MOAB: Mesh Oriented datABase
(version 5.2.1)
Common utility stuff for implementing target metrics. More...
#include "Mesquite.hpp"
Classes | |
struct | MBMesquite::DimConst< D > |
Dimension-specific constants. More... | |
struct | MBMesquite::DimConst< 2 > |
struct | MBMesquite::DimConst< 3 > |
Namespaces | |
namespace | MBMesquite |
Implements the NonSmoothDescent class member functions. | |
Defines | |
#define | TMP_T_TEMPL_IMPL_DIM(N, D) |
#define | TMP_T_TEMPL_IMPL_COMMON(N) |
A macro that declares virtual evaluation functions for a TMetric subclass N . | |
#define | TMP_T_TEMPL_IMPL_ERR_DIM(N, D) |
#define | TMP_T_TEMPL_IMPL_COMMON_ERR(N) |
#define | TMP_AW_TEMPL_IMPL_DIM(N, D) |
#define | TMP_AW_TEMPL_IMPL_COMMON(N) |
A macro that declares virtual evaluation functions for a AWMetric subclass N . | |
#define | TMP_AW_TEMPL_IMPL_NO2ND_DIM(N, D) |
#define | TMP_AW_TEMPL_IMPL_COMMON_NO2ND(N) |
Definition in file TMPCommon.hpp.
#define TMP_AW_TEMPL_IMPL_COMMON | ( | N | ) |
TMP_AW_TEMPL_IMPL_DIM( N, 2 ) \ TMP_AW_TEMPL_IMPL_DIM( N, 3 )
subclass N
Like TMP_AW_TEMPL_IMPL_COMMON, except no implementation of 2nd derivs.
IF a AWMetric
class provides template functions named eval
, grad
, and hess
, then this macro can be used to provide the trivial implementations of the 2D and 3D evaluate
, evaluate_with_grad
, and evaluate_with_hess
virtual member functions in terms of those macros.
#define TMP_AW_TEMPL_IMPL_COMMON_NO2ND | ( | N | ) |
TMP_AW_TEMPL_IMPL_NO2ND_DIM( N, 2 ) \ TMP_AW_TEMPL_IMPL_NO2ND_DIM( N, 3 )
Definition at line 145 of file TMPCommon.hpp.
#define TMP_AW_TEMPL_IMPL_DIM | ( | N, | |
D | |||
bool N::evaluate( const MsqMatrix< D, D >& A, const MsqMatrix< D, D >& W, double& r, MsqError& ) \ { \ return eval( A, W, r ); \ } \ bool N::evaluate_with_grad( const MsqMatrix< D, D >& A, const MsqMatrix< D, D >& W, double& r, \ MsqMatrix< D, D >& d1, MsqError& ) \ { \ return grad( A, W, r, d1 ); \ } \ bool N::evaluate_with_hess( const MsqMatrix< D, D >& A, const MsqMatrix< D, D >& W, double& r, \ MsqMatrix< D, D >& d1, MsqMatrix< D, D >* d2, MsqError& ) \ { \ return hess( A, W, r, d1, d2 ); \ }
Definition at line 110 of file TMPCommon.hpp.
#define TMP_AW_TEMPL_IMPL_NO2ND_DIM | ( | N, | |
D | |||
Definition at line 134 of file TMPCommon.hpp.
#define TMP_T_TEMPL_IMPL_COMMON | ( | N | ) |
TMP_T_TEMPL_IMPL_DIM( N, 2 ) \ TMP_T_TEMPL_IMPL_DIM( N, 3 )
subclass N
IF a TMetric
, grad
, and hess
Definition at line 64 of file TMPCommon.hpp.
#define TMP_T_TEMPL_IMPL_COMMON_ERR | ( | N | ) |
TMP_T_TEMPL_IMPL_ERR_DIM( N, 2 ) \ TMP_T_TEMPL_IMPL_ERR_DIM( N, 3 )
subclass N
IF a TMetric
, grad
, and hess
The difference between this macro and TMP_AW_TEMPL_IMPL_COMMON
is that this variation expects the eval
, grad
, and hess
to accept an MsqError
as their last argument. This variation is typically used for metrics that are a function of some other metric.
Definition at line 97 of file TMPCommon.hpp.
#define TMP_T_TEMPL_IMPL_DIM | ( | N, | |
D | |||
bool N::evaluate( const MsqMatrix< D, D >& T, double& r, MsqError& ) \ { \ return eval( T, r ); \ } \ bool N::evaluate_with_grad( const MsqMatrix< D, D >& T, double& r, MsqMatrix< D, D >& d1, MsqError& ) \ { \ return grad( T, r, d1 ); \ } \ bool N::evaluate_with_hess( const MsqMatrix< D, D >& T, double& r, MsqMatrix< D, D >& d1, MsqMatrix< D, D >* d2, \ MsqError& ) \ { \ return hess( T, r, d1, d2 ); \ }
Definition at line 49 of file TMPCommon.hpp.
#define TMP_T_TEMPL_IMPL_ERR_DIM | ( | N, | |
D | |||
bool N::evaluate( const MsqMatrix< D, D >& T, double& r, MsqError& err ) \ { \ return eval( T, r, err ); \ } \ bool N::evaluate_with_grad( const MsqMatrix< D, D >& T, double& r, MsqMatrix< D, D >& d1, MsqError& err ) \ { \ return grad( T, r, d1, err ); \ } \ bool N::evaluate_with_hess( const MsqMatrix< D, D >& T, double& r, MsqMatrix< D, D >& d1, MsqMatrix< D, D >* d2, \ MsqError& err ) \ { \ return hess( T, r, d1, d2, err ); \ }
Definition at line 82 of file TMPCommon.hpp.
