Mesh Oriented datABase
(version 5.4.1)
Write MOAB HDF5 file in parallel. More...
#include <WriteHDF5Parallel.hpp>
Inheritance diagram for moab::WriteHDF5Parallel:
Collaboration diagram for moab::WriteHDF5Parallel:Classes | |
| struct | DataSetCreator |
| Argument ot create_dataset. More... | |
| struct | NoopDescCreator |
Public Member Functions | |
| WriteHDF5Parallel (Interface *iface) | |
| virtual | ~WriteHDF5Parallel () |
Static Public Member Functions | |
| static WriterIface * | factory (Interface *) |
Protected Member Functions | |
| virtual void | debug_barrier_line (int lineno) |
| virtual void | print_times (const double *times) const |
| virtual ErrorCode | parallel_create_file (const char *filename, bool overwrite, const std::vector< std::string > &qa_records, const FileOptions &opts, const Tag *user_tag_list=0, int user_tag_count=0, int dimension=3, double *times=0) |
| Called by normal (non-parallel) writer. Sets up necessary data for parallel write. | |
| ErrorCode | gather_interface_meshes (Range &non_local_ents) |
| Figure out which mesh local mesh is duplicated on remote processors and which processor will write that mesh. | |
| ErrorCode | exchange_file_ids (const Range &non_local_ents) |
| For entities that will be written by another processor but are referenced by entities on this processor, get the file Ids that will be assigned to those so they can be referenced by entities to be written on this processor. | |
| ErrorCode | communicate_shared_set_ids (const Range &owned, const Range &remote) |
| Get remote ids for shared sets. | |
| ErrorCode | pack_set (Range::const_iterator set, unsigned long *set_data, size_t set_data_length) |
| Pack set data for communication. | |
| ErrorCode | unpack_set (EntityHandle set, const unsigned long *set_data, size_t set_data_length) |
| Unpack set data from communication. | |
| ErrorCode | communicate_shared_set_data (const Range &owned, const Range &remote) |
| Communicate set contents between processors such that each owner knows the contents, parents, & child lists from all processors that have a copy of the set. | |
| ErrorCode | create_node_table (int dimension) |
| Create the node table in the file. | |
| ErrorCode | negotiate_type_list () |
| Communicate with other processors to negotiate the types of elements that will be written (the union of the types defined on each proc.) | |
| ErrorCode | create_element_tables () |
| Create tables to hold element connectivity. | |
| ErrorCode | create_adjacency_tables () |
| Create tables to hold element adjacencies. | |
| ErrorCode | create_meshset_tables (double *times) |
| Create tables for mesh sets. | |
| ErrorCode | create_tag_tables () |
| Write tag descriptions and create tables to hold tag data. | |
| void | remove_remote_entities (EntityHandle relative, Range &range) |
| Remove any remote mesh entities from the passed range. | |
| void | remove_remote_entities (EntityHandle relative, std::vector< EntityHandle > &vect) |
| void | remove_remote_sets (EntityHandle relative, Range &range) |
| void | remove_remote_sets (EntityHandle relative, std::vector< EntityHandle > &vect) |
| ErrorCode | get_sharedset_tags () |
| get any existing tags which aren't excluded and add to shared set tags | |
| ErrorCode | append_serial_tag_data (std::vector< unsigned char > &buffer, const WriteHDF5::TagDesc &tag) |
| ErrorCode | check_serial_tag_data (const std::vector< unsigned char > &buffer, std::vector< TagDesc * > *missing=0, std::vector< TagDesc * > *newlist=0) |
| helper function for create_tag_tables | |
| ErrorCode | create_dataset (int num_datasets, const long *num_owned_entities, long *offsets_out, long *max_proc_ents_out, long *total_ents_out, const DataSetCreator &creator=NoopDescCreator(), ExportSet *groups[]=0, wid_t *first_ids_out=NULL) |
| Do typical communication for dataset creation. | |
| void | print_shared_sets () |
| void | print_set_sharing_data (const Range &range, const char *label, Tag idt) |
Private Attributes | |
| ParallelComm * | myPcomm |
| pcomm controlling parallel nature of mesh | |
| bool | pcommAllocated |
| whether this instance allocated (and dtor should delete) the pcomm | |
| H5S_seloper_t | hslabOp |
| Operation to use to append hyperslab selections. | |
Definition at line 20 of file WriteHDF5Parallel.hpp.
Consturctor
Definition at line 279 of file WriteHDF5Parallel.cpp.
Referenced by factory().
: WriteHDF5( iface ), myPcomm( NULL ), pcommAllocated( false ), hslabOp( H5S_SELECT_OR ) { }
| moab::WriteHDF5Parallel::~WriteHDF5Parallel | ( | ) | [virtual] |
Definition at line 284 of file WriteHDF5Parallel.cpp.
References myPcomm, and pcommAllocated.
if( pcommAllocated && myPcomm ) delete myPcomm;
| ErrorCode moab::WriteHDF5Parallel::append_serial_tag_data | ( | std::vector< unsigned char > & | buffer, |
| const WriteHDF5::TagDesc & | tag | ||
| ) | [protected] |
Definition at line 582 of file WriteHDF5Parallel.cpp.
References moab::serial_tag_data::def_val_len, moab::error(), ErrorCode, moab::WriteHDF5::iFace, moab::serial_tag_data::len(), MB_SUCCESS, MB_VARIABLE_DATA_LENGTH, MB_VARIABLE_LENGTH, moab::serial_tag_data::name, moab::serial_tag_data::name_len, moab::serial_tag_data::set_default_value(), moab::serial_tag_data::size, moab::serial_tag_data::storage, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), moab::WriteHDF5::TagDesc::tag_id, and moab::serial_tag_data::type.
Referenced by create_tag_tables().
ErrorCode rval;
std::string name;
rval = iFace->tag_get_name( tag.tag_id, name );
if( MB_SUCCESS != rval ) return error( rval );
// Get name length, including space for null char
size_t name_len = name.size() + 1;
if( name_len == 1 ) return MB_SUCCESS; // Skip tags with no name
DataType data_type;
rval = iFace->tag_get_data_type( tag.tag_id, data_type );
// Get default value
int def_val_len;
const void* def_val;
if( MB_SUCCESS != iFace->tag_get_default_value( tag.tag_id, def_val, def_val_len ) )
def_val_len = 0;
def_val = 0;
// Allocate struct within buffer
size_t init_size = buffer.size();
buffer.resize( init_size + serial_tag_data::len( name_len, def_val_len, data_type ) );
serial_tag_data* ptr = reinterpret_cast< serial_tag_data* >( &buffer[init_size] );
// Populate struct
rval = iFace->tag_get_type( tag.tag_id, ptr->storage );
ptr->type = data_type;
rval = iFace->tag_get_length( tag.tag_id, ptr->size );
if( MB_VARIABLE_DATA_LENGTH == rval )
ptr->size = MB_VARIABLE_LENGTH;
else if( MB_SUCCESS != rval )
ptr->name_len = name_len;
Range range;
memset( ptr->name, 0, ptr->name_len );
memcpy( ptr->name, name.data(), name.size() );
ptr->def_val_len = def_val_len;
ptr->set_default_value( def_val );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::check_serial_tag_data | ( | const std::vector< unsigned char > & | buffer, |
| std::vector< TagDesc * > * | missing = 0, |
| std::vector< TagDesc * > * | newlist = 0 |
| ) | [protected] |
Definition at line 632 of file WriteHDF5Parallel.cpp.
References moab::serial_tag_data::def_val_len, moab::serial_tag_data::default_value(), moab::error(), ErrorCode, moab::WriteHDF5::iFace, moab::serial_tag_data::len(), moab::WriteHDF5::TagDesc::max_num_ents, moab::WriteHDF5::TagDesc::max_num_vals, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_VARLEN, MB_VARIABLE_LENGTH, moab::serial_tag_data::name, size, moab::serial_tag_data::size, moab::WriteHDF5::TagDesc::sparse_offset, moab::serial_tag_data::storage, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::WriteHDF5::TagDesc::tag_id, moab::WriteHDF5::tagList, moab::serial_tag_data::type, moab::WriteHDF5::TagDesc::var_data_offset, and moab::WriteHDF5::TagDesc::write_sparse.
ErrorCode rval;
// Use 'write_sparse' field as a 'visited' mark
std::list< TagDesc >::iterator tag_iter;
if( missing )
for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
tag_iter->write_sparse = true;
// Use a set as a temporary for what will ultimately go in
// newlist because we need to pass back newlist in the order
// of the tagList member.
std::set< TagDesc* > newset;
// Iterate over data from, updating the local list of tags.
// Be careful to keep tagList sorted such that in the end all
// procs have the same list in the same order.
std::vector< unsigned char >::const_iterator diter = buffer.begin();
while( diter < buffer.end() )
// Get struct from buffer
const serial_tag_data* ptr = reinterpret_cast< const serial_tag_data* >( &*diter );
// Find local struct for tag
std::string name( ptr->name );
std::string n;
iFace->tag_get_name( tag_iter->tag_id, n ); // Second time we've called, so shouldn't fail
if( n > name )
tag_iter = tagList.begin(); // New proc, start search from beginning
while( n < name )
++tag_iter;
if( tag_iter == tagList.end() ) break;
if( tag_iter == tagList.end() || n != name )
{ // New tag
TagDesc newtag;
if( ptr->size == MB_VARIABLE_LENGTH )
rval = iFace->tag_get_handle( name.c_str(), ptr->def_val_len, ptr->type, newtag.tag_id,
MB_TAG_VARLEN | MB_TAG_CREAT | ptr->storage, ptr->default_value() );
else
rval = iFace->tag_get_handle( name.c_str(), ptr->size, ptr->type, newtag.tag_id,
newtag.sparse_offset = 0;
newtag.var_data_offset = 0;
newtag.write_sparse = false;
newtag.max_num_ents = 0;
newtag.max_num_vals = 0;
tag_iter = tagList.insert( tag_iter, newtag );
if( newlist ) newset.insert( &*tag_iter );
else
{ // Check that tag is as expected
DataType type;
iFace->tag_get_data_type( tag_iter->tag_id, type );
if( type != ptr->type )
MB_SET_ERR( MB_FAILURE, "Processes have inconsistent data type for tag \"" << name << "\"" );
int size;
iFace->tag_get_length( tag_iter->tag_id, size );
if( size != ptr->size )
MB_SET_ERR( MB_FAILURE, "Processes have inconsistent size for tag \"" << name << "\"" );
tag_iter->write_sparse = false;
// Step to next variable-length struct.
diter += ptr->len();
// Now pass back any local tags that weren't in the buffer
if( missing )
if( tag_iter->write_sparse )
missing->push_back( &*tag_iter );
// Be careful to populate newlist in the same, sorted, order as tagList
if( newlist )
if( newset.find( &*tag_iter ) != newset.end() ) newlist->push_back( &*tag_iter );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::communicate_shared_set_data | ( | const Range & | owned, |
| const Range & | remote | ||
| ) | [protected] |
Definition at line 1860 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), CHECK_MB, CHECK_MPI, moab::CREATE_HANDLE(), moab::WriteHDF5::dbgOut, moab::Range::end(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_procs(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), moab::ID_FROM_HANDLE(), moab::WriteHDF5::iFace, MB_SUCCESS, MBENTITYSET, moab::Range::merge(), mhdf_SET_RANGE_BIT, myPcomm, pack_set(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::range_to_blocked_list(), moab::WriteHDF5::SpecialSetData::setFlags, moab::WriteHDF5::SpecialSetData::setHandle, size, moab::Range::size(), moab::WriteHDF5::specialSets, moab::DebugOutput::tprintf(), unpack_set(), and moab::WriteHDF5::vector_to_id_list().
Referenced by create_meshset_tables().
ErrorCode rval;
int mperr;
const unsigned rank = myPcomm->proc_config().proc_rank();
const MPI_Comm comm = myPcomm->proc_config().proc_comm();
dbgOut.tprintf( 1, "COMMUNICATING SHARED SET DATA (%lu owned & %lu remote)\n", (unsigned long)owned.size(),
(unsigned long)remote.size() );
// Calculate the total number of messages to be in transit (send and receive)
size_t nummess = 0;
std::vector< unsigned > procs;
Range shared( owned );
shared.merge( remote );
for( Range::iterator i = shared.begin(); i != shared.end(); ++i )
procs.clear();
rval = myPcomm->get_entityset_procs( *i, procs );
CHECK_MB( rval );
nummess += procs.size();
// Choose a receive buffer size. We need 4*sizeof(long) minimum,
// but that is almost useless so use 16*sizeof(long) as the minimum
// instead. Choose an upper limit such that we don't exceed 32 MB
// of allocated memory (unless we absolutely must to meet the minimum.)
// Also, don't initially choose buffers larger than 128*sizeof(long).
const size_t MAX_BUFFER_MEM = 32 * 1024 * 1024 / sizeof( long );
// const size_t INIT_BUFFER_SIZE = 128;
const size_t INIT_BUFFER_SIZE = 1024;
const size_t MIN_BUFFER_SIZE = 16;
size_t init_buff_size = INIT_BUFFER_SIZE;
if( init_buff_size * nummess > MAX_BUFFER_MEM ) init_buff_size = MAX_BUFFER_MEM / nummess;
if( init_buff_size < MIN_BUFFER_SIZE ) init_buff_size = MIN_BUFFER_SIZE;
dbgOut.printf( 2, "Using buffer size of %lu for an expected message count of %lu\n", (unsigned long)init_buff_size,
(unsigned long)nummess );
// Count number of recvs
size_t numrecv = 0;
for( Range::iterator i = owned.begin(); i != owned.end(); ++i )
procs.clear();
CHECK_MB( rval );
numrecv += procs.size();
if( std::find( procs.begin(), procs.end(), rank ) != procs.end() ) --numrecv;
// Post receive buffers for all owned sets for all sharing procs
std::vector< MPI_Request > recv_req( numrecv, MPI_REQUEST_NULL );
std::vector< MPI_Request > lrecv_req( numrecv, MPI_REQUEST_NULL );
std::vector< std::vector< unsigned long > > recv_buf( numrecv, std::vector< unsigned long >( init_buff_size ) );
int idx = 0;
procs.clear();
CHECK_MB( rval );
for( size_t j = 0; j < procs.size(); ++j )
if( procs[j] == rank ) continue;
int tag = ID_FROM_HANDLE( *i );
if( *i != CREATE_HANDLE( MBENTITYSET, tag ) )
#ifndef NDEBUG
abort();
#endif
CHECK_MB( MB_FAILURE );
dbgOut.printf( 5, "Posting buffer to receive set %d from proc %u\n", tag, procs[j] );
mperr =
MPI_Irecv( &recv_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, procs[j], tag, comm, &recv_req[idx] );
CHECK_MPI( mperr );
++idx;
assert( (size_t)idx == numrecv );
// Now send set data for all remote sets that I know about
std::vector< MPI_Request > send_req( remote.size() );
std::vector< std::vector< unsigned long > > send_buf( remote.size() );
idx = 0;
for( Range::iterator i = remote.begin(); i != remote.end(); ++i, ++idx )
send_buf[idx].resize( init_buff_size );
rval = pack_set( i, &send_buf[idx][0], init_buff_size );
CHECK_MB( rval );
EntityHandle remote_handle;
unsigned owner;
rval = myPcomm->get_entityset_owner( *i, owner, &remote_handle );
CHECK_MB( rval );
int tag = ID_FROM_HANDLE( remote_handle );
assert( remote_handle == CREATE_HANDLE( MBENTITYSET, tag ) );
dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n",
send_buf[idx][1] + send_buf[idx][2] + send_buf[idx][3] + 4, tag, owner );
mperr = MPI_Isend( &send_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
CHECK_MPI( mperr );
// Tag mattag;
// iFace->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag);
// Now initialize local data for managing contents of owned, shared sets
assert( specialSets.empty() );
specialSets.clear();
specialSets.reserve( owned.size() );
// int block;
// if (MB_SUCCESS != iFace->tag_get_data(mattag, &*i, 1, &block))
// block = 0;
// std::vector<int> ids;
SpecialSetData data;
data.setHandle = *i;
rval = iFace->get_meshset_options( *i, data.setFlags );
CHECK_MB( rval );
specialSets.push_back( data );
std::vector< EntityHandle > list;
if( data.setFlags & MESHSET_ORDERED )
list.clear();
rval = iFace->get_entities_by_handle( *i, list );
CHECK_MB( rval );
rval = vector_to_id_list( list, specialSets.back().contentIds, true );
CHECK_MB( rval );
// if (block)
// get_global_ids(iFace, &list[0], list.size(), MESHSET_ORDERED, ids);
else
Range range;
rval = iFace->get_entities_by_handle( *i, range );
CHECK_MB( rval );
bool ranged;
rval = range_to_blocked_list( range, specialSets.back().contentIds, ranged );
if( ranged ) specialSets.back().setFlags |= mhdf_SET_RANGE_BIT;
// if (block) {
// std::vector<EntityHandle> tmp;
// for (Range::const_pair_iterator pi = range.const_pair_begin(); pi !=
// range.const_pair_end(); ++pi) {
// tmp.push_back(pi->first);
// tmp.push_back(pi->second);
// get_global_ids(iFace, &tmp[0], tmp.size(), ranged ? 0 : MESHSET_ORDERED, ids);
list.clear();
rval = iFace->get_parent_meshsets( *i, list );
CHECK_MB( rval );
rval = vector_to_id_list( list, specialSets.back().parentIds, true );
CHECK_MB( rval );
rval = iFace->get_child_meshsets( *i, list );
CHECK_MB( rval );
rval = vector_to_id_list( list, specialSets.back().childIds, true );
CHECK_MB( rval );
// Process received buffers, repost larger buffers where necessary
size_t remaining = numrecv;
numrecv = 0;
while( remaining-- )
std::vector< unsigned long > dead;
MPI_Status status;
mperr = MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status );
CHECK_MPI( mperr );
EntityHandle handle = CREATE_HANDLE( MBENTITYSET, status.MPI_TAG );
std::vector< unsigned long >& buff = recv_buf[idx];
size_t size = buff[1] + buff[2] + buff[3] + 4;
dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", (unsigned long)size, status.MPI_TAG,
status.MPI_SOURCE );
if( size <= init_buff_size )
rval = unpack_set( handle, &buff[0], init_buff_size );
CHECK_MB( rval );
dead.swap( buff ); // Release memory
else
// Data was too big for init_buff_size
// repost with larger buffer
buff.resize( size );
dbgOut.printf( 5, "Re-Posting buffer to receive set %d from proc %d with size %lu\n", status.MPI_TAG,
status.MPI_SOURCE, (unsigned long)size );
mperr = MPI_Irecv( &buff[0], size, MPI_UNSIGNED_LONG, status.MPI_SOURCE, status.MPI_TAG, comm,
&lrecv_req[idx] );
CHECK_MPI( mperr );
++numrecv;
recv_req[idx] = MPI_REQUEST_NULL;
// Wait for sends to complete
MPI_Waitall( send_req.size(), &send_req[0], MPI_STATUSES_IGNORE );
// Re-send sets that didn't fit initial buffer size
idx = 0;
std::vector< unsigned long >& buff = send_buf[idx];
if( size <= init_buff_size ) continue;
rval = pack_set( i, &buff[0], size );
CHECK_MB( rval );
unsigned owner;
CHECK_MB( rval );
dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n", (unsigned long)size, tag, owner );
mperr = MPI_Isend( &buff[0], size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
CHECK_MPI( mperr );
MPI_Status status;
mperr = MPI_Waitany( lrecv_req.size(), &lrecv_req[0], &idx, &status );
CHECK_MPI( mperr );
dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", 4 + buff[1] + buff[2] + buff[3],
status.MPI_TAG, status.MPI_SOURCE );
rval = unpack_set( handle, &buff[0], buff.size() );
CHECK_MB( rval );
lrecv_req[idx] = MPI_REQUEST_NULL;
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::communicate_shared_set_ids | ( | const Range & | owned, |
| ) | [protected] |
Definition at line 1511 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), CHECK_MB, CHECK_MPI, moab::WriteHDF5::dbgOut, moab::Range::end(), moab::error(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::WriteHDF5::find(), moab::ParallelComm::get_entityset_local_handle(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_owners(), moab::ParallelComm::get_entityset_procs(), moab::ParallelComm::get_owned_sets(), moab::DebugOutput::get_verbosity(), moab::WriteHDF5::idMap, moab::RangeMap< KeyType, ValType, NullVal >::insert(), moab::Range::insert(), moab::intersect(), MB_SUCCESS, myPcomm, moab::DebugOutput::print(), print_shared_sets(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Range::rbegin(), moab::Range::rend(), size, moab::Range::size(), moab::SSVB, and moab::DebugOutput::tprint().
ErrorCode rval;
int mperr;
const int TAG = 0xD0E;
// const unsigned rank = myPcomm->proc_config().proc_rank();
dbgOut.tprint( 1, "COMMUNICATING SHARED SET IDS\n" );
dbgOut.print( 6, "Owned, shared sets: ", owned );
// Post receive buffers for all procs for which we share sets
rval = myPcomm->get_entityset_owners( procs );
CHECK_MB( rval );
std::vector< unsigned >::iterator it = std::find( procs.begin(), procs.end(), myPcomm->proc_config().proc_rank() );
if( it != procs.end() ) procs.erase( it );
std::vector< MPI_Request > recv_req( procs.size(), MPI_REQUEST_NULL );
std::vector< std::vector< unsigned long > > recv_buf( procs.size() );
size_t recv_count = 0;
for( size_t i = 0; i < procs.size(); ++i )
Range tmp;
rval = myPcomm->get_owned_sets( procs[i], tmp );
CHECK_MB( rval );
size_t count =
intersect( tmp, remote ).size(); // Necessary because we might not be writing all of the database
if( count )
dbgOut.printf( 6, "Sets owned by proc %u (remote handles): ", procs[i] );
if( dbgOut.get_verbosity() >= 6 )
Range remote_handles;
tmp = intersect( tmp, remote );
for( Range::iterator j = tmp.begin(); j != tmp.end(); ++j )
unsigned r;
EntityHandle h;
myPcomm->get_entityset_owner( *j, r, &h );
assert( r == procs[i] );
remote_handles.insert( h );
dbgOut.print( 6, remote_handles );
recv_count++;
recv_buf[i].resize( 2 * count + 1 );
dbgOut.printf( 5, "Posting receive buffer of size %lu for proc %u (%lu of %lu owned sets)\n",
(unsigned long)recv_buf[i].size(), procs[i], count, tmp.size() );
mperr =
MPI_Irecv( &recv_buf[i][0], recv_buf[i].size(), MPI_UNSIGNED_LONG, procs[i], TAG, comm, &recv_req[i] );
CHECK_MPI( mperr );
// Send set ids to all procs with which we share them
// First build per-process lists of sets for which we need to send data
std::map< unsigned, Range > send_sets;
std::vector< unsigned > set_procs;
for( Range::reverse_iterator i = owned.rbegin(); i != owned.rend(); ++i )
set_procs.clear();
rval = myPcomm->get_entityset_procs( *i, set_procs );
CHECK_MB( rval );
for( size_t j = 0; j < set_procs.size(); ++j )
if( set_procs[j] != myPcomm->proc_config().proc_rank() ) send_sets[set_procs[j]].insert( *i );
assert( send_sets.find( myPcomm->proc_config().proc_rank() ) == send_sets.end() );
// Now send the data
std::vector< std::vector< unsigned long > > send_buf( send_sets.size() );
std::vector< MPI_Request > send_req( send_sets.size() );
std::map< unsigned, Range >::iterator si = send_sets.begin();
for( size_t i = 0; si != send_sets.end(); ++si, ++i )
dbgOut.printf( 6, "Sending data for shared sets to proc %u: ", si->first );
dbgOut.print( 6, si->second );
send_buf[i].reserve( 2 * si->second.size() + 1 );
send_buf[i].push_back( si->second.size() );
for( Range::iterator j = si->second.begin(); j != si->second.end(); ++j )
send_buf[i].push_back( *j );
send_buf[i].push_back( idMap.find( *j ) );
dbgOut.printf( 5, "Sending buffer of size %lu to proc %u (%lu of %lu owned sets)\n",
(unsigned long)send_buf[i].size(), si->first, si->second.size(), owned.size() );
mperr = MPI_Isend( &send_buf[i][0], send_buf[i].size(), MPI_UNSIGNED_LONG, si->first, TAG, comm, &send_req[i] );
// Process received data
MPI_Status status;
int idx;
while( recv_count-- )
CHECK_MPI( mperr );
assert( (unsigned)status.MPI_SOURCE == procs[idx] );
assert( 2 * recv_buf[idx].front() + 1 == recv_buf[idx].size() );
const size_t n = std::min< size_t >( recv_buf[idx].front(), ( recv_buf[idx].size() - 1 ) / 2 );
dbgOut.printf( 5, "Received buffer of size %lu from proc %d\n", (unsigned long)( 2 * n + 1 ),
(int)status.MPI_SOURCE );
for( size_t i = 0; i < n; ++i )
EntityHandle handle = 0;
rval = myPcomm->get_entityset_local_handle( procs[idx], recv_buf[idx][2 * i + 1], handle );
CHECK_MB( rval );
assert( handle != 0 );
if( !idMap.insert( handle, recv_buf[idx][2 * i + 2], 1 ).second )
error( MB_FAILURE ); // Conflicting IDs??????
assert( MPI_SUCCESS == MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status ) &&
MPI_UNDEFINED == idx ); // Check that we got them all
// Wait for all sends to complete before we release send
// buffers (implicitly releases when we return from this function)
std::vector< MPI_Status > stats( send_req.size() );
mperr = MPI_Waitall( send_req.size(), &send_req[0], &stats[0] );
CHECK_MPI( mperr );
if( dbgOut.get_verbosity() >= SSVB ) print_shared_sets();
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::create_adjacency_tables | ( | ) | [protected] |
Definition at line 1402 of file WriteHDF5Parallel.cpp.
References CHECK_HDFN, CHECK_MB, moab::WriteHDF5::count_adjacencies(), create_dataset(), ErrorCode, moab::WriteHDF5::exportList, moab::WriteHDF5::file_ptr(), MB_SUCCESS, mhdf_closeData(), mhdf_createAdjacency(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5::nodeSet, and size.
Referenced by parallel_create_file().
struct AdjSetCreator : public DataSetCreator
ErrorCode operator()( WriteHDF5* file, long size, const ExportSet* ex, long& start_id ) const
mhdf_Status status;
hid_t handle = mhdf_createAdjacency( file->file_ptr(), ex->name(), size, &status );
CHECK_HDFN( status );
mhdf_closeData( file->file_ptr(), handle, &status );
start_id = -1;
return MB_SUCCESS;
std::vector< ExportSet* > groups;
#ifdef WRITE_NODE_ADJACENCIES
groups.push_back( &nodeSet );
#endif
for( std::list< ExportSet >::iterator ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter )
groups.push_back( &*ex_iter );
ErrorCode rval;
const int numtypes = groups.size();
std::vector< long > counts( numtypes );
std::vector< long > offsets( numtypes );
std::vector< long > max_ents( numtypes );
std::vector< long > totals( numtypes );
for( int i = 0; i < numtypes; ++i )
wid_t count;
rval = count_adjacencies( groups[i]->range, count );
CHECK_MB( rval );
counts[i] = count;
rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &totals[0], AdjSetCreator(), &groups[0] );
CHECK_MB( rval );
// Cppcheck warning (false positive): variable groups is assigned a value that is never used
groups[i]->max_num_adjs = max_ents[i];
groups[i]->adj_offset = offsets[i];
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::create_dataset | ( | int | num_datasets, |
| const long * | num_owned_entities, | ||
| long * | offsets_out, | ||
| long * | max_proc_ents_out, | ||
| long * | total_ents_out, | ||
| const DataSetCreator & | creator = NoopDescCreator(), |
| ExportSet * | groups[] = 0, |
| wid_t * | first_ids_out = NULL |
| ) | [protected] |
Given the number of entities each processor intends to write, do necessary communication and create dataset on root, passing back misc info to each proc.
| creator | Functor to do actual dataset creation. Used only on root process. |
| num_datasets | The number of datasets to create. |
| groups | Third argument passed to DataSetCreator. Array of length num_datasets pr NULL. |
| num_owned_entities | The number of entities this proc will write. Array of length num_datasets . |
| offsets_out | Output: The offset in the dataset at which this process should write. Array of length num_datasets . |
| max_proc_ents_out | Output: The maximun number of entities that any proc will write Array of length num_datasets . |
| total_ents_out | Output: The size of the created dataset (sum of counts over all procs) Array of length num_datasets . |
| first_ids_out | Output: The first ID of the first entity in the data set. First ID for this proc's entities is first_id_out+offset_out Array of length num_datasets or NULL. |
Definition at line 1080 of file WriteHDF5Parallel.cpp.
References CHECK_MB, CHECK_MPI, ErrorCode, MB_SUCCESS, myPcomm, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and VALGRIND_CHECK_MEM_IS_DEFINED.
Referenced by create_adjacency_tables(), create_element_tables(), create_meshset_tables(), create_node_table(), and create_tag_tables().
int result;
ErrorCode rval;
const unsigned nproc = myPcomm->proc_config().proc_size();
// Gather entity counts for each processor on root
std::vector< long > counts( rank ? 0 : nproc * num_datasets );
(void)VALGRIND_CHECK_MEM_IS_DEFINED( &num_owned, sizeof( long ) );
result = MPI_Gather( const_cast< long* >( num_owned ), num_datasets, MPI_LONG, &counts[0], num_datasets, MPI_LONG,
0, comm );
CHECK_MPI( result );
// Create node data in file
DatasetVals zero_val = { 0, 0, 0 };
std::vector< DatasetVals > cumulative( num_datasets, zero_val );
if( rank == 0 )
for( unsigned i = 0; i < nproc; i++ )
const long* proc_data = &counts[i * num_datasets];
for( int index = 0; index < num_datasets; ++index )
cumulative[index].total += proc_data[index];
if( proc_data[index] > cumulative[index].max_count ) cumulative[index].max_count = proc_data[index];
if( cumulative[index].total )
rval = creator( this, cumulative[index].total, groups ? groups[index] : 0, cumulative[index].start_id );
CHECK_MB( rval );
else
cumulative[index].start_id = -1;
// Send id offset to every proc
result = MPI_Bcast( (void*)&cumulative[0], 3 * num_datasets, MPI_LONG, 0, comm );
if( first_ids_out ) first_ids_out[index] = (wid_t)cumulative[index].start_id;
max_proc_entities[index] = cumulative[index].max_count;
total_entities[index] = cumulative[index].total;
// Convert array of per-process counts to per-process offsets
if( rank == 0 )
// Initialize prev_size with data sizes for root process
std::vector< long > prev_size( counts.begin(), counts.begin() + num_datasets );
// Root process gets offset zero
std::fill( counts.begin(), counts.begin() + num_datasets, 0L );
// For each proc other than this one (root)
for( unsigned i = 1; i < nproc; ++i )
// Get pointer to offsets for previous process in list
long* prev_data = &counts[( i - 1 ) * num_datasets];
// Get pointer to offsets for this process in list
// For each data set
for( int j = 0; j < num_datasets; ++j )
// Get size of data in dataset from process i
long mysize = proc_data[j];
// Offset for process i is offset of previous process plus
// number of values previous process will write
proc_data[j] = prev_data[j] + prev_size[j];
// Store my size, as it is no longer available in 'counts'
prev_size[j] = mysize;
// Send each proc it's offset in the table
if( rank == 0 )
(void)VALGRIND_CHECK_MEM_IS_DEFINED( &counts[0], num_datasets * nproc * sizeof( long ) );
result = MPI_Scatter( &counts[0], num_datasets, MPI_LONG, offsets_out, num_datasets, MPI_LONG, 0, comm );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::create_element_tables | ( | ) | [protected] |
Definition at line 1363 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_MB, create_dataset(), moab::WriteHDF5::create_elem_table(), ErrorCode, moab::WriteHDF5::exportList, MB_SUCCESS, and size.
struct ElemSetCreator : public DataSetCreator
return file->create_elem_table( *ex, size, start_id );
const int numtypes = exportList.size();
std::vector< ExportSet* > groups( numtypes );
std::vector< long > counts( numtypes ), offsets( numtypes ), max_ents( numtypes ), total_ents( numtypes );
std::vector< wid_t > start_ids( numtypes );
size_t idx = 0;
std::list< ExportSet >::iterator ex_iter;
for( ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
groups[idx] = &*ex_iter;
counts[idx] = ex_iter->range.size();
ErrorCode rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &total_ents[0], ElemSetCreator(),
&groups[0], &start_ids[0] );
CHECK_MB( rval );
for( idx = 0, ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
ex_iter->first_id = start_ids[idx];
ex_iter->offset = offsets[idx];
ex_iter->max_num_ents = max_ents[idx];
ex_iter->total_num_ents = total_ents[idx];
rval = assign_ids( ex_iter->range, ex_iter->first_id + ex_iter->offset );
CHECK_MB( rval );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::create_meshset_tables | ( | double * | times | ) | [protected] |
Definition at line 2110 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_MB, communicate_shared_set_data(), communicate_shared_set_ids(), moab::WriteHDF5::count_set_size(), create_dataset(), moab::WriteHDF5::create_set_meta(), moab::WriteHDF5::create_set_tables(), moab::WriteHDF5::dbgOut, END_SERIAL, ErrorCode, moab::WriteHDF5::ExportSet::first_id, moab::ParallelComm::get_owned_sets(), moab::ParallelComm::get_shared_sets(), moab::WriteHDF5::iFace, moab::intersect(), moab::WriteHDF5::ExportSet::max_num_ents, moab::WriteHDF5::maxNumSetChildren, moab::WriteHDF5::maxNumSetContents, moab::WriteHDF5::maxNumSetParents, MB_SUCCESS, myPcomm, moab::WriteHDF5::ExportSet::offset, moab::print_type_sets(), moab::DebugOutput::printf(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::ExportSet::range, moab::WriteHDF5::SET_OFFSET_TIME, moab::WriteHDF5::setChildrenOffset, moab::WriteHDF5::setContentsOffset, moab::WriteHDF5::setParentsOffset, moab::WriteHDF5::setSet, moab::WriteHDF5::SHARED_SET_CONTENTS, moab::WriteHDF5::SHARED_SET_IDS, size, moab::Range::size(), START_SERIAL, moab::subtract(), moab::CpuTimer::time_elapsed(), moab::WriteHDF5::ExportSet::total_num_ents, moab::WriteHDF5::writeSetChildren, moab::WriteHDF5::writeSetContents, moab::WriteHDF5::writeSetParents, and moab::WriteHDF5::writeSets.
Range::const_iterator riter;
START_SERIAL;
print_type_sets( iFace, &dbgOut, setSet.range );
END_SERIAL;
CpuTimer timer;
// Remove remote sets from setSets
Range shared, owned, remote;
ErrorCode rval = myPcomm->get_shared_sets( shared );
CHECK_MB( rval );
shared = intersect( shared, setSet.range );
rval = myPcomm->get_owned_sets( rank, owned );
CHECK_MB( rval );
owned = intersect( owned, setSet.range );
remote = subtract( shared, owned );
setSet.range = subtract( setSet.range, remote );
// Create set meta table
struct SetDescCreator : public DataSetCreator
ErrorCode operator()( WriteHDF5* writer, long size, const ExportSet*, long& start_id ) const
return writer->create_set_meta( size, start_id );
long count = setSet.range.size();
rval = create_dataset( 1, &count, &setSet.offset, &setSet.max_num_ents, &setSet.total_num_ents, SetDescCreator(),
NULL, &setSet.first_id );
CHECK_MB( rval );
writeSets = setSet.max_num_ents > 0;
rval = assign_ids( setSet.range, setSet.first_id + setSet.offset );
CHECK_MB( rval );
if( times ) times[SET_OFFSET_TIME] = timer.time_elapsed();
// Exchange file IDS for sets between all procs
rval = communicate_shared_set_ids( owned, remote );
CHECK_MB( rval );
if( times ) times[SHARED_SET_IDS] = timer.time_elapsed();
// Communicate remote set contents, children, etc.
rval = communicate_shared_set_data( owned, remote );
CHECK_MB( rval );
if( times ) times[SHARED_SET_CONTENTS] = timer.time_elapsed();
// Communicate counts for owned sets
long data_counts[3]; // { #contents, #children, #parents }
rval = count_set_size( setSet.range, data_counts[0], data_counts[1], data_counts[2] );
CHECK_MB( rval );
if( times ) times[SET_OFFSET_TIME] += timer.time_elapsed();
long offsets[3], max_counts[3], totals[3];
rval = create_dataset( 3, data_counts, offsets, max_counts, totals );
CHECK_MB( rval );
// Create the datasets
if( 0 == myPcomm->proc_config().proc_rank() )
rval = create_set_tables( totals[0], totals[1], totals[2] );
CHECK_MB( rval );
// Store communicated global data
setContentsOffset = offsets[0];
setChildrenOffset = offsets[1];
setParentsOffset = offsets[2];
maxNumSetContents = max_counts[0];
maxNumSetChildren = max_counts[1];
maxNumSetParents = max_counts[2];
writeSetContents = totals[0] > 0;
writeSetChildren = totals[1] > 0;
writeSetParents = totals[2] > 0;
dbgOut.printf( 2, "set contents: %ld local, %ld global, offset = %ld\n", data_counts[0], totals[0], offsets[0] );
dbgOut.printf( 2, "set children: %ld local, %ld global, offset = %ld\n", data_counts[1], totals[1], offsets[1] );
dbgOut.printf( 2, "set parents: %ld local, %ld global, offset = %ld\n", data_counts[2], totals[2], offsets[2] );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::create_node_table | ( | int | dimension | ) | [protected] |
Definition at line 1180 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_HDFN, CHECK_MB, create_dataset(), ErrorCode, moab::WriteHDF5::file_ptr(), moab::WriteHDF5::ExportSet::first_id, moab::WriteHDF5::ExportSet::max_num_ents, MB_SUCCESS, mhdf_closeData(), mhdf_createNodeCoords(), moab::WriteHDF5::nodeSet, moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::offset, moab::WriteHDF5::ExportSet::range, moab::Range::size(), and moab::WriteHDF5::ExportSet::total_num_ents.
nodeSet.num_nodes = dimension; // Put it here so NodeSetCreator can access it
struct NodeSetCreator : public DataSetCreator
ErrorCode operator()( WriteHDF5* file, long count, const ExportSet* group, long& start_id ) const
mhdf_Status status;
hid_t handle = mhdf_createNodeCoords( file->file_ptr(), group->num_nodes, count, &start_id, &status );
return MB_SUCCESS;
const long count = nodeSet.range.size();
ExportSet* array[] = { &nodeSet };
ErrorCode rval = create_dataset( 1, &count, &nodeSet.offset, &nodeSet.max_num_ents, &nodeSet.total_num_ents,
NodeSetCreator(), array, &nodeSet.first_id );
CHECK_MB( rval );
return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
| ErrorCode moab::WriteHDF5Parallel::create_tag_tables | ( | ) | [protected] |
Definition at line 753 of file WriteHDF5Parallel.cpp.
References append_serial_tag_data(), moab::WriteHDF5::check_dense_format_tag(), CHECK_MB, CHECK_MPI, check_serial_tag_data(), create_dataset(), moab::WriteHDF5::create_tag(), moab::WriteHDF5::dbgOut, moab::error(), ErrorCode, moab::WriteHDF5::exportList, moab::get_bit(), moab::WriteHDF5::get_num_sparse_tagged_entities(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::WriteHDF5::get_tag_data_length(), moab::DebugOutput::get_verbosity(), moab::WriteHDF5::iFace, MB_SET_ERR_CONT, MB_SUCCESS, MB_TAG_DENSE, MB_VARIABLE_DATA_LENGTH, moab::my_Gatherv(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::ExportSet::range, moab::set_bit(), moab::WriteHDF5::setSet, size, moab::Range::size(), moab::WriteHDF5::subState, moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), moab::WriteHDF5::tagList, TagType, moab::DebugOutput::tprint(), and moab::WriteHDF5::writeTagDense.
ErrorCode rval;
int err;
const int rank = myPcomm->proc_config().proc_rank();
subState.start( "negotiating tag list" );
dbgOut.tprint( 1, "communicating tag metadata\n" );
dbgOut.printf( 2, "Exchanging tag data for %d tags.\n", (int)tagList.size() );
// Sort tagList contents in alphabetical order by tag name
tagList.sort( TagNameCompare( iFace ) );
// Negotiate total list of tags to write
// Build concatenated list of all tag data
std::vector< unsigned char > tag_buffer;
rval = append_serial_tag_data( tag_buffer, *tag_iter );
CHECK_MB( rval );
// Broadcast list from root to all other procs
unsigned long size = tag_buffer.size();
err = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, comm );
CHECK_MPI( err );
tag_buffer.resize( size );
err = MPI_Bcast( &tag_buffer[0], size, MPI_UNSIGNED_CHAR, 0, comm );
CHECK_MPI( err );
// Update local tag list
std::vector< TagDesc* > missing;
rval = check_serial_tag_data( tag_buffer, &missing, 0 );
CHECK_MB( rval );
// Check if we're done (0->done, 1->more, 2+->error)
int code, lcode = ( MB_SUCCESS != rval ) ? rval + 2 : missing.empty() ? 0 : 1;
err = MPI_Allreduce( &lcode, &code, 1, MPI_INT, MPI_MAX, comm );
CHECK_MPI( err );
if( code > 1 )
MB_SET_ERR_CONT( "Inconsistent tag definitions between procs" );
return error( (ErrorCode)( code - 2 ) );
// If not done...
if( code )
dbgOut.print( 1, "Not all procs had same tag definitions, negotiating...\n" );
// Get tags defined on this proc but not on root proc
tag_buffer.clear();
for( size_t i = 0; i < missing.size(); ++i )
rval = append_serial_tag_data( tag_buffer, *missing[i] );
CHECK_MB( rval );
// Gather extra tag definitions on root processor
std::vector< int > junk; // don't care how many from each proc
assert( rank || tag_buffer.empty() ); // must be empty on root
err = my_Gatherv( &tag_buffer[0], tag_buffer.size(), MPI_UNSIGNED_CHAR, tag_buffer, junk, 0, comm );
CHECK_MPI( err );
// Process serialized tag descriptions on root, and
rval = MB_SUCCESS;
if( 0 == rank )
std::vector< TagDesc* > newlist;
rval = check_serial_tag_data( tag_buffer, 0, &newlist );
tag_buffer.clear();
// re-serialize a unique list of new tag definitions
for( size_t i = 0; MB_SUCCESS == rval && i != newlist.size(); ++i )
rval = append_serial_tag_data( tag_buffer, *newlist[i] );
CHECK_MB( rval );
// Broadcast any new tag definitions from root to other procs
long this_size = tag_buffer.size();
if( MB_SUCCESS != rval ) this_size = -rval;
err = MPI_Bcast( &this_size, 1, MPI_LONG, 0, comm );
CHECK_MPI( err );
if( this_size < 0 )
return error( (ErrorCode)-this_size );
tag_buffer.resize( this_size );
err = MPI_Bcast( &tag_buffer[0], this_size, MPI_UNSIGNED_CHAR, 0, comm );
CHECK_MPI( err );
// Process new tag definitions
rval = check_serial_tag_data( tag_buffer, 0, 0 );
CHECK_MB( rval );
subState.end();
subState.start( "negotiate which element/tag combinations are dense" );
// Figure out for which tag/element combinations we can
// write dense tag data.
// Construct a table of bits,
// where each row of the table corresponds to a tag
// and each column to an element group.
// Two extra, because first is nodes and last is sets.
// (n+7)/8 is ceil(n/8)
const int bytes_per_tag = ( exportList.size() + 9 ) / 8;
std::vector< unsigned char > data( bytes_per_tag * tagList.size(), 0 );
std::vector< unsigned char > recv( data.size(), 0 );
unsigned char* iter = &data[0];
if( writeTagDense && !data.empty() )
for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, iter += bytes_per_tag )
Range tagged;
rval = get_sparse_tagged_entities( *tag_iter, tagged );
CHECK_MB( rval );
int s;
if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) ) continue;
std::string n;
// Check if we want to write this tag in dense format even if not
// all of the entities have a tag value. The criterion of this
// is that the tag be dense, have a default value, and have at
// least 2/3 of the entities tagged.
bool prefer_dense = false;
TagType type;
rval = iFace->tag_get_type( tag_iter->tag_id, type );
CHECK_MB( rval );
if( MB_TAG_DENSE == type )
const void* defval = 0;
rval = iFace->tag_get_default_value( tag_iter->tag_id, defval, s );
if( MB_SUCCESS == rval ) prefer_dense = true;
int i = 0;
if( check_dense_format_tag( nodeSet, tagged, prefer_dense ) )
set_bit( i, iter );
dbgOut.printf( 2, "Can write dense data for \"%s\"/Nodes\n", n.c_str() );
std::list< ExportSet >::const_iterator ex_iter = exportList.begin();
for( ++i; ex_iter != exportList.end(); ++i, ++ex_iter )
// when writing in parallel, on some partitions, some of these element ranges might
// be empty so do not turn this tag as sparse, just because of that, leave it dense,
// if we prefer dense
if( ( prefer_dense && ex_iter->range.empty() ) ||
check_dense_format_tag( *ex_iter, tagged, prefer_dense ) )
set_bit( i, iter );
dbgOut.printf( 2, "Can write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
if( check_dense_format_tag( setSet, tagged, prefer_dense ) )
set_bit( i, iter );
dbgOut.printf( 2, "Can write dense data for \"%s\"/Sets\n", n.c_str() );
// Do bit-wise AND of list over all processors (only write dense format
// if all proccesses want dense format for this group of entities).
err = MPI_Allreduce( &data[0], &recv[0], data.size(), MPI_UNSIGNED_CHAR, MPI_BAND,
myPcomm->proc_config().proc_comm() );
CHECK_MPI( err );
} // if (writeTagDense)
// Store initial counts for sparse-formatted tag data.
// The total number of values to send and receive will be the number of
// tags plus the number of var-len tags because we need to negotiate
// offsets into two different tables for the var-len tags.
std::vector< long > counts;
// Record dense tag/element combinations
iter = &recv[0];
const unsigned char* iter2 = &data[0];
++tag_iter, iter += bytes_per_tag, iter2 += bytes_per_tag )
Range tagged;
CHECK_MB( rval );
std::string n;
int i = 0;
if( get_bit( i, iter ) )
assert( get_bit( i, iter2 ) );
tag_iter->dense_list.push_back( nodeSet );
tagged -= nodeSet.range;
dbgOut.printf( 2, "Will write dense data for \"%s\"/Nodes\n", n.c_str() );
tag_iter->dense_list.push_back( *ex_iter );
dbgOut.printf( 2, "WIll write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
tagged -= ex_iter->range;
tag_iter->dense_list.push_back( setSet );
dbgOut.printf( 2, "Will write dense data for \"%s\"/Sets\n", n.c_str() );
tagged -= setSet.range;
counts.push_back( tagged.size() );
int s;
unsigned long data_len;
rval = get_tag_data_length( *tag_iter, tagged, data_len );
CHECK_MB( rval );
counts.push_back( data_len );
subState.end();
subState.start( "Negotiate offsets for sparse tag info" );
std::vector< long > offsets( counts.size() ), maxima( counts.size() ), totals( counts.size() );
rval = create_dataset( counts.size(), &counts[0], &offsets[0], &maxima[0], &totals[0] );
CHECK_MB( rval );
// Copy values into local structs and if root then create tables
size_t idx = 0;
for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++idx )
assert( idx < counts.size() );
tag_iter->sparse_offset = offsets[idx];
tag_iter->max_num_ents = maxima[idx];
tag_iter->write_sparse = ( 0 != totals[idx] );
int s;
++idx;
tag_iter->var_data_offset = offsets[idx];
tag_iter->max_num_vals = maxima[idx];
else
tag_iter->var_data_offset = 0;
tag_iter->max_num_vals = 0;
subState.end();
// Create tag tables on root process
size_t iidx = 0;
for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++iidx )
assert( iidx < totals.size() );
unsigned long num_ents = totals[iidx];
unsigned long num_val = 0;
int s;
++iidx;
num_val = totals[iidx];
dbgOut.printf( 2, "Writing tag description for tag 0x%lx with %lu values\n",
(unsigned long)tag_iter->tag_id, num_val ? num_val : num_ents );
rval = create_tag( *tag_iter, num_ents, num_val );
if( dbgOut.get_verbosity() > 1 )
dbgOut.printf( 2, "Tags: %12s %8s %8s %8s %8s %8s\n", "Name", "Count", "Offset", "Var Off", "Max Ent",
"Handle" );
std::string name;
iFace->tag_get_name( tag_iter->tag_id, name );
size_t this_size;
get_num_sparse_tagged_entities( *tag_iter, this_size );
dbgOut.printf( 2, "%18s %8lu %8lu %8lu %8lu 0x%7lx\n", name.c_str(), (unsigned long)this_size,
(unsigned long)tag_iter->sparse_offset, (unsigned long)tag_iter->var_data_offset,
(unsigned long)tag_iter->max_num_ents, (unsigned long)tag_iter->tag_id );
return MB_SUCCESS;
| void moab::WriteHDF5Parallel::debug_barrier_line | ( | int | lineno | ) | [protected, virtual] |
Reimplemented from moab::WriteHDF5.
Definition at line 263 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::dbgOut, moab::DebugOutput::get_verbosity(), myPcomm, moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), and moab::ParallelComm::proc_config().
const unsigned threshold = 2;
static unsigned long count = 0;
if( dbgOut.get_verbosity() >= threshold && myPcomm )
dbgOut.printf( threshold, "*********** Debug Barrier %lu (@%d)***********\n", ++count, lineno );
MPI_Barrier( myPcomm->proc_config().proc_comm() );
| ErrorCode moab::WriteHDF5Parallel::exchange_file_ids | ( | const Range & | non_local_ents | ) | [protected] |
| non_local_ents | List of entities that are not to be written by this processor but are referenced by other entities that are to be written. |
Definition at line 2257 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::WriteHDF5::dbgOut, moab::Range::end(), moab::CN::EntityTypeName(), moab::error(), ErrorCode, moab::ParallelComm::exchange_tags(), moab::WriteHDF5::exportList, moab::ParallelComm::filter_pstatus(), moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::ParallelComm::get_owner(), moab::ID_FROM_HANDLE(), moab::WriteHDF5::idMap, moab::WriteHDF5::iFace, moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, moab::Range::merge(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::printf(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_AND, PSTATUS_SHARED, moab::WriteHDF5::ExportSet::range, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::TYPE_FROM_HANDLE().
ErrorCode rval;
// For each entity owned on the interface, write its file id to
// a tag. The sets of entities to be written should already contain
// only owned entities so by intersecting with them we not only
// filter by entities to be written, but also restrict to entities
// owned by the proc
// Get list of interface entities
Range imesh, tmp;
for( std::list< ExportSet >::reverse_iterator i = exportList.rbegin(); i != exportList.rend(); ++i )
tmp.clear();
rval = myPcomm->filter_pstatus( i->range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
imesh.merge( tmp );
tmp.clear();
rval = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
imesh.merge( tmp );
// Create tag to store file IDs
EntityHandle default_val = 0;
Tag file_id_tag = 0;
rval = iFace->tag_get_handle( "__hdf5_ll_fileid", 1, MB_TYPE_HANDLE, file_id_tag, MB_TAG_DENSE | MB_TAG_CREAT,
&default_val );
// Copy file IDs into tag
std::vector< EntityHandle > file_id_vect( imesh.size() );
Range::const_iterator i;
std::vector< EntityHandle >::iterator j = file_id_vect.begin();
for( i = imesh.begin(); i != imesh.end(); ++i, ++j )
*j = idMap.find( *i );
if( !*j )
iFace->tag_delete( file_id_tag );
return error( MB_FAILURE );
rval = iFace->tag_set_data( file_id_tag, imesh, &file_id_vect[0] );
// Do communication
rval = myPcomm->exchange_tags( file_id_tag, imesh );
// Copy file IDs from tag into idMap for remote entities
file_id_vect.resize( nonlocal.size() );
rval = iFace->tag_get_data( file_id_tag, nonlocal, &file_id_vect[0] );
for( i = nonlocal.begin(); i != nonlocal.end(); ++i, ++j )
if( *j == 0 )
int owner = -1;
myPcomm->get_owner( *i, owner );
const char* name = CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) );
int id = ID_FROM_HANDLE( *i );
MB_SET_ERR_CONT( "Process " << myPcomm->proc_config().proc_rank()
<< " did not receive valid id handle for shared " << name << " " << id
<< " owned by process " << owner );
dbgOut.printf( 1,
"Did not receive valid remote id for "
"shared %s %d owned by process %d",
name, id, owner );
else
if( !idMap.insert( *i, *j, 1 ).second )
#ifndef NDEBUG
// Check that writer is correct with regards to which entities
// that it owns by verifying that the file ids that we thought
// we were sending where not received instead
file_id_vect.resize( imesh.size() );
rval = iFace->tag_get_data( file_id_tag, imesh, &file_id_vect[0] );
int invalid_count = 0;
EntityHandle h = idMap.find( *i );
if( *j != h )
++invalid_count;
dbgOut.printf( 1, "Conflicting ownership for %s %ld\n", CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) ),
(long)ID_FROM_HANDLE( *i ) );
if( invalid_count )
MB_SET_ERR( MB_FAILURE, invalid_count << " entities with conflicting ownership found by process "
<< ". This will result in duplicate entities written to file" );
#endif
return iFace->tag_delete( file_id_tag );
| WriterIface * moab::WriteHDF5Parallel::factory | ( | Interface * | iface | ) | [static] |
Definition at line 274 of file WriteHDF5Parallel.cpp.
References WriteHDF5Parallel().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
return new WriteHDF5Parallel( iface );
| ErrorCode moab::WriteHDF5Parallel::gather_interface_meshes | ( | Range & | non_local_ents | ) | [protected] |
| non_local_ents | Output list of entities that are not to be written by this processor but are referenced by other entities that are to be written. |
Definition at line 295 of file WriteHDF5Parallel.cpp.
References moab::Range::clear(), moab::WriteHDF5::dbgOut, moab::error(), ErrorCode, moab::WriteHDF5::exportList, moab::ParallelComm::filter_pstatus(), MB_SUCCESS, moab::Range::merge(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::print(), PSTATUS_AND, PSTATUS_NOT_OWNED, moab::WriteHDF5::ExportSet::range, moab::WriteHDF5::setSet, and moab::subtract().
ErrorCode result;
// START_SERIAL;
dbgOut.print( 3, "Pre-interface mesh:\n" );
dbgOut.print( 3, nodeSet.range );
for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
dbgOut.print( 3, eiter->range );
dbgOut.print( 3, setSet.range );
// Move handles of non-owned entities from lists of entities
// that this processor will write to the 'nonowned' list.
nonowned.clear();
result = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &nonowned );
if( MB_SUCCESS != result ) return error( result );
nodeSet.range = subtract( nodeSet.range, nonowned );
Range tmpset;
result = myPcomm->filter_pstatus( eiter->range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &tmpset );
eiter->range = subtract( eiter->range, tmpset );
nonowned.merge( tmpset );
dbgOut.print( 3, "Post-interface mesh:\n" );
// END_SERIAL;
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::get_sharedset_tags | ( | ) | [protected] |
| ErrorCode moab::WriteHDF5Parallel::negotiate_type_list | ( | ) | [protected] |
Definition at line 1228 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::ExportSet::adj_offset, CHECK_MPI, moab::WriteHDF5::dbgOut, moab::CN::EntityTypeName(), moab::WriteHDF5::exportList, moab::WriteHDF5::ExportSet::first_id, MB_SUCCESS, myPcomm, moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::offset, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::WriteHDF5::ExportType::type, VALGRIND_CHECK_MEM_IS_DEFINED, and moab::VALGRIND_MAKE_VEC_UNDEFINED().
int result;
exportList.sort();
int num_types = exportList.size();
// Get list of types on this processor
typedef std::vector< std::pair< int, int > > typelist;
typelist my_types( num_types );
(void)VALGRIND_MAKE_VEC_UNDEFINED( my_types );
typelist::iterator viter = my_types.begin();
viter->first = eiter->type;
viter->second = eiter->num_nodes;
++viter;
dbgOut.print( 2, "Local Element Types:\n" );
for( viter = my_types.begin(); viter != my_types.end(); ++viter )
int type = viter->first;
int count = viter->second;
dbgOut.printf( 2, " %s : %d\n", CN::EntityTypeName( (EntityType)type ), count );
// Broadcast number of types from root to all nodes
int num_types0 = num_types;
result = MPI_Bcast( &num_types0, 1, MPI_INT, 0, comm );
// Broadcast type list from root to all nodes
typelist root_types( num_types0 );
if( 0 == myPcomm->proc_config().proc_rank() ) root_types = my_types;
result = MPI_Bcast( (void*)&root_types[0], 2 * num_types0, MPI_INT, 0, comm );
// Build local list of any types that root did not know about
typelist non_root_types;
viter = root_types.begin();
for( typelist::iterator iter = my_types.begin(); iter != my_types.end(); ++iter )
if( viter == root_types.end() || *viter != *iter )
non_root_types.push_back( *iter );
else
++viter;
// Determine if any process had types not defined on the root
int non_root_count = non_root_types.size();
int not_done;
result = MPI_Allreduce( &non_root_count, ¬_done, 1, MPI_INT, MPI_LOR, comm );
if( not_done )
// Get number of types each processor has that root does not
std::vector< int > counts( myPcomm->proc_config().proc_size() );
int two_count = 2 * non_root_count;
result = MPI_Gather( &two_count, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, comm );
// Get list of types from each processor
std::vector< int > displs( myPcomm->proc_config().proc_size() + 1 );
(void)VALGRIND_MAKE_VEC_UNDEFINED( displs );
displs[0] = 0;
for( unsigned long i = 1; i <= myPcomm->proc_config().proc_size(); ++i )
displs[i] = displs[i - 1] + counts[i - 1];
int total = displs[myPcomm->proc_config().proc_size()];
typelist alltypes( total / 2 );
(void)VALGRIND_MAKE_VEC_UNDEFINED( alltypes );
(void)VALGRIND_CHECK_MEM_IS_DEFINED( &non_root_types[0], non_root_types.size() * sizeof( int ) );
result = MPI_Gatherv( (void*)&non_root_types[0], 2 * non_root_count, MPI_INT, (int*)&alltypes[0], &counts[0],
&displs[0], MPI_INT, 0, comm );
// Merge type lists.
// Prefer O(n) insertions with O(ln n) search time because
// we expect data from a potentially large number of processes,
// but with a small total number of element types.
for( viter = alltypes.begin(); viter != alltypes.end(); ++viter )
typelist::iterator titer = std::lower_bound( my_types.begin(), my_types.end(), *viter );
if( titer == my_types.end() || *titer != *viter ) my_types.insert( titer, *viter );
dbgOut.print( 2, "Global Element Types:\n" );
dbgOut.printf( 2, " %s : %d\n", CN::EntityTypeName( (EntityType)viter->first ), viter->second );
// Send total number of types to each processor
total = my_types.size();
result = MPI_Bcast( &total, 1, MPI_INT, 0, comm );
// Send list of types to each processor
my_types.resize( total );
result = MPI_Bcast( (void*)&my_types[0], 2 * total, MPI_INT, 0, comm );
else
// Special case: if root had types but some subset of procs did not
// have those types, but there are no types that the root doesn't
// know about then we still need to update processes that are missing
// types.
my_types.swap( root_types );
// Insert missing types into exportList, with an empty
// range of entities to export.
while( ex_iter != exportList.end() && *ex_iter < *viter )
++ex_iter;
if( ex_iter == exportList.end() || !( *ex_iter == *viter ) )
ExportSet insert;
insert.type = (EntityType)viter->first;
insert.num_nodes = viter->second;
insert.first_id = 0;
insert.offset = 0;
insert.adj_offset = 0;
ex_iter = exportList.insert( ex_iter, insert );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::pack_set | ( | Range::const_iterator | set, |
| unsigned long * | set_data, | ||
| size_t | set_data_length | ||
| ) | [protected] |
If set_data_length is insufficient for the set data, the length entries at indices 1, 2, and 3 of set_data will be set with the necessary lengths, but no data will be written to set_data beyond that.
Definition at line 1669 of file WriteHDF5Parallel.cpp.
References CHECK_MB, moab::WriteUtilIface::CHILDREN, moab::WriteUtilIface::CONTENTS, ErrorCode, moab::WriteUtilIface::get_entity_list_pointers(), MB_SUCCESS, mhdf_SET_RANGE_BIT, moab::WriteUtilIface::PARENTS, moab::WriteHDF5::range_to_blocked_list(), moab::WriteHDF5::vector_to_id_list(), and moab::WriteHDF5::writeUtil.
Referenced by communicate_shared_set_data().
ErrorCode rval;
const EntityHandle* ptr;
int len;
unsigned char flags;
std::vector< wid_t > tmp;
size_t newlen;
// Buffer must always contain at least flags and desired sizes
assert( buffer_size >= 4 );
buffer_size -= 4;
Range::const_iterator nd = it;
++nd;
rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CONTENTS, &len, &flags );
CHECK_MB( rval );
// Tag mattag;
// int block;
// if (MB_SUCCESS != iFace->tag_get_data(mattag, &*it, 1, &block))
// block = 0;
// if (block) {
// get_global_ids(iFace, ptr, len, flags, ids);
if( len && !( flags & MESHSET_ORDERED ) )
tmp.clear();
bool blocked = false;
assert( ( 0 == len % 2 ) );
rval = range_to_blocked_list( ptr, len / 2, tmp, blocked );
CHECK_MB( rval );
if( blocked ) flags |= mhdf_SET_RANGE_BIT;
else
tmp.resize( len );
rval = vector_to_id_list( ptr, len, &tmp[0], newlen, true );
CHECK_MB( rval );
tmp.resize( newlen );
buffer[0] = flags;
buffer[1] = tmp.size();
if( tmp.size() <= buffer_size ) std::copy( tmp.begin(), tmp.end(), buffer + 4 );
rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CHILDREN, &len );
CHECK_MB( rval );
tmp.resize( len );
buffer[2] = tmp.size();
if( tmp.size() <= buffer_size - buffer[1] ) std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] );
rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::PARENTS, &len );
CHECK_MB( rval );
tmp.resize( len );
buffer[3] = tmp.size();
if( tmp.size() <= buffer_size - buffer[1] - buffer[2] )
std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] + buffer[2] );
return MB_SUCCESS;
| ErrorCode moab::WriteHDF5Parallel::parallel_create_file | ( | const char * | filename, |
| bool | overwrite, | ||
| const std::vector< std::string > & | qa_records, | ||
| const FileOptions & | opts, | ||
| const Tag * | user_tag_list = 0, |
| int | user_tag_count = 0, |
| int | dimension = 3, |
| double * | times = 0 |
Definition at line 334 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::collectiveIO, moab::WriteHDF5::CREATE_ADJ_TIME, create_adjacency_tables(), moab::WriteHDF5::CREATE_ELEM_TIME, create_element_tables(), create_meshset_tables(), create_node_table(), moab::WriteHDF5::CREATE_NODE_TIME, moab::WriteHDF5::CREATE_SET_TIME, create_tag_tables(), moab::WriteHDF5::CREATE_TAG_TIME, moab::WriteHDF5::dbgOut, debug_barrier, moab::CN::EntityTypeName(), moab::error(), ErrorCode, exchange_file_ids(), moab::WriteHDF5::FILEID_EXCHANGE_TIME, moab::WriteHDF5::filePtr, gather_interface_meshes(), moab::WriteHDF5::gather_tags(), moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), moab::ParallelComm::get_pcomm(), moab::FileOptions::get_str_option(), moab::HDF5_can_append_hyperslabs(), hslabOp, moab::WriteHDF5::id_type, moab::WriteHDF5::iFace, moab::DebugOutput::limit_output_to_first_N_procs(), MB_SET_ERR, MB_SUCCESS, MBEDGE, MBENTITYSET, MBMAXTYPE, mhdf_closeFile(), mhdf_createFile(), mhdf_message(), mhdf_openFileWithOpt(), myPcomm, negotiate_type_list(), moab::WriteHDF5::NEGOTIATE_TYPES_TIME, pcommAllocated, moab::DebugOutput::print(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::DebugOutput::set_rank(), moab::CpuTimer::time_elapsed(), moab::WriteHDF5::topState, moab::DebugOutput::tprint(), moab::DebugOutput::tprintf(), moab::WriteHDF5::write_qa(), and moab::WriteHDF5::writeProp.
ErrorCode rval;
mhdf_Status status;
int pcomm_no = 0;
opts.get_int_option( "PARALLEL_COMM", pcomm_no );
myPcomm = ParallelComm::get_pcomm( iFace, pcomm_no );
if( 0 == myPcomm )
myPcomm = new ParallelComm( iFace, MPI_COMM_WORLD );
pcommAllocated = true;
MPI_Info info = MPI_INFO_NULL;
std::string cb_size;
rval = opts.get_str_option( "CB_BUFFER_SIZE", cb_size );
MPI_Info_create( &info );
MPI_Info_set( info, const_cast< char* >( "cb_buffer_size" ), const_cast< char* >( cb_size.c_str() ) );
dbgOut.set_rank( myPcomm->proc_config().proc_rank() );
dbgOut.limit_output_to_first_N_procs( 32 );
Range nonlocal;
debug_barrier();
dbgOut.tprint( 1, "Gathering interface meshes\n" );
rval = gather_interface_meshes( nonlocal );
/**************** Get tag names for sets likely to be shared ***********/
// debug_barrier();
// dbgOut.tprint(1, "Getting shared entity sets\n");
// rval = get_sharedset_tags();
// if (MB_SUCCESS != rval) return error(rval);
/**************** Create actual file and write meta info ***************/
debug_barrier();
if( myPcomm->proc_config().proc_rank() == 0 )
dbgOut.tprintf( 1, "Creating file: %s\n", filename );
// Create the file
const char* type_names[MBMAXTYPE];
memset( type_names, 0, MBMAXTYPE * sizeof( char* ) );
for( EntityType i = MBEDGE; i < MBENTITYSET; ++i )
type_names[i] = CN::EntityTypeName( i );
dbgOut.tprint( 1, "call mhdf_createFile\n" );
filePtr = mhdf_createFile( filename, overwrite, type_names, MBMAXTYPE, id_type, &status );
if( !filePtr )
MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
dbgOut.tprint( 1, "call write_qa\n" );
rval = write_qa( qa_records );
/**************** Create node coordinate table ***************/
CpuTimer timer;
debug_barrier();
dbgOut.tprint( 1, "creating node table\n" );
topState.start( "creating node table" );
rval = create_node_table( dimension );
topState.end( rval );
if( times ) times[CREATE_NODE_TIME] = timer.time_elapsed();
/**************** Create element tables ***************/
debug_barrier();
dbgOut.tprint( 1, "negotiating element types\n" );
topState.start( "negotiating element types" );
rval = negotiate_type_list();
if( times ) times[NEGOTIATE_TYPES_TIME] = timer.time_elapsed();
dbgOut.tprint( 1, "creating element table\n" );
topState.start( "creating element tables" );
rval = create_element_tables();
if( times ) times[CREATE_ELEM_TIME] = timer.time_elapsed();
/*************** Exchange file IDs *****************/
debug_barrier();
dbgOut.tprint( 1, "communicating file ids\n" );
topState.start( "communicating file ids" );
rval = exchange_file_ids( nonlocal );
if( times ) times[FILEID_EXCHANGE_TIME] = timer.time_elapsed();
/**************** Create meshset tables *********************/
debug_barrier();
dbgOut.tprint( 1, "creating meshset table\n" );
topState.start( "creating meshset tables" );
rval = create_meshset_tables( times );
if( times ) times[CREATE_SET_TIME] = timer.time_elapsed();
/**************** Create adjacency tables *********************/
debug_barrier();
dbgOut.tprint( 1, "creating adjacency table\n" );
topState.start( "creating adjacency tables" );
rval = create_adjacency_tables();
if( times ) times[CREATE_ADJ_TIME] = timer.time_elapsed();
/**************** Create tag data *********************/
debug_barrier();
dbgOut.tprint( 1, "creating tag tables\n" );
topState.start( "creating tag tables" );
rval = gather_tags( user_tag_list, user_tag_count );
rval = create_tag_tables();
if( times ) times[CREATE_TAG_TIME] = timer.time_elapsed();
/************** Close serial file and reopen parallel *****************/
if( 0 == myPcomm->proc_config().proc_rank() ) mhdf_closeFile( filePtr, &status );
dbgOut.tprint( 1, "(re)opening file in parallel mode\n" );
unsigned long junk;
hid_t hdf_opt = H5Pcreate( H5P_FILE_ACCESS );
H5Pset_fapl_mpio( hdf_opt, myPcomm->proc_config().proc_comm(), info );
filePtr = mhdf_openFileWithOpt( filename, 1, &junk, id_type, hdf_opt, &status );
H5Pclose( hdf_opt );
if( !filePtr )
if( collectiveIO )
dbgOut.print( 1, "USING COLLECTIVE IO\n" );
writeProp = H5Pcreate( H5P_DATASET_XFER );
H5Pset_dxpl_mpio( writeProp, H5FD_MPIO_COLLECTIVE );
/* Test if we can use H5S_APPEND when selecting hyperslabs */
if( MB_SUCCESS != opts.get_null_option( "HYPERSLAB_OR" ) &&
( MB_SUCCESS == opts.get_null_option( "HYPERSLAB_APPEND" ) || HDF5_can_append_hyperslabs() ) )
dbgOut.print( 1, "HDF5 library supports H5Sselect_hyperlsab with H5S_SELECT_APPEND\n" );
hslabOp = H5S_SELECT_APPEND;
dbgOut.tprint( 1, "Exiting parallel_create_file\n" );
return MB_SUCCESS;
| void moab::WriteHDF5Parallel::print_set_sharing_data | ( | const Range & | range, |
| const char * | label, | ||
| Tag | idt | ||
| ) | [protected] |
Definition at line 1453 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::WriteHDF5::dbgOut, moab::Range::end(), moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_procs(), moab::WriteHDF5::idMap, moab::WriteHDF5::iFace, myPcomm, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::SSVB, and moab::Interface::tag_get_data().
Referenced by print_shared_sets().
dbgOut.printf( SSVB, "set\tid\towner\t%-*s\tfid\tshared\n", (int)( sizeof( EntityHandle ) * 2 ), "handle" );
for( Range::iterator it = range.begin(); it != range.end(); ++it )
int id;
iFace->tag_get_data( idt, &*it, 1, &id );
unsigned owner = 0;
wid_t file_id = 0;
myPcomm->get_entityset_owner( *it, owner, &handle );
if( !idMap.find( *it, file_id ) ) file_id = 0;
dbgOut.printf( SSVB, "%s\t%d\t%u\t%lx\t%lu\t", label, id, owner, (unsigned long)handle,
(unsigned long)file_id );
myPcomm->get_entityset_procs( *it, procs );
if( procs.empty() )
dbgOut.print( SSVB, "<none>\n" );
else
for( unsigned i = 0; i < procs.size() - 1; ++i )
dbgOut.printf( SSVB, "%u,", procs[i] );
dbgOut.printf( SSVB, "%u\n", procs.back() );
| void moab::WriteHDF5Parallel::print_shared_sets | ( | ) | [protected] |
Definition at line 1480 of file WriteHDF5Parallel.cpp.
References DIRICHLET_SET_TAG_NAME, geom, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), moab::WriteHDF5::iFace, MATERIAL_SET_TAG_NAME, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, NEUMANN_SET_TAG_NAME, print_set_sharing_data(), and moab::Interface::tag_get_handle().
Referenced by communicate_shared_set_ids().
const char* tag_names[][2] = { { MATERIAL_SET_TAG_NAME, "block" },
{ DIRICHLET_SET_TAG_NAME, "nodeset" },
{ NEUMANN_SET_TAG_NAME, "sideset" },
{ 0, 0 } };
for( int i = 0; tag_names[i][0]; ++i )
Tag tag;
if( MB_SUCCESS != iFace->tag_get_handle( tag_names[i][0], 1, MB_TYPE_INTEGER, tag ) ) continue;
Range tagged;
iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, tagged );
print_set_sharing_data( tagged, tag_names[i][1], tag );
Tag geom, id;
if( MB_SUCCESS != iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom ) ) return;
id = iFace->globalId_tag();
const char* geom_names[] = { "vertex", "curve", "surface", "volume" };
for( int d = 0; d <= 3; ++d )
Range tagged;
const void* vals[] = { &d };
iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom, vals, 1, tagged );
print_set_sharing_data( tagged, geom_names[d], id );
| void moab::WriteHDF5Parallel::print_times | ( | const double * | times | ) | const [protected, virtual] |
Definition at line 2389 of file WriteHDF5Parallel.cpp.
References myPcomm, moab::WriteHDF5::NUM_TIMES, moab::WriteHDF5::print_times(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), and moab::ProcConfig::proc_rank().
if( !myPcomm )
WriteHDF5::print_times( times );
else
double recv[NUM_TIMES];
MPI_Reduce( (void*)times, recv, NUM_TIMES, MPI_DOUBLE, MPI_MAX, 0, myPcomm->proc_config().proc_comm() );
if( 0 == myPcomm->proc_config().proc_rank() ) WriteHDF5::print_times( recv );
| void moab::WriteHDF5Parallel::remove_remote_entities | ( | EntityHandle | relative, |
| Range & | range | ||
| ) | [protected] |
Remove any remote mesh entities from the passed range.
Definition at line 2194 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::CREATE_HANDLE(), moab::Range::end(), moab::WriteHDF5::exportList, moab::intersect(), moab::Range::lower_bound(), MBENTITYSET, moab::Range::merge(), moab::WriteHDF5::nodeSet, moab::WriteHDF5::ExportSet::range, remove_remote_sets(), moab::WriteHDF5::setSet, and moab::Range::swap().
Referenced by remove_remote_entities().
Range result;
result.merge( intersect( range, nodeSet.range ) );
result.merge( intersect( range, setSet.range ) );
result.merge( intersect( range, eiter->range ) );
// result.merge(intersect(range, myParallelSets));
Range sets;
int junk;
sets.merge( Range::lower_bound( range.begin(), range.end(), CREATE_HANDLE( MBENTITYSET, 0, junk ) ), range.end() );
remove_remote_sets( relative, sets );
result.merge( sets );
range.swap( result );
| std::vector< EntityHandle > & | vect | ||
| ) | [protected] |
Definition at line 2219 of file WriteHDF5Parallel.cpp.
References moab::Range::end(), moab::Range::find(), moab::Range::insert(), and remove_remote_entities().
Range intrsct;
for( std::vector< EntityHandle >::const_iterator iter = vect.begin(); iter != vect.end(); ++iter )
intrsct.insert( *iter );
remove_remote_entities( relative, intrsct );
unsigned int read, write;
for( read = write = 0; read < vect.size(); ++read )
if( intrsct.find( vect[read] ) != intrsct.end() )
if( read != write ) vect[write] = vect[read];
++write;
if( write != vect.size() ) vect.resize( write );
| void moab::WriteHDF5Parallel::remove_remote_sets | ( | EntityHandle | relative, |
| ) | [protected] |
Definition at line 2211 of file WriteHDF5Parallel.cpp.
References moab::intersect(), moab::WriteHDF5::ExportSet::range, moab::WriteHDF5::setSet, and moab::Range::swap().
Referenced by remove_remote_entities(), and remove_remote_sets().
| ) | [protected] |
Definition at line 2238 of file WriteHDF5Parallel.cpp.
References moab::Range::end(), moab::Range::find(), moab::Range::insert(), and remove_remote_sets().
Range intrsct;
remove_remote_sets( relative, intrsct );
++write;
| ErrorCode moab::WriteHDF5Parallel::unpack_set | ( | EntityHandle | set, |
| const unsigned long * | set_data, | ||
| ) | [protected] |
Unpack set data from communication.
Definition at line 1792 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::SpecialSetData::childIds, children, moab::WriteHDF5::SpecialSetData::contentIds, moab::convert_to_ranged_ids(), moab::WriteHDF5::find_set_data(), MB_SUCCESS, moab::merge_ranged_ids(), moab::merge_vector_ids(), mhdf_SET_RANGE_BIT, moab::WriteHDF5::SpecialSetData::parentIds, and moab::WriteHDF5::SpecialSetData::setFlags.
// Use local variables for readability
assert( buffer[1] + buffer[2] + buffer[3] <= buffer_size );
const unsigned long flags = buffer[0];
unsigned long num_content = buffer[1];
const unsigned long num_child = buffer[2];
const unsigned long num_parent = buffer[3];
const unsigned long* contents = buffer + 4;
const unsigned long* children = contents + num_content;
const unsigned long* parents = children + num_child;
SpecialSetData* data = find_set_data( set );
assert( NULL != data );
if( NULL == data ) return MB_FAILURE;
// Tag mattag;
// int block;
// if (MB_SUCCESS != iFace->tag_get_data(mattag, &set, 1, &block))
// block = 0;
// If either the current data or the new data is in ranged format,
// then change the other to ranged format if it isn't already
// in both cases when they differ, the data will end up "compressed range"
if( ( flags & mhdf_SET_RANGE_BIT ) != ( data->setFlags & mhdf_SET_RANGE_BIT ) )
if( flags & mhdf_SET_RANGE_BIT )
tmp = data->contentIds;
convert_to_ranged_ids( &tmp[0], tmp.size(), data->contentIds );
data->setFlags |= mhdf_SET_RANGE_BIT;
else
tmp.clear();
convert_to_ranged_ids( contents, num_content, tmp );
num_content = tmp.size();
if( sizeof( wid_t ) < sizeof( long ) )
size_t old_size = tmp.size();
tmp.resize( sizeof( long ) * old_size / sizeof( wid_t ) );
unsigned long* array = reinterpret_cast< unsigned long* >( &tmp[0] );
for( long i = ( (long)old_size ) - 1; i >= 0; --i )
array[i] = tmp[i];
contents = array;
else if( sizeof( wid_t ) > sizeof( long ) )
std::copy( tmp.begin(), tmp.end(), array );
contents = reinterpret_cast< unsigned long* >( &tmp[0] );
if( data->setFlags & mhdf_SET_RANGE_BIT )
merge_ranged_ids( contents, num_content, data->contentIds );
else
merge_vector_ids( contents, num_content, data->contentIds );
merge_vector_ids( children, num_child, data->childIds );
merge_vector_ids( parents, num_parent, data->parentIds );
return MB_SUCCESS;
H5S_seloper_t moab::WriteHDF5Parallel::hslabOp [private] |
Operation to use to append hyperslab selections.
Definition at line 186 of file WriteHDF5Parallel.hpp.
ParallelComm* moab::WriteHDF5Parallel::myPcomm [private] |
pcomm controlling parallel nature of mesh
Definition at line 180 of file WriteHDF5Parallel.hpp.
Referenced by communicate_shared_set_data(), communicate_shared_set_ids(), create_dataset(), create_meshset_tables(), create_tag_tables(), debug_barrier_line(), exchange_file_ids(), gather_interface_meshes(), negotiate_type_list(), parallel_create_file(), print_set_sharing_data(), print_times(), and ~WriteHDF5Parallel().
bool moab::WriteHDF5Parallel::pcommAllocated [private] |
whether this instance allocated (and dtor should delete) the pcomm
Definition at line 183 of file WriteHDF5Parallel.hpp.
Referenced by parallel_create_file(), and ~WriteHDF5Parallel().
