moab::element_utility::Spectral_hex_map< _Matrix > Member List
This is the complete list of members for moab::element_utility::Spectral_hex_map< _Matrix >, including all inherited members.
_datamoab::element_utility::Spectral_hex_map< _Matrix > [private]
_initmoab::element_utility::Spectral_hex_map< _Matrix > [private]
_ldmoab::element_utility::Spectral_hex_map< _Matrix > [private]
_nmoab::element_utility::Spectral_hex_map< _Matrix > [private]
_odworkmoab::element_utility::Spectral_hex_map< _Matrix > [private]
_xyzmoab::element_utility::Spectral_hex_map< _Matrix > [private]
_zmoab::element_utility::Spectral_hex_map< _Matrix > [private]
evaluate(const Point &p, const Points &, Point &f)moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
evaluate_scalar_field(const Point &p, const Field &field) const moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
free_data()moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
initialize_spectral_hex(int order)moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
integrate_scalar_field(const Points &p, const Field &field) const moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
is_contained(const Point &p, const double tol) const moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
jacobian(const Point &, const Points &, Matrix &J)moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
Matrix typedefmoab::element_utility::Spectral_hex_map< _Matrix > [static]
operator()(const Moab &, const Entity_handle &, const Points &v, const Point &p, const double tol=1.e-6)moab::element_utility::Spectral_hex_map< _Matrix > [inline]
Self typedefmoab::element_utility::Spectral_hex_map< _Matrix > [private]
set_gl_points(double *x, double *y, double *z)moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
solve_inverse(const Point &x, Point &xi, const Points &points, const double tol=1.e-6)moab::element_utility::Spectral_hex_map< _Matrix > [inline, private]
Spectral_hex_map()moab::element_utility::Spectral_hex_map< _Matrix > [inline]
Spectral_hex_map(int order)moab::element_utility::Spectral_hex_map< _Matrix > [inline]
Spectral_hex_map(const Self &f)moab::element_utility::Spectral_hex_map< _Matrix > [inline]
