MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file MeshDecorator.hpp 00028 * \brief Definition of MBMesquite::MeshDecorator class 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_MESH_DECORATOR_HPP 00033 #define MSQ_MESH_DECORATOR_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "MeshInterface.hpp" 00037 00038 namespace MBMesquite 00039 { 00040 00041 /**\brief Utility class for implementing decorators for the MBMesquite::Mesh interface 00042 * 00043 * This is a utility class that to assist with implementing decorators 00044 * for the MBMesquite::Mesh interface. This class implements a "dumb" 00045 * decorator that passes all operations to its underlying (decorated) 00046 * Mesh instance unchanged. The intention is that useful decorators 00047 * subclass this class, overriding only those functions for which they 00048 * modify the behavioir. 00049 */ 00050 class MESQUITE_EXPORT MeshDecorator : public Mesh 00051 { 00052 private: 00053 Mesh* myMesh; //< The actual Mesh this instance decorates 00054 00055 protected: 00056 void set_mesh( Mesh* mesh ); 00057 00058 public: 00059 MeshDecorator(); 00060 MeshDecorator( Mesh* real_mesh ); 00061 00062 virtual ~MeshDecorator(); 00063 00064 /**\brief Get the real Mesh instance */ 00065 Mesh* get_mesh() const 00066 { 00067 return myMesh; 00068 } 00069 00070 //************ Operations on entire mesh **************** 00071 00072 virtual int get_geometric_dimension( MsqError& err ); 00073 00074 virtual void get_all_elements( std::vector< ElementHandle >& elements, MsqError& err ); 00075 00076 virtual void get_all_vertices( std::vector< VertexHandle >& vertices, MsqError& err ); 00077 00078 //************ Vertex Properties ******************** 00079 00080 virtual void vertices_get_fixed_flag( const VertexHandle vert_array[], 00081 std::vector< bool >& fixed_flag_array, 00082 size_t num_vtx, 00083 MsqError& err ); 00084 00085 virtual void vertices_get_slaved_flag( const VertexHandle vert_array[], 00086 std::vector< bool >& slaved_flag_array, 00087 size_t num_vtx, 00088 MsqError& err ); 00089 00090 virtual void vertices_get_coordinates( const VertexHandle vert_array[], 00091 MsqVertex* coordinates, 00092 size_t num_vtx, 00093 MsqError& err ); 00094 00095 virtual void vertex_set_coordinates( VertexHandle vertex, const Vector3D& coordinates, MsqError& err ); 00096 00097 virtual void vertex_set_byte( VertexHandle vertex, unsigned char byte, MsqError& err ); 00098 00099 virtual void vertices_set_byte( const VertexHandle* vert_array, 00100 const unsigned char* byte_array, 00101 size_t array_size, 00102 MsqError& err ); 00103 00104 virtual void vertex_get_byte( const VertexHandle vertex, unsigned char* byte, MsqError& err ); 00105 00106 virtual void vertices_get_byte( const VertexHandle* vertex, 00107 unsigned char* byte_array, 00108 size_t array_size, 00109 MsqError& err ); 00110 00111 //**************** Vertex Topology ***************** 00112 00113 virtual void vertices_get_attached_elements( const VertexHandle* vertex_array, 00114 size_t num_vertex, 00115 std::vector< ElementHandle >& elements, 00116 std::vector< size_t >& offsets, 00117 MsqError& err ); 00118 00119 //*************** Element Topology ************* 00120 00121 virtual void elements_get_attached_vertices( const ElementHandle* elem_handles, 00122 size_t num_elems, 00123 std::vector< VertexHandle >& vert_handles, 00124 std::vector< size_t >& offsets, 00125 MsqError& err ); 00126 00127 virtual void elements_get_topologies( const ElementHandle* element_handle_array, 00128 EntityTopology* element_topologies, 00129 size_t num_elements, 00130 MsqError& err ); 00131 00132 //*************** Tags *********** 00133 00134 virtual TagHandle tag_create( const std::string& tag_name, 00135 TagType type, 00136 unsigned length, 00137 const void* default_value, 00138 MsqError& err ); 00139 00140 virtual void tag_delete( TagHandle handle, MsqError& err ); 00141 00142 virtual TagHandle tag_get( const std::string& name, MsqError& err ); 00143 00144 virtual void tag_properties( TagHandle handle, 00145 std::string& name_out, 00146 TagType& type_out, 00147 unsigned& length_out, 00148 MsqError& err ); 00149 00150 virtual void tag_set_element_data( TagHandle handle, 00151 size_t num_elems, 00152 const ElementHandle* elem_array, 00153 const void* tag_data, 00154 MsqError& err ); 00155 00156 virtual void tag_set_vertex_data( TagHandle handle, 00157 size_t num_elems, 00158 const VertexHandle* node_array, 00159 const void* tag_data, 00160 MsqError& err ); 00161 00162 virtual void tag_get_element_data( TagHandle handle, 00163 size_t num_elems, 00164 const ElementHandle* elem_array, 00165 void* tag_data, 00166 MsqError& err ); 00167 00168 virtual void tag_get_vertex_data( TagHandle handle, 00169 size_t num_elems, 00170 const VertexHandle* node_array, 00171 void* tag_data, 00172 MsqError& err ); 00173 00174 //**************** Memory Management **************** 00175 00176 virtual void release_entity_handles( const EntityHandle* handle_array, size_t num_handles, MsqError& err ); 00177 00178 virtual void release(); 00179 }; 00180 00181 } // namespace MBMesquite 00182 00183 #endif
