Mesh Oriented datABase
(version 5.4.1)
Collaboration diagram for moab::BSPTreePoly::Edge:Definition at line 64 of file BSPTreePoly.cpp.
| moab::BSPTreePoly::Edge::Edge | ( | Vertex * | vstart, |
| Vertex * | vend | ||
| ) | [inline] |
Definition at line 73 of file BSPTreePoly.cpp.
References endPtr, and startPtr.
: forwardPtr( 0 ), reversePtr( 0 ) #ifdef DEBUG_IDS , id( nextID++ ) #endif { startPtr = new VertexUse( this, vstart ); endPtr = new VertexUse( this, vend ); }
Definition at line 356 of file BSPTreePoly.cpp.
delete startPtr;
delete endPtr;
delete forwardPtr;
delete reversePtr;
| void moab::BSPTreePoly::Edge::add_to_vertex | ( | BSPTreePoly::Vertex * | vtx_ptr | ) |
| BSPTreePoly::Vertex* moab::BSPTreePoly::Edge::common | ( | BSPTreePoly::Edge * | eother | ) | const [inline] |
| BSPTreePoly::Vertex* moab::BSPTreePoly::Edge::end | ( | ) | const [inline] |
Definition at line 90 of file BSPTreePoly.cpp.
References endPtr, and moab::BSPTreePoly::VertexUse::vtxPtr.
Referenced by common(), moab::BSPTreePoly::cut_polyhedron(), moab::BSPTreePoly::is_valid(), moab::BSPTreePoly::set_vertex_marks(), and moab::split_edge().
| BSPTreePoly::Face* moab::BSPTreePoly::Edge::forward | ( | ) | const [inline] |
Definition at line 95 of file BSPTreePoly.cpp.
References moab::BSPTreePoly::EdgeUse::facePtr, and forwardPtr.
return forwardPtr ? forwardPtr->facePtr : 0;
| BSPTreePoly::Edge* moab::BSPTreePoly::Edge::next | ( | BSPTreePoly::Vertex * | about | ) | const [inline] |
Definition at line 108 of file BSPTreePoly.cpp.
References moab::BSPTreePoly::VertexUse::edgePtr, moab::BSPTreePoly::VertexUse::nextPtr, and use().
| BSPTreePoly::Edge* moab::BSPTreePoly::Edge::next | ( | BSPTreePoly::Face * | about | ) | const [inline] |
Definition at line 121 of file BSPTreePoly.cpp.
| BSPTreePoly::VertexUse* moab::BSPTreePoly::Edge::other | ( | BSPTreePoly::VertexUse * | vuse | ) | const [inline] |
Definition at line 130 of file BSPTreePoly.cpp.
Referenced by moab::BSPTreePoly::cut_polyhedron().
| BSPTreePoly::EdgeUse* moab::BSPTreePoly::Edge::other | ( | BSPTreePoly::EdgeUse * | vuse | ) | const [inline] |
Definition at line 134 of file BSPTreePoly.cpp.
References forwardPtr, and reversePtr.
return vuse == forwardPtr ? reversePtr : vuse == reversePtr ? forwardPtr : 0;
| BSPTreePoly::Vertex* moab::BSPTreePoly::Edge::other | ( | BSPTreePoly::Vertex * | vtx | ) | const [inline] |
| BSPTreePoly::Edge* moab::BSPTreePoly::Edge::prev | ( | BSPTreePoly::Vertex * | about | ) | const [inline] |
Definition at line 112 of file BSPTreePoly.cpp.
References moab::BSPTreePoly::VertexUse::edgePtr, moab::BSPTreePoly::VertexUse::prevPtr, and use().
| BSPTreePoly::Edge* moab::BSPTreePoly::Edge::prev | ( | BSPTreePoly::Face * | about | ) | const [inline] |
Definition at line 125 of file BSPTreePoly.cpp.
| void moab::BSPTreePoly::Edge::remove_from_face | ( | BSPTreePoly::Face *& | face_ptr | ) |
| void moab::BSPTreePoly::Edge::remove_from_vertex | ( | BSPTreePoly::Vertex *& | vtx_ptr | ) |
| BSPTreePoly::Face* moab::BSPTreePoly::Edge::reverse | ( | ) | const [inline] |
Definition at line 99 of file BSPTreePoly.cpp.
References moab::BSPTreePoly::EdgeUse::facePtr, and reversePtr.
return reversePtr ? reversePtr->facePtr : 0;
| int moab::BSPTreePoly::Edge::sense | ( | BSPTreePoly::Face * | face | ) | const |
Definition at line 364 of file BSPTreePoly.cpp.
if( forwardPtr && forwardPtr->facePtr == face )
return 1;
else if( reversePtr && reversePtr->facePtr == face )
return -1;
else
return 0;
| BSPTreePoly::Vertex* moab::BSPTreePoly::Edge::start | ( | ) | const [inline] |
Definition at line 86 of file BSPTreePoly.cpp.
References startPtr, and moab::BSPTreePoly::VertexUse::vtxPtr.
Referenced by common(), moab::BSPTreePoly::cut_polyhedron(), moab::BSPTreePoly::is_valid(), and moab::BSPTreePoly::set_vertex_marks().
| BSPTreePoly::VertexUse* moab::BSPTreePoly::Edge::use | ( | BSPTreePoly::Vertex * | vtx | ) | const [inline] |
Definition at line 104 of file BSPTreePoly.cpp.
References endPtr, startPtr, and moab::BSPTreePoly::VertexUse::vtxPtr.
Referenced by moab::BSPTreePoly::cut_polyhedron(), next(), and prev().
| BSPTreePoly::EdgeUse* moab::BSPTreePoly::Edge::use | ( | BSPTreePoly::Face * | face | ) | const [inline] |
Definition at line 117 of file BSPTreePoly.cpp.
References moab::BSPTreePoly::EdgeUse::facePtr, forwardPtr, and reversePtr.
return ( face == forwardPtr->facePtr ) ? forwardPtr : ( face == reversePtr->facePtr ) ? reversePtr : 0;
Definition at line 66 of file BSPTreePoly.cpp.
Referenced by Edge(), end(), moab::BSPTreePoly::is_valid(), other(), moab::split_edge(), and use().
Definition at line 67 of file BSPTreePoly.cpp.
Referenced by moab::BSPTreePoly::cut_polyhedron(), forward(), moab::BSPTreePoly::is_valid(), other(), moab::BSPTreePoly::set(), moab::split_edge(), moab::split_face(), and use().
Referenced by moab::BSPTreePoly::cut_polyhedron(), moab::BSPTreePoly::is_valid(), other(), reverse(), moab::BSPTreePoly::set(), moab::split_edge(), moab::split_face(), and use().
Referenced by Edge(), moab::BSPTreePoly::is_valid(), other(), start(), and use().
