MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected], [email protected], [email protected], 00024 [email protected], [email protected], [email protected] 00025 [email protected] 00026 00027 ***************************************************************** */ 00028 00029 #define TOL 1e-5 00030 00031 //#define DO_QUALITY_ASSESSOR 00032 00033 #include <iostream> 00034 using std::cout; 00035 using std::endl; 00036 #include <cstdlib> 00037 00038 #include "Mesquite.hpp" 00039 #include "MeshImpl.hpp" 00040 #include "MsqError.hpp" 00041 #include "InstructionQueue.hpp" 00042 #include "TerminationCriterion.hpp" 00043 #include "QualityAssessor.hpp" 00044 #include "LPtoPTemplate.hpp" 00045 #include "LInfTemplate.hpp" 00046 #include "TestUtil.hpp" 00047 00048 // algorithms 00049 #include "IdealWeightMeanRatio.hpp" 00050 #include "IdealWeightInverseMeanRatio.hpp" 00051 #include "UntangleBetaQualityMetric.hpp" 00052 #include "FeasibleNewton.hpp" 00053 #include "ConditionNumberQualityMetric.hpp" 00054 using namespace MBMesquite; 00055 00056 // Use CPPUNIT_ASSERT in code so it's easy to convert to a unit test later. 00057 #define CPPUNIT_ASSERT( A ) \ 00058 do \ 00059 { \ 00060 if( !( A ) ) \ 00061 { \ 00062 std::cout << "Assertion Failed: " << #A << std::endl; \ 00063 std::cout << " File: " << __FILE__ << std::endl; \ 00064 std::cout << " Line: " << __LINE__ << std::endl; \ 00065 return 1; \ 00066 } \ 00067 } while( false ) 00068 00069 #define CPPUNIT_ASSERT_DOUBLES_EQUAL( E, V, T ) \ 00070 do \ 00071 { \ 00072 if( fabs( ( E ) - ( V ) ) > ( T ) ) \ 00073 { \ 00074 std::cout << "Assertion Failed: " << #V << " == " << #E << std::endl; \ 00075 std::cout << "Expected: " << ( E ) << " Got: " << ( V ) << std::endl; \ 00076 std::cout << " File: " << __FILE__ << std::endl; \ 00077 std::cout << " Line: " << __LINE__ << std::endl; \ 00078 return 1; \ 00079 } \ 00080 } while( false ) 00081 00082 #define CPPUNIT_ASSERT_EQUAL( E, V ) \ 00083 do \ 00084 { \ 00085 if( ( E ) != ( V ) ) \ 00086 { \ 00087 std::cout << "Assertion Failed: " << #V << " == " << #E << std::endl; \ 00088 std::cout << "Expected: " << ( E ) << " Got: " << ( V ) << std::endl; \ 00089 std::cout << " File: " << __FILE__ << std::endl; \ 00090 std::cout << " Line: " << __LINE__ << std::endl; \ 00091 return 1; \ 00092 } \ 00093 } while( false ) 00094 00095 #define CPPUNIT_ASSERT_VECTORS_EQUAL( E, V, T ) \ 00096 do \ 00097 { \ 00098 if( !( E ).within_tolerance_box( V, T ) ) \ 00099 { \ 00100 std::cout << "Assertion Failed: " << #V << " == " << #E << std::endl; \ 00101 std::cout << "Expected: " << ( E ) << " Got: " << ( V ) << std::endl; \ 00102 std::cout << " File: " << __FILE__ << std::endl; \ 00103 std::cout << " Line: " << __LINE__ << std::endl; \ 00104 return 1; \ 00105 } \ 00106 } while( false ) 00107 00108 // Given a mesh with a single free vertex located at the origin, 00109 // move the vertex to the specified position, smooth the mesh, 00110 // and verify that the vertex was moved back to the origin by 00111 // the smoother. 00112 bool smooth_mesh( MeshImpl* mesh, 00113 Mesh* ref_mesh, 00114 Mesh::VertexHandle vertex_8, 00115 Mesh::VertexHandle vertex_9, 00116 Vector3D delta, 00117 QualityMetric* metric ); 00118 00119 const unsigned NUM_ELEM = 6; 00120 const unsigned NUM_VERT = 14; 00121 const unsigned VERT_PER_ELEM = 6; 00122 00123 int main( int argc, char*[] ) 00124 { 00125 if( argc != 1 ) 00126 { 00127 std::cerr << "Invalid arguments.\n"; 00128 return 2; 00129 } 00130 00131 std::string meshfile = TestDir + "unittest/mesquite/3D/vtk/prisms/untangled/6-wedge-prism.vtk"; 00132 unsigned i; 00133 00134 MBMesquite::MsqPrintError err( cout ); 00135 IdealWeightMeanRatio m1; 00136 IdealWeightInverseMeanRatio m2( err ); 00137 ConditionNumberQualityMetric m3; 00138 QualityMetric* metrics[] = { &m1, &m2, &m3, 0 }; 00139 00140 // Read Mesh 00141 MBMesquite::MeshImpl mesh; 00142 mesh.read_vtk( meshfile.c_str(), err ); 00143 CPPUNIT_ASSERT( !err ); 00144 MBMesquite::MeshImpl ideal_mesh; 00145 ideal_mesh.read_vtk( meshfile.c_str(), err ); 00146 CPPUNIT_ASSERT( !err ); 00147 00148 // Check that the mesh read correctly, and contains what is 00149 // expected later. 00150 00151 // Get mesh data 00152 // Expecting file to contain 6 wedge elements constructed 00153 // from 14 vertices. 00154 std::vector< Mesh::VertexHandle > vert_array; 00155 std::vector< Mesh::ElementHandle > elem_array; 00156 std::vector< size_t > conn_offsets; 00157 mesh.get_all_elements( elem_array, err ); 00158 CPPUNIT_ASSERT( !err ); 00159 CPPUNIT_ASSERT_EQUAL( elem_array.size(), NUM_ELEM ); 00160 mesh.elements_get_attached_vertices( arrptr( elem_array ), elem_array.size(), vert_array, conn_offsets, err ); 00161 CPPUNIT_ASSERT( !err ); 00162 CPPUNIT_ASSERT_EQUAL( vert_array.size(), VERT_PER_ELEM * NUM_ELEM ); 00163 CPPUNIT_ASSERT_EQUAL( conn_offsets.size(), NUM_ELEM + 1 ); 00164 EntityTopology type_array[NUM_ELEM]; 00165 mesh.elements_get_topologies( arrptr( elem_array ), type_array, NUM_ELEM, err ); 00166 CPPUNIT_ASSERT( !err ); 00167 00168 // Verify element types and number of vertices 00169 for( i = 0; i < NUM_ELEM; ++i ) 00170 { 00171 CPPUNIT_ASSERT_EQUAL( type_array[i], PRISM ); 00172 CPPUNIT_ASSERT_EQUAL( conn_offsets[i], VERT_PER_ELEM * i ); 00173 } 00174 00175 // All wedges should share the 9th and 10th vertices 00176 const unsigned INDEX_8 = 1, INDEX_9 = 4; 00177 Mesh::VertexHandle handle8 = vert_array[INDEX_8]; 00178 Mesh::VertexHandle handle9 = vert_array[INDEX_9]; 00179 for( i = 1; i < NUM_ELEM; ++i ) 00180 { 00181 CPPUNIT_ASSERT_EQUAL( vert_array[VERT_PER_ELEM * i + INDEX_8], handle8 ); 00182 CPPUNIT_ASSERT_EQUAL( vert_array[VERT_PER_ELEM * i + INDEX_9], handle9 ); 00183 } 00184 00185 // The input file should be a hexagonal prism decomposed into 00186 // 6 wedges such that all wedges have one quad face on the 00187 // boundary and all wedges share a single edge which is the axis 00188 // of the prism. 00189 MsqVertex vertices[NUM_ELEM * VERT_PER_ELEM]; 00190 mesh.vertices_get_coordinates( arrptr( vert_array ), vertices, NUM_ELEM * VERT_PER_ELEM, err ); 00191 CPPUNIT_ASSERT( !err ); 00192 for( i = 0; i < NUM_ELEM * VERT_PER_ELEM; ++i ) 00193 { 00194 if( vert_array[i] == handle8 || vert_array[i] == handle9 ) 00195 { 00196 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, vertices[i][1], 1e-6 ); 00197 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, vertices[i][2], 1e-6 ); 00198 } 00199 else 00200 { 00201 Vector3D xproj( vertices[i] ); 00202 xproj[0] = 0; 00203 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, xproj.length(), 1e-6 ); 00204 } 00205 } 00206 00207 // Try smoothing w/out moving the free vertices and verify that 00208 // the smoother didn't move the vertex 00209 Vector3D delta( 0, 0, 0 ); 00210 for( i = 0; metrics[i] != NULL; ++i ) 00211 CPPUNIT_ASSERT( !smooth_mesh( &mesh, &ideal_mesh, handle8, handle9, delta, metrics[i] ) ); 00212 00213 // Now try moving the vertex and see if the smoother moves it back 00214 // to the origin 00215 delta.set( 0.1, 0.0, 0.1 ); 00216 for( i = 0; metrics[i] != NULL; ++i ) 00217 CPPUNIT_ASSERT( !smooth_mesh( &mesh, &ideal_mesh, handle8, handle9, delta, metrics[i] ) ); 00218 00219 // Now try moving the vertex further and see if the smoother moves it back 00220 // to the origin 00221 delta.set( 1.0, 0.0, 1.0 ); 00222 for( i = 0; metrics[i] != NULL; ++i ) 00223 CPPUNIT_ASSERT( !smooth_mesh( &mesh, &ideal_mesh, handle8, handle9, delta, metrics[i] ) ); 00224 00225 return 0; 00226 } 00227 00228 bool smooth_mesh( MeshImpl* mesh, 00229 Mesh*, 00230 Mesh::VertexHandle vert1, 00231 Mesh::VertexHandle vert2, 00232 Vector3D delta, 00233 QualityMetric* metric ) 00234 { 00235 MBMesquite::MsqPrintError err( cout ); 00236 const Vector3D origin( 0, 0, 0 ); 00237 00238 // print a little output so we know when we died 00239 std::cout << "**************************************************************************" << std::endl 00240 << "* Smoothing..." << std::endl 00241 << "* Metric: " << metric->get_name() << std::endl 00242 << "* Offset: " << delta 00243 << std::endl //<< 00244 //"**************************************************************************" 00245 << std::endl; 00246 00247 // Set free vertices to specified position 00248 Mesh::VertexHandle handles[] = { vert1, vert2 }; 00249 MsqVertex coordinates[2]; 00250 mesh->vertices_get_coordinates( handles, coordinates, 2, err ); 00251 CPPUNIT_ASSERT( !err ); 00252 Vector3D coord1 = coordinates[0] + delta; 00253 Vector3D coord2 = coordinates[1] + delta; 00254 mesh->vertex_set_coordinates( vert1, coord1, err ); 00255 CPPUNIT_ASSERT( !err ); 00256 mesh->vertex_set_coordinates( vert2, coord2, err ); 00257 CPPUNIT_ASSERT( !err ); 00258 00259 // Create an InstructionQueue 00260 InstructionQueue Q; 00261 00262 // Set up objective function 00263 LPtoPTemplate obj_func( metric, 1, err ); 00264 CPPUNIT_ASSERT( !err ); 00265 00266 // Create solver 00267 FeasibleNewton solver( &obj_func ); 00268 CPPUNIT_ASSERT( !err ); 00269 solver.use_global_patch(); 00270 00271 // Set stoping criteria for solver 00272 TerminationCriterion tc_inner; 00273 tc_inner.add_absolute_vertex_movement( 1e-7 ); 00274 solver.set_inner_termination_criterion( &tc_inner ); 00275 00276 TerminationCriterion tc_outer; 00277 tc_outer.add_iteration_limit( 1 ); 00278 solver.set_outer_termination_criterion( &tc_outer ); 00279 00280 #ifdef DO_QUALITY_ASSESSOR 00281 QualityAssessor qa( metric, 10 ); 00282 Q.add_quality_assessor( &qa, err ); 00283 CPPUNIT_ASSERT( !err ); 00284 #endif 00285 00286 // Add solver to queue 00287 Q.set_master_quality_improver( &solver, err ); 00288 CPPUNIT_ASSERT( !err ); 00289 00290 #ifdef DO_QUALITY_ASSESSOR 00291 Q.add_quality_assessor( &qa, err ); 00292 CPPUNIT_ASSERT( !err ); 00293 #endif 00294 00295 // And smooth... 00296 Q.run_instructions( mesh, err ); 00297 CPPUNIT_ASSERT( !err ); 00298 00299 // Verify that vertices were moved back to origin 00300 MsqVertex new_coords[2]; 00301 mesh->vertices_get_coordinates( handles, new_coords, 2, err ); 00302 CPPUNIT_ASSERT( !err ); 00303 00304 // print a little output so we know when we died 00305 std::cout //<< 00306 //"**************************************************************************" 00307 << std::endl 00308 << "* Done Smoothing:" << std::endl 00309 << "* Metric: " << metric->get_name() << std::endl 00310 << "* Position1: " << new_coords[0][0] << " " << new_coords[0][1] << " " << new_coords[0][2] << std::endl 00311 << "* Position2: " << new_coords[1][0] << " " << new_coords[1][1] << " " << new_coords[1][2] << std::endl 00312 << "**************************************************************************" << std::endl; 00313 00314 CPPUNIT_ASSERT_VECTORS_EQUAL( coordinates[0], new_coords[0], TOL ); 00315 CPPUNIT_ASSERT_VECTORS_EQUAL( coordinates[1], new_coords[1], TOL ); 00316 return false; 00317 }
