Mesh Oriented datABase
(version 5.4.1)
Export NC files. More...
#include <WriteNC.hpp>
Inheritance diagram for moab::WriteNC:
Collaboration diagram for moab::WriteNC:Classes | |
| class | AttData |
| class | VarData |
Public Member Functions | |
| WriteNC (Interface *impl=NULL) | |
| Constructor. | |
| virtual | ~WriteNC () |
| Destructor. | |
| ErrorCode | write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3) |
| Writes out a file. | |
Static Public Member Functions | |
| static WriterIface * | factory (Interface *) |
| Factory method. | |
Private Types | |
| enum | EntityLocation { ENTLOCVERT = 0, ENTLOCNSEDGE, ENTLOCEWEDGE, ENTLOCFACE, ENTLOCSET, ENTLOCEDGE, ENTLOCREGION } |
| ENTLOCNSEDGE for north/south edge ENTLOCWEEDGE for west/east edge. More... | |
Private Member Functions | |
| ErrorCode | parse_options (const FileOptions &opts, std::vector< std::string > &var_names, std::vector< std::string > &desired_names, std::vector< int > &tstep_nums, std::vector< double > &tstep_vals) |
| ErrorCode | process_conventional_tags (EntityHandle fileSet) |
| ErrorCode | process_concatenated_attribute (const void *attPtr, int attSz, std::vector< int > &attLen, std::map< std::string, AttData > &attributes) |
Private Attributes | |
| std::vector< std::string > | dimNames |
| This info will be reconstructed from metadata stored on conventional fileSet tags Dimension names. | |
| std::vector< int > | dimLens |
| Dimension lengths. | |
| std::set< std::string > | usedCoordinates |
| Will collect used dimensions (coordinate variables) | |
| std::set< std::string > | dummyVarNames |
| Dummy variables (for dimensions that have no corresponding coordinate variables) | |
| std::map< std::string, AttData > | globalAtts |
| Global attribs. | |
| std::map< std::string, VarData > | varInfo |
| Variable info. | |
| Interface * | mbImpl |
| Interface instance. | |
| WriteUtilIface * | mWriteIface |
| const char * | fileName |
| File var. | |
| int | fileId |
| File numbers assigned by (p)netcdf. | |
| DebugOutput | dbgOut |
| Debug stuff. | |
| bool | noMesh |
| Write options. | |
| bool | noVars |
| bool | append |
| Tag | mGlobalIdTag |
| Cached tags for writing. This will be important for ordering the data, in parallel. | |
| bool | isParallel |
| Are we writing in parallel? (probably in the future) | |
| std::string | grid_type |
| CAM Euler, etc,. | |
| NCWriteHelper * | myHelper |
| Helper class instance. | |
Friends | |
| class | NCWriteHelper |
| class | ScdNCWriteHelper |
| class | UcdNCWriteHelper |
| class | NCWriteEuler |
| class | NCWriteFV |
| class | NCWriteHOMME |
| class | NCWriteMPAS |
| class | NCWriteGCRM |
Export NC files.
Definition at line 70 of file WriteNC.hpp.
enum moab::WriteNC::EntityLocation [private] |
Definition at line 105 of file WriteNC.hpp.
ENTLOCVERT = 0,
ENTLOCNSEDGE,
ENTLOCEWEDGE,
ENTLOCFACE,
ENTLOCSET,
ENTLOCEDGE,
ENTLOCREGION
| moab::WriteNC::WriteNC | ( | Interface * | impl = NULL | ) |
Constructor.
Definition at line 32 of file WriteNC.cpp.
References mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
: mbImpl( impl ), dbgOut( stderr ), #ifdef MOAB_HAVE_MPI myPcomm( NULL ), #endif noMesh( false ), noVars( false ), append( false ), mGlobalIdTag( 0 ), isParallel( false ), myHelper( NULL ) { assert( impl != NULL ); impl->query_interface( mWriteIface ); }
| moab::WriteNC::~WriteNC | ( | ) | [virtual] |
Destructor.
Definition at line 43 of file WriteNC.cpp.
References mbImpl, mWriteIface, myHelper, and moab::Interface::release_interface().
mbImpl->release_interface( mWriteIface );
if( myHelper != NULL ) delete myHelper;
| WriterIface * moab::WriteNC::factory | ( | Interface * | iface | ) | [static] |
Factory method.
Definition at line 27 of file WriteNC.cpp.
References WriteNC().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| ErrorCode moab::WriteNC::parse_options | ( | const FileOptions & | opts, |
| std::vector< std::string > & | var_names, | ||
| std::vector< std::string > & | desired_names, | ||
| std::vector< int > & | tstep_nums, | ||
| std::vector< double > & | tstep_vals | ||
| ) | [private] |
Definition at line 140 of file WriteNC.cpp.
References append, dbgOut, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::ParallelComm::get_pcomm(), moab::FileOptions::get_reals_option(), moab::FileOptions::get_strs_option(), moab::DebugOutput::get_verbosity(), isParallel, moab::FileOptions::match_option(), MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MB_UNSUPPORTED_OPERATION, mbImpl, noMesh, noVars, moab::DebugOutput::set_prefix(), moab::DebugOutput::set_rank(), and moab::DebugOutput::set_verbosity().
Referenced by write_file().
int tmpval;
if( MB_SUCCESS == opts.get_int_option( "DEBUG_IO", 1, tmpval ) )
dbgOut.set_verbosity( tmpval );
dbgOut.set_prefix( "NCWrite" );
ErrorCode rval = opts.get_strs_option( "VARIABLE", var_names );
if( MB_TYPE_OUT_OF_RANGE == rval )
noVars = true;
else
noVars = false;
rval = opts.get_strs_option( "RENAME", desired_names );
if( MB_ENTITY_NOT_FOUND == rval )
if( !noVars )
desired_names.resize( var_names.size() );
std::copy( var_names.begin(), var_names.end(), desired_names.begin() );
// Either way
assert( desired_names.size() == var_names.size() );
opts.get_ints_option( "TIMESTEP", tstep_nums );
opts.get_reals_option( "TIMEVAL", tstep_vals );
rval = opts.get_null_option( "NOMESH" );
if( MB_SUCCESS == rval ) noMesh = true;
rval = opts.get_null_option( "APPEND" );
if( MB_SUCCESS == rval ) append = true;
if( 2 <= dbgOut.get_verbosity() )
if( !var_names.empty() )
std::cerr << "Variables requested: ";
for( unsigned int i = 0; i < var_names.size(); i++ )
std::cerr << var_names[i];
std::cerr << std::endl;
if( !tstep_nums.empty() )
std::cerr << "Timesteps requested: ";
for( unsigned int i = 0; i < tstep_nums.size(); i++ )
std::cerr << tstep_nums[i];
if( !tstep_vals.empty() )
std::cerr << "Time vals requested: ";
for( unsigned int i = 0; i < tstep_vals.size(); i++ )
std::cerr << tstep_vals[i];
// FIXME: copied from ReadNC, may need revise
isParallel = ( opts.match_option( "PARALLEL", "WRITE_PART" ) != MB_ENTITY_NOT_FOUND );
if( !isParallel )
// Return success here, since rval still has _NOT_FOUND from not finding option
// in this case, myPcomm will be NULL, so it can never be used; always check for isParallel
// before any use for myPcomm
return MB_SUCCESS;
int pcomm_no = 0;
rval = opts.get_int_option( "PARALLEL_COMM", pcomm_no );
MB_SET_ERR( rval, "Invalid value for PARALLEL_COMM option" );
myPcomm = ParallelComm::get_pcomm( mbImpl, pcomm_no );
if( 0 == myPcomm )
myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
#ifndef MOAB_HAVE_PNETCDF
const int procs = myPcomm->proc_config().proc_size();
if( procs > 1 )
MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Attempt to launch NC writer in parallel without pnetcdf support" );
#endif
const int rank = myPcomm->proc_config().proc_rank();
dbgOut.set_rank( rank );
#endif
return MB_SUCCESS;
| ErrorCode moab::WriteNC::process_concatenated_attribute | ( | const void * | attPtr, |
| int | attSz, | ||
| std::vector< int > & | attLen, | ||
| std::map< std::string, AttData > & | attributes | ||
| ) | [private] |
Definition at line 455 of file WriteNC.cpp.
References moab::WriteNC::AttData::attDataType, moab::WriteNC::AttData::attLen, moab::WriteNC::AttData::attValue, dbgOut, MB_SET_ERR, MB_SUCCESS, and moab::DebugOutput::tprintf().
Referenced by process_conventional_tags().
std::size_t start = 0;
std::size_t att_counter = 0;
std::string concatString( (char*)attPtr, (char*)attPtr + attSz );
for( std::size_t i = 0; i != (size_t)attSz; i++ )
if( concatString[i] == '\0' )
std::string att_name( &concatString[start], i - start );
start = i + 1;
while( concatString[i] != ';' )
++i;
std::string data_type( &concatString[start], i - start );
++i;
start = i;
i = attLen[att_counter];
if( concatString[i] != ';' ) MB_SET_ERR( MB_FAILURE, "Error parsing attributes" );
std::string data_val( &concatString[start], i - start );
start = i + 1;
AttData& attrib = attributes[att_name];
attrib.attValue = data_val;
attrib.attLen = data_val.size();
if( data_type == "char" )
attrib.attDataType = NC_CHAR;
else if( data_type == "double" )
attrib.attDataType = NC_DOUBLE;
else if( data_type == "float" )
attrib.attDataType = NC_FLOAT;
else if( data_type == "int" )
attrib.attDataType = NC_INT;
else if( data_type == "short" )
attrib.attDataType = NC_SHORT;
++att_counter;
dbgOut.tprintf( 2, " Process attribute %s with value %s \n", att_name.c_str(), data_val.c_str() );
return MB_SUCCESS;
| ErrorCode moab::WriteNC::process_conventional_tags | ( | EntityHandle | fileSet | ) | [private] |
Definition at line 244 of file WriteNC.cpp.
References dbgOut, dimLens, dimNames, dummyVarNames, moab::WriteNC::VarData::entLoc, ErrorCode, globalAtts, grid_type, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, moab::WriteNC::VarData::numAtts, process_concatenated_attribute(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::DebugOutput::tprintf(), moab::WriteNC::VarData::varAtts, moab::WriteNC::VarData::varDims, varInfo, and moab::WriteNC::VarData::varName.
ErrorCode rval;
// Start copy
Tag dimNamesTag = 0;
std::string tag_name = "__DIM_NAMES";
const void* data = NULL;
int dimNamesSz = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, dimNamesTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
rval = mbImpl->tag_get_by_ptr( dimNamesTag, &fileSet, 1, &data, &dimNamesSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
const char* p = static_cast< const char* >( data );
dbgOut.tprintf( 1, "__DIM_NAMES tag has string length %d\n", dimNamesSz );
Tag dimLensTag = 0;
tag_name = "__DIM_LENS";
data = NULL;
int dimLensSz = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, dimLensTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
rval = mbImpl->tag_get_by_ptr( dimLensTag, &fileSet, 1, &data, &dimLensSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
const int* int_p = static_cast< const int* >( data );
dbgOut.tprintf( 1, "__DIM_LENS tag has %d values\n", dimLensSz );
int idxDim = 0;
// Dim names are separated by '\0' in the string of __DIM_NAMES tag
for( std::size_t i = 0; i != static_cast< std::size_t >( dimNamesSz ); i++ )
if( p[i] == '\0' )
std::string dim_name( &p[start], i - start );
int len = int_p[idxDim];
dimNames.push_back( dim_name );
dimLens.push_back( len );
dbgOut.tprintf( 2, "Dimension %s has length %d\n", dim_name.c_str(), len );
// FIXME: Need info from moab to set unlimited dimension
// Currently assume each file has the same number of time dimensions
/*if ((dim_name == "time") || (dim_name == "Time"))
insert(dim_name, *(new pcdim(dim_name, len * m_file_names.size(), true)));
else
insert(dim_name, *(new pcdim(dim_name, len)));*/
start = i + 1;
idxDim++;
Tag meshTypeTag = 0;
tag_name = "__MESH_TYPE";
data = NULL;
int meshTypeSz = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
rval = mbImpl->tag_get_by_ptr( meshTypeTag, &fileSet, 1, &data, &meshTypeSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
grid_type = std::string( &p[0], meshTypeSz );
dbgOut.tprintf( 2, "Mesh type: %s\n", grid_type.c_str() );
// Read <__VAR_NAMES_LOCATIONS> tag
Tag varNamesLocsTag = 0;
tag_name = "__VAR_NAMES_LOCATIONS";
data = NULL;
int varNamesLocsSz = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, varNamesLocsTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
rval = mbImpl->tag_get_by_ptr( varNamesLocsTag, &fileSet, 1, &data, &varNamesLocsSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
std::vector< int > varNamesLocs( varNamesLocsSz );
std::copy( int_p, int_p + varNamesLocsSz, varNamesLocs.begin() );
Tag varNamesTag = 0;
tag_name = "__VAR_NAMES";
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varNamesTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
data = NULL;
int varNamesSz = 0;
rval = mbImpl->tag_get_by_ptr( varNamesTag, &fileSet, 1, &data, &varNamesSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
dbgOut.tprintf( 2, "__VAR_NAMES tag has string length %d\n", varNamesSz );
start = 0;
int idxVar = 0;
int sz;
// Var names are separated by '\0' in the string of __VAR_NAMES tag
for( std::size_t i = 0; i != static_cast< std::size_t >( varNamesSz ); i++ )
if( p[i] == '\0' )
std::string var_name( &p[start], i - start );
dbgOut.tprintf( 2, "var name: %s index %d \n", var_name.c_str(), idxVar );
// Process var name:
// This will create/initiate map; we will populate variableDataStruct with info about
// dims, tags, etc reference & is important; otherwise variableDataStruct will go out of
// scope, and deleted :(
VarData& variableDataStruct = varInfo[var_name];
variableDataStruct.varName = var_name;
variableDataStruct.entLoc = varNamesLocs[idxVar];
dbgOut.tprintf( 2, "at var name %s varInfo size %d \n", var_name.c_str(), (int)varInfo.size() );
sz = 0;
Tag dims_tag = 0;
std::string dim_names = "__" + var_name + "_DIMS";
rval = mbImpl->tag_get_handle( dim_names.c_str(), 0, MB_TYPE_OPAQUE, dims_tag, MB_TAG_ANY );
if( MB_SUCCESS != rval )
if( MB_TAG_NOT_FOUND == rval )
dbgOut.tprintf( 2, "tag : %s not found, continue \n", dim_names.c_str() );
start = i + 1;
idxVar++;
continue;
MB_SET_ERR( rval, "Trouble getting conventional tag " << dim_names );
rval = mbImpl->tag_get_length( dims_tag, sz );MB_CHK_SET_ERR( rval, "Trouble getting size of dimensions for variable " << var_name );
sz /= sizeof( Tag ); // The type is MB_TYPE_OPAQUE, but it is a list of tags, so we
// need to divide by the size of Tag
// sz is used for number of dimension tags in this list
dbgOut.tprintf( 2, "var name: %s has %d dimensions \n", var_name.c_str(), sz );
variableDataStruct.varDims.resize( sz );
const void* ptr = NULL;
rval = mbImpl->tag_get_by_ptr( dims_tag, &fileSet, 1, &ptr );
const Tag* ptags = static_cast< const moab::Tag* >( ptr );
for( std::size_t j = 0; j != static_cast< std::size_t >( sz ); j++ )
std::string dim_name;
rval = mbImpl->tag_get_name( ptags[j], dim_name );MB_CHK_SET_ERR( rval, "Trouble getting dimension of variable " << var_name );
dbgOut.tprintf( 2, "var name: %s has %s as dimension \n", var_name.c_str(), dim_name.c_str() );
std::vector< std::string >::iterator vit = std::find( dimNames.begin(), dimNames.end(), dim_name );
if( vit == dimNames.end() )
MB_SET_ERR( MB_FAILURE, "Dimension " << dim_name << " not found for variable " << var_name );
variableDataStruct.varDims[j] = (int)( vit - dimNames.begin() ); // Will be used for writing
// This will have to change to actual file dimension, for writing
// Attributes for this variable
std::stringstream ssTagName;
ssTagName << "__" << var_name << "_ATTRIBS";
tag_name = ssTagName.str();
Tag varAttTag = 0;
rval =
mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
const void* varAttPtr = NULL;
int varAttSz = 0;
rval = mbImpl->tag_get_by_ptr( varAttTag, &fileSet, 1, &varAttPtr, &varAttSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag retrieved for variable %s\n", tag_name.c_str() );
std::string attribString( (char*)varAttPtr, (char*)varAttPtr + varAttSz );
if( attribString == "NO_ATTRIBS" )
// This variable has no attributes
variableDataStruct.numAtts = 0;
else if( attribString == "DUMMY_VAR" )
// This variable is a dummy coordinate variable
dummyVarNames.insert( variableDataStruct.varName );
else
ssTagName << "_LEN";
Tag varAttLenTag = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, varAttLenTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
int varAttLenSz = 0;
rval = mbImpl->tag_get_length( varAttLenTag, varAttLenSz );MB_CHK_SET_ERR( rval, "Trouble getting length of conventional tag " << tag_name );
std::vector< int > varAttLen( varAttLenSz );
rval = mbImpl->tag_get_data( varAttLenTag, &fileSet, 1, &varAttLen[0] );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
rval = process_concatenated_attribute( varAttPtr, varAttSz, varAttLen, variableDataStruct.varAtts );MB_CHK_SET_ERR( rval, "Trouble processing attributes of variable " << var_name );
if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag metadata for variable %s\n", tag_name.c_str() );
// End attribute
start = i + 1;
idxVar++;
} // if (p[i] == '\0')
// Global attributes
tag_name = "__GLOBAL_ATTRIBS";
Tag globalAttTag = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
std::vector< int > gattLen;
const void* gattptr = NULL;
int globalAttSz = 0;
rval = mbImpl->tag_get_by_ptr( globalAttTag, &fileSet, 1, &gattptr, &globalAttSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag value retrieved for %s size %d\n", tag_name.c_str(), globalAttSz );
// <__GLOBAL_ATTRIBS_LEN>
tag_name = "__GLOBAL_ATTRIBS_LEN";
Tag globalAttLenTag = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, globalAttLenTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
int sizeGAtt = 0;
rval = mbImpl->tag_get_length( globalAttLenTag, sizeGAtt );MB_CHK_SET_ERR( rval, "Trouble getting length of conventional tag " << tag_name );
gattLen.resize( sizeGAtt );
rval = mbImpl->tag_get_data( globalAttLenTag, &fileSet, 1, &gattLen[0] );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
rval = process_concatenated_attribute( gattptr, globalAttSz, gattLen, globalAtts );MB_CHK_SET_ERR( rval, "Trouble processing global attributes" );
return MB_SUCCESS;
| ErrorCode moab::WriteNC::write_file | ( | const char * | file_name, |
| const bool | overwrite, | ||
| const FileOptions & | opts, | ||
| const EntityHandle * | output_list, | ||
| const int | num_sets, | ||
| const std::vector< std::string > & | qa_list, | ||
| const Tag * | tag_list = NULL, |
| int | num_tags = 0, |
| int | export_dimension = 3 |
| ) | [virtual] |
Writes out a file.
Implements moab::WriterIface.
Definition at line 50 of file WriteNC.cpp.
References append, moab::NCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), dbgOut, ErrorCode, fileId, fileName, moab::NCWriteHelper::get_nc_helper(), moab::Interface::globalId_tag(), moab::NCWriteHelper::init_file(), isParallel, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, mGlobalIdTag, myHelper, NCFUNC, parse_options(), process_conventional_tags(), moab::DebugOutput::tprintf(), and moab::NCWriteHelper::write_values().
ErrorCode rval;
// See if opts has variable(s) specified
std::vector< std::string > var_names;
std::vector< std::string > desired_names;
std::vector< int > tstep_nums;
std::vector< double > tstep_vals;
// Get and cache predefined tag handles
mGlobalIdTag = mbImpl->globalId_tag();
// num set has to be 1, we will write only one set, the original file set used to load
if( num_set != 1 ) MB_SET_ERR( MB_FAILURE, "We should write only one set (the file set used to read data into)" );
rval = parse_options( options, var_names, desired_names, tstep_nums, tstep_vals );MB_CHK_SET_ERR( rval, "Trouble parsing option string" );
// Important to create some data that will be used to write the file; dimensions, variables, etc
// new variables still need to have some way of defining their dimensions
// maybe it will be passed as write options
rval = process_conventional_tags( *file_set );MB_CHK_SET_ERR( rval, "Trouble processing conventional tags" );
// Create or append the file
if( append )
dbgOut.tprintf( 1, "opening file %s for appending \n", file_name );
else
dbgOut.tprintf( 1, "creating file %s\n", file_name );
fileName = file_name;
int success;
if( append )
int omode = NC_WRITE;
#ifdef MOAB_HAVE_PNETCDF
if( isParallel )
success = NCFUNC( open )( myPcomm->proc_config().proc_comm(), file_name, omode, MPI_INFO_NULL, &fileId );
else
success = NCFUNC( open )( MPI_COMM_SELF, file_name, omode, MPI_INFO_NULL, &fileId );
#else
// This is a regular netcdf file, open in write mode
success = NCFUNC( open )( file_name, omode, &fileId );
#endif
if( success ) MB_SET_ERR( MB_FAILURE, "Trouble opening file " << file_name << " for appending" );
else
{ // Case when the file is new, will be overwritten, most likely
int cmode = overwrite ? NC_CLOBBER : NC_NOCLOBBER;
if( isParallel )
success = NCFUNC( create )( myPcomm->proc_config().proc_comm(), file_name, cmode, MPI_INFO_NULL, &fileId );
else
success = NCFUNC( create )( MPI_COMM_SELF, file_name, cmode, MPI_INFO_NULL, &fileId );
#else
success = NCFUNC( create )( file_name, cmode, &fileId );
#endif
if( success ) MB_SET_ERR( MB_FAILURE, "Trouble creating file " << file_name << " for writing" );
if( NULL != myHelper ) delete myHelper;
// Get appropriate helper instance for WriteNC class based on some info in the file set
myHelper = NCWriteHelper::get_nc_helper( this, fileId, options, *file_set );
if( NULL == myHelper )
MB_SET_ERR( MB_FAILURE, "Failed to get NCWriteHelper class instance" );
rval = myHelper->collect_mesh_info();MB_CHK_SET_ERR( rval, "Trouble collecting mesh information" );
rval = myHelper->collect_variable_data( var_names, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble collecting variable data" );
rval = myHelper->init_file( var_names, desired_names, append );MB_CHK_SET_ERR( rval, "Trouble initializing file" );
rval = myHelper->write_values( var_names, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble writing values to file" );
success = NCFUNC( close )( fileId );
if( success ) MB_SET_ERR( MB_FAILURE, "Trouble closing file" );
return MB_SUCCESS;
friend class NCWriteEuler [friend] |
Definition at line 75 of file WriteNC.hpp.
friend class NCWriteFV [friend] |
Definition at line 76 of file WriteNC.hpp.
friend class NCWriteGCRM [friend] |
Definition at line 79 of file WriteNC.hpp.
friend class NCWriteHelper [friend] |
Definition at line 72 of file WriteNC.hpp.
friend class NCWriteHOMME [friend] |
Definition at line 77 of file WriteNC.hpp.
friend class NCWriteMPAS [friend] |
Definition at line 78 of file WriteNC.hpp.
friend class ScdNCWriteHelper [friend] |
Definition at line 73 of file WriteNC.hpp.
friend class UcdNCWriteHelper [friend] |
Definition at line 74 of file WriteNC.hpp.
bool moab::WriteNC::append [private] |
Definition at line 202 of file WriteNC.hpp.
Referenced by parse_options(), and write_file().
DebugOutput moab::WriteNC::dbgOut [private] |
Debug stuff.
Definition at line 193 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), parse_options(), process_concatenated_attribute(), process_conventional_tags(), and write_file().
std::vector< int > moab::WriteNC::dimLens [private] |
Dimension lengths.
Definition at line 152 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::NCWriteHelper::collect_variable_data(), and process_conventional_tags().
std::vector< std::string > moab::WriteNC::dimNames [private] |
Definition at line 149 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteMPAS::collect_variable_data(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), and process_conventional_tags().
std::set< std::string > moab::WriteNC::dummyVarNames [private] |
Definition at line 158 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), process_conventional_tags(), and moab::NCWriteHelper::write_values().
int moab::WriteNC::fileId [private] |
Definition at line 190 of file WriteNC.hpp.
const char* moab::WriteNC::fileName [private] |
std::map< std::string, AttData > moab::WriteNC::globalAtts [private] |
Global attribs.
Definition at line 161 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::init_file(), and process_conventional_tags().
std::string moab::WriteNC::grid_type [private] |
CAM Euler, etc,.
Definition at line 211 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::get_nc_helper(), and process_conventional_tags().
bool moab::WriteNC::isParallel [private] |
Definition at line 208 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), parse_options(), write_file(), and moab::NCWriteHelper::write_set_variables().
Interface* moab::WriteNC::mbImpl [private] |
Interface instance.
Definition at line 183 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), parse_options(), process_conventional_tags(), write_file(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), and ~WriteNC().
Tag moab::WriteNC::mGlobalIdTag [private] |
Definition at line 205 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), and write_file().
WriteUtilIface* moab::WriteNC::mWriteIface [private] |
Definition at line 184 of file WriteNC.hpp.
Referenced by WriteNC(), and ~WriteNC().
NCWriteHelper* moab::WriteNC::myHelper [private] |
Definition at line 214 of file WriteNC.hpp.
Referenced by write_file(), and ~WriteNC().
bool moab::WriteNC::noMesh [private] |
bool moab::WriteNC::noVars [private] |
Definition at line 201 of file WriteNC.hpp.
Referenced by parse_options().
std::set< std::string > moab::WriteNC::usedCoordinates [private] |
Definition at line 155 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), and moab::NCWriteHelper::write_values().
std::map< std::string, VarData > moab::WriteNC::varInfo [private] |
Variable info.
Definition at line 164 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteHOMME::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::NCWriteHelper::collect_variable_data(), moab::ScdNCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), process_conventional_tags(), and moab::NCWriteHelper::write_values().
