MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_AMBIVECTOR_H 00011 #define EIGEN_AMBIVECTOR_H 00012 00013 namespace Eigen { 00014 00015 namespace internal { 00016 00022 template<typename _Scalar, typename _StorageIndex> 00023 class AmbiVector 00024 { 00025 public: 00026 typedef _Scalar Scalar; 00027 typedef _StorageIndex StorageIndex; 00028 typedef typename NumTraits<Scalar>::Real RealScalar; 00029 00030 explicit AmbiVector(Index size) 00031 : m_buffer(0), m_zero(0), m_size(0), m_allocatedSize(0), m_allocatedElements(0), m_mode(-1) 00032 { 00033 resize(size); 00034 } 00035 00036 void init(double estimatedDensity); 00037 void init(int mode); 00038 00039 Index nonZeros() const; 00040 00042 void setBounds(Index start, Index end) { m_start = convert_index(start); m_end = convert_index(end); } 00043 00044 void setZero(); 00045 00046 void restart(); 00047 Scalar& coeffRef(Index i); 00048 Scalar& coeff(Index i); 00049 00050 class Iterator; 00051 00052 ~AmbiVector() { delete[] m_buffer; } 00053 00054 void resize(Index size) 00055 { 00056 if (m_allocatedSize < size) 00057 reallocate(size); 00058 m_size = convert_index(size); 00059 } 00060 00061 StorageIndex size() const { return m_size; } 00062 00063 protected: 00064 StorageIndex convert_index(Index idx) 00065 { 00066 return internal::convert_index<StorageIndex>(idx); 00067 } 00068 00069 void reallocate(Index size) 00070 { 00071 // if the size of the matrix is not too large, let's allocate a bit more than needed such 00072 // that we can handle dense vector even in sparse mode. 00073 delete[] m_buffer; 00074 if (size<1000) 00075 { 00076 Index allocSize = (size * sizeof(ListEl) + sizeof(Scalar) - 1)/sizeof(Scalar); 00077 m_allocatedElements = convert_index((allocSize*sizeof(Scalar))/sizeof(ListEl)); 00078 m_buffer = new Scalar[allocSize]; 00079 } 00080 else 00081 { 00082 m_allocatedElements = convert_index((size*sizeof(Scalar))/sizeof(ListEl)); 00083 m_buffer = new Scalar[size]; 00084 } 00085 m_size = convert_index(size); 00086 m_start = 0; 00087 m_end = m_size; 00088 } 00089 00090 void reallocateSparse() 00091 { 00092 Index copyElements = m_allocatedElements; 00093 m_allocatedElements = (std::min)(StorageIndex(m_allocatedElements*1.5),m_size); 00094 Index allocSize = m_allocatedElements * sizeof(ListEl); 00095 allocSize = (allocSize + sizeof(Scalar) - 1)/sizeof(Scalar); 00096 Scalar* newBuffer = new Scalar[allocSize]; 00097 memcpy(newBuffer, m_buffer, copyElements * sizeof(ListEl)); 00098 delete[] m_buffer; 00099 m_buffer = newBuffer; 00100 } 00101 00102 protected: 00103 // element type of the linked list 00104 struct ListEl 00105 { 00106 StorageIndex next; 00107 StorageIndex index; 00108 Scalar value; 00109 }; 00110 00111 // used to store data in both mode 00112 Scalar* m_buffer; 00113 Scalar m_zero; 00114 StorageIndex m_size; 00115 StorageIndex m_start; 00116 StorageIndex m_end; 00117 StorageIndex m_allocatedSize; 00118 StorageIndex m_allocatedElements; 00119 StorageIndex m_mode; 00120 00121 // linked list mode 00122 StorageIndex m_llStart; 00123 StorageIndex m_llCurrent; 00124 StorageIndex m_llSize; 00125 }; 00126 00128 template<typename _Scalar,typename _StorageIndex> 00129 Index AmbiVector<_Scalar,_StorageIndex>::nonZeros() const 00130 { 00131 if (m_mode==IsSparse) 00132 return m_llSize; 00133 else 00134 return m_end - m_start; 00135 } 00136 00137 template<typename _Scalar,typename _StorageIndex> 00138 void AmbiVector<_Scalar,_StorageIndex>::init(double estimatedDensity) 00139 { 00140 if (estimatedDensity>0.1) 00141 init(IsDense); 00142 else 00143 init(IsSparse); 00144 } 00145 00146 template<typename _Scalar,typename _StorageIndex> 00147 void AmbiVector<_Scalar,_StorageIndex>::init(int mode) 00148 { 00149 m_mode = mode; 00150 if (m_mode==IsSparse) 00151 { 00152 m_llSize = 0; 00153 m_llStart = -1; 00154 } 00155 } 00156 00162 template<typename _Scalar,typename _StorageIndex> 00163 void AmbiVector<_Scalar,_StorageIndex>::restart() 00164 { 00165 m_llCurrent = m_llStart; 00166 } 00167 00169 template<typename _Scalar,typename _StorageIndex> 00170 void AmbiVector<_Scalar,_StorageIndex>::setZero() 00171 { 00172 if (m_mode==IsDense) 00173 { 00174 for (Index i=m_start; i<m_end; ++i) 00175 m_buffer[i] = Scalar(0); 00176 } 00177 else 00178 { 00179 eigen_assert(m_mode==IsSparse); 00180 m_llSize = 0; 00181 m_llStart = -1; 00182 } 00183 } 00184 00185 template<typename _Scalar,typename _StorageIndex> 00186 _Scalar& AmbiVector<_Scalar,_StorageIndex>::coeffRef(Index i) 00187 { 00188 if (m_mode==IsDense) 00189 return m_buffer[i]; 00190 else 00191 { 00192 ListEl* EIGEN_RESTRICT llElements = reinterpret_cast<ListEl*>(m_buffer); 00193 // TODO factorize the following code to reduce code generation 00194 eigen_assert(m_mode==IsSparse); 00195 if (m_llSize==0) 00196 { 00197 // this is the first element 00198 m_llStart = 0; 00199 m_llCurrent = 0; 00200 ++m_llSize; 00201 llElements[0].value = Scalar(0); 00202 llElements[0].index = convert_index(i); 00203 llElements[0].next = -1; 00204 return llElements[0].value; 00205 } 00206 else if (i<llElements[m_llStart].index) 00207 { 00208 // this is going to be the new first element of the list 00209 ListEl& el = llElements[m_llSize]; 00210 el.value = Scalar(0); 00211 el.index = convert_index(i); 00212 el.next = m_llStart; 00213 m_llStart = m_llSize; 00214 ++m_llSize; 00215 m_llCurrent = m_llStart; 00216 return el.value; 00217 } 00218 else 00219 { 00220 StorageIndex nextel = llElements[m_llCurrent].next; 00221 eigen_assert(i>=llElements[m_llCurrent].index && "you must call restart() before inserting an element with lower or equal index"); 00222 while (nextel >= 0 && llElements[nextel].index<=i) 00223 { 00224 m_llCurrent = nextel; 00225 nextel = llElements[nextel].next; 00226 } 00227 00228 if (llElements[m_llCurrent].index==i) 00229 { 00230 // the coefficient already exists and we found it ! 00231 return llElements[m_llCurrent].value; 00232 } 00233 else 00234 { 00235 if (m_llSize>=m_allocatedElements) 00236 { 00237 reallocateSparse(); 00238 llElements = reinterpret_cast<ListEl*>(m_buffer); 00239 } 00240 eigen_internal_assert(m_llSize<m_allocatedElements && "internal error: overflow in sparse mode"); 00241 // let's insert a new coefficient 00242 ListEl& el = llElements[m_llSize]; 00243 el.value = Scalar(0); 00244 el.index = convert_index(i); 00245 el.next = llElements[m_llCurrent].next; 00246 llElements[m_llCurrent].next = m_llSize; 00247 ++m_llSize; 00248 return el.value; 00249 } 00250 } 00251 } 00252 } 00253 00254 template<typename _Scalar,typename _StorageIndex> 00255 _Scalar& AmbiVector<_Scalar,_StorageIndex>::coeff(Index i) 00256 { 00257 if (m_mode==IsDense) 00258 return m_buffer[i]; 00259 else 00260 { 00261 ListEl* EIGEN_RESTRICT llElements = reinterpret_cast<ListEl*>(m_buffer); 00262 eigen_assert(m_mode==IsSparse); 00263 if ((m_llSize==0) || (i<llElements[m_llStart].index)) 00264 { 00265 return m_zero; 00266 } 00267 else 00268 { 00269 Index elid = m_llStart; 00270 while (elid >= 0 && llElements[elid].index<i) 00271 elid = llElements[elid].next; 00272 00273 if (llElements[elid].index==i) 00274 return llElements[m_llCurrent].value; 00275 else 00276 return m_zero; 00277 } 00278 } 00279 } 00280 00282 template<typename _Scalar,typename _StorageIndex> 00283 class AmbiVector<_Scalar,_StorageIndex>::Iterator 00284 { 00285 public: 00286 typedef _Scalar Scalar; 00287 typedef typename NumTraits<Scalar>::Real RealScalar; 00288 00295 explicit Iterator(const AmbiVector& vec, const RealScalar& epsilon = 0) 00296 : m_vector(vec) 00297 { 00298 using std::abs; 00299 m_epsilon = epsilon; 00300 m_isDense = m_vector.m_mode==IsDense; 00301 if (m_isDense) 00302 { 00303 m_currentEl = 0; // this is to avoid a compilation warning 00304 m_cachedValue = 0; // this is to avoid a compilation warning 00305 m_cachedIndex = m_vector.m_start-1; 00306 ++(*this); 00307 } 00308 else 00309 { 00310 ListEl* EIGEN_RESTRICT llElements = reinterpret_cast<ListEl*>(m_vector.m_buffer); 00311 m_currentEl = m_vector.m_llStart; 00312 while (m_currentEl>=0 && abs(llElements[m_currentEl].value)<=m_epsilon) 00313 m_currentEl = llElements[m_currentEl].next; 00314 if (m_currentEl<0) 00315 { 00316 m_cachedValue = 0; // this is to avoid a compilation warning 00317 m_cachedIndex = -1; 00318 } 00319 else 00320 { 00321 m_cachedIndex = llElements[m_currentEl].index; 00322 m_cachedValue = llElements[m_currentEl].value; 00323 } 00324 } 00325 } 00326 00327 StorageIndex index() const { return m_cachedIndex; } 00328 Scalar value() const { return m_cachedValue; } 00329 00330 operator bool() const { return m_cachedIndex>=0; } 00331 00332 Iterator& operator++() 00333 { 00334 using std::abs; 00335 if (m_isDense) 00336 { 00337 do { 00338 ++m_cachedIndex; 00339 } while (m_cachedIndex<m_vector.m_end && abs(m_vector.m_buffer[m_cachedIndex])<m_epsilon); 00340 if (m_cachedIndex<m_vector.m_end) 00341 m_cachedValue = m_vector.m_buffer[m_cachedIndex]; 00342 else 00343 m_cachedIndex=-1; 00344 } 00345 else 00346 { 00347 ListEl* EIGEN_RESTRICT llElements = reinterpret_cast<ListEl*>(m_vector.m_buffer); 00348 do { 00349 m_currentEl = llElements[m_currentEl].next; 00350 } while (m_currentEl>=0 && abs(llElements[m_currentEl].value)<m_epsilon); 00351 if (m_currentEl<0) 00352 { 00353 m_cachedIndex = -1; 00354 } 00355 else 00356 { 00357 m_cachedIndex = llElements[m_currentEl].index; 00358 m_cachedValue = llElements[m_currentEl].value; 00359 } 00360 } 00361 return *this; 00362 } 00363 00364 protected: 00365 const AmbiVector& m_vector; // the target vector 00366 StorageIndex m_currentEl; // the current element in sparse/linked-list mode 00367 RealScalar m_epsilon; // epsilon used to prune zero coefficients 00368 StorageIndex m_cachedIndex; // current coordinate 00369 Scalar m_cachedValue; // current value 00370 bool m_isDense; // mode of the vector 00371 }; 00372 00373 } // end namespace internal 00374 00375 } // end namespace Eigen 00376 00377 #endif // EIGEN_AMBIVECTOR_H
