Mesh Oriented datABase
(version 5.4.1)
#include <MeshAssocPairSide.hpp>
Inheritance diagram for MeshAssocPairSide:
Collaboration diagram for MeshAssocPairSide:Public Member Functions | |
| MeshAssocPairSide (iRel_Instance relation, iBase_Instance instance, int id) | |
| virtual | ~MeshAssocPairSide () |
| virtual iBase_Instance | instance () const |
| virtual iRel_IfaceType | type () const |
| virtual int | create_relation_side () |
| virtual int | destroy_relation_side () |
| virtual int | get_all_entities (int dimension, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size) |
| virtual int | get_all_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size) |
| virtual int | get_entities (int dimension, iBase_EntitySetHandle set_handle, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size) |
| virtual int | get_ents_dims (iBase_EntityHandle *entities, int entities_size, int **ent_types, int *ent_types_alloc, int *ent_types_size) |
| virtual int | get_related_ents (iBase_EntityHandle **entities, int *entities_alloc, int *entities_size) |
| virtual int | get_related_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size) |
| virtual int | get_relation_side (iBase_EntityHandle *entities, int num_entities, void *values) |
| virtual int | get_relation_side (iBase_EntitySetHandle *sets, int num_sets, void *values) |
| virtual int | set_relation_side (iBase_EntityHandle *entities, int num_entities, const void *values) |
| virtual int | set_relation_side (iBase_EntitySetHandle *sets, int num_sets, const void *values) |
| virtual int | rmv_relation_side (iBase_EntityHandle *entities, int num_entities) |
| virtual int | rmv_relation_side (iBase_EntitySetHandle *sets, int num_sets) |
| virtual int | get_iterator (iBase_EntitySetHandle set, iBase_EntityIterator *iter) |
| virtual int | get_gids (iBase_EntityHandle *entities, int num_entities, int *values) |
| virtual int | get_gids (iBase_EntitySetHandle *sets, int num_sets, int *values) |
| virtual int | get_dims (iBase_EntityHandle *entities, int num_entities, int *values) |
| virtual int | get_dims (iBase_EntitySetHandle *sets, int num_sets, int *values) |
Private Attributes | |
| iRel_Instance | relation |
| iMesh_Instance | instance_ |
| int | id |
| iBase_TagHandle | relation_tag |
| iBase_TagHandle | gid_tag |
| iBase_TagHandle | dim_tag |
Definition at line 7 of file MeshAssocPairSide.hpp.
| MeshAssocPairSide::MeshAssocPairSide | ( | iRel_Instance | relation, |
| iBase_Instance | instance, | ||
| int | id | ||
Definition at line 31 of file MeshAssocPairSide.cpp.
References create_relation_side(), dim_tag, gid_tag, GLOBAL_ID_TAG_NAME, iBase_INTEGER, iBase_TAG_NOT_FOUND, iMesh_createTag, iMesh_getTagHandle, instance_, and MESH_DIMENSION_TAG_NAME.
: relation( p_relation ), instance_( reinterpret_cast< iMesh_Instance >( p_instance ) ), id( p_id ) { int result; create_relation_side(); iMesh_getTagHandle( instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result, strlen( GLOBAL_ID_TAG_NAME ) ); if( result == iBase_TAG_NOT_FOUND ) { iMesh_createTag( instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER, &gid_tag, &result, strlen( GLOBAL_ID_TAG_NAME ) ); } iMesh_getTagHandle( instance_, MESH_DIMENSION_TAG_NAME, &dim_tag, &result, strlen( MESH_DIMENSION_TAG_NAME ) ); if( result == iBase_TAG_NOT_FOUND ) dim_tag = NULL; }
| MeshAssocPairSide::~MeshAssocPairSide | ( | ) | [virtual] |
Definition at line 49 of file MeshAssocPairSide.cpp.
References destroy_relation_side().
destroy_relation_side();
| int MeshAssocPairSide::create_relation_side | ( | ) | [virtual] |
Implements AssocPairSide.
Definition at line 64 of file MeshAssocPairSide.cpp.
References iBase_ENTITY_HANDLE, iBase_SUCCESS, iBase_TAG_NOT_FOUND, id, iMesh_createTag, iMesh_getTagHandle, instance_, PROCESS_ERROR, relation_tag, RELATION_TAG_NAME, and RETURNR.
Referenced by MeshAssocPairSide().
int result;
std::stringstream ss;
ss << RELATION_TAG_NAME << id;
std::string rel_tag_name( ss.str() );
iMesh_getTagHandle( instance_, rel_tag_name.c_str(), &relation_tag, &result, rel_tag_name.size() );
iMesh_createTag( instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE, &relation_tag, &result,
PROCESS_ERROR;
RETURNR( iBase_SUCCESS );
| int MeshAssocPairSide::destroy_relation_side | ( | ) | [virtual] |
Definition at line 82 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_destroyTag, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
Referenced by ~MeshAssocPairSide().
if( relation_tag )
int result;
iMesh_destroyTag( instance_, relation_tag, true, &result );
relation_tag = NULL;
PROCESS_ERROR;
| int MeshAssocPairSide::get_all_entities | ( | int | dimension, |
| iBase_EntityHandle ** | entities, | ||
| int * | entities_alloc, | ||
| int * | entities_size | ||
| ) | [virtual] |
Definition at line 96 of file MeshAssocPairSide.cpp.
References iBase_ALL_TYPES, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_getEntities, instance_, PROCESS_ERROR, and RETURNR.
int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension );
int result;
iMesh_getEntities( instance_, 0, this_type, iMesh_ALL_TOPOLOGIES, entities, entities_alloc, entities_size,
&result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_all_sets | ( | iBase_EntitySetHandle ** | sets, |
| int * | sets_alloc, | ||
| int * | sets_size | ||
| ) | [virtual] |
Definition at line 110 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_getEntSets, instance_, PROCESS_ERROR, and RETURNR.
int result;
iMesh_getEntSets( instance_, 0, 0, sets, sets_alloc, sets_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_dims | ( | iBase_EntityHandle * | entities, |
| int | num_entities, | ||
| int * | values | ||
| ) | [virtual] |
Definition at line 275 of file MeshAssocPairSide.cpp.
References dim_tag, iBase_SUCCESS, iMesh_getArrData, instance_, PROCESS_ERROR, and RETURNR.
int values_alloc = num_entities * sizeof( int );
int values_size;
int result;
iMesh_getArrData( instance_, entities, num_entities, dim_tag, &values, &values_alloc, &values_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_dims | ( | iBase_EntitySetHandle * | sets, |
| int | num_sets, | ||
| int * | values | ||
| ) | [virtual] |
Definition at line 286 of file MeshAssocPairSide.cpp.
References dim_tag, iBase_SUCCESS, iMesh_getEntSetData, instance_, PROCESS_ERROR, and RETURNR.
char* data = reinterpret_cast< char* >( values );
int values_alloc = sizeof( int );
int values_size;
int result;
for( int i = 0; i < num_sets; i++ )
iMesh_getEntSetData( instance_, sets[i], dim_tag, reinterpret_cast< void** >( &data ), &values_alloc,
data += values_size;
PROCESS_ERROR;
| int MeshAssocPairSide::get_entities | ( | int | dimension, |
| iBase_EntitySetHandle | set_handle, | ||
| ) | [virtual] |
Definition at line 119 of file MeshAssocPairSide.cpp.
int result;
iMesh_getEntities( instance_, set_handle, this_type, iMesh_ALL_TOPOLOGIES, entities, entities_alloc, entities_size,
&result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_ents_dims | ( | iBase_EntityHandle * | entities, |
| int | entities_size, | ||
| int ** | ent_types, | ||
| int * | ent_types_alloc, | ||
| int * | ent_types_size | ||
| ) | [virtual] |
Definition at line 134 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_getEntArrType, instance_, PROCESS_ERROR, and RETURNR.
int result;
iMesh_getEntArrType( instance_, entities, entities_size, ent_types, ent_types_alloc, ent_types_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_gids | ( | iBase_EntityHandle * | entities, |
| int * | values | ||
| ) | [virtual] |
Definition at line 247 of file MeshAssocPairSide.cpp.
References gid_tag, iBase_SUCCESS, iMesh_getArrData, instance_, PROCESS_ERROR, and RETURNR.
int values_size;
int result;
iMesh_getArrData( instance_, entities, num_entities, gid_tag, &values, &values_alloc, &values_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_gids | ( | iBase_EntitySetHandle * | sets, |
| int * | values | ||
| ) | [virtual] |
Definition at line 258 of file MeshAssocPairSide.cpp.
References gid_tag, iBase_SUCCESS, iMesh_getEntSetData, instance_, PROCESS_ERROR, and RETURNR.
int values_size;
int result;
iMesh_getEntSetData( instance_, sets[i], gid_tag, reinterpret_cast< void** >( &data ), &values_alloc,
PROCESS_ERROR;
| int MeshAssocPairSide::get_iterator | ( | iBase_EntitySetHandle | set, |
| iBase_EntityIterator * | iter | ||
| ) | [virtual] |
Definition at line 239 of file MeshAssocPairSide.cpp.
References iBase_ALL_TYPES, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_initEntIter, instance_, and RETURNR.
int result;
int resilient = 0;
iMesh_initEntIter( instance_, set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, resilient, iter, &result );
| int MeshAssocPairSide::get_related_ents | ( | iBase_EntityHandle ** | entities, |
| ) | [virtual] |
Definition at line 147 of file MeshAssocPairSide.cpp.
References iBase_ALL_TYPES, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_getEntsByTagsRec, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int result;
iMesh_getEntsByTagsRec( instance_, 0, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &relation_tag, NULL, 1, false,
entities, entities_alloc, entities_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_related_sets | ( | iBase_EntitySetHandle ** | sets, |
| ) | [virtual] |
Definition at line 156 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_getEntSetsByTagsRec, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int result;
iMesh_getEntSetsByTagsRec( instance_, 0, &relation_tag, NULL, 1, false, sets, sets_alloc, sets_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_relation_side | ( | iBase_EntityHandle * | entities, |
| void * | values | ||
| ) | [virtual] |
Definition at line 164 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_getArrData, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int values_alloc = num_entities * sizeof( iBase_EntityHandle );
int values_size;
int result;
iMesh_getArrData( instance_, entities, num_entities, relation_tag, &values, &values_alloc, &values_size, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::get_relation_side | ( | iBase_EntitySetHandle * | sets, |
| ) | [virtual] |
Definition at line 175 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_getEntSetData, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
char* data = static_cast< char* >( values );
int values_alloc = sizeof( iBase_EntityHandle );
int values_size;
int result;
iMesh_getEntSetData( instance_, sets[i], relation_tag, reinterpret_cast< void** >( &data ), &values_alloc,
PROCESS_ERROR;
| iBase_Instance MeshAssocPairSide::instance | ( | ) | const [virtual] |
Definition at line 54 of file MeshAssocPairSide.cpp.
References instance_.
return instance_;
| int MeshAssocPairSide::rmv_relation_side | ( | iBase_EntityHandle * | entities, |
| int | num_entities | ||
| ) | [virtual] |
Definition at line 217 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_rmvArrTag, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int result;
iMesh_rmvArrTag( instance_, entities, num_entities, relation_tag, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::rmv_relation_side | ( | iBase_EntitySetHandle * | sets, |
| int | num_sets | ||
| ) | [virtual] |
Definition at line 226 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_rmvEntSetTag, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int result;
iMesh_rmvEntSetTag( instance_, sets[i], relation_tag, &result );
PROCESS_ERROR;
| int MeshAssocPairSide::set_relation_side | ( | iBase_EntityHandle * | entities, |
| const void * | values | ||
| ) | [virtual] |
Definition at line 192 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_setArrData, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
int result;
iMesh_setArrData( instance_, entities, num_entities, relation_tag, static_cast< const char* >( values ),
num_entities * sizeof( iBase_EntityHandle ), &result );
PROCESS_ERROR;
| int MeshAssocPairSide::set_relation_side | ( | iBase_EntitySetHandle * | sets, |
| ) | [virtual] |
Definition at line 202 of file MeshAssocPairSide.cpp.
References iBase_SUCCESS, iMesh_setEntSetData, instance_, PROCESS_ERROR, relation_tag, RETURNR, and size.
const char* data = static_cast< const char* >( values );
int size = sizeof( iBase_EntityHandle );
int result;
iMesh_setEntSetData( instance_, sets[i], relation_tag, data, size, &result );
data += size;
PROCESS_ERROR;
| iRel_IfaceType MeshAssocPairSide::type | ( | ) | const [virtual] |
Definition at line 59 of file MeshAssocPairSide.cpp.
References iRel_IMESH_IFACE.
return iRel_IMESH_IFACE;
iBase_TagHandle MeshAssocPairSide::dim_tag [private] |
Definition at line 65 of file MeshAssocPairSide.hpp.
Referenced by get_dims(), and MeshAssocPairSide().
iBase_TagHandle MeshAssocPairSide::gid_tag [private] |
Definition at line 64 of file MeshAssocPairSide.hpp.
Referenced by get_gids(), and MeshAssocPairSide().
int MeshAssocPairSide::id [private] |
Definition at line 61 of file MeshAssocPairSide.hpp.
Referenced by create_relation_side().
iMesh_Instance MeshAssocPairSide::instance_ [private] |
Definition at line 60 of file MeshAssocPairSide.hpp.
Referenced by create_relation_side(), destroy_relation_side(), get_all_entities(), get_all_sets(), get_dims(), get_entities(), get_ents_dims(), get_gids(), get_iterator(), get_related_ents(), get_related_sets(), get_relation_side(), instance(), MeshAssocPairSide(), rmv_relation_side(), and set_relation_side().
iRel_Instance MeshAssocPairSide::relation [private] |
Definition at line 59 of file MeshAssocPairSide.hpp.
Definition at line 63 of file MeshAssocPairSide.hpp.
Referenced by create_relation_side(), destroy_relation_side(), get_related_ents(), get_related_sets(), get_relation_side(), rmv_relation_side(), and set_relation_side().
