Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
| integer(c_int) function | iMOAB_GetBlockInfo (pid, global_block_ID, vertices_per_element, num_elements_in_block) |
Definition at line 169 of file iMOABF.F90.
| integer(c_int) function iMOAB::iMOAB_GetBlockInfo::iMOAB_GetBlockInfo | ( | integer(c_int), intent(in) | pid, |
| integer(c_int), intent(in) | global_block_ID, | ||
| integer(c_int), intent(out) | vertices_per_element, | ||
| integer(c_int), intent(out) | num_elements_in_block | ||
