MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 ***************************************************************** */ 00024 00025 #ifndef MSQ_INTERRUPT_HPP 00026 #define MSQ_INTERRUPT_HPP 00027 00028 #include "MsqError.hpp" 00029 00030 namespace MBMesquite 00031 { 00032 00033 /** \brief Class to watch for user-interrupt (SIGINT, ctrl-C) 00034 * 00035 * A class to watch for SIGINT. 00036 * 00037 * Creating an instance of the class ensures that the Mesquite 00038 * handler for SIGINT is registered. When all instances are 00039 * destroyed, the Mesquite handler is removed. The intent is 00040 * that each interruptable API declare an instance on the stack. 00041 * This way the handler is automatically unregistered when the 00042 * API returns. For example: 00043 * <code> 00044 * void my_api( MsqError& err ) 00045 * { 00046 * MsqInterrupt interrupt; 00047 * ... //do stuff 00048 * return; 00049 * } 00050 * </code> 00051 */ 00052 class MsqInterrupt 00053 { 00054 public: 00055 /**\brief Disable Mesquite's SIGINT handler */ 00056 static void disable( MsqError& err ); 00057 /**\brief Allow Mesquite to register a SIGINT handler */ 00058 static void allow( MsqError& err ); 00059 /**\brief Force Mesquite to register SIGINT handler */ 00060 static void enable( MsqError& err ); 00061 00062 /**\brief Check if an interrupt was seen */ 00063 static bool interrupt() 00064 { 00065 return sawInterrupt; 00066 } 00067 /**\brief Clear the interrupt flag */ 00068 static void clear() 00069 { 00070 sawInterrupt = false; 00071 } 00072 /**\brief Set the interrupt flag */ 00073 static void set_interrupt() 00074 { 00075 sawInterrupt = true; 00076 } 00077 00078 /** Constructor, increment instance count. If 00079 * instance count was zero, register SIGINT handler */ 00080 MsqInterrupt(); 00081 /** Constructor, decrement instance count. If 00082 * instance count goes to zero, remove SIGINT handler */ 00083 ~MsqInterrupt(); 00084 00085 static void set_handler(); 00086 00087 private: 00088 enum InterruptMode 00089 { 00090 CATCH, 00091 IGNORE, 00092 AUTO 00093 }; 00094 00095 static InterruptMode interruptMode; 00096 static unsigned instanceCount; 00097 static bool sawInterrupt; 00098 00099 // Don't allow any of this stuff (make them private) 00100 void* operator new( size_t size ); 00101 MsqInterrupt( const MsqInterrupt& ); 00102 MsqInterrupt& operator=( const MsqInterrupt& ); 00103 }; 00104 } // namespace MBMesquite 00105 00106 #endif
