MOAB: Mesh Oriented datABase
(version 5.3.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2010 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2010) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file MeshUtil.hpp 00028 * \author Jason Kraftcheck 00029 */ 00030 00031 #ifndef MSQ_MESH_UTIL_HPP 00032 #define MSQ_MESH_UTIL_HPP 00033 00034 #include "Mesquite.hpp" 00035 00036 namespace MBMesquite 00037 { 00038 00039 class Mesh; 00040 class MsqError; 00041 class SimpleStats; 00042 class Settings; 00043 class PatchData; 00044 00045 /**\brief Miscelanions operations performed on an entire \c Mesh 00046 * without the conveinience of a \c PatchData. 00047 */ 00048 class MeshUtil 00049 { 00050 private: 00051 Mesh* myMesh; 00052 Settings* mySettings; 00053 PatchData* globalPatch; 00054 00055 protected: 00056 PatchData* get_global_patch( MsqError& err ); 00057 00058 public: 00059 MeshUtil( Mesh* mesh, Settings* settings = 0 ) : myMesh( mesh ), mySettings( settings ), globalPatch( 0 ) {} 00060 00061 ~MeshUtil(); 00062 00063 /**\brief Calcluate statistics for mesh edge lengths 00064 */ 00065 void edge_length_distribution( SimpleStats& result, MsqError& err ); 00066 00067 void lambda_distribution( SimpleStats& result, MsqError& err ); 00068 00069 /**\brief Given two meshes, check if they are different, return true if they are. 00070 * 00071 *\param mesh1 the first mesh to compare 00072 *\param mesh2 the second mesh to compare 00073 *\param tol a relative tolerance for coordinates 00074 *\param do_print flag for printing differences 00075 * 00076 * \NOTE Only basic mesh properties are checked, number of vertices & elements, 00077 * element connectivity, and coordinates (within the given relative tolerance). 00078 */ 00079 static bool meshes_are_different( Mesh& mesh1, Mesh& mesh2, MsqError& err, double tol = 1.e-5, 00080 bool do_print = false ); 00081 }; 00082 00083 } // namespace MBMesquite 00084 00085 #endif
