Mesh Oriented datABase
(version 5.4.1)
Output Exodus File for VERDE. More...
#include <WriteNCDF.hpp>
Inheritance diagram for moab::WriteNCDF:
Collaboration diagram for moab::WriteNCDF:Classes | |
| struct | ExodusMeshInfo |
| contains the general information about a mesh More... | |
Public Member Functions | |
| WriteNCDF (Interface *impl) | |
| Constructor. | |
| virtual | ~WriteNCDF () |
| Destructor. | |
| ErrorCode | write_file (const char *exodus_file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_records, const Tag *=NULL, int=0, int user_dimension=3) |
| writes out an ExoII file | |
Static Public Member Functions | |
| static WriterIface * | factory (Interface *) |
Protected Member Functions | |
| ErrorCode | open_file (const char *file_name) |
| number of dimensions in this exo file | |
Private Member Functions | |
| ErrorCode | gather_mesh_information (ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_info, std::vector< NeumannSetData > &sideset_info, std::vector< DirichletSetData > &nodeset_info, std::vector< EntityHandle > &blocks, std::vector< EntityHandle > &sidesets, std::vector< EntityHandle > &nodesets) |
| ErrorCode | write_header (ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_info, std::vector< NeumannSetData > &sideset_info, std::vector< DirichletSetData > &nodeset_info, const char *filename) |
| ErrorCode | initialize_exodus_file (ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_data, std::vector< NeumannSetData > &sideset_data, std::vector< DirichletSetData > &nodeset_data, const char *title_string, bool write_maps=true, bool write_sideset_distribution_factors=true) |
| ErrorCode | write_qa_string (const char *string, int record_number, int record_position) |
| ErrorCode | write_qa_records (std::vector< std::string > &qa_record_list) |
| ErrorCode | write_nodes (int num_nodes, Range &nodes, int dimension) |
| ErrorCode | write_poly_faces (ExodusMeshInfo &mesh_info) |
| ErrorCode | write_elementblocks (ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_data) |
| ErrorCode | write_exodus_integer_variable (const char *variable_name, int *variable_array, int start_position, int number_values) |
| ErrorCode | write_global_node_order_map (int num_nodes, Range &nodes) |
| ErrorCode | write_global_element_order_map (int num_elements) |
| ErrorCode | write_element_order_map (int num_elements) |
| ErrorCode | write_BCs (std::vector< NeumannSetData > &sidesets, std::vector< DirichletSetData > &nodesets) |
| ErrorCode | find_side_element_type (const int element_id, ExoIIElementType &type) |
| void | reset_block (std::vector< MaterialSetData > &block_info) |
| free up allocated Ranges | |
| ErrorCode | get_sideset_elems (EntityHandle sideset, int current_sense, Range &forward_elems, Range &reverse_elems) |
| recursive function; given a meshset handle, get the entities and put them on the right list, then call recursively for any contained meshsets, first checking for sense reversals | |
| ErrorCode | get_valid_sides (Range &elems, ExodusMeshInfo &mesh_info, const int sense, NeumannSetData &sideset_data) |
Static Private Member Functions | |
| static void | time_and_date (char *time_string, char *date_string) |
| get the time and date in strings | |
Private Attributes | |
| Interface * | mdbImpl |
| interface instance | |
| WriteUtilIface * | mWriteIface |
| std::string | exodusFile |
| file name | |
| int | ncFile |
| EntityHandle | mCurrentMeshHandle |
| Meshset Handle for the mesh that is currently being read. | |
| Tag | mMaterialSetTag |
| Cached tags for reading. Note that all these tags are defined when the core is initialized. | |
| Tag | mDirichletSetTag |
| Tag | mNeumannSetTag |
| Tag | mHasMidNodesTag |
| Tag | mGeomDimensionTag |
| Tag | mDistFactorTag |
| Tag | mGlobalIdTag |
| Tag | mQaRecordTag |
| Tag | mEntityMark |
| int | repeat_face_blocks |
Definition at line 85 of file WriteNCDF.hpp.
| moab::WriteNCDF::WriteNCDF | ( | Interface * | impl | ) |
Constructor.
Get and cache predefined tag handles
Definition at line 100 of file WriteNCDF.cpp.
References DIRICHLET_SET_TAG_NAME, moab::Interface::globalId_tag(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mDirichletSetTag, mDistFactorTag, mEntityMark, mGlobalIdTag, mHasMidNodesTag, mMaterialSetTag, mNeumannSetTag, mQaRecordTag, mWriteIface, NEUMANN_SET_TAG_NAME, moab::Interface::query_interface(), and moab::Interface::tag_get_handle().
Referenced by factory().
: mdbImpl( impl ), ncFile( 0 ), mCurrentMeshHandle( 0 ), mGeomDimensionTag( 0 ), repeat_face_blocks( 0 ) { assert( impl != NULL ); impl->query_interface( mWriteIface ); // Initialize in case tag_get_handle fails below //! Get and cache predefined tag handles int negone = -1; impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, &negone ); impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, &negone ); impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, &negone ); mGlobalIdTag = impl->globalId_tag(); int dum_val_array[] = { -1, -1, -1, -1 }; impl->tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, mHasMidNodesTag, MB_TAG_SPARSE | MB_TAG_CREAT, dum_val_array ); impl->tag_get_handle( "distFactor", 0, MB_TYPE_DOUBLE, mDistFactorTag, MB_TAG_SPARSE | MB_TAG_VARLEN | MB_TAG_CREAT ); impl->tag_get_handle( "qaRecord", 0, MB_TYPE_OPAQUE, mQaRecordTag, MB_TAG_SPARSE | MB_TAG_VARLEN | MB_TAG_CREAT ); impl->tag_get_handle( "WriteNCDF element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT ); }
| moab::WriteNCDF::~WriteNCDF | ( | ) | [virtual] |
Destructor.
Definition at line 133 of file WriteNCDF.cpp.
References mdbImpl, mEntityMark, mWriteIface, ncFile, moab::Interface::release_interface(), and moab::Interface::tag_delete().
mdbImpl->release_interface( mWriteIface );
mdbImpl->tag_delete( mEntityMark );
if( 0 != ncFile ) ncFile = 0;
| WriterIface * moab::WriteNCDF::factory | ( | Interface * | iface | ) | [static] |
Definition at line 95 of file WriteNCDF.cpp.
References WriteNCDF().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| ErrorCode moab::WriteNCDF::find_side_element_type | ( | const int | element_id, |
| ExoIIElementType & | type | ||
| ) | [private] |
| ErrorCode moab::WriteNCDF::gather_mesh_information | ( | ExodusMeshInfo & | mesh_info, |
| std::vector< MaterialSetData > & | block_info, | ||
| std::vector< NeumannSetData > & | sideset_info, | ||
| std::vector< DirichletSetData > & | nodeset_info, | ||
| std::vector< EntityHandle > & | blocks, | ||
| std::vector< EntityHandle > & | sidesets, | ||
| std::vector< EntityHandle > & | nodesets | ||
| ) | [private] |
Definition at line 364 of file WriteNCDF.cpp.
References moab::Range::all_of_type(), moab::Range::back(), moab::Range::begin(), moab::CN::Dimension(), moab::MaterialSetData::element_type, moab::MaterialSetData::elements, moab::NeumannSetData::elements, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::EXOII_MAX_ELEM_TYPE, moab::EXOII_POLYGON, moab::EXOII_POLYHEDRON, moab::Range::front(), moab::WriteUtilIface::gather_nodes_from_elements(), moab::Interface::get_connectivity(), moab::ExoIIUtil::get_element_type_from_num_verts(), moab::Interface::get_entities_by_handle(), moab::Interface::get_parent_meshsets(), get_sideset_elems(), get_valid_sides(), moab::MaterialSetData::id, moab::DirichletSetData::id, moab::NeumannSetData::id, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TYPE_BIT, MB_TYPE_OUT_OF_RANGE, MBEDGE, MBQUAD, MBTRI, MBVERTEX, mdbImpl, mDirichletSetTag, mDistFactorTag, mEntityMark, moab::NeumannSetData::mesh_set_handle, mMaterialSetTag, mNeumannSetTag, mQaRecordTag, mWriteIface, moab::DirichletSetData::node_dist_factors, moab::DirichletSetData::nodes, moab::WriteNCDF::ExodusMeshInfo::nodes, moab::WriteNCDF::ExodusMeshInfo::num_dim, moab::WriteNCDF::ExodusMeshInfo::num_elementblocks, moab::WriteNCDF::ExodusMeshInfo::num_elements, moab::WriteNCDF::ExodusMeshInfo::num_nodes, moab::WriteNCDF::ExodusMeshInfo::num_polyhedra_blocks, moab::MaterialSetData::number_attributes, moab::MaterialSetData::number_elements, moab::NeumannSetData::number_elements, moab::DirichletSetData::number_nodes, moab::MaterialSetData::number_nodes_per_element, moab::WriteNCDF::ExodusMeshInfo::polyhedronFaces, moab::WriteNCDF::ExodusMeshInfo::qaRecords, size, moab::Range::size(), moab::Range::subset_by_dimension(), moab::subtract(), moab::Interface::tag_delete(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), and moab::ExoIIUtil::VerticesPerElement.
Referenced by write_file().
ErrorCode rval;
std::vector< EntityHandle >::iterator vector_iter, end_vector_iter;
mesh_info.num_nodes = 0;
mesh_info.num_elements = 0;
mesh_info.num_elementblocks = 0;
mesh_info.num_polyhedra_blocks = 0;
int id = 0;
vector_iter = blocks.begin();
end_vector_iter = blocks.end();
std::vector< EntityHandle > parent_meshsets;
// Clean out the bits for the element mark
rval = mdbImpl->tag_delete( mEntityMark );
if( MB_SUCCESS != rval ) return rval;
rval = mdbImpl->tag_get_handle( "WriteNCDF element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
int highest_dimension_of_element_blocks = 0;
for( vector_iter = blocks.begin(); vector_iter != blocks.end(); ++vector_iter )
MaterialSetData block_data;
// For the purpose of qa records, get the parents of these blocks
if( mdbImpl->get_parent_meshsets( *vector_iter, parent_meshsets ) != MB_SUCCESS ) return MB_FAILURE;
// Get all Entity Handles in the mesh set
Range dummy_range;
rval = mdbImpl->get_entities_by_handle( *vector_iter, dummy_range, true );
// Skip empty blocks
if( dummy_range.empty() ) continue;
// Get the block's id
if( mdbImpl->tag_get_data( mMaterialSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
MB_SET_ERR( MB_FAILURE, "Couldn't get block id from a tag for an element block" );
block_data.id = id;
block_data.number_attributes = 0;
// Wait a minute, we are doing some filtering here that doesn't make sense at this level CJS
// Find the dimension of the last entity in this range
int this_dim = CN::Dimension( TYPE_FROM_HANDLE( dummy_range.back() ) );
if( this_dim > 3 )
MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "Block " << id << " contains entity sets" );
block_data.elements = dummy_range.subset_by_dimension( this_dim );
// End of -- wait a minute, we are doing some filtering here that doesn't make sense at this
// level CJS
// Get the entity type for this block, verifying that it's the same for all elements
EntityType entity_type = TYPE_FROM_HANDLE( block_data.elements.front() );
if( !block_data.elements.all_of_type( entity_type ) )
MB_SET_ERR( MB_FAILURE, "Entities in block " << id << " not of common type" );
int dimension = -1;
if( entity_type == MBQUAD || entity_type == MBTRI )
dimension = 2; // Output shells by default
else if( entity_type == MBEDGE )
dimension = 1;
else
dimension = CN::Dimension( entity_type );
if( dimension > highest_dimension_of_element_blocks ) highest_dimension_of_element_blocks = dimension;
std::vector< EntityHandle > tmp_conn;
rval = mdbImpl->get_connectivity( &( block_data.elements.front() ), 1, tmp_conn );
block_data.element_type = ExoIIUtil::get_element_type_from_num_verts( tmp_conn.size(), entity_type, dimension );
if( block_data.element_type == EXOII_MAX_ELEM_TYPE )
MB_SET_ERR( MB_FAILURE, "Element type in block " << id << " didn't get set correctly" );
if( block_data.element_type == EXOII_POLYGON )
// get all poly connectivity
int numconn = 0;
for( Range::iterator eit = block_data.elements.begin(); eit != block_data.elements.end(); eit++ )
EntityHandle polg = *eit;
int nnodes = 0;
const EntityHandle* conn = NULL;
rval = mdbImpl->get_connectivity( polg, conn, nnodes );MB_CHK_ERR( rval );
numconn += nnodes;
block_data.number_nodes_per_element = numconn;
else
block_data.number_nodes_per_element = ExoIIUtil::VerticesPerElement[block_data.element_type];
// Number of nodes for this block
block_data.number_elements = block_data.elements.size();
// Total number of elements
mesh_info.num_elements += block_data.number_elements;
// Get the nodes for the elements
rval = mWriteIface->gather_nodes_from_elements( block_data.elements, mEntityMark, mesh_info.nodes );
// if polyhedra block
if( EXOII_POLYHEDRON == block_data.element_type )
rval = mdbImpl->get_connectivity( block_data.elements, mesh_info.polyhedronFaces );MB_CHK_ERR( rval );
mesh_info.num_polyhedra_blocks++;
if( !sidesets.empty() )
// If there are sidesets, keep track of which elements are being written out
for( Range::iterator iter = block_data.elements.begin(); iter != block_data.elements.end(); ++iter )
unsigned char bit = 0x1;
rval = mdbImpl->tag_set_data( mEntityMark, &( *iter ), 1, &bit );
block_info.push_back( block_data );
const void* data = NULL;
int size = 0;
if( MB_SUCCESS == mdbImpl->tag_get_by_ptr( mQaRecordTag, &( *vector_iter ), 1, &data, &size ) && NULL != data )
// There are qa records on this block - copy over to mesh qa records
const char* qa_rec = static_cast< const char* >( data );
int start = 0;
int count = 0;
for( int i = 0; i < size; i++ )
if( qa_rec[i] == '\0' )
std::string qa_string( &qa_rec[start], i - start );
mesh_info.qaRecords.push_back( qa_string );
start = i + 1;
count++;
// Constrained to multiples of 4 qa records
if( count > 0 ) assert( count % 4 == 0 );
mesh_info.num_elementblocks = block_info.size();
for( std::vector< MaterialSetData >::iterator blit = block_info.begin(); blit != block_info.end(); blit++ )
MaterialSetData& block = *blit;
if( block.element_type != EXOII_POLYHEDRON )
mesh_info.polyhedronFaces = subtract( mesh_info.polyhedronFaces, block.elements );
// If user hasn't entered dimension, we figure it out
if( mesh_info.num_dim == 0 )
// Never want 1 or zero dimensions
if( highest_dimension_of_element_blocks < 2 )
mesh_info.num_dim = 3;
else
mesh_info.num_dim = highest_dimension_of_element_blocks;
Range::iterator range_iter, end_range_iter;
range_iter = mesh_info.nodes.begin();
end_range_iter = mesh_info.nodes.end();
mesh_info.num_nodes = mesh_info.nodes.size();
//------nodesets--------
vector_iter = nodesets.begin();
end_vector_iter = nodesets.end();
for( ; vector_iter != end_vector_iter; ++vector_iter )
DirichletSetData nodeset_data;
nodeset_data.id = 0;
nodeset_data.number_nodes = 0;
// Get the nodeset's id
if( mdbImpl->tag_get_data( mDirichletSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
MB_SET_ERR( MB_FAILURE, "Couldn't get id tag for nodeset " << id );
nodeset_data.id = id;
std::vector< EntityHandle > node_vector;
// Get the nodes of the nodeset that are in mesh_info.nodes
if( mdbImpl->get_entities_by_handle( *vector_iter, node_vector, true ) != MB_SUCCESS )
MB_SET_ERR( MB_FAILURE, "Couldn't get nodes in nodeset " << id );
// Get the tag for distribution factors
const double* dist_factor_vector;
int dist_factor_size;
const void* ptr = 0;
int has_dist_factors = 0;
if( mdbImpl->tag_get_by_ptr( mDistFactorTag, &( *vector_iter ), 1, &ptr, &dist_factor_size ) == MB_SUCCESS &&
dist_factor_size )
has_dist_factors = 1;
dist_factor_size /= sizeof( double );
dist_factor_vector = reinterpret_cast< const double* >( ptr );
std::vector< EntityHandle >::iterator iter, end_iter;
iter = node_vector.begin();
end_iter = node_vector.end();
int j = 0;
unsigned char node_marked = 0;
ErrorCode result;
for( ; iter != end_iter; ++iter )
if( TYPE_FROM_HANDLE( *iter ) != MBVERTEX ) continue;
result = mdbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &node_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
if( 0x1 == node_marked )
nodeset_data.nodes.push_back( *iter );
if( 0 != has_dist_factors )
nodeset_data.node_dist_factors.push_back( dist_factor_vector[j] );
else
nodeset_data.node_dist_factors.push_back( 1.0 );
j++;
nodeset_data.number_nodes = nodeset_data.nodes.size();
nodeset_info.push_back( nodeset_data );
//------sidesets--------
vector_iter = sidesets.begin();
end_vector_iter = sidesets.end();
NeumannSetData sideset_data;
// Get the sideset's id
if( mdbImpl->tag_get_data( mNeumannSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS ) return MB_FAILURE;
sideset_data.id = id;
sideset_data.mesh_set_handle = *vector_iter;
// Get the sides in two lists, one forward the other reverse; starts with forward sense
// by convention
Range forward_elems, reverse_elems;
if( get_sideset_elems( *vector_iter, 0, forward_elems, reverse_elems ) == MB_FAILURE ) return MB_FAILURE;
ErrorCode result = get_valid_sides( forward_elems, mesh_info, 1, sideset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
result = get_valid_sides( reverse_elems, mesh_info, -1, sideset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
sideset_data.number_elements = sideset_data.elements.size();
sideset_info.push_back( sideset_data );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::get_sideset_elems | ( | EntityHandle | sideset, |
| int | current_sense, | ||
| Range & | forward_elems, | ||
| Range & | reverse_elems | ||
| ) | [private] |
Definition at line 2285 of file WriteNCDF.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_TYPE_INTEGER, MBENTITYSET, mdbImpl, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::TYPE_FROM_HANDLE().
Referenced by gather_mesh_information().
Range ss_elems, ss_meshsets;
// Get the sense tag; don't need to check return, might be an error if the tag
// hasn't been created yet
Tag sense_tag = 0;
mdbImpl->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, sense_tag );
// Get the entities in this set
ErrorCode result = mdbImpl->get_entities_by_handle( sideset, ss_elems, true );
if( MB_FAILURE == result ) return result;
// Now remove the meshsets into the ss_meshsets; first find the first meshset,
Range::iterator range_iter = ss_elems.begin();
while( TYPE_FROM_HANDLE( *range_iter ) != MBENTITYSET && range_iter != ss_elems.end() )
++range_iter;
// Then, if there are some, copy them into ss_meshsets and erase from ss_elems
if( range_iter != ss_elems.end() )
std::copy( range_iter, ss_elems.end(), range_inserter( ss_meshsets ) );
ss_elems.erase( range_iter, ss_elems.end() );
// OK, for the elements, check the sense of this set and copy into the right range
// (if the sense is 0, copy into both ranges)
// Need to step forward on list until we reach the right dimension
Range::iterator dum_it = ss_elems.end();
--dum_it;
int target_dim = CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) );
dum_it = ss_elems.begin();
while( target_dim != CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) ) && dum_it != ss_elems.end() )
++dum_it;
if( current_sense == 1 || current_sense == 0 ) std::copy( dum_it, ss_elems.end(), range_inserter( forward_elems ) );
if( current_sense == -1 || current_sense == 0 )
std::copy( dum_it, ss_elems.end(), range_inserter( reverse_elems ) );
// Now loop over the contained meshsets, getting the sense of those and calling this
// function recursively
for( range_iter = ss_meshsets.begin(); range_iter != ss_meshsets.end(); ++range_iter )
// First get the sense; if it's not there, by convention it's forward
int this_sense;
if( 0 == sense_tag || MB_FAILURE == mdbImpl->tag_get_data( sense_tag, &( *range_iter ), 1, &this_sense ) )
this_sense = 1;
// Now get all the entities on this meshset, with the proper (possibly reversed) sense
get_sideset_elems( *range_iter, this_sense * current_sense, forward_elems, reverse_elems );
return result;
| ErrorCode moab::WriteNCDF::get_valid_sides | ( | Range & | elems, |
| ExodusMeshInfo & | mesh_info, | ||
| const int | sense, | ||
| NeumannSetData & | sideset_data | ||
| ) | [private] |
Definition at line 650 of file WriteNCDF.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::NeumannSetData::elements, moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::NeumannSetData::id, MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, mdbImpl, mDistFactorTag, mEntityMark, moab::NeumannSetData::mesh_set_handle, moab::Interface::side_number(), moab::NeumannSetData::side_numbers, moab::NeumannSetData::ss_dist_factors, moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::TYPE_FROM_HANDLE(), and moab::CN::VerticesPerEntity().
// This is where we see if underlying element of side set element is included in output
// Get the sideset-based info for distribution factors
const double* dist_factor_vector = 0;
int dist_factor_size = 0;
// Initialize dist_fac_iter to get rid of compiler warning
const double* dist_fac_iter = 0;
bool has_dist_factors = false;
if( mdbImpl->tag_get_by_ptr( mDistFactorTag, &( sideset_data.mesh_set_handle ), 1, &ptr, &dist_factor_size ) ==
MB_SUCCESS &&
dist_factor_size )
has_dist_factors = true;
dist_fac_iter = dist_factor_vector;
unsigned char element_marked = 0;
ErrorCode result;
for( Range::iterator iter = elems.begin(); iter != elems.end(); ++iter )
// Should insert here if "side" is a quad/tri on a quad/tri mesh
result = mdbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
if( 0x1 == element_marked )
sideset_data.elements.push_back( *iter );
// TJT TODO: the sense should really be # edges + 1or2
sideset_data.side_numbers.push_back( ( sense == 1 ? 1 : 2 ) );
else
{ // Then "side" is probably a quad/tri on a hex/tet mesh
std::vector< EntityHandle > parents;
int dimension = CN::Dimension( TYPE_FROM_HANDLE( *iter ) );
// Get the adjacent parent element of "side"
if( mdbImpl->get_adjacencies( &( *iter ), 1, dimension + 1, false, parents ) != MB_SUCCESS )
#if 0
// This is not treated as an error, print warning messages for
// debugging only
fprintf(stderr, "[Warning]: Couldn't get adjacencies for sideset.\n");
#endif
if( !parents.empty() )
// Make sure the adjacent parent element will be output
for( unsigned int k = 0; k < parents.size(); k++ )
result = mdbImpl->tag_get_data( mEntityMark, &( parents[k] ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
int side_no, this_sense, this_offset;
if( 0x1 == element_marked &&
mdbImpl->side_number( parents[k], *iter, side_no, this_sense, this_offset ) == MB_SUCCESS &&
this_sense == sense )
sideset_data.elements.push_back( parents[k] );
sideset_data.side_numbers.push_back( side_no + 1 );
break;
else
#if 0
// debugging only
fprintf(stderr, "[Warning]: No parent element exists for element in sideset %i\n", sideset_data.id);
#endif
if( sideset_data.elements.size() != 0 )
// Distribution factors
int num_nodes = CN::VerticesPerEntity( TYPE_FROM_HANDLE( *iter ) );
// put some dummy dist factors for polygons; why do we need them?
if( TYPE_FROM_HANDLE( *iter ) == MBPOLYGON ) num_nodes = 1; // dummy
if( has_dist_factors )
std::copy( dist_fac_iter, dist_fac_iter + num_nodes,
std::back_inserter( sideset_data.ss_dist_factors ) );
dist_fac_iter += num_nodes;
else
for( int j = 0; j < num_nodes; j++ )
sideset_data.ss_dist_factors.push_back( 1.0 );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::initialize_exodus_file | ( | ExodusMeshInfo & | mesh_info, |
| std::vector< MaterialSetData > & | block_data, | ||
| std::vector< NeumannSetData > & | sideset_data, | ||
| std::vector< DirichletSetData > & | nodeset_data, | ||
| const char * | title_string, | ||
| bool | write_maps = true, |
| bool | write_sideset_distribution_factors = true |
| ) | [private] |
Definition at line 1569 of file WriteNCDF.cpp.
References moab::Range::begin(), moab::MaterialSetData::element_type, moab::MaterialSetData::elements, moab::ExoIIUtil::ElementTypeNames, moab::Range::end(), ErrorCode, moab::EXOII_POLYGON, moab::EXOII_POLYHEDRON, moab::Interface::get_connectivity(), moab::MaterialSetData::id, moab::DirichletSetData::id, moab::NeumannSetData::id, INS_ID, length(), moab::ExoIIInterface::MAX_STR_LENGTH, MB_CHK_ERR, MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, mdbImpl, ncFile, moab::WriteNCDF::ExodusMeshInfo::num_dim, moab::WriteNCDF::ExodusMeshInfo::num_elementblocks, moab::WriteNCDF::ExodusMeshInfo::num_elements, moab::WriteNCDF::ExodusMeshInfo::num_nodes, moab::MaterialSetData::number_attributes, moab::MaterialSetData::number_elements, moab::NeumannSetData::number_elements, moab::DirichletSetData::number_nodes, moab::MaterialSetData::number_nodes_per_element, moab::WriteNCDF::ExodusMeshInfo::polyhedronFaces, moab::WriteNCDF::ExodusMeshInfo::qaRecords, repeat_face_blocks, moab::Range::size(), and moab::NeumannSetData::ss_dist_factors.
Referenced by write_header().
// This routine takes the place of the exodusii routine ex_put_init,
// and additionally pre-defines variables such as qa, element blocks,
// sidesets and nodesets in a single pass.
// This is necessary because of the way exodusII works. Each time the
// netcdf routine endef is called to take the file out of define mode,
// the entire file is copied before the new information is added.
// With very large files, this is simply not workable. This routine takes
// the definition portions of all applicable exodus routines and puts them
// in a single definition, preventing repeated copying of the file.
// Most of the code is copied directly from the applicable exodus routine,
// and thus this routine may not seem very consistent in usage or variable
// naming, etc.
// Perform the initializations
int element_block_index;
// Inquire on defined string dimension and general dimension for qa
int dim_str, dim_four, dim_line, dim_time;
if( nc_def_dim( ncFile, "len_string", ExoIIInterface::MAX_STR_LENGTH, &dim_str ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to get string length in file" );
if( nc_def_dim( ncFile, "len_line", ExoIIInterface::MAX_STR_LENGTH, &dim_line ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to get line length in file" );
if( nc_def_dim( ncFile, "four", 4, &dim_four ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to locate four in file" );
if( nc_def_dim( ncFile, "time_step", 1, &dim_time ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to locate time step in file" );
// some whole_time dummy :(
int dtime;
if( NC_NOERR != nc_def_var( ncFile, "time_whole", NC_DOUBLE, 1, &dim_time, &dtime ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define time whole array" );
/* Put file into define mode */
// It is possible that an NT filename using backslashes is in the title string
// this can give fits to unix codes where the backslash is assumed to be an escape
// sequence. For the exodus file, just flip the backslash to a slash to prevent
// this problem
// Get a working copy of the title_string;
char working_title[80];
strncpy( working_title, title_string, 79 );
int length = strlen( working_title );
for( int pos = 0; pos < length; pos++ )
if( working_title[pos] == '\\' ) working_title[pos] = '/';
if( NC_NOERR != nc_put_att_text( ncFile, NC_GLOBAL, "title", length, working_title ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define title attribute" );
// Add other attributes while we're at it
float dum_vers = 6.28F;
if( NC_NOERR != nc_put_att_float( ncFile, NC_GLOBAL, "api_version", NC_FLOAT, 1, &dum_vers ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define api_version attribute" );
dum_vers = 6.28F;
if( NC_NOERR != nc_put_att_float( ncFile, NC_GLOBAL, "version", NC_FLOAT, 1, &dum_vers ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define version attribute" );
int dum_siz = sizeof( double );
if( NC_NOERR != nc_put_att_int( ncFile, NC_GLOBAL, "floating_point_word_size", NC_INT, 1, &dum_siz ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define floating pt word size attribute" );
// Set up number of dimensions
int num_el_blk, num_elem, num_nodes, num_dim, num_fa_blk, num_faces;
if( nc_def_dim( ncFile, "num_dim", (size_t)mesh_info.num_dim, &num_dim ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of dimensions" );
if( nc_def_dim( ncFile, "num_nodes", mesh_info.num_nodes, &num_nodes ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of nodes" );
int num_nod_per_fa; // it is needed for polyhedron only; need to compute it (connectivity of
// faces of polyhedra)
if( mesh_info.polyhedronFaces.size() > 0 )
if( nc_def_dim( ncFile, "num_faces", (int)mesh_info.polyhedronFaces.size(), &num_faces ) != NC_NOERR )
if( nc_def_dim( ncFile, "num_elem", mesh_info.num_elements, &num_elem ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of elements" );
if( nc_def_dim( ncFile, "num_el_blk", mesh_info.num_elementblocks, &num_el_blk ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of element blocks" );
/* ...and some variables */
/* Element block id status array */
int idstat = -1;
if( NC_NOERR != nc_def_var( ncFile, "eb_status", NC_LONG, 1, &num_el_blk, &idstat ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define element block status array" );
/* Element block id array */
int idarr = -1;
if( NC_NOERR != nc_def_var( ncFile, "eb_prop1", NC_LONG, 1, &num_el_blk, &idarr ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define element block id array" );
/* store property name as attribute of property array variable */
if( NC_NOERR != nc_put_att_text( ncFile, idarr, "name", strlen( "ID" ), "ID" ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store element block property name ID" );
// count how many are polyhedron blocks
int num_fa_blocks = 0, num_polyh_blocks = 0;
for( unsigned int i = 0; i < block_data.size(); i++ )
MaterialSetData& block = block_data[i];
if( EXOII_POLYHEDRON == block.element_type )
num_fa_blocks++;
num_polyh_blocks++;
if( 0 == this->repeat_face_blocks && num_fa_blocks > 1 ) num_fa_blocks = 1;
char wname[80];
if( num_fa_blocks > 0 )
/* face block id status array */
if( nc_def_dim( ncFile, "num_fa_blk", num_fa_blocks, &num_fa_blk ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of face blocks" );
int idstatf = -1;
if( NC_NOERR != nc_def_var( ncFile, "fa_status", NC_LONG, 1, &num_fa_blk, &idstatf ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define face block status array" );
int idarrf = -1;
if( NC_NOERR != nc_def_var( ncFile, "fa_prop1", NC_LONG, 1, &num_fa_blk, &idarrf ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define face block id array" );
if( NC_NOERR != nc_put_att_text( ncFile, idarrf, "name", strlen( "ID" ), "ID" ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store face block property name ID" );
// determine the number of num_nod_per_face
num_fa_in_blk1 = 15 ;
num_nod_per_fa1 = 58 ;
int fbconn1(num_nod_per_fa1) ;
fbconn1:elem_type = "nsided" ;
int fbepecnt1(num_fa_in_blk1) ;
fbepecnt1:entity_type1 = "NODE" ;
fbepecnt1:entity_type2 = "FACE" ;
int num_nodes_per_face = 0;
int dims[1]; // maybe 1 is enough here
for( Range::iterator eit = mesh_info.polyhedronFaces.begin(); eit != mesh_info.polyhedronFaces.end(); eit++ )
EntityHandle polyg = *eit;
int nnodes = 0;
ErrorCode rval = mdbImpl->get_connectivity( polyg, conn, nnodes );MB_CHK_ERR( rval );
num_nodes_per_face += nnodes;
// duplicate if needed; default is not duplicate
for( int j = 1; j <= num_fa_blocks; j++ )
INS_ID( wname, "num_nod_per_fa%d", j );
if( nc_def_dim( ncFile, wname, (size_t)num_nodes_per_face, &num_nod_per_fa ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of nodes for face block " );
dims[0] = num_nod_per_fa;
INS_ID( wname, "fbconn%d", j ); // first one, or more
int fbconn;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, dims, &fbconn ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create connectivity array for face block " << 1 );
std::string element_type_string( "nsided" );
if( NC_NOERR != nc_put_att_text( ncFile, fbconn, "elem_type", element_type_string.length(),
element_type_string.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store element type nsided " );
INS_ID( wname, "num_fa_in_blk%d", j ); // first one, or more
int num_fa_in_blk;
if( nc_def_dim( ncFile, wname, (size_t)mesh_info.polyhedronFaces.size(), &num_fa_in_blk ) != NC_NOERR )
// fbepecnt
INS_ID( wname, "fbepecnt%d", j ); // first one, or more
int fbepecnt;
dims[0] = num_fa_in_blk;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, dims, &fbepecnt ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create fbepecnt array for block " << 1 );
std::string enttype1( "NODE" );
if( NC_NOERR != nc_put_att_text( ncFile, fbepecnt, "entity_type1", enttype1.length(), enttype1.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store entity type 1 " );
std::string enttype2( "FACE" );
if( NC_NOERR != nc_put_att_text( ncFile, fbepecnt, "entity_type2", enttype2.length(), enttype2.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store entity type 2 " );
// Define element blocks
element_block_index = i + 1;
int num_el_in_blk = -1, num_att_in_blk = -1;
int blk_attrib, connect;
/* Define number of elements in this block */
INS_ID( wname, "num_el_in_blk%d", element_block_index );
if( nc_def_dim( ncFile, wname, (size_t)block.number_elements, &num_el_in_blk ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of elements/block for block " << i + 1 );
/* Define number of nodes per element for this block */
INS_ID( wname, "num_nod_per_el%d", element_block_index );
int num_nod_per_el = -1;
if( EXOII_POLYHEDRON != block.element_type )
if( nc_def_dim( ncFile, wname, (size_t)block.number_nodes_per_element, &num_nod_per_el ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of nodes/element for block " << block.id );
/* Define element attribute array for this block */
int dims[3];
if( block.number_attributes > 0 )
INS_ID( wname, "num_att_in_blk%d", element_block_index );
if( nc_def_dim( ncFile, wname, (size_t)block.number_attributes, &num_att_in_blk ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of attributes in block " << block.id );
INS_ID( wname, "attrib%d", element_block_index );
dims[0] = num_el_in_blk;
dims[1] = num_att_in_blk;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_DOUBLE, 2, dims, &blk_attrib ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define attributes for element block " << block.id );
/* Define element connectivity array for this block */
if( EXOII_POLYGON != block.element_type && EXOII_POLYHEDRON != block.element_type )
INS_ID( wname, "connect%d", element_block_index );
dims[1] = num_nod_per_el;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 2, dims, &connect ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create connectivity array for block " << i + 1 );
/* Store element type as attribute of connectivity variable */
std::string element_type_string( ExoIIUtil::ElementTypeNames[block.element_type] );
if( NC_NOERR != nc_put_att_text( ncFile, connect, "elem_type", element_type_string.length(),
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store element type name " << (int)block.element_type );
else if( EXOII_POLYGON == block.element_type )
// need to define num_nod_per_el as total number of nodes
// ebepecnt1 as number of nodes per polygon
* int connect1(num_nod_per_el1) ;
connect1:elem_type = "nsided" ;
int ebepecnt1(num_el_in_blk1) ;
ebepecnt1:entity_type1 = "NODE" ;
ebepecnt1:entity_type2 = "ELEM" ;*/
dims[0] = num_nod_per_el;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, dims, &connect ) )
INS_ID( wname, "ebepecnt%d", element_block_index );
int ebepecnt;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, dims, &ebepecnt ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create ebepecnt array for block " << i + 1 );
std::string etype1( "NODE" );
if( NC_NOERR != nc_put_att_text( ncFile, ebepecnt, "entity_type1", etype1.length(), etype1.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store entity type1 " << (int)block.element_type );
std::string etype2( "ELEM" );
if( NC_NOERR != nc_put_att_text( ncFile, ebepecnt, "entity_type2", etype2.length(), etype2.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store entity type2 " << (int)block.element_type );
else if( EXOII_POLYHEDRON == block.element_type )
// INS_ID(wname, "connect%d", element_block_index);
testn face example: 3 polyh, 15 total faces, 2 shared; 15+2 = 17
num_elem = 3 ;
num_face = 15 ; // not needed?
num_el_blk = 1 ;
num_el_in_blk1 = 3 ;
num_fac_per_el1 = 17 ;
* num faces will be total face conn
* num_faces_in_block will be number of faces (non repeated)
* num_nodes_per_face will have total face connectivity
int num_faces2 = 0;
for( Range::iterator eit = block.elements.begin(); eit != block.elements.end(); eit++ )
EntityHandle polyh = *eit;
int nfaces = 0;
ErrorCode rval = mdbImpl->get_connectivity( polyh, conn, nfaces );MB_CHK_ERR( rval );
num_faces2 += nfaces;
int num_fac_per_el;
INS_ID( wname, "num_fac_per_el%d", element_block_index );
if( nc_def_dim( ncFile, wname, (size_t)num_faces2, &num_fac_per_el ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of faces per block " << block.id );
int facconn1(num_fac_per_el1) ;
facconn1:elem_type = "NFACED" ;
ebepecnt1:entity_type1 = "FACE" ;
// facconn
INS_ID( wname, "facconn%d", element_block_index );
int facconn;
dims[0] = num_fac_per_el;
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, dims, &facconn ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create facconn array for block " << i + 1 );
std::string etype( "NFACED" );
if( NC_NOERR != nc_put_att_text( ncFile, facconn, "elem_type", etype.length(), etype.c_str() ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store elem type " << (int)block.element_type );
// ebepecnt
int ebepecnt;
std::string etype1( "FACE" );
block.number_nodes_per_element = num_faces2; // connectivity for all polyhedra in block
/* Node set id array: */
int non_empty_nss = 0;
// Need to go through nodesets to compute # nodesets, some might be empty
std::vector< DirichletSetData >::iterator ns_it;
for( ns_it = nodeset_data.begin(); ns_it != nodeset_data.end(); ++ns_it )
if( 0 != ( *ns_it ).number_nodes ) non_empty_nss++;
int num_ns = -1;
int ns_idstat = -1, ns_idarr = -1;
if( non_empty_nss > 0 )
if( nc_def_dim( ncFile, "num_node_sets", (size_t)( non_empty_nss ), &num_ns ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of node sets" );
/* Node set id status array: */
if( NC_NOERR != nc_def_var( ncFile, "ns_status", NC_LONG, 1, &num_ns, &ns_idstat ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create node sets status array" );
if( NC_NOERR != nc_def_var( ncFile, "ns_prop1", NC_LONG, 1, &num_ns, &ns_idarr ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create node sets property array" );
/* Store property name as attribute of property array variable */
if( NC_NOERR != nc_put_att_text( ncFile, NC_GLOBAL, "name", strlen( "ID" ), "ID" ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store node set property name ID" );
// Now, define the arrays needed for each node set
int index = 0;
for( unsigned i = 0; i < nodeset_data.size(); i++ )
DirichletSetData node_set = nodeset_data[i];
if( 0 == node_set.number_nodes )
MB_SET_ERR_CONT( "WriteNCDF: empty nodeset " << node_set.id );
continue;
index++;
int num_nod_ns = -1;
INS_ID( wname, "num_nod_ns%d", index );
if( nc_def_dim( ncFile, wname, (size_t)node_set.number_nodes, &num_nod_ns ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of nodes for set " << node_set.id );
/* Create variable array in which to store the node set node list */
int node_ns = -1;
INS_ID( wname, "node_ns%d", index );
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, &num_nod_ns, &node_ns ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create node set " << node_set.id << " node list" );
// Create distribution factor array
int fact_ns = -1;
INS_ID( wname, "dist_fact_ns%d", index );
if( NC_NOERR != nc_def_var( ncFile, wname, NC_DOUBLE, 1, &num_nod_ns, &fact_ns ) )
"WriteNCDF: failed to create node set " << node_set.id << " distribution factor list" );
/* Side set id array: */
long non_empty_ss = 0;
std::vector< NeumannSetData >::iterator ss_it;
for( ss_it = sideset_data.begin(); ss_it != sideset_data.end(); ++ss_it )
if( 0 != ( *ss_it ).number_elements ) non_empty_ss++;
if( non_empty_ss > 0 )
int num_ss = -1;
if( nc_def_dim( ncFile, "num_side_sets", non_empty_ss, &num_ss ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of side sets" );
/* Side set id status array: */
int ss_idstat = -1, ss_idarr = -1;
if( NC_NOERR != nc_def_var( ncFile, "ss_status", NC_LONG, 1, &num_ss, &ss_idstat ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define side set status" );
if( NC_NOERR != nc_def_var( ncFile, "ss_prop1", NC_LONG, 1, &num_ss, &ss_idarr ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define side set property" );
if( NC_NOERR != nc_put_att_text( ncFile, ss_idarr, "name", strlen( "ID" ), "ID" ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to store side set property name ID" );
// Now, define the arrays needed for each side set
int index = 0;
for( unsigned int i = 0; i < sideset_data.size(); i++ )
NeumannSetData side_set = sideset_data[i];
// Don't define an empty set
if( 0 == side_set.number_elements ) continue;
index++;
int num_side_ss = -1;
int elem_ss = -1, side_ss = -1;
INS_ID( wname, "num_side_ss%d", index );
if( nc_def_dim( ncFile, wname, (size_t)side_set.number_elements, &num_side_ss ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of sides in side set " << side_set.id );
INS_ID( wname, "elem_ss%d", index );
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, &num_side_ss, &elem_ss ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create element list for side set "
<< side_set.id ); /* Exit define mode and return */
INS_ID( wname, "side_ss%d", index );
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, &num_side_ss, &side_ss ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create side list for side set "
// sideset distribution factors
int num_df_ss = -1;
INS_ID( wname, "num_df_ss%d", index );
if( nc_def_dim( ncFile, wname, (size_t)side_set.ss_dist_factors.size(), &num_df_ss ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define number of dist factors in side set "
/* Create variable array in which to store the side set distribution factors */
int fact_ss = -1;
INS_ID( wname, "dist_fact_ss%d", index );
if( NC_NOERR != nc_def_var( ncFile, wname, NC_LONG, 1, &num_df_ss, &fact_ss ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create dist factors list for side set "
/* Node coordinate arrays: */
int coord, name_coord, dims[3];
dims[0] = num_dim;
dims[1] = num_nodes;
if( NC_NOERR != nc_def_var( ncFile, "coord", NC_DOUBLE, 2, dims, &coord ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define node coordinate array" );
/* Coordinate names array */
dims[0] = num_dim;
dims[1] = dim_str;
if( NC_NOERR != nc_def_var( ncFile, "coor_names", NC_CHAR, 2, dims, &name_coord ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define coordinate name array" );
// Define genesis maps if required
if( write_maps )
// Element map
int elem_map = -1, elem_map2 = -1, node_map = -1;
if( NC_NOERR != nc_def_var( ncFile, "elem_map", NC_LONG, 1, &num_elem, &elem_map ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create element map array" ); /* Exit define mode and return */
// Create the element number map
if( NC_NOERR != nc_def_var( ncFile, "elem_num_map", NC_LONG, 1, &num_elem, &elem_map2 ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create element numbering map" ); /* Exit define mode
and return */
// Create node number map
if( NC_NOERR != nc_def_var( ncFile, "node_num_map", NC_LONG, 1, &num_nodes, &node_map ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to create node numbering map array" ); /* Exit define mode and
return */
// Define qa records to be used
int num_qa_rec = mesh_info.qaRecords.size() / 4;
int num_qa = -1;
if( nc_def_dim( ncFile, "num_qa_rec", (long)num_qa_rec, &num_qa ) != NC_NOERR )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define qa record array size" );
// Define qa array
int qa_title;
dims[0] = num_qa;
dims[1] = dim_four;
dims[2] = dim_str;
if( NC_NOERR != nc_def_var( ncFile, "qa_records", NC_CHAR, 3, dims, &qa_title ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to define qa record array" );
// Take it out of define mode
if( NC_NOERR != nc_enddef( ncFile ) )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: Trouble leaving define mode" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::open_file | ( | const char * | file_name | ) | [protected] |
open an ExoII file for writing
Definition at line 2266 of file WriteNCDF.cpp.
References moab::fail(), MB_SET_ERR, MB_SUCCESS, and ncFile.
// Not a valid filename
if( strlen( (const char*)filename ) == 0 )
MB_SET_ERR( MB_FAILURE, "Output Exodus filename not specified" );
int fail = nc_create( filename, NC_CLOBBER, &ncFile );
// File couldn't be opened
if( NC_NOERR != fail )
MB_SET_ERR( MB_FAILURE, "Cannot open " << filename );
return MB_SUCCESS;
| void moab::WriteNCDF::reset_block | ( | std::vector< MaterialSetData > & | block_info | ) | [private] |
Definition at line 142 of file WriteNCDF.cpp.
std::vector< MaterialSetData >::iterator iter;
for( iter = block_info.begin(); iter != block_info.end(); ++iter )
iter->elements.clear();
| void moab::WriteNCDF::time_and_date | ( | char * | time_string, |
| char * | date_string | ||
| ) | [static, private] |
Definition at line 152 of file WriteNCDF.cpp.
References moab::TIME_STR_LEN.
Referenced by write_file(), and write_header().
struct tm* local_time;
time_t calendar_time;
calendar_time = time( NULL );
local_time = localtime( &calendar_time );
assert( NULL != time_string && NULL != date_string );
strftime( time_string, TIME_STR_LEN, "%H:%M:%S", local_time );
strftime( date_string, TIME_STR_LEN, "%m/%d/%Y", local_time );
// Terminate with NULL character
time_string[10] = (char)NULL;
date_string[10] = (char)NULL;
| ErrorCode moab::WriteNCDF::write_BCs | ( | std::vector< NeumannSetData > & | sidesets, |
| std::vector< DirichletSetData > & | nodesets | ||
| ) | [private] |
Definition at line 1363 of file WriteNCDF.cpp.
References moab::NeumannSetData::elements, ErrorCode, moab::fail(), GET_VAR, moab::NeumannSetData::id, moab::ID_FROM_HANDLE(), INS_ID, MB_CHK_SET_ERR, MB_CHK_SET_ERR_RET_VAL, MB_SET_ERR, MB_SUCCESS, mdbImpl, mGlobalIdTag, ncFile, moab::NeumannSetData::number_elements, moab::NeumannSetData::side_numbers, moab::NeumannSetData::ss_dist_factors, moab::Interface::tag_get_data(), and write_exodus_integer_variable().
unsigned int i, j;
int id;
int ns_index = -1;
for( std::vector< DirichletSetData >::iterator ns_it = nodesets.begin(); ns_it != nodesets.end(); ++ns_it )
// Get number of nodes in set
int number_nodes = ( *ns_it ).number_nodes;
if( 0 == number_nodes ) continue;
// If we're here, we have a non-empty nodeset; increment the index
ns_index++;
// Get the node set id
id = ( *ns_it ).id;
// Build new array to old exodus ids
int* exodus_id_array = new int[number_nodes];
double* dist_factor_array = new double[number_nodes];
std::vector< EntityHandle >::iterator begin_iter, end_iter;
std::vector< double >::iterator other_iter;
begin_iter = ( *ns_it ).nodes.begin();
end_iter = ( *ns_it ).nodes.end();
other_iter = ( *ns_it ).node_dist_factors.begin();
j = 0;
int exodus_id;
ErrorCode result;
// Fill up node array and dist. factor array at the same time
for( ; begin_iter != end_iter; ++begin_iter )
result = mdbImpl->tag_get_data( mGlobalIdTag, &( *begin_iter ), 1, &exodus_id );MB_CHK_SET_ERR( result, "Problem getting id tag data" );
exodus_id_array[j] = exodus_id;
dist_factor_array[j] = *( other_iter );
++other_iter;
j++;
// Write out the id for the nodeset
int num_values = 1;
result = write_exodus_integer_variable( "ns_prop1", &id, ns_index, num_values );MB_CHK_SET_ERR_RET_VAL( result, "Problem writing node set id " << id, MB_FAILURE );
// Write out the nodeset status
int status = 1;
if( !number_nodes ) status = 0;
result = write_exodus_integer_variable( "ns_status", &status, ns_index, num_values );MB_CHK_SET_ERR_RET_VAL( result, "Problem writing node set status", MB_FAILURE );
// Write it out
char wname[80];
int nc_var = -1;
std::vector< int > dims;
INS_ID( wname, "node_ns%d", ns_index + 1 );
GET_VAR( wname, nc_var, dims );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Failed to get node_ns variable" );
size_t start = 0, count = number_nodes;
int fail = nc_put_vara_int( ncFile, nc_var, &start, &count, exodus_id_array );
MB_SET_ERR( MB_FAILURE, "Failed writing exodus id array" );
// Write out nodeset distribution factors
INS_ID( wname, "dist_fact_ns%d", ns_index + 1 );
nc_var = -1;
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Failed to get dist_fact variable" );
fail = nc_put_vara_double( ncFile, nc_var, &start, &count, dist_factor_array );
MB_SET_ERR( MB_FAILURE, "Failed writing dist factor array" );
delete[] dist_factor_array;
delete[] exodus_id_array;
// Now do sidesets
int ss_index = 0; // Index of sideset - not the same as 'i' because
// only writing non-empty side sets
for( i = 0; i < sidesets.size(); i++ )
NeumannSetData sideset_data = sidesets[i];
// Get the side set id
int side_set_id = sideset_data.id;
// Get number of elements in set
int number_elements = sideset_data.number_elements;
if( 0 == number_elements ) continue;
int* output_element_ids = new int[number_elements];
int* output_element_side_numbers = new int[number_elements];
begin_iter = sideset_data.elements.begin();
end_iter = sideset_data.elements.end();
std::vector< int >::iterator side_iter = sideset_data.side_numbers.begin();
// Get the tag handle
j = 0;
int exodus_id;
// For each "side"
for( ; begin_iter != end_iter; ++begin_iter, ++side_iter )
ErrorCode result = mdbImpl->tag_get_data( mGlobalIdTag, &( *begin_iter ), 1, &exodus_id );MB_CHK_SET_ERR( result, "Problem getting exodus id for sideset element "
<< (long unsigned int)ID_FROM_HANDLE( *begin_iter ) );
output_element_ids[j] = exodus_id;
output_element_side_numbers[j++] = *side_iter;
if( 0 != number_elements )
int num_values = 1;
// ss_prop1[ss_index] = side_set_id
ErrorCode result = write_exodus_integer_variable( "ss_prop1", &side_set_id, ss_index, num_values );MB_CHK_SET_ERR_RET_VAL( result, "Problem writing node set id " << id, MB_FAILURE );
// FIXME : Something seems wrong here. The we are within a block
// started with if (0 != number_elements), so this condition is always
// false. This code seems to indicate that we want to write all
// sidesets, not just empty ones. But the code both here and in
// initialize_exodus_file() skip empty side sets.
// - j.k. 2007-03-09
int status = 1;
if( 0 == number_elements ) status = 0;
// ss_status[ss_index] = status
result = write_exodus_integer_variable( "ss_status", &status, ss_index, num_values );MB_CHK_SET_ERR_RET_VAL( result, "Problem writing side set status", MB_FAILURE );
// Increment ss_index now because we want a) we need to
// increment it somewhere within the if (0 != number_elements)
// block and b) the above calls need a zero-based index
// while the following use a one-based index.
++ss_index;
char wname[80];
int nc_var;
INS_ID( wname, "elem_ss%d", ss_index );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Failed to get elem_ss variable" );
size_t start = 0, count = number_elements;
int fail = nc_put_vara_int( ncFile, nc_var, &start, &count, output_element_ids );
MB_SET_ERR( MB_FAILURE, "Failed writing sideset element array" );
INS_ID( wname, "side_ss%d", ss_index );
nc_var = -1;
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Failed to get side_ss variable" );
fail = nc_put_vara_int( ncFile, nc_var, &start, &count, output_element_side_numbers );
MB_SET_ERR( MB_FAILURE, "Failed writing sideset side array" );
INS_ID( wname, "dist_fact_ss%d", ss_index );
nc_var = -1;
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Failed to get sideset dist factors variable" );
count = sideset_data.ss_dist_factors.size();
fail = nc_put_vara_double( ncFile, nc_var, &start, &count, &( sideset_data.ss_dist_factors[0] ) );
MB_SET_ERR( MB_FAILURE, "Failed writing sideset dist factors array" );
delete[] output_element_ids;
delete[] output_element_side_numbers;
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_element_order_map | ( | int | num_elements | ) | [private] |
Definition at line 1289 of file WriteNCDF.cpp.
References moab::error(), MB_SET_ERR, MB_SUCCESS, and write_exodus_integer_variable().
// Note: this routine bypasses the standard exodusII interface for efficiency!
// Element order map
int* map = new int[num_elements];
// For now, output a dummy map!
for( int i = 0; i < num_elements; i++ )
map[i] = i + 1;
// Output array and cleanup
int error = write_exodus_integer_variable( "elem_map", map, 0, num_elements );
if( map ) delete[] map;
if( error < 0 )
MB_SET_ERR( MB_FAILURE, "Failed writing element map" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_elementblocks | ( | ExodusMeshInfo & | mesh_info, |
| std::vector< MaterialSetData > & | block_data | ||
| ) | [private] |
Definition at line 1035 of file WriteNCDF.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), moab::MaterialSetData::element_type, moab::MaterialSetData::elements, moab::Range::end(), ErrorCode, exodus_elem_order_map, moab::EXOII_POLYGON, moab::EXOII_POLYHEDRON, moab::ExoIIUtil::ExoIIElementMBEntity, moab::fail(), moab::Interface::get_connectivity(), moab::WriteUtilIface::get_element_connect(), GET_VAR, moab::MaterialSetData::id, moab::Range::index(), INS_ID, MB_CHK_ERR, MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, mdbImpl, mGlobalIdTag, mWriteIface, ncFile, moab::MaterialSetData::number_elements, moab::MaterialSetData::number_nodes_per_element, moab::WriteNCDF::ExodusMeshInfo::polyhedronFaces, moab::WriteUtilIface::reorder(), moab::Range::size(), and write_exodus_integer_variable().
unsigned int i;
int block_index = 0; // Index into block list, may != 1 if there are inactive blocks
int exodus_id = 1;
for( i = 0; i < block_data.size(); i++ )
unsigned int num_nodes_per_elem = block.number_nodes_per_element;
// Write out the id for the block
int id = block.id;
int num_values = 1;
if( write_exodus_integer_variable( "eb_prop1", &id, block_index, num_values ) != MB_SUCCESS )
MB_SET_ERR_CONT( "Problem writing element block id " << id );
// Write out the block status
int status = 1;
if( 0 == block.number_elements )
MB_SET_ERR( MB_FAILURE, "No elements in block " << id );
if( write_exodus_integer_variable( "eb_status", &status, block_index, num_values ) != MB_SUCCESS )
MB_SET_ERR( MB_FAILURE, "Problem writing element block status" );
// Map the connectivity to the new nodes
const unsigned int num_elem = block.number_elements;
unsigned int num_nodes = num_nodes_per_elem * num_elem;
if( EXOII_POLYGON == block.element_type || EXOII_POLYHEDRON == block.element_type )
num_nodes = num_nodes_per_elem;
int* connectivity = new int[num_nodes];
ErrorCode result = MB_SUCCESS;
mWriteIface->get_element_connect( num_elem, num_nodes_per_elem, mGlobalIdTag, block.elements, mGlobalIdTag,
exodus_id, connectivity );
if( result != MB_SUCCESS )
delete[] connectivity;
MB_SET_ERR( result, "Couldn't get element array to write from" );
// If necessary, convert from EXODUS to CN node order
const EntityType elem_type = ExoIIUtil::ExoIIElementMBEntity[block.element_type];
assert( block.elements.all_of_type( elem_type ) );
const int* reorder = 0;
if( block.element_type != EXOII_POLYHEDRON && block.element_type != EXOII_POLYGON )
reorder = exodus_elem_order_map[elem_type][block.number_nodes_per_element];
if( reorder )
WriteUtilIface::reorder( reorder, connectivity, block.number_elements, block.number_nodes_per_element );
char wname[80];
int nc_var = -1;
exodus_id += num_elem;
INS_ID( wname, "connect%u", i + 1 );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Couldn't get connectivity variable" );
size_t start[1] = { 0 }, count[1] = { num_nodes_per_elem };
int fail = nc_put_vara_int( ncFile, nc_var, start, count, connectivity );
MB_SET_ERR( MB_FAILURE, "Couldn't write connectivity variable" );
// now put also number ebepecnt1
INS_ID( wname, "ebepecnt%u", i + 1 );
count[0] = block.number_elements;
start[0] = 0;
// reuse connectivity array, to not allocate another one
int j = 0;
for( Range::iterator eit = block.elements.begin(); eit != block.elements.end(); j++, eit++ )
int nnodes = 0;
ErrorCode rval = mdbImpl->get_connectivity( polg, conn, nnodes );MB_CHK_ERR( rval );
connectivity[j] = nnodes;
MB_SET_ERR( MB_FAILURE, "Couldn't write ebepecnt variable" );
else if( block.element_type != EXOII_POLYHEDRON )
size_t start[2] = { 0, 0 }, count[2] = { num_elem, num_nodes_per_elem };
else // if (block.element_type == EXOII_POLYHEDRON)
/* write a lot of stuff // faconn
Range& block_faces = mesh_info.polyhedronFaces;
// ErrorCode rval = mdbImpl->get_connectivity(block.elements, block_faces);
// MB_CHK_ERR(rval);
// reuse now connectivity for facconn1
INS_ID( wname, "facconn%u", i + 1 );
GET_VAR( wname, nc_var, dims ); // fbconn# variable, 1 dimensional
std::vector< int > ebepe( block.elements.size() ); // ebepecnt1
int ixcon = 0, j = 0;
size_t start[1] = { 0 }, count[1] = { 0 };
int nfaces = 0;
for( int k = 0; k < nfaces; k++ )
int index = block_faces.index( conn[k] );
if( index == -1 ) MB_SET_ERR( MB_FAILURE, "Couldn't find face in polyhedron" );
connectivity[ixcon++] = index + 1;
ebepe[j++] = nfaces;
// num_faces+=nfaces;
count[0] = ixcon; // facconn1
MB_SET_ERR( MB_FAILURE, "Couldn't write fbconn variable" );
GET_VAR( wname, nc_var, dims ); // ebepecnt# variable, 1 dimensional
count[0] = block.elements.size();
fail = nc_put_vara_int( ncFile, nc_var, start, count, &ebepe[0] );
MB_SET_ERR( MB_FAILURE, "Couldn't write fbepecnt variable" );
block_index++;
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_exodus_integer_variable | ( | const char * | variable_name, |
| int * | variable_array, | ||
| int | start_position, | ||
| int | number_values | ||
| ) | [private] |
Definition at line 1317 of file WriteNCDF.cpp.
References moab::fail(), GET_VAR, MB_SET_ERR, MB_SUCCESS, and ncFile.
Referenced by write_BCs(), write_element_order_map(), write_elementblocks(), write_global_element_order_map(), write_global_node_order_map(), and write_poly_faces().
// Write directly to netcdf interface for efficiency
// Get the variable id of the element map
int nc_var = -1;
GET_VAR( variable_name, nc_var, dims );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "WriteNCDF: failed to locate variable " << variable_name << " in file" );
// This contortion is necessary because netCDF is expecting nclongs;
// fortunately it's necessary only when ints and nclongs aren't the same size
size_t start[1], count[1];
start[0] = start_position;
count[0] = number_values;
int fail = NC_NOERR;
if( sizeof( int ) == sizeof( long ) )
fail = nc_put_vara_int( ncFile, nc_var, start, count, variable_array );
else
long* lptr = new long[number_values];
for( int jj = 0; jj < number_values; jj++ )
lptr[jj] = variable_array[jj];
fail = nc_put_vara_long( ncFile, nc_var, start, count, lptr );
delete[] lptr;
MB_SET_ERR( MB_FAILURE, "Failed to store variable " << variable_name );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_file | ( | const char * | exodus_file_name, |
| const bool | overwrite, | ||
| const FileOptions & | opts, | ||
| const EntityHandle * | output_list, | ||
| const int | num_sets, | ||
| const std::vector< std::string > & | qa_records, | ||
| const Tag * | = NULL, |
| int | = 0, |
| int | user_dimension = 3 |
| ) | [virtual] |
Implements moab::WriterIface.
Definition at line 170 of file WriteNCDF.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::create_meshset(), moab::Range::empty(), moab::Range::end(), entities, moab::fail(), gather_mesh_information(), moab::Interface::get_dimension(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::FileOptions::get_null_option(), GET_VAR, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mdbImpl, mDirichletSetTag, MESHSET_SET, mMaterialSetTag, mNeumannSetTag, ncFile, moab::WriteNCDF::ExodusMeshInfo::nodes, moab::WriteNCDF::ExodusMeshInfo::num_dim, moab::WriteNCDF::ExodusMeshInfo::num_elements, moab::WriteNCDF::ExodusMeshInfo::num_nodes, moab::WriteNCDF::ExodusMeshInfo::polyhedronFaces, moab::WriteNCDF::ExodusMeshInfo::qaRecords, repeat_face_blocks, reset_block(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), time_and_date(), write_BCs(), write_element_order_map(), write_elementblocks(), write_global_element_order_map(), write_global_node_order_map(), write_header(), write_nodes(), write_poly_faces(), and write_qa_records().
assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag );
if( user_dimension == 0 ) mdbImpl->get_dimension( user_dimension );
if( opts.get_null_option( "REPEAT_FACE_BLOCKS" ) == MB_SUCCESS ) repeat_face_blocks = 1;
std::vector< EntityHandle > blocks, nodesets, sidesets, entities;
// Separate into blocks, nodesets, sidesets
if( num_sets == 0 )
// Default to all defined block, nodeset and sideset-type sets
Range this_range;
mdbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, this_range );
std::copy( this_range.begin(), this_range.end(), std::back_inserter( blocks ) );
this_range.clear();
mdbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, this_range );
std::copy( this_range.begin(), this_range.end(), std::back_inserter( nodesets ) );
this_range.clear();
mdbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, this_range );
std::copy( this_range.begin(), this_range.end(), std::back_inserter( sidesets ) );
// If there is nothing to write, write everything as one block.
if( blocks.empty() && nodesets.empty() && sidesets.empty() )
this_range.clear();
for( int d = user_dimension; d > 0 && this_range.empty(); --d )
mdbImpl->get_entities_by_dimension( 0, d, this_range, false );
if( this_range.empty() ) return MB_FILE_WRITE_ERROR;
EntityHandle block_handle;
int block_id = 1;
mdbImpl->create_meshset( MESHSET_SET, block_handle );
mdbImpl->tag_set_data( mMaterialSetTag, &block_handle, 1, &block_id );
mdbImpl->add_entities( block_handle, this_range );
blocks.push_back( block_handle );
else
int dummy;
for( const EntityHandle* iter = ent_handles; iter < ent_handles + num_sets; ++iter )
if( MB_SUCCESS == mdbImpl->tag_get_data( mMaterialSetTag, &( *iter ), 1, &dummy ) && -1 != dummy )
blocks.push_back( *iter );
else if( MB_SUCCESS == mdbImpl->tag_get_data( mDirichletSetTag, &( *iter ), 1, &dummy ) && -1 != dummy )
nodesets.push_back( *iter );
else if( MB_SUCCESS == mdbImpl->tag_get_data( mNeumannSetTag, &( *iter ), 1, &dummy ) && -1 != dummy )
sidesets.push_back( *iter );
// If there is nothing to write just return.
if( blocks.empty() && nodesets.empty() && sidesets.empty() ) return MB_FILE_WRITE_ERROR;
// Try to get mesh information
ExodusMeshInfo mesh_info;
std::vector< MaterialSetData > block_info;
std::vector< NeumannSetData > sideset_info;
std::vector< DirichletSetData > nodeset_info;
mesh_info.num_dim = user_dimension;
if( qa_records.empty() )
// qa records are empty - initialize some MB-standard ones
mesh_info.qaRecords.push_back( "MB" );
mesh_info.qaRecords.push_back( "0.99" );
char string1[80], string2[80];
time_and_date( string2, string1 );
mesh_info.qaRecords.push_back( string2 );
mesh_info.qaRecords.push_back( string1 );
else
assert( qa_records.size() % 4 == 0 );
std::copy( qa_records.begin(), qa_records.end(), std::back_inserter( mesh_info.qaRecords ) );
block_info.clear();
if( gather_mesh_information( mesh_info, block_info, sideset_info, nodeset_info, blocks, sidesets, nodesets ) !=
MB_SUCCESS )
reset_block( block_info );
return MB_FAILURE;
// Try to open the file after gather mesh info succeeds
int fail = nc_create( exodus_file_name, overwrite ? NC_CLOBBER : NC_NOCLOBBER, &ncFile );
return MB_FAILURE;
if( write_header( mesh_info, block_info, sideset_info, nodeset_info, exodus_file_name ) != MB_SUCCESS )
return MB_FAILURE;
// write dummy time_whole
double timev = 0.0; // dummy, to make paraview happy
size_t start = 0, count = 1;
int nc_var;
GET_VAR( "time_whole", nc_var, dims );
fail = nc_put_vara_double( ncFile, nc_var, &start, &count, &timev );
if( write_nodes( mesh_info.num_nodes, mesh_info.nodes, mesh_info.num_dim ) != MB_SUCCESS )
return MB_FAILURE;
if( !mesh_info.polyhedronFaces.empty() )
if( write_poly_faces( mesh_info ) != MB_SUCCESS )
return MB_FAILURE;
if( write_elementblocks( mesh_info, block_info ) )
return MB_FAILURE;
// Write the three maps
if( write_global_node_order_map( mesh_info.num_nodes, mesh_info.nodes ) != MB_SUCCESS )
return MB_FAILURE;
if( write_global_element_order_map( mesh_info.num_elements ) != MB_SUCCESS )
return MB_FAILURE;
if( write_element_order_map( mesh_info.num_elements ) != MB_SUCCESS )
return MB_FAILURE;
if (write_elementmap(mesh_info) != MB_SUCCESS)
return MB_FAILURE;
if( write_BCs( sideset_info, nodeset_info ) != MB_SUCCESS )
return MB_FAILURE;
if( write_qa_records( mesh_info.qaRecords ) != MB_SUCCESS ) return MB_FAILURE;
// Copy the qa records into the argument
// mesh_info.qaRecords.swap(qa_records);
// Close the file
fail = nc_close( ncFile );
MB_SET_ERR( MB_FAILURE, "Trouble closing file" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_global_element_order_map | ( | int | num_elements | ) | [private] |
Definition at line 1263 of file WriteNCDF.cpp.
// Allocate map array
// Many Sandia codes assume this map is unique, and CUBIT does not currently
// have unique ids for all elements. Therefore, to make sure nothing crashes,
// insert a dummy map...
map[i] = i + 1;
int error = write_exodus_integer_variable( "elem_num_map", map, 0, num_elements );
if( error < 0 )
MB_SET_ERR( MB_FAILURE, "Failed writing global element order map" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_global_node_order_map | ( | int | num_nodes, |
| Range & | nodes | ||
| ) | [private] |
Definition at line 1228 of file WriteNCDF.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), moab::ID_FROM_HANDLE(), MB_SET_ERR, MB_SUCCESS, and write_exodus_integer_variable().
// Node order map
int* map = new int[num_nodes];
Range::iterator range_iter, end_iter;
range_iter = nodes.begin();
end_iter = nodes.end();
int i = 0;
for( ; range_iter != end_iter; ++range_iter )
// TODO -- do we really want to cast this to an int?
map[i++] = (int)ID_FROM_HANDLE( *range_iter );
int error = write_exodus_integer_variable( "node_num_map", map, 0, num_nodes );
if( error < 0 )
MB_SET_ERR( MB_FAILURE, "Failed writing global node order map" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_header | ( | ExodusMeshInfo & | mesh_info, |
| std::vector< MaterialSetData > & | block_info, | ||
| std::vector< NeumannSetData > & | sideset_info, | ||
| std::vector< DirichletSetData > & | nodeset_info, | ||
| const char * | filename | ||
| ) | [private] |
Definition at line 1004 of file WriteNCDF.cpp.
References initialize_exodus_file(), moab::ExoIIInterface::MAX_LINE_LENGTH, MB_SUCCESS, time_and_date(), and moab::TIME_STR_LEN.
// Get the date and time
char time[TIME_STR_LEN];
char date[TIME_STR_LEN];
time_and_date( time, date );
std::string title_string = "MOAB";
title_string.append( "(" );
title_string.append( filename );
title_string.append( "): " );
title_string.append( date );
title_string.append( ": " );
title_string.append( "time " );
if( title_string.length() > ExoIIInterface::MAX_LINE_LENGTH )
title_string.resize( ExoIIInterface::MAX_LINE_LENGTH );
// Initialize the exodus file
int result = initialize_exodus_file( mesh_info, block_info, sideset_info, nodeset_info, title_string.c_str() );
if( result == MB_FAILURE ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_nodes | ( | int | num_nodes, |
| Range & | nodes, | ||
| int | dimension | ||
| ) | [private] |
Definition at line 799 of file WriteNCDF.cpp.
References ErrorCode, moab::fail(), moab::WriteUtilIface::get_node_coords(), GET_VAR, moab::ExoIIInterface::MAX_STR_LENGTH, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, mdbImpl, mesh, MESH_TRANSFORM_TAG_NAME, mGlobalIdTag, mWriteIface, ncFile, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
// Write coordinates names
int nc_var = -1;
GET_VAR( "coor_names", nc_var, dims );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Trouble getting coordinate name variable" );
size_t start[2] = { 0, 0 }, count[2] = { 1, ExoIIInterface::MAX_STR_LENGTH };
char dum_str[ExoIIInterface::MAX_STR_LENGTH];
strcpy( dum_str, "x" );
int fail = nc_put_vara_text( ncFile, nc_var, start, count, dum_str );
MB_SET_ERR( MB_FAILURE, "Trouble adding x coordinate name; netcdf message: " << nc_strerror( fail ) );
start[0] = 1;
strcpy( dum_str, "y" );
MB_SET_ERR( MB_FAILURE, "Trouble adding y coordinate name; netcdf message: " << nc_strerror( fail ) );
start[0] = 2;
strcpy( dum_str, "z" );
MB_SET_ERR( MB_FAILURE, "Trouble adding z coordinate name; netcdf message: " << nc_strerror( fail ) );
// See if should transform coordinates
ErrorCode result;
Tag trans_tag;
result = mdbImpl->tag_get_handle( MESH_TRANSFORM_TAG_NAME, 16, MB_TYPE_DOUBLE, trans_tag );
bool transform_needed = true;
if( result == MB_TAG_NOT_FOUND ) transform_needed = false;
int num_coords_to_fill = transform_needed ? 3 : dimension;
std::vector< double* > coord_arrays( 3 );
coord_arrays[0] = new double[num_nodes];
coord_arrays[1] = new double[num_nodes];
coord_arrays[2] = NULL;
if( num_coords_to_fill == 3 ) coord_arrays[2] = new double[num_nodes];
result = mWriteIface->get_node_coords( dimension, num_nodes, nodes, mGlobalIdTag, 1, coord_arrays );
delete[] coord_arrays[0];
delete[] coord_arrays[1];
if( coord_arrays[2] ) delete[] coord_arrays[2];
return result;
if( transform_needed )
double trans_matrix[16];
const EntityHandle mesh = 0;
result = mdbImpl->tag_get_data( trans_tag, &mesh, 0, trans_matrix );MB_CHK_SET_ERR( result, "Couldn't get transform data" );
for( int i = 0; i < num_nodes; i++ )
double vec1[3];
double vec2[3];
vec2[0] = coord_arrays[0][i];
vec2[1] = coord_arrays[1][i];
vec2[2] = coord_arrays[2][i];
for( int row = 0; row < 3; row++ )
vec1[row] = 0.0;
for( int col = 0; col < 3; col++ )
vec1[row] += ( trans_matrix[( row * 4 ) + col] * vec2[col] );
coord_arrays[0][i] = vec1[0];
coord_arrays[1][i] = vec1[1];
coord_arrays[2][i] = vec1[2];
// Write the nodes
nc_var = -1;
GET_VAR( "coord", nc_var, dims );
if( -1 == nc_var )
MB_SET_ERR( MB_FAILURE, "Trouble getting coordinate variable" );
start[0] = 0;
count[1] = num_nodes;
fail = nc_put_vara_double( ncFile, nc_var, start, count, &( coord_arrays[0][0] ) );
MB_SET_ERR( MB_FAILURE, "Trouble writing x coordinate" );
start[0] = 1;
fail = nc_put_vara_double( ncFile, nc_var, start, count, &( coord_arrays[1][0] ) );
MB_SET_ERR( MB_FAILURE, "Trouble writing y coordinate" );
start[0] = 2;
fail = nc_put_vara_double( ncFile, nc_var, start, count, &( coord_arrays[2][0] ) );
MB_SET_ERR( MB_FAILURE, "Trouble writing z coordinate" );
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_poly_faces | ( | ExodusMeshInfo & | mesh_info | ) | [private] |
Definition at line 924 of file WriteNCDF.cpp.
References moab::Range::begin(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::fail(), moab::Interface::get_connectivity(), GET_DIM, GET_VAR, INS_ID, MB_CHK_ERR, MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, mdbImpl, ncFile, moab::WriteNCDF::ExodusMeshInfo::num_polyhedra_blocks, moab::WriteNCDF::ExodusMeshInfo::polyhedronFaces, repeat_face_blocks, moab::Range::size(), and write_exodus_integer_variable().
Referenced by write_file().
// write all polygons that are not in another element block;
// usually they are nowhere else, but be sure, write in this block only ones that are not in the
// other blocks
Range pfaces = mesh_info.polyhedronFaces;
* int fbconn1(num_nod_per_fa1) ;
if( pfaces.empty() ) return MB_SUCCESS;
char wname[80];
int nc_var = -1;
// write one for each element block, to make paraview and visit happy
int num_faces_in_block = (int)pfaces.size();
for( unsigned int bl = 0; bl < mesh_info.num_polyhedra_blocks; bl++ )
INS_ID( wname, "fbconn%u", bl + 1 ); // it is the first block
INS_ID( wname, "num_nod_per_fa%u", bl + 1 );
int ncdim, num_nod_per_face;
GET_DIM( ncdim, wname, num_nod_per_face );
int* connectivity = new int[num_nod_per_face];
std::vector< int > fbepe( num_faces_in_block ); // fbepecnt1
for( Range::iterator eit = pfaces.begin(); eit != pfaces.end(); eit++ )
int nnodes = 0;
const EntityHandle* conn = NULL;
for( int k = 0; k < nnodes; k++ )
connectivity[ixcon++] = conn[k];
fbepe[j++] = nnodes;
count[0] = ixcon;
INS_ID( wname, "fbepecnt%u", bl + 1 );
count[0] = num_faces_in_block;
fail = nc_put_vara_int( ncFile, nc_var, start, count, &fbepe[0] );
int id = bl + 1;
if( write_exodus_integer_variable( "fa_prop1", &id, bl, 1 ) != MB_SUCCESS )
int status = 1;
if( write_exodus_integer_variable( "fa_status", &status, bl, 1 ) != MB_SUCCESS )
MB_SET_ERR( MB_FAILURE, "Problem writing face block status" );
if( 0 == repeat_face_blocks ) break; // do not repeat face blocks
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_qa_records | ( | std::vector< std::string > & | qa_record_list | ) | [private] |
Definition at line 755 of file WriteNCDF.cpp.
References MB_SUCCESS, and write_qa_string().
int i = 0;
for( std::vector< std::string >::iterator string_it = qa_record_list.begin(); string_it != qa_record_list.end(); )
for( int j = 0; j < 4; j++ )
write_qa_string( ( *string_it++ ).c_str(), i, j );
i++;
return MB_SUCCESS;
| ErrorCode moab::WriteNCDF::write_qa_string | ( | const char * | string, |
| int | record_number, | ||
| int | record_position | ||
| ) | [private] |
Definition at line 769 of file WriteNCDF.cpp.
Referenced by write_qa_records().
// Get the variable id in the exodus file
int temp_var = -1;
GET_VAR( "qa_records", temp_var, dims );
if( -1 == temp_var )
MB_SET_ERR( MB_FAILURE, "WriteNCDF:: Problem getting qa record variable" );
size_t count[3], start[3];
// Write out the record
start[0] = record_number;
start[1] = record_position;
start[2] = 0;
count[0] = 1;
count[1] = 1;
count[2] = (long)strlen( string ) + 1;
int fail = nc_put_vara_text( ncFile, temp_var, start, count, string );
MB_SET_ERR( MB_FAILURE, "Failed to position qa string variable" );
return MB_SUCCESS;
std::string moab::WriteNCDF::exodusFile [private] |
file name
Definition at line 135 of file WriteNCDF.hpp.
Meshset Handle for the mesh that is currently being read.
Definition at line 139 of file WriteNCDF.hpp.
Interface* moab::WriteNCDF::mdbImpl [private] |
interface instance
Definition at line 131 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), get_sideset_elems(), get_valid_sides(), initialize_exodus_file(), write_BCs(), write_elementblocks(), write_file(), write_nodes(), write_poly_faces(), and ~WriteNCDF().
Tag moab::WriteNCDF::mDirichletSetTag [private] |
Definition at line 144 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), write_file(), and WriteNCDF().
Tag moab::WriteNCDF::mDistFactorTag [private] |
Definition at line 148 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), get_valid_sides(), and WriteNCDF().
Tag moab::WriteNCDF::mEntityMark [private] |
Definition at line 152 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), get_valid_sides(), WriteNCDF(), and ~WriteNCDF().
Tag moab::WriteNCDF::mGeomDimensionTag [private] |
Definition at line 147 of file WriteNCDF.hpp.
Tag moab::WriteNCDF::mGlobalIdTag [private] |
Definition at line 149 of file WriteNCDF.hpp.
Referenced by write_BCs(), write_elementblocks(), write_nodes(), and WriteNCDF().
Tag moab::WriteNCDF::mHasMidNodesTag [private] |
Definition at line 146 of file WriteNCDF.hpp.
Referenced by WriteNCDF().
Tag moab::WriteNCDF::mMaterialSetTag [private] |
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 143 of file WriteNCDF.hpp.
Tag moab::WriteNCDF::mNeumannSetTag [private] |
Definition at line 145 of file WriteNCDF.hpp.
Tag moab::WriteNCDF::mQaRecordTag [private] |
Definition at line 150 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), and WriteNCDF().
WriteUtilIface* moab::WriteNCDF::mWriteIface [private] |
Definition at line 132 of file WriteNCDF.hpp.
Referenced by gather_mesh_information(), write_elementblocks(), write_nodes(), WriteNCDF(), and ~WriteNCDF().
int moab::WriteNCDF::ncFile [private] |
Definition at line 136 of file WriteNCDF.hpp.
Referenced by initialize_exodus_file(), open_file(), write_BCs(), write_elementblocks(), write_exodus_integer_variable(), write_file(), write_nodes(), write_poly_faces(), write_qa_string(), and ~WriteNCDF().
int moab::WriteNCDF::repeat_face_blocks [private] |
Definition at line 154 of file WriteNCDF.hpp.
Referenced by initialize_exodus_file(), write_file(), and write_poly_faces().
