Classes |
| struct | internal::colamd_col< IndexType > |
| struct | internal::Colamd_Row< IndexType > |
Namespaces |
| namespace | internal |
Defines |
| #define | COLAMD_NDEBUG |
| #define | COLAMD_KNOBS 20 |
| #define | COLAMD_STATS 20 |
| #define | COLAMD_DENSE_ROW 0 |
| #define | COLAMD_DENSE_COL 1 |
| #define | COLAMD_DEFRAG_COUNT 2 |
| #define | COLAMD_STATUS 3 |
| #define | COLAMD_INFO1 4 |
| #define | COLAMD_INFO2 5 |
| #define | COLAMD_INFO3 6 |
| #define | COLAMD_OK (0) |
| #define | COLAMD_OK_BUT_JUMBLED (1) |
| #define | COLAMD_ERROR_A_not_present (-1) |
| #define | COLAMD_ERROR_p_not_present (-2) |
| #define | COLAMD_ERROR_nrow_negative (-3) |
| #define | COLAMD_ERROR_ncol_negative (-4) |
| #define | COLAMD_ERROR_nnz_negative (-5) |
| #define | COLAMD_ERROR_p0_nonzero (-6) |
| #define | COLAMD_ERROR_A_too_small (-7) |
| #define | COLAMD_ERROR_col_length_negative (-8) |
| #define | COLAMD_ERROR_row_index_out_of_bounds (-9) |
| #define | COLAMD_ERROR_out_of_memory (-10) |
| #define | COLAMD_ERROR_internal_error (-999) |
| #define | ONES_COMPLEMENT(r) (-(r)-1) |
| #define | COLAMD_EMPTY (-1) |
| #define | ALIVE (0) |
| #define | DEAD (-1) |
| #define | DEAD_PRINCIPAL (-1) |
| #define | DEAD_NON_PRINCIPAL (-2) |
| #define | ROW_IS_DEAD(r) ROW_IS_MARKED_DEAD (Row[r].shared2.mark) |
| #define | ROW_IS_MARKED_DEAD(row_mark) (row_mark < ALIVE) |
| #define | ROW_IS_ALIVE(r) (Row [r].shared2.mark >= ALIVE) |
| #define | COL_IS_DEAD(c) (Col [c].start < ALIVE) |
| #define | COL_IS_ALIVE(c) (Col [c].start >= ALIVE) |
| #define | COL_IS_DEAD_PRINCIPAL(c) (Col [c].start == DEAD_PRINCIPAL) |
| #define | KILL_ROW(r) { Row [r].shared2.mark = DEAD ; } |
| #define | KILL_PRINCIPAL_COL(c) { Col [c].start = DEAD_PRINCIPAL ; } |
| #define | KILL_NON_PRINCIPAL_COL(c) { Col [c].start = DEAD_NON_PRINCIPAL ; } |
| #define | COLAMD_DEBUG0(params) ; |
| #define | COLAMD_DEBUG1(params) ; |
| #define | COLAMD_DEBUG2(params) ; |
| #define | COLAMD_DEBUG3(params) ; |
| #define | COLAMD_DEBUG4(params) ; |
| #define | COLAMD_ASSERT(expression) ((void) 0) |
Functions |
| template<typename IndexType > |
| IndexType | internal::colamd_c (IndexType n_col) |
| IndexType | internal::colamd_r (IndexType n_row) |
| static IndexType | internal::init_rows_cols (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > col[], IndexType A[], IndexType p[], IndexType stats[COLAMD_STATS]) |
| static void | internal::init_scoring (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType head[], double knobs[COLAMD_KNOBS], IndexType *p_n_row2, IndexType *p_n_col2, IndexType *p_max_deg) |
| static IndexType | internal::find_ordering (IndexType n_row, IndexType n_col, IndexType Alen, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType head[], IndexType n_col2, IndexType max_deg, IndexType pfree) |
| static void | internal::order_children (IndexType n_col, colamd_col< IndexType > Col[], IndexType p[]) |
| static void | internal::detect_super_cols (colamd_col< IndexType > Col[], IndexType A[], IndexType head[], IndexType row_start, IndexType row_length) |
| static IndexType | internal::garbage_collection (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType *pfree) |
| static IndexType | internal::clear_mark (IndexType n_row, Colamd_Row< IndexType > Row[]) |
| IndexType | internal::colamd_recommended (IndexType nnz, IndexType n_row, IndexType n_col) |
| | Returns the recommended value of Alen.
| static void | internal::colamd_set_defaults (double knobs[COLAMD_KNOBS]) |
| | set default parameters The use of this routine is optional.
| static bool | internal::colamd (IndexType n_row, IndexType n_col, IndexType Alen, IndexType *A, IndexType *p, double knobs[COLAMD_KNOBS], IndexType stats[COLAMD_STATS]) |
| | Computes a column ordering using the column approximate minimum degree ordering.
