MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 #include "FileTokenizer.hpp" 00002 #include "MsqError.hpp" 00003 #include "cppunit/extensions/HelperMacros.h" 00004 #include <cassert> 00005 00006 #include <iostream> 00007 using std::cout; 00008 00009 #include <cstring> 00010 #include <cstdlib> 00011 #include <cstdio> 00012 #ifdef WIN32 00013 #include <string> 00014 #include <direct.h> 00015 #endif 00016 00017 using MBMesquite::FileTokenizer; 00018 using MBMesquite::MsqPrintError; 00019 00020 extern const char* const tokens[] = { "foo", "bar", "0", "123abc", "123", "0x5", "1e200", "jason", "abc123", "1.0", 0 }; 00021 extern const char* const spaces[] = { " ", " \n ", "\n\n\n ", "\t", "\t\t", " ", "\n", " ", "\t\n", 0 }; 00022 00023 extern const bool doubles[] = { false, false, true, false, true, false, true, false, false, true }; 00024 extern const bool longs[] = { false, false, true, false, true, true, false, false, false, false }; 00025 extern const bool booleans[] = { false, false, true, false, false, false, false, false, false, false }; 00026 00027 class FileTokenizerTest : public CppUnit::TestFixture 00028 { 00029 private: 00030 CPPUNIT_TEST_SUITE( FileTokenizerTest ); 00031 CPPUNIT_TEST( token_test ); 00032 CPPUNIT_TEST( line_number_test ); 00033 CPPUNIT_TEST( newline_test ); 00034 CPPUNIT_TEST( match_one_test ); 00035 CPPUNIT_TEST( match_multiple_test ); 00036 CPPUNIT_TEST( double_test ); 00037 CPPUNIT_TEST( long_test ); 00038 CPPUNIT_TEST( boolean_test ); 00039 CPPUNIT_TEST( unget_test ); 00040 CPPUNIT_TEST_SUITE_END(); 00041 00042 public: 00043 FileTokenizerTest() {} 00044 00045 void setUp() {} 00046 00047 void tearDown() {} 00048 00049 FILE* make_file() 00050 { 00051 #ifdef WIN32 00052 char name1[L_tmpnam_s]; 00053 errno_t err = tmpnam_s( name1, L_tmpnam_s ); 00054 00055 // Get the current working directory: 00056 char* buffer; 00057 buffer = _getcwd( NULL, 0 ); 00058 std::string full_path( buffer ); 00059 std::string temp_name( name1 ); 00060 full_path = full_path + temp_name; 00061 FILE* file = fopen( full_path.c_str(), "w+" ); 00062 #else 00063 FILE* file = tmpfile(); 00064 #endif 00065 00066 CPPUNIT_ASSERT( !!file ); 00067 const char* const* t_iter = tokens; 00068 const char* const* s_iter = spaces; 00069 fputs( *t_iter, file ); 00070 ++t_iter; 00071 while( *t_iter ) 00072 { 00073 fputs( *s_iter, file ); 00074 ++s_iter; 00075 fputs( *t_iter, file ); 00076 ++t_iter; 00077 } 00078 rewind( file ); 00079 return file; 00080 } 00081 00082 void token_test() 00083 { 00084 MsqPrintError err( cout ); 00085 const char* token; 00086 00087 FileTokenizer ft( make_file() ); 00088 00089 for( const char* const* t_iter = tokens; *t_iter; ++t_iter ) 00090 { 00091 token = ft.get_string( err ); 00092 CPPUNIT_ASSERT( token ); 00093 CPPUNIT_ASSERT( !err ); 00094 CPPUNIT_ASSERT( !strcmp( *t_iter, token ) ); 00095 } 00096 00097 token = ft.get_string( err ); 00098 CPPUNIT_ASSERT( !token ); 00099 CPPUNIT_ASSERT( ft.eof() ); 00100 err.clear(); 00101 } 00102 00103 static int count_newlines( const char* str ) 00104 { 00105 int result = 0; 00106 for( ; *str; ++str ) 00107 if( *str == '\n' ) ++result; 00108 return result; 00109 } 00110 00111 void line_number_test() 00112 { 00113 MsqPrintError err( cout ); 00114 const char* token; 00115 00116 FileTokenizer ft( make_file() ); 00117 00118 int lineno = 1; 00119 token = ft.get_string( err ); 00120 CPPUNIT_ASSERT( token ); 00121 CPPUNIT_ASSERT( !err ); 00122 00123 for( const char* const* s_iter = spaces; *s_iter; ++s_iter ) 00124 { 00125 token = ft.get_string( err ); 00126 CPPUNIT_ASSERT( token ); 00127 CPPUNIT_ASSERT( !err ); 00128 00129 lineno += count_newlines( *s_iter ); 00130 CPPUNIT_ASSERT( ft.line_number() == lineno ); 00131 } 00132 } 00133 00134 void newline_test() 00135 { 00136 MsqPrintError err( cout ); 00137 const char* token; 00138 00139 FileTokenizer ft( make_file() ); 00140 00141 token = ft.get_string( err ); 00142 CPPUNIT_ASSERT( token ); 00143 CPPUNIT_ASSERT( !err ); 00144 00145 for( const char* const* s_iter = spaces; *s_iter; ++s_iter ) 00146 { 00147 int count = count_newlines( *s_iter ); 00148 bool b; 00149 while( count-- ) 00150 { 00151 b = ft.get_newline( err ); 00152 CPPUNIT_ASSERT( b && !err ); 00153 } 00154 00155 b = ft.get_newline( err ); 00156 CPPUNIT_ASSERT( !b && err ); 00157 err.clear(); 00158 00159 token = ft.get_string( err ); 00160 CPPUNIT_ASSERT( token ); 00161 CPPUNIT_ASSERT( !err ); 00162 } 00163 } 00164 00165 void match_one_test() 00166 { 00167 MsqPrintError err( cout ); 00168 const char* const* t_iter; 00169 bool b; 00170 00171 FileTokenizer ft( make_file() ); 00172 00173 for( t_iter = tokens; *t_iter; ++t_iter ) 00174 { 00175 b = ft.match_token( *t_iter, err ); 00176 CPPUNIT_ASSERT( b && !err ); 00177 } 00178 00179 FileTokenizer ft2( make_file() ); 00180 00181 b = ft2.match_token( "", err ); 00182 CPPUNIT_ASSERT( !b && err ); 00183 err.clear(); 00184 00185 b = ft2.match_token( "Mesquite", err ); 00186 CPPUNIT_ASSERT( !b && err ); 00187 err.clear(); 00188 } 00189 00190 void match_multiple_test() 00191 { 00192 MsqPrintError err( cout ); 00193 const char* const* t_iter = tokens; 00194 00195 FileTokenizer ft( make_file() ); 00196 00197 int result; 00198 const char* const test1[] = { *t_iter, "Mesquite", "x", 0 }; 00199 result = ft.match_token( test1, err ); 00200 CPPUNIT_ASSERT( result == 1 && !err ); 00201 ++t_iter; 00202 00203 const char* const test2[] = { "x", "y", *t_iter, 0 }; 00204 result = ft.match_token( test2, err ); 00205 CPPUNIT_ASSERT( result == 3 && !err ); 00206 ++t_iter; 00207 00208 const char* const test3[] = { *t_iter, 0 }; 00209 result = ft.match_token( test3, err ); 00210 CPPUNIT_ASSERT( result == 1 && !err ); 00211 ++t_iter; 00212 00213 const char* const test4[] = { "Mesquite", "Mesh", 0 }; 00214 result = ft.match_token( test4, err ); 00215 CPPUNIT_ASSERT( result == 0 && err ); 00216 err.clear(); 00217 ++t_iter; 00218 } 00219 00220 void double_test() 00221 { 00222 MsqPrintError err( cout ); 00223 FileTokenizer ft( make_file() ); 00224 00225 for( int i = 0; tokens[i]; ++i ) 00226 { 00227 double value; 00228 ft.get_doubles( 1, &value, err ); 00229 if( doubles[i] ) 00230 { 00231 CPPUNIT_ASSERT( !err ); 00232 CPPUNIT_ASSERT( value == strtod( tokens[i], 0 ) ); 00233 } 00234 else 00235 { 00236 CPPUNIT_ASSERT( err ); 00237 err.clear(); 00238 } 00239 } 00240 } 00241 00242 void long_test() 00243 { 00244 MsqPrintError err( cout ); 00245 FileTokenizer ft( make_file() ); 00246 00247 for( int i = 0; tokens[i]; ++i ) 00248 { 00249 long value; 00250 ft.get_long_ints( 1, &value, err ); 00251 if( longs[i] ) 00252 { 00253 CPPUNIT_ASSERT( !err ); 00254 CPPUNIT_ASSERT( value == strtol( tokens[i], 0, 0 ) ); 00255 } 00256 else 00257 { 00258 CPPUNIT_ASSERT( err ); 00259 err.clear(); 00260 } 00261 } 00262 } 00263 00264 void boolean_test() 00265 { 00266 MsqPrintError err( cout ); 00267 FileTokenizer ft( make_file() ); 00268 00269 for( int i = 0; tokens[i]; ++i ) 00270 { 00271 bool value; 00272 ft.get_booleans( 1, &value, err ); 00273 if( booleans[i] ) 00274 { 00275 CPPUNIT_ASSERT( !err ); 00276 CPPUNIT_ASSERT( value == !!atoi( tokens[i] ) ); 00277 } 00278 else 00279 { 00280 CPPUNIT_ASSERT( err ); 00281 err.clear(); 00282 } 00283 } 00284 } 00285 00286 void unget_test() 00287 { 00288 MsqPrintError err( cout ); 00289 FileTokenizer ft( make_file() ); 00290 00291 const char* const* t_iter = tokens; 00292 const char* token = ft.get_string( err ); 00293 CPPUNIT_ASSERT( !err ); 00294 CPPUNIT_ASSERT( !strcmp( token, *t_iter ) ); 00295 00296 ft.unget_token(); 00297 token = ft.get_string( err ); 00298 CPPUNIT_ASSERT( !err ); 00299 CPPUNIT_ASSERT( !strcmp( token, *t_iter ) ); 00300 00301 ++t_iter; 00302 token = ft.get_string( err ); 00303 CPPUNIT_ASSERT( !err ); 00304 CPPUNIT_ASSERT( !strcmp( token, *t_iter ) ); 00305 00306 ++t_iter; 00307 token = ft.get_string( err ); 00308 CPPUNIT_ASSERT( !err ); 00309 CPPUNIT_ASSERT( !strcmp( token, *t_iter ) ); 00310 00311 ft.unget_token(); 00312 token = ft.get_string( err ); 00313 CPPUNIT_ASSERT( !err ); 00314 CPPUNIT_ASSERT( !strcmp( token, *t_iter ) ); 00315 } 00316 }; 00317 00318 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( FileTokenizerTest, "FileTokenizerTest" ); 00319 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( FileTokenizerTest, "Unit" );
