MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file MeshTag.hpp 00002 * \author Jason Kraftcheck 00003 * \date 2010-12-14 00004 */ 00005 00006 #ifndef MESH_TAG_HPP 00007 #define MESH_TAG_HPP 00008 00009 #include "TagInfo.hpp" 00010 00011 namespace moab 00012 { 00013 00014 /**\brief Tag with only a global/mesh value 00015 * 00016 * Trivial tag implementation. No per-entity values. Only 00017 * the global mesh value which is handled by the \c TagInfo 00018 * base class. 00019 */ 00020 class MeshTag : public TagInfo 00021 { 00022 public: 00023 //! constructor that takes all parameters 00024 MeshTag( const char* name, int size, DataType type, const void* default_value, int default_value_size ); 00025 00026 virtual ~MeshTag(); 00027 00028 virtual TagType get_storage_type() const; 00029 00030 /**\brief Remove/clear tag data for all entities 00031 * 00032 * Remove tag values from entities. 00033 * 00034 *\param delete_pending If true, then release any global 00035 * data associated with the tag in preparation for deleting 00036 * the tag itself. 00037 * 00038 *\Note Invalidates tag if \c tag_delete_pending is true. The only 00039 * valid method that can be invoked that is is the destructor. 00040 * 00041 *\param seqman Pointer to mesh entity database 00042 */ 00043 virtual ErrorCode release_all_data( SequenceManager* seqman, Error* error_handler, bool delete_pending ); 00044 00045 /**\brief Get tag value for passed entities 00046 * 00047 * Get tag values for specified entities. 00048 * 00049 *\Note Will fail for variable-length data. 00050 *\param seqman Pointer to mesh entity database 00051 *\param entities Entity handles for which to retrieve tag data 00052 *\param num_entities Length of \c entities array 00053 *\param data Pointer to memory in which to store consecutive tag values, 00054 * one for each passed entity. 00055 */ 00056 virtual ErrorCode get_data( const SequenceManager* seqman, 00057 Error* error_handler, 00058 const EntityHandle* entities, 00059 size_t num_entities, 00060 void* data ) const; 00061 00062 /**\brief Get tag value for passed entities 00063 * 00064 * Get tag values for specified entities. 00065 * 00066 *\Note Will fail for variable-length data. 00067 *\param seqman Pointer to mesh entity database 00068 *\param entities Entity handles for which to retrieve tag data 00069 *\param data Pointer to memory in which to store consecutive tag values, 00070 * one for each passed entity. 00071 */ 00072 virtual ErrorCode get_data( const SequenceManager* seqman, 00073 Error* error_handler, 00074 const Range& entities, 00075 void* data ) const; 00076 00077 /**\brief Get tag value for passed entities 00078 * 00079 * Get tag values for specified entities. 00080 * 00081 *\param seqman Pointer to mesh entity database 00082 *\param entities Entity handles for which to retrieve tag data 00083 *\param num_entities Length of \c entities array 00084 *\param data_ptrs Array of pointers to tag values, one pointer 00085 * for each passed entity. 00086 *\param data_lengths One value for each entity specifying the 00087 * length of the tag value for the corresponding 00088 * entity. 00089 */ 00090 virtual ErrorCode get_data( const SequenceManager* seqman, 00091 Error* error_handler, 00092 const EntityHandle* entities, 00093 size_t num_entities, 00094 const void** data_ptrs, 00095 int* data_lengths ) const; 00096 00097 /**\brief Get tag value for passed entities 00098 * 00099 * Get tag values for specified entities. 00100 * 00101 *\param seqman Pointer to mesh entity database 00102 *\param entities Entity handles for which to retrieve tag data 00103 *\param data_ptrs Array of pointers to tag values, one pointer 00104 * for each passed entity. 00105 *\param data_lengths One value for each entity specifying the 00106 * length of the tag value for the corresponding 00107 * entity. 00108 */ 00109 virtual ErrorCode get_data( const SequenceManager* seqman, 00110 Error* error_handler, 00111 const Range& entities, 00112 const void** data_ptrs, 00113 int* data_lengths ) const; 00114 00115 /**\brief Set tag value for passed entities 00116 * 00117 * Store tag data or update stored tag values 00118 *\Note Will fail for variable-length data. 00119 *\param seqman Pointer to mesh entity database 00120 *\param entities Entity handles for which to store tag data 00121 *\param num_entities Length of \c entities array 00122 *\param data Pointer to memory holding consecutive tag values, 00123 * one for each passed entity. 00124 */ 00125 virtual ErrorCode set_data( SequenceManager* seqman, 00126 Error* error_handler, 00127 const EntityHandle* entities, 00128 size_t num_entities, 00129 const void* data ); 00130 00131 /**\brief Set tag value for passed entities 00132 * 00133 * Store tag data or update stored tag values 00134 *\Note Will fail for variable-length data. 00135 *\param seqman Pointer to mesh entity database 00136 *\param entities Entity handles for which to store tag data 00137 *\param data Pointer to memory holding consecutive tag values, 00138 * one for each passed entity. 00139 */ 00140 virtual ErrorCode set_data( SequenceManager* seqman, 00141 Error* error_handler, 00142 const Range& entities, 00143 const void* data ); 00144 00145 /**\brief Set tag value for passed entities 00146 * 00147 * Store tag data or update stored tag values 00148 * 00149 *\param seqman Pointer to mesh entity database 00150 *\param entities Entity handles for which to store tag data 00151 *\param num_entities Length of \c entities array 00152 *\param data_ptrs Array of pointers to tag values, one pointer 00153 * for each passed entity. 00154 *\param data_lengths One value for each entity specifying the 00155 * length of the tag value for the corresponding 00156 * entity. Array is required for variable-length 00157 * tags and is ignored for fixed-length tags. 00158 */ 00159 virtual ErrorCode set_data( SequenceManager* seqman, 00160 Error* error_handler, 00161 const EntityHandle* entities, 00162 size_t num_entities, 00163 void const* const* data_ptrs, 00164 const int* data_lengths ); 00165 00166 /**\brief Set tag value for passed entities 00167 * 00168 * Store tag data or update stored tag values 00169 * 00170 *\param seqman Pointer to mesh entity database 00171 *\param entities Entity handles for which to store tag data 00172 *\param data_ptrs Array of pointers to tag values, one pointer 00173 * for each passed entity. 00174 *\param data_lengths One value for each entity specifying the 00175 * length of the tag value for the corresponding 00176 * entity. Array is required for variable-length 00177 * tags and is ignored for fixed-length tags. 00178 */ 00179 virtual ErrorCode set_data( SequenceManager* seqman, 00180 Error* error_handler, 00181 const Range& entities, 00182 void const* const* data_ptrs, 00183 const int* data_lengths ); 00184 00185 /**\brief Set tag value for passed entities 00186 * 00187 * Store tag data or update stored tag values. 00188 * 00189 *\param seqman Pointer to mesh entity database 00190 *\param entities Entity handles for which to store tag data 00191 *\param num_entities Length of \c entities array 00192 *\param value_ptr Pointer to a single tag value which is to be 00193 * stored for each of the passed entities. 00194 *\param value_len Length of tag value in bytes. Ignored for 00195 * fixed-length tags. Required for variable- 00196 * length tags. 00197 */ 00198 virtual ErrorCode clear_data( SequenceManager* seqman, 00199 Error* error_handler, 00200 const EntityHandle* entities, 00201 size_t num_entities, 00202 const void* value_ptr, 00203 int value_len = 0 ); 00204 00205 /**\brief Set tag value for passed entities 00206 * 00207 * Store tag data or update stored tag values. 00208 * 00209 *\param seqman Pointer to mesh entity database 00210 *\param entities Entity handles for which to store tag data 00211 *\param value_ptr Pointer to a single tag value which is to be 00212 * stored for each of the passed entities. 00213 *\param value_len Length of tag value in bytes. Ignored for 00214 * fixed-length tags. Required for variable- 00215 * length tags. 00216 */ 00217 virtual ErrorCode clear_data( SequenceManager* seqman, 00218 Error* error_handler, 00219 const Range& entities, 00220 const void* value_ptr, 00221 int value_len = 0 ); 00222 00223 /**\brief Remove/clear tag data for entities 00224 * 00225 * Remove tag values from entities. 00226 * 00227 *\param seqman Pointer to mesh entity database 00228 *\param entities Entity handles for which to store tag data 00229 *\param num_entities Length of \c entities array 00230 */ 00231 virtual ErrorCode remove_data( SequenceManager* seqman, 00232 Error* error_handler, 00233 const EntityHandle* entities, 00234 size_t num_entities ); 00235 00236 /**\brief Remove/clear tag data for entities 00237 * 00238 * Remove tag values from entities. 00239 * 00240 *\param seqman Pointer to mesh entity database 00241 *\param entities Entity handles for which to store tag data 00242 */ 00243 virtual ErrorCode remove_data( SequenceManager* seqman, Error* error_handler, const Range& entities ); 00244 00245 /**\brief Access tag data via direct pointer into contiguous blocks 00246 * 00247 * Iteratively obtain direct access to contiguous blocks of tag 00248 * storage. This function cannot be used with bit tags because 00249 * of the compressed bit storage. This function cannot be used 00250 * with variable length tags because it does not provide a mechanism 00251 * to determine the length of the value for each entity. This 00252 * function may be used with sparse tags, but if it is used, it 00253 * will return data for a single entity at a time. 00254 * 00255 *\param iter As input, the first entity for which to return 00256 * data. As output, one past the last entity for 00257 * which data was returned. 00258 *\param end One past the last entity for which data is desired 00259 *\param data_ptr Output: pointer to tag storage. 00260 *\param allocate If true, allocate space for this tag as part of this call, else don't 00261 * 00262 *\Note If this function is called for entities for which no tag value 00263 * has been set, but for which a default value exists, it will 00264 * force the allocation of explicit storage for each such entity 00265 * even though MOAB would normally not explicitly store tag values 00266 * for such entities. 00267 */ 00268 virtual ErrorCode tag_iterate( SequenceManager* seqman, 00269 Error* error_handler, 00270 Range::iterator& iter, 00271 const Range::iterator& end, 00272 void*& data_ptr, 00273 bool allocate = true ); 00274 00275 /**\brief Get all tagged entities 00276 * 00277 * Get the list of entities for which the a tag value has been set, 00278 * or a close approximation if the tag storage scheme cannot 00279 * accurately determine exactly which entities have explicit values. 00280 * 00281 *\param seqman Pointer to entity storage database 00282 *\param output_entities Results *appended* to this range 00283 *\param type Optional entity type. If specified, search is 00284 * limited to entities of specified type. 00285 *\param intersect Optional intersect list. If specified, 00286 * search is restricted to entities in this list. 00287 */ 00288 virtual ErrorCode get_tagged_entities( const SequenceManager* seqman, 00289 Range& output_entities, 00290 EntityType type = MBMAXTYPE, 00291 const Range* intersect = 0 ) const; 00292 00293 /**\brief Count all tagged entities 00294 * 00295 * Count the entities for which the a tag value has been set, 00296 * or a close approximation if the tag storage scheme cannot 00297 * accurately determine exactly which entities have explicit values. 00298 * 00299 *\param seqman Pointer to entity storage database 00300 *\param output_count This is *incremented* for each detected entity. 00301 *\param type Optional entity type. If specified, search is 00302 * limited to entities of specified type. 00303 *\param intersect Optional intersect list. If specified, 00304 * search is restricted to entities in this list. 00305 */ 00306 virtual ErrorCode num_tagged_entities( const SequenceManager* seqman, 00307 size_t& output_count, 00308 EntityType type = MBMAXTYPE, 00309 const Range* intersect = 0 ) const; 00310 00311 /**\brief Get all tagged entities with tag value 00312 * 00313 * Get the list of entities which have the specified tag value. 00314 * 00315 *\param seqman Pointer to entity storage database 00316 *\param output_entities Results *appended* to this range 00317 *\param value Pointer to tag value 00318 *\param value_bytes Size of tag value in bytes. 00319 *\param type Optional entity type. If specified, search is 00320 * limited to entities of specified type. 00321 *\param intersect_entities Optional intersect list. If specified, 00322 * search is restricted to entities in this list. 00323 */ 00324 virtual ErrorCode find_entities_with_value( const SequenceManager* seqman, 00325 Error* error_handler, 00326 Range& output_entities, 00327 const void* value, 00328 int value_bytes = 0, 00329 EntityType type = MBMAXTYPE, 00330 const Range* intersect_entities = 0 ) const; 00331 00332 /**\brief Check if entity is tagged */ 00333 virtual bool is_tagged( const SequenceManager*, EntityHandle h ) const; 00334 00335 /**\brief Get memory use for tag data. 00336 * 00337 */ 00338 virtual ErrorCode get_memory_use( const SequenceManager* seqman, 00339 unsigned long& total, 00340 unsigned long& per_entity ) const; 00341 00342 private: 00343 MeshTag( const MeshTag& ); 00344 MeshTag& operator=( const MeshTag& ); 00345 std::vector< unsigned char > mValue; 00346 }; 00347 00348 } // namespace moab 00349 00350 #endif // MESH_TAG_HPP
