MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "FileTokenizer.hpp"
#include "MsqError.hpp"
#include "cppunit/extensions/HelperMacros.h"
#include <cassert>
#include <iostream>
#include <cstring>
#include <cstdlib>
#include <cstdio>
Classes | |
class | FileTokenizerTest |
Functions | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (FileTokenizerTest,"FileTokenizerTest") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (FileTokenizerTest,"Unit") | |
Variables | |
const char *const | tokens [] = { "foo", "bar", "0", "123abc", "123", "0x5", "1e200", "jason", "abc123", "1.0", 0 } |
const char *const | spaces [] = { " ", " \n ", "\n\n\n ", "\t", "\t\t", " ", "\n", " ", "\t\n", 0 } |
const bool | doubles [] = { false, false, true, false, true, false, true, false, false, true } |
const bool | longs [] = { false, false, true, false, true, true, false, false, false, false } |
const bool | booleans [] = { false, false, true, false, false, false, false, false, false, false } |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | FileTokenizerTest | , |
"FileTokenizerTest" | |||
"Unit" | |||
const bool booleans[] = { false, false, true, false, false, false, false, false, false, false } |
Referenced by FileTokenizerTest::boolean_test().
const bool doubles[] = { false, false, true, false, true, false, true, false, false, true } |
const bool longs[] = { false, false, true, false, true, true, false, false, false, false } |
Referenced by FileTokenizerTest::long_test().
const char* const tokens[] = { "foo", "bar", "0", "123abc", "123", "0x5", "1e200", "jason", "abc123", "1.0", 0 } |
Referenced by moab::ReadSTL::ascii_read_triangles(), FileTokenizerTest::boolean_test(), FileTokenizerTest::double_test(), moab::ReadRTT::get_cell_data(), moab::ReadRTT::get_facet_data(), moab::ReadABAQUS::get_keyword(), moab::ReadRTT::get_node_data(), moab::ReadRTT::get_side_data(), moab::ReadRTT::get_tet_data(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadNASTRAN::load_file(), moab::ReadOBJ::load_file(), FileTokenizerTest::long_test(), FileTokenizerTest::make_file(), FileTokenizerTest::match_multiple_test(), FileTokenizerTest::match_one_test(), moab::ReadABAQUS::read_assembly(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadABAQUS::read_instance(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadABAQUS::read_part(), moab::ReadABAQUS::read_solid_section(), MBMesquite::MeshImpl::read_vtk(), ReadTriangleOutput(), moab::ReadRTT::split_string(), summarize_cell_volume_change(), FileTokenizerTest::token_test(), FileTokenizerTest::unget_test(), and moab::ReadNCDF::update().
