Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
| integer(c_int) function | iMOAB_GetVisibleElementsInfo (pid, num_visible_elements, element_global_IDs, ranks, block_IDs) |
Definition at line 178 of file iMOABF.F90.
| integer(c_int) function iMOAB::iMOAB_GetVisibleElementsInfo::iMOAB_GetVisibleElementsInfo | ( | integer(c_int), intent(in) | pid, |
| integer(c_int), intent(out) | num_visible_elements, | ||
| integer(c_int), dimension(*), intent(out) | element_global_IDs, | ||
| integer(c_int), dimension(*), intent(out) | ranks, | ||
| integer(c_int), dimension(*), intent(out) | block_IDs | ||
