Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef ENTITY_SEQUENCE_HPP 00002 #define ENTITY_SEQUENCE_HPP 00003 00004 #include "moab/Types.hpp" 00005 #include "Internals.hpp" 00006 00007 namespace moab 00008 { 00009 00010 class SequenceData; 00011 00012 class EntitySequence 00013 { 00014 private: 00015 EntityHandle startHandle, endHandle; 00016 SequenceData* sequenceData; 00017 00018 protected: 00019 EntitySequence( EntityHandle h ) : startHandle( h ), endHandle( h ), sequenceData( NULL ) {} 00020 00021 EntitySequence( EntitySequence& split_from, EntityHandle here ) 00022 : startHandle( here ), endHandle( split_from.endHandle ), sequenceData( split_from.sequenceData ) 00023 { 00024 split_from.endHandle = here - 1; 00025 } 00026 00027 SequenceData* create_data_subset( EntityHandle start_handle, 00028 EntityHandle end_handle, 00029 int num_sequence_arrays, 00030 unsigned const* bytes_per_element ) const; 00031 00032 ErrorCode prepend_entities( EntityID count ); 00033 ErrorCode append_entities( EntityID count ); 00034 00035 public: 00036 EntitySequence( EntityHandle start, EntityID count, SequenceData* dat ) 00037 : startHandle( start ), endHandle( start + count - 1 ), sequenceData( dat ) 00038 { 00039 } 00040 00041 virtual ~EntitySequence() {} 00042 00043 EntityType type() const 00044 { 00045 return TYPE_FROM_HANDLE( start_handle() ); 00046 } 00047 00048 EntityHandle start_handle() const 00049 { 00050 return startHandle; 00051 } 00052 00053 EntityHandle end_handle() const 00054 { 00055 return endHandle; 00056 } 00057 00058 SequenceData* data() const 00059 { 00060 return sequenceData; 00061 } 00062 00063 void data( SequenceData* ptr ) 00064 { 00065 sequenceData = ptr; 00066 } 00067 00068 EntityID size() const 00069 { 00070 return endHandle - startHandle + 1; 00071 } 00072 00073 /**\brief True if SequenceData has no holes and is used only 00074 * by this EntitySequence */ 00075 bool using_entire_data() const; 00076 00077 /**\brief Integer value used in finding appropriate SequenceData 00078 * 00079 * This value is matched to input values by TypeSequenceManager to 00080 * determine if an available, unused portino of a SequenceData can 00081 * be used for a specific entity allocation. For example, it is 00082 * used to find a SequenceData with the appropriate number of vertices 00083 * per element when allocating elements. The default value is zero. 00084 */ 00085 virtual int values_per_entity() const; 00086 00087 /**\brief Split this sequence into two consecutive sequences 00088 * 00089 * Split this sequence into two sequences. 00090 *\param here New sequences should be [start_handle(),here) & [here,end_handle()] 00091 *\return New sequence containing [here,end_handle()] 00092 */ 00093 virtual EntitySequence* split( EntityHandle here ) = 0; 00094 00095 /**\brief Merge this sequence with another 00096 * 00097 * Combine two adjacent sequences. Sequence handle blocks must be 00098 * consective and sequences must share a common SequenceData. 00099 */ 00100 virtual ErrorCode merge( EntitySequence& other ); 00101 00102 /**\brief Erase entities in range: (end_handle()-count, end_handle()] */ 00103 virtual ErrorCode pop_back( EntityID count ); 00104 00105 /**\brief Erase entities in range: [start_handle(), start_handle()+count) */ 00106 virtual ErrorCode pop_front( EntityID count ); 00107 00108 /**\brief Create a new SequenceData that is a copy of a subset of 00109 * the one referenced by this sequence. 00110 * 00111 * Create a new SequenceData that is a copy of a subset of the 00112 * SequenceData referenced by this EntitySequence. Do not make any 00113 * changes to this EntitySequence or the current SequenceData. 00114 */ 00115 virtual SequenceData* create_data_subset( EntityHandle start_handle, EntityHandle end_handle ) const = 0; 00116 00117 /**\brief Get memory characteristcs that are the same for all entities 00118 * 00119 * Get charactersitic constant memory use for all entities in sequence. 00120 *\param bytes_per_entity The total bytes consumed for each entity in 00121 * the underlying SequenceData. It is assumed 00122 * that the same amount of memory is consumed 00123 * for unused portions of the SequenceData. 00124 *\param size_of_sequence The size of the leaf subclass of this class 00125 */ 00126 virtual void get_const_memory_use( unsigned long& bytes_per_entity, unsigned long& size_of_sequence ) const = 0; 00127 /**\brief Get portion of memory use that varies per entity 00128 * 00129 *\return Any per-entity memory use not accounted for in the results 00130 * of get_const_memory_use. 00131 */ 00132 virtual unsigned long get_per_entity_memory_use( EntityHandle first, EntityHandle last ) const; 00133 }; 00134 00135 } // namespace moab 00136 00137 #endif
