Mesh Oriented datABase
(version 5.4.1)
#include <SweptElementSeq.hpp>
Inheritance diagram for moab::SweptElementSeq:
Collaboration diagram for moab::SweptElementSeq:Public Member Functions | |
| SweptElementSeq (EntityHandle start_handle, const int imin, const int jmin, const int kmin, const int imax, const int jmax, const int kmax, const int *Cq) | |
| constructor | |
| virtual | ~SweptElementSeq () |
| ScdElementData * | sdata () |
| ScdElementData const * | sdata () const |
| EntityHandle | get_vertex (const int i, const int j, const int k) const |
| get handle of vertex at i, j, k | |
| EntityHandle | get_vertex (const HomCoord &coords) const |
| get handle of vertex at homogeneous coords | |
| EntityHandle | get_element (const int i, const int j, const int k) const |
| get handle of element at i, j, k | |
| EntityHandle | get_element (const HomCoord &coords) const |
| get handle of element at homogeneous coords | |
| const HomCoord & | min_params () const |
| get min params for this element | |
| void | min_params (HomCoord &coords) const |
| void | min_params (int &i, int &j, int &k) const |
| const HomCoord & | max_params () const |
| get max params for this element | |
| void | max_params (HomCoord &coords) const |
| void | max_params (int &i, int &j, int &k) const |
| void | param_extents (int &di, int &dj, int &dk) const |
| get the number of vertices in each direction, inclusive | |
| ErrorCode | get_params (const EntityHandle ehandle, int &i, int &j, int &k) const |
| given a handle, get the corresponding parameters | |
| int | i_min () const |
| convenience functions for parameter extents | |
| int | j_min () const |
| int | k_min () const |
| int | i_max () const |
| int | j_max () const |
| int | k_max () const |
| bool | boundary_complete () const |
| test the bounding vertex sequences and determine whether they fully define the vertices covering this element block's parameter space | |
| bool | contains (const int i, const int j, const int k) const |
| test whether this sequence contains these parameters | |
| bool | contains (const HomCoord &coords) const |
| ErrorCode | get_params_connectivity (const int i, const int j, const int k, std::vector< EntityHandle > &connectivity) const |
| get connectivity of an entity given entity's parameters | |
| virtual ErrorCode | get_connectivity (EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const |
| virtual ErrorCode | get_connectivity (EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const |
| virtual ErrorCode | set_connectivity (EntityHandle handle, EntityHandle const *connect, int connect_length) |
| virtual EntityHandle * | get_connectivity_array () |
| virtual int | values_per_entity () const |
| Integer value used in finding appropriate SequenceData. | |
| virtual EntitySequence * | split (EntityHandle here) |
| Split this sequence into two consecutive sequences. | |
| virtual SequenceData * | create_data_subset (EntityHandle start_handle, EntityHandle end_handle) const |
| Create a new SequenceData that is a copy of a subset of the one referenced by this sequence. | |
| virtual void | get_const_memory_use (unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const |
| Get memory characteristcs that are the same for all entities. | |
Protected Member Functions | |
| SweptElementSeq (SweptElementSeq &split_from, EntityHandle here) | |
Definition at line 31 of file SweptElementSeq.hpp.
| moab::SweptElementSeq::SweptElementSeq | ( | EntityHandle | start_handle, |
| const int | imin, | ||
| const int | jmin, | ||
| const int | kmin, | ||
| const int | imax, | ||
| const int | jmax, | ||
| const int | kmax, | ||
| const int * | Cq | ||
constructor
Definition at line 27 of file SweptElementSeq.cpp.
Referenced by split().
: ElementSequence( shandle, ScdElementData::calc_num_entities( shandle, imax - imin, jmax - jmin, kmax - kmin ), CN::VerticesPerEntity( TYPE_FROM_HANDLE( shandle ) ), new SweptElementData( shandle, imin, jmin, kmin, imax, jmax, kmax, Cq ) ) { }
| moab::SweptElementSeq::~SweptElementSeq | ( | ) | [virtual] |
Definition at line 42 of file SweptElementSeq.cpp.
| moab::SweptElementSeq::SweptElementSeq | ( | SweptElementSeq & | split_from, |
| EntityHandle | here | ||
| ) | [inline, protected] |
Definition at line 206 of file SweptElementSeq.hpp.
: ElementSequence( split_from, here ) {}
| bool moab::SweptElementSeq::boundary_complete | ( | ) | const [inline] |
Definition at line 151 of file SweptElementSeq.hpp.
References moab::ScdElementData::boundary_complete(), and sdata().
return sdata()->boundary_complete();
| bool moab::SweptElementSeq::contains | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 157 of file SweptElementSeq.hpp.
References moab::ScdElementData::contains(), and sdata().
| bool moab::SweptElementSeq::contains | ( | const HomCoord & | coords | ) | const [inline] |
Definition at line 161 of file SweptElementSeq.hpp.
| SequenceData * moab::SweptElementSeq::create_data_subset | ( | EntityHandle | start_handle, |
| EntityHandle | end_handle | ||
| ) | const [virtual] |
Create a new SequenceData that is a copy of a subset of the SequenceData referenced by this EntitySequence. Do not make any changes to this EntitySequence or the current SequenceData.
Implements moab::EntitySequence.
Definition at line 94 of file SweptElementSeq.cpp.
return 0;
| ErrorCode moab::SweptElementSeq::get_connectivity | ( | EntityHandle | handle, |
| std::vector< EntityHandle > & | connect, | ||
| bool | topological = false |
Implements moab::ElementSequence.
Definition at line 44 of file SweptElementSeq.cpp.
References ErrorCode, get_params(), get_params_connectivity(), and MB_SUCCESS.
Referenced by get_connectivity().
int i, j, k;
ErrorCode rval = get_params( handle, i, j, k );
if( MB_SUCCESS == rval ) rval = get_params_connectivity( i, j, k, connect );
return rval;
| EntityHandle const *& | connect, | ||
| int & | connect_length, | ||
| bool | topological = false, |
| std::vector< EntityHandle > * | storage = 0 |
Definition at line 54 of file SweptElementSeq.cpp.
References ErrorCode, get_connectivity(), and MB_NOT_IMPLEMENTED.
if( !storage )
connect = 0;
connect_length = 0;
return MB_NOT_IMPLEMENTED;
storage->clear();
ErrorCode rval = get_connectivity( handle, *storage, topo );
connect = &( *storage )[0];
connect_length = storage->size();
return rval;
| EntityHandle * moab::SweptElementSeq::get_connectivity_array | ( | ) | [virtual] |
| void moab::SweptElementSeq::get_const_memory_use | ( | unsigned long & | bytes_per_entity, |
| unsigned long & | size_of_sequence | ||
Get charactersitic constant memory use for all entities in sequence.
| bytes_per_entity | The total bytes consumed for each entity in the underlying SequenceData. It is assumed that the same amount of memory is consumed for unused portions of the SequenceData. |
| size_of_sequence | The size of the leaf subclass of this class |
Definition at line 99 of file SweptElementSeq.cpp.
References moab::ScdElementData::get_memory_use(), sdata(), and moab::SequenceData::size().
sequence_size = sizeof( *this );
bytes_per_entity = sdata()->get_memory_use() / sdata()->size();
| EntityHandle moab::SweptElementSeq::get_element | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 68 of file SweptElementSeq.hpp.
References moab::ScdElementData::get_element(), and sdata().
return sdata()->get_element( i, j, k );
| EntityHandle moab::SweptElementSeq::get_element | ( | const HomCoord & | coords | ) | const [inline] |
Definition at line 74 of file SweptElementSeq.hpp.
References moab::ScdElementData::get_element(), moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and sdata().
return sdata()->get_element( coords.i(), coords.j(), coords.k() );
| ErrorCode moab::SweptElementSeq::get_params | ( | const EntityHandle | ehandle, |
| int & | i, | ||
| int & | j, | ||
| int & | k | ||
Definition at line 118 of file SweptElementSeq.hpp.
References moab::ScdElementData::get_params(), and sdata().
return sdata()->get_params( ehandle, i, j, k );
| ErrorCode moab::SweptElementSeq::get_params_connectivity | ( | const int | i, |
| const int | j, | ||
| const int | k, | ||
| std::vector< EntityHandle > & | connectivity | ||
Definition at line 167 of file SweptElementSeq.hpp.
References moab::ScdElementData::get_params_connectivity(), and sdata().
return sdata()->get_params_connectivity( i, j, k, connectivity );
| EntityHandle moab::SweptElementSeq::get_vertex | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 56 of file SweptElementSeq.hpp.
return get_vertex( HomCoord( i, j, k ) );
| EntityHandle moab::SweptElementSeq::get_vertex | ( | const HomCoord & | coords | ) | const [inline] |
Definition at line 62 of file SweptElementSeq.hpp.
References moab::ScdElementData::get_vertex(), and sdata().
return sdata()->get_vertex( coords );
| int moab::SweptElementSeq::i_max | ( | ) | const [inline] |
Definition at line 136 of file SweptElementSeq.hpp.
References moab::HomCoord::i(), and max_params().
return max_params().i();
| int moab::SweptElementSeq::i_min | ( | ) | const [inline] |
Definition at line 124 of file SweptElementSeq.hpp.
References moab::HomCoord::i(), and min_params().
return min_params().i();
| int moab::SweptElementSeq::j_max | ( | ) | const [inline] |
Definition at line 140 of file SweptElementSeq.hpp.
References moab::HomCoord::j(), and max_params().
return max_params().j();
| int moab::SweptElementSeq::j_min | ( | ) | const [inline] |
Definition at line 128 of file SweptElementSeq.hpp.
References moab::HomCoord::j(), and min_params().
return min_params().j();
| int moab::SweptElementSeq::k_max | ( | ) | const [inline] |
Definition at line 144 of file SweptElementSeq.hpp.
References moab::HomCoord::k(), and max_params().
return max_params().k();
| int moab::SweptElementSeq::k_min | ( | ) | const [inline] |
Definition at line 132 of file SweptElementSeq.hpp.
References moab::HomCoord::k(), and min_params().
return min_params().k();
| const HomCoord& moab::SweptElementSeq::max_params | ( | ) | const [inline] |
Definition at line 96 of file SweptElementSeq.hpp.
References moab::ScdElementData::max_params(), and sdata().
Referenced by i_max(), j_max(), k_max(), and max_params().
return sdata()->max_params();
| void moab::SweptElementSeq::max_params | ( | HomCoord & | coords | ) | const [inline] |
Definition at line 100 of file SweptElementSeq.hpp.
References max_params().
coords = max_params();
| void moab::SweptElementSeq::max_params | ( | int & | i, |
| int & | j, | ||
| int & | k | ||
Definition at line 104 of file SweptElementSeq.hpp.
References moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and max_params().
i = max_params().i();
j = max_params().j();
k = max_params().k();
| const HomCoord& moab::SweptElementSeq::min_params | ( | ) | const [inline] |
Definition at line 80 of file SweptElementSeq.hpp.
References moab::ScdElementData::min_params(), and sdata().
Referenced by i_min(), j_min(), k_min(), and min_params().
return sdata()->min_params();
| void moab::SweptElementSeq::min_params | ( | HomCoord & | coords | ) | const [inline] |
Definition at line 84 of file SweptElementSeq.hpp.
References min_params().
coords = min_params();
| void moab::SweptElementSeq::min_params | ( | int & | i, |
| int & | j, | ||
| int & | k | ||
Definition at line 88 of file SweptElementSeq.hpp.
References moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and min_params().
i = min_params().i();
j = min_params().j();
k = min_params().k();
| void moab::SweptElementSeq::param_extents | ( | int & | di, |
| int & | dj, | ||
| int & | dk | ||
Definition at line 112 of file SweptElementSeq.hpp.
References moab::ScdElementData::param_extents(), and sdata().
sdata()->param_extents( di, dj, dk );
| ScdElementData* moab::SweptElementSeq::sdata | ( | ) | [inline] |
Definition at line 46 of file SweptElementSeq.hpp.
References moab::EntitySequence::data().
Referenced by boundary_complete(), contains(), get_const_memory_use(), get_element(), get_params(), get_params_connectivity(), get_vertex(), max_params(), min_params(), and param_extents().
return reinterpret_cast< ScdElementData* >( data() );
| ScdElementData const* moab::SweptElementSeq::sdata | ( | ) | const [inline] |
Definition at line 50 of file SweptElementSeq.hpp.
return reinterpret_cast< const ScdElementData* >( data() );
| ErrorCode moab::SweptElementSeq::set_connectivity | ( | EntityHandle | handle, |
| EntityHandle const * | connect, | ||
| int | connect_length | ||
| ) | [virtual] |
Definition at line 74 of file SweptElementSeq.cpp.
References MB_NOT_IMPLEMENTED.
| EntitySequence * moab::SweptElementSeq::split | ( | EntityHandle | here | ) | [virtual] |
Split this sequence into two sequences.
| here | New sequences should be [start_handle(),here) & [here,end_handle()] |
Definition at line 89 of file SweptElementSeq.cpp.
References SweptElementSeq().
return new SweptElementSeq( *this, here );
| int moab::SweptElementSeq::values_per_entity | ( | ) | const [virtual] |
This value is matched to input values by TypeSequenceManager to determine if an available, unused portino of a SequenceData can be used for a specific entity allocation. For example, it is used to find a SequenceData with the appropriate number of vertices per element when allocating elements. The default value is zero.
Reimplemented from moab::EntitySequence.
Definition at line 84 of file SweptElementSeq.cpp.
return -1;
} // never reuse freed handles for swept elements
