MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008-2009 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_GENERAL_BLOCK_PANEL_H 00011 #define EIGEN_GENERAL_BLOCK_PANEL_H 00012 00013 00014 namespace Eigen { 00015 00016 namespace internal { 00017 00018 template<typename _LhsScalar, typename _RhsScalar, bool _ConjLhs=false, bool _ConjRhs=false> 00019 class gebp_traits; 00020 00021 00023 inline std::ptrdiff_t manage_caching_sizes_helper(std::ptrdiff_t a, std::ptrdiff_t b) 00024 { 00025 return a<=0 ? b : a; 00026 } 00027 00028 #if EIGEN_ARCH_i386_OR_x86_64 00029 const std::ptrdiff_t defaultL1CacheSize = 32*1024; 00030 const std::ptrdiff_t defaultL2CacheSize = 256*1024; 00031 const std::ptrdiff_t defaultL3CacheSize = 2*1024*1024; 00032 #else 00033 const std::ptrdiff_t defaultL1CacheSize = 16*1024; 00034 const std::ptrdiff_t defaultL2CacheSize = 512*1024; 00035 const std::ptrdiff_t defaultL3CacheSize = 512*1024; 00036 #endif 00037 00039 struct CacheSizes { 00040 CacheSizes(): m_l1(-1),m_l2(-1),m_l3(-1) { 00041 int l1CacheSize, l2CacheSize, l3CacheSize; 00042 queryCacheSizes(l1CacheSize, l2CacheSize, l3CacheSize); 00043 m_l1 = manage_caching_sizes_helper(l1CacheSize, defaultL1CacheSize); 00044 m_l2 = manage_caching_sizes_helper(l2CacheSize, defaultL2CacheSize); 00045 m_l3 = manage_caching_sizes_helper(l3CacheSize, defaultL3CacheSize); 00046 } 00047 00048 std::ptrdiff_t m_l1; 00049 std::ptrdiff_t m_l2; 00050 std::ptrdiff_t m_l3; 00051 }; 00052 00053 00055 inline void manage_caching_sizes(Action action, std::ptrdiff_t* l1, std::ptrdiff_t* l2, std::ptrdiff_t* l3) 00056 { 00057 static CacheSizes m_cacheSizes; 00058 00059 if(action==SetAction) 00060 { 00061 // set the cpu cache size and cache all block sizes from a global cache size in byte 00062 eigen_internal_assert(l1!=0 && l2!=0); 00063 m_cacheSizes.m_l1 = *l1; 00064 m_cacheSizes.m_l2 = *l2; 00065 m_cacheSizes.m_l3 = *l3; 00066 } 00067 else if(action==GetAction) 00068 { 00069 eigen_internal_assert(l1!=0 && l2!=0); 00070 *l1 = m_cacheSizes.m_l1; 00071 *l2 = m_cacheSizes.m_l2; 00072 *l3 = m_cacheSizes.m_l3; 00073 } 00074 else 00075 { 00076 eigen_internal_assert(false); 00077 } 00078 } 00079 00080 /* Helper for computeProductBlockingSizes. 00081 * 00082 * Given a m x k times k x n matrix product of scalar types \c LhsScalar and \c RhsScalar, 00083 * this function computes the blocking size parameters along the respective dimensions 00084 * for matrix products and related algorithms. The blocking sizes depends on various 00085 * parameters: 00086 * - the L1 and L2 cache sizes, 00087 * - the register level blocking sizes defined by gebp_traits, 00088 * - the number of scalars that fit into a packet (when vectorization is enabled). 00089 * 00090 * \sa setCpuCacheSizes */ 00091 00092 template<typename LhsScalar, typename RhsScalar, int KcFactor> 00093 void evaluateProductBlockingSizesHeuristic(Index& k, Index& m, Index& n, Index num_threads = 1) 00094 { 00095 typedef gebp_traits<LhsScalar,RhsScalar> Traits; 00096 00097 // Explanations: 00098 // Let's recall that the product algorithms form mc x kc vertical panels A' on the lhs and 00099 // kc x nc blocks B' on the rhs. B' has to fit into L2/L3 cache. Moreover, A' is processed 00100 // per mr x kc horizontal small panels where mr is the blocking size along the m dimension 00101 // at the register level. This small horizontal panel has to stay within L1 cache. 00102 std::ptrdiff_t l1, l2, l3; 00103 manage_caching_sizes(GetAction, &l1, &l2, &l3); 00104 00105 if (num_threads > 1) { 00106 typedef typename Traits::ResScalar ResScalar; 00107 enum { 00108 kdiv = KcFactor * (Traits::mr * sizeof(LhsScalar) + Traits::nr * sizeof(RhsScalar)), 00109 ksub = Traits::mr * Traits::nr * sizeof(ResScalar), 00110 k_mask = -8, 00111 00112 mr = Traits::mr, 00113 mr_mask = -mr, 00114 00115 nr = Traits::nr, 00116 nr_mask = -nr 00117 }; 00118 // Increasing k gives us more time to prefetch the content of the "C" 00119 // registers. However once the latency is hidden there is no point in 00120 // increasing the value of k, so we'll cap it at 320 (value determined 00121 // experimentally). 00122 const Index k_cache = (std::min<Index>)((l1-ksub)/kdiv, 320); 00123 if (k_cache < k) { 00124 k = k_cache & k_mask; 00125 eigen_internal_assert(k > 0); 00126 } 00127 00128 const Index n_cache = (l2-l1) / (nr * sizeof(RhsScalar) * k); 00129 const Index n_per_thread = numext::div_ceil(n, num_threads); 00130 if (n_cache <= n_per_thread) { 00131 // Don't exceed the capacity of the l2 cache. 00132 eigen_internal_assert(n_cache >= static_cast<Index>(nr)); 00133 n = n_cache & nr_mask; 00134 eigen_internal_assert(n > 0); 00135 } else { 00136 n = (std::min<Index>)(n, (n_per_thread + nr - 1) & nr_mask); 00137 } 00138 00139 if (l3 > l2) { 00140 // l3 is shared between all cores, so we'll give each thread its own chunk of l3. 00141 const Index m_cache = (l3-l2) / (sizeof(LhsScalar) * k * num_threads); 00142 const Index m_per_thread = numext::div_ceil(m, num_threads); 00143 if(m_cache < m_per_thread && m_cache >= static_cast<Index>(mr)) { 00144 m = m_cache & mr_mask; 00145 eigen_internal_assert(m > 0); 00146 } else { 00147 m = (std::min<Index>)(m, (m_per_thread + mr - 1) & mr_mask); 00148 } 00149 } 00150 } 00151 else { 00152 // In unit tests we do not want to use extra large matrices, 00153 // so we reduce the cache size to check the blocking strategy is not flawed 00154 #ifdef EIGEN_DEBUG_SMALL_PRODUCT_BLOCKS 00155 l1 = 9*1024; 00156 l2 = 32*1024; 00157 l3 = 512*1024; 00158 #endif 00159 00160 // Early return for small problems because the computation below are time consuming for small problems. 00161 // Perhaps it would make more sense to consider k*n*m?? 00162 // Note that for very tiny problem, this function should be bypassed anyway 00163 // because we use the coefficient-based implementation for them. 00164 if((std::max)(k,(std::max)(m,n))<48) 00165 return; 00166 00167 typedef typename Traits::ResScalar ResScalar; 00168 enum { 00169 k_peeling = 8, 00170 k_div = KcFactor * (Traits::mr * sizeof(LhsScalar) + Traits::nr * sizeof(RhsScalar)), 00171 k_sub = Traits::mr * Traits::nr * sizeof(ResScalar) 00172 }; 00173 00174 // ---- 1st level of blocking on L1, yields kc ---- 00175 00176 // Blocking on the third dimension (i.e., k) is chosen so that an horizontal panel 00177 // of size mr x kc of the lhs plus a vertical panel of kc x nr of the rhs both fits within L1 cache. 00178 // We also include a register-level block of the result (mx x nr). 00179 // (In an ideal world only the lhs panel would stay in L1) 00180 // Moreover, kc has to be a multiple of 8 to be compatible with loop peeling, leading to a maximum blocking size of: 00181 const Index max_kc = std::max<Index>(((l1-k_sub)/k_div) & (~(k_peeling-1)),1); 00182 const Index old_k = k; 00183 if(k>max_kc) 00184 { 00185 // We are really blocking on the third dimension: 00186 // -> reduce blocking size to make sure the last block is as large as possible 00187 // while keeping the same number of sweeps over the result. 00188 k = (k%max_kc)==0 ? max_kc 00189 : max_kc - k_peeling * ((max_kc-1-(k%max_kc))/(k_peeling*(k/max_kc+1))); 00190 00191 eigen_internal_assert(((old_k/k) == (old_k/max_kc)) && "the number of sweeps has to remain the same"); 00192 } 00193 00194 // ---- 2nd level of blocking on max(L2,L3), yields nc ---- 00195 00196 // TODO find a reliable way to get the actual amount of cache per core to use for 2nd level blocking, that is: 00197 // actual_l2 = max(l2, l3/nb_core_sharing_l3) 00198 // The number below is quite conservative: it is better to underestimate the cache size rather than overestimating it) 00199 // For instance, it corresponds to 6MB of L3 shared among 4 cores. 00200 #ifdef EIGEN_DEBUG_SMALL_PRODUCT_BLOCKS 00201 const Index actual_l2 = l3; 00202 #else 00203 const Index actual_l2 = 1572864; // == 1.5 MB 00204 #endif 00205 00206 // Here, nc is chosen such that a block of kc x nc of the rhs fit within half of L2. 00207 // The second half is implicitly reserved to access the result and lhs coefficients. 00208 // When k<max_kc, then nc can arbitrarily growth. In practice, it seems to be fruitful 00209 // to limit this growth: we bound nc to growth by a factor x1.5. 00210 // However, if the entire lhs block fit within L1, then we are not going to block on the rows at all, 00211 // and it becomes fruitful to keep the packed rhs blocks in L1 if there is enough remaining space. 00212 Index max_nc; 00213 const Index lhs_bytes = m * k * sizeof(LhsScalar); 00214 const Index remaining_l1 = l1- k_sub - lhs_bytes; 00215 if(remaining_l1 >= Index(Traits::nr*sizeof(RhsScalar))*k) 00216 { 00217 // L1 blocking 00218 max_nc = remaining_l1 / (k*sizeof(RhsScalar)); 00219 } 00220 else 00221 { 00222 // L2 blocking 00223 max_nc = (3*actual_l2)/(2*2*max_kc*sizeof(RhsScalar)); 00224 } 00225 // WARNING Below, we assume that Traits::nr is a power of two. 00226 Index nc = std::min<Index>(actual_l2/(2*k*sizeof(RhsScalar)), max_nc) & (~(Traits::nr-1)); 00227 if(n>nc) 00228 { 00229 // We are really blocking over the columns: 00230 // -> reduce blocking size to make sure the last block is as large as possible 00231 // while keeping the same number of sweeps over the packed lhs. 00232 // Here we allow one more sweep if this gives us a perfect match, thus the commented "-1" 00233 n = (n%nc)==0 ? nc 00234 : (nc - Traits::nr * ((nc/*-1*/-(n%nc))/(Traits::nr*(n/nc+1)))); 00235 } 00236 else if(old_k==k) 00237 { 00238 // So far, no blocking at all, i.e., kc==k, and nc==n. 00239 // In this case, let's perform a blocking over the rows such that the packed lhs data is kept in cache L1/L2 00240 // TODO: part of this blocking strategy is now implemented within the kernel itself, so the L1-based heuristic here should be obsolete. 00241 Index problem_size = k*n*sizeof(LhsScalar); 00242 Index actual_lm = actual_l2; 00243 Index max_mc = m; 00244 if(problem_size<=1024) 00245 { 00246 // problem is small enough to keep in L1 00247 // Let's choose m such that lhs's block fit in 1/3 of L1 00248 actual_lm = l1; 00249 } 00250 else if(l3!=0 && problem_size<=32768) 00251 { 00252 // we have both L2 and L3, and problem is small enough to be kept in L2 00253 // Let's choose m such that lhs's block fit in 1/3 of L2 00254 actual_lm = l2; 00255 max_mc = (std::min<Index>)(576,max_mc); 00256 } 00257 Index mc = (std::min<Index>)(actual_lm/(3*k*sizeof(LhsScalar)), max_mc); 00258 if (mc > Traits::mr) mc -= mc % Traits::mr; 00259 else if (mc==0) return; 00260 m = (m%mc)==0 ? mc 00261 : (mc - Traits::mr * ((mc/*-1*/-(m%mc))/(Traits::mr*(m/mc+1)))); 00262 } 00263 } 00264 } 00265 00266 inline bool useSpecificBlockingSizes(Index& k, Index& m, Index& n) 00267 { 00268 #ifdef EIGEN_TEST_SPECIFIC_BLOCKING_SIZES 00269 if (EIGEN_TEST_SPECIFIC_BLOCKING_SIZES) { 00270 k = std::min<Index>(k, EIGEN_TEST_SPECIFIC_BLOCKING_SIZE_K); 00271 m = std::min<Index>(m, EIGEN_TEST_SPECIFIC_BLOCKING_SIZE_M); 00272 n = std::min<Index>(n, EIGEN_TEST_SPECIFIC_BLOCKING_SIZE_N); 00273 return true; 00274 } 00275 #else 00276 EIGEN_UNUSED_VARIABLE(k) 00277 EIGEN_UNUSED_VARIABLE(m) 00278 EIGEN_UNUSED_VARIABLE(n) 00279 #endif 00280 return false; 00281 } 00282 00299 template<typename LhsScalar, typename RhsScalar, int KcFactor> 00300 void computeProductBlockingSizes(Index& k, Index& m, Index& n, Index num_threads = 1) 00301 { 00302 if (!useSpecificBlockingSizes(k, m, n)) { 00303 evaluateProductBlockingSizesHeuristic<LhsScalar, RhsScalar, KcFactor>(k, m, n, num_threads); 00304 } 00305 00306 typedef gebp_traits<LhsScalar,RhsScalar> Traits; 00307 enum { 00308 kr = 8, 00309 mr = Traits::mr, 00310 nr = Traits::nr 00311 }; 00312 if (k > kr) k -= k % kr; 00313 if (m > mr) m -= m % mr; 00314 if (n > nr) n -= n % nr; 00315 } 00316 00317 template<typename LhsScalar, typename RhsScalar> 00318 inline void computeProductBlockingSizes(Index& k, Index& m, Index& n, Index num_threads = 1) 00319 { 00320 computeProductBlockingSizes<LhsScalar,RhsScalar,1>(k, m, n, num_threads); 00321 } 00322 00323 #ifdef EIGEN_HAS_SINGLE_INSTRUCTION_CJMADD 00324 #define CJMADD(CJ,A,B,C,T) C = CJ.pmadd(A,B,C); 00325 #else 00326 00327 // FIXME (a bit overkill maybe ?) 00328 00329 template<typename CJ, typename A, typename B, typename C, typename T> struct gebp_madd_selector { 00330 EIGEN_ALWAYS_INLINE static void run(const CJ& cj, A& a, B& b, C& c, T& /*t*/) 00331 { 00332 c = cj.pmadd(a,b,c); 00333 } 00334 }; 00335 00336 template<typename CJ, typename T> struct gebp_madd_selector<CJ,T,T,T,T> { 00337 EIGEN_ALWAYS_INLINE static void run(const CJ& cj, T& a, T& b, T& c, T& t) 00338 { 00339 t = b; t = cj.pmul(a,t); c = padd(c,t); 00340 } 00341 }; 00342 00343 template<typename CJ, typename A, typename B, typename C, typename T> 00344 EIGEN_STRONG_INLINE void gebp_madd(const CJ& cj, A& a, B& b, C& c, T& t) 00345 { 00346 gebp_madd_selector<CJ,A,B,C,T>::run(cj,a,b,c,t); 00347 } 00348 00349 #define CJMADD(CJ,A,B,C,T) gebp_madd(CJ,A,B,C,T); 00350 // #define CJMADD(CJ,A,B,C,T) T = B; T = CJ.pmul(A,T); C = padd(C,T); 00351 #endif 00352 00353 /* Vectorization logic 00354 * real*real: unpack rhs to constant packets, ... 00355 * 00356 * cd*cd : unpack rhs to (b_r,b_r), (b_i,b_i), mul to get (a_r b_r,a_i b_r) (a_r b_i,a_i b_i), 00357 * storing each res packet into two packets (2x2), 00358 * at the end combine them: swap the second and addsub them 00359 * cf*cf : same but with 2x4 blocks 00360 * cplx*real : unpack rhs to constant packets, ... 00361 * real*cplx : load lhs as (a0,a0,a1,a1), and mul as usual 00362 */ 00363 template<typename _LhsScalar, typename _RhsScalar, bool _ConjLhs, bool _ConjRhs> 00364 class gebp_traits 00365 { 00366 public: 00367 typedef _LhsScalar LhsScalar; 00368 typedef _RhsScalar RhsScalar; 00369 typedef typename scalar_product_traits<LhsScalar, RhsScalar>::ReturnType ResScalar; 00370 00371 enum { 00372 ConjLhs = _ConjLhs, 00373 ConjRhs = _ConjRhs, 00374 Vectorizable = packet_traits<LhsScalar>::Vectorizable && packet_traits<RhsScalar>::Vectorizable, 00375 LhsPacketSize = Vectorizable ? packet_traits<LhsScalar>::size : 1, 00376 RhsPacketSize = Vectorizable ? packet_traits<RhsScalar>::size : 1, 00377 ResPacketSize = Vectorizable ? packet_traits<ResScalar>::size : 1, 00378 00379 NumberOfRegisters = EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS, 00380 00381 // register block size along the N direction must be 1 or 4 00382 nr = 4, 00383 00384 // register block size along the M direction (currently, this one cannot be modified) 00385 default_mr = (EIGEN_PLAIN_ENUM_MIN(16,NumberOfRegisters)/2/nr)*LhsPacketSize, 00386 #if defined(EIGEN_HAS_SINGLE_INSTRUCTION_MADD) && !defined(EIGEN_VECTORIZE_ALTIVEC) && !defined(EIGEN_VECTORIZE_VSX) 00387 // we assume 16 registers 00388 // See bug 992, if the scalar type is not vectorizable but that EIGEN_HAS_SINGLE_INSTRUCTION_MADD is defined, 00389 // then using 3*LhsPacketSize triggers non-implemented paths in syrk. 00390 mr = Vectorizable ? 3*LhsPacketSize : default_mr, 00391 #else 00392 mr = default_mr, 00393 #endif 00394 00395 LhsProgress = LhsPacketSize, 00396 RhsProgress = 1 00397 }; 00398 00399 typedef typename packet_traits<LhsScalar>::type _LhsPacket; 00400 typedef typename packet_traits<RhsScalar>::type _RhsPacket; 00401 typedef typename packet_traits<ResScalar>::type _ResPacket; 00402 00403 typedef typename conditional<Vectorizable,_LhsPacket,LhsScalar>::type LhsPacket; 00404 typedef typename conditional<Vectorizable,_RhsPacket,RhsScalar>::type RhsPacket; 00405 typedef typename conditional<Vectorizable,_ResPacket,ResScalar>::type ResPacket; 00406 00407 typedef ResPacket AccPacket; 00408 00409 EIGEN_STRONG_INLINE void initAcc(AccPacket& p) 00410 { 00411 p = pset1<ResPacket>(ResScalar(0)); 00412 } 00413 00414 EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1, RhsPacket& b2, RhsPacket& b3) 00415 { 00416 pbroadcast4(b, b0, b1, b2, b3); 00417 } 00418 00419 // EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1) 00420 // { 00421 // pbroadcast2(b, b0, b1); 00422 // } 00423 00424 template<typename RhsPacketType> 00425 EIGEN_STRONG_INLINE void loadRhs(const RhsScalar* b, RhsPacketType& dest) const 00426 { 00427 dest = pset1<RhsPacketType>(*b); 00428 } 00429 00430 EIGEN_STRONG_INLINE void loadRhsQuad(const RhsScalar* b, RhsPacket& dest) const 00431 { 00432 dest = ploadquad<RhsPacket>(b); 00433 } 00434 00435 template<typename LhsPacketType> 00436 EIGEN_STRONG_INLINE void loadLhs(const LhsScalar* a, LhsPacketType& dest) const 00437 { 00438 dest = pload<LhsPacketType>(a); 00439 } 00440 00441 template<typename LhsPacketType> 00442 EIGEN_STRONG_INLINE void loadLhsUnaligned(const LhsScalar* a, LhsPacketType& dest) const 00443 { 00444 dest = ploadu<LhsPacketType>(a); 00445 } 00446 00447 template<typename LhsPacketType, typename RhsPacketType, typename AccPacketType> 00448 EIGEN_STRONG_INLINE void madd(const LhsPacketType& a, const RhsPacketType& b, AccPacketType& c, AccPacketType& tmp) const 00449 { 00450 // It would be a lot cleaner to call pmadd all the time. Unfortunately if we 00451 // let gcc allocate the register in which to store the result of the pmul 00452 // (in the case where there is no FMA) gcc fails to figure out how to avoid 00453 // spilling register. 00454 #ifdef EIGEN_HAS_SINGLE_INSTRUCTION_MADD 00455 EIGEN_UNUSED_VARIABLE(tmp); 00456 c = pmadd(a,b,c); 00457 #else 00458 tmp = b; tmp = pmul(a,tmp); c = padd(c,tmp); 00459 #endif 00460 } 00461 00462 EIGEN_STRONG_INLINE void acc(const AccPacket& c, const ResPacket& alpha, ResPacket& r) const 00463 { 00464 r = pmadd(c,alpha,r); 00465 } 00466 00467 template<typename ResPacketHalf> 00468 EIGEN_STRONG_INLINE void acc(const ResPacketHalf& c, const ResPacketHalf& alpha, ResPacketHalf& r) const 00469 { 00470 r = pmadd(c,alpha,r); 00471 } 00472 00473 protected: 00474 // conj_helper<LhsScalar,RhsScalar,ConjLhs,ConjRhs> cj; 00475 // conj_helper<LhsPacket,RhsPacket,ConjLhs,ConjRhs> pcj; 00476 }; 00477 00478 template<typename RealScalar, bool _ConjLhs> 00479 class gebp_traits<std::complex<RealScalar>, RealScalar, _ConjLhs, false> 00480 { 00481 public: 00482 typedef std::complex<RealScalar> LhsScalar; 00483 typedef RealScalar RhsScalar; 00484 typedef typename scalar_product_traits<LhsScalar, RhsScalar>::ReturnType ResScalar; 00485 00486 enum { 00487 ConjLhs = _ConjLhs, 00488 ConjRhs = false, 00489 Vectorizable = packet_traits<LhsScalar>::Vectorizable && packet_traits<RhsScalar>::Vectorizable, 00490 LhsPacketSize = Vectorizable ? packet_traits<LhsScalar>::size : 1, 00491 RhsPacketSize = Vectorizable ? packet_traits<RhsScalar>::size : 1, 00492 ResPacketSize = Vectorizable ? packet_traits<ResScalar>::size : 1, 00493 00494 NumberOfRegisters = EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS, 00495 nr = 4, 00496 #if defined(EIGEN_HAS_SINGLE_INSTRUCTION_MADD) && !defined(EIGEN_VECTORIZE_ALTIVEC) && !defined(EIGEN_VECTORIZE_VSX) 00497 // we assume 16 registers 00498 mr = 3*LhsPacketSize, 00499 #else 00500 mr = (EIGEN_PLAIN_ENUM_MIN(16,NumberOfRegisters)/2/nr)*LhsPacketSize, 00501 #endif 00502 00503 LhsProgress = LhsPacketSize, 00504 RhsProgress = 1 00505 }; 00506 00507 typedef typename packet_traits<LhsScalar>::type _LhsPacket; 00508 typedef typename packet_traits<RhsScalar>::type _RhsPacket; 00509 typedef typename packet_traits<ResScalar>::type _ResPacket; 00510 00511 typedef typename conditional<Vectorizable,_LhsPacket,LhsScalar>::type LhsPacket; 00512 typedef typename conditional<Vectorizable,_RhsPacket,RhsScalar>::type RhsPacket; 00513 typedef typename conditional<Vectorizable,_ResPacket,ResScalar>::type ResPacket; 00514 00515 typedef ResPacket AccPacket; 00516 00517 EIGEN_STRONG_INLINE void initAcc(AccPacket& p) 00518 { 00519 p = pset1<ResPacket>(ResScalar(0)); 00520 } 00521 00522 EIGEN_STRONG_INLINE void loadRhs(const RhsScalar* b, RhsPacket& dest) const 00523 { 00524 dest = pset1<RhsPacket>(*b); 00525 } 00526 00527 EIGEN_STRONG_INLINE void loadRhsQuad(const RhsScalar* b, RhsPacket& dest) const 00528 { 00529 dest = pset1<RhsPacket>(*b); 00530 } 00531 00532 EIGEN_STRONG_INLINE void loadLhs(const LhsScalar* a, LhsPacket& dest) const 00533 { 00534 dest = pload<LhsPacket>(a); 00535 } 00536 00537 EIGEN_STRONG_INLINE void loadLhsUnaligned(const LhsScalar* a, LhsPacket& dest) const 00538 { 00539 dest = ploadu<LhsPacket>(a); 00540 } 00541 00542 EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1, RhsPacket& b2, RhsPacket& b3) 00543 { 00544 pbroadcast4(b, b0, b1, b2, b3); 00545 } 00546 00547 // EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1) 00548 // { 00549 // pbroadcast2(b, b0, b1); 00550 // } 00551 00552 EIGEN_STRONG_INLINE void madd(const LhsPacket& a, const RhsPacket& b, AccPacket& c, RhsPacket& tmp) const 00553 { 00554 madd_impl(a, b, c, tmp, typename conditional<Vectorizable,true_type,false_type>::type()); 00555 } 00556 00557 EIGEN_STRONG_INLINE void madd_impl(const LhsPacket& a, const RhsPacket& b, AccPacket& c, RhsPacket& tmp, const true_type&) const 00558 { 00559 #ifdef EIGEN_HAS_SINGLE_INSTRUCTION_MADD 00560 EIGEN_UNUSED_VARIABLE(tmp); 00561 c.v = pmadd(a.v,b,c.v); 00562 #else 00563 tmp = b; tmp = pmul(a.v,tmp); c.v = padd(c.v,tmp); 00564 #endif 00565 } 00566 00567 EIGEN_STRONG_INLINE void madd_impl(const LhsScalar& a, const RhsScalar& b, ResScalar& c, RhsScalar& /*tmp*/, const false_type&) const 00568 { 00569 c += a * b; 00570 } 00571 00572 EIGEN_STRONG_INLINE void acc(const AccPacket& c, const ResPacket& alpha, ResPacket& r) const 00573 { 00574 r = cj.pmadd(c,alpha,r); 00575 } 00576 00577 protected: 00578 conj_helper<ResPacket,ResPacket,ConjLhs,false> cj; 00579 }; 00580 00581 template<typename Packet> 00582 struct DoublePacket 00583 { 00584 Packet first; 00585 Packet second; 00586 }; 00587 00588 template<typename Packet> 00589 DoublePacket<Packet> padd(const DoublePacket<Packet> &a, const DoublePacket<Packet> &b) 00590 { 00591 DoublePacket<Packet> res; 00592 res.first = padd(a.first, b.first); 00593 res.second = padd(a.second,b.second); 00594 return res; 00595 } 00596 00597 template<typename Packet> 00598 const DoublePacket<Packet>& predux4(const DoublePacket<Packet> &a) 00599 { 00600 return a; 00601 } 00602 00603 template<typename Packet> struct unpacket_traits<DoublePacket<Packet> > { typedef DoublePacket<Packet> half; }; 00604 // template<typename Packet> 00605 // DoublePacket<Packet> pmadd(const DoublePacket<Packet> &a, const DoublePacket<Packet> &b) 00606 // { 00607 // DoublePacket<Packet> res; 00608 // res.first = padd(a.first, b.first); 00609 // res.second = padd(a.second,b.second); 00610 // return res; 00611 // } 00612 00613 template<typename RealScalar, bool _ConjLhs, bool _ConjRhs> 00614 class gebp_traits<std::complex<RealScalar>, std::complex<RealScalar>, _ConjLhs, _ConjRhs > 00615 { 00616 public: 00617 typedef std::complex<RealScalar> Scalar; 00618 typedef std::complex<RealScalar> LhsScalar; 00619 typedef std::complex<RealScalar> RhsScalar; 00620 typedef std::complex<RealScalar> ResScalar; 00621 00622 enum { 00623 ConjLhs = _ConjLhs, 00624 ConjRhs = _ConjRhs, 00625 Vectorizable = packet_traits<RealScalar>::Vectorizable 00626 && packet_traits<Scalar>::Vectorizable, 00627 RealPacketSize = Vectorizable ? packet_traits<RealScalar>::size : 1, 00628 ResPacketSize = Vectorizable ? packet_traits<ResScalar>::size : 1, 00629 LhsPacketSize = Vectorizable ? packet_traits<LhsScalar>::size : 1, 00630 RhsPacketSize = Vectorizable ? packet_traits<RhsScalar>::size : 1, 00631 00632 // FIXME: should depend on NumberOfRegisters 00633 nr = 4, 00634 mr = ResPacketSize, 00635 00636 LhsProgress = ResPacketSize, 00637 RhsProgress = 1 00638 }; 00639 00640 typedef typename packet_traits<RealScalar>::type RealPacket; 00641 typedef typename packet_traits<Scalar>::type ScalarPacket; 00642 typedef DoublePacket<RealPacket> DoublePacketType; 00643 00644 typedef typename conditional<Vectorizable,RealPacket, Scalar>::type LhsPacket; 00645 typedef typename conditional<Vectorizable,DoublePacketType,Scalar>::type RhsPacket; 00646 typedef typename conditional<Vectorizable,ScalarPacket,Scalar>::type ResPacket; 00647 typedef typename conditional<Vectorizable,DoublePacketType,Scalar>::type AccPacket; 00648 00649 EIGEN_STRONG_INLINE void initAcc(Scalar& p) { p = Scalar(0); } 00650 00651 EIGEN_STRONG_INLINE void initAcc(DoublePacketType& p) 00652 { 00653 p.first = pset1<RealPacket>(RealScalar(0)); 00654 p.second = pset1<RealPacket>(RealScalar(0)); 00655 } 00656 00657 // Scalar path 00658 EIGEN_STRONG_INLINE void loadRhs(const RhsScalar* b, ResPacket& dest) const 00659 { 00660 dest = pset1<ResPacket>(*b); 00661 } 00662 00663 // Vectorized path 00664 EIGEN_STRONG_INLINE void loadRhs(const RhsScalar* b, DoublePacketType& dest) const 00665 { 00666 dest.first = pset1<RealPacket>(real(*b)); 00667 dest.second = pset1<RealPacket>(imag(*b)); 00668 } 00669 00670 EIGEN_STRONG_INLINE void loadRhsQuad(const RhsScalar* b, ResPacket& dest) const 00671 { 00672 loadRhs(b,dest); 00673 } 00674 EIGEN_STRONG_INLINE void loadRhsQuad(const RhsScalar* b, DoublePacketType& dest) const 00675 { 00676 eigen_internal_assert(unpacket_traits<ScalarPacket>::size<=4); 00677 loadRhs(b,dest); 00678 } 00679 00680 EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1, RhsPacket& b2, RhsPacket& b3) 00681 { 00682 // FIXME not sure that's the best way to implement it! 00683 loadRhs(b+0, b0); 00684 loadRhs(b+1, b1); 00685 loadRhs(b+2, b2); 00686 loadRhs(b+3, b3); 00687 } 00688 00689 // Vectorized path 00690 EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, DoublePacketType& b0, DoublePacketType& b1) 00691 { 00692 // FIXME not sure that's the best way to implement it! 00693 loadRhs(b+0, b0); 00694 loadRhs(b+1, b1); 00695 } 00696 00697 // Scalar path 00698 EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsScalar& b0, RhsScalar& b1) 00699 { 00700 // FIXME not sure that's the best way to implement it! 00701 loadRhs(b+0, b0); 00702 loadRhs(b+1, b1); 00703 } 00704 00705 // nothing special here 00706 EIGEN_STRONG_INLINE void loadLhs(const LhsScalar* a, LhsPacket& dest) const 00707 { 00708 dest = pload<LhsPacket>((const typename unpacket_traits<LhsPacket>::type*)(a)); 00709 } 00710 00711 EIGEN_STRONG_INLINE void loadLhsUnaligned(const LhsScalar* a, LhsPacket& dest) const 00712 { 00713 dest = ploadu<LhsPacket>((const typename unpacket_traits<LhsPacket>::type*)(a)); 00714 } 00715 00716 EIGEN_STRONG_INLINE void madd(const LhsPacket& a, const RhsPacket& b, DoublePacketType& c, RhsPacket& /*tmp*/) const 00717 { 00718 c.first = padd(pmul(a,b.first), c.first); 00719 c.second = padd(pmul(a,b.second),c.second); 00720 } 00721 00722 EIGEN_STRONG_INLINE void madd(const LhsPacket& a, const RhsPacket& b, ResPacket& c, RhsPacket& /*tmp*/) const 00723 { 00724 c = cj.pmadd(a,b,c); 00725 } 00726 00727 EIGEN_STRONG_INLINE void acc(const Scalar& c, const Scalar& alpha, Scalar& r) const { r += alpha * c; } 00728 00729 EIGEN_STRONG_INLINE void acc(const DoublePacketType& c, const ResPacket& alpha, ResPacket& r) const 00730 { 00731 // assemble c 00732 ResPacket tmp; 00733 if((!ConjLhs)&&(!ConjRhs)) 00734 { 00735 tmp = pcplxflip(pconj(ResPacket(c.second))); 00736 tmp = padd(ResPacket(c.first),tmp); 00737 } 00738 else if((!ConjLhs)&&(ConjRhs)) 00739 { 00740 tmp = pconj(pcplxflip(ResPacket(c.second))); 00741 tmp = padd(ResPacket(c.first),tmp); 00742 } 00743 else if((ConjLhs)&&(!ConjRhs)) 00744 { 00745 tmp = pcplxflip(ResPacket(c.second)); 00746 tmp = padd(pconj(ResPacket(c.first)),tmp); 00747 } 00748 else if((ConjLhs)&&(ConjRhs)) 00749 { 00750 tmp = pcplxflip(ResPacket(c.second)); 00751 tmp = psub(pconj(ResPacket(c.first)),tmp); 00752 } 00753 00754 r = pmadd(tmp,alpha,r); 00755 } 00756 00757 protected: 00758 conj_helper<LhsScalar,RhsScalar,ConjLhs,ConjRhs> cj; 00759 }; 00760 00761 template<typename RealScalar, bool _ConjRhs> 00762 class gebp_traits<RealScalar, std::complex<RealScalar>, false, _ConjRhs > 00763 { 00764 public: 00765 typedef std::complex<RealScalar> Scalar; 00766 typedef RealScalar LhsScalar; 00767 typedef Scalar RhsScalar; 00768 typedef Scalar ResScalar; 00769 00770 enum { 00771 ConjLhs = false, 00772 ConjRhs = _ConjRhs, 00773 Vectorizable = packet_traits<RealScalar>::Vectorizable 00774 && packet_traits<Scalar>::Vectorizable, 00775 LhsPacketSize = Vectorizable ? packet_traits<LhsScalar>::size : 1, 00776 RhsPacketSize = Vectorizable ? packet_traits<RhsScalar>::size : 1, 00777 ResPacketSize = Vectorizable ? packet_traits<ResScalar>::size : 1, 00778 00779 NumberOfRegisters = EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS, 00780 // FIXME: should depend on NumberOfRegisters 00781 nr = 4, 00782 mr = (EIGEN_PLAIN_ENUM_MIN(16,NumberOfRegisters)/2/nr)*ResPacketSize, 00783 00784 LhsProgress = ResPacketSize, 00785 RhsProgress = 1 00786 }; 00787 00788 typedef typename packet_traits<LhsScalar>::type _LhsPacket; 00789 typedef typename packet_traits<RhsScalar>::type _RhsPacket; 00790 typedef typename packet_traits<ResScalar>::type _ResPacket; 00791 00792 typedef typename conditional<Vectorizable,_LhsPacket,LhsScalar>::type LhsPacket; 00793 typedef typename conditional<Vectorizable,_RhsPacket,RhsScalar>::type RhsPacket; 00794 typedef typename conditional<Vectorizable,_ResPacket,ResScalar>::type ResPacket; 00795 00796 typedef ResPacket AccPacket; 00797 00798 EIGEN_STRONG_INLINE void initAcc(AccPacket& p) 00799 { 00800 p = pset1<ResPacket>(ResScalar(0)); 00801 } 00802 00803 EIGEN_STRONG_INLINE void loadRhs(const RhsScalar* b, RhsPacket& dest) const 00804 { 00805 dest = pset1<RhsPacket>(*b); 00806 } 00807 00808 void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1, RhsPacket& b2, RhsPacket& b3) 00809 { 00810 pbroadcast4(b, b0, b1, b2, b3); 00811 } 00812 00813 // EIGEN_STRONG_INLINE void broadcastRhs(const RhsScalar* b, RhsPacket& b0, RhsPacket& b1) 00814 // { 00815 // // FIXME not sure that's the best way to implement it! 00816 // b0 = pload1<RhsPacket>(b+0); 00817 // b1 = pload1<RhsPacket>(b+1); 00818 // } 00819 00820 EIGEN_STRONG_INLINE void loadLhs(const LhsScalar* a, LhsPacket& dest) const 00821 { 00822 dest = ploaddup<LhsPacket>(a); 00823 } 00824 00825 EIGEN_STRONG_INLINE void loadRhsQuad(const RhsScalar* b, RhsPacket& dest) const 00826 { 00827 eigen_internal_assert(unpacket_traits<RhsPacket>::size<=4); 00828 loadRhs(b,dest); 00829 } 00830 00831 EIGEN_STRONG_INLINE void loadLhsUnaligned(const LhsScalar* a, LhsPacket& dest) const 00832 { 00833 dest = ploaddup<LhsPacket>(a); 00834 } 00835 00836 EIGEN_STRONG_INLINE void madd(const LhsPacket& a, const RhsPacket& b, AccPacket& c, RhsPacket& tmp) const 00837 { 00838 madd_impl(a, b, c, tmp, typename conditional<Vectorizable,true_type,false_type>::type()); 00839 } 00840 00841 EIGEN_STRONG_INLINE void madd_impl(const LhsPacket& a, const RhsPacket& b, AccPacket& c, RhsPacket& tmp, const true_type&) const 00842 { 00843 #ifdef EIGEN_HAS_SINGLE_INSTRUCTION_MADD 00844 EIGEN_UNUSED_VARIABLE(tmp); 00845 c.v = pmadd(a,b.v,c.v); 00846 #else 00847 tmp = b; tmp.v = pmul(a,tmp.v); c = padd(c,tmp); 00848 #endif 00849 00850 } 00851 00852 EIGEN_STRONG_INLINE void madd_impl(const LhsScalar& a, const RhsScalar& b, ResScalar& c, RhsScalar& /*tmp*/, const false_type&) const 00853 { 00854 c += a * b; 00855 } 00856 00857 EIGEN_STRONG_INLINE void acc(const AccPacket& c, const ResPacket& alpha, ResPacket& r) const 00858 { 00859 r = cj.pmadd(alpha,c,r); 00860 } 00861 00862 protected: 00863 conj_helper<ResPacket,ResPacket,false,ConjRhs> cj; 00864 }; 00865 00866 // helper for the rotating kernel below 00867 template <typename GebpKernel, bool UseRotatingKernel = GebpKernel::UseRotatingKernel> 00868 struct PossiblyRotatingKernelHelper 00869 { 00870 // default implementation, not rotating 00871 00872 typedef typename GebpKernel::Traits Traits; 00873 typedef typename Traits::RhsScalar RhsScalar; 00874 typedef typename Traits::RhsPacket RhsPacket; 00875 typedef typename Traits::AccPacket AccPacket; 00876 00877 const Traits& traits; 00878 PossiblyRotatingKernelHelper(const Traits& t) : traits(t) {} 00879 00880 00881 template <size_t K, size_t Index> 00882 void loadOrRotateRhs(RhsPacket& to, const RhsScalar* from) const 00883 { 00884 traits.loadRhs(from + (Index+4*K)*Traits::RhsProgress, to); 00885 } 00886 00887 void unrotateResult(AccPacket&, 00888 AccPacket&, 00889 AccPacket&, 00890 AccPacket&) 00891 { 00892 } 00893 }; 00894 00895 // rotating implementation 00896 template <typename GebpKernel> 00897 struct PossiblyRotatingKernelHelper<GebpKernel, true> 00898 { 00899 typedef typename GebpKernel::Traits Traits; 00900 typedef typename Traits::RhsScalar RhsScalar; 00901 typedef typename Traits::RhsPacket RhsPacket; 00902 typedef typename Traits::AccPacket AccPacket; 00903 00904 const Traits& traits; 00905 PossiblyRotatingKernelHelper(const Traits& t) : traits(t) {} 00906 00907 template <size_t K, size_t Index> 00908 void loadOrRotateRhs(RhsPacket& to, const RhsScalar* from) const 00909 { 00910 if (Index == 0) { 00911 to = pload<RhsPacket>(from + 4*K*Traits::RhsProgress); 00912 } else { 00913 EIGEN_ASM_COMMENT("Do not reorder code, we're very tight on registers"); 00914 to = protate<1>(to); 00915 } 00916 } 00917 00918 void unrotateResult(AccPacket& res0, 00919 AccPacket& res1, 00920 AccPacket& res2, 00921 AccPacket& res3) 00922 { 00923 PacketBlock<AccPacket> resblock; 00924 resblock.packet[0] = res0; 00925 resblock.packet[1] = res1; 00926 resblock.packet[2] = res2; 00927 resblock.packet[3] = res3; 00928 ptranspose(resblock); 00929 resblock.packet[3] = protate<1>(resblock.packet[3]); 00930 resblock.packet[2] = protate<2>(resblock.packet[2]); 00931 resblock.packet[1] = protate<3>(resblock.packet[1]); 00932 ptranspose(resblock); 00933 res0 = resblock.packet[0]; 00934 res1 = resblock.packet[1]; 00935 res2 = resblock.packet[2]; 00936 res3 = resblock.packet[3]; 00937 } 00938 }; 00939 00940 /* optimized GEneral packed Block * packed Panel product kernel 00941 * 00942 * Mixing type logic: C += A * B 00943 * | A | B | comments 00944 * |real |cplx | no vectorization yet, would require to pack A with duplication 00945 * |cplx |real | easy vectorization 00946 */ 00947 template<typename LhsScalar, typename RhsScalar, typename Index, typename DataMapper, int mr, int nr, bool ConjugateLhs, bool ConjugateRhs> 00948 struct gebp_kernel 00949 { 00950 typedef gebp_traits<LhsScalar,RhsScalar,ConjugateLhs,ConjugateRhs> Traits; 00951 typedef typename Traits::ResScalar ResScalar; 00952 typedef typename Traits::LhsPacket LhsPacket; 00953 typedef typename Traits::RhsPacket RhsPacket; 00954 typedef typename Traits::ResPacket ResPacket; 00955 typedef typename Traits::AccPacket AccPacket; 00956 00957 typedef gebp_traits<RhsScalar,LhsScalar,ConjugateRhs,ConjugateLhs> SwappedTraits; 00958 typedef typename SwappedTraits::ResScalar SResScalar; 00959 typedef typename SwappedTraits::LhsPacket SLhsPacket; 00960 typedef typename SwappedTraits::RhsPacket SRhsPacket; 00961 typedef typename SwappedTraits::ResPacket SResPacket; 00962 typedef typename SwappedTraits::AccPacket SAccPacket; 00963 00964 typedef typename DataMapper::LinearMapper LinearMapper; 00965 00966 enum { 00967 Vectorizable = Traits::Vectorizable, 00968 LhsProgress = Traits::LhsProgress, 00969 RhsProgress = Traits::RhsProgress, 00970 ResPacketSize = Traits::ResPacketSize 00971 }; 00972 00973 00974 static const bool UseRotatingKernel = 00975 EIGEN_ARCH_ARM && 00976 internal::is_same<LhsScalar, float>::value && 00977 internal::is_same<RhsScalar, float>::value && 00978 internal::is_same<ResScalar, float>::value && 00979 Traits::LhsPacketSize == 4 && 00980 Traits::RhsPacketSize == 4 && 00981 Traits::ResPacketSize == 4; 00982 00983 EIGEN_DONT_INLINE 00984 void operator()(const DataMapper& res, const LhsScalar* blockA, const RhsScalar* blockB, 00985 Index rows, Index depth, Index cols, ResScalar alpha, 00986 Index strideA=-1, Index strideB=-1, Index offsetA=0, Index offsetB=0); 00987 }; 00988 00989 template<typename LhsScalar, typename RhsScalar, typename Index, typename DataMapper, int mr, int nr, bool ConjugateLhs, bool ConjugateRhs> 00990 EIGEN_DONT_INLINE 00991 void gebp_kernel<LhsScalar,RhsScalar,Index,DataMapper,mr,nr,ConjugateLhs,ConjugateRhs> 00992 ::operator()(const DataMapper& res, const LhsScalar* blockA, const RhsScalar* blockB, 00993 Index rows, Index depth, Index cols, ResScalar alpha, 00994 Index strideA, Index strideB, Index offsetA, Index offsetB) 00995 { 00996 Traits traits; 00997 SwappedTraits straits; 00998 00999 if(strideA==-1) strideA = depth; 01000 if(strideB==-1) strideB = depth; 01001 conj_helper<LhsScalar,RhsScalar,ConjugateLhs,ConjugateRhs> cj; 01002 Index packet_cols4 = nr>=4 ? (cols/4) * 4 : 0; 01003 const Index peeled_mc3 = mr>=3*Traits::LhsProgress ? (rows/(3*LhsProgress))*(3*LhsProgress) : 0; 01004 const Index peeled_mc2 = mr>=2*Traits::LhsProgress ? peeled_mc3+((rows-peeled_mc3)/(2*LhsProgress))*(2*LhsProgress) : 0; 01005 const Index peeled_mc1 = mr>=1*Traits::LhsProgress ? (rows/(1*LhsProgress))*(1*LhsProgress) : 0; 01006 enum { pk = 8 }; // NOTE Such a large peeling factor is important for large matrices (~ +5% when >1000 on Haswell) 01007 const Index peeled_kc = depth & ~(pk-1); 01008 const Index prefetch_res_offset = 32/sizeof(ResScalar); 01009 // const Index depth2 = depth & ~1; 01010 01011 //---------- Process 3 * LhsProgress rows at once ---------- 01012 // This corresponds to 3*LhsProgress x nr register blocks. 01013 // Usually, make sense only with FMA 01014 if(mr>=3*Traits::LhsProgress) 01015 { 01016 PossiblyRotatingKernelHelper<gebp_kernel> possiblyRotatingKernelHelper(traits); 01017 01018 // Here, the general idea is to loop on each largest micro horizontal panel of the lhs (3*Traits::LhsProgress x depth) 01019 // and on each largest micro vertical panel of the rhs (depth * nr). 01020 // Blocking sizes, i.e., 'depth' has been computed so that the micro horizontal panel of the lhs fit in L1. 01021 // However, if depth is too small, we can extend the number of rows of these horizontal panels. 01022 // This actual number of rows is computed as follow: 01023 const Index l1 = defaultL1CacheSize; // in Bytes, TODO, l1 should be passed to this function. 01024 // The max(1, ...) here is needed because we may be using blocking params larger than what our known l1 cache size 01025 // suggests we should be using: either because our known l1 cache size is inaccurate (e.g. on Android, we can only guess), 01026 // or because we are testing specific blocking sizes. 01027 const Index actual_panel_rows = (3*LhsProgress) * std::max<Index>(1,( (l1 - sizeof(ResScalar)*mr*nr - depth*nr*sizeof(RhsScalar)) / (depth * sizeof(LhsScalar) * 3*LhsProgress) )); 01028 for(Index i1=0; i1<peeled_mc3; i1+=actual_panel_rows) 01029 { 01030 const Index actual_panel_end = (std::min)(i1+actual_panel_rows, peeled_mc3); 01031 for(Index j2=0; j2<packet_cols4; j2+=nr) 01032 { 01033 for(Index i=i1; i<actual_panel_end; i+=3*LhsProgress) 01034 { 01035 01036 // We selected a 3*Traits::LhsProgress x nr micro block of res which is entirely 01037 // stored into 3 x nr registers. 01038 01039 const LhsScalar* blA = &blockA[i*strideA+offsetA*(3*LhsProgress)]; 01040 prefetch(&blA[0]); 01041 01042 // gets res block as register 01043 AccPacket C0, C1, C2, C3, 01044 C4, C5, C6, C7, 01045 C8, C9, C10, C11; 01046 traits.initAcc(C0); traits.initAcc(C1); traits.initAcc(C2); traits.initAcc(C3); 01047 traits.initAcc(C4); traits.initAcc(C5); traits.initAcc(C6); traits.initAcc(C7); 01048 traits.initAcc(C8); traits.initAcc(C9); traits.initAcc(C10); traits.initAcc(C11); 01049 01050 LinearMapper r0 = res.getLinearMapper(i, j2 + 0); 01051 LinearMapper r1 = res.getLinearMapper(i, j2 + 1); 01052 LinearMapper r2 = res.getLinearMapper(i, j2 + 2); 01053 LinearMapper r3 = res.getLinearMapper(i, j2 + 3); 01054 01055 r0.prefetch(0); 01056 r1.prefetch(0); 01057 r2.prefetch(0); 01058 r3.prefetch(0); 01059 01060 // performs "inner" products 01061 const RhsScalar* blB = &blockB[j2*strideB+offsetB*nr]; 01062 prefetch(&blB[0]); 01063 LhsPacket A0, A1; 01064 01065 for(Index k=0; k<peeled_kc; k+=pk) 01066 { 01067 EIGEN_ASM_COMMENT("begin gebp micro kernel 3pX4"); 01068 RhsPacket B_0, T0; 01069 LhsPacket A2; 01070 01071 #define EIGEN_GEBP_ONESTEP(K) \ 01072 do { \ 01073 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 3pX4"); \ 01074 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01075 internal::prefetch(blA+(3*K+16)*LhsProgress); \ 01076 if (EIGEN_ARCH_ARM) internal::prefetch(blB+(4*K+16)*RhsProgress); /* Bug 953 */ \ 01077 traits.loadLhs(&blA[(0+3*K)*LhsProgress], A0); \ 01078 traits.loadLhs(&blA[(1+3*K)*LhsProgress], A1); \ 01079 traits.loadLhs(&blA[(2+3*K)*LhsProgress], A2); \ 01080 possiblyRotatingKernelHelper.template loadOrRotateRhs<K, 0>(B_0, blB); \ 01081 traits.madd(A0, B_0, C0, T0); \ 01082 traits.madd(A1, B_0, C4, T0); \ 01083 traits.madd(A2, B_0, C8, B_0); \ 01084 possiblyRotatingKernelHelper.template loadOrRotateRhs<K, 1>(B_0, blB); \ 01085 traits.madd(A0, B_0, C1, T0); \ 01086 traits.madd(A1, B_0, C5, T0); \ 01087 traits.madd(A2, B_0, C9, B_0); \ 01088 possiblyRotatingKernelHelper.template loadOrRotateRhs<K, 2>(B_0, blB); \ 01089 traits.madd(A0, B_0, C2, T0); \ 01090 traits.madd(A1, B_0, C6, T0); \ 01091 traits.madd(A2, B_0, C10, B_0); \ 01092 possiblyRotatingKernelHelper.template loadOrRotateRhs<K, 3>(B_0, blB); \ 01093 traits.madd(A0, B_0, C3 , T0); \ 01094 traits.madd(A1, B_0, C7, T0); \ 01095 traits.madd(A2, B_0, C11, B_0); \ 01096 EIGEN_ASM_COMMENT("end step of gebp micro kernel 3pX4"); \ 01097 } while(false) 01098 01099 internal::prefetch(blB); 01100 EIGEN_GEBP_ONESTEP(0); 01101 EIGEN_GEBP_ONESTEP(1); 01102 EIGEN_GEBP_ONESTEP(2); 01103 EIGEN_GEBP_ONESTEP(3); 01104 EIGEN_GEBP_ONESTEP(4); 01105 EIGEN_GEBP_ONESTEP(5); 01106 EIGEN_GEBP_ONESTEP(6); 01107 EIGEN_GEBP_ONESTEP(7); 01108 01109 blB += pk*4*RhsProgress; 01110 blA += pk*3*Traits::LhsProgress; 01111 01112 EIGEN_ASM_COMMENT("end gebp micro kernel 3pX4"); 01113 } 01114 // process remaining peeled loop 01115 for(Index k=peeled_kc; k<depth; k++) 01116 { 01117 RhsPacket B_0, T0; 01118 LhsPacket A2; 01119 EIGEN_GEBP_ONESTEP(0); 01120 blB += 4*RhsProgress; 01121 blA += 3*Traits::LhsProgress; 01122 } 01123 01124 #undef EIGEN_GEBP_ONESTEP 01125 01126 possiblyRotatingKernelHelper.unrotateResult(C0, C1, C2, C3); 01127 possiblyRotatingKernelHelper.unrotateResult(C4, C5, C6, C7); 01128 possiblyRotatingKernelHelper.unrotateResult(C8, C9, C10, C11); 01129 01130 ResPacket R0, R1, R2; 01131 ResPacket alphav = pset1<ResPacket>(alpha); 01132 01133 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01134 R1 = r0.loadPacket(1 * Traits::ResPacketSize); 01135 R2 = r0.loadPacket(2 * Traits::ResPacketSize); 01136 traits.acc(C0, alphav, R0); 01137 traits.acc(C4, alphav, R1); 01138 traits.acc(C8, alphav, R2); 01139 r0.storePacket(0 * Traits::ResPacketSize, R0); 01140 r0.storePacket(1 * Traits::ResPacketSize, R1); 01141 r0.storePacket(2 * Traits::ResPacketSize, R2); 01142 01143 R0 = r1.loadPacket(0 * Traits::ResPacketSize); 01144 R1 = r1.loadPacket(1 * Traits::ResPacketSize); 01145 R2 = r1.loadPacket(2 * Traits::ResPacketSize); 01146 traits.acc(C1, alphav, R0); 01147 traits.acc(C5, alphav, R1); 01148 traits.acc(C9, alphav, R2); 01149 r1.storePacket(0 * Traits::ResPacketSize, R0); 01150 r1.storePacket(1 * Traits::ResPacketSize, R1); 01151 r1.storePacket(2 * Traits::ResPacketSize, R2); 01152 01153 R0 = r2.loadPacket(0 * Traits::ResPacketSize); 01154 R1 = r2.loadPacket(1 * Traits::ResPacketSize); 01155 R2 = r2.loadPacket(2 * Traits::ResPacketSize); 01156 traits.acc(C2, alphav, R0); 01157 traits.acc(C6, alphav, R1); 01158 traits.acc(C10, alphav, R2); 01159 r2.storePacket(0 * Traits::ResPacketSize, R0); 01160 r2.storePacket(1 * Traits::ResPacketSize, R1); 01161 r2.storePacket(2 * Traits::ResPacketSize, R2); 01162 01163 R0 = r3.loadPacket(0 * Traits::ResPacketSize); 01164 R1 = r3.loadPacket(1 * Traits::ResPacketSize); 01165 R2 = r3.loadPacket(2 * Traits::ResPacketSize); 01166 traits.acc(C3, alphav, R0); 01167 traits.acc(C7, alphav, R1); 01168 traits.acc(C11, alphav, R2); 01169 r3.storePacket(0 * Traits::ResPacketSize, R0); 01170 r3.storePacket(1 * Traits::ResPacketSize, R1); 01171 r3.storePacket(2 * Traits::ResPacketSize, R2); 01172 } 01173 } 01174 01175 // Deal with remaining columns of the rhs 01176 for(Index j2=packet_cols4; j2<cols; j2++) 01177 { 01178 for(Index i=i1; i<actual_panel_end; i+=3*LhsProgress) 01179 { 01180 // One column at a time 01181 const LhsScalar* blA = &blockA[i*strideA+offsetA*(3*Traits::LhsProgress)]; 01182 prefetch(&blA[0]); 01183 01184 // gets res block as register 01185 AccPacket C0, C4, C8; 01186 traits.initAcc(C0); 01187 traits.initAcc(C4); 01188 traits.initAcc(C8); 01189 01190 LinearMapper r0 = res.getLinearMapper(i, j2); 01191 r0.prefetch(0); 01192 01193 // performs "inner" products 01194 const RhsScalar* blB = &blockB[j2*strideB+offsetB]; 01195 LhsPacket A0, A1, A2; 01196 01197 for(Index k=0; k<peeled_kc; k+=pk) 01198 { 01199 EIGEN_ASM_COMMENT("begin gebp micro kernel 3pX1"); 01200 RhsPacket B_0; 01201 #define EIGEN_GEBGP_ONESTEP(K) \ 01202 do { \ 01203 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 3pX1"); \ 01204 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01205 traits.loadLhs(&blA[(0+3*K)*LhsProgress], A0); \ 01206 traits.loadLhs(&blA[(1+3*K)*LhsProgress], A1); \ 01207 traits.loadLhs(&blA[(2+3*K)*LhsProgress], A2); \ 01208 traits.loadRhs(&blB[(0+K)*RhsProgress], B_0); \ 01209 traits.madd(A0, B_0, C0, B_0); \ 01210 traits.madd(A1, B_0, C4, B_0); \ 01211 traits.madd(A2, B_0, C8, B_0); \ 01212 EIGEN_ASM_COMMENT("end step of gebp micro kernel 3pX1"); \ 01213 } while(false) 01214 01215 EIGEN_GEBGP_ONESTEP(0); 01216 EIGEN_GEBGP_ONESTEP(1); 01217 EIGEN_GEBGP_ONESTEP(2); 01218 EIGEN_GEBGP_ONESTEP(3); 01219 EIGEN_GEBGP_ONESTEP(4); 01220 EIGEN_GEBGP_ONESTEP(5); 01221 EIGEN_GEBGP_ONESTEP(6); 01222 EIGEN_GEBGP_ONESTEP(7); 01223 01224 blB += pk*RhsProgress; 01225 blA += pk*3*Traits::LhsProgress; 01226 01227 EIGEN_ASM_COMMENT("end gebp micro kernel 3pX1"); 01228 } 01229 01230 // process remaining peeled loop 01231 for(Index k=peeled_kc; k<depth; k++) 01232 { 01233 RhsPacket B_0; 01234 EIGEN_GEBGP_ONESTEP(0); 01235 blB += RhsProgress; 01236 blA += 3*Traits::LhsProgress; 01237 } 01238 #undef EIGEN_GEBGP_ONESTEP 01239 ResPacket R0, R1, R2; 01240 ResPacket alphav = pset1<ResPacket>(alpha); 01241 01242 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01243 R1 = r0.loadPacket(1 * Traits::ResPacketSize); 01244 R2 = r0.loadPacket(2 * Traits::ResPacketSize); 01245 traits.acc(C0, alphav, R0); 01246 traits.acc(C4, alphav, R1); 01247 traits.acc(C8, alphav, R2); 01248 r0.storePacket(0 * Traits::ResPacketSize, R0); 01249 r0.storePacket(1 * Traits::ResPacketSize, R1); 01250 r0.storePacket(2 * Traits::ResPacketSize, R2); 01251 } 01252 } 01253 } 01254 } 01255 01256 //---------- Process 2 * LhsProgress rows at once ---------- 01257 if(mr>=2*Traits::LhsProgress) 01258 { 01259 const Index l1 = defaultL1CacheSize; // in Bytes, TODO, l1 should be passed to this function. 01260 // The max(1, ...) here is needed because we may be using blocking params larger than what our known l1 cache size 01261 // suggests we should be using: either because our known l1 cache size is inaccurate (e.g. on Android, we can only guess), 01262 // or because we are testing specific blocking sizes. 01263 Index actual_panel_rows = (2*LhsProgress) * std::max<Index>(1,( (l1 - sizeof(ResScalar)*mr*nr - depth*nr*sizeof(RhsScalar)) / (depth * sizeof(LhsScalar) * 2*LhsProgress) )); 01264 01265 for(Index i1=peeled_mc3; i1<peeled_mc2; i1+=actual_panel_rows) 01266 { 01267 Index actual_panel_end = (std::min)(i1+actual_panel_rows, peeled_mc2); 01268 for(Index j2=0; j2<packet_cols4; j2+=nr) 01269 { 01270 for(Index i=i1; i<actual_panel_end; i+=2*LhsProgress) 01271 { 01272 01273 // We selected a 2*Traits::LhsProgress x nr micro block of res which is entirely 01274 // stored into 2 x nr registers. 01275 01276 const LhsScalar* blA = &blockA[i*strideA+offsetA*(2*Traits::LhsProgress)]; 01277 prefetch(&blA[0]); 01278 01279 // gets res block as register 01280 AccPacket C0, C1, C2, C3, 01281 C4, C5, C6, C7; 01282 traits.initAcc(C0); traits.initAcc(C1); traits.initAcc(C2); traits.initAcc(C3); 01283 traits.initAcc(C4); traits.initAcc(C5); traits.initAcc(C6); traits.initAcc(C7); 01284 01285 LinearMapper r0 = res.getLinearMapper(i, j2 + 0); 01286 LinearMapper r1 = res.getLinearMapper(i, j2 + 1); 01287 LinearMapper r2 = res.getLinearMapper(i, j2 + 2); 01288 LinearMapper r3 = res.getLinearMapper(i, j2 + 3); 01289 01290 r0.prefetch(prefetch_res_offset); 01291 r1.prefetch(prefetch_res_offset); 01292 r2.prefetch(prefetch_res_offset); 01293 r3.prefetch(prefetch_res_offset); 01294 01295 // performs "inner" products 01296 const RhsScalar* blB = &blockB[j2*strideB+offsetB*nr]; 01297 prefetch(&blB[0]); 01298 LhsPacket A0, A1; 01299 01300 for(Index k=0; k<peeled_kc; k+=pk) 01301 { 01302 EIGEN_ASM_COMMENT("begin gebp micro kernel 2pX4"); 01303 RhsPacket B_0, B1, B2, B3, T0; 01304 01305 #define EIGEN_GEBGP_ONESTEP(K) \ 01306 do { \ 01307 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 2pX4"); \ 01308 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01309 traits.loadLhs(&blA[(0+2*K)*LhsProgress], A0); \ 01310 traits.loadLhs(&blA[(1+2*K)*LhsProgress], A1); \ 01311 traits.broadcastRhs(&blB[(0+4*K)*RhsProgress], B_0, B1, B2, B3); \ 01312 traits.madd(A0, B_0, C0, T0); \ 01313 traits.madd(A1, B_0, C4, B_0); \ 01314 traits.madd(A0, B1, C1, T0); \ 01315 traits.madd(A1, B1, C5, B1); \ 01316 traits.madd(A0, B2, C2, T0); \ 01317 traits.madd(A1, B2, C6, B2); \ 01318 traits.madd(A0, B3, C3, T0); \ 01319 traits.madd(A1, B3, C7, B3); \ 01320 EIGEN_ASM_COMMENT("end step of gebp micro kernel 2pX4"); \ 01321 } while(false) 01322 01323 internal::prefetch(blB+(48+0)); 01324 EIGEN_GEBGP_ONESTEP(0); 01325 EIGEN_GEBGP_ONESTEP(1); 01326 EIGEN_GEBGP_ONESTEP(2); 01327 EIGEN_GEBGP_ONESTEP(3); 01328 internal::prefetch(blB+(48+16)); 01329 EIGEN_GEBGP_ONESTEP(4); 01330 EIGEN_GEBGP_ONESTEP(5); 01331 EIGEN_GEBGP_ONESTEP(6); 01332 EIGEN_GEBGP_ONESTEP(7); 01333 01334 blB += pk*4*RhsProgress; 01335 blA += pk*(2*Traits::LhsProgress); 01336 01337 EIGEN_ASM_COMMENT("end gebp micro kernel 2pX4"); 01338 } 01339 // process remaining peeled loop 01340 for(Index k=peeled_kc; k<depth; k++) 01341 { 01342 RhsPacket B_0, B1, B2, B3, T0; 01343 EIGEN_GEBGP_ONESTEP(0); 01344 blB += 4*RhsProgress; 01345 blA += 2*Traits::LhsProgress; 01346 } 01347 #undef EIGEN_GEBGP_ONESTEP 01348 01349 ResPacket R0, R1, R2, R3; 01350 ResPacket alphav = pset1<ResPacket>(alpha); 01351 01352 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01353 R1 = r0.loadPacket(1 * Traits::ResPacketSize); 01354 R2 = r1.loadPacket(0 * Traits::ResPacketSize); 01355 R3 = r1.loadPacket(1 * Traits::ResPacketSize); 01356 traits.acc(C0, alphav, R0); 01357 traits.acc(C4, alphav, R1); 01358 traits.acc(C1, alphav, R2); 01359 traits.acc(C5, alphav, R3); 01360 r0.storePacket(0 * Traits::ResPacketSize, R0); 01361 r0.storePacket(1 * Traits::ResPacketSize, R1); 01362 r1.storePacket(0 * Traits::ResPacketSize, R2); 01363 r1.storePacket(1 * Traits::ResPacketSize, R3); 01364 01365 R0 = r2.loadPacket(0 * Traits::ResPacketSize); 01366 R1 = r2.loadPacket(1 * Traits::ResPacketSize); 01367 R2 = r3.loadPacket(0 * Traits::ResPacketSize); 01368 R3 = r3.loadPacket(1 * Traits::ResPacketSize); 01369 traits.acc(C2, alphav, R0); 01370 traits.acc(C6, alphav, R1); 01371 traits.acc(C3, alphav, R2); 01372 traits.acc(C7, alphav, R3); 01373 r2.storePacket(0 * Traits::ResPacketSize, R0); 01374 r2.storePacket(1 * Traits::ResPacketSize, R1); 01375 r3.storePacket(0 * Traits::ResPacketSize, R2); 01376 r3.storePacket(1 * Traits::ResPacketSize, R3); 01377 } 01378 } 01379 01380 // Deal with remaining columns of the rhs 01381 for(Index j2=packet_cols4; j2<cols; j2++) 01382 { 01383 for(Index i=i1; i<actual_panel_end; i+=2*LhsProgress) 01384 { 01385 // One column at a time 01386 const LhsScalar* blA = &blockA[i*strideA+offsetA*(2*Traits::LhsProgress)]; 01387 prefetch(&blA[0]); 01388 01389 // gets res block as register 01390 AccPacket C0, C4; 01391 traits.initAcc(C0); 01392 traits.initAcc(C4); 01393 01394 LinearMapper r0 = res.getLinearMapper(i, j2); 01395 r0.prefetch(prefetch_res_offset); 01396 01397 // performs "inner" products 01398 const RhsScalar* blB = &blockB[j2*strideB+offsetB]; 01399 LhsPacket A0, A1; 01400 01401 for(Index k=0; k<peeled_kc; k+=pk) 01402 { 01403 EIGEN_ASM_COMMENT("begin gebp micro kernel 2pX1"); 01404 RhsPacket B_0, B1; 01405 01406 #define EIGEN_GEBGP_ONESTEP(K) \ 01407 do { \ 01408 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 2pX1"); \ 01409 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01410 traits.loadLhs(&blA[(0+2*K)*LhsProgress], A0); \ 01411 traits.loadLhs(&blA[(1+2*K)*LhsProgress], A1); \ 01412 traits.loadRhs(&blB[(0+K)*RhsProgress], B_0); \ 01413 traits.madd(A0, B_0, C0, B1); \ 01414 traits.madd(A1, B_0, C4, B_0); \ 01415 EIGEN_ASM_COMMENT("end step of gebp micro kernel 2pX1"); \ 01416 } while(false) 01417 01418 EIGEN_GEBGP_ONESTEP(0); 01419 EIGEN_GEBGP_ONESTEP(1); 01420 EIGEN_GEBGP_ONESTEP(2); 01421 EIGEN_GEBGP_ONESTEP(3); 01422 EIGEN_GEBGP_ONESTEP(4); 01423 EIGEN_GEBGP_ONESTEP(5); 01424 EIGEN_GEBGP_ONESTEP(6); 01425 EIGEN_GEBGP_ONESTEP(7); 01426 01427 blB += pk*RhsProgress; 01428 blA += pk*2*Traits::LhsProgress; 01429 01430 EIGEN_ASM_COMMENT("end gebp micro kernel 2pX1"); 01431 } 01432 01433 // process remaining peeled loop 01434 for(Index k=peeled_kc; k<depth; k++) 01435 { 01436 RhsPacket B_0, B1; 01437 EIGEN_GEBGP_ONESTEP(0); 01438 blB += RhsProgress; 01439 blA += 2*Traits::LhsProgress; 01440 } 01441 #undef EIGEN_GEBGP_ONESTEP 01442 ResPacket R0, R1; 01443 ResPacket alphav = pset1<ResPacket>(alpha); 01444 01445 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01446 R1 = r0.loadPacket(1 * Traits::ResPacketSize); 01447 traits.acc(C0, alphav, R0); 01448 traits.acc(C4, alphav, R1); 01449 r0.storePacket(0 * Traits::ResPacketSize, R0); 01450 r0.storePacket(1 * Traits::ResPacketSize, R1); 01451 } 01452 } 01453 } 01454 } 01455 //---------- Process 1 * LhsProgress rows at once ---------- 01456 if(mr>=1*Traits::LhsProgress) 01457 { 01458 // loops on each largest micro horizontal panel of lhs (1*LhsProgress x depth) 01459 for(Index i=peeled_mc2; i<peeled_mc1; i+=1*LhsProgress) 01460 { 01461 // loops on each largest micro vertical panel of rhs (depth * nr) 01462 for(Index j2=0; j2<packet_cols4; j2+=nr) 01463 { 01464 // We select a 1*Traits::LhsProgress x nr micro block of res which is entirely 01465 // stored into 1 x nr registers. 01466 01467 const LhsScalar* blA = &blockA[i*strideA+offsetA*(1*Traits::LhsProgress)]; 01468 prefetch(&blA[0]); 01469 01470 // gets res block as register 01471 AccPacket C0, C1, C2, C3; 01472 traits.initAcc(C0); 01473 traits.initAcc(C1); 01474 traits.initAcc(C2); 01475 traits.initAcc(C3); 01476 01477 LinearMapper r0 = res.getLinearMapper(i, j2 + 0); 01478 LinearMapper r1 = res.getLinearMapper(i, j2 + 1); 01479 LinearMapper r2 = res.getLinearMapper(i, j2 + 2); 01480 LinearMapper r3 = res.getLinearMapper(i, j2 + 3); 01481 01482 r0.prefetch(prefetch_res_offset); 01483 r1.prefetch(prefetch_res_offset); 01484 r2.prefetch(prefetch_res_offset); 01485 r3.prefetch(prefetch_res_offset); 01486 01487 // performs "inner" products 01488 const RhsScalar* blB = &blockB[j2*strideB+offsetB*nr]; 01489 prefetch(&blB[0]); 01490 LhsPacket A0; 01491 01492 for(Index k=0; k<peeled_kc; k+=pk) 01493 { 01494 EIGEN_ASM_COMMENT("begin gebp micro kernel 1pX4"); 01495 RhsPacket B_0, B1, B2, B3; 01496 01497 #define EIGEN_GEBGP_ONESTEP(K) \ 01498 do { \ 01499 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 1pX4"); \ 01500 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01501 traits.loadLhs(&blA[(0+1*K)*LhsProgress], A0); \ 01502 traits.broadcastRhs(&blB[(0+4*K)*RhsProgress], B_0, B1, B2, B3); \ 01503 traits.madd(A0, B_0, C0, B_0); \ 01504 traits.madd(A0, B1, C1, B1); \ 01505 traits.madd(A0, B2, C2, B2); \ 01506 traits.madd(A0, B3, C3, B3); \ 01507 EIGEN_ASM_COMMENT("end step of gebp micro kernel 1pX4"); \ 01508 } while(false) 01509 01510 internal::prefetch(blB+(48+0)); 01511 EIGEN_GEBGP_ONESTEP(0); 01512 EIGEN_GEBGP_ONESTEP(1); 01513 EIGEN_GEBGP_ONESTEP(2); 01514 EIGEN_GEBGP_ONESTEP(3); 01515 internal::prefetch(blB+(48+16)); 01516 EIGEN_GEBGP_ONESTEP(4); 01517 EIGEN_GEBGP_ONESTEP(5); 01518 EIGEN_GEBGP_ONESTEP(6); 01519 EIGEN_GEBGP_ONESTEP(7); 01520 01521 blB += pk*4*RhsProgress; 01522 blA += pk*1*LhsProgress; 01523 01524 EIGEN_ASM_COMMENT("end gebp micro kernel 1pX4"); 01525 } 01526 // process remaining peeled loop 01527 for(Index k=peeled_kc; k<depth; k++) 01528 { 01529 RhsPacket B_0, B1, B2, B3; 01530 EIGEN_GEBGP_ONESTEP(0); 01531 blB += 4*RhsProgress; 01532 blA += 1*LhsProgress; 01533 } 01534 #undef EIGEN_GEBGP_ONESTEP 01535 01536 ResPacket R0, R1; 01537 ResPacket alphav = pset1<ResPacket>(alpha); 01538 01539 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01540 R1 = r1.loadPacket(0 * Traits::ResPacketSize); 01541 traits.acc(C0, alphav, R0); 01542 traits.acc(C1, alphav, R1); 01543 r0.storePacket(0 * Traits::ResPacketSize, R0); 01544 r1.storePacket(0 * Traits::ResPacketSize, R1); 01545 01546 R0 = r2.loadPacket(0 * Traits::ResPacketSize); 01547 R1 = r3.loadPacket(0 * Traits::ResPacketSize); 01548 traits.acc(C2, alphav, R0); 01549 traits.acc(C3, alphav, R1); 01550 r2.storePacket(0 * Traits::ResPacketSize, R0); 01551 r3.storePacket(0 * Traits::ResPacketSize, R1); 01552 } 01553 01554 // Deal with remaining columns of the rhs 01555 for(Index j2=packet_cols4; j2<cols; j2++) 01556 { 01557 // One column at a time 01558 const LhsScalar* blA = &blockA[i*strideA+offsetA*(1*Traits::LhsProgress)]; 01559 prefetch(&blA[0]); 01560 01561 // gets res block as register 01562 AccPacket C0; 01563 traits.initAcc(C0); 01564 01565 LinearMapper r0 = res.getLinearMapper(i, j2); 01566 01567 // performs "inner" products 01568 const RhsScalar* blB = &blockB[j2*strideB+offsetB]; 01569 LhsPacket A0; 01570 01571 for(Index k=0; k<peeled_kc; k+=pk) 01572 { 01573 EIGEN_ASM_COMMENT("begin gebp micro kernel 1pX1"); 01574 RhsPacket B_0; 01575 01576 #define EIGEN_GEBGP_ONESTEP(K) \ 01577 do { \ 01578 EIGEN_ASM_COMMENT("begin step of gebp micro kernel 1pX1"); \ 01579 EIGEN_ASM_COMMENT("Note: these asm comments work around bug 935!"); \ 01580 traits.loadLhs(&blA[(0+1*K)*LhsProgress], A0); \ 01581 traits.loadRhs(&blB[(0+K)*RhsProgress], B_0); \ 01582 traits.madd(A0, B_0, C0, B_0); \ 01583 EIGEN_ASM_COMMENT("end step of gebp micro kernel 1pX1"); \ 01584 } while(false); 01585 01586 EIGEN_GEBGP_ONESTEP(0); 01587 EIGEN_GEBGP_ONESTEP(1); 01588 EIGEN_GEBGP_ONESTEP(2); 01589 EIGEN_GEBGP_ONESTEP(3); 01590 EIGEN_GEBGP_ONESTEP(4); 01591 EIGEN_GEBGP_ONESTEP(5); 01592 EIGEN_GEBGP_ONESTEP(6); 01593 EIGEN_GEBGP_ONESTEP(7); 01594 01595 blB += pk*RhsProgress; 01596 blA += pk*1*Traits::LhsProgress; 01597 01598 EIGEN_ASM_COMMENT("end gebp micro kernel 1pX1"); 01599 } 01600 01601 // process remaining peeled loop 01602 for(Index k=peeled_kc; k<depth; k++) 01603 { 01604 RhsPacket B_0; 01605 EIGEN_GEBGP_ONESTEP(0); 01606 blB += RhsProgress; 01607 blA += 1*Traits::LhsProgress; 01608 } 01609 #undef EIGEN_GEBGP_ONESTEP 01610 ResPacket R0; 01611 ResPacket alphav = pset1<ResPacket>(alpha); 01612 R0 = r0.loadPacket(0 * Traits::ResPacketSize); 01613 traits.acc(C0, alphav, R0); 01614 r0.storePacket(0 * Traits::ResPacketSize, R0); 01615 } 01616 } 01617 } 01618 //---------- Process remaining rows, 1 at once ---------- 01619 if(peeled_mc1<rows) 01620 { 01621 // loop on each panel of the rhs 01622 for(Index j2=0; j2<packet_cols4; j2+=nr) 01623 { 01624 // loop on each row of the lhs (1*LhsProgress x depth) 01625 for(Index i=peeled_mc1; i<rows; i+=1) 01626 { 01627 const LhsScalar* blA = &blockA[i*strideA+offsetA]; 01628 prefetch(&blA[0]); 01629 const RhsScalar* blB = &blockB[j2*strideB+offsetB*nr]; 01630 01631 if( (SwappedTraits::LhsProgress % 4)==0 ) 01632 { 01633 // NOTE The following piece of code wont work for 512 bit registers 01634 SAccPacket C0, C1, C2, C3; 01635 straits.initAcc(C0); 01636 straits.initAcc(C1); 01637 straits.initAcc(C2); 01638 straits.initAcc(C3); 01639 01640 const Index spk = (std::max)(1,SwappedTraits::LhsProgress/4); 01641 const Index endk = (depth/spk)*spk; 01642 const Index endk4 = (depth/(spk*4))*(spk*4); 01643 01644 Index k=0; 01645 for(; k<endk4; k+=4*spk) 01646 { 01647 SLhsPacket A0,A1; 01648 SRhsPacket B_0,B_1; 01649 01650 straits.loadLhsUnaligned(blB+0*SwappedTraits::LhsProgress, A0); 01651 straits.loadLhsUnaligned(blB+1*SwappedTraits::LhsProgress, A1); 01652 01653 straits.loadRhsQuad(blA+0*spk, B_0); 01654 straits.loadRhsQuad(blA+1*spk, B_1); 01655 straits.madd(A0,B_0,C0,B_0); 01656 straits.madd(A1,B_1,C1,B_1); 01657 01658 straits.loadLhsUnaligned(blB+2*SwappedTraits::LhsProgress, A0); 01659 straits.loadLhsUnaligned(blB+3*SwappedTraits::LhsProgress, A1); 01660 straits.loadRhsQuad(blA+2*spk, B_0); 01661 straits.loadRhsQuad(blA+3*spk, B_1); 01662 straits.madd(A0,B_0,C2,B_0); 01663 straits.madd(A1,B_1,C3,B_1); 01664 01665 blB += 4*SwappedTraits::LhsProgress; 01666 blA += 4*spk; 01667 } 01668 C0 = padd(padd(C0,C1),padd(C2,C3)); 01669 for(; k<endk; k+=spk) 01670 { 01671 SLhsPacket A0; 01672 SRhsPacket B_0; 01673 01674 straits.loadLhsUnaligned(blB, A0); 01675 straits.loadRhsQuad(blA, B_0); 01676 straits.madd(A0,B_0,C0,B_0); 01677 01678 blB += SwappedTraits::LhsProgress; 01679 blA += spk; 01680 } 01681 if(SwappedTraits::LhsProgress==8) 01682 { 01683 // Special case where we have to first reduce the accumulation register C0 01684 typedef typename conditional<SwappedTraits::LhsProgress==8,typename unpacket_traits<SResPacket>::half,SResPacket>::type SResPacketHalf; 01685 typedef typename conditional<SwappedTraits::LhsProgress==8,typename unpacket_traits<SLhsPacket>::half,SLhsPacket>::type SLhsPacketHalf; 01686 typedef typename conditional<SwappedTraits::LhsProgress==8,typename unpacket_traits<SLhsPacket>::half,SRhsPacket>::type SRhsPacketHalf; 01687 typedef typename conditional<SwappedTraits::LhsProgress==8,typename unpacket_traits<SAccPacket>::half,SAccPacket>::type SAccPacketHalf; 01688 01689 SResPacketHalf R = res.template gatherPacket<SResPacketHalf>(i, j2); 01690 SResPacketHalf alphav = pset1<SResPacketHalf>(alpha); 01691 01692 if(depth-endk>0) 01693 { 01694 // We have to handle the last row of the rhs which corresponds to a half-packet 01695 SLhsPacketHalf a0; 01696 SRhsPacketHalf b0; 01697 straits.loadLhsUnaligned(blB, a0); 01698 straits.loadRhs(blA, b0); 01699 SAccPacketHalf c0 = predux4(C0); 01700 straits.madd(a0,b0,c0,b0); 01701 straits.acc(c0, alphav, R); 01702 } 01703 else 01704 { 01705 straits.acc(predux4(C0), alphav, R); 01706 } 01707 res.scatterPacket(i, j2, R); 01708 } 01709 else 01710 { 01711 SResPacket R = res.template gatherPacket<SResPacket>(i, j2); 01712 SResPacket alphav = pset1<SResPacket>(alpha); 01713 straits.acc(C0, alphav, R); 01714 res.scatterPacket(i, j2, R); 01715 } 01716 } 01717 else // scalar path 01718 { 01719 // get a 1 x 4 res block as registers 01720 ResScalar C0(0), C1(0), C2(0), C3(0); 01721 01722 for(Index k=0; k<depth; k++) 01723 { 01724 LhsScalar A0; 01725 RhsScalar B_0, B_1; 01726 01727 A0 = blA[k]; 01728 01729 B_0 = blB[0]; 01730 B_1 = blB[1]; 01731 CJMADD(cj,A0,B_0,C0, B_0); 01732 CJMADD(cj,A0,B_1,C1, B_1); 01733 01734 B_0 = blB[2]; 01735 B_1 = blB[3]; 01736 CJMADD(cj,A0,B_0,C2, B_0); 01737 CJMADD(cj,A0,B_1,C3, B_1); 01738 01739 blB += 4; 01740 } 01741 res(i, j2 + 0) += alpha * C0; 01742 res(i, j2 + 1) += alpha * C1; 01743 res(i, j2 + 2) += alpha * C2; 01744 res(i, j2 + 3) += alpha * C3; 01745 } 01746 } 01747 } 01748 // remaining columns 01749 for(Index j2=packet_cols4; j2<cols; j2++) 01750 { 01751 // loop on each row of the lhs (1*LhsProgress x depth) 01752 for(Index i=peeled_mc1; i<rows; i+=1) 01753 { 01754 const LhsScalar* blA = &blockA[i*strideA+offsetA]; 01755 prefetch(&blA[0]); 01756 // gets a 1 x 1 res block as registers 01757 ResScalar C0(0); 01758 const RhsScalar* blB = &blockB[j2*strideB+offsetB]; 01759 for(Index k=0; k<depth; k++) 01760 { 01761 LhsScalar A0 = blA[k]; 01762 RhsScalar B_0 = blB[k]; 01763 CJMADD(cj, A0, B_0, C0, B_0); 01764 } 01765 res(i, j2) += alpha * C0; 01766 } 01767 } 01768 } 01769 } 01770 01771 01772 #undef CJMADD 01773 01774 // pack a block of the lhs 01775 // The traversal is as follow (mr==4): 01776 // 0 4 8 12 ... 01777 // 1 5 9 13 ... 01778 // 2 6 10 14 ... 01779 // 3 7 11 15 ... 01780 // 01781 // 16 20 24 28 ... 01782 // 17 21 25 29 ... 01783 // 18 22 26 30 ... 01784 // 19 23 27 31 ... 01785 // 01786 // 32 33 34 35 ... 01787 // 36 36 38 39 ... 01788 template<typename Scalar, typename Index, typename DataMapper, int Pack1, int Pack2, bool Conjugate, bool PanelMode> 01789 struct gemm_pack_lhs<Scalar, Index, DataMapper, Pack1, Pack2, ColMajor, Conjugate, PanelMode> 01790 { 01791 typedef typename DataMapper::LinearMapper LinearMapper; 01792 EIGEN_DONT_INLINE void operator()(Scalar* blockA, const DataMapper& lhs, Index depth, Index rows, Index stride=0, Index offset=0); 01793 }; 01794 01795 template<typename Scalar, typename Index, typename DataMapper, int Pack1, int Pack2, bool Conjugate, bool PanelMode> 01796 EIGEN_DONT_INLINE void gemm_pack_lhs<Scalar, Index, DataMapper, Pack1, Pack2, ColMajor, Conjugate, PanelMode> 01797 ::operator()(Scalar* blockA, const DataMapper& lhs, Index depth, Index rows, Index stride, Index offset) 01798 { 01799 typedef typename packet_traits<Scalar>::type Packet; 01800 enum { PacketSize = packet_traits<Scalar>::size }; 01801 01802 EIGEN_ASM_COMMENT("EIGEN PRODUCT PACK LHS"); 01803 EIGEN_UNUSED_VARIABLE(stride); 01804 EIGEN_UNUSED_VARIABLE(offset); 01805 eigen_assert(((!PanelMode) && stride==0 && offset==0) || (PanelMode && stride>=depth && offset<=stride)); 01806 eigen_assert( ((Pack1%PacketSize)==0 && Pack1<=4*PacketSize) || (Pack1<=4) ); 01807 conj_if<NumTraits<Scalar>::IsComplex && Conjugate> cj; 01808 Index count = 0; 01809 01810 const Index peeled_mc3 = Pack1>=3*PacketSize ? (rows/(3*PacketSize))*(3*PacketSize) : 0; 01811 const Index peeled_mc2 = Pack1>=2*PacketSize ? peeled_mc3+((rows-peeled_mc3)/(2*PacketSize))*(2*PacketSize) : 0; 01812 const Index peeled_mc1 = Pack1>=1*PacketSize ? (rows/(1*PacketSize))*(1*PacketSize) : 0; 01813 const Index peeled_mc0 = Pack2>=1*PacketSize ? peeled_mc1 01814 : Pack2>1 ? (rows/Pack2)*Pack2 : 0; 01815 01816 Index i=0; 01817 01818 // Pack 3 packets 01819 if(Pack1>=3*PacketSize) 01820 { 01821 for(; i<peeled_mc3; i+=3*PacketSize) 01822 { 01823 if(PanelMode) count += (3*PacketSize) * offset; 01824 01825 for(Index k=0; k<depth; k++) 01826 { 01827 Packet A, B, C; 01828 A = lhs.loadPacket(i+0*PacketSize, k); 01829 B = lhs.loadPacket(i+1*PacketSize, k); 01830 C = lhs.loadPacket(i+2*PacketSize, k); 01831 pstore(blockA+count, cj.pconj(A)); count+=PacketSize; 01832 pstore(blockA+count, cj.pconj(B)); count+=PacketSize; 01833 pstore(blockA+count, cj.pconj(C)); count+=PacketSize; 01834 } 01835 if(PanelMode) count += (3*PacketSize) * (stride-offset-depth); 01836 } 01837 } 01838 // Pack 2 packets 01839 if(Pack1>=2*PacketSize) 01840 { 01841 for(; i<peeled_mc2; i+=2*PacketSize) 01842 { 01843 if(PanelMode) count += (2*PacketSize) * offset; 01844 01845 for(Index k=0; k<depth; k++) 01846 { 01847 Packet A, B; 01848 A = lhs.loadPacket(i+0*PacketSize, k); 01849 B = lhs.loadPacket(i+1*PacketSize, k); 01850 pstore(blockA+count, cj.pconj(A)); count+=PacketSize; 01851 pstore(blockA+count, cj.pconj(B)); count+=PacketSize; 01852 } 01853 if(PanelMode) count += (2*PacketSize) * (stride-offset-depth); 01854 } 01855 } 01856 // Pack 1 packets 01857 if(Pack1>=1*PacketSize) 01858 { 01859 for(; i<peeled_mc1; i+=1*PacketSize) 01860 { 01861 if(PanelMode) count += (1*PacketSize) * offset; 01862 01863 for(Index k=0; k<depth; k++) 01864 { 01865 Packet A; 01866 A = lhs.loadPacket(i+0*PacketSize, k); 01867 pstore(blockA+count, cj.pconj(A)); 01868 count+=PacketSize; 01869 } 01870 if(PanelMode) count += (1*PacketSize) * (stride-offset-depth); 01871 } 01872 } 01873 // Pack scalars 01874 if(Pack2<PacketSize && Pack2>1) 01875 { 01876 for(; i<peeled_mc0; i+=Pack2) 01877 { 01878 if(PanelMode) count += Pack2 * offset; 01879 01880 for(Index k=0; k<depth; k++) 01881 for(Index w=0; w<Pack2; w++) 01882 blockA[count++] = cj(lhs(i+w, k)); 01883 01884 if(PanelMode) count += Pack2 * (stride-offset-depth); 01885 } 01886 } 01887 for(; i<rows; i++) 01888 { 01889 if(PanelMode) count += offset; 01890 for(Index k=0; k<depth; k++) 01891 blockA[count++] = cj(lhs(i, k)); 01892 if(PanelMode) count += (stride-offset-depth); 01893 } 01894 } 01895 01896 template<typename Scalar, typename Index, typename DataMapper, int Pack1, int Pack2, bool Conjugate, bool PanelMode> 01897 struct gemm_pack_lhs<Scalar, Index, DataMapper, Pack1, Pack2, RowMajor, Conjugate, PanelMode> 01898 { 01899 typedef typename DataMapper::LinearMapper LinearMapper; 01900 EIGEN_DONT_INLINE void operator()(Scalar* blockA, const DataMapper& lhs, Index depth, Index rows, Index stride=0, Index offset=0); 01901 }; 01902 01903 template<typename Scalar, typename Index, typename DataMapper, int Pack1, int Pack2, bool Conjugate, bool PanelMode> 01904 EIGEN_DONT_INLINE void gemm_pack_lhs<Scalar, Index, DataMapper, Pack1, Pack2, RowMajor, Conjugate, PanelMode> 01905 ::operator()(Scalar* blockA, const DataMapper& lhs, Index depth, Index rows, Index stride, Index offset) 01906 { 01907 typedef typename packet_traits<Scalar>::type Packet; 01908 enum { PacketSize = packet_traits<Scalar>::size }; 01909 01910 EIGEN_ASM_COMMENT("EIGEN PRODUCT PACK LHS"); 01911 EIGEN_UNUSED_VARIABLE(stride); 01912 EIGEN_UNUSED_VARIABLE(offset); 01913 eigen_assert(((!PanelMode) && stride==0 && offset==0) || (PanelMode && stride>=depth && offset<=stride)); 01914 conj_if<NumTraits<Scalar>::IsComplex && Conjugate> cj; 01915 Index count = 0; 01916 01917 // const Index peeled_mc3 = Pack1>=3*PacketSize ? (rows/(3*PacketSize))*(3*PacketSize) : 0; 01918 // const Index peeled_mc2 = Pack1>=2*PacketSize ? peeled_mc3+((rows-peeled_mc3)/(2*PacketSize))*(2*PacketSize) : 0; 01919 // const Index peeled_mc1 = Pack1>=1*PacketSize ? (rows/(1*PacketSize))*(1*PacketSize) : 0; 01920 01921 int pack = Pack1; 01922 Index i = 0; 01923 while(pack>0) 01924 { 01925 Index remaining_rows = rows-i; 01926 Index peeled_mc = i+(remaining_rows/pack)*pack; 01927 for(; i<peeled_mc; i+=pack) 01928 { 01929 if(PanelMode) count += pack * offset; 01930 01931 const Index peeled_k = (depth/PacketSize)*PacketSize; 01932 Index k=0; 01933 if(pack>=PacketSize) 01934 { 01935 for(; k<peeled_k; k+=PacketSize) 01936 { 01937 for (Index m = 0; m < pack; m += PacketSize) 01938 { 01939 PacketBlock<Packet> kernel; 01940 for (int p = 0; p < PacketSize; ++p) kernel.packet[p] = lhs.loadPacket(i+p+m, k); 01941 ptranspose(kernel); 01942 for (int p = 0; p < PacketSize; ++p) pstore(blockA+count+m+(pack)*p, cj.pconj(kernel.packet[p])); 01943 } 01944 count += PacketSize*pack; 01945 } 01946 } 01947 for(; k<depth; k++) 01948 { 01949 Index w=0; 01950 for(; w<pack-3; w+=4) 01951 { 01952 Scalar a(cj(lhs(i+w+0, k))), 01953 b(cj(lhs(i+w+1, k))), 01954 c(cj(lhs(i+w+2, k))), 01955 d(cj(lhs(i+w+3, k))); 01956 blockA[count++] = a; 01957 blockA[count++] = b; 01958 blockA[count++] = c; 01959 blockA[count++] = d; 01960 } 01961 if(pack%4) 01962 for(;w<pack;++w) 01963 blockA[count++] = cj(lhs(i+w, k)); 01964 } 01965 01966 if(PanelMode) count += pack * (stride-offset-depth); 01967 } 01968 01969 pack -= PacketSize; 01970 if(pack<Pack2 && (pack+PacketSize)!=Pack2) 01971 pack = Pack2; 01972 } 01973 01974 for(; i<rows; i++) 01975 { 01976 if(PanelMode) count += offset; 01977 for(Index k=0; k<depth; k++) 01978 blockA[count++] = cj(lhs(i, k)); 01979 if(PanelMode) count += (stride-offset-depth); 01980 } 01981 } 01982 01983 // copy a complete panel of the rhs 01984 // this version is optimized for column major matrices 01985 // The traversal order is as follow: (nr==4): 01986 // 0 1 2 3 12 13 14 15 24 27 01987 // 4 5 6 7 16 17 18 19 25 28 01988 // 8 9 10 11 20 21 22 23 26 29 01989 // . . . . . . . . . . 01990 template<typename Scalar, typename Index, typename DataMapper, int nr, bool Conjugate, bool PanelMode> 01991 struct gemm_pack_rhs<Scalar, Index, DataMapper, nr, ColMajor, Conjugate, PanelMode> 01992 { 01993 typedef typename packet_traits<Scalar>::type Packet; 01994 typedef typename DataMapper::LinearMapper LinearMapper; 01995 enum { PacketSize = packet_traits<Scalar>::size }; 01996 EIGEN_DONT_INLINE void operator()(Scalar* blockB, const DataMapper& rhs, Index depth, Index cols, Index stride=0, Index offset=0); 01997 }; 01998 01999 template<typename Scalar, typename Index, typename DataMapper, int nr, bool Conjugate, bool PanelMode> 02000 EIGEN_DONT_INLINE void gemm_pack_rhs<Scalar, Index, DataMapper, nr, ColMajor, Conjugate, PanelMode> 02001 ::operator()(Scalar* blockB, const DataMapper& rhs, Index depth, Index cols, Index stride, Index offset) 02002 { 02003 EIGEN_ASM_COMMENT("EIGEN PRODUCT PACK RHS COLMAJOR"); 02004 EIGEN_UNUSED_VARIABLE(stride); 02005 EIGEN_UNUSED_VARIABLE(offset); 02006 eigen_assert(((!PanelMode) && stride==0 && offset==0) || (PanelMode && stride>=depth && offset<=stride)); 02007 conj_if<NumTraits<Scalar>::IsComplex && Conjugate> cj; 02008 Index packet_cols8 = nr>=8 ? (cols/8) * 8 : 0; 02009 Index packet_cols4 = nr>=4 ? (cols/4) * 4 : 0; 02010 Index count = 0; 02011 const Index peeled_k = (depth/PacketSize)*PacketSize; 02012 // if(nr>=8) 02013 // { 02014 // for(Index j2=0; j2<packet_cols8; j2+=8) 02015 // { 02016 // // skip what we have before 02017 // if(PanelMode) count += 8 * offset; 02018 // const Scalar* b0 = &rhs[(j2+0)*rhsStride]; 02019 // const Scalar* b1 = &rhs[(j2+1)*rhsStride]; 02020 // const Scalar* b2 = &rhs[(j2+2)*rhsStride]; 02021 // const Scalar* b3 = &rhs[(j2+3)*rhsStride]; 02022 // const Scalar* b4 = &rhs[(j2+4)*rhsStride]; 02023 // const Scalar* b5 = &rhs[(j2+5)*rhsStride]; 02024 // const Scalar* b6 = &rhs[(j2+6)*rhsStride]; 02025 // const Scalar* b7 = &rhs[(j2+7)*rhsStride]; 02026 // Index k=0; 02027 // if(PacketSize==8) // TODO enbale vectorized transposition for PacketSize==4 02028 // { 02029 // for(; k<peeled_k; k+=PacketSize) { 02030 // PacketBlock<Packet> kernel; 02031 // for (int p = 0; p < PacketSize; ++p) { 02032 // kernel.packet[p] = ploadu<Packet>(&rhs[(j2+p)*rhsStride+k]); 02033 // } 02034 // ptranspose(kernel); 02035 // for (int p = 0; p < PacketSize; ++p) { 02036 // pstoreu(blockB+count, cj.pconj(kernel.packet[p])); 02037 // count+=PacketSize; 02038 // } 02039 // } 02040 // } 02041 // for(; k<depth; k++) 02042 // { 02043 // blockB[count+0] = cj(b0[k]); 02044 // blockB[count+1] = cj(b1[k]); 02045 // blockB[count+2] = cj(b2[k]); 02046 // blockB[count+3] = cj(b3[k]); 02047 // blockB[count+4] = cj(b4[k]); 02048 // blockB[count+5] = cj(b5[k]); 02049 // blockB[count+6] = cj(b6[k]); 02050 // blockB[count+7] = cj(b7[k]); 02051 // count += 8; 02052 // } 02053 // // skip what we have after 02054 // if(PanelMode) count += 8 * (stride-offset-depth); 02055 // } 02056 // } 02057 02058 if(nr>=4) 02059 { 02060 for(Index j2=packet_cols8; j2<packet_cols4; j2+=4) 02061 { 02062 // skip what we have before 02063 if(PanelMode) count += 4 * offset; 02064 const LinearMapper dm0 = rhs.getLinearMapper(0, j2 + 0); 02065 const LinearMapper dm1 = rhs.getLinearMapper(0, j2 + 1); 02066 const LinearMapper dm2 = rhs.getLinearMapper(0, j2 + 2); 02067 const LinearMapper dm3 = rhs.getLinearMapper(0, j2 + 3); 02068 02069 Index k=0; 02070 if((PacketSize%4)==0) // TODO enable vectorized transposition for PacketSize==2 ?? 02071 { 02072 for(; k<peeled_k; k+=PacketSize) { 02073 PacketBlock<Packet,(PacketSize%4)==0?4:PacketSize> kernel; 02074 kernel.packet[0] = dm0.loadPacket(k); 02075 kernel.packet[1%PacketSize] = dm1.loadPacket(k); 02076 kernel.packet[2%PacketSize] = dm2.loadPacket(k); 02077 kernel.packet[3%PacketSize] = dm3.loadPacket(k); 02078 ptranspose(kernel); 02079 pstoreu(blockB+count+0*PacketSize, cj.pconj(kernel.packet[0])); 02080 pstoreu(blockB+count+1*PacketSize, cj.pconj(kernel.packet[1%PacketSize])); 02081 pstoreu(blockB+count+2*PacketSize, cj.pconj(kernel.packet[2%PacketSize])); 02082 pstoreu(blockB+count+3*PacketSize, cj.pconj(kernel.packet[3%PacketSize])); 02083 count+=4*PacketSize; 02084 } 02085 } 02086 for(; k<depth; k++) 02087 { 02088 blockB[count+0] = cj(dm0(k)); 02089 blockB[count+1] = cj(dm1(k)); 02090 blockB[count+2] = cj(dm2(k)); 02091 blockB[count+3] = cj(dm3(k)); 02092 count += 4; 02093 } 02094 // skip what we have after 02095 if(PanelMode) count += 4 * (stride-offset-depth); 02096 } 02097 } 02098 02099 // copy the remaining columns one at a time (nr==1) 02100 for(Index j2=packet_cols4; j2<cols; ++j2) 02101 { 02102 if(PanelMode) count += offset; 02103 const LinearMapper dm0 = rhs.getLinearMapper(0, j2); 02104 for(Index k=0; k<depth; k++) 02105 { 02106 blockB[count] = cj(dm0(k)); 02107 count += 1; 02108 } 02109 if(PanelMode) count += (stride-offset-depth); 02110 } 02111 } 02112 02113 // this version is optimized for row major matrices 02114 template<typename Scalar, typename Index, typename DataMapper, int nr, bool Conjugate, bool PanelMode> 02115 struct gemm_pack_rhs<Scalar, Index, DataMapper, nr, RowMajor, Conjugate, PanelMode> 02116 { 02117 typedef typename packet_traits<Scalar>::type Packet; 02118 typedef typename DataMapper::LinearMapper LinearMapper; 02119 enum { PacketSize = packet_traits<Scalar>::size }; 02120 EIGEN_DONT_INLINE void operator()(Scalar* blockB, const DataMapper& rhs, Index depth, Index cols, Index stride=0, Index offset=0); 02121 }; 02122 02123 template<typename Scalar, typename Index, typename DataMapper, int nr, bool Conjugate, bool PanelMode> 02124 EIGEN_DONT_INLINE void gemm_pack_rhs<Scalar, Index, DataMapper, nr, RowMajor, Conjugate, PanelMode> 02125 ::operator()(Scalar* blockB, const DataMapper& rhs, Index depth, Index cols, Index stride, Index offset) 02126 { 02127 EIGEN_ASM_COMMENT("EIGEN PRODUCT PACK RHS ROWMAJOR"); 02128 EIGEN_UNUSED_VARIABLE(stride); 02129 EIGEN_UNUSED_VARIABLE(offset); 02130 eigen_assert(((!PanelMode) && stride==0 && offset==0) || (PanelMode && stride>=depth && offset<=stride)); 02131 conj_if<NumTraits<Scalar>::IsComplex && Conjugate> cj; 02132 Index packet_cols8 = nr>=8 ? (cols/8) * 8 : 0; 02133 Index packet_cols4 = nr>=4 ? (cols/4) * 4 : 0; 02134 Index count = 0; 02135 02136 // if(nr>=8) 02137 // { 02138 // for(Index j2=0; j2<packet_cols8; j2+=8) 02139 // { 02140 // // skip what we have before 02141 // if(PanelMode) count += 8 * offset; 02142 // for(Index k=0; k<depth; k++) 02143 // { 02144 // if (PacketSize==8) { 02145 // Packet A = ploadu<Packet>(&rhs[k*rhsStride + j2]); 02146 // pstoreu(blockB+count, cj.pconj(A)); 02147 // } else if (PacketSize==4) { 02148 // Packet A = ploadu<Packet>(&rhs[k*rhsStride + j2]); 02149 // Packet B = ploadu<Packet>(&rhs[k*rhsStride + j2 + PacketSize]); 02150 // pstoreu(blockB+count, cj.pconj(A)); 02151 // pstoreu(blockB+count+PacketSize, cj.pconj(B)); 02152 // } else { 02153 // const Scalar* b0 = &rhs[k*rhsStride + j2]; 02154 // blockB[count+0] = cj(b0[0]); 02155 // blockB[count+1] = cj(b0[1]); 02156 // blockB[count+2] = cj(b0[2]); 02157 // blockB[count+3] = cj(b0[3]); 02158 // blockB[count+4] = cj(b0[4]); 02159 // blockB[count+5] = cj(b0[5]); 02160 // blockB[count+6] = cj(b0[6]); 02161 // blockB[count+7] = cj(b0[7]); 02162 // } 02163 // count += 8; 02164 // } 02165 // // skip what we have after 02166 // if(PanelMode) count += 8 * (stride-offset-depth); 02167 // } 02168 // } 02169 if(nr>=4) 02170 { 02171 for(Index j2=packet_cols8; j2<packet_cols4; j2+=4) 02172 { 02173 // skip what we have before 02174 if(PanelMode) count += 4 * offset; 02175 for(Index k=0; k<depth; k++) 02176 { 02177 if (PacketSize==4) { 02178 Packet A = rhs.loadPacket(k, j2); 02179 pstoreu(blockB+count, cj.pconj(A)); 02180 count += PacketSize; 02181 } else { 02182 const LinearMapper dm0 = rhs.getLinearMapper(k, j2); 02183 blockB[count+0] = cj(dm0(0)); 02184 blockB[count+1] = cj(dm0(1)); 02185 blockB[count+2] = cj(dm0(2)); 02186 blockB[count+3] = cj(dm0(3)); 02187 count += 4; 02188 } 02189 } 02190 // skip what we have after 02191 if(PanelMode) count += 4 * (stride-offset-depth); 02192 } 02193 } 02194 // copy the remaining columns one at a time (nr==1) 02195 for(Index j2=packet_cols4; j2<cols; ++j2) 02196 { 02197 if(PanelMode) count += offset; 02198 for(Index k=0; k<depth; k++) 02199 { 02200 blockB[count] = cj(rhs(k, j2)); 02201 count += 1; 02202 } 02203 if(PanelMode) count += stride-offset-depth; 02204 } 02205 } 02206 02207 } // end namespace internal 02208 02211 inline std::ptrdiff_t l1CacheSize() 02212 { 02213 std::ptrdiff_t l1, l2, l3; 02214 internal::manage_caching_sizes(GetAction, &l1, &l2, &l3); 02215 return l1; 02216 } 02217 02220 inline std::ptrdiff_t l2CacheSize() 02221 { 02222 std::ptrdiff_t l1, l2, l3; 02223 internal::manage_caching_sizes(GetAction, &l1, &l2, &l3); 02224 return l2; 02225 } 02226 02232 inline void setCpuCacheSizes(std::ptrdiff_t l1, std::ptrdiff_t l2, std::ptrdiff_t l3) 02233 { 02234 internal::manage_caching_sizes(SetAction, &l1, &l2, &l3); 02235 } 02236 02237 } // end namespace Eigen 02238 02239 #endif // EIGEN_GENERAL_BLOCK_PANEL_H
