MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2010 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2010) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file CompareQM.hpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_COMPARE_QM_HPP 00033 #define MSQ_COMPARE_QM_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "QualityMetric.hpp" 00037 #include "SimpleStats.hpp" 00038 00039 namespace MBMesquite 00040 { 00041 00042 /**\brief Compare values for two supposedly equivalent quality metrics 00043 * 00044 * Evaluate two different quality metrics during the evaluation, 00045 * comparing the results with each other and passing the results 00046 * of the primary one on to the objective function. 00047 * 00048 * Both metrics must be of the same "type", meaning that they must be 00049 * evaluated at the same sample locations in the mesh. For example, 00050 * an error will be generated if one of the metrics is vertex based 00051 * and one is element based. Further, both metrics must use the 00052 * same handle values to indicate their list of sample locations 00053 * such that the evaluation for a given same handle dependes on the 00054 * same vertices for both metrics. 00055 */ 00056 class CompareQM : public QualityMetric 00057 { 00058 public: 00059 MESQUITE_EXPORT 00060 CompareQM( QualityMetric* primary, QualityMetric* other, const char* primary_name = 0, const char* other_name = 0 ); 00061 00062 MESQUITE_EXPORT 00063 void abort_on_mismatch( double tolerance_factor = 1e-6 ); 00064 00065 MESQUITE_EXPORT 00066 void do_not_abort(); 00067 00068 MESQUITE_EXPORT 00069 bool will_abort_on_mismatch() const; 00070 00071 MESQUITE_EXPORT 00072 void print_stats() const; 00073 00074 MESQUITE_EXPORT virtual ~CompareQM(); 00075 00076 MESQUITE_EXPORT virtual MetricType get_metric_type() const; 00077 00078 MESQUITE_EXPORT virtual std::string get_name() const; 00079 00080 MESQUITE_EXPORT virtual int get_negate_flag() const; 00081 00082 MESQUITE_EXPORT virtual void get_evaluations( PatchData& pd, 00083 std::vector< size_t >& handles, 00084 bool free_vertices_only, 00085 MsqError& err ); 00086 00087 MESQUITE_EXPORT virtual bool evaluate( PatchData& pd, size_t handle, double& value, MsqError& err ); 00088 00089 MESQUITE_EXPORT virtual bool evaluate_with_indices( PatchData& pd, 00090 size_t handle, 00091 double& value, 00092 std::vector< size_t >& indices, 00093 MsqError& err ); 00094 00095 MESQUITE_EXPORT virtual bool evaluate_with_gradient( PatchData& pd, 00096 size_t handle, 00097 double& value, 00098 std::vector< size_t >& indices, 00099 std::vector< Vector3D >& gradient, 00100 MsqError& err ); 00101 00102 MESQUITE_EXPORT virtual bool evaluate_with_Hessian_diagonal( PatchData& pd, 00103 size_t handle, 00104 double& value, 00105 std::vector< size_t >& indices, 00106 std::vector< Vector3D >& gradient, 00107 std::vector< SymMatrix3D >& Hessian_diagonal, 00108 MsqError& err ); 00109 00110 MESQUITE_EXPORT virtual bool evaluate_with_Hessian( PatchData& pd, 00111 size_t handle, 00112 double& value, 00113 std::vector< size_t >& indices, 00114 std::vector< Vector3D >& gradient, 00115 std::vector< Matrix3D >& Hessian, 00116 MsqError& err ); 00117 00118 private: 00119 double epsilon( double val1, double val2 ); 00120 00121 bool check_valid( size_t handle, bool valid1, bool valid2 ); 00122 00123 /** Compare values, add to stats, etc. */ 00124 void check_value( size_t handle, double value1, double value2 ); 00125 00126 /** Check that two index lists are equivalent and return 00127 * in \c map_out for each index in \c idx1 the position 00128 * of the same index in \c idx2. 00129 */ 00130 void check_indices( size_t handle, 00131 const std::vector< size_t >& idx1, 00132 const std::vector< size_t >& idx2, 00133 std::vector< size_t >& map_out, 00134 MsqError& err ); 00135 00136 void check_grad( size_t handle, 00137 const std::vector< size_t >& indices, 00138 const std::vector< size_t >& index_map, 00139 const std::vector< Vector3D >& grad1, 00140 const std::vector< Vector3D >& grad2 ); 00141 00142 void check_hess_diag( size_t handle, 00143 const std::vector< size_t >& indices, 00144 const std::vector< size_t >& index_map, 00145 const std::vector< SymMatrix3D >& hess1, 00146 const std::vector< SymMatrix3D >& hess2 ); 00147 00148 void check_hess( size_t handle, 00149 const std::vector< size_t >& indices, 00150 const std::vector< size_t >& index_map, 00151 const std::vector< Matrix3D >& hess1, 00152 const std::vector< Matrix3D >& hess2 ); 00153 00154 void index_mismatch( size_t handle, 00155 const std::vector< size_t >& idx1, 00156 const std::vector< size_t >& idx2, 00157 MsqError& err ); 00158 00159 struct GradStat 00160 { 00161 SimpleStats x, y, z; 00162 void add( Vector3D grad ); 00163 void add_diff( Vector3D grad1, Vector3D grad2 ); 00164 }; 00165 struct HessStat 00166 { 00167 SimpleStats xx, xy, xz, yy, yz, zz; 00168 void add_diag( Matrix3D hess ); 00169 void add_diag( SymMatrix3D hess ); 00170 void add_diag_diff( Matrix3D hess1, Matrix3D hess2 ); 00171 void add_diag_diff( SymMatrix3D hess1, SymMatrix3D hess2 ); 00172 void add_nondiag( Matrix3D hess ); 00173 void add_nondiag_diff( Matrix3D hess1, Matrix3D hess2 ); 00174 }; 00175 00176 std::string primaryName, otherName; 00177 QualityMetric *primaryMetric, *otherMetric; 00178 bool abortOnMismatch; 00179 double toleranceFactor; 00180 SimpleStats valPrimary, valOther, valDiff; 00181 GradStat gradPrimary, gradOther, gradDiff; 00182 HessStat hessPrimary, hessOther, hessDiff; 00183 }; 00184 00185 } // namespace MBMesquite 00186 00187 #endif
