uber_parallel_test.cpp File Reference
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "ReadParallel.hpp"
#include "moab/FileOptions.hpp"
#include "MBTagConventions.hpp"
#include "moab/Core.hpp"
#include "moab_mpi.h"
#include "TestUtil.hpp"
#include <iostream>
#include <algorithm>
#include <sstream>
#include <cassert>
#include <unistd.h>
+ Include dependency graph for uber_parallel_test.cpp:
Defines
#define CHKERR(a)
#define PCHECK(A)   if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ )
#define RUN_TEST_ARG3(A, B, C)   run_test( &( A ), #A, B, C )
Functions
ErrorCode report_error (const char *file, int line)
ErrorCode test_read (const char *filename, const char *option)
int is_any_proc_error (int is_my_error)
int run_test (ErrorCode(*func)(const char *, const char *), const char *func_name, const std::string &file_name, const char *option)
int main (int argc, char *argv[])
Define Documentation
#define CHKERR (   a)
Value:
do        \
        ErrorCode val = ( a );        \
        if( MB_SUCCESS != val )        \
            std::cerr << "Error code  " << val << " at " << __FILE__ << ":" << __LINE__ << std::endl; \
            return val;        \
    } while( false )
Definition at line 20 of file uber_parallel_test.cpp.
Referenced by test_read().
#define PCHECK (   A)    if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ )
Definition at line 31 of file uber_parallel_test.cpp.
#define RUN_TEST_ARG3 (   A,
  B,
  C
Definition at line 42 of file uber_parallel_test.cpp.
Referenced by main().
Function Documentation
int is_any_proc_error ( int  is_my_error)
Definition at line 44 of file uber_parallel_test.cpp.
References MPI_COMM_WORLD.
    int result = 0;
    int err    = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
    return err || result;
int main ( int  argc,
char *  argv[]
Definition at line 71 of file uber_parallel_test.cpp.
References filename, MPI_COMM_WORLD, rank, RUN_TEST_ARG3, size, and test_read().
    int rank, size;
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    int num_errors = 0;
    const char* option;
    std::string vtk_test_filename = TestDir + "unittest/hex_2048.vtk";
#ifdef MOAB_HAVE_HDF5
    std::string filename;
    if( 1 < argc )
        filename = std::string( argv[1] );
    else
        filename = TestDir + "unittest/64bricks_512hex.h5m";
    //=========== read_delete, geom_dimension, resolve_shared
    option = "PARALLEL=READ_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;"
             "PARALLEL_RESOLVE_SHARED_ENTS;";
    num_errors += RUN_TEST_ARG3( test_read, filename, option );
    //=========== read_delete, material_set, resolve_shared
    option = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
             "SHARED_ENTS;";
    //=========== bcast_delete, geom_dimension, resolve_shared
    option = "PARALLEL=BCAST_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;"
    //=========== bcast_delete, material_set, resolve_shared
    option = "PARALLEL=BCAST_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
             "SHARED_ENTS;";
    //=========== read_delete, geom_dimension, resolve_shared, exch ghost
             "PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
    //=========== read_delete, material_set, resolve_shared, exch ghost
             "SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
    //=========== bcast_delete, geom_dimension, resolve_shared, exch ghost
    //=========== bcast_delete, material_set, resolve_shared, exch ghost
#endif
    if( vtk_test_filename.size() )
        //=========== bcast_delete, trivial, resolve_shared
        option = "PARALLEL=BCAST_DELETE;PARTITION=TRIVIAL;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
                 "SHARED_ENTS;";
        num_errors += RUN_TEST_ARG3( test_read, vtk_test_filename, option );
        //=========== bcast_delete, trivial, resolve_shared + ghosting
    MPI_Finalize();
    return num_errors;
ErrorCode report_error ( const char *  file,
int  line
Definition at line 34 of file uber_parallel_test.cpp.
    std::cerr << "Failure at " << file << ':' << line << std::endl;
    return MB_FAILURE;
int run_test ( ErrorCode(*)(const char *, const char *)  func,
const char *  func_name,
const std::string &  file_name,
const char *  option
Definition at line 51 of file uber_parallel_test.cpp.
References ErrorCode, is_any_proc_error(), MB_SUCCESS, MPI_COMM_WORLD, and rank.
    ErrorCode result = ( *func )( file_name.c_str(), option );
    int is_err       = is_any_proc_error( ( MB_SUCCESS != result ) );
    int rank;
    if( rank == 0 )
        if( is_err )
            std::cout << func_name << " : FAILED!!" << std::endl;
        else
            std::cout << func_name << " : success" << std::endl;
    return is_err;
ErrorCode test_read ( const char *  filename,
const char *  option
Definition at line 145 of file uber_parallel_test.cpp.
References moab::ParallelComm::check_all_shared_handles(), CHKERR, ErrorCode, moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), mb_instance(), and MB_SUCCESS.
    Core mb_instance;
    Interface& moab = mb_instance;
    ErrorCode rval;
    rval = moab.load_file( filename, 0, option );CHKERR( rval );
    ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 );
    rval = pcomm->check_all_shared_handles();CHKERR( rval );
    return MB_SUCCESS;
