AWSizeNB1.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2010) kraftche@cae.wisc.edu
00024
00025   ***************************************************************** */
00026
00027 /** \file AWSizeNB1.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "AWSizeNB1.hpp"
00034 #include "MsqMatrix.hpp"
00035 #include "TMPDerivs.hpp"
00036 #include "TMPCommon.hpp"
00037
00038 namespace MBMesquite
00039 {
00040
00041 std::string AWSizeNB1::get_name() const
00042 {
00043     return "AWSizeNB1";
00044 }
00045
00046 AWSizeNB1::~AWSizeNB1() {}
00047
00048 template < unsigned DIM >
00049 static inline bool eval( const MsqMatrix< DIM, DIM >& A, const MsqMatrix< DIM, DIM >& W, double& result )
00050 {
00051     result = det( A ) - det( W );
00052     result *= result;
00053     return true;
00054 }
00055
00056 template < unsigned DIM >
00057 static inline bool grad( const MsqMatrix< DIM, DIM >& A,
00058                          const MsqMatrix< DIM, DIM >& W,
00059                          double& result,
00060                          MsqMatrix< DIM, DIM >& deriv )
00061 {
00062     result = det( A ) - det( W );
00063     deriv  = transpose_adj( A );
00064     deriv *= 2 * result;
00065     result *= result;
00066     return true;
00067 }
00068
00069 template < unsigned DIM >
00070 static inline bool hess( const MsqMatrix< DIM, DIM >& A,
00071                          const MsqMatrix< DIM, DIM >& W,
00072                          double& result,
00073                          MsqMatrix< DIM, DIM >& deriv,
00074                          MsqMatrix< DIM, DIM >* second )
00075 {
00076     result = det( A ) - det( W );
00077     deriv  = transpose_adj( A );
00078     set_scaled_outer_product( second, 2.0, deriv );
00079     pluseq_scaled_2nd_deriv_of_det( second, 2 * result, A );
00080     deriv *= 2 * result;
00081     result *= result;
00082     return true;
00083 }
00084
00085 TMP_AW_TEMPL_IMPL_COMMON( AWSizeNB1 )
00086
00087 }  // namespace MBMesquite
