Mesh Oriented datABase
(version 5.4.1)
Maintain data structures organizing EntitySequence instances. More...
#include <TypeSequenceManager.hpp>
Collaboration diagram for moab::TypeSequenceManager:Classes | |
| class | DummySequence |
| Dummy EntitySequence for use in querying set container. More... | |
| class | SequenceCompare |
| Comparison function used in std::set. More... | |
| struct | SequenceDataPtr |
Public Types | |
| typedef std::set < EntitySequence *, SequenceCompare < EntitySequence > > | set_type |
| Type of container for organizing EntitySequence instances. | |
| typedef set_type::iterator | iterator |
| Iterator for set_type. | |
| typedef set_type::const_iterator | const_iterator |
| typedef std::set< SequenceData *, SequenceCompare < SequenceData > > | data_set_type |
| Type of container for organizing SequenceData instances. | |
| typedef data_set_type::iterator | data_iterator |
| iterator type for data_set_type | |
Public Member Functions | |
| ErrorCode | insert_sequence (EntitySequence *seq_ptr) |
| Add an entity sequence. | |
| ErrorCode | remove_sequence (const EntitySequence *seq_ptr, bool &is_last_user_of_sequence_data) |
| Remove an entity sequence. | |
| ErrorCode | replace_subsequence (EntitySequence *seq_ptr, const int *tag_sizes, int num_tag_sizes) |
| Replace sequence or subset of sequence. | |
| TypeSequenceManager () | |
| ~TypeSequenceManager () | |
| const_iterator | begin () const |
| Start of EntitySequence set. | |
| iterator | begin () |
| const_iterator | end () const |
| End of EntitySequence set. | |
| iterator | end () |
| const_iterator | lower_bound (EntityHandle h) const |
| Return EntitySequence for specified handle. | |
| iterator | lower_bound (EntityHandle h) |
| const_iterator | upper_bound (EntityHandle h) const |
| Return EntitySequence after specified handle. | |
| EntitySequence * | find (EntityHandle h) const |
| Get EntitySequence for handle. | |
| EntitySequence * | find (EntityHandle h) |
| ErrorCode | find (EntityHandle h, EntitySequence *&) |
| ErrorCode | find (EntityHandle h, const EntitySequence *&) const |
| const EntitySequence * | get_last_accessed () const |
| void | get_entities (Range &entities_out) const |
| Get handles for all entities in all sequences. | |
| void | get_entities (std::vector< EntityHandle > &entities_out) const |
| EntityID | get_number_entities () const |
| Get number of entities represented by all sequences. | |
| ErrorCode | check_valid_handles (Error *error_handler, EntityHandle first, EntityHandle last) const |
| ErrorCode | erase (Error *error_handler, EntityHandle first, EntityHandle last) |
| Remove entities. | |
| ErrorCode | erase (Error *error_handler, EntityHandle entity) |
| bool | empty () const |
| Test if this instance contains no sequences. | |
| iterator | find_free_handle (EntityHandle min_start_handle, EntityHandle max_end_handle, bool &append_out, int values_per_ent=0) |
| Allocate a handle in an existing entity sequence. | |
| EntityHandle | find_free_block (EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle) |
| Find block of free handles. | |
| EntityHandle | find_free_sequence (EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle, SequenceData *&sequence_data_out, EntityID &sequence_data_size, int values_per_ent=0) |
| bool | is_free_sequence (EntityHandle start_handle, EntityID num_entities, SequenceData *&sequence_data_out, int values_per_ent=0) |
| Check if block of handles is free. | |
| ErrorCode | is_free_handle (EntityHandle handle, iterator &seq_ptr_out, SequenceData *&data_ptr_out, EntityHandle &block_start, EntityHandle &block_end, int values_per_ent=0) |
| Check if specific handle is free for allocation. | |
| EntityHandle | last_free_handle (EntityHandle after_this) const |
| ErrorCode | notify_prepended (iterator seq) |
| Notify that sequence was prepended to. | |
| ErrorCode | notify_appended (iterator seq) |
| Notify that sequence was appended to. | |
| void | get_memory_use (unsigned long long &total_entity_storage, unsigned long long &total_storage) const |
| void | get_memory_use (EntityHandle start, EntityHandle end, unsigned long long &total_entity_storage, unsigned long long &total_amortized_storage) const |
| unsigned long | get_sequence_count () const |
| EntityID | get_occupied_size (const SequenceData *) const |
| Get used size of SequenceData. | |
Private Member Functions | |
| iterator | erase (iterator i) |
| Remove a sequence. | |
| iterator | split_sequence (iterator i, EntityHandle h) |
| split a sequence | |
| void | append_memory_use (EntityHandle first, EntityHandle last, const SequenceData *data, unsigned long long &entity_storage, unsigned long long &total_storage) const |
| ErrorCode | check_merge_next (iterator i) |
| ErrorCode | check_merge_prev (iterator i) |
| ErrorCode | merge_internal (iterator keep, iterator dead) |
| bool | check_valid_data (const EntitySequence *seq) const |
Private Attributes | |
| EntitySequence * | lastReferenced |
| Last accessed EntitySequence - Null only if no sequences. | |
| set_type | sequenceSet |
| Set of all managed EntitySequence instances. | |
| data_set_type | availableList |
| SequenceData containing unused entries. | |
EntitySequenceManager is a composition of instances of TypeSequenceManager, one instance for each EntityType. The TypeSequenceManager provides organization, ownership, and querying of EntitySequences for a specific EntityType.
Definition at line 22 of file TypeSequenceManager.hpp.
| typedef set_type::const_iterator moab::TypeSequenceManager::const_iterator |
Definition at line 69 of file TypeSequenceManager.hpp.
| typedef data_set_type::iterator moab::TypeSequenceManager::data_iterator |
Definition at line 73 of file TypeSequenceManager.hpp.
| typedef std::set< SequenceData*, SequenceCompare< SequenceData > > moab::TypeSequenceManager::data_set_type |
Definition at line 71 of file TypeSequenceManager.hpp.
| typedef set_type::iterator moab::TypeSequenceManager::iterator |
Definition at line 67 of file TypeSequenceManager.hpp.
| typedef std::set< EntitySequence*, SequenceCompare< EntitySequence > > moab::TypeSequenceManager::set_type |
Definition at line 65 of file TypeSequenceManager.hpp.
| moab::TypeSequenceManager::TypeSequenceManager | ( | ) | [inline] |
Definition at line 147 of file TypeSequenceManager.hpp.
: lastReferenced( 0 ) {}
Definition at line 10 of file TypeSequenceManager.cpp.
References availableList, begin(), moab::EntitySequence::data(), end(), sequenceSet, and moab::EntitySequence::using_entire_data().
// We assume that for there to be multiple sequences referencing
// the same SequenceData, there must be some portion of the
// SequenceData that is unused. Otherwise the sequences should
// have been merged. Given that assumption, it is the case that
// either a) a SequenceData is in availableList or b) the
// SequenceData is referenced by exactly one sequence.
// Delete every entity sequence
for( iterator i = begin(); i != end(); ++i )
EntitySequence* seq = *i;
// Check for case b) above
if( seq->using_entire_data() )
// Delete sequence before data, because sequence
// has a pointer to data and may try to dereference
// that pointer during its destruction.
SequenceData* data = seq->data();
delete seq;
delete data;
else
delete seq;
sequenceSet.clear();
// Case a) above
for( data_iterator i = availableList.begin(); i != availableList.end(); ++i )
delete *i;
availableList.clear();
| void moab::TypeSequenceManager::append_memory_use | ( | EntityHandle | first, |
| EntityHandle | last, | ||
| const SequenceData * | data, | ||
| unsigned long long & | entity_storage, | ||
| unsigned long long & | total_storage | ||
| ) | const [private] |
Definition at line 852 of file TypeSequenceManager.cpp.
References end(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, moab::SequenceData::seqManData, moab::SequenceData::size(), and moab::sum().
Referenced by get_memory_use().
const unsigned long allocated_count = data->size();
unsigned long bytes_per_ent, seq_size;
const_iterator i = data->seqManData.firstSequence;
( *i )->get_const_memory_use( bytes_per_ent, seq_size );
unsigned long other_ent_mem = 0;
unsigned long occupied_count = 0, entity_count = 0, sequence_count = 0;
for( ; i != end() && ( *i )->data() == data; ++i )
occupied_count += ( *i )->size();
++sequence_count;
EntityHandle start = std::max( first, ( *i )->start_handle() );
EntityHandle stop = std::min( last, ( *i )->end_handle() );
if( stop < start ) continue;
entity_count += stop - start + 1;
other_ent_mem += ( *i )->get_per_entity_memory_use( start, stop );
unsigned long sum = sequence_count * seq_size + allocated_count * bytes_per_ent;
// Watch for overflow
assert( entity_count > 0 && occupied_count > 0 && allocated_count > 0 );
if( std::numeric_limits< unsigned long >::max() / entity_count <= sum )
total_storage += sum * ( entity_count / occupied_count ) + other_ent_mem;
entity_storage += sum * ( entity_count / allocated_count ) + other_ent_mem;
else
total_storage += sum * entity_count / occupied_count + other_ent_mem;
entity_storage += sum * entity_count / allocated_count + other_ent_mem;
| const_iterator moab::TypeSequenceManager::begin | ( | ) | const [inline] |
Definition at line 152 of file TypeSequenceManager.hpp.
References sequenceSet.
Referenced by check_merge_prev(), check_valid_data(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), find_free_sequence(), moab::WriteUtil::get_element_connect(), moab::ReorderTool::get_entities(), get_entities(), moab::AEntityFactory::get_memory_use(), moab::DenseTag::get_memory_use(), moab::VarLenDenseTag::get_memory_use(), moab::WriteUtil::get_node_coords(), get_number_entities(), moab::get_tagged(), moab::DenseTag::get_tagged_entities(), moab::ReorderTool::handle_order_from_int_tag(), insert_sequence(), is_free_handle(), is_free_sequence(), moab::operator<<(), moab::Core::print_database(), moab::SequenceManager::release_tag_array(), moab::ReorderTool::reorder_entities(), moab::AEntityFactory::~AEntityFactory(), and ~TypeSequenceManager().
return sequenceSet.begin();
| iterator moab::TypeSequenceManager::begin | ( | ) | [inline] |
Definition at line 156 of file TypeSequenceManager.hpp.
| ErrorCode moab::TypeSequenceManager::check_merge_next | ( | iterator | i | ) | [private] |
Definition at line 67 of file TypeSequenceManager.cpp.
References end(), MB_SUCCESS, and merge_internal().
Referenced by insert_sequence(), and notify_appended().
iterator j = i;
++j;
if( j == end() || ( *j )->data() != ( *i )->data() || ( *j )->start_handle() > ( *i )->end_handle() + 1 )
return MB_SUCCESS;
assert( ( *i )->end_handle() + 1 == ( *j )->start_handle() );
return merge_internal( i, j );
| ErrorCode moab::TypeSequenceManager::check_merge_prev | ( | iterator | i | ) | [private] |
Definition at line 78 of file TypeSequenceManager.cpp.
References begin(), MB_SUCCESS, and merge_internal().
Referenced by insert_sequence(), and notify_prepended().
if( i == begin() ) return MB_SUCCESS;
iterator j = i;
--j;
if( ( *j )->data() != ( *i )->data() || ( *j )->end_handle() + 1 < ( *i )->start_handle() ) return MB_SUCCESS;
assert( ( *j )->end_handle() + 1 == ( *i )->start_handle() );
| bool moab::TypeSequenceManager::check_valid_data | ( | const EntitySequence * | seq | ) | const [private] |
Definition at line 926 of file TypeSequenceManager.cpp.
References begin(), moab::EntitySequence::data(), empty(), end(), moab::SequenceData::end_handle(), moab::EntitySequence::end_handle(), find(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, lastReferenced, lower_bound(), moab::SequenceData::seqManData, sequenceSet, moab::SequenceData::start_handle(), and moab::EntitySequence::start_handle().
Referenced by erase(), insert_sequence(), and split_sequence().
// Caller passed a sequence that should be contained, so cannot be empty
if( empty() ) return false;
// Make sure lastReferenced points to something
if( !lastReferenced ) return false;
const_iterator seqi = sequenceSet.lower_bound( lastReferenced );
if( seqi == sequenceSet.end() || *seqi != lastReferenced ) return false;
// Make sure passed sequence is in list
const EntitySequence* seq2 = find( seq->start_handle() );
if( seq2 != seq ) return false;
// Check all sequences referencing the same SequenceData
const SequenceData* data = seq->data();
const_iterator i = lower_bound( data->start_handle() );
if( i != data->seqManData.firstSequence ) return false;
if( i != begin() )
const_iterator j = i;
--j;
if( ( *j )->end_handle() >= data->start_handle() ) return false;
if( ( *j )->data()->end_handle() >= data->start_handle() ) return false;
for( ;; )
seq2 = *i;
++i;
if( i == end() ) return true;
if( ( *i )->data() != data ) break;
if( seq2->end_handle() >= ( *i )->start_handle() ) return false;
if( ( *i )->start_handle() <= data->end_handle() ) return false;
if( ( *i )->data()->start_handle() <= data->end_handle() ) return false;
return true;
| ErrorCode moab::TypeSequenceManager::check_valid_handles | ( | Error * | error_handler, |
| EntityHandle | first, | ||
| EntityHandle | last | ||
| ) | const |
Definition at line 602 of file TypeSequenceManager.cpp.
References end(), moab::GeomUtil::first(), lower_bound(), MB_ENTITY_NOT_FOUND, and MB_SUCCESS.
Referenced by moab::SequenceManager::check_valid_entities(), and erase().
const_iterator i = lower_bound( first );
if( i == end() || ( *i )->start_handle() > first )
#if 0
// MB_ENTITY_NOT_FOUND could be a non-error condition, do not call
// MB_SET_ERR on it
fprintf(
stderr,
"[Warning]: Invalid entity handle: 0x%lx\n", (unsigned long)first
#endif
return MB_ENTITY_NOT_FOUND;
while( ( *i )->end_handle() < last )
EntityHandle prev_end = ( *i )->end_handle();
++i;
if( i == end() || prev_end + 1 != ( *i )->start_handle() ) return MB_ENTITY_NOT_FOUND;
return MB_SUCCESS;
| bool moab::TypeSequenceManager::empty | ( | ) | const [inline] |
Definition at line 231 of file TypeSequenceManager.hpp.
References lastReferenced.
Referenced by check_valid_data(), get_memory_use(), is_free_sequence(), moab::operator<<(), and moab::Core::print_database().
return 0 == lastReferenced;
| const_iterator moab::TypeSequenceManager::end | ( | ) | const [inline] |
Definition at line 162 of file TypeSequenceManager.hpp.
Referenced by append_memory_use(), check_merge_next(), check_valid_data(), check_valid_handles(), erase(), find(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), find_free_block(), find_free_handle(), find_free_sequence(), moab::RangeSeqIntersectIter::find_invalid_range(), moab::Core::get_coords(), moab::WriteUtil::get_element_connect(), moab::ReorderTool::get_entities(), get_entities(), moab::AEntityFactory::get_memory_use(), moab::DenseTag::get_memory_use(), moab::VarLenDenseTag::get_memory_use(), get_memory_use(), moab::WriteUtil::get_node_coords(), get_number_entities(), get_occupied_size(), moab::get_tagged(), moab::DenseTag::get_tagged_entities(), moab::ReorderTool::handle_order_from_int_tag(), insert_sequence(), is_free_handle(), is_free_sequence(), last_free_handle(), moab::operator<<(), moab::Core::print_database(), moab::SequenceManager::release_tag_array(), remove_sequence(), moab::ReorderTool::reorder_entities(), replace_subsequence(), split_sequence(), moab::AEntityFactory::~AEntityFactory(), and ~TypeSequenceManager().
return sequenceSet.end();
| iterator moab::TypeSequenceManager::end | ( | ) | [inline] |
Definition at line 166 of file TypeSequenceManager.hpp.
Remove a sequence.
Definition at line 259 of file TypeSequenceManager.cpp.
References availableList, check_valid_data(), moab::EntitySequence::data(), end(), find(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, lastReferenced, moab::SequenceData::seqManData, sequenceSet, moab::EntitySequence::start_handle(), and moab::EntitySequence::using_entire_data().
Referenced by moab::SequenceManager::delete_entities(), moab::SequenceManager::delete_entity(), and erase().
iterator j;
// Check if we need to delete the referenced SequenceData also
bool delete_data;
if( seq->using_entire_data() ) // Only sequence
delete_data = true;
else if( data->seqManData.firstSequence != i )
{ // Earlier sequence?
delete_data = false;
availableList.insert( data );
else
{ // Later sequence ?
j = i;
++j;
delete_data = ( j == end() || ( *j )->data() != data );
if( delete_data )
availableList.erase( data );
else
data->seqManData.firstSequence = j;
// Remove sequence, updating i to be next sequence
j = i++;
sequenceSet.erase( j );
// Make sure lastReferenced isn't stale. It can only be NULL if
// no sequences.
if( lastReferenced == seq ) lastReferenced = sequenceSet.empty() ? 0 : *sequenceSet.begin();
// Always delete sequence before the SequenceData it references.
assert( 0 == find( seq->start_handle() ) );
delete seq;
if( delete_data )
delete data;
else
assert( check_valid_data( *data->seqManData.firstSequence ) );
assert( lastReferenced != seq );
return i;
| ErrorCode moab::TypeSequenceManager::erase | ( | Error * | error_handler, |
Remove entities.
Update EntitySequence data as necessary to "delete" the specified entities (e.g. split sequences, delete sequences, free SequenceData instances, etc.)
Definition at line 679 of file TypeSequenceManager.cpp.
References availableList, check_valid_data(), check_valid_handles(), end(), erase(), ErrorCode, moab::GeomUtil::first(), lower_bound(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, and split_sequence().
// First check that all entities in range are valid
ErrorCode rval = check_valid_handles( NULL, first, last );
if( MB_SUCCESS != rval ) return rval;
// Now remove entities
// Get first sequence intersecting range
if( i == end() ) // Shouldn't be possible given check_valid_handles call above.
// If range is entirely in interior of sequence, need to split sequence.
if( ( *i )->start_handle() < first && ( *i )->end_handle() > last )
if( ( *i )->using_entire_data() ) availableList.insert( ( *i )->data() );
i = split_sequence( i, first );
( *i )->pop_front( last - first + 1 );
assert( check_valid_data( *i ) );
return MB_SUCCESS;
// If range doesn't entirely contain first sequence, remove some
// handles from the end of the sequence and advance to the next
// sequence.
if( ( *i )->start_handle() < first )
( *i )->pop_back( ( *i )->end_handle() - first + 1 );
++i;
// Destroy all sequences contained entirely within the range
while( i != end() && ( *i )->end_handle() <= last )
i = erase( i );
// If necessary, remove entities from the beginning of the
// last sequence.
if( i != end() && ( *i )->start_handle() <= last )
( *i )->pop_front( last - ( *i )->start_handle() + 1 );
return MB_SUCCESS;
| EntityHandle | entity | ||
Definition at line 630 of file TypeSequenceManager.cpp.
References availableList, moab::EntitySequence::data(), moab::EntitySequence::end_handle(), ErrorCode, find(), lower_bound(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::EntitySequence::pop_back(), moab::EntitySequence::pop_front(), remove_sequence(), split_sequence(), moab::EntitySequence::start_handle(), and moab::EntitySequence::using_entire_data().
EntitySequence* seq = find( h );
if( !seq )
#if 0
// MB_SET_ERR on it
fprintf(
stderr,
"[Warning]: Invalid entity handle: 0x%lx\n", (unsigned long)h
#endif
if( seq->start_handle() == h )
if( seq->end_handle() != h )
if( seq->using_entire_data() ) availableList.insert( seq->data() );
seq->pop_front( 1 );
return MB_SUCCESS;
bool delete_data;
ErrorCode rval = remove_sequence( seq, delete_data );
delete seq;
if( delete_data ) delete data;
else if( seq->end_handle() == h )
seq->pop_back( 1 );
else
iterator i = lower_bound( h );
i = split_sequence( i, h );
seq = *i;
assert( seq->start_handle() == h );
return MB_SUCCESS;
| EntitySequence * moab::TypeSequenceManager::find | ( | EntityHandle | h | ) | const [inline] |
Definition at line 376 of file TypeSequenceManager.hpp.
References end(), moab::EntitySequence::end_handle(), lastReferenced, sequenceSet, and moab::EntitySequence::start_handle().
Referenced by check_valid_data(), erase(), and moab::SequenceManager::find().
if( !lastReferenced ) // only null if empty
return 0;
else if( h >= lastReferenced->start_handle() && h <= lastReferenced->end_handle() )
return lastReferenced;
else
DummySequence seq( h );
const_iterator i = sequenceSet.find( &seq );
return i == end() ? 0 : ( lastReferenced = *i );
| EntitySequence * moab::TypeSequenceManager::find | ( | EntityHandle | h | ) | [inline] |
Definition at line 389 of file TypeSequenceManager.hpp.
return 0;
else
| ErrorCode moab::TypeSequenceManager::find | ( | EntityHandle | h, |
| EntitySequence *& | seq | ||
| ) | [inline] |
Definition at line 429 of file TypeSequenceManager.hpp.
References end(), moab::EntitySequence::end_handle(), lastReferenced, MB_ENTITY_NOT_FOUND, MB_SUCCESS, sequenceSet, and moab::EntitySequence::start_handle().
{ // only null if empty
seq = 0;
seq = lastReferenced;
if( h >= seq->start_handle() && h <= seq->end_handle() )
return MB_SUCCESS;
DummySequence ds( h );
iterator i = sequenceSet.lower_bound( &ds );
if( i == end() || ( *i )->start_handle() > h )
seq = 0;
seq = *i;
lastReferenced = *i;
return MB_SUCCESS;
| const EntitySequence *& | seq | ||
Definition at line 403 of file TypeSequenceManager.hpp.
seq = 0;
return MB_SUCCESS;
seq = 0;
seq = *i;
return MB_SUCCESS;
| EntityHandle moab::TypeSequenceManager::find_free_block | ( | EntityID | num_entities, |
| EntityHandle | min_start_handle, | ||
| EntityHandle | max_end_handle | ||
Find block of free handles, such that block does not overlap any existing EntitySequence.
Definition at line 423 of file TypeSequenceManager.cpp.
References end(), and lower_bound().
const_iterator i = lower_bound( min_start_handle );
if( i == end() ) return min_start_handle;
if( ( *i )->start_handle() < min_start_handle + num_entities ) return min_start_handle;
++i;
for( ; i != end(); prev_end = ( *i )->end_handle(), ++i )
EntityID len = ( *i )->start_handle() - prev_end - 1;
if( len >= num_entities ) break;
if( prev_end + num_entities > max_end_handle )
return 0;
else
return prev_end + 1;
| TypeSequenceManager::iterator moab::TypeSequenceManager::find_free_handle | ( | EntityHandle | min_start_handle, |
| EntityHandle | max_end_handle, | ||
| bool & | append_out, | ||
| int | values_per_ent = 0 |
Find an existing entity sequence to which a new handle can be prepended or appended. The 'append_out' flag indicates to the caller that the new handle should be appended to the returned sequence if true, and prepended if false.
If no appropriate EntitySequence is available, NULL will be returned. The caller will typically then want to use find_free_sequence() to find appropriate values for the creation of a new EntitySequence.
Definition at line 334 of file TypeSequenceManager.cpp.
References availableList, and end().
Referenced by moab::SequenceManager::create_element(), moab::SequenceManager::create_mesh_set(), and moab::SequenceManager::create_vertex().
if( ( *( *i )->seqManData.firstSequence )->values_per_entity() != values_per_ent ) continue;
if( ( *i )->start_handle() > max_end_handle || ( *i )->end_handle() < min_start_handle ) continue;
for( iterator j = ( *i )->seqManData.firstSequence;
j != end() && ( *j )->start_handle() <= ( max_end_handle + 1 ) && ( *j )->data() == *i; ++j )
if( ( *j )->end_handle() + 1 < min_start_handle ) continue;
if( ( *j )->start_handle() > ( *i )->start_handle() && ( *j )->start_handle() > min_start_handle )
append_out = false;
return j;
if( ( *j )->end_handle() < ( *i )->end_handle() && ( *j )->end_handle() < max_end_handle )
append_out = true;
return j;
return end();
| EntityHandle moab::TypeSequenceManager::find_free_sequence | ( | EntityID | num_entities, |
| SequenceData *& | sequence_data_out, | ||
| EntityID & | sequence_data_size, | ||
Find block of free handles, such that block a) does not overlap any existing EntitySequence and b) is either entirely within one existing SequenceData or does not overlap any SequenceData.
| num_entities | Size of handle block. |
| min_start_handle | Block may not contain any handle less than this. |
| max_end_handle | Block may not contain any handle greater than this. |
| sequence_data_out | If block is within an unused portion of an existing SequenceData, a pointer to that SequenceData. NULL otherwise. |
Definition at line 467 of file TypeSequenceManager.cpp.
References begin(), moab::check_range(), end(), moab::range_data::first, moab::range_data::last, and lower_bound().
Referenced by moab::SequenceManager::create_element(), moab::SequenceManager::create_mesh_set(), moab::SequenceManager::create_vertex(), and moab::SequenceManager::sequence_start_handle().
if( max_end_handle < min_start_handle + num_entities - 1 ) return 0;
EntityHandle result;
iterator p, i = lower_bound( min_start_handle );
range_data d = { num_entities, min_start_handle, max_end_handle, 0, 0 };
if( i == end() )
data_out = 0;
else if( i == begin() )
if( ( *i )->values_per_entity() == num_verts )
d.first = ( *i )->data()->start_handle();
d.last = ( *i )->start_handle() - 1;
if( check_range( d, true, result ) )
data_out = ( *i )->data();
return result;
d.first = min_start_handle;
d.last = ( *i )->data()->start_handle() - 1;
data_out = 0;
// This will back up against the end of the seq data, so
// size the data that way
data_size = num_entities;
return result;
p = i++;
else
p = i;
--p;
for( ; i != end() && ( *i )->start_handle() < max_end_handle; p = i++ )
if( ( *p )->data() == ( *i )->data() )
if( ( *p )->values_per_entity() == num_verts )
d.first = ( *p )->end_handle() + 1;
if( check_range( d, false, result ) )
data_out = ( *p )->data();
return result;
else
d.last = ( *p )->data()->end_handle();
return result;
return result;
d.first = ( *p )->data()->end_handle() + 1;
data_out = 0;
data_size = d.last - d.first + 1;
return result;
return result;
d.last = max_end_handle;
data_out = 0;
return result;
data_out = 0;
return 0;
| void moab::TypeSequenceManager::get_entities | ( | Range & | entities_out | ) | const [inline] |
Definition at line 460 of file TypeSequenceManager.hpp.
References begin(), moab::Range::begin(), end(), and moab::Range::insert().
Referenced by moab::SequenceManager::get_entities().
Range::iterator in = entities_out.begin();
for( const_iterator i = begin(); i != end(); ++i )
in = entities_out.insert( in, ( *i )->start_handle(), ( *i )->end_handle() );
| void moab::TypeSequenceManager::get_entities | ( | std::vector< EntityHandle > & | entities_out | ) | const [inline] |
Definition at line 467 of file TypeSequenceManager.hpp.
References begin(), and end().
for( EntityHandle j = ( *i )->start_handle(); j <= ( *i )->end_handle(); ++j )
entities_out.push_back( j );
| const EntitySequence * moab::TypeSequenceManager::get_last_accessed | ( | ) | const [inline] |
Definition at line 455 of file TypeSequenceManager.hpp.
Referenced by moab::SequenceManager::get_last_accessed_sequence().
return lastReferenced; /* only NULL if TypeSequenceManager is empty */
| void moab::TypeSequenceManager::get_memory_use | ( | unsigned long long & | total_entity_storage, |
| ) | const |
Definition at line 841 of file TypeSequenceManager.cpp.
References moab::CREATE_HANDLE(), empty(), lastReferenced, MB_END_ID, MB_START_ID, moab::EntitySequence::start_handle(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::SequenceManager::get_memory_use().
entity_storage = total_storage = 0;
if( empty() ) return;
EntityType mytype = TYPE_FROM_HANDLE( lastReferenced->start_handle() );
int junk;
get_memory_use( CREATE_HANDLE( mytype, MB_START_ID, junk ), CREATE_HANDLE( mytype, MB_END_ID, junk ),
entity_storage, total_storage );
| void moab::TypeSequenceManager::get_memory_use | ( | EntityHandle | start, |
| EntityHandle | end, | ||
| unsigned long long & | total_entity_storage, | ||
| unsigned long long & | total_amortized_storage | ||
| ) | const |
Definition at line 895 of file TypeSequenceManager.cpp.
References append_memory_use(), end(), moab::SequenceData::end_handle(), and lower_bound().
while( first <= last )
if( i == end() ) return;
SequenceData* data = ( *i )->data();
if( first < data->end_handle() )
append_memory_use( first, last, data, entity_storage, total_storage );
first = data->end_handle() + 1;
| EntityID moab::TypeSequenceManager::get_number_entities | ( | ) | const [inline] |
Definition at line 474 of file TypeSequenceManager.hpp.
Referenced by moab::SequenceManager::get_number_entities().
EntityID count = 0;
return count;
| EntityID moab::TypeSequenceManager::get_occupied_size | ( | const SequenceData * | data | ) | const |
Get the sum of the size of all EntitySequences referencing a SequenceData. Used for memory use calculations.
Definition at line 916 of file TypeSequenceManager.cpp.
References end(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, and moab::SequenceData::seqManData.
EntityID result = 0;
for( const_iterator i = data->seqManData.firstSequence; i != end() && ( *i )->data() == data; ++i )
result += ( *i )->size();
return result;
| unsigned long moab::TypeSequenceManager::get_sequence_count | ( | ) | const [inline] |
Definition at line 363 of file TypeSequenceManager.hpp.
return sequenceSet.size();
Take ownership of passed EntitySequence, and update relevant data structures. Sequence may not overlap with any existing sequence.
NOTE: Sequence may be merged with other, existing sequences. This function will always ensure that the passed EntitySequence* is the remaining one, but the passed sequence may have modified start and end handles.
Definition at line 90 of file TypeSequenceManager.cpp.
References availableList, begin(), check_merge_next(), check_merge_prev(), check_valid_data(), moab::EntitySequence::data(), end(), moab::SequenceData::end_handle(), moab::EntitySequence::end_handle(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, lastReferenced, lower_bound(), MB_ALREADY_ALLOCATED, MB_SUCCESS, moab::SequenceData::seqManData, sequenceSet, moab::SequenceData::start_handle(), moab::EntitySequence::start_handle(), and moab::EntitySequence::using_entire_data().
Referenced by moab::SequenceManager::allocate_mesh_set(), moab::SequenceManager::create_element(), moab::SequenceManager::create_entity_sequence(), moab::SequenceManager::create_mesh_set(), moab::SequenceManager::create_meshset_sequence(), moab::SequenceManager::create_scd_sequence(), moab::SequenceManager::create_sweep_sequence(), moab::SequenceManager::create_vertex(), and replace_subsequence().
if( !seq_ptr->data() ) return MB_FAILURE;
if( seq_ptr->data()->start_handle() > seq_ptr->start_handle() ||
seq_ptr->data()->end_handle() < seq_ptr->end_handle() || seq_ptr->end_handle() < seq_ptr->start_handle() )
return MB_FAILURE;
iterator i = lower_bound( seq_ptr->start_handle() );
if( i != end() )
if( ( *i )->start_handle() <= seq_ptr->end_handle() ) return MB_ALREADY_ALLOCATED;
if( seq_ptr->data() != ( *i )->data() && ( *i )->data()->start_handle() <= seq_ptr->data()->end_handle() )
if( i != begin() )
iterator j = i;
--j;
if( seq_ptr->data() != ( *j )->data() && ( *j )->data()->end_handle() >= seq_ptr->data()->start_handle() )
i = sequenceSet.insert( i, seq_ptr );
// Merge with previous sequence ?
if( seq_ptr->start_handle() > seq_ptr->data()->start_handle() && i != begin() )
if( MB_SUCCESS != check_merge_prev( i ) )
sequenceSet.erase( i );
return MB_FAILURE;
// Merge with next sequence ?
if( ( *i )->end_handle() < ( *i )->data()->end_handle() )
if( MB_SUCCESS != check_merge_next( i ) )
return MB_FAILURE;
// We merged adjacent sequences sharing a SequenceData, so
// we can safely assume that unless this EntitySequence is
// using the entire SequenceData, there are unused portions.
if( !seq_ptr->using_entire_data() ) availableList.insert( seq_ptr->data() );
// lastReferenced is only allowed to be NULL if there are
// no sequences (avoids unnecessary if's in fast path).
if( !lastReferenced ) lastReferenced = seq_ptr;
// Each SequenceData has a pointer to the first EntitySequence
// referencing it. Update that pointer if the new sequence is
// the first one.
if( ( *i )->start_handle() == ( *i )->data()->start_handle() || lower_bound( ( *i )->data()->start_handle() ) == i )
( *i )->data()->seqManData.firstSequence = i;
assert( check_valid_data( seq_ptr ) );
return MB_SUCCESS;
| ErrorCode moab::TypeSequenceManager::is_free_handle | ( | EntityHandle | handle, |
| iterator & | seq_ptr_out, | ||
| SequenceData *& | data_ptr_out, | ||
| EntityHandle & | block_start, | ||
| EntityHandle & | block_end, | ||
Check if a specific handle is not currently allocated and can be allocated with the passed value of values_per_ent. For example, the handle may not be allocated, but it may fall within an existing SequenceData. In that case, it must be possible to store the specified values_per_ent in the existing SequenceData.
There are four possible return 'states' from this function:
| handle | The handle the caller wishes to allocate as a new entity |
| seq_ptr_out | Output: pointer to sequence to append or prepend to to allocate handle. end() if no such sequence. |
| data_ptr_out | Output: Pointer to existing SequenceData containing input handle, or NULL if no such SequenceData. |
| block_start | Output: Smallest possible start handle for new sequence. |
| block_end | Output: Largest possible end handle for new sequence. |
Definition at line 740 of file TypeSequenceManager.cpp.
References begin(), moab::CREATE_HANDLE(), end(), moab::SequenceData::end_handle(), lower_bound(), MB_ALREADY_ALLOCATED, MB_END_ID, MB_START_ID, MB_SUCCESS, moab::SequenceData::start_handle(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::SequenceManager::allocate_mesh_set().
int junk;
block_start = CREATE_HANDLE( TYPE_FROM_HANDLE( handle ), MB_START_ID, junk );
block_end = CREATE_HANDLE( TYPE_FROM_HANDLE( handle ), MB_END_ID, junk );
iterator i = lower_bound( handle );
if( i != end() )
block_end = ( *i )->start_handle() - 1;
// If sequence contains handle, then already allocated
if( ( *i )->start_handle() <= handle ) return MB_ALREADY_ALLOCATED;
// Handle is not within an existing sequence, but is
// within an existing SequenceData...
if( ( *i )->data()->start_handle() <= handle )
// If values_per_entity don't match, can't put new entity
// in existing SequenceData
if( ( *i )->values_per_entity() != values_per_ent ) return MB_ALREADY_ALLOCATED;
data_ptr_out = ( *i )->data();
if( block_end == handle )
// Prepend to existing sequence
seq_iter_out = i;
block_start = handle;
else
// Add new sequence to existing SequenceData
seq_iter_out = end();
if( i == begin() || ( *--i )->data() != data_ptr_out )
block_start = data_ptr_out->start_handle();
else
block_start = ( *i )->end_handle() + 1;
return MB_SUCCESS;
if( i != begin() )
--i;
// Handle is within previous sequence data...
if( ( *i )->data()->end_handle() >= handle )
if( block_start == handle )
// Append to existing sequence
seq_iter_out = i;
block_end = handle;
else
if( ++i == end() || ( *i )->data() != data_ptr_out )
block_end = data_ptr_out->end_handle();
else
return MB_SUCCESS;
data_ptr_out = 0;
return MB_SUCCESS;
| bool moab::TypeSequenceManager::is_free_sequence | ( | EntityHandle | start_handle, |
| EntityID | num_entities, | ||
Check if block of handles is free and can be allocated as a single EntitySequence. If the block of handles is contained within an unused portion of a SequenceData, the SequenceData is returned.
Definition at line 365 of file TypeSequenceManager.cpp.
References begin(), empty(), end(), moab::SequenceData::end_handle(), lower_bound(), and moab::SequenceData::start_handle().
Referenced by moab::SequenceManager::sequence_start_handle().
data_out = 0;
if( empty() ) return true;
const_iterator i = lower_bound( start );
if( i == end() )
--i; // Safe because already tested empty()
// If we don't overlap the last data object...
if( ( *i )->data()->end_handle() < start ) return true;
if( ( *i )->values_per_entity() != values_per_ent ) return false;
// If we overlap a data object, we must be entirely inside of it
return start + num_entities - 1 <= ( *i )->data()->end_handle();
#ifndef NDEBUG
if( i != begin() )
--j;
assert( ( *j )->end_handle() < start );
#endif
// Check if we fit in the block of free handles
if( start + num_entities > ( *i )->start_handle() ) // start + num + 1 >= i->start
return false;
// Check if we overlap the data for the next sequence
if( start + num_entities > ( *i )->data()->start_handle() )
// If overlap, must be entirely contained
return start >= data_out->start_handle() && start + num_entities - 1 <= data_out->end_handle();
// Check if we overlap the data for the previous sequence
if( i != begin() )
--i;
if( ( *i )->data()->end_handle() >= start )
// Unused handle block that overlaps no SequenceData
return true;
| EntityHandle moab::TypeSequenceManager::last_free_handle | ( | EntityHandle | after_this | ) | const |
Definition at line 586 of file TypeSequenceManager.cpp.
References moab::CREATE_HANDLE(), end(), lower_bound(), MB_END_ID, and moab::TYPE_FROM_HANDLE().
Referenced by moab::SequenceManager::new_sequence_size().
int junk;
const_iterator it = lower_bound( after_this );
if( it == end() )
return CREATE_HANDLE( TYPE_FROM_HANDLE( after_this ), MB_END_ID, junk );
else if( ( *it )->start_handle() > after_this )
// Need to check against the sequence data first
EntityHandle rhandle = ( *it )->data()->start_handle();
return rhandle - 1;
else
return 0;
| const_iterator moab::TypeSequenceManager::lower_bound | ( | EntityHandle | h | ) | const [inline] |
Return EntitySequence for specified handle, or if no such sequence, the next one. Returns end() if all sequences have ranges less than specified handle.
Definition at line 177 of file TypeSequenceManager.hpp.
Referenced by check_valid_data(), check_valid_handles(), erase(), find_free_block(), find_free_sequence(), moab::Core::get_coords(), get_memory_use(), insert_sequence(), is_free_handle(), is_free_sequence(), last_free_handle(), remove_sequence(), and replace_subsequence().
DummySequence f( h );
return sequenceSet.lower_bound( &f );
| iterator moab::TypeSequenceManager::lower_bound | ( | EntityHandle | h | ) | [inline] |
Definition at line 182 of file TypeSequenceManager.hpp.
| ErrorCode moab::TypeSequenceManager::merge_internal | ( | iterator | keep, |
| iterator | dead | ||
| ) | [private] |
Definition at line 46 of file TypeSequenceManager.cpp.
References availableList, ErrorCode, lastReferenced, MB_SUCCESS, and sequenceSet.
Referenced by check_merge_next(), and check_merge_prev().
EntitySequence* dead = *j;
ErrorCode rval = ( *i )->merge( *dead );
sequenceSet.insert( dead );
return rval;
if( lastReferenced == dead ) lastReferenced = *i;
delete dead;
// If merging results in no unused portions of the SequenceData,
// remove it from the available list.
if( ( *i )->using_entire_data() ) availableList.erase( ( *i )->data() );
return MB_SUCCESS;
Notify of sequence modifications so we can check if sequence needs to be merged.
Definition at line 825 of file TypeSequenceManager.cpp.
References availableList, check_merge_next(), and ErrorCode.
Referenced by moab::SequenceManager::allocate_mesh_set(), moab::SequenceManager::create_element(), moab::SequenceManager::create_mesh_set(), and moab::SequenceManager::create_vertex().
ErrorCode rval = check_merge_next( seq );
if( ( *seq )->using_entire_data() ) availableList.erase( ( *seq )->data() );
return rval;
Definition at line 833 of file TypeSequenceManager.cpp.
References availableList, check_merge_prev(), and ErrorCode.
ErrorCode rval = check_merge_prev( seq );
return rval;
| ErrorCode moab::TypeSequenceManager::remove_sequence | ( | const EntitySequence * | seq_ptr, |
| bool & | is_last_user_of_sequence_data | ||
Give up ownership of specified EntitySequence, and remove it from all internal data structures. Passes back bool flag to notify caller that ownership of the corresponding SequenceData is also relinquished because the specified EntitySequence is the last one referencing it.
Definition at line 309 of file TypeSequenceManager.cpp.
References availableList, moab::EntitySequence::data(), end(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, lastReferenced, lower_bound(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::SequenceData::seqManData, sequenceSet, moab::SequenceData::start_handle(), moab::EntitySequence::start_handle(), and moab::EntitySequence::using_entire_data().
Referenced by erase().
// Remove sequence from set
if( i == end() || *i != seq_ptr ) return MB_ENTITY_NOT_FOUND;
// Check if this is the only sequence referencing its data
if( seq_ptr->using_entire_data() )
unreferenced_data = true;
else
i = lower_bound( seq_ptr->data()->start_handle() );
unreferenced_data = i == end() || ( *i )->data() != seq_ptr->data();
if( unreferenced_data )
availableList.erase( seq_ptr->data() );
else
seq_ptr->data()->seqManData.firstSequence = i; // Might be 'i' already
if( lastReferenced == seq_ptr ) lastReferenced = sequenceSet.empty() ? 0 : *sequenceSet.begin();
return MB_SUCCESS;
| ErrorCode moab::TypeSequenceManager::replace_subsequence | ( | EntitySequence * | seq_ptr, |
| const int * | tag_sizes, | ||
| int | num_tag_sizes | ||
Replace one sequence or a subset of one sequence with another sequence. With fail if a) the existing sequence is not a subset of an existing sequence or b) existing sequence shares a SequenceData with the passed sequence.
This method is provided for use when changing the number of nodes in elements.
Definition at line 155 of file TypeSequenceManager.cpp.
References availableList, moab::EntitySequence::data(), end(), moab::EntitySequence::end_handle(), moab::TypeSequenceManager::SequenceDataPtr::firstSequence, insert_sequence(), lastReferenced, lower_bound(), moab::SequenceData::move_tag_data(), moab::SequenceData::seqManData, sequenceSet, moab::EntitySequence::size(), split_sequence(), moab::EntitySequence::start_handle(), and moab::EntitySequence::using_entire_data().
Referenced by moab::SequenceManager::replace_subsequence().
// Find the sequence of interest
if( i == end() || ( *i )->data() == seq_ptr->data() ) return MB_FAILURE;
// New sequence must be a subset of an existing one
if( seq_ptr->start_handle() < ( *i )->start_handle() || seq_ptr->end_handle() > ( *i )->end_handle() )
return MB_FAILURE;
// New sequence's data must be new also, and cannot intersect
// any existing sequence (just require that the data range
// matches the sequence range for now)
if( !seq_ptr->using_entire_data() ) return MB_FAILURE;
// Copy tag data (move ownership of var-len data)
SequenceData* const dead_data = ( *i )->data();
dead_data->move_tag_data( seq_ptr->data(), tag_sizes, num_tag_sizes );
// Split sequences sharing old data into two groups:
// p->i : first sequence to i
// i->n : i to one past last sequence
iterator p, n = i;
p = ( *i )->data()->seqManData.firstSequence;
for( ++n; n != end() && ( *n )->data() == ( *i )->data(); ++n )
// First subdivide EntitySequence as necessary
// Move i to be the first sequence past the insertion point
// such that the new order will be:
// [p,i-1] seq_ptr [i,n]
// where p == i if no previous sequence
// Four possible cases:
// 0. All entities in sequence are in new sequence
// 1. Old entities in sequence before and after new sequence,
// requiring sequence to be split.
// 2. Old entities after new sequence
// 3. Old entities before new sequence
const bool some_before = ( ( *i )->start_handle() < seq_ptr->start_handle() );
const bool some_after = ( ( *i )->end_handle() > seq_ptr->end_handle() );
// Case 0
if( !( some_before || some_after ) )
// Remove dead sequence from internal lists
iterator dead = i;
++i;
if( p == dead ) p = i;
sequenceSet.erase( dead );
// Delete old sequence
delete seq;
if( lastReferenced == seq ) lastReferenced = seq_ptr;
// Case 1
else if( some_before && some_after )
i = split_sequence( i, seq_ptr->start_handle() );
( *i )->pop_front( seq_ptr->size() );
// Case 2
else if( some_after )
// Case 3
else
{ // some_before
( *i )->pop_back( seq_ptr->size() );
++i;
// Now subdivide the underlying sequence data as necessary
availableList.erase( dead_data );
if( p != i )
iterator last = i;
--last;
SequenceData* new_data = ( *p )->create_data_subset( ( *p )->start_handle(), ( *last )->end_handle() );
new_data->seqManData.firstSequence = p;
for( ; p != i; ++p )
( *p )->data( new_data );
dead_data->move_tag_data( new_data, tag_sizes, num_tag_sizes );
if( !( *new_data->seqManData.firstSequence )->using_entire_data() ) availableList.insert( new_data );
if( i != n )
iterator last = n;
--last;
SequenceData* new_data = ( *i )->create_data_subset( ( *i )->start_handle(), ( *last )->end_handle() );
new_data->seqManData.firstSequence = i;
for( ; i != n; ++i )
( *i )->data( new_data );
delete dead_data;
// Put new sequence in lists
return insert_sequence( seq_ptr );
| TypeSequenceManager::iterator moab::TypeSequenceManager::split_sequence | ( | iterator | i, |
| EntityHandle | h | ||
| ) | [private] |
split a sequence
Definition at line 729 of file TypeSequenceManager.cpp.
References check_valid_data(), end(), sequenceSet, and moab::EntitySequence::split().
Referenced by erase(), and replace_subsequence().
EntitySequence* seq = ( *i )->split( h );
if( !seq ) return end();
i = sequenceSet.insert( i, seq );
return i;
| const_iterator moab::TypeSequenceManager::upper_bound | ( | EntityHandle | h | ) | const [inline] |
Return EntitySequence with smallest start handle that is greater than input handle. Returns end() if all sequences have start handles less than specified handle.
Definition at line 195 of file TypeSequenceManager.hpp.
Referenced by moab::RangeSeqIntersectIter::find_invalid_range().
return sequenceSet.upper_bound( &f );
Definition at line 85 of file TypeSequenceManager.hpp.
Referenced by erase(), find_free_handle(), insert_sequence(), merge_internal(), notify_appended(), notify_prepended(), remove_sequence(), replace_subsequence(), and ~TypeSequenceManager().
EntitySequence* moab::TypeSequenceManager::lastReferenced [mutable, private] |
Definition at line 83 of file TypeSequenceManager.hpp.
Referenced by check_valid_data(), empty(), erase(), find(), get_last_accessed(), get_memory_use(), insert_sequence(), merge_internal(), remove_sequence(), and replace_subsequence().
Definition at line 84 of file TypeSequenceManager.hpp.
Referenced by begin(), check_valid_data(), end(), erase(), find(), get_sequence_count(), insert_sequence(), lower_bound(), merge_internal(), remove_sequence(), replace_subsequence(), split_sequence(), upper_bound(), and ~TypeSequenceManager().
