetVertexLat,
( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ) /* fLatLon = false */,
m_remapper->max_target_edges );
vecTargetFaceArea.Allocate( m_meshOutput->vecFaceArea.GetRows() );
for( unsigned i = 0; i < m_meshOutput->vecFaceArea.GetRows(); ++i )
vecTargetFaceArea[i] = m_meshOutput->vecFaceArea[i];
else
DataArray3D< double > dataGLLJacobianDest;
this->InitializeCoordinatesFromMeshFE( *m_meshOutput, m_nDofsPEl_Dest, dataGLLNodesDest, dTargetCenterLon,
dTargetCenterLat, dTargetVertexLon, dTargetVertexLat );
GenerateMetaData( *m_meshOutput, m_nDofsPEl_Dest, false /* fBubble */, dataGLLNodesDest, dataGLLJacobianDest );
if( m_destDiscType == DiscretizationType_CGLL )
GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, m_meshOutput->vecFaceArea );
else
GenerateDiscontinuousJacobian( dataGLLJacobianDest, m_meshOutput->vecFaceArea );
vecTargetFaceArea.Allocate( m_meshOutput->faces.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest );
int offset = 0;
for( size_t e = 0; e < m_meshOutput->faces.size(); e++ )
for( int s = 0; s < m_nDofsPEl_Dest; s++ )
for( int t = 0; t < m_nDofsPEl_Dest; t++ )
vecTargetFaceArea[row_dtoc_dofmap[offset + s * m_nDofsPEl_Dest + t]] = dataGLLJacobianDest[s][t][e];
offset += m_nDofsPEl_Dest * m_nDofsPEl_Dest;
moab::EntityHandle& m_meshOverlapSet = m_remapper->m_overlap_set;
int tot_src_ents = m_remapper->m_source_entities.size();
int tot_tgt_ents = m_remapper->m_target_entities.size();
int tot_src_size = dSourceCenterLon.GetRows();
int tot_tgt_size = m_dTargetCenterLon.GetRows();
int tot_vsrc_size = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns();
int tot_vtgt_size = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns();
const int weightMatNNZ = m_weightMatrix.nonZeros();
moab::Tag tagMapMetaData, tagMapIndexRow, tagMapIndexCol, tagMapValues, srcEleIDs, tgtEleIDs;
rval = m_interface->tag_get_handle( "SMAT_DATA", 13, moab::MB_TYPE_INTEGER, tagMapMetaData,
moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" );
rval = m_interface->tag_get_handle( "SMAT_ROWS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexRow,
moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" );
rval = m_interface->tag_get_handle( "SMAT_COLS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexCol,
rval = m_interface->tag_get_handle( "SMAT_VALS", weightMatNNZ, moab::MB_TYPE_DOUBLE, tagMapValues,
rval = m_interface->tag_get_handle( "SourceGIDS", tot_src_size, moab::MB_TYPE_INTEGER, srcEleIDs,
rval = m_interface->tag_get_handle( "TargetGIDS", tot_tgt_size, moab::MB_TYPE_INTEGER, tgtEleIDs,
moab::Tag srcAreaValues, tgtAreaValues;
rval = m_interface->tag_get_handle( "SourceAreas", tot_src_size, moab::MB_TYPE_DOUBLE, srcAreaValues,
rval = m_interface->tag_get_handle( "TargetAreas", tot_tgt_size, moab::MB_TYPE_DOUBLE, tgtAreaValues,
moab::Tag tagSrcCoordsCLon, tagSrcCoordsCLat, tagTgtCoordsCLon, tagTgtCoordsCLat;
rval = m_interface->tag_get_handle( "SourceCoordCenterLon", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLon,
rval = m_interface->tag_get_handle( "SourceCoordCenterLat", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLat,
rval = m_interface->tag_get_handle( "TargetCoordCenterLon", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLon,
rval = m_interface->tag_get_handle( "TargetCoordCenterLat", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLat,
moab::Tag tagSrcCoordsVLon, tagSrcCoordsVLat, tagTgtCoordsVLon, tagTgtCoordsVLat;
rval = m_interface->tag_get_handle( "SourceCoordVertexLon", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLon,
rval = m_interface->tag_get_handle( "SourceCoordVertexLat", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLat,
rval = m_interface->tag_get_handle( "TargetCoordVertexLon", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLon,
rval = m_interface->tag_get_handle( "TargetCoordVertexLat", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLat,
moab::Tag srcMaskValues, tgtMaskValues;
if( m_iSourceMask.IsAttached() )
rval = m_interface->tag_get_handle( "SourceMask", m_iSourceMask.GetRows(), moab::MB_TYPE_INTEGER, srcMaskValues,
if( m_iTargetMask.IsAttached() )
rval = m_interface->tag_get_handle( "TargetMask", m_iTargetMask.GetRows(), moab::MB_TYPE_INTEGER, tgtMaskValues,
std::vector< int > smatrowvals( weightMatNNZ ), smatcolvals( weightMatNNZ );
std::vector< double > smatvals( weightMatNNZ );
// const double* smatvals = m_weightMatrix.valuePtr();
// Loop over the matrix entries and find the max global ID for rows and columns
for( int k = 0, offset = 0; k < m_weightMatrix.outerSize(); ++k )
for( moab::TempestOnlineMap::WeightMatrix::InnerIterator it( m_weightMatrix, k ); it; ++it, ++offset )
smatrowvals[offset] = this->GetRowGlobalDoF( it.row() );
smatcolvals[offset] = this->GetColGlobalDoF( it.col() );
smatvals[offset] = it.value();
/* Set the global IDs for the DoFs */
// col_gdofmap [ col_ldofmap [ 0 : local_ndofs ] ] = GDOF
// row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF
int maxrow = 0, maxcol = 0;
std::vector< int > src_global_dofs( tot_src_size ), tgt_global_dofs( tot_tgt_size );
for( int i = 0; i < tot_src_size; ++i )
src_global_dofs[i] = srccol_gdofmap[i];
maxcol = ( src_global_dofs[i] > maxcol ) ? src_global_dofs[i] : maxcol;
for( int i = 0; i < tot_tgt_size; ++i )
tgt_global_dofs[i] = row_gdofmap[i];
maxrow = ( tgt_global_dofs[i] > maxrow ) ? tgt_global_dofs[i] : maxrow;
// The metadata in H5M file contains the following data:
// 1. n_a: Total source entities: (number of elements in source mesh)
// 2. n_b: Total target entities: (number of elements in target mesh)
// 3. nv_a: Max edge size of elements in source mesh
// 4. nv_b: Max edge size of elements in target mesh
// 5. maxrows: Number of rows in remap weight matrix
// 6. maxcols: Number of cols in remap weight matrix
// 7. nnz: Number of total nnz in sparse remap weight matrix
// 8. np_a: The order of the field description on the source mesh: >= 1
// 9. np_b: The order of the field description on the target mesh: >= 1
// 10. method_a: The type of discretization for field on source mesh: [0 = FV, 1 = cGLL, 2 =
// dGLL]
// 11. method_b: The type of discretization for field on target mesh: [0 = FV, 1 = cGLL, 2 =
// dGLL]
// 12. conserved: Flag to specify whether the remap operator has conservation constraints: [0,
// 1]
// 13. monotonicity: Flags to specify whether the remap operator has monotonicity constraints:
// [0, 1, 2]
int map_disc_details[6];
map_disc_details[0] = m_nDofsPEl_Src;
map_disc_details[1] = m_nDofsPEl_Dest;
map_disc_details[2] = ( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD
? 0
: ( m_srcDiscType == DiscretizationType_CGLL ? 1 : 2 ) );
map_disc_details[3] = ( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD
? 0
: ( m_destDiscType == DiscretizationType_CGLL ? 1 : 2 ) );
map_disc_details[4] = ( m_bConserved ? 1 : 0 );
map_disc_details[5] = m_iMonotonicity;
int loc_smatmetadata[13] = {tot_src_ents,
tot_tgt_ents,
m_remapper->max_source_edges,
m_remapper->max_target_edges,
maxrow + 1,
maxcol + 1,
weightMatNNZ,
map_disc_details[0],
map_disc_details[1],
map_disc_details[2],
map_disc_details[3],
map_disc_details[4],
map_disc_details[5]};
rval = m_interface->tag_set_data( tagMapMetaData, &m_meshOverlapSet, 1, &loc_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
int glb_smatmetadata[13] = {0,
0,
0,
0,
0,
0,
0,
int loc_buf[7] = {
tot_src_ents, tot_tgt_ents, weightMatNNZ, m_remapper->max_source_edges, m_remapper->max_target_edges,
maxrow, maxcol};
int glb_buf[4] = {0, 0, 0, 0};
MPI_Reduce( &loc_buf[0], &glb_buf[0], 3, MPI_INT, MPI_SUM, 0, m_pcomm->comm() );
glb_smatmetadata[0] = glb_buf[0];
glb_smatmetadata[1] = glb_buf[1];
glb_smatmetadata[6] = glb_buf[2];
MPI_Reduce( &loc_buf[3], &glb_buf[0], 4, MPI_INT, MPI_MAX, 0, m_pcomm->comm() );
glb_smatmetadata[2] = glb_buf[0];
glb_smatmetadata[3] = glb_buf[1];
glb_smatmetadata[4] = glb_buf[2];
glb_smatmetadata[5] = glb_buf[3];
#else
int glb_smatmetadata[13] = {tot_src_ents,
tot_tgt_ents,
maxrow,
maxcol,
weightMatNNZ,
#endif
// These values represent number of rows and columns. So should be 1-based.
glb_smatmetadata[4]++;
glb_smatmetadata[5]++;
if( this->is_root )
std::cout << " " << this->rank << " Writing remap weights with size [" << glb_smatmetadata[4] << " X "
<< glb_smatmetadata[5] << "] and NNZ = " << glb_smatmetadata[6] << std::endl;
EntityHandle root_set = 0;
rval = m_interface->tag_set_data( tagMapMetaData, &root_set, 1, &glb_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
int dsize;
const int numval = weightMatNNZ;
const void* smatrowvals_d = smatrowvals.data();
const void* smatcolvals_d = smatcolvals.data();
const void* smatvals_d = smatvals.data();
rval = m_interface->tag_set_by_ptr( tagMapIndexRow, &m_meshOverlapSet, 1, &smatrowvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagMapIndexCol, &m_meshOverlapSet, 1, &smatcolvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagMapValues, &m_meshOverlapSet, 1, &smatvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
const void* srceleidvals_d = src_global_dofs.data();
const void* tgteleidvals_d = tgt_global_dofs.data();
dsize = src_global_dofs.size();
rval = m_interface->tag_set_by_ptr( srcEleIDs, &m_meshOverlapSet, 1, &srceleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
dsize = tgt_global_dofs.size();
rval = m_interface->tag_set_by_ptr( tgtEleIDs, &m_meshOverlapSet, 1, &tgteleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
/* Set the source and target areas */
const void* srcareavals_d = vecSourceFaceArea;
const void* tgtareavals_d = vecTargetFaceArea;
dsize = tot_src_size;
rval = m_interface->tag_set_by_ptr( srcAreaValues, &m_meshOverlapSet, 1, &srcareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
dsize = tot_tgt_size;
rval = m_interface->tag_set_by_ptr( tgtAreaValues, &m_meshOverlapSet, 1, &tgtareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
/* Set the coordinates for source and target center vertices */
const void* srccoordsclonvals_d = &dSourceCenterLon[0];
const void* srccoordsclatvals_d = &dSourceCenterLat[0];
dsize = dSourceCenterLon.GetRows();
rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLon, &m_meshOverlapSet, 1, &srccoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLat, &m_meshOverlapSet, 1, &srccoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
const void* tgtcoordsclonvals_d = &m_dTargetCenterLon[0];
const void* tgtcoordsclatvals_d = &m_dTargetCenterLat[0];
dsize = vecTargetFaceArea.GetRows();
rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLon, &m_meshOverlapSet, 1, &tgtcoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLat, &m_meshOverlapSet, 1, &tgtcoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
/* Set the coordinates for source and target element vertices */
const void* srccoordsvlonvals_d = &( dSourceVertexLon[0][0] );
const void* srccoordsvlatvals_d = &( dSourceVertexLat[0][0] );
dsize = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns();
rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLon, &m_meshOverlapSet, 1, &srccoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLat, &m_meshOverlapSet, 1, &srccoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
const void* tgtcoordsvlonvals_d = &( m_dTargetVertexLon[0][0] );
const void* tgtcoordsvlatvals_d = &( m_dTargetVertexLat[0][0] );
dsize = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns();
rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLon, &m_meshOverlapSet, 1, &tgtcoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLat, &m_meshOverlapSet, 1, &tgtcoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
/* Set the masks for source and target meshes if available */
const void* srcmaskvals_d = m_iSourceMask;
dsize = m_iSourceMask.GetRows();
rval = m_interface->tag_set_by_ptr( srcMaskValues, &m_meshOverlapSet, 1, &srcmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
const void* tgtmaskvals_d = m_iTargetMask;
dsize = m_iTargetMask.GetRows();
rval = m_interface->tag_set_by_ptr( tgtMaskValues, &m_meshOverlapSet, 1, &tgtmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
const char* writeOptions = ( this->size > 1 ? "PARALLEL=WRITE_PART" : "" );
#else
const char* writeOptions = "";
#endif
// EntityHandle sets[3] = {m_remapper->m_source_set, m_remapper->m_target_set, m_remapper->m_overlap_set};
EntityHandle sets[1] = {m_remapper->m_overlap_set};
rval = m_interface->write_file( strOutputFile.c_str(), NULL, writeOptions, sets, 1 );MB_CHK_ERR( rval );
#ifdef WRITE_SCRIP_FILE
sstr.str( "" );
sstr << ctx.outFilename.substr( 0, lastindex ) << "_" << proc_id << ".nc";
std::map< std::string, std::string > mapAttributes;
mapAttributes["Creator"] = "MOAB mbtempest workflow";
if( !ctx.proc_id ) std::cout << "Writing offline map to file: " << sstr.str() << std::endl;
this->Write( strOutputFile.c_str(), mapAttributes, NcFile::Netcdf4 );
sstr.str( "" );
#endif
| moab::ErrorCode moab::TempestOnlineMap::WriteParallelMap | ( | const std::string & | strTarget | ) |
Write the TempestOnlineMap to a parallel NetCDF file.
Definition at line 168 of file TempestOnlineMapIO.cpp.
References ErrorCode, and MB_CHK_ERR.
Referenced by main().
size_t lastindex = strFilename.find_last_of( "." );
std::string extension = strFilename.substr( lastindex + 1, strFilename.size() );
// Write the map file to disk in parallel
if( extension == "nc" )
/* Invoke the actual call to write the parallel map to disk in SCRIP format */
rval = this->WriteSCRIPMapFile( strFilename.c_str() );MB_CHK_ERR( rval );
else
/* Write to the parallel H5M format */
rval = this->WriteHDF5MapFile( strFilename.c_str() );MB_CHK_ERR( rval );
return rval;
| moab::ErrorCode moab::TempestOnlineMap::WriteSCRIPMapFile | ( | const std::string & | strOutputFile | ) | [private] |
Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections.
Parallel I/O with HDF5 to write out the remapping weights from multiple processors.
Definition at line 192 of file TempestOnlineMapIO.cpp.
References moab::TupleList::enableWriteAccess(), moab::error(), ErrorCode, moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_CHK_SET_ERR, MB_SUCCESS, nr, moab::TempestRemapper::RLL, size, moab::Remapper::SourceMesh, moab::Remapper::TargetMesh, moab::TupleList::vi_wr, and moab::TupleList::vr_wr.
NcError error( NcError::silent_nonfatal );
ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcFile::Replace, NcFile::Netcdf4 );
#else
NcFile ncMap( strFilename.c_str(), NcFile::Replace );
#endif
if( !ncMap.is_valid() )
_EXCEPTION1( "Unable to open output map file \"%s\"", strFilename.c_str() );
// Attributes
ncMap.add_att( "Title", "MOAB-TempestRemap Online Regridding Weight Generator" );
( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ), /* fLatLon = false */
else
GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, vecSourceFaceArea );
else
GenerateDiscontinuousJacobian( dataGLLJacobianSrc, vecSourceFaceArea );
( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ), /* fLatLon = false */
else
GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, vecTargetFaceArea );
else
GenerateDiscontinuousJacobian( dataGLLJacobianDest, vecTargetFaceArea );
// Map dimensions
unsigned nA = ( vecSourceFaceArea.GetRows() );
unsigned nB = ( vecTargetFaceArea.GetRows() );
std::vector< int > masksA, masksB;
ErrorCode rval = m_remapper->GetIMasks( moab::Remapper::SourceMesh, masksA );MB_CHK_SET_ERR( rval, "Trouble getting masks for source" );
rval = m_remapper->GetIMasks( moab::Remapper::TargetMesh, masksB );MB_CHK_SET_ERR( rval, "Trouble getting masks for target" );
// Number of nodes per Face
int nSourceNodesPerFace = dSourceVertexLon.GetColumns();
int nTargetNodesPerFace = dTargetVertexLon.GetColumns();
// if source or target cells have triangles at poles, center of those triangles need to come from
// the original quad, not from center in 3d, converted to 2d again
// start copy OnlineMap.cpp tempestremap
// right now, do this only for source mesh; copy the logic for target mesh
for( unsigned i = 0; i < nA; i++ )
const Face& face = m_meshInput->faces[i];
int nNodes = face.edges.size();
int indexNodeAtPole = -1;
if( 3 == nNodes ) // check if one node at the poles
for( int j = 0; j < nNodes; j++ )
if( fabs( fabs( dSourceVertexLat[i][j] ) - 90.0 ) < 1.0e-12 )
indexNodeAtPole = j;
break;
if( indexNodeAtPole < 0 ) continue; // continue i loop, do nothing
// recompute center of cell, from 3d data; add one 2 nodes at pole, and average
int nodeAtPole = face[indexNodeAtPole]; // use the overloaded operator
Node nodePole = m_meshInput->nodes[nodeAtPole];
Node newCenter = nodePole * 2;
for( int j = 1; j < nNodes; j++ )
int indexi = ( indexNodeAtPole + j ) % nNodes; // nNodes is 3 !
const Node& node = m_meshInput->nodes[face[indexi]];
newCenter = newCenter + node;
newCenter = newCenter * 0.25;
newCenter = newCenter.Normalized();
#ifdef VERBOSE
double iniLon = dSourceCenterLon[i], iniLat = dSourceCenterLat[i];
#endif
// dSourceCenterLon, dSourceCenterLat
XYZtoRLL_Deg( newCenter.x, newCenter.y, newCenter.z, dSourceCenterLon[i], dSourceCenterLat[i] );
#ifdef VERBOSE
std::cout << " modify center of triangle from " << iniLon << " " << iniLat << " to " << dSourceCenterLon[i]
<< " " << dSourceCenterLat[i] << "\n";
#endif
// first move data if in parallel
#if defined( MOAB_HAVE_MPI )
int max_row_dof, max_col_dof; // output; arrays will be re-distributed in chunks [maxdof/size]
// if (size > 1)
int ierr = rearrange_arrays_by_dofs( srccol_gdofmap, vecSourceFaceArea, dSourceCenterLon, dSourceCenterLat,
dSourceVertexLon, dSourceVertexLat, masksA, nA, nSourceNodesPerFace,
max_col_dof ); // now nA will be close to maxdof/size
if( ierr != 0 )
_EXCEPTION1( "Unable to arrange source data %d ", nA );
// rearrange target data: (nB)
ierr = rearrange_arrays_by_dofs( row_gdofmap, vecTargetFaceArea, dTargetCenterLon, dTargetCenterLat,
dTargetVertexLon, dTargetVertexLat, masksB, nB, nTargetNodesPerFace,
max_row_dof ); // now nA will be close to maxdof/size
if( ierr != 0 )
_EXCEPTION1( "Unable to arrange target data %d ", nB );
#endif
// Number of non-zeros in the remap matrix operator
int nS = m_weightMatrix.nonZeros();
#if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_NETCDFPAR )
int locbuf[5] = {(int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace};
int offbuf[3] = {0, 0, 0};
int globuf[5] = {0, 0, 0, 0, 0};
MPI_Scan( locbuf, offbuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() );
MPI_Allreduce( locbuf, globuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() );
MPI_Allreduce( &locbuf[3], &globuf[3], 2, MPI_INT, MPI_MAX, m_pcomm->comm() );
// MPI_Scan is inclusive of data in current rank; modify accordingly.
offbuf[0] -= nA;
offbuf[1] -= nB;
offbuf[2] -= nS;
#else
int globuf[5] = {(int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace};
#endif
// Write output dimensions entries
unsigned nSrcGridDims = ( m_vecSourceDimSizes.size() );
unsigned nDstGridDims = ( m_vecTargetDimSizes.size() );
NcDim* dimSrcGridRank = ncMap.add_dim( "src_grid_rank", nSrcGridDims );
NcDim* dimDstGridRank = ncMap.add_dim( "dst_grid_rank", nDstGridDims );
NcVar* varSrcGridDims = ncMap.add_var( "src_grid_dims", ncInt, dimSrcGridRank );
NcVar* varDstGridDims = ncMap.add_var( "dst_grid_dims", ncInt, dimDstGridRank );
ncMap.enable_var_par_access( varSrcGridDims, is_independent );
ncMap.enable_var_par_access( varDstGridDims, is_independent );
#endif
char szDim[64];
if( ( nSrcGridDims == 1 ) && ( m_vecSourceDimSizes[0] != (int)nA ) )
varSrcGridDims->put( &globuf[0], 1 );
varSrcGridDims->add_att( "name0", "num_dof" );
else
for( unsigned i = 0; i < m_vecSourceDimSizes.size(); i++ )
int tmp = ( i == 0 ? globuf[0] : m_vecSourceDimSizes[i] );
varSrcGridDims->set_cur( nSrcGridDims - i - 1 );
varSrcGridDims->put( &( tmp ), 1 );
sprintf( szDim, "name%i", i );
varSrcGridDims->add_att( szDim, m_vecSourceDimNames[nSrcGridDims - i - 1].c_str() );
if( ( nDstGridDims == 1 ) && ( m_vecTargetDimSizes[0] != (int)nB ) )
varDstGridDims->put( &globuf[1], 1 );
varDstGridDims->add_att( "name0", "num_dof" );
else
for( unsigned i = 0; i < m_vecTargetDimSizes.size(); i++ )
int tmp = ( i == 0 ? globuf[1] : m_vecTargetDimSizes[i] );
varDstGridDims->set_cur( nDstGridDims - i - 1 );
varDstGridDims->put( &( tmp ), 1 );
varDstGridDims->add_att( szDim, m_vecTargetDimNames[nDstGridDims - i - 1].c_str() );
// Source and Target mesh resolutions
NcDim* dimNA = ncMap.add_dim( "n_a", globuf[0] );
NcDim* dimNB = ncMap.add_dim( "n_b", globuf[1] );
NcDim* dimNVA = ncMap.add_dim( "nv_a", globuf[3] );
NcDim* dimNVB = ncMap.add_dim( "nv_b", globuf[4] );
// Write coordinates
NcVar* varYCA = ncMap.add_var( "yc_a", ncDouble, dimNA );
NcVar* varYCB = ncMap.add_var( "yc_b", ncDouble, dimNB );
NcVar* varXCA = ncMap.add_var( "xc_a", ncDouble, dimNA );
NcVar* varXCB = ncMap.add_var( "xc_b", ncDouble, dimNB );
NcVar* varYVA = ncMap.add_var( "yv_a", ncDouble, dimNA, dimNVA );
NcVar* varYVB = ncMap.add_var( "yv_b", ncDouble, dimNB, dimNVB );
NcVar* varXVA = ncMap.add_var( "xv_a", ncDouble, dimNA, dimNVA );
NcVar* varXVB = ncMap.add_var( "xv_b", ncDouble, dimNB, dimNVB );
// Write masks
NcVar* varMaskA = ncMap.add_var( "mask_a", ncInt, dimNA );
NcVar* varMaskB = ncMap.add_var( "mask_b", ncInt, dimNB );
ncMap.enable_var_par_access( varYCA, is_independent );
ncMap.enable_var_par_access( varYCB, is_independent );
ncMap.enable_var_par_access( varXCA, is_independent );
ncMap.enable_var_par_access( varXCB, is_independent );
ncMap.enable_var_par_access( varYVA, is_independent );
ncMap.enable_var_par_access( varYVB, is_independent );
ncMap.enable_var_par_access( varXVA, is_independent );
ncMap.enable_var_par_access( varXVB, is_independent );
ncMap.enable_var_par_access( varMaskA, is_independent );
ncMap.enable_var_par_access( varMaskB, is_independent );
#endif
varYCA->add_att( "units", "degrees" );
varYCB->add_att( "units", "degrees" );
varXCA->add_att( "units", "degrees" );
varXCB->add_att( "units", "degrees" );
varYVA->add_att( "units", "degrees" );
varYVB->add_att( "units", "degrees" );
varXVA->add_att( "units", "degrees" );
varXVB->add_att( "units", "degrees" );
// Verify dimensionality
if( dSourceCenterLon.GetRows() != nA )
_EXCEPTIONT( "Mismatch between dSourceCenterLon and nA" );
if( dSourceCenterLat.GetRows() != nA )
_EXCEPTIONT( "Mismatch between dSourceCenterLat and nA" );
if( dTargetCenterLon.GetRows() != nB )
_EXCEPTIONT( "Mismatch between dTargetCenterLon and nB" );
if( dTargetCenterLat.GetRows() != nB )
_EXCEPTIONT( "Mismatch between dTargetCenterLat and nB" );
if( dSourceVertexLon.GetRows() != nA )
_EXCEPTIONT( "Mismatch between dSourceVertexLon and nA" );
if( dSourceVertexLat.GetRows() != nA )
_EXCEPTIONT( "Mismatch between dSourceVertexLat and nA" );
if( dTargetVertexLon.GetRows() != nB )
_EXCEPTIONT( "Mismatch between dTargetVertexLon and nB" );
if( dTargetVertexLat.GetRows() != nB )
_EXCEPTIONT( "Mismatch between dTargetVertexLat and nB" );
varYCA->set_cur( (long)offbuf[0] );
varYCA->put( &( dSourceCenterLat[0] ), nA );
varYCB->set_cur( (long)offbuf[1] );
varYCB->put( &( dTargetCenterLat[0] ), nB );
varXCA->set_cur( (long)offbuf[0] );
varXCA->put( &( dSourceCenterLon[0] ), nA );
varXCB->set_cur( (long)offbuf[1] );
varXCB->put( &( dTargetCenterLon[0] ), nB );
varYVA->set_cur( (long)offbuf[0] );
varYVA->put( &( dSourceVertexLat[0][0] ), nA, nSourceNodesPerFace );
varYVB->set_cur( (long)offbuf[1] );
varYVB->put( &( dTargetVertexLat[0][0] ), nB, nTargetNodesPerFace );
varXVA->set_cur( (long)offbuf[0] );
varXVA->put( &( dSourceVertexLon[0][0] ), nA, nSourceNodesPerFace );
varXVB->set_cur( (long)offbuf[1] );
varXVB->put( &( dTargetVertexLon[0][0] ), nB, nTargetNodesPerFace );
varMaskA->set_cur( (long)offbuf[0] );
varMaskA->put( &( masksA[0] ), nA );
varMaskB->set_cur( (long)offbuf[1] );
varMaskB->put( &( masksB[0] ), nB );
// Write areas
NcVar* varAreaA = ncMap.add_var( "area_a", ncDouble, dimNA );
ncMap.enable_var_par_access( varAreaA, is_independent );
#endif
varAreaA->set_cur( (long)offbuf[0] );
varAreaA->put( &( vecSourceFaceArea[0] ), nA );
NcVar* varAreaB = ncMap.add_var( "area_b", ncDouble, dimNB );
ncMap.enable_var_par_access( varAreaB, is_independent );
#endif
varAreaB->set_cur( (long)offbuf[1] );
varAreaB->put( &( vecTargetFaceArea[0] ), nB );
// Write SparseMatrix entries
DataArray1D< int > vecRow( nS );
DataArray1D< int > vecCol( nS );
DataArray1D< double > vecS( nS );
DataArray1D< double > dFracA( nA );
DataArray1D< double > dFracB( nB );
moab::TupleList tlValRow, tlValCol;
// value has to be sent to processor row/nB for for fracA and col/nA for fracB
// vecTargetArea (indexRow ) has to be sent for fracA (index col?)
// vecTargetFaceArea will have to be sent to col index, with its index !
tlValRow.initialize( 2, 0, 0, numr, nS ); // to proc(row), global row , value
tlValCol.initialize( 3, 0, 0, numr, nS ); // to proc(col), global row / col, value
tlValRow.enableWriteAccess();
tlValCol.enableWriteAccess();
dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
dFracB[ row ] += val ;
int offset = 0;
int nAbase = ( max_col_dof + 1 ) / size; // it is nA, except last rank ( == size - 1 )
int nBbase = ( max_row_dof + 1 ) / size; // it is nB, except last rank ( == size - 1 )
#endif
for( int i = 0; i < m_weightMatrix.outerSize(); ++i )
for( WeightMatrix::InnerIterator it( m_weightMatrix, i ); it; ++it )
vecRow[offset] = 1 + this->GetRowGlobalDoF( it.row() ); // row index
vecCol[offset] = 1 + this->GetColGlobalDoF( it.col() ); // col index
vecS[offset] = it.value(); // value
// value M(row, col) will contribute to procRow and procCol values for fracA and fracB
int procRow = ( vecRow[offset] - 1 ) / nBbase;
if( procRow >= size ) procRow = size - 1;
int procCol = ( vecCol[offset] - 1 ) / nAbase;
if( procCol >= size ) procCol = size - 1;
int nrInd = tlValRow.get_n();
tlValRow.vi_wr[2 * nrInd] = procRow;
tlValRow.vi_wr[2 * nrInd + 1] = vecRow[offset] - 1;
tlValRow.vr_wr[nrInd] = vecS[offset];
tlValRow.inc_n();
int ncInd = tlValCol.get_n();
tlValCol.vi_wr[3 * ncInd] = procCol;
tlValCol.vi_wr[3 * ncInd + 1] = vecRow[offset] - 1;
tlValCol.vi_wr[3 * ncInd + 2] = vecCol[offset] - 1; // this is column
tlValCol.vr_wr[ncInd] = vecS[offset];
tlValCol.inc_n();
#endif
offset++;
// need to send values for their row and col processors, to compute fractions there
// now do the heavy communication
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValCol, 0 );
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValRow, 0 );
// we have now, for example, dFracB[ row ] += val ;
// so we know that on current task, we received tlValRow
// reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
// dFracB[ row ] += val ;
for( unsigned i = 0; i < tlValRow.get_n(); i++ )
// int fromProc = tlValRow.vi_wr[2 * i];
int gRowInd = tlValRow.vi_wr[2 * i + 1];
int localIndexRow = gRowInd - nBbase * rank; // modulo nBbase rank is from 0 to size - 1;
double wgt = tlValRow.vr_wr[i];
assert( localIndexRow >= 0 );
assert( nB - localIndexRow > 0 );
dFracB[localIndexRow] += wgt;
// to compute dFracA we need vecTargetFaceArea[ row ]; we know the row, and we can get the proc we need it from
std::set< int > neededRows;
for( unsigned i = 0; i < tlValCol.get_n(); i++ )
int rRowInd = tlValCol.vi_wr[3 * i + 1];
neededRows.insert( rRowInd );
// we need vecTargetFaceAreaGlobal[ rRowInd ]; this exists on proc procRow
moab::TupleList tgtAreaReq;
tgtAreaReq.initialize( 2, 0, 0, 0, neededRows.size() );
tgtAreaReq.enableWriteAccess();
for( std::set< int >::iterator sit = neededRows.begin(); sit != neededRows.end(); sit++ )
int neededRow = *sit;
int procRow = neededRow / nBbase;
int nr = tgtAreaReq.get_n();
tgtAreaReq.vi_wr[2 * nr] = procRow;
tgtAreaReq.vi_wr[2 * nr + 1] = neededRow;
tgtAreaReq.inc_n();
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaReq, 0 );
// we need to send back the tgtArea corresponding to row
moab::TupleList tgtAreaInfo; // load it with tgtArea at row
tgtAreaInfo.initialize( 2, 0, 0, 1, tgtAreaReq.get_n() );
tgtAreaInfo.enableWriteAccess();
for( unsigned i = 0; i < tgtAreaReq.get_n(); i++ )
int from_proc = tgtAreaReq.vi_wr[2 * i];
int row = tgtAreaReq.vi_wr[2 * i + 1];
int locaIndexRow = row - rank * nBbase;
double areaToSend = vecTargetFaceArea[locaIndexRow];
// int remoteIndex = tgtAreaReq.vi_wr[3*i + 2] ;
tgtAreaInfo.vi_wr[2 * i] = from_proc; // send back requested info
tgtAreaInfo.vi_wr[2 * i + 1] = row;
tgtAreaInfo.vr_wr[i] = areaToSend; // this will be tgt area at row
tgtAreaInfo.inc_n();
( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaInfo, 0 );
std::map< int, double > areaAtRow;
for( unsigned i = 0; i < tgtAreaInfo.get_n(); i++ )
// we have received from proc, value for row !
int row = tgtAreaInfo.vi_wr[2 * i + 1];
areaAtRow[row] = tgtAreaInfo.vr_wr[i];
// we have now for rows the
// it is ordered by index, so:
// now compute reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
// tgtAreaInfo will have at index i the area we need (from row)
// there should be an easier way :(
int colInd = tlValCol.vi_wr[3 * i + 2];
double val = tlValCol.vr_wr[i];
int localColInd = colInd - rank * nAbase; // < local nA
auto itMap = areaAtRow.find( rRowInd ); // it should be different from end
if( itMap != areaAtRow.end() )
double areaRow = itMap->second; // we fished a lot for this !
assert( localColInd < vecSourceFaceArea.GetRows() );
dFracA[localColInd] += val / vecSourceFaceArea[localColInd] * areaRow;
#endif
// Load in data
NcDim* dimNS = ncMap.add_dim( "n_s", globuf[2] );
NcVar* varRow = ncMap.add_var( "row", ncInt, dimNS );
NcVar* varCol = ncMap.add_var( "col", ncInt, dimNS );
NcVar* varS = ncMap.add_var( "S", ncDouble, dimNS );
#ifdef MOAB_HAVE_NETCDFPAR
#endif
varRow->set_cur( (long)offbuf[2] );
varRow->put( &( vecRow[0] ), nS );
varCol->set_cur( (long)offbuf[2] );
varCol->put( &( vecCol[0] ), nS );
varS->set_cur( (long)offbuf[2] );
varS->put( &( vecS[0] ), nS );
// Calculate and write fractional coverage arrays
NcVar* varFracA = ncMap.add_var( "frac_a", ncDouble, dimNA );
ncMap.enable_var_par_access( varFracA, is_independent );
#endif
varFracA->add_att( "name", "fraction of target coverage of source dof" );
varFracA->add_att( "units", "unitless" );
varFracA->set_cur( (long)offbuf[0] );
varFracA->put( &( dFracA[0] ), nA );
NcVar* varFracB = ncMap.add_var( "frac_b", ncDouble, dimNB );
ncMap.enable_var_par_access( varFracB, is_independent );
#endif
varFracB->add_att( "name", "fraction of source coverage of target dof" );
varFracB->add_att( "units", "unitless" );
varFracB->set_cur( (long)offbuf[1] );
varFracB->put( &( dFracB[0] ), nB );
// Add global attributes
// std::map<std::string, std::string>::const_iterator iterAttributes =
// mapAttributes.begin();
// for (; iterAttributes != mapAttributes.end(); iterAttributes++) {
// ncMap.add_att(
// iterAttributes->first.c_str(),
// iterAttributes->second.c_str());
ncMap.close();
std::vector< int > moab::TempestOnlineMap::col_dtoc_dofmap [private] |
Definition at line 444 of file TempestOnlineMap.hpp.
std::vector< unsigned > moab::TempestOnlineMap::col_gdofmap [private] |
Definition at line 441 of file TempestOnlineMap.hpp.
Referenced by fill_col_ids(), and LinearRemapNN_MOAB().
std::map< int, int > moab::TempestOnlineMap::colMap [private] |
Definition at line 446 of file TempestOnlineMap.hpp.
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesDest [private] |
Definition at line 448 of file TempestOnlineMap.hpp.
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesSrc [private] |
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesSrcCov [private] |
bool moab::TempestOnlineMap::is_parallel [private] |
Definition at line 463 of file TempestOnlineMap.hpp.
bool moab::TempestOnlineMap::is_root [private] |
bool moab::TempestOnlineMap::m_bConserved [private] |
Definition at line 455 of file TempestOnlineMap.hpp.
Definition at line 449 of file TempestOnlineMap.hpp.
Definition at line 440 of file TempestOnlineMap.hpp.
moab::Tag moab::TempestOnlineMap::m_dofTagSrc [private] |
The original tag data and local to global DoF mapping to associate matrix values to solution.
Definition at line 454 of file TempestOnlineMap.hpp.
int moab::TempestOnlineMap::m_iMonotonicity [private] |
Definition at line 456 of file TempestOnlineMap.hpp.
The reference to the moab::Core object that contains source/target and overlap sets.
Definition at line 428 of file TempestOnlineMap.hpp.
Mesh* moab::TempestOnlineMap::m_meshInput [private] |
Definition at line 458 of file TempestOnlineMap.hpp.
Mesh* moab::TempestOnlineMap::m_meshInputCov [private] |
Definition at line 459 of file TempestOnlineMap.hpp.
Mesh* moab::TempestOnlineMap::m_meshOutput [private] |
Definition at line 460 of file TempestOnlineMap.hpp.
Mesh* moab::TempestOnlineMap::m_meshOverlap [private] |
Definition at line 461 of file TempestOnlineMap.hpp.
int moab::TempestOnlineMap::m_nDofsPEl_Dest [private] |
Definition at line 453 of file TempestOnlineMap.hpp.
int moab::TempestOnlineMap::m_nDofsPEl_Src [private] |
int moab::TempestOnlineMap::m_nTotDofs_Dest [private] |
Definition at line 450 of file TempestOnlineMap.hpp.
Referenced by LinearRemapNN_MOAB().
int moab::TempestOnlineMap::m_nTotDofs_Src [private] |
int moab::TempestOnlineMap::m_nTotDofs_SrcCov [private] |
The fundamental remapping operator object.
Definition at line 415 of file TempestOnlineMap.hpp.
int moab::TempestOnlineMap::rank [private] |
Definition at line 464 of file TempestOnlineMap.hpp.
int moab::TempestOnlineMap::root_proc [private] |
std::vector< int > moab::TempestOnlineMap::row_dtoc_dofmap [private] |
std::vector< unsigned > moab::TempestOnlineMap::row_gdofmap [private] |
Referenced by fill_row_ids(), and LinearRemapNN_MOAB().
std::map< int, int > moab::TempestOnlineMap::rowMap [private] |
int moab::TempestOnlineMap::size [private] |
std::vector< int > moab::TempestOnlineMap::srccol_dtoc_dofmap [private] |
std::vector< unsigned > moab::TempestOnlineMap::srccol_gdofmap [private] |
