MOAB
4.9.3pre
00001 /* 00002 Copyright (c) 2011, Intel Corporation. All rights reserved. 00003 Copyright (C) 2015 Gael Guennebaud <[email protected]> 00004 00005 Redistribution and use in source and binary forms, with or without modification, 00006 are permitted provided that the following conditions are met: 00007 00008 * Redistributions of source code must retain the above copyright notice, this 00009 list of conditions and the following disclaimer. 00010 * Redistributions in binary form must reproduce the above copyright notice, 00011 this list of conditions and the following disclaimer in the documentation 00012 and/or other materials provided with the distribution. 00013 * Neither the name of Intel Corporation nor the names of its contributors may 00014 be used to endorse or promote products derived from this software without 00015 specific prior written permission. 00016 00017 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND 00018 ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED 00019 WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE 00020 DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR 00021 ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES 00022 (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; 00023 LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON 00024 ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT 00025 (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS 00026 SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. 00027 00028 ******************************************************************************** 00029 * Content : Eigen bindings to Intel(R) MKL 00030 * MKL VML support for coefficient-wise unary Eigen expressions like a=b.sin() 00031 ******************************************************************************** 00032 */ 00033 00034 #ifndef EIGEN_ASSIGN_VML_H 00035 #define EIGEN_ASSIGN_VML_H 00036 00037 namespace Eigen { 00038 00039 namespace internal { 00040 00041 template<typename Dst, typename Src> 00042 class vml_assign_traits 00043 { 00044 private: 00045 enum { 00046 DstHasDirectAccess = Dst::Flags & DirectAccessBit, 00047 SrcHasDirectAccess = Src::Flags & DirectAccessBit, 00048 StorageOrdersAgree = (int(Dst::IsRowMajor) == int(Src::IsRowMajor)), 00049 InnerSize = int(Dst::IsVectorAtCompileTime) ? int(Dst::SizeAtCompileTime) 00050 : int(Dst::Flags)&RowMajorBit ? int(Dst::ColsAtCompileTime) 00051 : int(Dst::RowsAtCompileTime), 00052 InnerMaxSize = int(Dst::IsVectorAtCompileTime) ? int(Dst::MaxSizeAtCompileTime) 00053 : int(Dst::Flags)&RowMajorBit ? int(Dst::MaxColsAtCompileTime) 00054 : int(Dst::MaxRowsAtCompileTime), 00055 MaxSizeAtCompileTime = Dst::SizeAtCompileTime, 00056 00057 MightEnableVml = StorageOrdersAgree && DstHasDirectAccess && SrcHasDirectAccess && Src::InnerStrideAtCompileTime==1 && Dst::InnerStrideAtCompileTime==1, 00058 MightLinearize = MightEnableVml && (int(Dst::Flags) & int(Src::Flags) & LinearAccessBit), 00059 VmlSize = MightLinearize ? MaxSizeAtCompileTime : InnerMaxSize, 00060 LargeEnough = VmlSize==Dynamic || VmlSize>=EIGEN_MKL_VML_THRESHOLD 00061 }; 00062 public: 00063 enum { 00064 EnableVml = MightEnableVml && LargeEnough, 00065 Traversal = MightLinearize ? LinearTraversal : DefaultTraversal 00066 }; 00067 }; 00068 00069 #define EIGEN_PP_EXPAND(ARG) ARG 00070 #if !defined (EIGEN_FAST_MATH) || (EIGEN_FAST_MATH != 1) 00071 #define EIGEN_VMLMODE_EXPAND_LA , VML_HA 00072 #else 00073 #define EIGEN_VMLMODE_EXPAND_LA , VML_LA 00074 #endif 00075 00076 #define EIGEN_VMLMODE_EXPAND__ 00077 00078 #define EIGEN_VMLMODE_PREFIX_LA vm 00079 #define EIGEN_VMLMODE_PREFIX__ v 00080 #define EIGEN_VMLMODE_PREFIX(VMLMODE) EIGEN_CAT(EIGEN_VMLMODE_PREFIX_,VMLMODE) 00081 00082 #define EIGEN_MKL_VML_DECLARE_UNARY_CALL(EIGENOP, VMLOP, EIGENTYPE, VMLTYPE, VMLMODE) \ 00083 template< typename DstXprType, typename SrcXprNested> \ 00084 struct Assignment<DstXprType, CwiseUnaryOp<scalar_##EIGENOP##_op<EIGENTYPE>, SrcXprNested>, assign_op<EIGENTYPE>, \ 00085 Dense2Dense, typename enable_if<vml_assign_traits<DstXprType,SrcXprNested>::EnableVml,EIGENTYPE>::type> { \ 00086 typedef CwiseUnaryOp<scalar_##EIGENOP##_op<EIGENTYPE>, SrcXprNested> SrcXprType; \ 00087 static void run(DstXprType &dst, const SrcXprType &src, const assign_op<EIGENTYPE> &/*func*/) { \ 00088 eigen_assert(dst.rows() == src.rows() && dst.cols() == src.cols()); \ 00089 if(vml_assign_traits<DstXprType,SrcXprNested>::Traversal==LinearTraversal) { \ 00090 VMLOP(dst.size(), (const VMLTYPE*)src.nestedExpression().data(), \ 00091 (VMLTYPE*)dst.data() EIGEN_PP_EXPAND(EIGEN_VMLMODE_EXPAND_##VMLMODE) ); \ 00092 } else { \ 00093 const Index outerSize = dst.outerSize(); \ 00094 for(Index outer = 0; outer < outerSize; ++outer) { \ 00095 const EIGENTYPE *src_ptr = src.IsRowMajor ? &(src.nestedExpression().coeffRef(outer,0)) : \ 00096 &(src.nestedExpression().coeffRef(0, outer)); \ 00097 EIGENTYPE *dst_ptr = dst.IsRowMajor ? &(dst.coeffRef(outer,0)) : &(dst.coeffRef(0, outer)); \ 00098 VMLOP( dst.innerSize(), (const VMLTYPE*)src_ptr, \ 00099 (VMLTYPE*)dst_ptr EIGEN_PP_EXPAND(EIGEN_VMLMODE_EXPAND_##VMLMODE)); \ 00100 } \ 00101 } \ 00102 } \ 00103 }; \ 00104 00105 00106 #define EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(EIGENOP, VMLOP, VMLMODE) \ 00107 EIGEN_MKL_VML_DECLARE_UNARY_CALL(EIGENOP, EIGEN_CAT(EIGEN_VMLMODE_PREFIX(VMLMODE),s##VMLOP), float, float, VMLMODE) \ 00108 EIGEN_MKL_VML_DECLARE_UNARY_CALL(EIGENOP, EIGEN_CAT(EIGEN_VMLMODE_PREFIX(VMLMODE),d##VMLOP), double, double, VMLMODE) 00109 00110 #define EIGEN_MKL_VML_DECLARE_UNARY_CALLS_CPLX(EIGENOP, VMLOP, VMLMODE) \ 00111 EIGEN_MKL_VML_DECLARE_UNARY_CALL(EIGENOP, EIGEN_CAT(EIGEN_VMLMODE_PREFIX(VMLMODE),c##VMLOP), scomplex, MKL_Complex8, VMLMODE) \ 00112 EIGEN_MKL_VML_DECLARE_UNARY_CALL(EIGENOP, EIGEN_CAT(EIGEN_VMLMODE_PREFIX(VMLMODE),z##VMLOP), dcomplex, MKL_Complex16, VMLMODE) 00113 00114 #define EIGEN_MKL_VML_DECLARE_UNARY_CALLS(EIGENOP, VMLOP, VMLMODE) \ 00115 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(EIGENOP, VMLOP, VMLMODE) \ 00116 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_CPLX(EIGENOP, VMLOP, VMLMODE) 00117 00118 00119 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(sin, Sin, LA) 00120 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(asin, Asin, LA) 00121 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(sinh, Sinh, LA) 00122 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(cos, Cos, LA) 00123 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(acos, Acos, LA) 00124 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(cosh, Cosh, LA) 00125 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(tan, Tan, LA) 00126 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(atan, Atan, LA) 00127 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(tanh, Tanh, LA) 00128 // EIGEN_MKL_VML_DECLARE_UNARY_CALLS(abs, Abs, _) 00129 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(exp, Exp, LA) 00130 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(log, Ln, LA) 00131 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(log10, Log10, LA) 00132 EIGEN_MKL_VML_DECLARE_UNARY_CALLS(sqrt, Sqrt, _) 00133 00134 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(square, Sqr, _) 00135 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_CPLX(arg, Arg, _) 00136 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(round, Round, _) 00137 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(floor, Floor, _) 00138 EIGEN_MKL_VML_DECLARE_UNARY_CALLS_REAL(ceil, Ceil, _) 00139 00140 #define EIGEN_MKL_VML_DECLARE_POW_CALL(EIGENOP, VMLOP, EIGENTYPE, VMLTYPE, VMLMODE) \ 00141 template< typename DstXprType, typename SrcXprNested> \ 00142 struct Assignment<DstXprType, CwiseUnaryOp<scalar_##EIGENOP##_op<EIGENTYPE>, SrcXprNested>, assign_op<EIGENTYPE>, \ 00143 Dense2Dense, typename enable_if<vml_assign_traits<DstXprType,SrcXprNested>::EnableVml,EIGENTYPE>::type> { \ 00144 typedef CwiseUnaryOp<scalar_##EIGENOP##_op<EIGENTYPE>, SrcXprNested> SrcXprType; \ 00145 static void run(DstXprType &dst, const SrcXprType &src, const assign_op<EIGENTYPE> &/*func*/) { \ 00146 eigen_assert(dst.rows() == src.rows() && dst.cols() == src.cols()); \ 00147 VMLTYPE exponent = reinterpret_cast<const VMLTYPE&>(src.functor().m_exponent); \ 00148 if(vml_assign_traits<DstXprType,SrcXprNested>::Traversal==LinearTraversal) \ 00149 { \ 00150 VMLOP( dst.size(), (const VMLTYPE*)src.nestedExpression().data(), exponent, \ 00151 (VMLTYPE*)dst.data() EIGEN_PP_EXPAND(EIGEN_VMLMODE_EXPAND_##VMLMODE) ); \ 00152 } else { \ 00153 const Index outerSize = dst.outerSize(); \ 00154 for(Index outer = 0; outer < outerSize; ++outer) { \ 00155 const EIGENTYPE *src_ptr = src.IsRowMajor ? &(src.nestedExpression().coeffRef(outer,0)) : \ 00156 &(src.nestedExpression().coeffRef(0, outer)); \ 00157 EIGENTYPE *dst_ptr = dst.IsRowMajor ? &(dst.coeffRef(outer,0)) : &(dst.coeffRef(0, outer)); \ 00158 VMLOP( dst.innerSize(), (const VMLTYPE*)src_ptr, exponent, \ 00159 (VMLTYPE*)dst_ptr EIGEN_PP_EXPAND(EIGEN_VMLMODE_EXPAND_##VMLMODE)); \ 00160 } \ 00161 } \ 00162 } \ 00163 }; 00164 00165 EIGEN_MKL_VML_DECLARE_POW_CALL(pow, vmsPowx, float, float, LA) 00166 EIGEN_MKL_VML_DECLARE_POW_CALL(pow, vmdPowx, double, double, LA) 00167 EIGEN_MKL_VML_DECLARE_POW_CALL(pow, vmcPowx, scomplex, MKL_Complex8, LA) 00168 EIGEN_MKL_VML_DECLARE_POW_CALL(pow, vmzPowx, dcomplex, MKL_Complex16, LA) 00169 00170 } // end namespace internal 00171 00172 } // end namespace Eigen 00173 00174 #endif // EIGEN_ASSIGN_VML_H
