Mesh Oriented datABase
(version 5.4.1)
| exodusFile | moab::WriteNCDF | [private] |
| factory(Interface *) | moab::WriteNCDF | [static] |
| find_side_element_type(const int element_id, ExoIIElementType &type) | moab::WriteNCDF | [private] |
| gather_mesh_information(ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_info, std::vector< NeumannSetData > &sideset_info, std::vector< DirichletSetData > &nodeset_info, std::vector< EntityHandle > &blocks, std::vector< EntityHandle > &sidesets, std::vector< EntityHandle > &nodesets) | moab::WriteNCDF | [private] |
| get_sideset_elems(EntityHandle sideset, int current_sense, Range &forward_elems, Range &reverse_elems) | moab::WriteNCDF | [private] |
| get_valid_sides(Range &elems, ExodusMeshInfo &mesh_info, const int sense, NeumannSetData &sideset_data) | moab::WriteNCDF | [private] |
| initialize_exodus_file(ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_data, std::vector< NeumannSetData > &sideset_data, std::vector< DirichletSetData > &nodeset_data, const char *title_string, bool write_maps=true, bool write_sideset_distribution_factors=true) | moab::WriteNCDF | [private] |
| mCurrentMeshHandle | moab::WriteNCDF | [private] |
| mdbImpl | moab::WriteNCDF | [private] |
| mDirichletSetTag | moab::WriteNCDF | [private] |
| mDistFactorTag | moab::WriteNCDF | [private] |
| mEntityMark | moab::WriteNCDF | [private] |
| mGeomDimensionTag | moab::WriteNCDF | [private] |
| mGlobalIdTag | moab::WriteNCDF | [private] |
| mHasMidNodesTag | moab::WriteNCDF | [private] |
| mMaterialSetTag | moab::WriteNCDF | [private] |
| mNeumannSetTag | moab::WriteNCDF | [private] |
| mQaRecordTag | moab::WriteNCDF | [private] |
| mWriteIface | moab::WriteNCDF | [private] |
| ncFile | moab::WriteNCDF | [private] |
| open_file(const char *file_name) | moab::WriteNCDF | [protected] |
| repeat_face_blocks | moab::WriteNCDF | [private] |
| reset_block(std::vector< MaterialSetData > &block_info) | moab::WriteNCDF | [private] |
| time_and_date(char *time_string, char *date_string) | moab::WriteNCDF | [private, static] |
| write_BCs(std::vector< NeumannSetData > &sidesets, std::vector< DirichletSetData > &nodesets) | moab::WriteNCDF | [private] |
| write_element_order_map(int num_elements) | moab::WriteNCDF | [private] |
| write_elementblocks(ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_data) | moab::WriteNCDF | [private] |
| write_exodus_integer_variable(const char *variable_name, int *variable_array, int start_position, int number_values) | moab::WriteNCDF | [private] |
| write_file(const char *exodus_file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_records, const Tag *=NULL, int=0, int user_dimension=3) | moab::WriteNCDF | [virtual] |
| write_global_element_order_map(int num_elements) | moab::WriteNCDF | [private] |
| write_global_node_order_map(int num_nodes, Range &nodes) | moab::WriteNCDF | [private] |
| write_header(ExodusMeshInfo &mesh_info, std::vector< MaterialSetData > &block_info, std::vector< NeumannSetData > &sideset_info, std::vector< DirichletSetData > &nodeset_info, const char *filename) | moab::WriteNCDF | [private] |
| write_nodes(int num_nodes, Range &nodes, int dimension) | moab::WriteNCDF | [private] |
| write_poly_faces(ExodusMeshInfo &mesh_info) | moab::WriteNCDF | [private] |
| write_qa_records(std::vector< std::string > &qa_record_list) | moab::WriteNCDF | [private] |
| write_qa_string(const char *string, int record_number, int record_position) | moab::WriteNCDF | [private] |
| WriteNCDF(Interface *impl) | moab::WriteNCDF | |
| ~WriteNCDF() | moab::WriteNCDF | [virtual] |
| ~WriterIface() | moab::WriterIface | [inline, virtual] |
