MOAB: Mesh Oriented datABase
(version 5.3.1)
Class to watch for user-interrupt (SIGINT, ctrl-C) More...
#include <MsqInterrupt.hpp>
Public Member Functions | |
MsqInterrupt () | |
~MsqInterrupt () | |
Static Public Member Functions | |
static void | disable (MsqError &err) |
Disable Mesquite's SIGINT handler. | |
static void | allow (MsqError &err) |
Allow Mesquite to register a SIGINT handler. | |
static void | enable (MsqError &err) |
Force Mesquite to register SIGINT handler. | |
static bool | interrupt () |
Check if an interrupt was seen. | |
static void | clear () |
Clear the interrupt flag. | |
static void | set_interrupt () |
Set the interrupt flag. | |
static void | set_handler () |
Private Types | |
enum | InterruptMode { CATCH, IGNORE, AUTO } |
Private Member Functions | |
void * | operator new (size_t size) |
MsqInterrupt (const MsqInterrupt &) | |
MsqInterrupt & | operator= (const MsqInterrupt &) |
Static Private Attributes | |
static InterruptMode | interruptMode = MsqInterrupt::AUTO |
static unsigned | instanceCount = 0 |
static bool | sawInterrupt = false |
A class to watch for SIGINT.
Creating an instance of the class ensures that the Mesquite handler for SIGINT is registered. When all instances are destroyed, the Mesquite handler is removed. The intent is that each interruptable API declare an instance on the stack. This way the handler is automatically unregistered when the API returns. For example: void my_api( MsqError& err ) { MsqInterrupt interrupt; ... //do stuff return; }
Definition at line 52 of file MsqInterrupt.hpp.
enum MBMesquite::MsqInterrupt::InterruptMode [private] |
Definition at line 88 of file MsqInterrupt.hpp.
Constructor, increment instance count. If instance count was zero, register SIGINT handler
Definition at line 82 of file MsqInterrupt.cpp.
References IGNORE, instanceCount, interruptMode, sawInterrupt, and set_handler().
{ if( !instanceCount ) { if( IGNORE != interruptMode ) set_handler(); sawInterrupt = false; } ++instanceCount; }
Constructor, decrement instance count. If instance count goes to zero, remove SIGINT handler
Definition at line 92 of file MsqInterrupt.cpp.
References instanceCount, MBMesquite::oldHandler, and sawInterrupt.
{ if( !--instanceCount && SIG_ERR != oldHandler ) { signal( SIGINT, oldHandler ); oldHandler = SIG_ERR; } sawInterrupt = false; }
MBMesquite::MsqInterrupt::MsqInterrupt | ( | const MsqInterrupt & | ) | [private] |
void MBMesquite::MsqInterrupt::allow | ( | MsqError & | err | ) | [static] |
Definition at line 75 of file MsqInterrupt.cpp.
References AUTO, instanceCount, interruptMode, MBMesquite::oldHandler, sawInterrupt, and set_handler().
{ sawInterrupt = false; interruptMode = AUTO; if( instanceCount && SIG_ERR == oldHandler ) set_handler(); }
static void MBMesquite::MsqInterrupt::clear | ( | ) | [inline, static] |
Definition at line 68 of file MsqInterrupt.hpp.
References sawInterrupt.
{ sawInterrupt = false; }
void MBMesquite::MsqInterrupt::disable | ( | MsqError & | err | ) | [static] |
Definition at line 57 of file MsqInterrupt.cpp.
References IGNORE, instanceCount, interruptMode, MBMesquite::oldHandler, and sawInterrupt.
{ interruptMode = IGNORE; if( instanceCount && SIG_ERR != oldHandler ) { signal( SIGINT, oldHandler ); oldHandler = SIG_ERR; } sawInterrupt = false; }
void MBMesquite::MsqInterrupt::enable | ( | MsqError & | err | ) | [static] |
Definition at line 68 of file MsqInterrupt.cpp.
References CATCH, instanceCount, interruptMode, MBMesquite::oldHandler, sawInterrupt, and set_handler().
{ sawInterrupt = false; interruptMode = CATCH; if( instanceCount && SIG_ERR == oldHandler ) set_handler(); }
static bool MBMesquite::MsqInterrupt::interrupt | ( | ) | [inline, static] |
Definition at line 63 of file MsqInterrupt.hpp.
Referenced by MBMesquite::InstructionQueue::run_common(), and MBMesquite::TerminationCriterion::terminate().
{ return sawInterrupt; }
void* MBMesquite::MsqInterrupt::operator new | ( | size_t | size | ) | [private] |
MsqInterrupt& MBMesquite::MsqInterrupt::operator= | ( | const MsqInterrupt & | ) | [private] |
void MBMesquite::MsqInterrupt::set_handler | ( | ) | [static] |
Definition at line 47 of file MsqInterrupt.cpp.
References AUTO, interruptMode, MBMesquite::msq_sigint_handler(), and MBMesquite::oldHandler.
Referenced by allow(), enable(), MBMesquite::msq_sigint_handler(), and MsqInterrupt().
{ oldHandler = signal( SIGINT, &msq_sigint_handler ); if( MsqInterrupt::interruptMode == MsqInterrupt::AUTO && ( oldHandler == SIG_DFL || oldHandler == SIG_IGN ) ) { signal( SIGINT, oldHandler ); oldHandler = SIG_ERR; } }
static void MBMesquite::MsqInterrupt::set_interrupt | ( | ) | [inline, static] |
Definition at line 73 of file MsqInterrupt.hpp.
Referenced by MBMesquite::msq_sigint_handler().
{ sawInterrupt = true; }
unsigned MBMesquite::MsqInterrupt::instanceCount = 0 [static, private] |
Definition at line 96 of file MsqInterrupt.hpp.
Referenced by allow(), disable(), enable(), MsqInterrupt(), and ~MsqInterrupt().
MsqInterrupt::InterruptMode MBMesquite::MsqInterrupt::interruptMode = MsqInterrupt::AUTO [static, private] |
Definition at line 95 of file MsqInterrupt.hpp.
Referenced by allow(), disable(), enable(), MsqInterrupt(), and set_handler().
bool MBMesquite::MsqInterrupt::sawInterrupt = false [static, private] |
Definition at line 97 of file MsqInterrupt.hpp.
Referenced by allow(), clear(), disable(), enable(), interrupt(), MsqInterrupt(), set_interrupt(), and ~MsqInterrupt().
