Mesh Oriented datABase
(version 5.4.1)
Read SMF (Simple Model Format) files. More...
#include <ReadSmf.hpp>
Inheritance diagram for moab::ReadSmf:
Collaboration diagram for moab::ReadSmf:Classes | |
| struct | cmd_entry |
Public Types | |
| typedef ErrorCode(ReadSmf::* | read_cmd )(std::vector< std::string > &argv) |
Public Member Functions | |
| ErrorCode | load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) |
| load a file | |
| ErrorCode | read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) |
| Read tag values from a file. | |
| ReadSmf (Interface *impl=NULL) | |
| Constructor. | |
| virtual | ~ReadSmf () |
| Destructor. | |
| void | init () |
Static Public Member Functions | |
| static ReaderIface * | factory (Interface *) |
Protected Member Functions | |
| ErrorCode | annotation (char *cmd, std::vector< std::string > &argv) |
| void | bad_annotation (const char *cmd) |
| ErrorCode | vertex (std::vector< std::string > &) |
| ErrorCode | v_normal (std::vector< std::string > &) |
| ErrorCode | v_color (std::vector< std::string > &) |
| ErrorCode | f_color (std::vector< std::string > &) |
| ErrorCode | face (std::vector< std::string > &) |
| ErrorCode | begin (std::vector< std::string > &) |
| ErrorCode | end (std::vector< std::string > &) |
| ErrorCode | set (std::vector< std::string > &) |
| ErrorCode | inc (std::vector< std::string > &) |
| ErrorCode | dec (std::vector< std::string > &) |
| ErrorCode | trans (std::vector< std::string > &) |
| ErrorCode | scale (std::vector< std::string > &) |
| ErrorCode | rot (std::vector< std::string > &) |
| ErrorCode | mmult (std::vector< std::string > &) |
| ErrorCode | mload (std::vector< std::string > &) |
| ErrorCode | parse_line (char *line) |
| ErrorCode | parse_doubles (int count, const std::vector< std::string > &argv, double results[]) |
| ErrorCode | parse_mat (const std::vector< std::string > &argv, AffineXform &mat_out) |
| ErrorCode | check_length (int count, const std::vector< std::string > &argv) |
Private Attributes | |
| ReadUtilIface * | readMeshIface |
| Interface * | mdbImpl |
| interface instance interface instance | |
| EntityHandle | mCurrentMeshHandle |
| Meshset Handle for the mesh that is currently being read. | |
| std::string | mPartitionTagName |
| A field which, if present and having a single integer for storage, should be used to partition the mesh by range. Defaults to MATERIAL_SET_TAG_NAME. | |
| char | line [SMF_MAXLINE] |
| std::vector< SMF_State > | state |
| SMF_ivars | ivar |
| int | _numNodes |
| int | _numFaces |
| std::vector< double > | _coords |
| std::vector< int > | _connec |
| int | _numNodesInFile |
| int | _numElementsInFile |
| size_t | lineNo |
| size_t | commandNo |
| int | versionMajor |
| int | versionMinor |
Static Private Attributes | |
| static cmd_entry | read_cmds [] |
File format is documented at: http://people.sc.fsu.edu/~burkardt/data/smf/smf.txt
Definition at line 39 of file ReadSmf.hpp.
| typedef ErrorCode( ReadSmf::* moab::ReadSmf::read_cmd)(std::vector< std::string > &argv) |
Definition at line 64 of file ReadSmf.hpp.
| ReadSmf::ReadSmf | ( | Interface * | impl = NULL | ) |
Constructor.
Definition at line 87 of file ReadSmf.cpp.
References _numElementsInFile, _numFaces, _numNodes, _numNodesInFile, ivar, mdbImpl, moab::SMF_ivars::next_face, moab::SMF_ivars::next_vertex, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
: mdbImpl( impl ), mCurrentMeshHandle( 0 ), lineNo( 0 ), commandNo( 0 ), versionMajor( 0 ), versionMinor( 0 ) { mdbImpl->query_interface( readMeshIface ); ivar.next_vertex = 0; ivar.next_face = 0; _numNodes = _numFaces = 0; _numNodesInFile = _numElementsInFile = 0; }
| ReadSmf::~ReadSmf | ( | ) | [virtual] |
Destructor.
Definition at line 97 of file ReadSmf.cpp.
References mdbImpl, readMeshIface, and moab::Interface::release_interface().
if( readMeshIface )
mdbImpl->release_interface( readMeshIface );
readMeshIface = 0;
| ErrorCode ReadSmf::annotation | ( | char * | cmd, |
| std::vector< std::string > & | argv | ||
| ) | [protected] |
Definition at line 208 of file ReadSmf.cpp.
References _numFaces, _numNodes, bad_annotation(), commandNo, lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, streq(), versionMajor, and versionMinor.
Referenced by parse_line().
// Skip over the '#$' prefix
cmd += 2;
if( streq( cmd, "SMF" ) )
// If SMF version is specified, it must be the first
// thing specified in the file.
if( commandNo > 1 )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "SMF file version specified at line " << lineNo );
if( 2 == sscanf( argv[0].c_str(), "%d.%d", &versionMajor, &versionMinor ) )
if( versionMajor != 1 || versionMinor != 0 )
"Unsupported SMF file version: " << versionMajor << "." << versionMinor );
else
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Invalid SMF version annotation" );
else if( streq( cmd, "vertices" ) )
if( argv.size() == 1 )
_numNodes = atoi( argv[0].c_str() );
else
bad_annotation( cmd );
else if( streq( cmd, "faces" ) )
_numFaces = atoi( argv[0].c_str() );
else
else if( streq( cmd, "BBox" ) )
else if( streq( cmd, "BSphere" ) )
else if( streq( cmd, "PXform" ) )
if( argv.size() == 16 )
// parse_mat(argv);
else
else if( streq( cmd, "MXform" ) )
// parse_mat(argv);
else
return MB_SUCCESS;
| void ReadSmf::bad_annotation | ( | const char * | cmd | ) | [protected] |
Definition at line 77 of file ReadSmf.cpp.
Referenced by annotation().
std::cerr << "SMF: Malformed annotation [" << cmd << "]" << std::endl;
| ErrorCode ReadSmf::begin | ( | std::vector< std::string > & | ) | [protected] |
Definition at line 424 of file ReadSmf.cpp.
References ivar, MB_SUCCESS, and state.
state.push_back( SMF_State( ivar, &state.back() ) );
return MB_SUCCESS;
| ErrorCode ReadSmf::check_length | ( | int | count, |
| const std::vector< std::string > & | argv | ||
| ) | [protected] |
Definition at line 341 of file ReadSmf.cpp.
References lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, and MB_SUCCESS.
Referenced by face(), parse_doubles(), and rot().
if( ( argv.size() < (unsigned)count ) || ( argv.size() > (unsigned)count && argv[count][0] != '#' ) )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Expect " << count << " arguments at line " << lineNo );
return MB_SUCCESS;
| ErrorCode ReadSmf::dec | ( | std::vector< std::string > & | ) | [protected] |
Definition at line 468 of file ReadSmf.cpp.
References MB_SUCCESS.
// std::cerr << "SMF: DEC not yet implemented." << std::endl;
return MB_SUCCESS;
| ErrorCode ReadSmf::end | ( | std::vector< std::string > & | ) | [protected] |
Definition at line 431 of file ReadSmf.cpp.
References lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, and state.
// There must always be at least one state on the stack.
// Don't let mismatched begin/end statements cause us
// to read from an empty vector.
if( state.size() == 1 )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "End w/out Begin at line " << lineNo );
state.pop_back();
return MB_SUCCESS;
| ErrorCode ReadSmf::f_color | ( | std::vector< std::string > & | ) | [protected] |
| ErrorCode ReadSmf::face | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 399 of file ReadSmf.cpp.
References _connec, _numElementsInFile, check_length(), ErrorCode, ivar, lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, moab::SMF_ivars::next_face, and state.
ErrorCode err = check_length( 3, argv );
if( MB_SUCCESS != err ) return err;
int vert[3] = {};
char* endptr;
for( unsigned int i = 0; i < argv.size(); i++ )
vert[i] = strtol( argv[i].c_str(), &endptr, 0 );
if( *endptr )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Invalid face spec at line " << lineNo );
state.back().face( vert, ivar );
ivar.next_face++;
for( int j = 0; j < 3; j++ )
_connec.push_back( vert[j] );
_numElementsInFile++;
return MB_SUCCESS;
| ReaderIface * ReadSmf::factory | ( | Interface * | iface | ) | [static] |
Definition at line 82 of file ReadSmf.cpp.
References ReadSmf().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| ErrorCode ReadSmf::inc | ( | std::vector< std::string > & | ) | [protected] |
Definition at line 462 of file ReadSmf.cpp.
// std::cerr << "SMF: INC not yet implemented." << std::endl;
return MB_SUCCESS;
| void moab::ReadSmf::init | ( | ) |
| ErrorCode ReadSmf::load_file | ( | const char * | file_name, |
| const EntityHandle * | file_set, | ||
| const FileOptions & | opts, | ||
| const SubsetList * | subset_list = 0, |
| const Tag * | file_id_tag = 0 |
| ) | [virtual] |
load a file
Implements moab::ReaderIface.
Definition at line 115 of file ReadSmf.cpp.
References _connec, _coords, _numElementsInFile, _numNodesInFile, moab::ReadUtilIface::assign_ids(), commandNo, ErrorCode, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::FileOptions::get_option(), ivar, line, lineNo, MB_FILE_DOES_NOT_EXIST, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_START_ID, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, MBTRI, mPartitionTagName, moab::SMF_ivars::next_face, moab::SMF_ivars::next_vertex, parse_line(), readMeshIface, SMF_MAXLINE, state, moab::ReadUtilIface::update_adjacencies(), versionMajor, and versionMinor.
ErrorCode result;
lineNo = 0;
commandNo = 0;
versionMajor = 0;
versionMinor = 0;
if( subset_list )
MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for VTK" );
// Does the caller want a field to be used for partitioning the entities?
// If not, we'll assume any scalar integer field named MATERIAL_SET specifies partitions.
std::string partition_tag_name;
result = opts.get_option( "PARTITION", partition_tag_name );
if( result == MB_SUCCESS ) mPartitionTagName = partition_tag_name;
std::ifstream smfFile( filename );
if( !smfFile ) return MB_FILE_DOES_NOT_EXIST;
ivar.next_face = 1;
ivar.next_vertex = 1;
state.push_back( SMF_State( ivar ) );
while( smfFile.getline( line, SMF_MAXLINE, '\n' ).good() )
++lineNo;
result = parse_line( line );
if( MB_SUCCESS != result ) return result;
if( !smfFile.eof() )
// Parsing terminated for a reason other than EOF: signal failure.
return MB_FILE_WRITE_ERROR;
// At this point we have _numNodesInFile vertices and _numElementsInFile triangles
// the coordinates are in _coords, and connectivities in _connec
// std::vector<double> _coords; // 3*numNodes; we might not know the number of nodes
// std::vector<int> _connec; // 3*num of elements; we might not know them;
// Create vertices
std::vector< double* > arrays;
EntityHandle start_handle_out;
start_handle_out = 0;
result = readMeshIface->get_node_coords( 3, _numNodesInFile, MB_START_ID, start_handle_out, arrays );
// Fill the arrays with data from _coords
// Cppcheck warning (false positive): variable arrays is assigned a value that is never used
for( int i = 0; i < _numNodesInFile; i++ )
int i3 = 3 * i;
arrays[0][i] = _coords[i3];
arrays[1][i] = _coords[i3 + 1];
arrays[2][i] = _coords[i3 + 2];
// Elements
EntityHandle start_handle_elem_out;
start_handle_elem_out = 0;
EntityHandle* conn_array_out;
result = readMeshIface->get_element_connect( _numElementsInFile, 3,
MBTRI, // EntityType
MB_START_ID, start_handle_elem_out, conn_array_out );
for( int j = 0; j < _numElementsInFile * 3; j++ )
conn_array_out[j] = _connec[j];
// Notify MOAB of the new elements
result = readMeshIface->update_adjacencies( start_handle_elem_out, _numElementsInFile, 3, conn_array_out );
if( file_id_tag )
Range nodes( start_handle_out, start_handle_out + _numNodesInFile - 1 );
Range elems( start_handle_elem_out, start_handle_elem_out + _numElementsInFile - 1 );
readMeshIface->assign_ids( *file_id_tag, nodes );
readMeshIface->assign_ids( *file_id_tag, elems );
return MB_SUCCESS;
| ErrorCode ReadSmf::mload | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 549 of file ReadSmf.cpp.
References ErrorCode, MB_SUCCESS, parse_mat(), and state.
AffineXform mat;
ErrorCode rval = parse_mat( argv, mat );
if( MB_SUCCESS != rval ) return rval;
state.back().mload( mat );
return MB_SUCCESS;
| ErrorCode ReadSmf::mmult | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 538 of file ReadSmf.cpp.
AffineXform mat;
state.back().mmult( mat );
return MB_SUCCESS;
| ErrorCode ReadSmf::parse_doubles | ( | int | count, |
| const std::vector< std::string > & | argv, | ||
| double | results[] | ||
| ) | [protected] |
Definition at line 351 of file ReadSmf.cpp.
References check_length(), ErrorCode, lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, and MB_SUCCESS.
Referenced by parse_mat(), rot(), scale(), trans(), and vertex().
ErrorCode rval = check_length( count, argv );
char* endptr;
for( int i = 0; i < count; i++ )
results[i] = strtod( argv[i].c_str(), &endptr );
if( *endptr )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Invalid vertex coordinates at line " << lineNo );
return MB_SUCCESS;
| ErrorCode ReadSmf::parse_line | ( | char * | line | ) | [protected] |
Definition at line 277 of file ReadSmf.cpp.
References annotation(), moab::ReadSmf::cmd_entry::cmd, commandNo, ErrorCode, lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, moab::ReadSmf::cmd_entry::name, read_cmds, streq(), and versionMajor.
Referenced by load_file().
char *cmd, *s;
std::vector< std::string > argv;
ErrorCode err;
while( *ln == ' ' || *ln == '\t' )
ln++; // Skip initial white space
// Ignore empty lines
if( ln[0] == '\n' || ln[0] == '\0' ) return MB_SUCCESS;
// Ignore comments
if( ln[0] == '#' && ln[1] != '$' ) return MB_SUCCESS;
// First, split the line into tokens
cmd = strtok( ln, " \t\n" );
while( ( s = strtok( NULL, " \t\n" ) ) )
std::string stg( s );
argv.push_back( stg );
// Figure out what command it is and execute it
if( cmd[0] == '#' && cmd[1] == '$' )
err = annotation( cmd, argv );
else
cmd_entry* entry = &read_cmds[0];
bool handled = false;
while( entry->name && !handled )
if( streq( entry->name, cmd ) )
err = ( this->*( entry->cmd ) )( argv );
handled = true;
++commandNo;
else
entry++;
if( !handled )
// If the first command was invalid, this probably
// wasn't an Smf file. Fail silently in this case.
// If versionMajor is set, then we saw an initial #$SMF,
// in which case it must be a SMF file.
if( !versionMajor && !commandNo ) return MB_FILE_WRITE_ERROR;
// Invalid command:
MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Illegal SMF command at line " << lineNo << ": \"" << cmd << "\"" );
return MB_SUCCESS;
| ErrorCode ReadSmf::parse_mat | ( | const std::vector< std::string > & | argv, |
| AffineXform & | mat_out | ||
| ) | [protected] |
Definition at line 67 of file ReadSmf.cpp.
References ErrorCode, MB_SUCCESS, and parse_doubles().
Referenced by mload(), and mmult().
double values[12];
ErrorCode err = parse_doubles( 12, argv, values );
mat = AffineXform( values, values + 9 );
return MB_SUCCESS;
| ErrorCode ReadSmf::read_tag_values | ( | const char * | file_name, |
| const char * | tag_name, | ||
| std::vector< int > & | tag_values_out, | ||
| const SubsetList * | subset_list = 0 |
| ) | [virtual] |
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
| file_name | The file to read. |
| tag_name | The tag for which to read values |
| tag_values_out | Output: The list of tag values. |
| subset_list | An array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read. |
| subset_list_length | The length of the 'subset_list' array. |
Definition at line 106 of file ReadSmf.cpp.
References MB_NOT_IMPLEMENTED.
return MB_NOT_IMPLEMENTED;
| ErrorCode ReadSmf::rot | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 500 of file ReadSmf.cpp.
References moab::angle(), check_length(), ErrorCode, lineNo, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, parse_doubles(), moab::AffineXform::rotation(), and state.
ErrorCode err = check_length( 2, argv );
double axis[3] = { 0., 0., 0. };
std::string axisname = argv.front();
argv.erase( argv.begin() );
if( axisname.size() != 1 )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Malformed rotation command at line " << lineNo );
switch( axisname[0] )
case 'x':
axis[0] = 1.;
break;
case 'y':
axis[1] = 1.;
break;
case 'z':
axis[2] = 1.;
break;
default:
double angle;
err = parse_doubles( 1, argv, &angle );
angle *= M_PI / 180.0;
AffineXform M = AffineXform::rotation( angle, axis );
state.back().mmult( M );
return MB_SUCCESS;
| ErrorCode ReadSmf::scale | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 487 of file ReadSmf.cpp.
References ErrorCode, MB_SUCCESS, parse_doubles(), and state.
double v3[3];
ErrorCode err = parse_doubles( 3, argv, v3 );
AffineXform M = AffineXform::scale( v3 );
// Mat4 M = Mat4::scale(atof(argv(0)), atof(argv(1)), atof(argv(2)));
return MB_SUCCESS;
| ErrorCode ReadSmf::set | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 446 of file ReadSmf.cpp.
if( argv.size() < 2 || argv[0] != "vertex_coorection" ) return MB_SUCCESS;
char* endptr;
int val = strtol( argv[1].c_str(), &endptr, 0 );
if( *endptr )
MB_SET_ERR( MB_FILE_WRITE_ERROR, "Invalid value at line " << lineNo );
state.back().set_vertex_correction( val );
return MB_SUCCESS;
| ErrorCode ReadSmf::trans | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 474 of file ReadSmf.cpp.
References ErrorCode, MB_SUCCESS, parse_doubles(), state, and moab::AffineXform::translation().
double v3[3];
AffineXform M = AffineXform::translation( v3 );
// Mat4 M = Mat4::trans(atof(argv(0)), atof(argv(1)), atof(argv(2)));
return MB_SUCCESS;
| ErrorCode ReadSmf::v_color | ( | std::vector< std::string > & | ) | [protected] |
| ErrorCode ReadSmf::v_normal | ( | std::vector< std::string > & | ) | [protected] |
| ErrorCode ReadSmf::vertex | ( | std::vector< std::string > & | argv | ) | [protected] |
Definition at line 369 of file ReadSmf.cpp.
References _coords, _numNodesInFile, ErrorCode, ivar, MB_SUCCESS, moab::SMF_ivars::next_vertex, parse_doubles(), and state.
double v[3];
ErrorCode err = parse_doubles( 3, argv, v );
state.back().vertex( v );
ivar.next_vertex++;
_numNodesInFile++;
_coords.push_back( v[j] );
// model->in_Vertex(v);
return MB_SUCCESS;
std::vector< int > moab::ReadSmf::_connec [private] |
Definition at line 124 of file ReadSmf.hpp.
Referenced by face(), and load_file().
std::vector< double > moab::ReadSmf::_coords [private] |
Definition at line 123 of file ReadSmf.hpp.
Referenced by load_file(), and vertex().
int moab::ReadSmf::_numElementsInFile [private] |
Definition at line 126 of file ReadSmf.hpp.
Referenced by face(), load_file(), and ReadSmf().
int moab::ReadSmf::_numFaces [private] |
Definition at line 122 of file ReadSmf.hpp.
Referenced by annotation(), and ReadSmf().
int moab::ReadSmf::_numNodes [private] |
Definition at line 121 of file ReadSmf.hpp.
int moab::ReadSmf::_numNodesInFile [private] |
Definition at line 125 of file ReadSmf.hpp.
Referenced by load_file(), ReadSmf(), and vertex().
size_t moab::ReadSmf::commandNo [private] |
Definition at line 128 of file ReadSmf.hpp.
Referenced by annotation(), load_file(), and parse_line().
SMF_ivars moab::ReadSmf::ivar [private] |
Definition at line 120 of file ReadSmf.hpp.
Referenced by begin(), face(), load_file(), ReadSmf(), and vertex().
char moab::ReadSmf::line[SMF_MAXLINE] [private] |
Definition at line 118 of file ReadSmf.hpp.
size_t moab::ReadSmf::lineNo [private] |
Definition at line 127 of file ReadSmf.hpp.
Referenced by annotation(), check_length(), end(), face(), load_file(), parse_doubles(), parse_line(), rot(), and set().
Definition at line 110 of file ReadSmf.hpp.
Interface* moab::ReadSmf::mdbImpl [private] |
Definition at line 107 of file ReadSmf.hpp.
Referenced by ReadSmf(), and ~ReadSmf().
std::string moab::ReadSmf::mPartitionTagName [private] |
Definition at line 114 of file ReadSmf.hpp.
ReadSmf::cmd_entry ReadSmf::read_cmds [static, private] |
{ { "v", &ReadSmf::vertex },
{ ":vn", &ReadSmf::v_normal },
{ ":vc", &ReadSmf::v_color },
{ ":fc", &ReadSmf::f_color },
{ "t", &ReadSmf::face },
{ "f", &ReadSmf::face },
{ "begin", &ReadSmf::begin },
{ "end", &ReadSmf::end },
{ "set", &ReadSmf::set },
{ "inc", &ReadSmf::inc },
{ "dec", &ReadSmf::dec },
{ "mmult", &ReadSmf::mload },
{ "mload", &ReadSmf::mmult },
{ "trans", &ReadSmf::trans },
{ "scale", &ReadSmf::scale },
{ "rot", &ReadSmf::rot },
{ NULL, NULL } }
Definition at line 117 of file ReadSmf.hpp.
ReadUtilIface* moab::ReadSmf::readMeshIface [private] |
Definition at line 101 of file ReadSmf.hpp.
Referenced by load_file(), ReadSmf(), and ~ReadSmf().
std::vector< SMF_State > moab::ReadSmf::state [private] |
int moab::ReadSmf::versionMajor [private] |
Definition at line 129 of file ReadSmf.hpp.
int moab::ReadSmf::versionMinor [private] |
Referenced by annotation(), and load_file().
