Mesh Oriented datABase
(version 5.4.1)
#include <HalfFacetRep.hpp>
Collaboration diagram for moab::HalfFacetRep:Classes | |
| struct | adj_matrix |
| struct | LocalMaps2D |
| 2D local maps More... | |
| struct | LocalMaps3D |
| 3D local maps More... | |
Public Member Functions | |
| HalfFacetRep (Core *impl, ParallelComm *comm=0, moab::EntityHandle rset=0, bool filter_ghosts=true) | |
| ~HalfFacetRep () | |
| bool | check_mixed_entity_type () |
| ErrorCode | initialize () |
| Constructs the sibling-half-facet and vertex-to-incident-half-facet maps for each dimension present in the input. This routine should be called before any calls for adjacency is made. | |
| ErrorCode | deinitialize () |
| Deinitialize. | |
| ErrorCode | print_tags (int dim) |
| Prints the tag values. | |
| ErrorCode | get_adjacencies (const EntityHandle source_entity, const unsigned int target_dimension, std::vector< EntityHandle > &target_entities) |
| Get the adjacencies associated with an entity. | |
| ErrorCode | get_up_adjacencies (EntityHandle ent, int out_dim, std::vector< EntityHandle > &adjents, std::vector< int > *lids=NULL) |
| Get the upward incidences associated with an entity. | |
| ErrorCode | get_neighbor_adjacencies (EntityHandle ent, std::vector< EntityHandle > &adjents) |
| Get the same-dimensional entities connected with an entity. | |
| ErrorCode | get_down_adjacencies (EntityHandle ent, int out_dim, std::vector< EntityHandle > &adjents) |
| Get the downward adjacent entities connected with an entity. | |
| ErrorCode | determine_sibling_halfverts (Range &verts, Range &edges) |
| Given a range of edges, determines the map for sibling half-verts and stores them into SIBHVS_EID, SIBHVS_LVID tags. | |
| ErrorCode | determine_incident_halfverts (Range &edges) |
| Given a range of edges, determines the map for incident half-verts and stores them into V2HV_EID, V2HV_LVID tags. | |
| ErrorCode | get_up_adjacencies_1d (EntityHandle vid, std::vector< EntityHandle > &adjents, std::vector< int > *lvids=NULL) |
| Given a vertex, finds the edges incident on it. | |
| ErrorCode | get_neighbor_adjacencies_1d (EntityHandle eid, std::vector< EntityHandle > &adjents) |
| Given an edge, finds vertex-connected neighbor edges. | |
| ErrorCode | determine_sibling_halfedges (Range &faces) |
| Given a range of faces, determines the sibling half-edges and stores them into SIBHES_FID, SIBHES_LEID tags. | |
| ErrorCode | determine_incident_halfedges (Range &faces) |
| Given a range of faces, determines the incident half-edges and stores them into V2HE_FID, V2HE_LEID tags. | |
| ErrorCode | get_up_adjacencies_vert_2d (EntityHandle vid, std::vector< EntityHandle > &adjents) |
| Given a vertex, finds the faces incident on it. | |
| ErrorCode | get_up_adjacencies_2d (EntityHandle eid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL) |
| Given an edge, finds the faces incident on it. | |
| ErrorCode | get_up_adjacencies_2d (EntityHandle fid, int leid, bool add_inent, std::vector< EntityHandle > &adj_ents, std::vector< int > *adj_leids=NULL, std::vector< int > *adj_orients=NULL) |
| Given a half-edge <fid, leid>, finds the faces incident on it. | |
| ErrorCode | get_neighbor_adjacencies_2d (EntityHandle fid, std::vector< EntityHandle > &adjents) |
| Given an edge, finds edge-connected neighbor face. | |
| ErrorCode | get_down_adjacencies_2d (EntityHandle fid, std::vector< EntityHandle > &adjents) |
| Given a face, finds its edges. | |
| int | find_total_edges_2d (Range &faces) |
| Given a range of faces, finds the total number of edges. | |
| ErrorCode | get_face_edges (EntityHandle fid, std::vector< EntityHandle > &edges) |
| ErrorCode | determine_sibling_halffaces (Range &cells) |
| Given a range of cells, determines the sibling half-faces and stores them into SIBHFS_CID, SIBHFS_LFID tags. | |
| ErrorCode | determine_incident_halffaces (Range &cells) |
| Given a range of cells, determines the incident half-faces and stores them into V2HF_CID, V2HF_LFID tags. | |
| ErrorCode | determine_border_vertices (Range &cells, Tag isborder) |
| Given a range of cells, tags all border vertices with a true value. | |
| ErrorCode | get_up_adjacencies_vert_3d (EntityHandle vid, std::vector< EntityHandle > &adjents) |
| Given a vertex, finds the cells incident on it. | |
| ErrorCode | get_up_adjacencies_edg_3d (EntityHandle eid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL) |
| Given an edge, finds the cells incident on it. | |
| ErrorCode | get_up_adjacencies_edg_3d (EntityHandle cid, int leid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL, std::vector< int > *adj_orients=NULL) |
| Given a local edge <cid, leid>, finds the cells incident on it. | |
| ErrorCode | get_up_adjacencies_edg_3d_comp (EntityHandle cid, int leid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL, std::vector< int > *adj_orients=NULL) |
| ErrorCode | get_up_adjacencies_face_3d (EntityHandle fid, std::vector< EntityHandle > &adjents, std::vector< int > *lfids=NULL) |
| Given an face, finds the cells incident on it. | |
| ErrorCode | get_up_adjacencies_face_3d (EntityHandle cid, int lfid, std::vector< EntityHandle > &adjents, std::vector< int > *lfids=NULL) |
| Given a local face <cid, lfid>, finds the cells incident on it. | |
| ErrorCode | get_neighbor_adjacencies_3d (EntityHandle cid, std::vector< EntityHandle > &adjents) |
| Given a cell, finds face-connected neighbor cells. | |
| ErrorCode | get_down_adjacencies_edg_3d (EntityHandle cid, std::vector< EntityHandle > &adjents) |
| Given a cell, finds its edges. | |
| ErrorCode | get_down_adjacencies_face_3d (EntityHandle cid, std::vector< EntityHandle > &adjents) |
| Given a cell, finds its faces. | |
| ErrorCode | find_total_edges_faces_3d (const Range &cells, int *nedges, int *nfaces) |
| ErrorCode | count_subentities (Range &edges, Range &faces, Range &cells, int *nedges, int *nfaces) |
| void | get_memory_use (unsigned long long &entity_total, unsigned long long &memory_total) |
| ErrorCode | get_half_facet_in_comp (EntityHandle cid, int leid, std::vector< EntityHandle > &ents, std::vector< int > &lids, std::vector< int > &lfids) |
| HFacet | create_halffacet (EntityHandle handle, int lid) |
| EntityHandle | fid_from_halfacet (const HFacet facet, EntityType type) |
| int | lid_from_halffacet (const HFacet facet) |
| ErrorCode | update_entity_ranges (EntityHandle fileset) |
| ErrorCode | resize_hf_maps (EntityHandle start_vert, int nverts, EntityHandle start_edge, int nedges, EntityHandle start_face, int nfaces, EntityHandle start_cell, int ncells) |
| ErrorCode | get_sibling_map (EntityType type, EntityHandle ent, EntityHandle *sib_entids, int *sib_lids, int num_halffacets) |
| ErrorCode | get_sibling_map (EntityType type, EntityHandle ent, int lid, EntityHandle &sib_entid, int &sib_lid) |
| ErrorCode | set_sibling_map (EntityType type, EntityHandle ent, EntityHandle *set_entids, int *set_lids, int num_halffacets) |
| ErrorCode | set_sibling_map (EntityType type, EntityHandle ent, int lid, EntityHandle &set_entid, int &set_lid) |
| ErrorCode | get_incident_map (EntityType type, EntityHandle vid, std::vector< EntityHandle > &inci_entid, std::vector< int > &inci_lid) |
| ErrorCode | set_incident_map (EntityType type, EntityHandle vid, std::vector< EntityHandle > &set_entid, std::vector< int > &set_lid) |
| bool | check_nonmanifold_vertices (EntityType type, EntityHandle vid) |
| int | get_index_in_lmap (EntityHandle cid) |
| ErrorCode | get_entity_ranges (Range &verts, Range &edges, Range &faces, Range &cells) |
| MESHTYPE | get_mesh_type (int nverts, int nedges, int nfaces, int ncells) |
| EntityHandle * | get_rset () |
Public Attributes | |
| MESHTYPE | thismeshtype |
| std::map< EntityType, int > | cell_index |
Static Public Attributes | |
| static const LocalMaps2D | lConnMap2D [2] |
| static const LocalMaps3D | lConnMap3D [4] |
Protected Member Functions | |
| HalfFacetRep () | |
| int | get_index_for_meshtype (MESHTYPE mesh_type) |
| ErrorCode | init_curve () |
| ErrorCode | init_surface () |
| ErrorCode | init_volume () |
| ErrorCode | get_up_adjacencies_2d (EntityHandle he_fid, int he_lid, int *qsize, int *count) |
| Contains the local information for 2D entities. | |
| bool | find_matching_halfedge (EntityHandle eid, EntityHandle *hefid, int *helid) |
| Given an edge, finds a matching half-edge in the surface. | |
| ErrorCode | gather_halfedges (EntityHandle vid, EntityHandle he_fid, int he_lid, int *qsize, int *count) |
| Gather half-edges to a queue of half-edges. | |
| ErrorCode | another_halfedge (EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *he2_fid, int *he2_lid) |
| Obtains another half-edge belonging to the same face as the input half-edge. | |
| ErrorCode | mark_halfedges (EntityHandle vid, EntityHandle he_fid, int he_lid, Range &faces, std::vector< char > &markHEdgs, HFacet &bnd_hf) |
| bool | collect_and_compare (const EntityHandle vid, const EntityHandle *edg_vert, int *qsize, int *count, EntityHandle *he_fid, int *he_lid) |
| Collect and compare to find a matching half-edge with the given edge connectivity. | |
| ErrorCode | add_cells_of_single_component (EntityHandle vid, EntityHandle curcid, int curlid, std::multimap< EntityHandle, EntityHandle > &comps, HFacet &hf) |
| bool | find_cell_in_component (EntityHandle vid, EntityHandle cell, std::multimap< EntityHandle, EntityHandle > &comps) |
| bool | find_matching_implicit_edge_in_cell (EntityHandle eid, std::vector< EntityHandle > &cid, std::vector< int > &leid) |
| Given an edge, finds a matching local edge in an incident cell. | |
| bool | find_matching_halfface (EntityHandle fid, EntityHandle *cid, int *leid) |
| Given a face, finds a matching local face in an incident cell. | |
| bool | find_match_in_array (EntityHandle ent, EntityHandle *ent_list, int count, bool get_index=false, int *index=NULL) |
Protected Attributes | |
| Core * | mb |
| ParallelComm * | pcomm |
| EntityHandle | _rset |
| bool | _filterghost |
| bool | mInitAHFmaps |
| Range | _verts |
| Range | _edges |
| Range | _faces |
| Range | _cells |
| std::vector< HFacet > | sibhvs |
| std::vector< HFacet > | v2hv |
| std::vector< HFacet > | sibhes |
| std::vector< HFacet > | v2he |
| std::vector< HFacet > | sibhfs |
| std::vector< HFacet > | v2hf |
| std::multimap< EntityHandle, HFacet > | v2hes |
| std::multimap< EntityHandle, HFacet > | v2hfs |
| EntityHandle | queue_fid [MAXSIZE] |
| EntityHandle | Stkcells [MAXSIZE] |
| EntityHandle | cellq [MAXSIZE] |
| EntityHandle | trackfaces [MAXSIZE] |
| EntityHandle | trackcells [MAXSIZE] |
| int | queue_lid [MAXSIZE] |
| bool | is_mixed |
| bool | chk_mixed |
Static Protected Attributes | |
| static const adj_matrix | adjMatrix [7] |
Definition at line 76 of file HalfFacetRep.hpp.
| moab::HalfFacetRep::HalfFacetRep | ( | Core * | impl, |
| ParallelComm * | comm = 0, |
| moab::EntityHandle | rset = 0, |
| bool | filter_ghosts = true |
Definition at line 45 of file HalfFacetRep.cpp.
References chk_mixed, is_mixed, and mInitAHFmaps.
: thismeshtype( CURVE ), mb( impl ), pcomm( comm ), _rset( rset ), _filterghost( filter_ghosts ) { assert( NULL != impl ); mInitAHFmaps = false; chk_mixed = false; is_mixed = false; }
Definition at line 54 of file HalfFacetRep.cpp.
| moab::HalfFacetRep::HalfFacetRep | ( | ) | [protected] |
| ErrorCode moab::HalfFacetRep::add_cells_of_single_component | ( | EntityHandle | vid, |
| EntityHandle | curcid, | ||
| int | curlid, | ||
| std::multimap< EntityHandle, EntityHandle > & | comps, | ||
| HFacet & | hf | ||
| ) | [protected] |
Definition at line 1960 of file HalfFacetRep.cpp.
References create_halffacet(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, Stkcells, trackcells, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, and moab::HalfFacetRep::LocalMaps3D::v2hf_num.
Referenced by determine_incident_halffaces().
ErrorCode error;
EntityType ctype = mb->type_from_handle( curcid );
int index = get_index_in_lmap( curcid );
int nvpc = lConnMap3D[index].num_verts_in_cell;
int nfpc = lConnMap3D[index].num_faces_in_cell;
int Stksize = 0, count = -1;
Stkcells[0] = curcid;
hf = create_halffacet( curcid, curlid );
EntityHandle cur_cid;
while( Stksize >= 0 )
cur_cid = Stkcells[Stksize];
Stksize -= 1;
bool found = find_match_in_array( cur_cid, trackcells, count );
if( !found )
count += 1;
trackcells[count] = cur_cid;
// Add the current cell
comps.insert( std::pair< EntityHandle, EntityHandle >( vid, cur_cid ) );
// Connectivity of the cell
const EntityHandle* conn;
error = mb->get_connectivity( cur_cid, conn, nvpc, true );MB_CHK_ERR( error );
// Local id of vid in the cell and the half-faces incident on it
int lv = -1;
for( int i = 0; i < nvpc; ++i )
if( conn[i] == vid )
lv = i;
break;
if( lv < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
int nhf_thisv = lConnMap3D[index].v2hf_num[lv];
int cidx = ID_FROM_HANDLE( cur_cid ) - 1;
// Add new cells into the stack
EntityHandle ngb;
HFacet hf_ngb;
for( int i = 0; i < nhf_thisv; ++i )
int ind = lConnMap3D[index].v2hf[lv][i];
hf_ngb = sibhfs[nfpc * cidx + ind];
ngb = fid_from_halfacet( hf_ngb, ctype );
if( ngb )
bool found_ent = find_match_in_array( ngb, trackcells, count );
if( !found_ent )
Stksize += 1;
Stkcells[Stksize] = ngb;
else
hf = create_halffacet( cur_cid, ind );
// Change the visited faces to false
for( int i = 0; i < Stksize; i++ )
Stkcells[i] = 0;
for( int i = 0; i <= count; i++ )
trackcells[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::another_halfedge | ( | EntityHandle | vid, |
| EntityHandle | he_fid, | ||
| int | he_lid, | ||
| EntityHandle * | he2_fid, | ||
| int * | he2_lid | ||
| ) | [protected] |
It uses the local maps to find another half-edge that is either incident or outgoing depending on vid and input half-edge
Definition at line 1392 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::HalfFacetRep::LocalMaps2D::prev, and moab::Core::type_from_handle().
Referenced by collect_and_compare(), gather_halfedges(), get_up_adjacencies_vert_2d(), and mark_halfedges().
ErrorCode error;
EntityType ftype = mb->type_from_handle( he_fid );
int nepf = lConnMap2D[ftype - 2].num_verts_in_face;
error = mb->get_connectivity( he_fid, conn, nepf, true );MB_CHK_ERR( error );
*he2_fid = he_fid;
if( conn[he_lid] == vid )
*he2_lid = lConnMap2D[ftype - 2].prev[he_lid];
else
*he2_lid = lConnMap2D[ftype - 2].next[he_lid];
return MB_SUCCESS;
Definition at line 131 of file HalfFacetRep.cpp.
References _rset, chk_mixed, moab::Range::empty(), moab::error(), ErrorCode, moab::ScdInterface::find_boxes(), moab::Core::get_entities_by_dimension(), is_mixed, mb, MB_CHK_ERR, MBHEX, MBPOLYGON, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, moab::Interface::query_interface(), moab::Range::size(), and moab::Range::subset_by_type().
Referenced by moab::NestedRefine::initialize().
if( !chk_mixed )
chk_mixed = true;
ErrorCode error;
Range felems, celems;
error = mb->get_entities_by_dimension( this->_rset, 2, felems );MB_CHK_ERR( error );
if( felems.size() )
Range tris, quad, poly;
tris = felems.subset_by_type( MBTRI );
quad = felems.subset_by_type( MBQUAD );
poly = felems.subset_by_type( MBPOLYGON );
if( ( tris.size() && quad.size() ) || ( tris.size() && poly.size() ) || ( quad.size() && poly.size() ) )
is_mixed = true;
if( poly.size() ) is_mixed = true;
if( is_mixed ) return is_mixed;
error = mb->get_entities_by_dimension( this->_rset, 3, celems );MB_CHK_ERR( error );
if( celems.size() )
Range tet, pyr, prism, hex, polyhed;
tet = celems.subset_by_type( MBTET );
pyr = celems.subset_by_type( MBPYRAMID );
prism = celems.subset_by_type( MBPRISM );
hex = celems.subset_by_type( MBHEX );
polyhed = celems.subset_by_type( MBPOLYHEDRON );
if( ( tet.size() && pyr.size() ) || ( tet.size() && prism.size() ) || ( tet.size() && hex.size() ) ||
( tet.size() && polyhed.size() ) || ( pyr.size() && prism.size() ) || ( pyr.size() && hex.size() ) ||
( pyr.size() && polyhed.size() ) || ( prism.size() && hex.size() ) ||
( prism.size() && polyhed.size() ) || ( hex.size() && polyhed.size() ) )
is_mixed = true;
if( polyhed.size() ) is_mixed = true;
ScdInterface* scdi = NULL;
error = mb->query_interface( scdi );MB_CHK_ERR( error );
if( scdi )
Range boxes;
error = scdi->find_boxes( boxes );MB_CHK_ERR( error );
if( !boxes.empty() ) is_mixed = true;
return is_mixed;
| bool moab::HalfFacetRep::check_nonmanifold_vertices | ( | EntityType | type, |
| EntityHandle | vid | ||
Definition at line 3357 of file HalfFacetRep.cpp.
References moab::ID_FROM_HANDLE(), MB_SET_ERR, MBHEX, MBQUAD, MBTET, MBTRI, v2he, v2hes, v2hf, and v2hfs.
Referenced by moab::NestedRefine::update_global_ahf_3D().
bool status = false;
if( type == MBTRI || type == MBQUAD )
HFacet hf = v2he[ID_FROM_HANDLE( vid ) - 1];
if( hf == 0 && ( v2hes.find( vid ) != v2hes.end() ) ) status = true;
else if( type == MBTET || type == MBHEX )
HFacet hf = v2hf[ID_FROM_HANDLE( vid ) - 1];
if( hf == 0 && ( v2hfs.find( vid ) != v2hfs.end() ) ) status = true;
else
MB_SET_ERR( MB_FAILURE, "Requesting non-manifold vertex checks for either (1) 1D mesh or "
"(2) not-implemented entity types" );
return status;
| bool moab::HalfFacetRep::collect_and_compare | ( | const EntityHandle | vid, |
| const EntityHandle * | edg_vert, | ||
| int * | qsize, | ||
| int * | count, | ||
| EntityHandle * | he_fid, | ||
| int * | he_lid | ||
| ) | [protected] |
Given edge connectivity, compare to an input list of half-edges to find a matching half-edge and add a list of half-edges belonging to the one-ring neighborhood to a queue till it finds a match.
Definition at line 1415 of file HalfFacetRep.cpp.
References _faces, another_halfedge(), moab::Range::begin(), moab::error(), ErrorCode, find_match_in_array(), moab::Core::get_connectivity(), get_up_adjacencies_2d(), lConnMap2D, moab::MAXSIZE, mb, MB_CHK_ERR, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, trackfaces, and moab::Core::type_from_handle().
Referenced by find_matching_halfedge().
ErrorCode error;
EntityType ftype = mb->type_from_handle( *_faces.begin() );
bool found = false;
int num_qvals = 0, counter = 0;
while( num_qvals < *qsize && counter < MAXSIZE )
EntityHandle curfid = queue_fid[num_qvals];
int curlid = queue_lid[num_qvals];
num_qvals += 1;
error = mb->get_connectivity( curfid, conn, nepf, true );MB_CHK_ERR( error );
int id = lConnMap2D[ftype - 2].next[curlid];
if( ( ( conn[curlid] == edg_vert[0] ) && ( conn[id] == edg_vert[1] ) ) ||
( ( conn[curlid] == edg_vert[1] ) && ( conn[id] == edg_vert[0] ) ) )
*he_fid = curfid;
*he_lid = curlid;
found = true;
break;
bool val = find_match_in_array( curfid, trackfaces, count[0] );
if( val ) continue;
count[0] += 1;
trackfaces[*count] = curfid;
EntityHandle he2_fid;
int he2_lid;
error = another_halfedge( vid, curfid, curlid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
error = get_up_adjacencies_2d( he2_fid, he2_lid, qsize, count );MB_CHK_ERR( error );
counter += 1;
return found;
| ErrorCode moab::HalfFacetRep::count_subentities | ( | Range & | edges, |
| Range & | faces, | ||
| Range & | cells, | ||
| int * | nedges, | ||
| int * | nfaces | ||
Definition at line 611 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_total_edges_2d(), find_total_edges_faces_3d(), MB_CHK_ERR, MB_SUCCESS, and moab::Range::size().
Referenced by moab::NestedRefine::count_subentities().
ErrorCode error;
if( edges.size() && !faces.size() && !cells.size() )
nedges[0] = edges.size();
nfaces[0] = 0;
else if( faces.size() && !cells.size() )
nedges[0] = find_total_edges_2d( faces );
nfaces[0] = 0;
else if( cells.size() )
error = find_total_edges_faces_3d( cells, nedges, nfaces );MB_CHK_ERR( error );
return MB_SUCCESS;
| HFacet moab::HalfFacetRep::create_halffacet | ( | EntityHandle | handle, |
| int | lid | ||
Definition at line 3694 of file HalfFacetRep.cpp.
References moab::CREATE_HALFFACET(), and moab::ID_FROM_HANDLE().
Referenced by add_cells_of_single_component(), determine_incident_halfedges(), determine_incident_halfverts(), determine_sibling_halfedges(), determine_sibling_halffaces(), determine_sibling_halfverts(), mark_halfedges(), set_incident_map(), and set_sibling_map().
EntityID fid = ID_FROM_HANDLE( handle );
return CREATE_HALFFACET( lid, fid );
Deinitialize.
Definition at line 273 of file HalfFacetRep.cpp.
References MB_SUCCESS.
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::determine_border_vertices | ( | Range & | cells, |
| Tag | isborder | ||
Tag border vertices by using the sibhf_cid map. All vertices on half-faces with no sibling half-faces are considered as border vertices.
| cells | Range of cells |
| isborder,: | A dense tag over all vertices of size 1. Value is true for a border vertex, otherwise is false. |
Definition at line 1920 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, t, moab::Core::tag_set_data(), and moab::Core::type_from_handle().
ErrorCode error;
EntityHandle start_cell = *cells.begin();
EntityType ctype = mb->type_from_handle( *cells.begin() );
int index = get_index_in_lmap( start_cell );
int val = 1;
for( Range::iterator t = cells.begin(); t != cells.end(); ++t )
error = mb->get_connectivity( *t, conn, nvpc, true );MB_CHK_ERR( error );
int cidx = ID_FROM_HANDLE( *t ) - 1;
for( int i = 0; i < nfpc; ++i )
HFacet hf = sibhfs[nfpc * cidx + i];
EntityHandle sib_cid = fid_from_halfacet( hf, ctype );
if( sib_cid == 0 )
int nvF = lConnMap3D[index].hf2v_num[i];
for( int j = 0; j < nvF; ++j )
int ind = lConnMap3D[index].hf2v[i][j];
error = mb->tag_set_data( isborder, &conn[ind], 1, &val );MB_CHK_ERR( error );
return MB_SUCCESS;
Compute a map between a vertex and an incident half-edge. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
| faces | Range of faces |
Definition at line 955 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mark_halfedges(), mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::Range::size(), moab::Core::type_from_handle(), v2he, and v2hes.
Referenced by init_surface().
ErrorCode error;
EntityType ftype = mb->type_from_handle( *faces.begin() );
std::vector< char > markEdges( nepf * faces.size(), 0 );
for( Range::iterator it = faces.begin(); it != faces.end(); ++it )
EntityHandle fid = *it;
error = mb->get_connectivity( fid, conn, nepf, true );MB_CHK_ERR( error );
for( int i = 0; i < nepf; ++i )
EntityHandle v = conn[i];
int vidx = ID_FROM_HANDLE( v ) - 1;
HFacet hf = v2he[vidx];
if( hf == 0 && ( v2hes.empty() || ( v2hes.find( v ) == v2hes.end() ) ) )
// This is the first time a half-facet is assigned to a vertex.
HFacet nwhf = 0;
error = mark_halfedges( v, fid, i, faces, markEdges, nwhf );MB_CHK_ERR( error );
if( nwhf == 0 ) nwhf = create_halffacet( fid, i );
v2he[vidx] = nwhf;
else if( hf != 0 && !markEdges[nepf * faces.index( fid ) + i] )
// This is the first time a non-manifold vertex is encountered. Copy the existing he
// in v2he[v] to the multimap.
v2hes.insert( std::pair< EntityHandle, HFacet >( v, hf ) );
HFacet nwhf = 0;
v2hes.insert( std::pair< EntityHandle, HFacet >( v, nwhf ) );
v2he[vidx] = 0;
else if( hf == 0 && ( !v2hes.empty() ) && ( v2hes.find( v ) != v2hes.end() ) &&
// This is check if reached if the vertex is non-manifold and has encountered a
// half-facet to a new component.
HFacet nwhf = 0;
// error = print_tags(2);
return MB_SUCCESS;
Compute a map between a vertex and an incident half-face. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
| faces | Range of cells |
Definition at line 1867 of file HalfFacetRep.cpp.
References add_cells_of_single_component(), moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, find_cell_in_component(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, v2hf, and v2hfs.
Referenced by init_volume().
ErrorCode error;
int index = get_index_in_lmap( *cells.begin() );
std::multimap< EntityHandle, EntityHandle > comps;
HFacet nwhf;
for( Range::iterator cid = cells.begin(); cid != cells.end(); ++cid )
EntityHandle cell = *cid;
error = mb->get_connectivity( *cid, conn, nvpc, true );MB_CHK_ERR( error );
HFacet hf = v2hf[vidx];
bool found = find_cell_in_component( v, cell, comps );
if( hf == 0 && !found && ( v2hfs.empty() || ( v2hfs.find( v ) == v2hfs.end() ) ) )
nwhf = 0;
error = add_cells_of_single_component( v, cell, lConnMap3D[index].v2hf[i][0], comps, nwhf );MB_CHK_ERR( error );
v2hf[vidx] = nwhf;
else if( hf != 0 && !found )
nwhf = 0;
v2hfs.insert( std::pair< EntityHandle, HFacet >( v, hf ) );
v2hfs.insert( std::pair< EntityHandle, HFacet >( v, nwhf ) );
v2hf[vidx] = 0;
else if( hf == 0 && !found && ( !v2hfs.empty() ) && ( v2hfs.find( v ) != v2hfs.end() ) )
nwhf = 0;
// error = print_tags(3);
return MB_SUCCESS;
Compute a map between a vertex and an incident half-vertex. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
| edges | Range of edges |
Definition at line 711 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), mb, MB_CHK_ERR, MB_SUCCESS, MBEDGE, and v2hv.
Referenced by init_curve(), and moab::NestedRefine::update_ahf_1D().
ErrorCode error;
for( Range::iterator e_it = edges.begin(); e_it != edges.end(); ++e_it )
EntityHandle cur_eid = *e_it;
int num_conn = 0;
error = mb->get_connectivity( *e_it, conn, num_conn, true );MB_CHK_ERR( error );
for( int i = 0; i < 2; ++i )
HFacet hf = v2hv[vidx];
EntityHandle eid = fid_from_halfacet( hf, MBEDGE );
if( eid == 0 )
v2hv[vidx] = create_halffacet( cur_eid, i );
return MB_SUCCESS;
Compute all sibling half-edges for all half-edges in the given surface. The sibling half-edges is defined in terms of the containing face and the local id of the edge w.r.t that entity. That is, the map consists of two pieces of information: <EntityHandle fid, int leid>
Definition at line 831 of file HalfFacetRep.cpp.
References _verts, moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, moab::Range::size(), and moab::Core::type_from_handle().
ErrorCode error;
EntityHandle start_face = *faces.begin();
EntityType ftype = mb->type_from_handle( start_face );
int nfaces = faces.size();
// Step 1: Create an index list storing the starting position for each vertex
int nv = _verts.size();
std::vector< int > is_index( nv + 1 );
for( int i = 0; i < nv + 1; i++ )
is_index[i] = 0;
int index;
for( Range::iterator fid = faces.begin(); fid != faces.end(); ++fid )
error = mb->get_connectivity( *fid, conn, nepf, true );MB_CHK_ERR( error );
for( int i = 0; i < nepf; i++ )
index = _verts.index( conn[i] );
is_index[index + 1] += 1;
is_index[0] = 0;
for( int i = 0; i < nv; i++ )
is_index[i + 1] = is_index[i] + is_index[i + 1];
// Step 2: Define two arrays v2hv_eid, v2hv_lvid storing every half-facet on a vertex
std::vector< EntityHandle > v2nv( nepf * nfaces );
std::vector< EntityHandle > v2he_map_fid( nepf * nfaces );
std::vector< int > v2he_map_leid( nepf * nfaces );
for( int j = 0; j < nepf; j++ )
int v = _verts.index( conn[j] );
int nidx = lConnMap2D[ftype - 2].next[j];
v2nv[is_index[v]] = conn[nidx];
v2he_map_fid[is_index[v]] = *fid;
v2he_map_leid[is_index[v]] = j;
is_index[v] += 1;
for( int i = nv - 2; i >= 0; i-- )
is_index[i + 1] = is_index[i];
is_index[0] = 0;
// Step 3: Fill up sibling half-verts map
int fidx = ID_FROM_HANDLE( *fid ) - 1;
for( int k = 0; k < nepf; k++ )
HFacet hf = sibhes[nepf * fidx + k];
EntityHandle sibfid = fid_from_halfacet( hf, ftype );
if( sibfid != 0 ) continue;
int nidx = lConnMap2D[ftype - 2].next[k];
int v = _verts.index( conn[k] );
int vn = _verts.index( conn[nidx] );
EntityHandle first_fid = *fid;
int first_leid = k;
EntityHandle prev_fid = *fid;
int prev_leid = k;
for( index = is_index[vn]; index <= is_index[vn + 1] - 1; index++ )
if( v2nv[index] == conn[k] )
EntityHandle cur_fid = v2he_map_fid[index];
int cur_leid = v2he_map_leid[index];
int pidx = ID_FROM_HANDLE( prev_fid ) - 1;
sibhes[nepf * pidx + prev_leid] = create_halffacet( cur_fid, cur_leid );
prev_fid = cur_fid;
prev_leid = cur_leid;
for( index = is_index[v]; index <= is_index[v + 1] - 1; index++ )
if( ( v2nv[index] == conn[nidx] ) && ( v2he_map_fid[index] != *fid ) )
prev_fid = cur_fid;
if( prev_fid != first_fid )
sibhes[nepf * pidx + prev_leid] = create_halffacet( first_fid, first_leid );
return MB_SUCCESS;
Compute all sibling half-faces for all half-faces in the given volume. The sibling half-faces is defined in terms of the containing cell and the local id of the face w.r.t that cell. That is, the map consists of two pieces of information: <EntityHandle cid, int lfid>
Definition at line 1727 of file HalfFacetRep.cpp.
References _verts, moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::prev, sibhfs, moab::Range::size(), and moab::Core::type_from_handle().
ErrorCode error;
EntityType ctype = mb->type_from_handle( start_cell );
is_index[i] = 0;
int vindex;
EntityHandle v = 0;
for( int k = 0; k < nvF; k++ )
int id = lConnMap3D[index].hf2v[i][k];
if( v <= conn[id] ) v = conn[id];
vindex = _verts.index( v );
is_index[vindex + 1] += 1;
is_index[0] = 0;
// Step 2: Define four arrays v2hv_eid, v2hv_lvid storing every half-facet on a vertex
std::vector< EntityHandle > v2oe_v1( is_index[nv] );
std::vector< EntityHandle > v2oe_v2( is_index[nv] );
std::vector< EntityHandle > v2hf_map_cid( is_index[nv] );
std::vector< int > v2hf_map_lfid( is_index[nv] );
for( int i = 0; i < nfpc; i++ )
std::vector< EntityHandle > vs( nvF );
EntityHandle vmax = 0;
int lv = -1;
vs[k] = conn[id];
if( vmax <= conn[id] )
vmax = conn[id];
lv = k;
int nidx = lConnMap2D[nvF - 3].next[lv];
int pidx = lConnMap2D[nvF - 3].prev[lv];
int v = _verts.index( vmax );
v2oe_v1[is_index[v]] = vs[nidx];
v2oe_v2[is_index[v]] = vs[pidx];
v2hf_map_cid[is_index[v]] = *cid;
v2hf_map_lfid[is_index[v]] = i;
is_index[v] += 1;
is_index[0] = 0;
int cidx = ID_FROM_HANDLE( *cid ) - 1;
EntityHandle sibcid = fid_from_halfacet( hf, ctype );
if( sibcid != 0 ) continue;
int lv = -1;
vs[k] = conn[id];
vmax = conn[id];
lv = k;
EntityHandle v1 = vs[pidx];
EntityHandle v2 = vs[nidx];
for( int ind = is_index[v]; ind <= is_index[v + 1] - 1; ind++ )
if( ( v2oe_v1[ind] == v1 ) && ( v2oe_v2[ind] == v2 ) )
// Map to opposite hf
EntityHandle cur_cid = v2hf_map_cid[ind];
int cur_lfid = v2hf_map_lfid[ind];
sibhfs[nfpc * cidx + i] = create_halffacet( cur_cid, cur_lfid );
int scidx = ID_FROM_HANDLE( cur_cid ) - 1;
sibhfs[nfpc * scidx + cur_lfid] = create_halffacet( *cid, i );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::determine_sibling_halfverts | ( | Range & | verts, |
| Range & | edges | ||
Compute all sibling half-vertices for all half-vertices in the given curve. The sibling half-verts is defined in terms of the containing edge and the local id of the vertex w.r.t that edge. That is, the map consists of two pieces of information: <EntityHandle eid, int lvid>
| edges | Range of edges. |
Definition at line 634 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), mb, MB_CHK_ERR, MB_SUCCESS, sibhvs, and moab::Range::size().
ErrorCode error;
int nv = verts.size();
is_index[i] = 0;
for( Range::iterator eid = edges.begin(); eid != edges.end(); ++eid )
int num_conn = 0;
error = mb->get_connectivity( *eid, conn, num_conn, true );MB_CHK_ERR( error );
int index = verts.index( conn[0] );
index = verts.index( conn[1] );
is_index[0] = 0;
std::vector< EntityHandle > v2hv_map_eid( 2 * edges.size() );
std::vector< int > v2hv_map_lvid( 2 * edges.size() );
int num_conn = 0;
for( int j = 0; j < 2; j++ )
int v = verts.index( conn[j] );
v2hv_map_eid[is_index[v]] = *eid;
v2hv_map_lvid[is_index[v]] = j;
is_index[v] += 1;
is_index[0] = 0;
for( Range::iterator vid = verts.begin(); vid != verts.end(); ++vid )
int v = verts.index( *vid );
int last = is_index[v + 1] - 1;
if( last > is_index[v] )
EntityHandle prev_eid = v2hv_map_eid[last];
int prev_lvid = v2hv_map_lvid[last];
for( int i = is_index[v]; i <= last; i++ )
EntityHandle cur_eid = v2hv_map_eid[i];
int cur_lvid = v2hv_map_lvid[i];
int pidx = ID_FROM_HANDLE( prev_eid ) - 1;
sibhvs[2 * pidx + prev_lvid] = create_halffacet( cur_eid, cur_lvid );
prev_eid = cur_eid;
prev_lvid = cur_lvid;
return MB_SUCCESS;
| EntityHandle moab::HalfFacetRep::fid_from_halfacet | ( | const HFacet | facet, |
| EntityType | type | ||
Definition at line 3700 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::FID_FROM_HALFFACET(), moab::Core::handle_from_id(), mb, and MB_CHK_ERR.
Referenced by add_cells_of_single_component(), determine_border_vertices(), determine_incident_halfverts(), determine_sibling_halfedges(), determine_sibling_halffaces(), find_matching_halfedge(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_half_facet_in_comp(), get_incident_map(), get_neighbor_adjacencies_1d(), get_neighbor_adjacencies_3d(), get_sibling_map(), get_up_adjacencies_1d(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), mark_halfedges(), and print_tags().
EntityID id = FID_FROM_HALFFACET( facet );
EntityHandle handle = 0;
if( id == 0 ) return handle;
ErrorCode error = mb->handle_from_id( type, id, handle );MB_CHK_ERR( error );
return handle;
| bool moab::HalfFacetRep::find_cell_in_component | ( | EntityHandle | vid, |
| EntityHandle | cell, | ||
| std::multimap< EntityHandle, EntityHandle > & | comps | ||
| ) | [protected] |
Definition at line 2045 of file HalfFacetRep.cpp.
bool found = false;
if( comps.empty() ) return found;
std::pair< std::multimap< EntityHandle, EntityHandle >::iterator,
std::multimap< EntityHandle, EntityHandle >::iterator >
rit;
rit = comps.equal_range( vid );
for( std::multimap< EntityHandle, EntityHandle >::iterator it = rit.first; it != rit.second; ++it )
if( it->second == cell )
found = true;
break;
return found;
| bool moab::HalfFacetRep::find_match_in_array | ( | EntityHandle | ent, |
| EntityHandle * | ent_list, | ||
| int | count, | ||
| bool | get_index = false, |
| int * | index = NULL |
| ) | [protected] |
Definition at line 3138 of file HalfFacetRep.cpp.
Referenced by add_cells_of_single_component(), collect_and_compare(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), and mark_halfedges().
bool found = false;
if( ent == ent_list[i] )
found = true;
if( get_index ) *index = i;
break;
return found;
| bool moab::HalfFacetRep::find_matching_halfedge | ( | EntityHandle | eid, |
| EntityHandle * | hefid, | ||
| int * | helid | ||
| ) | [protected] |
Given an edge eid, it first collects few half-edges belonging to one-ring neighborhood of the starting vertex of the given edge, and then simultaneously searches and adds to the local list of half-edges for searching, till it finds a matching half-edge.
| eid | EntityHandle of the query edge |
| hefid,helid,: | Returns the matching half-edge corresponding to the query edge. |
Definition at line 1318 of file HalfFacetRep.cpp.
References _faces, moab::Range::begin(), collect_and_compare(), moab::error(), ErrorCode, fid_from_halfacet(), gather_halfedges(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, trackfaces, moab::Core::type_from_handle(), and v2he.
Referenced by get_up_adjacencies_2d().
ErrorCode error;
int num_conn = 0;
error = mb->get_connectivity( eid, conn, num_conn, true );MB_CHK_ERR( error );
EntityHandle vid = conn[0];
int vidx = ID_FROM_HANDLE( conn[0] ) - 1;
if( hf == 0 )
vidx = ID_FROM_HANDLE( conn[1] ) - 1;
hf = v2he[vidx];
if( hf == 0 ) // The edge is either a dangling edge or attached to two non-manifold
// vertices
return MB_SUCCESS;
vid = conn[1];
EntityHandle fid = fid_from_halfacet( hf, ftype );
int lid = lid_from_halffacet( hf );
bool found = false;
int qsize = 0, count = -1;
error = gather_halfedges( vid, fid, lid, &qsize, &count );MB_CHK_ERR( error );
found = collect_and_compare( vid, conn, &qsize, &count, hefid, helid );MB_CHK_ERR( error );
for( int i = 0; i < qsize; i++ )
queue_fid[i] = 0;
queue_lid[i] = 0;
trackfaces[i] = 0;
return found;
| bool moab::HalfFacetRep::find_matching_halfface | ( | EntityHandle | fid, |
| EntityHandle * | cid, | ||
| int * | leid | ||
| ) | [protected] |
Find a local face with the same connectivity as the input face, belonging to an incident cell.
| fid | EntityHandle of the face |
| cid | Returns EntityHandle of the incident cell |
| lfid | Returns the local id of the face corresponding to the input face w.r.t the incident cell. |
Definition at line 2790 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhfs, Stkcells, trackcells, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by get_up_adjacencies_face_3d().
ErrorCode error;
EntityHandle start_cell = *_cells.begin();
EntityType ftype = mb->type_from_handle( fid );
int nvF = lConnMap2D[ftype - 2].num_verts_in_face;
const EntityHandle* fid_verts;
error = mb->get_connectivity( fid, fid_verts, nvF, true );MB_CHK_ERR( error );
std::vector< EntityHandle > start_cells;
int vidx, locfv0 = -1;
HFacet hf = 0;
for( int i = 0; i < nvF; i++ )
vidx = ID_FROM_HANDLE( fid_verts[i] ) - 1;
hf = v2hf[vidx];
if( hf != 0 )
start_cells.push_back( fid_from_halfacet( hf, ctype ) );
locfv0 = i;
break;
else if( hf == 0 && v2hfs.find( fid_verts[i] ) != v2hfs.end() )
std::pair< std::multimap< EntityHandle, HFacet >::iterator,
std::multimap< EntityHandle, HFacet >::iterator >
it_hfs;
it_hfs = v2hfs.equal_range( fid_verts[i] );
for( std::multimap< EntityHandle, HFacet >::iterator it = it_hfs.first; it != it_hfs.second; ++it )
start_cells.push_back( fid_from_halfacet( it->second, ctype ) );
locfv0 = i;
break;
if( start_cells.empty() ) return false;
bool found = false;
for( int i = 0; i < (int)start_cells.size(); i++ )
Stkcells[i] = start_cells[i];
Stksize = start_cells.size() - 1;
Stksize -= 1;
count += 1;
int lv[4] = { -1, -1, -1, -1 };
int cnt = 0;
for( int i = 0; i < nvpc; i++ )
for( int j = 0; j < nvF; j++ )
if( conn[i] == fid_verts[j] )
lv[j] = i;
cnt += 1;
if( cnt == nvF ) // All face verts are part of the cell
found = true;
int nhf_thisv = lConnMap3D[index].v2hf_num[lv[locfv0]];
int lfid = -1;
lfid = lConnMap3D[index].v2hf[lv[locfv0]][i];
int lcnt = 0;
for( int k = 0; k < nvF; ++k )
if( lv[k] == lConnMap3D[index].hf2v[lfid][j] ) lcnt += 1;
if( lcnt == nvF ) break;
cid[0] = cur_cid;
lid[0] = lfid;
break;
else
// Add other cells that are incident on fid_verts[0]
if( locfv0 < 0 || lv[locfv0] < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
EntityHandle ngb;
int ind = lConnMap3D[index].v2hf[lv[locfv0]][i];
hf = sibhfs[nfpc * cidx + ind];
ngb = fid_from_halfacet( hf, ctype );
if( ngb )
if( !found_ent )
Stksize += 1;
Stkcells[i] = 0;
trackcells[i] = 0;
return found;
| bool moab::HalfFacetRep::find_matching_implicit_edge_in_cell | ( | EntityHandle | eid, |
| std::vector< EntityHandle > & | cid, | ||
| std::vector< int > & | leid | ||
| ) | [protected] |
Find a local edge with the same connectivity as the input edge, belonging to an incident cell.
| eid | EntityHandle of the edge |
| leid | Returns the local id of the edge corresponding to the input edge w.r.t the incident cell. |
Definition at line 2654 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), cellq, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
ErrorCode error;
EntityType ctype = mb->type_from_handle( *_cells.begin() );
// Find the edge vertices
const EntityHandle* econn;
int num_conn = 0;
error = mb->get_connectivity( eid, econn, num_conn, true );MB_CHK_ERR( error );
EntityHandle v_start = econn[0], v_end = econn[1];
int v1idx = ID_FROM_HANDLE( v_start ) - 1;
int v2idx = ID_FROM_HANDLE( v_end ) - 1;
// Find an incident cell to v_start
HFacet hf1 = v2hf[v1idx];
HFacet hf2 = v2hf[v2idx];
int ncomps1 = 0, ncomps2 = 0, ncomp;
if( hf1 == 0 && !v2hfs.empty() )
std::pair< std::multimap< EntityHandle, HFacet >::iterator, std::multimap< EntityHandle, HFacet >::iterator >
it_hes;
it_hes = v2hfs.equal_range( v_start );
for( std::multimap< EntityHandle, HFacet >::iterator it = it_hes.first; it != it_hes.second; ++it )
ncomps1 += 1;
else if( hf1 != 0 )
start_cells.push_back( fid_from_halfacet( hf1, ctype ) );
ncomps1 += 1;
if( hf2 == 0 && !v2hfs.empty() )
it_hes;
it_hes = v2hfs.equal_range( v_end );
ncomps2 += 1;
else if( hf2 != 0 )
start_cells.push_back( fid_from_halfacet( hf2, ctype ) );
ncomps2 += 1;
ncomp = std::min( ncomps1, ncomps2 );
bool found = false;
if( start_cells.empty() ) return found;
cellq[i] = start_cells[i];
int qsize = start_cells.size();
int num_qvals = 0;
while( num_qvals < qsize )
EntityHandle cell_id = cellq[num_qvals];
num_qvals += 1;
error = mb->get_connectivity( cell_id, conn, nvpc, true );MB_CHK_ERR( error );
int lv0 = -1, lv1 = -1, lv = -1;
// locate v_origin in poped out tet, check if v_end is in
if( v_start == conn[i] )
lv0 = i;
lv = lv0;
else if( v_end == conn[i] )
lv1 = i;
lv = lv1;
if( ( lv0 >= 0 ) && ( lv1 >= 0 ) )
found = true;
cid.push_back( cell_id );
leid.push_back( lConnMap3D[index].lookup_leids[lv0][lv1] );
if( (int)cid.size() == ncomp ) break;
// push back new found unchecked incident tets of v_start
int cidx = ID_FROM_HANDLE( cell_id ) - 1;
for( int i = 0; i < nhf_thisv; i++ )
HFacet hf = sibhfs[nfpc * cidx + ind];
EntityHandle ngb = fid_from_halfacet( hf, ctype );
if( ngb )
bool found_ent = find_match_in_array( ngb, &cellq[0], qsize - 1 );
if( !found_ent )
cellq[qsize] = ngb;
qsize += 1;
cellq[i] = 0;
return found;
| int moab::HalfFacetRep::find_total_edges_2d | ( | Range & | faces | ) |
Definition at line 1546 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, get_up_adjacencies_2d(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::Range::size(), and moab::Core::type_from_handle().
Referenced by count_subentities().
ErrorCode error;
int total_edges = nepf * nfaces;
std::vector< int > trackF( total_edges, 0 );
std::vector< EntityHandle > adj_fids;
std::vector< int > adj_lids;
for( Range::iterator f = faces.begin(); f != faces.end(); ++f )
for( int l = 0; l < nepf; l++ )
adj_fids.clear();
adj_lids.clear();
int id = nepf * ( faces.index( *f ) ) + l;
if( !trackF[id] )
error = get_up_adjacencies_2d( *f, l, false, adj_fids, &adj_lids );MB_CHK_ERR( error );
total_edges -= adj_fids.size();
for( int i = 0; i < (int)adj_fids.size(); i++ )
trackF[nepf * ( faces.index( adj_fids[i] ) ) + adj_lids[i]] = 1;
return total_edges;
| ErrorCode moab::HalfFacetRep::find_total_edges_faces_3d | ( | const Range & | cells, |
| int * | nfaces | ||
Definition at line 3078 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, get_index_in_lmap(), get_up_adjacencies_edg_3d(), get_up_adjacencies_face_3d(), moab::Range::index(), lConnMap3D, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, and moab::Range::size().
ErrorCode error;
int nepc = lConnMap3D[index].num_edges_in_cell;
int ncells = cells.size();
int total_edges = nepc * ncells;
int total_faces = nfpc * ncells;
std::vector< int > trackE( total_edges, 0 );
std::vector< int > trackF( total_faces, 0 );
std::vector< EntityHandle > inc_cids, sib_cids;
std::vector< int > inc_leids, sib_lfids;
for( Range::iterator it = cells.begin(); it != cells.end(); ++it )
// Count edges
for( int i = 0; i < nepc; i++ )
inc_cids.clear();
inc_leids.clear();
int id = nepc * ( cells.index( *it ) ) + i;
if( !trackE[id] )
error = get_up_adjacencies_edg_3d( *it, i, inc_cids, &inc_leids );MB_CHK_ERR( error );
total_edges -= inc_cids.size() - 1;
for( int j = 0; j < (int)inc_cids.size(); j++ )
trackE[nepc * ( cells.index( inc_cids[j] ) ) + inc_leids[j]] = 1;
// Count faces
sib_cids.clear();
sib_lfids.clear();
int id = nfpc * ( cells.index( *it ) ) + i;
if( !trackF[id] )
error = get_up_adjacencies_face_3d( *it, i, sib_cids, &sib_lfids );MB_CHK_ERR( error );
if( sib_cids.size() == 1 ) continue;
total_faces -= sib_cids.size() - 1;
trackF[nfpc * ( cells.index( sib_cids[1] ) ) + sib_lfids[1]] = 1;
nedges[0] = total_edges;
nfaces[0] = total_faces;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::gather_halfedges | ( | EntityHandle | vid, |
| int | he_lid, | ||
| int * | qsize, | ||
| int * | count | ||
| ) | [protected] |
Given a vertex vid, and a half-edge <he_fid,he_lid>, add another half-edge in the same face sharing the vertex
Definition at line 1366 of file HalfFacetRep.cpp.
References another_halfedge(), moab::error(), ErrorCode, get_up_adjacencies_2d(), MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, and trackfaces.
Referenced by find_matching_halfedge(), get_up_adjacencies_vert_2d(), and mark_halfedges().
ErrorCode error;
EntityHandle he2_fid = 0;
int he2_lid = 0;
error = another_halfedge( vid, he_fid, he_lid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
queue_fid[*qsize] = he_fid;
queue_lid[*qsize] = he_lid;
*qsize += 1;
queue_fid[*qsize] = he2_fid;
queue_lid[*qsize] = he2_lid;
*qsize += 1;
*count += 1;
trackfaces[*count] = he_fid;
error = get_up_adjacencies_2d( he_fid, he_lid, qsize, count );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_adjacencies | ( | const EntityHandle | source_entity, |
| const unsigned int | target_dimension, | ||
| std::vector< EntityHandle > & | target_entities | ||
Given an entity of dimension d, gather all the adjacent D dimensional entities where D >, = , < d .
| source_entity | EntityHandle to which adjacent entities have to be found. |
| target_dimension | Int Dimension of the desired adjacent entities. |
| target_entities | Vector in which the adjacent EntityHandle are returned. |
Definition at line 489 of file HalfFacetRep.cpp.
References adjMatrix, moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_down_adjacencies(), get_index_for_meshtype(), get_neighbor_adjacencies(), get_up_adjacencies(), initialize(), mb, MB_CHK_ERR, MB_SUCCESS, mInitAHFmaps, thismeshtype, and moab::HalfFacetRep::adj_matrix::val.
Referenced by moab::NestedRefine::get_adjacencies().
ErrorCode error;
unsigned int source_dimension = mb->dimension_from_handle( source_entity );
assert( ( source_dimension <= target_dimension ) || ( source_dimension > target_dimension ) );
if( mInitAHFmaps == false )
error = initialize();MB_CHK_ERR( error );
int mindex = get_index_for_meshtype( thismeshtype );
int adj_possible = adjMatrix[mindex].val[source_dimension][target_dimension];
if( adj_possible )
if( source_dimension < target_dimension )
error = get_up_adjacencies( source_entity, target_dimension, target_entities );MB_CHK_ERR( error );
else if( source_dimension == target_dimension )
error = get_neighbor_adjacencies( source_entity, target_entities );MB_CHK_ERR( error );
else
error = get_down_adjacencies( source_entity, target_dimension, target_entities );MB_CHK_ERR( error );
else
return MB_SUCCESS;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_down_adjacencies | ( | EntityHandle | ent, |
| int | out_dim, | ||
| std::vector< EntityHandle > & | adjents | ||
Given an entity of dimension d, gather all the d-1 dimensional entities.
| ent | EntityHandle to which neighbor entities have to be found. |
| out_dim | Dimension of the desired downward adjacency. |
| adjents | Vector in which the neighbor entities are returned. |
Definition at line 590 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_down_adjacencies_2d(), get_down_adjacencies_edg_3d(), get_down_adjacencies_face_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
Referenced by get_adjacencies().
ErrorCode error;
int in_dim = mb->dimension_from_handle( ent );
assert( ( in_dim >= 2 && in_dim <= 3 ) && ( out_dim < in_dim ) );
if( ( in_dim == 2 ) && ( out_dim == 1 ) )
error = get_down_adjacencies_2d( ent, adjents );MB_CHK_ERR( error );
else if( ( in_dim == 3 ) && ( out_dim == 1 ) )
error = get_down_adjacencies_edg_3d( ent, adjents );MB_CHK_ERR( error );
else if( ( in_dim == 3 ) && ( out_dim == 2 ) )
error = get_down_adjacencies_face_3d( ent, adjents );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_down_adjacencies_2d | ( | EntityHandle | fid, |
Given a face, it first finds incident edges on each vertex of the face, and then it performs a set intersection to gather all the edges of the given face.
| fid | EntityHandle of the query face |
| adjents | Vector returning its edges |
Definition at line 1485 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_up_adjacencies_1d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, MBTRI, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::HalfFacetRep::LocalMaps2D::prev, and moab::Core::type_from_handle().
Referenced by get_down_adjacencies().
// Returns explicit edges, if any, of the face
ErrorCode error;
adjents.reserve( 10 );
std::vector< EntityHandle > temp;
// Loop over 2 vertices
for( int i = 0; i < 2; i++ )
// Choose the two adjacent vertices for a triangle, and two opposite vertices for a quad
int l;
if( ftype == MBTRI )
l = i;
else
l = 2 * i;
// Get the current, next and prev vertices
int nidx = lConnMap2D[ftype - 2].next[l];
int pidx = lConnMap2D[ftype - 2].prev[l];
EntityHandle v = conn[l];
EntityHandle vnext = conn[nidx];
EntityHandle vprev = conn[pidx];
// Get incident edges on v
error = get_up_adjacencies_1d( v, temp );MB_CHK_ERR( error );
// Loop over the incident edges and check if its end vertices match those in the face
for( int k = 0; k < (int)temp.size(); k++ )
int num_conn = 0;
error = mb->get_connectivity( temp[k], econn, num_conn, true );MB_CHK_ERR( error );
if( ( econn[0] == v && econn[1] == vnext ) || ( econn[0] == v && econn[1] == vprev ) ||
( econn[0] == vnext && econn[1] == v ) || ( econn[0] == vprev && econn[1] == v ) )
bool found = false;
for( int j = 0; j < (int)adjents.size(); j++ )
if( adjents[j] == temp[k] )
found = true;
break;
if( !found ) adjents.push_back( temp[k] );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_down_adjacencies_edg_3d | ( | EntityHandle | cid, |
Given a cell, it first finds incident edges on each vertex of the cell, and then it performs a set intersection to gather all the edges of the given cell.
| cid | EntityHandle of the query cell |
Definition at line 2953 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_1d(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps3D::search_everts, and moab::HalfFacetRep::LocalMaps3D::v2le.
// TODO: Try intersection without using std templates
ErrorCode error;
adjents.reserve( 20 );
int index = get_index_in_lmap( cid );
error = mb->get_connectivity( cid, conn, nvpc, true );MB_CHK_ERR( error );
// Gather all the incident edges on each vertex of the face
int ns = lConnMap3D[index].search_everts[0];
for( int i = 0; i < ns; i++ )
temp.clear();
int lv0 = lConnMap3D[index].search_everts[i + 1];
error = get_up_adjacencies_1d( conn[lv0], temp );MB_CHK_ERR( error );
int nle = lConnMap3D[index].v2le[i][0];
int count = 0;
for( int j = 0; j < (int)temp.size(); j++ )
int nvpe = 0;
error = mb->get_connectivity( temp[j], econn, nvpe, true );MB_CHK_ERR( error );
for( int k = 0; k < nle; k++ )
int lv1 = lConnMap3D[index].v2le[i][k + 1];
if( ( ( econn[0] == conn[lv0] ) && ( econn[1] == conn[lv1] ) ) ||
( ( econn[1] == conn[lv0] ) && ( econn[0] == conn[lv1] ) ) )
adjents.push_back( temp[j] );
count += 1;
if( count == nle ) break;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_down_adjacencies_face_3d | ( | EntityHandle | cid, |
Given a cell, it first finds incident faces on each vertex of the cell, and then performs a set intersection to gather all the faces of the given cell.
| adjents | Vector returning its faces |
Definition at line 2998 of file HalfFacetRep.cpp.
References moab::CN::ConnectivityMatch(), moab::error(), ErrorCode, moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_vert_2d(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps3D::search_fverts, moab::HalfFacetRep::LocalMaps3D::v2hf, and moab::HalfFacetRep::LocalMaps3D::v2hf_num.
// Returns explicit face, if any of the cell
ErrorCode error;
// Get the connectivity of the input cell
// Collect all the half-faces of the cell
EntityHandle half_faces[6][4];
int nvf = lConnMap3D[index].hf2v_num[i];
for( int j = 0; j < nvf; j++ )
half_faces[i][j] = conn[ind];
// Add two vertices for which the upward adjacencies are computed
int search_verts[2];
search_verts[0] = lConnMap3D[index].search_fverts[0];
search_verts[1] = lConnMap3D[index].search_fverts[1];
temp.reserve( 20 );
// Get the incident faces on the local vertex
int lv = search_verts[i];
temp.clear();
error = get_up_adjacencies_vert_2d( conn[lv], temp );MB_CHK_ERR( error );
if( temp.size() == 0 ) continue;
// Get the half-faces incident on the local vertex and match it with the obtained faces
int nhfthisv = lConnMap3D[index].v2hf_num[lv];
int fsize = 0;
error = mb->get_connectivity( temp[k], fid_verts, fsize, true );MB_CHK_ERR( error );
for( int j = 0; j < nhfthisv; j++ )
// Collect all the vertices of this half-face
int idx = lConnMap3D[index].v2hf[lv][j];
int nvF = lConnMap3D[index].hf2v_num[idx];
if( fsize != nvF ) continue;
int direct, offset;
bool they_match = CN::ConnectivityMatch( &half_faces[idx][0], &fid_verts[0], nvF, direct, offset );
if( they_match )
bool found = false;
for( int p = 0; p < (int)adjents.size(); p++ )
if( adjents[p] == temp[k] )
found = true;
break;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_entity_ranges | ( | Range & | verts, |
| Range & | edges, | ||
| Range & | cells | ||
Definition at line 3652 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, and MB_SUCCESS.
verts = _verts;
edges = _edges;
faces = _faces;
cells = _cells;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_face_edges | ( | EntityHandle | fid, |
| std::vector< EntityHandle > & | edges | ||
Definition at line 1583 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_up_adjacencies_1d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, and moab::Core::type_from_handle().
ErrorCode error;
edges.clear();
std::vector< EntityHandle > conn;
error = mb->get_connectivity( &fid, 1, conn );MB_CHK_ERR( error );
EntityHandle v0 = conn[i];
EntityHandle v1 = conn[lConnMap2D[ftype - 2].next[i]];
std::vector< EntityHandle > e0, e1, ecom;
error = get_up_adjacencies_1d( v0, e0 );MB_CHK_ERR( error );
error = get_up_adjacencies_1d( v1, e1 );MB_CHK_ERR( error );
std::sort( e0.begin(), e0.end() );
std::sort( e1.begin(), e1.end() );
std::set_intersection( e0.begin(), e0.end(), e1.begin(), e1.end(), std::back_inserter( ecom ) );
assert( ecom.size() == 1 || ecom.size() == 0 );
if( ecom.size() == 0 )
edges.push_back( 0 );
else
edges.push_back( ecom[0] );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_half_facet_in_comp | ( | EntityHandle | cid, |
| int | leid, | ||
| std::vector< EntityHandle > & | ents, | ||
| std::vector< int > & | lids, | ||
| std::vector< int > & | lfids | ||
Definition at line 3158 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), moab::HalfFacetRep::LocalMaps3D::e2hf, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_edg_3d(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), lConnMap3D, lid_from_halffacet(), moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, and moab::Core::type_from_handle().
ErrorCode error;
ents.clear();
lids.clear();
EntityType ctype = mb->type_from_handle( cid );
int index = get_index_in_lmap( *_cells.begin() );
// Get all incident cells
std::vector< EntityHandle > adjents;
std::vector< int > adjlids;
error = get_up_adjacencies_edg_3d( cid, leid, adjents, &adjlids );MB_CHK_ERR( error );
// Get the end vertices of the edge <cid,leid>
error = mb->get_connectivity( cid, econn, nvpc, true );MB_CHK_ERR( error );
int id = lConnMap3D[index].e2v[leid][0];
EntityHandle vstart = econn[id];
id = lConnMap3D[index].e2v[leid][1];
EntityHandle vend = econn[id];
std::vector< int > mark( adjents.size(), 0 );
int count = 0;
for( int k = 0; k < (int)adjents.size(); k++ )
if( mark[k] != 0 ) continue;
count += 1;
mark[k] = count;
// Loop over each half-face incident on this local edge
EntityHandle cur_cell = adjents[k];
int cur_leid = adjlids[k];
int lface = i;
while( true )
int cidx = ID_FROM_HANDLE( cur_cell ) - 1;
int lfid = lConnMap3D[index].e2hf[cur_leid][lface];
HFacet hf = sibhfs[nfpc * cidx + lfid];
cur_cell = fid_from_halfacet( hf, ctype );
lfid = lid_from_halffacet( hf );
// Check if loop reached starting cell or a boundary
if( ( cur_cell == adjents[k] ) || ( cur_cell == 0 ) ) break;
const EntityHandle* sib_conn;
error = mb->get_connectivity( cur_cell, sib_conn, nvpc, true );MB_CHK_ERR( error );
// Find the local edge id wrt to sibhf
int nv_curF = lConnMap3D[index].hf2v_num[lfid];
int lv0 = -1, lv1 = -1, idx = -1;
for( int j = 0; j < nv_curF; j++ )
idx = lConnMap3D[index].hf2v[lfid][j];
if( vstart == sib_conn[idx] ) lv0 = idx;
if( vend == sib_conn[idx] ) lv1 = idx;
assert( ( lv0 >= 0 ) && ( lv1 >= 0 ) );
cur_leid = lConnMap3D[index].lookup_leids[lv0][lv1];
int chk_lfid = lConnMap3D[index].e2hf[cur_leid][0];
if( lfid == chk_lfid )
lface = 1;
else
lface = 0;
int ind = std::find( adjents.begin(), adjents.end(), cur_cell ) - adjents.begin();
mark[ind] = count;
// Loop back
if( cur_cell != 0 ) break;
// Loop over again to find cells on the boundary
for( int c = 0; c < count; c++ )
for( int i = 0; i < (int)adjents.size(); i++ )
if( mark[i] == c + 1 )
int cidx = ID_FROM_HANDLE( adjents[i] ) - 1;
for( int j = 0; j < nfpc; j++ )
HFacet hf = sibhfs[nfpc * cidx + j];
EntityHandle cell = fid_from_halfacet( hf, ctype );
if( cell == 0 )
ents.push_back( adjents[i] );
lids.push_back( adjlids[i] );
lfids.push_back( j );
break;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_incident_map | ( | EntityType | type, |
| EntityHandle | vid, | ||
| std::vector< EntityHandle > & | inci_entid, | ||
| std::vector< int > & | inci_lid | ||
Definition at line 3535 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, v2he, v2hes, v2hf, v2hfs, and v2hv.
Referenced by moab::NestedRefine::is_vertex_on_boundary(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
inci_entid.clear();
inci_lid.clear();
if( type == MBEDGE )
HFacet hf = v2hv[ID_FROM_HANDLE( vid ) - 1];
inci_entid.push_back( fid_from_halfacet( hf, type ) );
inci_lid.push_back( lid_from_halffacet( hf ) );
else if( type == MBTRI || type == MBQUAD )
it_hes;
it_hes = v2hes.equal_range( vid );
inci_entid.push_back( fid_from_halfacet( it->second, type ) );
inci_lid.push_back( lid_from_halffacet( it->second ) );
else if( hf != 0 )
else if( hf == 0 && ( v2hes.find( vid ) == v2hes.end() ) )
else
it_hes;
it_hes = v2hfs.equal_range( vid );
else if( hf != 0 )
else if( hf == 0 && ( v2hfs.find( vid ) == v2hfs.end() ) )
return MB_SUCCESS;
| int moab::HalfFacetRep::get_index_for_meshtype | ( | MESHTYPE | mesh_type | ) | [protected] |
Definition at line 101 of file HalfFacetRep.cpp.
References moab::CURVE, moab::SURFACE, moab::SURFACE_MIXED, moab::VOLUME, moab::VOLUME_MIXED, moab::VOLUME_MIXED_1, and moab::VOLUME_MIXED_2.
int index = 0;
switch( mesh_type )
case CURVE:
index = 0;
break;
case SURFACE:
index = 1;
break;
case SURFACE_MIXED:
index = 2;
break;
case VOLUME:
index = 3;
break;
case VOLUME_MIXED_1:
index = 4;
break;
case VOLUME_MIXED_2:
index = 5;
break;
case VOLUME_MIXED:
index = 6;
break;
return index;
Definition at line 1620 of file HalfFacetRep.cpp.
References cell_index, mb, and moab::Core::type_from_handle().
Referenced by add_cells_of_single_component(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::create_hm_storage_single_level(), determine_border_vertices(), determine_incident_halffaces(), determine_sibling_halffaces(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), find_total_edges_faces_3d(), moab::NestedRefine::get_connectivity(), get_down_adjacencies_edg_3d(), get_down_adjacencies_face_3d(), get_half_facet_in_comp(), moab::NestedRefine::get_lid_inci_child(), get_neighbor_adjacencies_3d(), get_sibling_map(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_3d(), init_volume(), moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_edge_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), print_tags(), moab::NestedRefine::reorder_indices(), resize_hf_maps(), set_sibling_map(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), moab::NestedRefine::update_global_ahf_3D(), moab::NestedRefine::update_local_ahf(), and moab::NestedRefine::update_tracking_verts().
EntityType type = mb->type_from_handle( cid );
int index = cell_index.find( type )->second;
return index;
| void moab::HalfFacetRep::get_memory_use | ( | unsigned long long & | entity_total, |
| unsigned long long & | memory_total | ||
Definition at line 3676 of file HalfFacetRep.cpp.
References sibhes, sibhfs, sibhvs, v2he, v2hf, and v2hv.
entity_total = memory_total = 0;
// 1D
if( !v2hv.empty() ) entity_total += v2hv.capacity() * sizeof( HFacet ) + sizeof( v2hv );
if( !sibhvs.empty() ) entity_total += sibhvs.capacity() * sizeof( HFacet ) + sizeof( sibhvs );
// 2D
if( !v2he.empty() ) entity_total += v2he.capacity() * sizeof( HFacet ) + sizeof( v2he );
if( !sibhes.empty() ) entity_total += sibhes.capacity() * sizeof( HFacet ) + sizeof( sibhes );
// 3D
if( !v2hf.empty() ) entity_total += v2hf.capacity() * sizeof( HFacet ) + sizeof( v2hf );
if( !sibhfs.empty() ) entity_total += sibhfs.capacity() * sizeof( HFacet ) + sizeof( sibhfs );
memory_total = entity_total;
| MESHTYPE moab::HalfFacetRep::get_mesh_type | ( | int | nverts, |
| int | nedges, | ||
| int | nfaces, | ||
| int | ncells | ||
Definition at line 56 of file HalfFacetRep.cpp.
Referenced by moab::NestedRefine::create_hm_storage_single_level(), and initialize().
MESHTYPE mesh_type = CURVE;
if( nverts && nedges && ( !nfaces ) && ( !ncells ) )
mesh_type = CURVE;
else if( nverts && !nedges && nfaces && !ncells )
mesh_type = SURFACE;
else if( nverts && nedges && nfaces && !ncells )
mesh_type = SURFACE_MIXED;
else if( nverts && !nedges && !nfaces && ncells )
mesh_type = VOLUME;
else if( nverts && nedges && !nfaces && ncells )
mesh_type = VOLUME_MIXED_1;
else if( nverts && !nedges && nfaces && ncells )
mesh_type = VOLUME_MIXED_2;
else if( nverts && nedges && nfaces && ncells )
mesh_type = VOLUME_MIXED;
return mesh_type;
| ErrorCode moab::HalfFacetRep::get_neighbor_adjacencies | ( | EntityHandle | ent, |
Get the same-dimensional entities connected with an entity.
Given an entity of dimension d, gather all the entities connected via d-1 dimensional entities. Same as bridge_adjacencies in MOAB.
Definition at line 568 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_neighbor_adjacencies_1d(), get_neighbor_adjacencies_2d(), get_neighbor_adjacencies_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
ErrorCode error;
assert( in_dim >= 1 && in_dim <= 3 );
if( in_dim == 1 )
error = get_neighbor_adjacencies_1d( ent, adjents );MB_CHK_ERR( error );
else if( in_dim == 2 )
error = get_neighbor_adjacencies_2d( ent, adjents );MB_CHK_ERR( error );
else if( in_dim == 3 )
error = get_neighbor_adjacencies_3d( ent, adjents );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_neighbor_adjacencies_1d | ( | EntityHandle | eid, |
Given an edge, finds vertex-connected neighbor edges.
Given an edge, it gathers all the incident edges of each vertex of the edge.
| adjents | Vector returning neighbor edges |
Definition at line 779 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, and sibhvs.
Referenced by get_neighbor_adjacencies().
adjents.clear();
EntityHandle sibhv_eid;
int sibhv_lid;
int eidx = ID_FROM_HANDLE( eid ) - 1;
for( int lid = 0; lid < 2; ++lid )
HFacet shf = sibhvs[2 * eidx + lid];
sibhv_eid = fid_from_halfacet( shf, MBEDGE );
sibhv_lid = lid_from_halffacet( shf );
if( sibhv_eid != 0 )
adjents.push_back( sibhv_eid );
eidx = ID_FROM_HANDLE( sibhv_eid ) - 1;
HFacet nhf = sibhvs[2 * eidx + sibhv_lid];
EntityHandle hv_eid = fid_from_halfacet( nhf, MBEDGE );
int hv_lid = lid_from_halffacet( nhf );
while( hv_eid != 0 )
if( hv_eid != eid ) adjents.push_back( hv_eid );
eidx = ID_FROM_HANDLE( hv_eid ) - 1;
HFacet hf = sibhvs[2 * eidx + hv_lid];
EntityHandle edge = fid_from_halfacet( hf, MBEDGE );
if( edge == sibhv_eid ) break;
hv_eid = edge;
hv_lid = lid_from_halffacet( hf );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_neighbor_adjacencies_2d | ( | EntityHandle | fid, |
Given an edge, finds edge-connected neighbor face.
Given an face, it gathers all the neighbor faces of each local edge of the face.
| adjents | Vector returning neighbor faces |
Definition at line 1466 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, get_up_adjacencies_2d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, and moab::Core::type_from_handle().
ErrorCode error;
if( fid != 0 )
for( int lid = 0; lid < nepf; ++lid )
error = get_up_adjacencies_2d( fid, lid, false, adjents );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_neighbor_adjacencies_3d | ( | EntityHandle | cid, |
Given a cell, finds face-connected neighbor cells.
Given a cell, it gathers all the neighbor cells of each local face of the cell.
| adjents | Vector returning neighbor cells |
Definition at line 2931 of file HalfFacetRep.cpp.
References fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, and moab::Core::type_from_handle().
int cidx = ID_FROM_HANDLE( cid ) - 1;
if( cid != 0 )
for( int lfid = 0; lfid < nfpc; ++lfid )
if( sibcid != 0 ) adjents.push_back( sibcid );
return MB_SUCCESS;
| EntityHandle* moab::HalfFacetRep::get_rset | ( | ) | [inline] |
| ErrorCode moab::HalfFacetRep::get_sibling_map | ( | EntityType | type, |
| EntityHandle | ent, | ||
| EntityHandle * | sib_entids, | ||
| int * | sib_lids, | ||
| int | num_halffacets | ||
Definition at line 3377 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), MB_SET_ERR, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
Referenced by moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_edge_on_boundary(), moab::NestedRefine::is_face_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
if( num_halffacets != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfvertices." );
int eidx = ID_FROM_HANDLE( ent ) - 1;
HFacet hf = sibhvs[2 * eidx + i];
sib_entids[i] = fid_from_halfacet( hf, MBEDGE );
sib_lids[i] = lid_from_halffacet( hf );
int nepf = lConnMap2D[type - 2].num_verts_in_face;
if( num_halffacets != nepf ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfedges." );
int fidx = ID_FROM_HANDLE( ent ) - 1;
HFacet hf = sibhes[nepf * fidx + i];
sib_entids[i] = fid_from_halfacet( hf, type );
else
int idx = get_index_in_lmap( *_cells.begin() );
int nfpc = lConnMap3D[idx].num_faces_in_cell;
if( num_halffacets != nfpc ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halffaces." );
int cidx = ID_FROM_HANDLE( ent ) - 1;
return MB_SUCCESS;
| int | lid, | ||
| EntityHandle & | sib_entid, | ||
| int & | sib_lid | ||
Definition at line 3428 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
HFacet hf = sibhvs[2 * eidx + lid];
sib_entid = fid_from_halfacet( hf, MBEDGE );
sib_lid = lid_from_halffacet( hf );
HFacet hf = sibhes[nepf * fidx + lid];
sib_entid = fid_from_halfacet( hf, type );
else
HFacet hf = sibhfs[nfpc * cidx + lid];
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies | ( | EntityHandle | ent, |
| int | out_dim, | ||
| std::vector< EntityHandle > & | adjents, | ||
| std::vector< int > * | lids = NULL |
Get the upward incidences associated with an entity.
Given an entity of dimension d, gather all the incident D(>d) dimensional entities. :
| ent | EntityHandle to which incident entities have to be found. |
| out_dim | Dimension of the desired incidence information. |
| adjents | Vector in which the incident entities are returned. |
| local_id | Set to false by default. If true, returns the local id's of the half-facets |
| lids | Vector in which the local id's are returned. |
Definition at line 528 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_up_adjacencies_1d(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
Referenced by get_adjacencies(), and moab::HiReconstruction::vertex_get_incident_elements().
ErrorCode error;
assert( ( in_dim >= 0 && in_dim <= 2 ) && ( out_dim > in_dim ) );
if( in_dim == 0 )
if( out_dim == 1 )
error = get_up_adjacencies_1d( ent, adjents, lids );MB_CHK_ERR( error );
else if( out_dim == 2 )
error = get_up_adjacencies_vert_2d( ent, adjents );MB_CHK_ERR( error );
else if( out_dim == 3 )
error = get_up_adjacencies_vert_3d( ent, adjents );MB_CHK_ERR( error );
else if( ( in_dim == 1 ) && ( out_dim == 2 ) )
error = get_up_adjacencies_2d( ent, adjents, lids );MB_CHK_ERR( error );
else if( ( in_dim == 1 ) && ( out_dim == 3 ) )
error = get_up_adjacencies_edg_3d( ent, adjents, lids );MB_CHK_ERR( error );
else if( ( in_dim == 2 ) && ( out_dim == 3 ) )
error = get_up_adjacencies_face_3d( ent, adjents, lids );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_1d | ( | EntityHandle | vid, |
| std::vector< int > * | lvids = NULL |
Given a vertex, finds the edges incident on it.
Given a vertex handle, it starts by first finding an incident half-vert by using the incident half-vert map, and then obtaining all the sibling half-verts of the corresponding half-vertex.
| vid | EntityHandle of the query vertex |
| adjents | Vector returning the incident edges |
| local_id | False by default. If true, returns the local vertex id's corresponding to vid |
| lvids | Vector returning the local vertex id's |
Definition at line 739 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, sibhvs, and v2hv.
Referenced by get_down_adjacencies_2d(), get_down_adjacencies_edg_3d(), get_face_edges(), get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
adjents.clear();
if( lvids != NULL ) lvids->reserve( 20 );
int vidx = ID_FROM_HANDLE( vid ) - 1;
EntityHandle start_eid = fid_from_halfacet( hf, MBEDGE );
int start_lid = lid_from_halffacet( hf );
EntityHandle eid = start_eid;
int lid = start_lid;
if( eid != 0 )
adjents.push_back( eid );
if( lvids != NULL ) lvids->push_back( lid );
while( eid != 0 )
if( ( !eid ) || ( eid == start_eid ) ) break;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d | ( | EntityHandle | eid, |
| std::vector< int > * | leids = NULL |
Given an edge, finds the faces incident on it.
Given an edge, it first finds a matching half-edge corresponding to eid, and then collects all the incident half-edges/faces via the sibhes map.
| adjents | Vector returning the incident faces |
| local_id | By default false. If true, returns the local edge id's corresponding to the input edge |
| leids | Vector returning local edge ids |
Definition at line 1167 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_matching_halfedge(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by collect_and_compare(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), find_total_edges_2d(), gather_halfedges(), get_neighbor_adjacencies_2d(), get_up_adjacencies(), get_up_adjacencies_vert_2d(), moab::NestedRefine::is_edge_on_boundary(), and mark_halfedges().
// Given an explicit edge eid, find the incident faces.
ErrorCode error;
EntityHandle he_fid = 0;
int he_lid = 0;
// Step 1: Given an explicit edge, find a corresponding half-edge from the surface mesh.
bool found = find_matching_halfedge( eid, &he_fid, &he_lid );
// Step 2: If there is a corresponding half-edge, collect all sibling half-edges and store the
// incident faces.
if( found )
error = get_up_adjacencies_2d( he_fid, he_lid, true, adjents, leids );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d | ( | EntityHandle | fid, |
| int | leid, | ||
| bool | add_inent, | ||
| std::vector< EntityHandle > & | adj_ents, | ||
| std::vector< int > * | adj_leids = NULL, |
| std::vector< int > * | adj_orients = NULL |
Given a half-edge <fid, leid>, finds the faces incident on it.
| fid | EntityHandle of the containing face |
| leid | local id of the edge w.r.t to the face |
| add_inent | If true, adds the input fid into the returning vector of adjents. |
| local_id | By default false. If true, returns the local edge id's as well. |
Definition at line 1191 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), lConnMap2D, lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, and moab::Core::type_from_handle().
// Given an implicit half-edge <fid, leid>, find the incident half-edges.
ErrorCode error;
int nepf = lConnMap2D[ftype - 2].num_verts_in_face;
if( !fid ) return MB_FAILURE;
adj_ents.reserve( 20 );
bool local_id = false;
bool orient = false;
if( adj_leids != NULL )
local_id = true;
adj_leids->reserve( 20 );
if( adj_orients != NULL )
orient = true;
adj_orients->reserve( 20 );
if( add_inent )
adj_ents.push_back( fid );
if( local_id ) adj_leids->push_back( leid );
EntityHandle fedge[2] = { 0, 0 };
if( orient )
// get connectivity and match their directions
const EntityHandle* fid_conn;
error = mb->get_connectivity( fid, fid_conn, nepf, true );MB_CHK_ERR( error );
int nidx = lConnMap2D[ftype - 2].next[leid];
fedge[0] = fid_conn[leid];
fedge[1] = fid_conn[nidx];
int fidx = ID_FROM_HANDLE( fid ) - 1;
HFacet hf = sibhes[nepf * fidx + leid];
EntityHandle curfid = fid_from_halfacet( hf, ftype );
int curlid = lid_from_halffacet( hf );
while( ( curfid != fid ) && ( curfid != 0 ) )
{ // Should not go into the loop when no sibling exists
adj_ents.push_back( curfid );
if( local_id ) adj_leids->push_back( curlid );
if( orient )
const EntityHandle* conn;
error = mb->get_connectivity( curfid, conn, nepf, true );MB_CHK_ERR( error );
int nidx = lConnMap2D[ftype - 2].next[curlid];
if( ( fedge[0] == conn[curlid] ) && ( fedge[1] == conn[nidx] ) )
adj_orients->push_back( 1 );
else if( ( fedge[1] == conn[curlid] ) && ( fedge[0] == conn[nidx] ) )
adj_orients->push_back( 0 );
int cidx = ID_FROM_HANDLE( curfid ) - 1;
hf = sibhes[nepf * cidx + curlid];
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d | ( | EntityHandle | he_fid, |
| int | he_lid, | ||
| int * | qsize, | ||
| int * | count | ||
| ) | [protected] |
Contains the local information for 2D entities.
Given a face, find the face type specific information
| face | EntityHandle. Used to gather info about the type of face for which local info is required |
| nepf,: | Returns the number of vertices/edges for given face type. Contains the local information for 2D entities Given number of edges, returns local indices of next and previous local edges. |
| nepf,: | The number of vertices/edges for given face type. |
| next,prev,: | Local ids of next and previous edges w.r.t to the face |
Note: For 2D entities, the number of vertices and edges are same and each local edge is outgoing corresponding to the local vertex, i.e,
v2 v3 __e2__v2 /\ | | e2 / \ e1 e3| |e1 /____\ |______| v0 e0 v1 v0 e0 v1 Given a half-edge as <he_fid,he_lid> , finds the half-edges incident on it and adds them Given an half-edge, obtain all the incident half-edges via the sibhes map and add them to a given queue of half-edges, if they do not already exist in the queue. This function is used to increment the search space for finding a matching half-edge.
| he_fid | EntityHandle of query half-edge |
| he_lid | Local id of query half-edge |
Definition at line 1274 of file HalfFacetRep.cpp.
References fid_from_halfacet(), find_match_in_array(), moab::ID_FROM_HANDLE(), lConnMap2D, lid_from_halffacet(), mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, and moab::Core::type_from_handle().
if( curfid == 0 )
int index = 0;
bool found_ent = find_match_in_array( fid, queue_fid, qsize[0] - 1, true, &index );
if( ( !found_ent ) || ( ( found_ent ) && ( queue_lid[index] != lid ) ) )
queue_fid[qsize[0]] = fid;
queue_lid[qsize[0]] = lid;
qsize[0] += 1;
bool val = find_match_in_array( curfid, trackfaces, count[0] );
if( !val )
queue_fid[qsize[0]] = curfid;
queue_lid[qsize[0]] = curlid;
qsize[0] += 1;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d | ( | EntityHandle | eid, |
Given an edge, finds the cells incident on it.
Given an edge, it first finds a matching local edge in a cell corresponding to eid, and then collects all the incident cells via the sibhfs map.
| adjents | Vector returning the incident cells |
Definition at line 2165 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), cellq, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by moab::NestedRefine::construct_hm_1D(), find_total_edges_faces_3d(), get_half_facet_in_comp(), get_up_adjacencies(), moab::NestedRefine::is_edge_on_boundary(), and moab::NestedRefine::update_tracking_verts().
ErrorCode error;
int index = get_index_in_lmap( start_cell );
int nvpc = lConnMap3D[index].num_verts_in_cell;
int nfpc = lConnMap3D[index].num_faces_in_cell;
if( leids != NULL ) leids->reserve( 20 );
int num_conn = 0;
// Find an half-facets incident to each end vertex of the edge
it_hes;
else if( hf1 != 0 )
it_hes;
else if( hf2 != 0 )
if( start_cells.empty() ) return MB_SUCCESS;
std::sort( start_cells.begin(), start_cells.end() );
std::vector< EntityHandle >::iterator last = std::unique( start_cells.begin(), start_cells.end() );
start_cells.erase( last, start_cells.end() );
int num_qvals = 0;
num_qvals += 1;
lv0 = i;
lv = lv0;
lv1 = i;
lv = lv1;
adjents.push_back( cell_id );
if( leids != NULL ) leids->push_back( lConnMap3D[index].lookup_leids[lv0][lv1] );
if( lv < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
int nhf_thisv = lConnMap3D[index].v2hf_num[lv];
int ind = lConnMap3D[index].v2hf[lv][i];
if( ngb )
if( !found_ent )
cellq[qsize] = ngb;
qsize += 1;
cellq[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d | ( | EntityHandle | cid, |
| int | leid, | ||
| std::vector< int > * | leids = NULL, |
Given a local edge <cid, leid>, finds the cells incident on it.
Given a local edge, it gathers all the incident cells via the sibhfs map.
| cid | EntityHandle of the cell containing the local edge |
| leid | local edge id w.r.t the cell |
Definition at line 2298 of file HalfFacetRep.cpp.
References cellq, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
ErrorCode error;
adjents.clear();
if( leids != NULL )
leids->clear();
adj_orients->clear();
EntityHandle v_start = econn[id];
EntityHandle v_end = econn[id];
it_hes;
else if( hf1 != 0 )
it_hes;
else if( hf2 != 0 )
int num_qvals = 0;
num_qvals += 1;
lv0 = i;
lv = lv0;
lv1 = i;
lv = lv1;
int cur_leid = lConnMap3D[index].lookup_leids[lv0][lv1];
int id1 = lConnMap3D[index].e2v[cur_leid][0];
int id2 = lConnMap3D[index].e2v[cur_leid][1];
if( ( v_start == conn[id1] ) && ( v_end == conn[id2] ) )
else if( ( v_start == conn[id2] ) && ( v_end == conn[id1] ) )
if( ngb )
if( !found_ent )
cellq[qsize] = ngb;
qsize += 1;
cellq[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp | ( | EntityHandle | cid, |
| int | leid, | ||
Definition at line 2455 of file HalfFacetRep.cpp.
References cellq, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by moab::NestedRefine::update_global_ahf_3D().
ErrorCode error;
adjents.clear();
if( leids != NULL )
leids->clear();
error = mb->get_connectivity( cid, econn, nvpc );MB_CHK_ERR( error );
if( ( hf1 == 0 ) && ( v2hfs.find( v_start ) != v2hfs.end() ) && ( hf2 == 0 ) &&
( v2hfs.find( v_end ) != v2hfs.end() ) )
it_hes;
else
return MB_SUCCESS;
// std::sort(start_cells.begin(), start_cells.end());
// std::vector<EntityHandle>::iterator last = std::unique(start_cells.begin(),
// start_cells.end()); start_cells.erase(last, start_cells.end());
for( int c = 0; c < (int)start_cells.size(); c++ )
cellq[0] = start_cells[c];
int qsize = 1;
int num_qvals = 0;
num_qvals += 1;
error = mb->get_connectivity( cell_id, conn, nvpc );MB_CHK_ERR( error );
lv0 = i;
lv = lv0;
lv1 = i;
lv = lv1;
cellq[i] = 0;
break;
if( ngb )
if( !found_ent )
cellq[qsize] = ngb;
qsize += 1;
cellq[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_face_3d | ( | EntityHandle | fid, |
| std::vector< int > * | lfids = NULL |
Given an face, finds the cells incident on it.
Given an face, it first finds a matching half-face in a cell corresponding to face, and then collects all the incident cells via the sibhfs map.
| local_id | By default false. If true, returns the local face id's corresponding to the input face |
| leids | Vector returning local face ids |
Definition at line 2602 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_matching_halfface(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by moab::NestedRefine::construct_hm_2D(), find_total_edges_faces_3d(), get_up_adjacencies(), moab::NestedRefine::is_face_on_boundary(), and moab::NestedRefine::update_tracking_verts().
ErrorCode error;
EntityHandle cid = 0;
int lid = 0;
bool found = find_matching_halfface( fid, &cid, &lid );
if( found )
error = get_up_adjacencies_face_3d( cid, lid, adjents, lfids );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_face_3d | ( | EntityHandle | cid, |
| int | lfid, | ||
Given a local face <cid, lfid>, finds the cells incident on it.
Given a local face, it gathers all the incident cells via the sibhfs map.
| lfid | local face id w.r.t the cell |
| lfids | Vector returning local face ids |
Definition at line 2620 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, lid_from_halffacet(), mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, and moab::Core::type_from_handle().
adjents.reserve( 4 );
adjents.push_back( cid );
if( lfids != NULL )
lfids->reserve( 4 );
lfids->push_back( lfid );
int siblid = lid_from_halffacet( hf );
if( sibcid != 0 )
if( lfids != NULL ) lfids->push_back( siblid );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_vert_2d | ( | EntityHandle | vid, |
Given a vertex, finds the faces incident on it.
Given a vertex, it first finds an incident half-edge via v2he map, and then collects all the incident half-edges/faces via the sibhes map.
Definition at line 1089 of file HalfFacetRep.cpp.
References _faces, another_halfedge(), moab::Range::begin(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), gather_halfedges(), get_up_adjacencies_2d(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, trackfaces, moab::Core::type_from_handle(), v2he, and v2hes.
Referenced by get_down_adjacencies_face_3d(), get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
ErrorCode error;
EntityType ftype = mb->type_from_handle( *_faces.begin() );
HFacet hf = v2he[vidx];
std::vector< EntityHandle > start_fids;
std::vector< int > start_lids;
if( hf == 0 && ( v2hes.find( vid ) != v2hes.end() ) )
it_hes;
start_fids.push_back( fid_from_halfacet( it->second, ftype ) );
start_lids.push_back( lid_from_halffacet( it->second ) );
else if( hf != 0 )
start_fids.push_back( fid_from_halfacet( hf, ftype ) );
start_lids.push_back( lid_from_halffacet( hf ) );
if( start_fids.empty() ) return MB_SUCCESS;
int num_qvals = 0;
adjents.reserve( (int)start_fids.size() );
for( int i = 0; i < (int)start_fids.size(); i++ )
adjents.push_back( start_fids[i] );
error = gather_halfedges( vid, start_fids[i], start_lids[i], &qsize, &count );MB_CHK_ERR( error );
EntityHandle curfid = queue_fid[num_qvals];
int curlid = queue_lid[num_qvals];
num_qvals += 1;
int he2_lid = 0;
error = another_halfedge( vid, curfid, curlid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
bool val = find_match_in_array( he2_fid, trackfaces, count );
if( val ) continue;
count += 1;
trackfaces[count] = he2_fid;
error = get_up_adjacencies_2d( he2_fid, he2_lid, &qsize, &count );MB_CHK_ERR( error );
adjents.push_back( he2_fid );
// Change the visited faces to false, also empty the queue
for( int i = 0; i <= qsize; i++ )
queue_fid[i] = 0;
queue_lid[i] = 0;
for( int i = 0; i <= count; i++ )
trackfaces[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::get_up_adjacencies_vert_3d | ( | EntityHandle | vid, |
Given a vertex, finds the cells incident on it.
Given a vertex, it first finds an incident half-face via v2hf map, and then collects all the incident half-faces via the sibhfs map.
Definition at line 2072 of file HalfFacetRep.cpp.
Referenced by get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
ErrorCode error;
// Obtain a half-face/s incident on v
HFacet hf = v2hf[vidx];
if( hf == 0 && ( v2hfs.find( vid ) != v2hfs.end() ) ) // Vertex is non-manifold
it_hes;
else if( hf != 0 )
int index = get_index_in_lmap( start_cells[0] );
EntityHandle cur_cid;
int num_qvals = 0;
cur_cid = cellq[num_qvals];
num_qvals += 1;
// Add the current cell to output adj vector
adjents.push_back( cur_cid );
// Connectivity of the cell
error = mb->get_connectivity( cur_cid, conn, nvpc, true );MB_CHK_ERR( error );
// Local id of vid in the cell and the half-faces incident on it
int lv = -1;
for( int i = 0; i < nvpc; ++i )
if( conn[i] == vid )
lv = i;
break;
// Number of local half-faces incident on the current vertex
int cidx = ID_FROM_HANDLE( cur_cid ) - 1;
// Add new cells into the stack
EntityHandle ngb;
for( int i = 0; i < nhf_thisv; ++i )
if( ngb )
bool found_ent = find_match_in_array( ngb, cellq, qsize - 1 );
if( !found_ent )
cellq[qsize] = ngb;
qsize += 1;
cellq[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::init_curve | ( | ) | [protected] |
Definition at line 278 of file HalfFacetRep.cpp.
References _edges, _verts, determine_incident_halfverts(), determine_sibling_halfverts(), moab::Range::end(), moab::error(), ErrorCode, moab::ID_FROM_HANDLE(), MB_CHK_ERR, MB_SUCCESS, sibhvs, and v2hv.
Referenced by initialize().
ErrorCode error;
int nv = ID_FROM_HANDLE( *( _verts.end() - 1 ) );
int ne = ID_FROM_HANDLE( *( _edges.end() - 1 ) );
v2hv.resize( nv, 0 );
sibhvs.resize( ne * 2, 0 );
error = determine_sibling_halfverts( _verts, _edges );MB_CHK_ERR( error );
error = determine_incident_halfverts( _edges );MB_CHK_ERR( error );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::init_surface | ( | ) | [protected] |
Definition at line 294 of file HalfFacetRep.cpp.
References _faces, _verts, moab::Range::begin(), determine_incident_halfedges(), determine_sibling_halfedges(), moab::Range::end(), moab::error(), ErrorCode, moab::ID_FROM_HANDLE(), lConnMap2D, moab::MAXSIZE, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, moab::Core::type_from_handle(), and v2he.
ErrorCode error;
int nf = ID_FROM_HANDLE( *( _faces.end() - 1 ) );
v2he.resize( nv, 0 );
sibhes.resize( nf * nepf, 0 );
// Construct ahf maps
error = determine_sibling_halfedges( _faces );MB_CHK_ERR( error );
error = determine_incident_halfedges( _faces );MB_CHK_ERR( error );
// Initialize queues for storing face and local id's during local search
for( int i = 0; i < MAXSIZE; i++ )
queue_fid[i] = 0;
queue_lid[i] = 0;
trackfaces[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::init_volume | ( | ) | [protected] |
Definition at line 321 of file HalfFacetRep.cpp.
References _cells, _verts, moab::Range::begin(), cell_index, cellq, determine_incident_halffaces(), determine_sibling_halffaces(), moab::Range::end(), moab::error(), ErrorCode, get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::MAXSIZE, MB_CHK_ERR, MB_SUCCESS, MBHEX, MBPRISM, MBPYRAMID, MBTET, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, Stkcells, trackcells, and v2hf.
ErrorCode error;
// Initialize std::map between cell-types and their index in lConnMap3D
cell_index[MBTET] = 0;
cell_index[MBPYRAMID] = 1;
cell_index[MBPRISM] = 2;
cell_index[MBHEX] = 3;
int nc = ID_FROM_HANDLE( *( _cells.end() - 1 ) );
v2hf.resize( nv, 0 );
sibhfs.resize( nc * nfpc, 0 );
// Construct the maps
error = determine_sibling_halffaces( _cells );MB_CHK_ERR( error );
error = determine_incident_halffaces( _cells );MB_CHK_ERR( error );
Stkcells[i] = 0;
cellq[i] = 0;
trackcells[i] = 0;
return MB_SUCCESS;
Constructs the sibling-half-facet and vertex-to-incident-half-facet maps for each dimension present in the input. This routine should be called before any calls for adjacency is made.
Definition at line 190 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _filterghost, _rset, _verts, moab::CURVE, moab::error(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Core::get_entities_by_dimension(), get_mesh_type(), init_curve(), init_surface(), init_volume(), mb, MB_CHK_ERR, MB_SUCCESS, mInitAHFmaps, pcomm, PSTATUS_GHOST, PSTATUS_NOT, moab::Range::size(), moab::SURFACE, moab::SURFACE_MIXED, thismeshtype, moab::VOLUME, moab::VOLUME_MIXED, moab::VOLUME_MIXED_1, and moab::VOLUME_MIXED_2.
Referenced by get_adjacencies(), moab::NestedRefine::initialize(), and moab::HiReconstruction::initialize().
ErrorCode error;
if( !mInitAHFmaps )
mInitAHFmaps = true;
#ifdef MOAB_HAVE_MPI
if( pcomm && _filterghost )
moab::Range _averts, _aedgs, _afacs, _acels;
error = mb->get_entities_by_dimension( this->_rset, 0, _averts, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 1, _aedgs, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 2, _afacs, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 3, _acels, true );MB_CHK_ERR( error );
// filter based on parallel status
error = pcomm->filter_pstatus( _averts, PSTATUS_GHOST, PSTATUS_NOT, -1, &_verts );MB_CHK_ERR( error );
error = pcomm->filter_pstatus( _aedgs, PSTATUS_GHOST, PSTATUS_NOT, -1, &_edges );MB_CHK_ERR( error );
error = pcomm->filter_pstatus( _afacs, PSTATUS_GHOST, PSTATUS_NOT, -1, &_faces );MB_CHK_ERR( error );
error = pcomm->filter_pstatus( _acels, PSTATUS_GHOST, PSTATUS_NOT, -1, &_cells );MB_CHK_ERR( error );
else
error = mb->get_entities_by_dimension( this->_rset, 0, _verts, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 1, _edges, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 2, _faces, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( this->_rset, 3, _cells, true );MB_CHK_ERR( error );
#else
#endif
int nverts = _verts.size();
int nedges = _edges.size();
int nfaces = _faces.size();
int ncells = _cells.size();
MESHTYPE mesh_type = get_mesh_type( nverts, nedges, nfaces, ncells );
thismeshtype = mesh_type;
// Initialize mesh type specific maps
if( thismeshtype == CURVE )
error = init_curve();MB_CHK_ERR( error );
else if( thismeshtype == SURFACE )
error = init_surface();MB_CHK_ERR( error );
else if( thismeshtype == SURFACE_MIXED )
else if( thismeshtype == VOLUME )
error = init_volume();MB_CHK_ERR( error );
else if( thismeshtype == VOLUME_MIXED_1 )
else if( thismeshtype == VOLUME_MIXED_2 )
else if( thismeshtype == VOLUME_MIXED )
return MB_SUCCESS;
| int moab::HalfFacetRep::lid_from_halffacet | ( | const HFacet | facet | ) |
Definition at line 3710 of file HalfFacetRep.cpp.
References moab::LID_FROM_HALFFACET().
Referenced by find_matching_halfedge(), get_half_facet_in_comp(), get_incident_map(), get_neighbor_adjacencies_1d(), get_sibling_map(), get_up_adjacencies_1d(), get_up_adjacencies_2d(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_2d(), and print_tags().
if( facet == 0 )
return 0;
else
return LID_FROM_HALFFACET( facet );
| ErrorCode moab::HalfFacetRep::mark_halfedges | ( | EntityHandle | vid, |
| EntityHandle | he_fid, | ||
| int | he_lid, | ||
| Range & | faces, | ||
| std::vector< char > & | markHEdgs, | ||
| HFacet & | bnd_hf | ||
| ) | [protected] |
Definition at line 1019 of file HalfFacetRep.cpp.
References another_halfedge(), create_halffacet(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), gather_halfedges(), moab::Core::get_connectivity(), get_up_adjacencies_2d(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, and moab::Core::type_from_handle().
Referenced by determine_incident_halfedges().
ErrorCode error;
EntityType ftype = mb->type_from_handle( he_fid );
int qsize = 0, count = -1;
int num_qvals = 0;
error = gather_halfedges( vid, he_fid, he_lid, &qsize, &count );MB_CHK_ERR( error );
num_qvals += 1;
int fidx = ID_FROM_HANDLE( curfid ) - 1;
if( !markHEdgs[nepf * faces.index( curfid ) + curlid] && ( conn[curlid] == vid ) )
markHEdgs[nepf * faces.index( curfid ) + curlid] = 1;
HFacet hf = sibhes[nepf * fidx + curlid];
EntityHandle sibfid = fid_from_halfacet( hf, ftype );
if( sibfid == 0 ) bnd_hf = create_halffacet( curfid, curlid );
int he2_lid = 0;
if( !markHEdgs[nepf * faces.index( curfid ) + he2_lid] && ( conn[he2_lid] == vid ) )
markHEdgs[nepf * faces.index( curfid ) + he2_lid] = 1;
HFacet hf = sibhes[nepf * fidx + he2_lid];
if( sibfid == 0 ) bnd_hf = create_halffacet( he2_fid, he2_lid );
if( val ) continue;
count += 1;
queue_fid[i] = 0;
queue_lid[i] = 0;
trackfaces[i] = 0;
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::print_tags | ( | int | dim | ) |
Prints the tag values.
Definition at line 356 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, moab::Range::begin(), moab::Range::end(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), mb, MB_SUCCESS, MBEDGE, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, sibhvs, moab::Core::type_from_handle(), v2he, v2hf, v2hfs, and v2hv.
if( dim == 1 )
EntityHandle start_edge = *_edges.begin();
std::cout << "start_edge = " << start_edge << std::endl;
std::cout << "<SIBHVS_EID,SIBHVS_LVID>" << std::endl;
for( Range::iterator i = _edges.begin(); i != _edges.end(); ++i )
EntityHandle eid[2];
int lvid[2];
int eidx = ID_FROM_HANDLE( *i ) - 1;
HFacet hf1 = sibhvs[2 * eidx];
HFacet hf2 = sibhvs[2 * eidx + 1];
eid[0] = fid_from_halfacet( hf1, MBEDGE );
eid[1] = fid_from_halfacet( hf2, MBEDGE );
lvid[0] = lid_from_halffacet( hf1 );
lvid[1] = lid_from_halffacet( hf2 );
std::cout << "Entity = " << *i << " :: <" << eid[0] << "," << lvid[0] << ">"
<< "<" << eid[1] << "," << lvid[1] << ">" << std::endl;
std::cout << "<V2HV_EID, V2HV_LVID>" << std::endl;
for( Range::iterator i = _verts.begin(); i != _verts.end(); ++i )
int vidx = ID_FROM_HANDLE( *i ) - 1;
HFacet hf = v2hv[vidx];
EntityHandle eid = fid_from_halfacet( hf, MBEDGE );
int lvid = lid_from_halffacet( hf );
std::cout << "Vertex = " << *i << " :: <" << eid << "," << lvid << ">" << std::endl;
else if( dim == 2 )
EntityHandle start_face = *_faces.begin();
std::cout << "start_face = " << start_face << std::endl;
std::cout << "<SIBHES_FID,SIBHES_LEID>" << std::endl;
for( Range::iterator i = _faces.begin(); i != _faces.end(); ++i )
int fidx = ID_FROM_HANDLE( *i ) - 1;
std::cout << "Entity = " << *i;
for( int j = 0; j < nepf; j++ )
HFacet hf = sibhes[nepf * fidx + j];
EntityHandle sib = fid_from_halfacet( hf, ftype );
int lid = lid_from_halffacet( hf );
std::cout << " :: <" << sib << "," << lid << ">"
std::cout << std::endl;
std::cout << "<V2HE_FID, V2HE_LEID>" << std::endl;
EntityHandle fid = fid_from_halfacet( hf, ftype );
std::cout << "Vertex = " << *i << " :: <" << fid << "," << lid << ">" << std::endl;
else if( dim == 3 )
EntityType ctype = mb->type_from_handle( *_cells.begin() );
EntityHandle start_cell = *_cells.begin();
std::cout << "start_cell = " << start_cell << std::endl;
std::cout << "<SIBHES_CID,SIBHES_LFID>" << std::endl;
for( Range::iterator i = _cells.begin(); i != _cells.end(); ++i )
int cidx = ID_FROM_HANDLE( *i ) - 1;
EntityHandle sib = fid_from_halfacet( hf, ctype );
std::cout << "<V2HF_CID, V2HF_LFID>" << std::endl;
EntityHandle cid;
int lid;
if( hf == 0 && ( v2hfs.find( *i ) != v2hfs.end() ) )
std::pair< std::multimap< EntityHandle, HFacet >::iterator,
std::multimap< EntityHandle, HFacet >::iterator >
it_hfs;
it_hfs = v2hfs.equal_range( *i );
for( std::multimap< EntityHandle, HFacet >::iterator it = it_hfs.first; it != it_hfs.second; ++it )
cid = fid_from_halfacet( it->second, ctype );
std::cout << "Vertex = " << *i << " :: <" << cid << "," << lid << ">" << std::endl;
else
cid = fid_from_halfacet( hf, ctype );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::resize_hf_maps | ( | EntityHandle | start_vert, |
| int | nverts, | ||
| EntityHandle | start_edge, | ||
| int | nedges, | ||
| EntityHandle | start_face, | ||
| int | nfaces, | ||
| EntityHandle | start_cell, | ||
| int | ncells | ||
Definition at line 3276 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, moab::Range::begin(), moab::Range::end(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, mb, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, sibhvs, moab::Core::type_from_handle(), v2he, v2hf, and v2hv.
Referenced by moab::NestedRefine::create_hm_storage_single_level().
int nwsz = 0, insz = 0;
if( nedges )
if( ID_FROM_HANDLE( ( *( _edges.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_edge ) )
nwsz = ( ID_FROM_HANDLE( start_edge ) - ID_FROM_HANDLE( *_edges.end() ) + nedges ) * 2;
else
nwsz = nedges * 2;
insz = sibhvs.size();
sibhvs.resize( insz + nwsz, 0 );
if( v2hv.empty() )
if( ( !v2he.empty() ) )
insz = v2he.size();
else if( ( !v2hf.empty() ) )
insz = v2hf.size();
else
MB_SET_ERR( MB_FAILURE, "Trying to resize ahf maps for a mesh with no edges, faces and cells" );
else
insz = v2hv.size();
if( ID_FROM_HANDLE( *( _verts.end() - 1 ) + 1 ) != ID_FROM_HANDLE( start_vert ) )
nwsz = ID_FROM_HANDLE( start_vert ) - ID_FROM_HANDLE( *_verts.end() ) + nverts;
else
nwsz = nverts;
v2hv.resize( insz + nwsz, 0 );
if( nfaces )
if( ID_FROM_HANDLE( ( *( _faces.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_face ) )
nwsz = ( ID_FROM_HANDLE( start_face ) - ID_FROM_HANDLE( *_faces.end() ) + nfaces ) * nepf;
else
nwsz = nfaces * nepf;
insz = sibhes.size();
sibhes.resize( insz + nwsz, 0 );
else
nwsz = nverts;
insz = v2he.size();
v2he.resize( insz + nwsz, 0 );
if( ncells )
if( ID_FROM_HANDLE( ( *( _cells.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_cell ) )
nwsz = ( ID_FROM_HANDLE( start_cell ) - ID_FROM_HANDLE( *_cells.end() ) + ncells ) * nfpc;
else
nwsz = ncells * nfpc;
insz = sibhfs.size();
sibhfs.resize( insz + nwsz, 0 );
else
nwsz = nverts;
insz = v2hf.size();
v2hf.resize( insz + nwsz, 0 );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::set_incident_map | ( | EntityType | type, |
| std::vector< EntityHandle > & | set_entid, | ||
| std::vector< int > & | set_lid | ||
Definition at line 3607 of file HalfFacetRep.cpp.
References create_halffacet(), moab::ID_FROM_HANDLE(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, v2he, v2hes, v2hf, v2hfs, and v2hv.
Referenced by moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
v2hv[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
if( set_entid.size() == 1 )
v2he[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
else
HFacet hf = 0;
for( int i = 0; i < (int)set_entid.size(); i++ )
hf = create_halffacet( set_entid[i], set_lid[i] );
v2hes.insert( std::pair< EntityHandle, HFacet >( vid, hf ) );
else
v2hf[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
else
HFacet hf = v2hf[ID_FROM_HANDLE( vid ) - 1];
if( hf != 0 )
v2hf[ID_FROM_HANDLE( vid ) - 1] = 0;
v2hfs.insert( std::pair< EntityHandle, HFacet >( vid, hf ) );
return MB_SUCCESS;
| ErrorCode moab::HalfFacetRep::set_sibling_map | ( | EntityType | type, |
| EntityHandle * | set_entids, | ||
| int * | set_lids, | ||
Definition at line 3462 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), create_halffacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
if( num_halffacets != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfvertices" );
sibhvs[2 * eidx + i] = create_halffacet( set_entids[i], set_lids[i] );
for( int i = 0; i < nepf; i++ )
sibhes[nepf * fidx + i] = create_halffacet( set_entids[i], set_lids[i] );
else
for( int i = 0; i < nfpc; i++ )
sibhfs[nfpc * cidx + i] = create_halffacet( set_entids[i], set_lids[i] );
return MB_SUCCESS;
| int | lid, | ||
| EntityHandle & | set_entid, | ||
| int & | set_lid | ||
Definition at line 3506 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), create_halffacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
sibhvs[2 * eidx + lid] = create_halffacet( set_entid, set_lid );
sibhes[nepf * fidx + lid] = create_halffacet( set_entid, set_lid );
else
sibhfs[nfpc * cidx + lid] = create_halffacet( set_entid, set_lid );
return MB_SUCCESS;
Definition at line 3661 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, moab::error(), ErrorCode, moab::Core::get_entities_by_dimension(), mb, MB_CHK_ERR, and MB_SUCCESS.
ErrorCode error;
error = mb->get_entities_by_dimension( fileset, 0, _verts, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( fileset, 1, _edges, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( fileset, 2, _faces, true );MB_CHK_ERR( error );
error = mb->get_entities_by_dimension( fileset, 3, _cells, true );MB_CHK_ERR( error );
return MB_SUCCESS;
Range moab::HalfFacetRep::_cells [protected] |
Definition at line 558 of file HalfFacetRep.hpp.
Referenced by find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_entity_ranges(), get_half_facet_in_comp(), get_sibling_map(), get_up_adjacencies_edg_3d(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_3d(), init_volume(), initialize(), print_tags(), resize_hf_maps(), set_sibling_map(), and update_entity_ranges().
Range moab::HalfFacetRep::_edges [protected] |
Referenced by get_entity_ranges(), init_curve(), initialize(), print_tags(), resize_hf_maps(), and update_entity_ranges().
Range moab::HalfFacetRep::_faces [protected] |
Referenced by collect_and_compare(), find_matching_halfedge(), get_entity_ranges(), get_up_adjacencies_vert_2d(), init_surface(), initialize(), print_tags(), resize_hf_maps(), and update_entity_ranges().
bool moab::HalfFacetRep::_filterghost [protected] |
Definition at line 555 of file HalfFacetRep.hpp.
EntityHandle moab::HalfFacetRep::_rset [protected] |
Definition at line 554 of file HalfFacetRep.hpp.
Referenced by check_mixed_entity_type(), get_rset(), and initialize().
Range moab::HalfFacetRep::_verts [protected] |
Referenced by determine_sibling_halfedges(), determine_sibling_halffaces(), get_entity_ranges(), init_curve(), init_surface(), init_volume(), initialize(), print_tags(), resize_hf_maps(), and update_entity_ranges().
const HalfFacetRep::adj_matrix moab::HalfFacetRep::adjMatrix [static, protected] |
{ { { 0, 1, 0, 0 }, { 1, 1, 0, 0 }, { 0, 0, 0, 0 }, { 0, 0, 0, 0 } } },
{ { { 0, 0, 1, 0 }, { 0, 0, 0, 0 }, { 1, 0, 1, 0 }, { 0, 0, 0, 0 } } },
{ { { 0, 1, 1, 0 }, { 1, 1, 1, 0 }, { 1, 1, 1, 0 }, { 0, 0, 0, 0 } } },
{ { { 0, 0, 0, 1 }, { 0, 0, 0, 0 }, { 0, 0, 0, 0 }, { 1, 0, 0, 1 } } },
{ { { 0, 1, 0, 1 }, { 1, 1, 0, 1 }, { 0, 0, 0, 0 }, { 1, 1, 0, 1 } } },
{ { { 0, 0, 1, 1 }, { 0, 0, 0, 0 }, { 1, 0, 1, 1 }, { 1, 0, 1, 1 } } },
{ { { 0, 1, 1, 1 }, { 1, 1, 1, 1 }, { 1, 1, 1, 1 }, { 1, 1, 1, 1 } } } }
Definition at line 578 of file HalfFacetRep.hpp.
Referenced by get_adjacencies().
| std::map< EntityType, int > moab::HalfFacetRep::cell_index |
Definition at line 538 of file HalfFacetRep.hpp.
Referenced by get_index_in_lmap(), and init_volume().
EntityHandle moab::HalfFacetRep::cellq[MAXSIZE] [protected] |
Definition at line 569 of file HalfFacetRep.hpp.
Referenced by find_matching_implicit_edge_in_cell(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_vert_3d(), and init_volume().
bool moab::HalfFacetRep::chk_mixed [protected] |
Definition at line 583 of file HalfFacetRep.hpp.
Referenced by check_mixed_entity_type(), and HalfFacetRep().
bool moab::HalfFacetRep::is_mixed [protected] |
Definition at line 582 of file HalfFacetRep.hpp.
const HalfFacetRep::LocalMaps2D moab::HalfFacetRep::lConnMap2D [static] |
{ 3, { 1, 2, 0 }, { 2, 0, 1 } },
{ 4, { 1, 2, 3, 0 }, { 3, 0, 1, 2 } } }
Definition at line 503 of file HalfFacetRep.hpp.
Referenced by another_halfedge(), collect_and_compare(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::create_hm_storage_single_level(), determine_incident_halfedges(), determine_sibling_halfedges(), determine_sibling_halffaces(), find_matching_halfface(), find_total_edges_2d(), moab::NestedRefine::get_connectivity(), get_down_adjacencies_2d(), get_face_edges(), get_neighbor_adjacencies_2d(), get_sibling_map(), get_up_adjacencies_2d(), init_surface(), moab::NestedRefine::is_face_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), mark_halfedges(), print_tags(), resize_hf_maps(), set_sibling_map(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), and moab::NestedRefine::update_local_ahf().
const HalfFacetRep::LocalMaps3D moab::HalfFacetRep::lConnMap3D [static] |
Definition at line 535 of file HalfFacetRep.hpp.
Core* moab::HalfFacetRep::mb [protected] |
Definition at line 552 of file HalfFacetRep.hpp.
Referenced by add_cells_of_single_component(), another_halfedge(), check_mixed_entity_type(), collect_and_compare(), determine_border_vertices(), determine_incident_halfedges(), determine_incident_halffaces(), determine_incident_halfverts(), determine_sibling_halfedges(), determine_sibling_halffaces(), determine_sibling_halfverts(), fid_from_halfacet(), find_matching_halfedge(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), find_total_edges_2d(), get_adjacencies(), get_down_adjacencies(), get_down_adjacencies_2d(), get_down_adjacencies_edg_3d(), get_down_adjacencies_face_3d(), get_face_edges(), get_half_facet_in_comp(), get_index_in_lmap(), get_neighbor_adjacencies(), get_neighbor_adjacencies_2d(), get_neighbor_adjacencies_3d(), get_up_adjacencies(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), init_surface(), initialize(), mark_halfedges(), print_tags(), resize_hf_maps(), and update_entity_ranges().
bool moab::HalfFacetRep::mInitAHFmaps [protected] |
Definition at line 556 of file HalfFacetRep.hpp.
Referenced by get_adjacencies(), HalfFacetRep(), and initialize().
ParallelComm* moab::HalfFacetRep::pcomm [protected] |
Definition at line 553 of file HalfFacetRep.hpp.
EntityHandle moab::HalfFacetRep::queue_fid[MAXSIZE] [protected] |
Referenced by collect_and_compare(), find_matching_halfedge(), gather_halfedges(), get_up_adjacencies_2d(), get_up_adjacencies_vert_2d(), init_surface(), and mark_halfedges().
int moab::HalfFacetRep::queue_lid[MAXSIZE] [protected] |
Definition at line 571 of file HalfFacetRep.hpp.
std::vector< HFacet > moab::HalfFacetRep::sibhes [protected] |
Definition at line 562 of file HalfFacetRep.hpp.
Referenced by determine_sibling_halfedges(), get_memory_use(), get_sibling_map(), get_up_adjacencies_2d(), init_surface(), mark_halfedges(), print_tags(), resize_hf_maps(), and set_sibling_map().
std::vector< HFacet > moab::HalfFacetRep::sibhfs [protected] |
Definition at line 563 of file HalfFacetRep.hpp.
Referenced by add_cells_of_single_component(), determine_border_vertices(), determine_sibling_halffaces(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_half_facet_in_comp(), get_memory_use(), get_neighbor_adjacencies_3d(), get_sibling_map(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_3d(), init_volume(), print_tags(), resize_hf_maps(), and set_sibling_map().
std::vector< HFacet > moab::HalfFacetRep::sibhvs [protected] |
Definition at line 561 of file HalfFacetRep.hpp.
Referenced by determine_sibling_halfverts(), get_memory_use(), get_neighbor_adjacencies_1d(), get_sibling_map(), get_up_adjacencies_1d(), init_curve(), print_tags(), resize_hf_maps(), and set_sibling_map().
EntityHandle moab::HalfFacetRep::Stkcells[MAXSIZE] [protected] |
Referenced by add_cells_of_single_component(), find_matching_halfface(), and init_volume().
Definition at line 536 of file HalfFacetRep.hpp.
Referenced by moab::NestedRefine::construct_hm_entities(), moab::NestedRefine::create_hm_storage_single_level(), get_adjacencies(), and initialize().
EntityHandle moab::HalfFacetRep::trackcells[MAXSIZE] [protected] |
Definition at line 570 of file HalfFacetRep.hpp.
EntityHandle moab::HalfFacetRep::trackfaces[MAXSIZE] [protected] |
std::vector< HFacet > moab::HalfFacetRep::v2he [protected] |
Referenced by check_nonmanifold_vertices(), determine_incident_halfedges(), find_matching_halfedge(), get_incident_map(), get_memory_use(), get_up_adjacencies_vert_2d(), init_surface(), print_tags(), resize_hf_maps(), and set_incident_map().
std::multimap< EntityHandle, HFacet > moab::HalfFacetRep::v2hes [protected] |
Definition at line 566 of file HalfFacetRep.hpp.
Referenced by check_nonmanifold_vertices(), determine_incident_halfedges(), get_incident_map(), get_up_adjacencies_vert_2d(), and set_incident_map().
std::vector< HFacet > moab::HalfFacetRep::v2hf [protected] |
Referenced by check_nonmanifold_vertices(), determine_incident_halffaces(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_incident_map(), get_memory_use(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_vert_3d(), init_volume(), print_tags(), resize_hf_maps(), and set_incident_map().
std::multimap< EntityHandle, HFacet > moab::HalfFacetRep::v2hfs [protected] |
Referenced by check_nonmanifold_vertices(), determine_incident_halffaces(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_incident_map(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_vert_3d(), print_tags(), and set_incident_map().
std::vector< HFacet > moab::HalfFacetRep::v2hv [protected] |
Referenced by determine_incident_halfverts(), get_incident_map(), get_memory_use(), get_up_adjacencies_1d(), init_curve(), print_tags(), resize_hf_maps(), and set_incident_map().
