Mesh Oriented datABase
(version 5.4.1)
#include <ReadDamsel.hpp>
Inheritance diagram for moab::ReadDamsel:
Collaboration diagram for moab::ReadDamsel:Classes | |
| class | subrange |
Public Member Functions | |
| ErrorCode | load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) |
| Load an NC file. | |
| ReadDamsel (Interface *impl=NULL) | |
| Constructor. | |
| virtual | ~ReadDamsel () |
| Destructor. | |
| virtual ErrorCode | read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) |
| Read tag values from a file. | |
Static Public Member Functions | |
| static ReaderIface * | factory (Interface *) |
Private Member Functions | |
| ErrorCode | get_contents (damsel_model m, damsel_container c, Range &ents) |
| Get contents of the container (containing file-side handles) and translate to moab-side handles. | |
| ErrorCode | get_contents (damsel_model m, damsel_container c, EntityHandle *ents) |
| Get contents of the container (containing file-side handles) and translate to moab-side handles ents argument should point to already-allocated space. | |
| ErrorCode | init () |
| ErrorCode | parse_options (const FileOptions &opts, bool ¶llel) |
| ErrorCode | process_tags (std::vector< damsel_tag_buf_type > &tag_infos) |
| ErrorCode | process_ent_info (const damsel_entity_buf_type &einfo) |
| ErrorCode | process_entity_tags (int count, damsel_container tag_container, damsel_container app_cont, Range &these_ents) |
| ErrorCode | process_coll_infos (std::vector< damsel_collection_buf_type > &coll_infos) |
| ErrorCode | container_to_handle_pairs (damsel_container &cont, std::vector< damsel_handle > &handle_pairs) |
| Convert handles in a container into handle pairs, one pair per contiguous sequence of handles in the container. | |
| ErrorCode | insert_into_map (std::vector< damsel_handle > &handle_pairs, EntityHandle start_handle) |
| Store MOAB handles starting from start_handle, corresponding to store handles in handle_pairs, into the entity map. | |
Private Attributes | |
| Interface * | mbImpl |
| Interface instance. | |
| ReadUtilIface * | readMeshIface |
| UtilIface. | |
| std::string | fileName |
| File name. | |
| bool | nativeParallel |
| Whether this reader natively supports parallel semantics. | |
| ParallelComm * | myPcomm |
| Parallel info. | |
| Tag | mGlobalIdTag |
| Used to track file handles. | |
| RangeMap< damsel_handle, EntityHandle, 0 > | dmHandleRMap |
| map from damsel to moab handles | |
| DamselUtil | dU |
| Keep various damsel data. | |
Definition at line 36 of file ReadDamsel.hpp.
| moab::ReadDamsel::ReadDamsel | ( | Interface * | impl = NULL | ) |
Constructor.
Definition at line 30 of file ReadDamsel.cpp.
References init().
Referenced by factory().
: mbImpl( impl ), readMeshIface( NULL ), nativeParallel( false ), myPcomm( NULL ), mGlobalIdTag( 0 ), dU() { init(); }
| moab::ReadDamsel::~ReadDamsel | ( | ) | [virtual] |
Destructor.
Definition at line 36 of file ReadDamsel.cpp.
References moab::DamselUtil::dmslLib, dU, mbImpl, readMeshIface, and moab::Interface::release_interface().
if( readMeshIface ) mbImpl->release_interface( readMeshIface );
DMSLlib_finalize( dU.dmslLib );
| ErrorCode moab::ReadDamsel::container_to_handle_pairs | ( | damsel_container & | cont, |
| std::vector< damsel_handle > & | handle_pairs | ||
| ) | [private] |
| ReaderIface * moab::ReadDamsel::factory | ( | Interface * | iface | ) | [static] |
Definition at line 25 of file ReadDamsel.cpp.
References ReadDamsel().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
return new ReadDamsel( iface );
| ErrorCode moab::ReadDamsel::get_contents | ( | damsel_model | m, |
| damsel_container | c, | ||
| Range & | ents | ||
| ) | [private] |
Definition at line 433 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, dmHandleRMap, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::Range::insert(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), and MB_SUCCESS.
Referenced by get_contents(), and process_ent_info().
EntityHandle eh;
if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_SEQUENCE )
damsel_handle start;
size_t count, stride;
damsel_err_t err = DMSLcontainer_sequence_get_contents( m, c, &start, &count, &stride );
CHK_DMSL_ERR( err, "DMSLcontainer_sequence_get_contents" );
if( stride == 1 )
while( count )
// Get start in rangemap
RangeMap< damsel_handle, EntityHandle, 0 >::iterator beg = dmHandleRMap.lower_bound( start );
if( beg == dmHandleRMap.end() ) return MB_SUCCESS;
unsigned long diff = std::max( ( *beg ).begin - start, (damsel_handle)0 );
unsigned long num = std::min( count - diff, (size_t)( *beg ).count );
ents.insert( ( *beg ).begin + diff, ( *beg ).begin + diff + num - 1 );
count -= ( diff + num );
++beg;
else
for( int i = count - 1; i >= 0; i-- )
if( dmHandleRMap.find( start + i, eh ) ) ents.insert( eh );
else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_VECTOR )
damsel_handle* handle_ptr;
size_t count;
damsel_err_t err = DMSLcontainer_vector_get_contents( m, c, &handle_ptr, &count );
CHK_DMSL_ERR( err, "Trouble getting vector contents" );
if( dmHandleRMap.find( handle_ptr[i], eh ) ) ents.insert( eh );
else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_TREE )
damsel_handle_ptr node_ptr = NULL;
damsel_container cont = NULL;
while( DMSLcontainer_tree_get_contents( m, c, &node_ptr, &cont ) == DMSL_OK && cont )
ErrorCode rval = get_contents( m, c, ents );
if( MB_SUCCESS != rval ) return rval;
return MB_SUCCESS;
| EntityHandle * | ents | ||
| ) | [private] |
Definition at line 489 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, dmHandleRMap, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), get_contents(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), and MB_SUCCESS.
EntityHandle eh;
int ind = 0;
CHK_DMSL_ERR( err, "Problem calling DMSLcontainer_sequence_get_contents" );
if( stride == 1 )
while( count )
unsigned int diff = std::max( ( *beg ).begin - start, (damsel_handle)0 );
unsigned int num = std::min( count - diff, (size_t)( *beg ).count );
for( EntityHandle hdl = ( *beg ).begin + diff; hdl <= (int)( *beg ).begin + diff + num - 1; hdl++ )
ents[ind++] = hdl;
++beg;
else
if( dmHandleRMap.find( start + i, eh ) ) ents[i] = eh;
damsel_handle_ptr handle_ptr;
size_t count;
CHK_DMSL_ERR( err, "Failed to get vector contents" );
if( dmHandleRMap.find( handle_ptr[i], eh ) ) ents[i] = eh;
ErrorCode rval = get_contents( m, cont, ents );
unsigned int num = DMSLcontainer_count( cont );
ents += num;
return MB_SUCCESS;
| ErrorCode moab::ReadDamsel::init | ( | ) | [private] |
Definition at line 43 of file ReadDamsel.cpp.
References MB_SUCCESS, mbImpl, moab::Interface::query_interface(), and readMeshIface.
Referenced by ReadDamsel().
mbImpl->query_interface( readMeshIface );
assert( readMeshIface );
return MB_SUCCESS;
| ErrorCode moab::ReadDamsel::insert_into_map | ( | std::vector< damsel_handle > & | handle_pairs, |
| EntityHandle | start_handle | ||
| ) | [private] |
| ErrorCode moab::ReadDamsel::load_file | ( | const char * | file_name, |
| const EntityHandle * | file_set, | ||
| const FileOptions & | opts, | ||
| const SubsetList * | subset_list = 0, |
| const Tag * | file_id_tag = 0 |
| ) | [virtual] |
Load an NC file.
Implements moab::ReaderIface.
Definition at line 70 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, moab::DamselUtil::dmslLib, moab::DamselUtil::dmslModel, dU, ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, myPcomm, nativeParallel, parse_options(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), process_ent_info(), and process_tags().
ErrorCode rval;
rval = parse_options( opts, nativeParallel );
// Initialize damsel
dU.dmslLib = DMSLlib_init();
// Create a damsel model
dU.dmslModel =
DMSLmodel_create( sizeof( EntityHandle ) == 8 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 );
// Model attach - need model id from make model, filename
#ifdef MOAB_HAVE_MPI
MPI_Comm comm = MPI_COMM_WORLD;
if( nativeParallel )
comm = myPcomm->proc_config().proc_comm();
#endif
damsel_err_t err;
err = DMSLmodel_attach( dU.dmslModel, filename, comm, NULL );
CHK_DMSL_ERR( err, "DMSLmodel_attach failed" );
err = DMSLmodel_populate( dU.dmslModel );
CHK_DMSL_ERR( err, "DMSLmodel_populate failed" );
// STEP 0: GET COLLECTION, TAG, ENTITY INFOS FOR GLOBAL MODEL
int num_containers = 0, num_tag_infos = 0, num_ent_infos = 0;
DMSLmodel_get_tuple_count( dU.dmslModel, &num_containers, &num_tag_infos );
num_ent_infos = DMSLmodel_get_entity_count( dU.dmslModel );
int num_coll_infos = DMSLmodel_get_collection_count( dU.dmslModel );
CHK_DMSL_ERR( err, "DMSLmodel_get_collection_count failed" );
if( -1 == num_containers || -1 == num_tag_infos || -1 == num_ent_infos )
MB_SET_ERR( MB_FAILURE, "Bad count for containers/tags/ents" );
std::vector< damsel_entity_buf_type > ent_infos( num_ent_infos );
std::vector< damsel_collection_buf_type > coll_infos( num_coll_infos );
std::vector< damsel_tag_buf_type > tag_infos( num_tag_infos );
std::vector< damsel_container_buf_type > cont_infos( num_containers );
err = DMSLmodel_get_entity_infos( dU.dmslModel, &ent_infos[0] );
CHK_DMSL_ERR( err, "Failure getting entity infos" );
err = DMSLmodel_get_collection_infos( dU.dmslModel, &coll_infos[0] );
CHK_DMSL_ERR( err, "Failure getting collection infos" );
err = DMSLmodel_get_tag_infos( dU.dmslModel, &tag_infos[0] );
CHK_DMSL_ERR( err, "Failure getting tag infos" );
err = DMSLmodel_get_container_infos( dU.dmslModel, &cont_infos[0] );
CHK_DMSL_ERR( err, "Failure getting container infos" );
// Create MOAB-side tags for all damsel tags except pre-defined ones
rval = process_tags( tag_infos );MB_CHK_SET_ERR( rval, "Error processing tags" );
if (nativeParallel) {
// STEP 1: GET COLLECTION(S) REPRESENTING PARTITION:
// Input: tag name, optionally value;
// Output: container with file-side handles of collections satisfying those criteria
// - Get all handles/values for tag
// - Select handles matching criteria for tag value (will be collection handles)
std::string partn_tag_name("PARALLEL_PARTITION");
damsel_handle partn_tag = DMSLselect_tag_by_name(dU.dmslModel, partn_tag_name.c_str());
// Get all the parts with that tag regardless of value
damsel_container part_handles = DMSLselect_handles_with_values(dU.dmslModel, partn_tag);
// STEP 2: GET HANDLES FOR TAGS WE NEED FOR THIS READER:
// - "SET_CHARACTERISTIC"
damsel_handle setchar_tag = DMSLselect_tag_by_name(dU.dmslModel, "SET_CHARACTERISTIC");
// - "PARENT_LIST"
//damsel_handle plist_tag = DMSLselect_tag_by_name(dU.dmslModel, "PARENT_LIST");
// - "CHILD_LIST"
//damsel_handle clist_tag = DMSLselect_tag_by_name(dU.dmslModel, "CHILD_LIST");
// STEP 3: GET VALUES FOR "SET_CHARACTERISTIC" TAG ON PARTITION COLLECTIONS,
// GET VECTOR- OR SET-TYPE FLAGS FOR PARTITION COLLECTIONS
// (gives tracking flag for moab)
int num_handles = DMSLcontainer_count(part_handles);
std::vector<unsigned> char_tagvals(num_handles);
// Map the set chars
err = DMSLmodel_map_tag(&char_tagvals[0], part_handles, &setchar_tag);CHK_DMSL_ERR(err,
"Problem calling DMSLmodel_map_tag");
// Execute the transfer
err = DMSLmodel_transfer_sync(dU.dmslModel, DAMSEL_TRANSFER_TYPE_READ);CHK_DMSL_ERR(err,
"Problem calling DMSLmodel_transfer_sync");
// STEP 4: READ/PROCESS PARTITION COLLECTION(S)
// Decide the handles I am responsible using round-robin for now
// - GET TYPE, CONTENTS OF COLLECTION CONTENTS CONTAINER
// - Allocate moab-side container (using count from container)
// - MAP storage TO CONTAINER
// - EXECUTE
// ==> have list of all handles (entities + collections) represented on this proc
int tmp_num = num_handles / proc_size, extra = num_handles % proc_size;
if (extra) tmp_num++;
int my_num_handles = tmp_num;
if (proc_rank >= extra) my_num_handles--;
int first_ind = std::min(proc_rank, extra) * tmp_num +
std::max(proc_rank - extra, 0) * (tmp_num - 1);
// - Create moab entity sets for partition collection(s)
EntityHandle start_handle;
rval = readMeshIface->create_entity_sets(my_num_handles, &char_tagvals[first_ind], 0,
start_handle);MB_CHK_SET_ERR(rval, "Problem creating entity sets");
else {
// Initialize just by entity; each call to process_ent_info will:
// a. Create moab-side representation to read into
// b. Map those handles to damsel handles
// c. Map coords / connectivity storage to damsel equivalent
// d. For each tag, map moab storage to damsel storage
std::vector< damsel_entity_buf_type >::iterator eiit;
// Process verts info first
for( eiit = ent_infos.begin(); eiit != ent_infos.end(); ++eiit )
if( ( *eiit ).entity_type == DAMSEL_ENTITY_TYPE_VERTEX )
rval = process_ent_info( *eiit );MB_CHK_ERR( rval );
if( ( *eiit ).entity_type != DAMSEL_ENTITY_TYPE_VERTEX )
// Process collections
rval = process_coll_infos(coll_infos);MB_CHK_ERR(rval);
// STEP 5: Process into list of local info structs, each represents file-side struct and
// portion of that struct
// ASSUMPTION: Each local info struct represents single entity type & # vertices or collection
// STEP 6: For each local info struct:
// STEP 6b: READ CONTAINER INTO LOCAL BUFFER
// STEP 6c: Create app representation of entities/vertices/collection, and damsel container
for them,
// and MAP APP HANDLE CONTAINER TO DAMSEL CONTAINER
// STEP 6d: Process vertices/entities/collection
// 6d1: If vertices, continue
// 6d2: If entities:
// - MAP LOCAL CONNECTIVITY REP'N TO DAMSEL (might be tag, don't know yet)
// 6d3: If collection:
// - (everything in STEP 4 for this collection except for EXECUTE)
// - might need to filter out things not represented on this rank
// 6d4: If sparse tag:
// - Create app-side representation of sparse tag
// - READ CONTAINER OF MODEL HANDLES INTO LOCAL BUFFER
// - Allocate app-side storage for tag values
// - MAP APP STORAGE TO MODEL TAG + (implicit?) CONTAINER
// STEP 6e: Process dense tags for the local info struct; for each dense tag:
// - Get app tag handle for model tag handle
// - Get app storage for app tag handle + container
// - MAP APP STORAGE TO MODEL TAG + CONTAINER
// STEP 7: EXECUTE
// - Assign all mapped data
// - Translate all damsel handles to app handles
// uninit damsel
return MB_SUCCESS;
| ErrorCode moab::ReadDamsel::parse_options | ( | const FileOptions & | opts, |
| bool & | parallel | ||
| ) | [private] |
Definition at line 51 of file ReadDamsel.cpp.
References ErrorCode, moab::FileOptions::get_null_option(), moab::FileOptions::match_option(), MB_ENTITY_NOT_FOUND, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, and nativeParallel.
Referenced by load_file().
// Handle parallel options
bool use_mpio = ( MB_SUCCESS == opts.get_null_option( "USE_MPIO" ) );
ErrorCode rval = opts.match_option( "PARALLEL", "READ_PART" );
parallel = ( rval != MB_ENTITY_NOT_FOUND );
nativeParallel = ( rval == MB_SUCCESS );
if( use_mpio && !parallel )
MB_SET_ERR( MB_NOT_IMPLEMENTED, "'USE_MPIO' option specified w/out 'PARALLEL' option" );
return MB_SUCCESS;
| ErrorCode moab::ReadDamsel::process_coll_infos | ( | std::vector< damsel_collection_buf_type > & | coll_infos | ) | [private] |
| ErrorCode moab::ReadDamsel::process_ent_info | ( | const damsel_entity_buf_type & | einfo | ) | [private] |
Definition at line 317 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, moab::DamselUtil::container_to_range(), dmHandleRMap, moab::DamselUtil::dmslModel, moab::DamselUtil::dtom_entity_type, dU, ErrorCode, get_contents(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), moab::Range::insert(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, moab::DamselUtil::tinfo::mTagh, process_entity_tags(), moab::Range::psize(), readMeshIface, moab::Range::size(), moab::DamselUtil::xcoordsTag, moab::DamselUtil::ycoordsTag, and moab::DamselUtil::zcoordsTag.
// Create this chunk of entities
EntityHandle *connect, start_handle;
ErrorCode rval;
damsel_err_t err;
damsel_container app_cont;
Range these_ents;
// Check that there's only one contiguous run of file-side handles, fail if there isn't
#ifndef NDEBUG
Range fside_handles;
rval = DamselUtil::container_to_range( dU.dmslModel, const_cast< damsel_container& >( einfo.entity_container ),
fside_handles );
if( MB_SUCCESS != rval || fside_handles.size() != einfo.count || fside_handles.psize() != 1 ) return MB_FAILURE;
#endif
if( einfo.entity_type != DAMSEL_ENTITY_TYPE_VERTEX )
// Create the moab entities
rval = readMeshIface->get_element_connect( einfo.count, einfo.vertices_per_entity,
DamselUtil::dtom_entity_type[einfo.entity_type], 0, start_handle,
connect );MB_CHK_ERR( rval );
these_ents.insert( start_handle, start_handle + einfo.count - 1 );
// Create an app-side sequence and map to file-side container
app_cont = DMSLcontainer_create_sequence( dU.dmslModel, einfo.count, start_handle, 1 );
err = DMSLmodel_map_handles( app_cont, einfo.entity_container );
CHK_DMSL_ERR( err, "Error returned mapping entity handles" );
// Map connectivity
assert( DMSLcontainer_count( einfo.vertex_container ) == (int)( einfo.vertices_per_entity * einfo.count ) );
rval = get_contents( dU.dmslModel, einfo.vertex_container, connect );MB_CHK_SET_ERR( rval, "Error returned mapping connectivity" );
else
// Get the number of coordinate arrays
int num_ctags = 0;
damsel_handle xcoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_XCOORDS" );
if( xcoord_dtag ) num_ctags++;
damsel_handle ycoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_YCOORDS" );
if( ycoord_dtag ) num_ctags++;
damsel_handle zcoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_ZCOORDS" );
if( zcoord_dtag ) num_ctags++;
// Should have one vertex per entity
assert( einfo.vertices_per_entity == 1 );
std::vector< double* > coord_arrays;
rval = readMeshIface->get_node_coords( num_ctags, einfo.count, 0, start_handle, coord_arrays );MB_CHK_ERR( rval );
app_cont = DMSLcontainer_create_sequence( dU.dmslModel, start_handle, einfo.count, 1 );
CHK_DMSL_ERR( err, "Trouble mapping entity handles" );
// Map the coords storage
if( xcoord_dtag != 0 )
err = DMSLmodel_map_tag( coord_arrays[0], app_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh );
CHK_DMSL_ERR( err, "Trouble mapping x coordinate tag" );
if( ycoord_dtag != 0 )
err = DMSLmodel_map_tag( coord_arrays[1], app_cont, (damsel_handle_ptr)&dU.ycoordsTag.mTagh );
CHK_DMSL_ERR( err, "Trouble mapping y coordinate tag" );
if( zcoord_dtag != 0 )
err = DMSLmodel_map_tag( coord_arrays[2], app_cont, (damsel_handle_ptr)&dU.zcoordsTag.mTagh );
CHK_DMSL_ERR( err, "Trouble mapping z coordinate tag" );
// Save mapping from moab entity to einfo
dmHandleRMap.insert( DMSLcontainer_handle_at_position( einfo.entity_container, 0 ), start_handle, einfo.count );
rval = process_entity_tags( einfo.tag_count, einfo.tag_handle_container, app_cont, these_ents );
return rval;
| ErrorCode moab::ReadDamsel::process_entity_tags | ( | int | count, |
| damsel_container | tag_container, | ||
| damsel_container | app_cont, | ||
| Range & | these_ents | ||
| ) | [private] |
Definition at line 400 of file ReadDamsel.cpp.
References moab::Range::begin(), CHK_DMSL_ERR, dU, moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_ANY, mbImpl, moab::Range::size(), moab::Interface::tag_iterate(), and moab::DamselUtil::tagMap.
Referenced by process_ent_info().
// Process tags on these entities
ErrorCode rval = MB_SUCCESS;
for( int i = 0; i < count; i++ )
damsel_handle dtagh = DMSLcontainer_handle_at_position( tag_container, i );
// Don't do conventional tags here
std::vector< DamselUtil::tinfo >::iterator vit =
std::find_if( dU.tagMap.begin(), dU.tagMap.end(), DamselUtil::DtagP< DamselUtil::tinfo >( dtagh ) );
if( ( *vit ).tagType == MB_TAG_ANY )
continue;
else if( vit == dU.tagMap.end() )
MB_SET_ERR( MB_FAILURE, "Failed to find tag" );
Tag tagh = ( *vit ).mTagh;
assert( tagh );
void* tag_data;
int ecount = these_ents.size();
rval = mbImpl->tag_iterate( tagh, these_ents.begin(), these_ents.end(), ecount, tag_data );MB_CHK_SET_ERR( rval, "Problem getting tag iterator" );
assert( ecount == (int)these_ents.size() );
damsel_err_t err = DMSLmodel_map_tag( tag_data, app_cont, (damsel_handle_ptr)&tagh );
CHK_DMSL_ERR( err, "Problem calling DMSLmodel_map_tag" );
return rval;
| ErrorCode moab::ReadDamsel::process_tags | ( | std::vector< damsel_tag_buf_type > & | tag_infos | ) | [private] |
Definition at line 260 of file ReadDamsel.cpp.
References moab::DamselUtil::childrenTag, moab::DamselUtil::collFlagsTag, moab::DamselUtil::dtom_data_type, dU, ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, mbImpl, moab::DamselUtil::parentsTag, moab::Interface::tag_get_handle(), moab::DamselUtil::tagMap, moab::DamselUtil::xcoordsTag, moab::DamselUtil::ycoordsTag, and moab::DamselUtil::zcoordsTag.
Tag tagh;
ErrorCode rval = MB_SUCCESS, tmp_rval;
for( std::vector< damsel_tag_buf_type >::iterator tit = tag_infos.begin(); tit != tag_infos.end(); ++tit )
if( DamselUtil::dtom_data_type[( *tit ).tag_datatype] == MB_TYPE_OPAQUE )
std::cout << "Damsel reader encountered opaque tag." << std::endl;
continue;
tmp_rval = mbImpl->tag_get_handle( ( *tit ).name, 1, DamselUtil::dtom_data_type[( *tit ).tag_datatype], tagh,
MB_TAG_CREAT | MB_TAG_DENSE );
if( MB_SUCCESS != tmp_rval )
rval = tmp_rval;
else
dU.tagMap.push_back( DamselUtil::tinfo( tagh, 0, MB_TAG_DENSE ) );
// Also store predefined tags specially...
if( !strncmp( ( *tit ).name, "mbdmsl_", 7 ) )
// Predefined tag name, store the handle
if( !strcmp( ( *tit ).name, "mbdmsl_XCOORDS" ) )
dU.xcoordsTag = dU.tagMap.back();
else if( !strcmp( ( *tit ).name, "mbdmsl_YCOORDS" ) )
dU.ycoordsTag = dU.tagMap.back();
else if( !strcmp( ( *tit ).name, "mbdmsl_ZCOORDS" ) )
dU.zcoordsTag = dU.tagMap.back();
else if( !strcmp( ( *tit ).name, "mbdmsl_COLL_FLAGS" ) )
dU.collFlagsTag = dU.tagMap.back();
else if( !strcmp( ( *tit ).name, "mbdmsl_PARENTS" ) )
dU.parentsTag = dU.tagMap.back();
else if( !strcmp( ( *tit ).name, "mbdmsl_CHILDREN" ) )
dU.childrenTag = dU.tagMap.back();
else
rval = MB_FAILURE;
continue;
return rval;
| ErrorCode moab::ReadDamsel::read_tag_values | ( | const char * | file_name, |
| const char * | tag_name, | ||
| std::vector< int > & | tag_values_out, | ||
| const SubsetList * | subset_list = 0 |
| ) | [virtual] |
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
| file_name | The file to read. |
| tag_name | The tag for which to read values |
| tag_values_out | Output: The list of tag values. |
| subset_list | An array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read. |
| subset_list_length | The length of the 'subset_list' array. |
Definition at line 251 of file ReadDamsel.cpp.
return MB_FAILURE;
RangeMap< damsel_handle, EntityHandle, 0 > moab::ReadDamsel::dmHandleRMap [private] |
Definition at line 122 of file ReadDamsel.hpp.
DamselUtil moab::ReadDamsel::dU [private] |
Definition at line 125 of file ReadDamsel.hpp.
Referenced by load_file(), process_ent_info(), process_entity_tags(), process_tags(), and ~ReadDamsel().
std::string moab::ReadDamsel::fileName [private] |
File name.
Definition at line 110 of file ReadDamsel.hpp.
Interface* moab::ReadDamsel::mbImpl [private] |
Interface instance.
Definition at line 104 of file ReadDamsel.hpp.
Referenced by init(), process_entity_tags(), process_tags(), and ~ReadDamsel().
Tag moab::ReadDamsel::mGlobalIdTag [private] |
Definition at line 119 of file ReadDamsel.hpp.
ParallelComm* moab::ReadDamsel::myPcomm [private] |
bool moab::ReadDamsel::nativeParallel [private] |
Definition at line 113 of file ReadDamsel.hpp.
Referenced by load_file(), and parse_options().
ReadUtilIface* moab::ReadDamsel::readMeshIface [private] |
UtilIface.
Definition at line 107 of file ReadDamsel.hpp.
Referenced by init(), process_ent_info(), and ~ReadDamsel().
