MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2007-2010 Benoit Jacob <[email protected]> 00005 // Copyright (C) 2008 Gael Guennebaud <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_MAPBASE_H 00012 #define EIGEN_MAPBASE_H 00013 00014 #define EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) \ 00015 EIGEN_STATIC_ASSERT((int(internal::evaluator<Derived>::Flags) & LinearAccessBit) || Derived::IsVectorAtCompileTime, \ 00016 YOU_ARE_TRYING_TO_USE_AN_INDEX_BASED_ACCESSOR_ON_AN_EXPRESSION_THAT_DOES_NOT_SUPPORT_THAT) 00017 00018 namespace Eigen { 00019 00027 template<typename Derived> class MapBase<Derived, ReadOnlyAccessors> 00028 : public internal::dense_xpr_base<Derived>::type 00029 { 00030 public: 00031 00032 typedef typename internal::dense_xpr_base<Derived>::type Base; 00033 enum { 00034 RowsAtCompileTime = internal::traits<Derived>::RowsAtCompileTime, 00035 ColsAtCompileTime = internal::traits<Derived>::ColsAtCompileTime, 00036 SizeAtCompileTime = Base::SizeAtCompileTime 00037 }; 00038 00039 typedef typename internal::traits<Derived>::StorageKind StorageKind; 00040 typedef typename internal::traits<Derived>::Scalar Scalar; 00041 typedef typename internal::packet_traits<Scalar>::type PacketScalar; 00042 typedef typename NumTraits<Scalar>::Real RealScalar; 00043 typedef typename internal::conditional< 00044 bool(internal::is_lvalue<Derived>::value), 00045 Scalar *, 00046 const Scalar *>::type 00047 PointerType; 00048 00049 using Base::derived; 00050 // using Base::RowsAtCompileTime; 00051 // using Base::ColsAtCompileTime; 00052 // using Base::SizeAtCompileTime; 00053 using Base::MaxRowsAtCompileTime; 00054 using Base::MaxColsAtCompileTime; 00055 using Base::MaxSizeAtCompileTime; 00056 using Base::IsVectorAtCompileTime; 00057 using Base::Flags; 00058 using Base::IsRowMajor; 00059 00060 using Base::rows; 00061 using Base::cols; 00062 using Base::size; 00063 using Base::coeff; 00064 using Base::coeffRef; 00065 using Base::lazyAssign; 00066 using Base::eval; 00067 00068 using Base::innerStride; 00069 using Base::outerStride; 00070 using Base::rowStride; 00071 using Base::colStride; 00072 00073 // bug 217 - compile error on ICC 11.1 00074 using Base::operator=; 00075 00076 typedef typename Base::CoeffReturnType CoeffReturnType; 00077 00078 EIGEN_DEVICE_FUNC inline Index rows() const { return m_rows.value(); } 00079 EIGEN_DEVICE_FUNC inline Index cols() const { return m_cols.value(); } 00080 00087 EIGEN_DEVICE_FUNC inline const Scalar* data() const { return m_data; } 00088 00089 EIGEN_DEVICE_FUNC 00090 inline const Scalar& coeff(Index rowId, Index colId) const 00091 { 00092 return m_data[colId * colStride() + rowId * rowStride()]; 00093 } 00094 00095 EIGEN_DEVICE_FUNC 00096 inline const Scalar& coeff(Index index) const 00097 { 00098 EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) 00099 return m_data[index * innerStride()]; 00100 } 00101 00102 EIGEN_DEVICE_FUNC 00103 inline const Scalar& coeffRef(Index rowId, Index colId) const 00104 { 00105 return this->m_data[colId * colStride() + rowId * rowStride()]; 00106 } 00107 00108 EIGEN_DEVICE_FUNC 00109 inline const Scalar& coeffRef(Index index) const 00110 { 00111 EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) 00112 return this->m_data[index * innerStride()]; 00113 } 00114 00115 template<int LoadMode> 00116 inline PacketScalar packet(Index rowId, Index colId) const 00117 { 00118 return internal::ploadt<PacketScalar, LoadMode> 00119 (m_data + (colId * colStride() + rowId * rowStride())); 00120 } 00121 00122 template<int LoadMode> 00123 inline PacketScalar packet(Index index) const 00124 { 00125 EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) 00126 return internal::ploadt<PacketScalar, LoadMode>(m_data + index * innerStride()); 00127 } 00128 00129 EIGEN_DEVICE_FUNC 00130 explicit inline MapBase(PointerType dataPtr) : m_data(dataPtr), m_rows(RowsAtCompileTime), m_cols(ColsAtCompileTime) 00131 { 00132 EIGEN_STATIC_ASSERT_FIXED_SIZE(Derived) 00133 checkSanity<Derived>(); 00134 } 00135 00136 EIGEN_DEVICE_FUNC 00137 inline MapBase(PointerType dataPtr, Index vecSize) 00138 : m_data(dataPtr), 00139 m_rows(RowsAtCompileTime == Dynamic ? vecSize : Index(RowsAtCompileTime)), 00140 m_cols(ColsAtCompileTime == Dynamic ? vecSize : Index(ColsAtCompileTime)) 00141 { 00142 EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived) 00143 eigen_assert(vecSize >= 0); 00144 eigen_assert(dataPtr == 0 || SizeAtCompileTime == Dynamic || SizeAtCompileTime == vecSize); 00145 checkSanity<Derived>(); 00146 } 00147 00148 EIGEN_DEVICE_FUNC 00149 inline MapBase(PointerType dataPtr, Index rows, Index cols) 00150 : m_data(dataPtr), m_rows(rows), m_cols(cols) 00151 { 00152 eigen_assert( (dataPtr == 0) 00153 || ( rows >= 0 && (RowsAtCompileTime == Dynamic || RowsAtCompileTime == rows) 00154 && cols >= 0 && (ColsAtCompileTime == Dynamic || ColsAtCompileTime == cols))); 00155 checkSanity<Derived>(); 00156 } 00157 00158 #ifdef EIGEN_MAPBASE_PLUGIN 00159 #include EIGEN_MAPBASE_PLUGIN 00160 #endif 00161 00162 protected: 00163 00164 template<typename T> 00165 EIGEN_DEVICE_FUNC 00166 void checkSanity(typename internal::enable_if<(internal::traits<T>::Alignment>0),void*>::type = 0) const 00167 { 00168 #if EIGEN_MAX_ALIGN_BYTES>0 00169 eigen_assert(( ((size_t(m_data) % internal::traits<Derived>::Alignment) == 0) 00170 || (cols() * rows() * innerStride() * sizeof(Scalar)) < internal::traits<Derived>::Alignment ) && "data is not aligned"); 00171 #endif 00172 } 00173 00174 template<typename T> 00175 EIGEN_DEVICE_FUNC 00176 void checkSanity(typename internal::enable_if<internal::traits<T>::Alignment==0,void*>::type = 0) const 00177 {} 00178 00179 PointerType m_data; 00180 const internal::variable_if_dynamic<Index, RowsAtCompileTime> m_rows; 00181 const internal::variable_if_dynamic<Index, ColsAtCompileTime> m_cols; 00182 }; 00183 00184 template<typename Derived> class MapBase<Derived, WriteAccessors> 00185 : public MapBase<Derived, ReadOnlyAccessors> 00186 { 00187 typedef MapBase<Derived, ReadOnlyAccessors> ReadOnlyMapBase; 00188 public: 00189 00190 typedef MapBase<Derived, ReadOnlyAccessors> Base; 00191 00192 typedef typename Base::Scalar Scalar; 00193 typedef typename Base::PacketScalar PacketScalar; 00194 typedef typename Base::StorageIndex StorageIndex; 00195 typedef typename Base::PointerType PointerType; 00196 00197 using Base::derived; 00198 using Base::rows; 00199 using Base::cols; 00200 using Base::size; 00201 using Base::coeff; 00202 using Base::coeffRef; 00203 00204 using Base::innerStride; 00205 using Base::outerStride; 00206 using Base::rowStride; 00207 using Base::colStride; 00208 00209 typedef typename internal::conditional< 00210 internal::is_lvalue<Derived>::value, 00211 Scalar, 00212 const Scalar 00213 >::type ScalarWithConstIfNotLvalue; 00214 00215 EIGEN_DEVICE_FUNC 00216 inline const Scalar* data() const { return this->m_data; } 00217 EIGEN_DEVICE_FUNC 00218 inline ScalarWithConstIfNotLvalue* data() { return this->m_data; } // no const-cast here so non-const-correct code will give a compile error 00219 00220 EIGEN_DEVICE_FUNC 00221 inline ScalarWithConstIfNotLvalue& coeffRef(Index row, Index col) 00222 { 00223 return this->m_data[col * colStride() + row * rowStride()]; 00224 } 00225 00226 EIGEN_DEVICE_FUNC 00227 inline ScalarWithConstIfNotLvalue& coeffRef(Index index) 00228 { 00229 EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) 00230 return this->m_data[index * innerStride()]; 00231 } 00232 00233 template<int StoreMode> 00234 inline void writePacket(Index row, Index col, const PacketScalar& val) 00235 { 00236 internal::pstoret<Scalar, PacketScalar, StoreMode> 00237 (this->m_data + (col * colStride() + row * rowStride()), val); 00238 } 00239 00240 template<int StoreMode> 00241 inline void writePacket(Index index, const PacketScalar& val) 00242 { 00243 EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS(Derived) 00244 internal::pstoret<Scalar, PacketScalar, StoreMode> 00245 (this->m_data + index * innerStride(), val); 00246 } 00247 00248 EIGEN_DEVICE_FUNC explicit inline MapBase(PointerType dataPtr) : Base(dataPtr) {} 00249 EIGEN_DEVICE_FUNC inline MapBase(PointerType dataPtr, Index vecSize) : Base(dataPtr, vecSize) {} 00250 EIGEN_DEVICE_FUNC inline MapBase(PointerType dataPtr, Index p_rows, Index p_cols) : Base(dataPtr, p_rows, p_cols) {} 00251 00252 EIGEN_DEVICE_FUNC 00253 Derived& operator=(const MapBase& other) 00254 { 00255 ReadOnlyMapBase::Base::operator=(other); 00256 return derived(); 00257 } 00258 00259 // In theory we could simply refer to Base:Base::operator=, but MSVC does not like Base::Base, 00260 // see bugs 821 and 920. 00261 using ReadOnlyMapBase::Base::operator=; 00262 }; 00263 00264 #undef EIGEN_STATIC_ASSERT_INDEX_BASED_ACCESS 00265 00266 } // end namespace Eigen 00267 00268 #endif // EIGEN_MAPBASE_H
