Mesh Oriented datABase
(version 5.4.1)
#include <ReadIDEAS.hpp>
Inheritance diagram for moab::ReadIDEAS:
Collaboration diagram for moab::ReadIDEAS:Public Member Functions | |
| ErrorCode | load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) |
| Load mesh from a file. | |
| ErrorCode | read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) |
| Read tag values from a file. | |
| ReadIDEAS (Interface *impl=NULL) | |
| Constructor. | |
| virtual | ~ReadIDEAS () |
| Destructor. | |
Static Public Member Functions | |
| static ReaderIface * | factory (Interface *) |
Protected Member Functions | |
| ErrorCode | skip_header () |
| ErrorCode | create_vertices (EntityHandle &first_vertex, const Tag *file_id_tag) |
| ErrorCode | create_elements (EntityHandle first_vertex, const Tag *file_id_tag) |
Private Attributes | |
| std::ifstream | file |
| RangeMap< int, EntityHandle > | nodeIdMap |
| ReadUtilIface * | readMeshIface |
| Interface * | MBI |
Static Private Attributes | |
| static const unsigned | SINGLE_PRECISION_NODES = 15 |
| static const unsigned | DOUBLE_PRECISION_NODES0 = 781 |
| static const unsigned | DOUBLE_PRECISION_NODES1 = 2411 |
| static const unsigned | ELEMENTS0 = 71 |
| static const unsigned | ELEMENTS1 = 780 |
| static const unsigned | ELEMENTS2 = 2412 |
| static const int | ROD0 = 11 |
| static const int | ROD1 = 171 |
| static const int | TRI0 = 41 |
| static const int | TRI1 = 91 |
| static const int | QUAD0 = 44 |
| static const int | QUAD1 = 94 |
| static const int | TET = 111 |
| static const int | WEDGE = 112 |
| static const int | HEX = 115 |
Definition at line 24 of file ReadIDEAS.hpp.
| moab::ReadIDEAS::ReadIDEAS | ( | Interface * | impl = NULL | ) |
Constructor.
Definition at line 25 of file ReadIDEAS.cpp.
References moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
: MBI( impl ) { impl->query_interface( readMeshIface ); }
| virtual moab::ReadIDEAS::~ReadIDEAS | ( | ) | [inline, virtual] |
| ErrorCode moab::ReadIDEAS::create_elements | ( | EntityHandle | first_vertex, |
| const Tag * | file_id_tag | ||
| ) | [protected] |
Definition at line 209 of file ReadIDEAS.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Range::empty(), ErrorCode, file, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), HEX, MAT_PROP_TABLE_TAG, moab::CN::MAX_NODES_PER_ELEMENT, MB_ALREADY_ALLOCATED, MB_CHK_SET_ERR, MB_MULTIPLE_ENTITIES_FOUND, MB_NOT_IMPLEMENTED, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBENTITYSET, MBHEX, MBI, MBPRISM, MBQUAD, MBTET, MBTRI, MESHSET_SET, PHYS_PROP_TABLE_TAG, QUAD0, QUAD1, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TET, TRI0, TRI1, moab::CN::VerticesPerEntity(), and WEDGE.
Referenced by load_file().
char line1[10000], line2[10000];
int il1, il2;
char *ctmp1, *ctmp2;
std::string s1, s2;
ErrorCode rval;
EntityHandle handle;
Tag mat_tag, phys_tag, id_tag;
rval = MBI->tag_get_handle( MAT_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, mat_tag, MB_TAG_DENSE | MB_TAG_CREAT );
if( MB_SUCCESS != rval && MB_ALREADY_ALLOCATED != rval ) return rval;
rval = MBI->tag_get_handle( PHYS_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, phys_tag, MB_TAG_DENSE | MB_TAG_CREAT );
id_tag = MBI->globalId_tag();
for( ;; )
if( !file.getline( line1, 10000 ) || !file.getline( line2, 10000 ) ) return MB_FAILURE;
// Check if we are at the end of the block
il1 = std::strtol( line1, &ctmp1, 10 );
il2 = std::strtol( line2, &ctmp2, 10 );
if( ( il1 == -1 ) && ( il2 == -1 ) )
s1 = ctmp1;
s2 = ctmp2;
if( ( s1.empty() ) && ( s2.empty() ) ) return MB_SUCCESS;
// The first line describes attributes of the element other than connectivity.
const int element_id = strtol( line1 + 1, &ctmp1, 10 );
const int ideas_type = strtol( line1 + 11, &ctmp1, 10 );
const int phys_table = strtol( line1 + 21, &ctmp1, 10 );
const int mat_table = strtol( line1 + 31, &ctmp1, 10 );
// Determine the element type.
EntityType mb_type;
if( TRI0 == ideas_type || TRI1 == ideas_type )
mb_type = MBTRI;
else if( QUAD0 == ideas_type || QUAD1 == ideas_type )
mb_type = MBQUAD;
else if( TET == ideas_type )
mb_type = MBTET;
else if( HEX == ideas_type )
mb_type = MBHEX;
else if( WEDGE == ideas_type )
mb_type = MBPRISM;
else
std::cout << "IDEAS element type not yet added to MOAB reader." << std::endl;
return MB_NOT_IMPLEMENTED;
// Get the connectivity out of the 2nd line
std::stringstream ss( line2 );
const int n_conn = CN::VerticesPerEntity( mb_type );
EntityHandle conn[CN::MAX_NODES_PER_ELEMENT];
EntityHandle vert;
for( int i = 0; i < n_conn; ++i )
ss >> vert;
conn[i] = vstart + vert - 1;
// Make the element. According to the Gmsh 2.2.3 source code, the IDEAS
// canonical numbering is the same as MBCN.
rval = MBI->create_element( mb_type, conn, n_conn, handle );MB_CHK_SET_ERR( rval, "can't create elements of type " << mb_type );
// If the phys set does not already exist, create it.
Range phys_sets;
EntityHandle phys_set;
const void* const phys_set_id_val[] = { &phys_table };
rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &phys_tag, phys_set_id_val, 1, phys_sets );MB_CHK_SET_ERR( rval, "can't get phys sets" );
if( phys_sets.empty() )
rval = MBI->create_meshset( MESHSET_SET, phys_set );MB_CHK_SET_ERR( rval, "can't create phys set" );
rval = MBI->tag_set_data( phys_tag, &phys_set, 1, &phys_table );MB_CHK_SET_ERR( rval, "can't set tag to phys set" );
else if( 1 == phys_sets.size() )
phys_set = phys_sets.front();
else
return MB_MULTIPLE_ENTITIES_FOUND;
rval = MBI->add_entities( phys_set, &handle, 1 );MB_CHK_SET_ERR( rval, "can't add entities to phys set" );
// If the material set does not already exist, create it.
Range mat_sets;
EntityHandle mat_set;
const void* const mat_set_id_val[] = { &mat_table };
rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, mat_set_id_val, 1, mat_sets );
if( MB_SUCCESS != rval ) return rval;
if( mat_sets.empty() )
rval = MBI->create_meshset( MESHSET_SET, mat_set );
rval = MBI->tag_set_data( mat_tag, &mat_set, 1, &mat_table );
else if( 1 == mat_sets.size() )
mat_set = mat_sets.front();
else
rval = MBI->add_entities( mat_set, &handle, 1 );
// Tag the element with its id
rval = MBI->tag_set_data( id_tag, &handle, 1, &element_id );MB_CHK_SET_ERR( rval, "Failed to assign IDs" );
if( file_id_tag )
rval = MBI->tag_set_data( *file_id_tag, &handle, 1, &element_id );MB_CHK_SET_ERR( rval, "Failed to assign file IDs" );
return MB_SUCCESS;
| ErrorCode moab::ReadIDEAS::create_vertices | ( | EntityHandle & | first_vertex, |
| ) | [protected] |
Definition at line 129 of file ReadIDEAS.cpp.
References moab::ReadUtilIface::assign_ids(), ErrorCode, file, moab::ReadUtilIface::get_node_coords(), moab::Interface::globalId_tag(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBI, and readMeshIface.
// Read two lines: first has some data, second has coordinates
int il1, il2;
std::string s1, s2;
ErrorCode rval;
std::streampos top_of_block = file.tellg();
unsigned int num_verts = 0;
for( ;; )
// Read both lines
if( !file.getline( line1, 10000 ) ) return MB_FAILURE;
if( !file.getline( line2, 10000 ) ) return MB_FAILURE;
s1 = ctmp1;
s2 = ctmp2;
if( ( s1.empty() ) && ( s2.empty() ) ) break;
num_verts++;
file.seekg( top_of_block );
std::vector< double* > arrays;
rval = readMeshIface->get_node_coords( 3, num_verts, 0, first_vertex, arrays );
Range verts;
verts.insert( first_vertex, first_vertex + num_verts - 1 );
double* x = arrays[0];
double* y = arrays[1];
double* z = arrays[2];
// For now, assume ids are sequential and begin with 1
Tag id_tag = MBI->globalId_tag();
const int beginning_node_id = 1;
int node_id = beginning_node_id;
for( unsigned int i = 0; i < num_verts; i++ )
// Get the id out of the 1st line. Check the assumption that node ids are
// sequential and begin with 1.
if( node_id != std::strtol( line1, &ctmp1, 10 ) )
MB_SET_ERR( MB_FAILURE, "node_id " << node_id << " line2:" << line2 << " ctmp1:" << ctmp1 );
else
++node_id;
// Get the doubles out of the 2nd line
x[i] = std::strtod( line2, &ctmp2 );
y[i] = std::strtod( ctmp2 + 1, &ctmp2 );
z[i] = std::strtod( ctmp2 + 1, NULL );
if( !file.getline( line1, 10000 ) ) MB_SET_ERR( MB_FAILURE, " expect more lines" );
if( !file.getline( line2, 10000 ) ) MB_SET_ERR( MB_FAILURE, " expect more lines 2" );
// Tag the nodes with ids
rval = readMeshIface->assign_ids( id_tag, verts, beginning_node_id );MB_CHK_SET_ERR( rval, "Failed to assign IDs" );
if( file_id_tag )
rval = readMeshIface->assign_ids( *file_id_tag, verts, beginning_node_id );MB_CHK_SET_ERR( rval, "Failed to assign file IDs" );
return MB_SUCCESS;
| ReaderIface * moab::ReadIDEAS::factory | ( | Interface * | iface | ) | [static] |
Definition at line 20 of file ReadIDEAS.cpp.
References ReadIDEAS().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| ErrorCode moab::ReadIDEAS::load_file | ( | const char * | file_name, |
| const EntityHandle * | file_set, | ||
| const FileOptions & | opts, | ||
| const SubsetList * | subset_list = 0, |
| const Tag * | file_id_tag = 0 |
| ) | [virtual] |
Method all readers must provide to import a mesh.
| file_name | The file to read. |
| file_set | Optional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data. |
| subset_list | An optional struct pointer specifying the tags identifying entity sets to be read. |
| file_id_tag | If specified, reader should store for each entity it reads, a unique integer ID for this tag. |
Implements moab::ReaderIface.
Definition at line 39 of file ReadIDEAS.cpp.
References create_elements(), create_vertices(), DOUBLE_PRECISION_NODES0, DOUBLE_PRECISION_NODES1, ELEMENTS0, ELEMENTS1, ELEMENTS2, ErrorCode, file, MB_CHK_SET_ERR, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, and skip_header().
if( subset_list )
MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for IDEAS" );
file.open( fname );
if( !file.good() )
MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, "Failed to open file: " << fname );
ErrorCode rval;
char line[10000];
file.getline( line, 10000 );
char* liter = line;
while( *liter && isspace( *liter ) )
++liter;
if( *liter != '-' ) return MB_FAILURE;
++liter;
if( *liter != '1' ) return MB_FAILURE;
while( *++liter )
if( !isspace( *liter ) ) return MB_FAILURE;
EntityHandle first_vertex = 0;
while( !file.eof() )
unsigned int header_id = (unsigned int)strtol( line, NULL, 10 );
// Create vertices
if( DOUBLE_PRECISION_NODES0 == header_id || DOUBLE_PRECISION_NODES1 == header_id )
if( first_vertex ) // multiple vertex blocks?
return MB_FAILURE;
rval = create_vertices( first_vertex, file_id_tag );MB_CHK_SET_ERR( rval, "Failed to read vertices" );
// Create elements
else if( ELEMENTS0 == header_id || ELEMENTS1 == header_id || ELEMENTS2 == header_id )
if( !first_vertex ) // Need to read vertices first
return MB_FAILURE;
rval = create_elements( first_vertex, file_id_tag );MB_CHK_SET_ERR( rval, "Failed to read elements" );
// Skip everything else
else
rval = skip_header();
if( MB_SUCCESS != rval ) return MB_FAILURE;
file.close();
return MB_SUCCESS;
| ErrorCode moab::ReadIDEAS::read_tag_values | ( | const char * | file_name, |
| const char * | tag_name, | ||
| std::vector< int > & | tag_values_out, | ||
| const SubsetList * | subset_list = 0 |
| ) | [virtual] |
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
| tag_name | The tag for which to read values |
| tag_values_out | Output: The list of tag values. |
| subset_list | An array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read. |
| subset_list_length | The length of the 'subset_list' array. |
Definition at line 30 of file ReadIDEAS.cpp.
References MB_NOT_IMPLEMENTED.
| ErrorCode moab::ReadIDEAS::skip_header | ( | ) | [protected] |
Definition at line 101 of file ReadIDEAS.cpp.
References file, and MB_SUCCESS.
// Go until finding a pair of -1 lines
char* ctmp;
char line[10000];
std::string s;
int end_of_block = 0;
long int il;
while( file.getline( line, 10000 ) )
il = std::strtol( line, &ctmp, 10 );
if( il == -1 )
s = ctmp;
if( s.empty() ) end_of_block++;
else
end_of_block = 0;
if( end_of_block >= 2 ) return MB_SUCCESS;
return MB_SUCCESS;
const unsigned moab::ReadIDEAS::DOUBLE_PRECISION_NODES0 = 781 [static, private] |
Definition at line 82 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::DOUBLE_PRECISION_NODES1 = 2411 [static, private] |
Definition at line 83 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS0 = 71 [static, private] |
Definition at line 91 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS1 = 780 [static, private] |
Definition at line 92 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS2 = 2412 [static, private] |
Definition at line 93 of file ReadIDEAS.hpp.
std::ifstream moab::ReadIDEAS::file [private] |
Definition at line 54 of file ReadIDEAS.hpp.
Referenced by create_elements(), create_vertices(), load_file(), and skip_header().
const int moab::ReadIDEAS::HEX = 115 [static, private] |
Definition at line 107 of file ReadIDEAS.hpp.
Referenced by create_elements().
Interface* moab::ReadIDEAS::MBI [private] |
Definition at line 61 of file ReadIDEAS.hpp.
Referenced by create_elements(), and create_vertices().
RangeMap< int, EntityHandle > moab::ReadIDEAS::nodeIdMap [private] |
Definition at line 55 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::QUAD0 = 44 [static, private] |
Definition at line 103 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::QUAD1 = 94 [static, private] |
Definition at line 104 of file ReadIDEAS.hpp.
ReadUtilIface* moab::ReadIDEAS::readMeshIface [private] |
Definition at line 58 of file ReadIDEAS.hpp.
Referenced by create_vertices(), and ReadIDEAS().
const int moab::ReadIDEAS::ROD0 = 11 [static, private] |
Definition at line 99 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::ROD1 = 171 [static, private] |
Definition at line 100 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::SINGLE_PRECISION_NODES = 15 [static, private] |
Definition at line 76 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TET = 111 [static, private] |
Definition at line 105 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TRI0 = 41 [static, private] |
Definition at line 101 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TRI1 = 91 [static, private] |
Definition at line 102 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::WEDGE = 112 [static, private] |
Definition at line 106 of file ReadIDEAS.hpp.
