MOAB
4.9.3pre
#include <AmbiVector.h>
Classes | |
| class | Iterator |
| struct | ListEl |
Public Types | |
| typedef _Scalar | Scalar |
| typedef _StorageIndex | StorageIndex |
| typedef NumTraits< Scalar >::Real | RealScalar |
Public Member Functions | |
| AmbiVector (Index size) | |
| void | init (double estimatedDensity) |
| void | init (int mode) |
| Index | nonZeros () const |
| void | setBounds (Index start, Index end) |
| void | setZero () |
| void | restart () |
| Scalar & | coeffRef (Index i) |
| Scalar & | coeff (Index i) |
| ~AmbiVector () | |
| void | resize (Index size) |
| StorageIndex | size () const |
Protected Member Functions | |
| StorageIndex | convert_index (Index idx) |
| void | reallocate (Index size) |
| void | reallocateSparse () |
Protected Attributes | |
| Scalar * | m_buffer |
| Scalar | m_zero |
| StorageIndex | m_size |
| StorageIndex | m_start |
| StorageIndex | m_end |
| StorageIndex | m_allocatedSize |
| StorageIndex | m_allocatedElements |
| StorageIndex | m_mode |
| StorageIndex | m_llStart |
| StorageIndex | m_llCurrent |
| StorageIndex | m_llSize |
Hybrid sparse/dense vector class designed for intensive read-write operations.
See BasicSparseLLT and SparseProduct for usage examples.
Definition at line 23 of file AmbiVector.h.
| typedef NumTraits<Scalar>::Real Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::RealScalar |
Definition at line 28 of file AmbiVector.h.
| typedef _Scalar Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::Scalar |
Definition at line 26 of file AmbiVector.h.
| typedef _StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::StorageIndex |
Definition at line 27 of file AmbiVector.h.
| Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::AmbiVector | ( | Index | size | ) | [inline, explicit] |
Definition at line 30 of file AmbiVector.h.
: m_buffer(0), m_zero(0), m_size(0), m_allocatedSize(0), m_allocatedElements(0), m_mode(-1) { resize(size); }
| Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::~AmbiVector | ( | ) | [inline] |
Definition at line 52 of file AmbiVector.h.
{ delete[] m_buffer; }
| _Scalar & Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::coeff | ( | Index | i | ) |
Definition at line 255 of file AmbiVector.h.
if (m_mode==IsDense)
return m_buffer[i];
else
ListEl* EIGEN_RESTRICT llElements = reinterpret_cast<ListEl*>(m_buffer);
eigen_assert(m_mode==IsSparse);
if ((m_llSize==0) || (i<llElements[m_llStart].index))
return m_zero;
else
Index elid = m_llStart;
while (elid >= 0 && llElements[elid].index<i)
elid = llElements[elid].next;
if (llElements[elid].index==i)
return llElements[m_llCurrent].value;
else
return m_zero;
| _Scalar & Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::coeffRef | ( | Index | i | ) |
Definition at line 186 of file AmbiVector.h.
return m_buffer[i];
else
// TODO factorize the following code to reduce code generation
if (m_llSize==0)
// this is the first element
m_llStart = 0;
m_llCurrent = 0;
++m_llSize;
llElements[0].value = Scalar(0);
llElements[0].index = convert_index(i);
llElements[0].next = -1;
return llElements[0].value;
else if (i<llElements[m_llStart].index)
// this is going to be the new first element of the list
ListEl& el = llElements[m_llSize];
el.value = Scalar(0);
el.index = convert_index(i);
el.next = m_llStart;
m_llStart = m_llSize;
++m_llSize;
m_llCurrent = m_llStart;
return el.value;
else
StorageIndex nextel = llElements[m_llCurrent].next;
eigen_assert(i>=llElements[m_llCurrent].index && "you must call restart() before inserting an element with lower or equal index");
while (nextel >= 0 && llElements[nextel].index<=i)
m_llCurrent = nextel;
nextel = llElements[nextel].next;
if (llElements[m_llCurrent].index==i)
// the coefficient already exists and we found it !
else
if (m_llSize>=m_allocatedElements)
reallocateSparse();
eigen_internal_assert(m_llSize<m_allocatedElements && "internal error: overflow in sparse mode");
// let's insert a new coefficient
el.next = llElements[m_llCurrent].next;
llElements[m_llCurrent].next = m_llSize;
++m_llSize;
return el.value;
| StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::convert_index | ( | Index | idx | ) | [inline, protected] |
Definition at line 64 of file AmbiVector.h.
return internal::convert_index<StorageIndex>(idx);
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::init | ( | double | estimatedDensity | ) |
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::init | ( | int | mode | ) |
| Index Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::nonZeros | ( | ) | const |
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::reallocate | ( | Index | size | ) | [inline, protected] |
Definition at line 69 of file AmbiVector.h.
// if the size of the matrix is not too large, let's allocate a bit more than needed such
// that we can handle dense vector even in sparse mode.
delete[] m_buffer;
if (size<1000)
Index allocSize = (size * sizeof(ListEl) + sizeof(Scalar) - 1)/sizeof(Scalar);
m_allocatedElements = convert_index((allocSize*sizeof(Scalar))/sizeof(ListEl));
m_buffer = new Scalar[allocSize];
else
m_allocatedElements = convert_index((size*sizeof(Scalar))/sizeof(ListEl));
m_buffer = new Scalar[size];
m_size = convert_index(size);
m_start = 0;
m_end = m_size;
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::reallocateSparse | ( | ) | [inline, protected] |
Definition at line 90 of file AmbiVector.h.
Index copyElements = m_allocatedElements;
m_allocatedElements = (std::min)(StorageIndex(m_allocatedElements*1.5),m_size);
Index allocSize = m_allocatedElements * sizeof(ListEl);
allocSize = (allocSize + sizeof(Scalar) - 1)/sizeof(Scalar);
Scalar* newBuffer = new Scalar[allocSize];
memcpy(newBuffer, m_buffer, copyElements * sizeof(ListEl));
delete[] m_buffer;
m_buffer = newBuffer;
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::resize | ( | Index | size | ) | [inline] |
Definition at line 54 of file AmbiVector.h.
if (m_allocatedSize < size)
reallocate(size);
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::restart | ( | ) |
Must be called whenever we might perform a write access with an index smaller than the previous one.
Don't worry, this function is extremely cheap.
Definition at line 163 of file AmbiVector.h.
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::setBounds | ( | Index | start, |
| Index | end | ||
| ) | [inline] |
Specifies a sub-vector to work on
Definition at line 42 of file AmbiVector.h.
{ m_start = convert_index(start); m_end = convert_index(end); }
| void Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::setZero | ( | ) |
| StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::size | ( | ) | const [inline] |
Definition at line 61 of file AmbiVector.h.
{ return m_size; }
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_allocatedElements [protected] |
Definition at line 118 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_allocatedSize [protected] |
Definition at line 117 of file AmbiVector.h.
Scalar* Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_buffer [protected] |
Definition at line 112 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_end [protected] |
Definition at line 116 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_llCurrent [protected] |
Definition at line 123 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_llSize [protected] |
Definition at line 124 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_llStart [protected] |
Definition at line 122 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_mode [protected] |
Definition at line 119 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_size [protected] |
Definition at line 114 of file AmbiVector.h.
StorageIndex Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_start [protected] |
Definition at line 115 of file AmbiVector.h.
Scalar Eigen::internal::AmbiVector< _Scalar, _StorageIndex >::m_zero [protected] |
Definition at line 113 of file AmbiVector.h.
